Просмотров в теме 4145   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 1
Старый 15.08.2012, 23:07 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Keeppower 26650 4000mAh (Black)
Official specifications:
  • 26650 4000mAh Protected Rechargeable Battery
  • Min Capacity: 4000mAh
  • Typical Capacity: 4100mAh
  • Normal Voltage: 3.7V
  • Standard charge current 2000mA
  • In Built Safety Circuitry
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.7 volts nominal voltage
The battery does easily meet the specified capacity.
Note: The internal resistance is calculated from 6 to 10 ampere.
Lots of capacity, but the batteries has difference capacity especially at high loads.
The protection trips at a very high value, as can be seen the output of the batteries has started to go down, before the protection trips.
Conclusion
This is the first keeppower battery I have seen, where I am disappointed with it, the performance is good, but I do not like the difference between the cells and the very high trip point of the over current protection.
Notes and links
Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them.
The batteries was supplied by Keeppower for review.
rezhik (06.09.2012), superstitious (20.12.2012)
Время генерации страницы 0.08728 секунды с 15 запросами
