Просмотров в теме 3566   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 18.08.2012, 17:48 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of A123 18650 1100mAh (Yellow)
This is a battery that can deliver very high amount of power!
Official specifications:
  • Nominal Capacity & Voltage: 1.1Ah, 3.3v
  • Recommended standard charge method: 1.5A to 3.6v CCCV, 45min
  • Recommended fast charge current: 5A to 3.6v CCCV, 15min
  • Max continuous discharge: 30A
  • Pulse discharge at 10sec: 65A
  • Cycle life at 10C discharge, 100% DOD: Over 1,000 cycles
  • Recommended charge/cutoff voltage: 3.5v to 2v
  • Operating temp: -30 ~ +60degC
  • Cell Weight: 39g
This battery has a lower voltage than the usual LiCoO2 batteries and also much lower capacity.
There is not much capacity, but the capacity is available at very high currents.
The battery is able to deliver 30A, but only for two minutes!
The battery has no protection and I discharged it before I was finished with this test.
I only uses a 1A charger current, the battery can be fast charged with a 4A current.
Conclusion
This battery uses a "safe" chemistry, but this does not make the battery completely safe due to the high currents it can deliver.
This is a very interesting battery for some applications, but due to the low voltage it is not really good for flashlights (leds need a lower Vf) and who would want a small super bright light that only works for two minutes (This is probably the wrong place to say that)?
This battery can only rate a as very good.
Notes and links
dead_skif (18.08.2012), MOHAPX (19.08.2012)
Время генерации страницы 0.07804 секунды с 15 запросами
