7163
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Keeppower 18650 3400mAh (Black)
![]() Official specifications:
![]() This is the latest cells from Panasonic with the highest capacity. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. ![]() ![]() ![]() ![]() ![]() These batteries are good at both low and higher current. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion This battery has higher capacity and better high current capacity than its predecessor (3100mAh/NCR18650A). With the added protection from Keeppower it is a very good battery. Notes and links Keeppower is a OEM manufacturer, i.e. many of the batteries they produce is sold with other names on them. The batteries was supplied by Keeppower for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
