7595
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
AW IMR 18650 2000mAh (Red)
![]() Official specifications:
![]() The most interesting parameter with these batteries is the 10A maximum discharge rate. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. ![]() ![]() ![]() ![]() ![]() The discharge curves at lower loads are not very interesting, many other batteries can do better, but the 5-10A range is above what most LiIon batteries can handle. It cannot match the old AW 1600mAh battery for voltage, but has better capacity. ![]() ![]() Notice the short runtime at 10A load, it is only slightly above 10 minutes. ![]() ![]() ![]() ![]() Conclusion The battery is good battery, but with only 2000mAh it is best used in application that need 5A to 10A current draw and where capacity is more important than maximum voltage. Notes and links How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Это где же можно купить такое счастье? может, знает кто?
Желаю странного
Регистрация: 11.03.2011 Последняя активность: 18.09.2025 09:13
sasha6464, lighthound.com, oveready.com ...
А у малиновой девочки взгляд откровенней, чем сталь клинка. Мои:Surefire C2 x2, M6LT, EB2T-A-TAN, U2, E2DL, L1, L2, Z2L, HS1-B-SL, G2X Pro x2, G2-YL, E1L, E1E-BK, E2E, M951, M952; FiveMega M4 z46, Leef P6T LF HO-M6R; Solarforce L2m, L2X, L4X x3; PeakLogan 17500/AA 219; StreamLight Sidewinder II; Fenix LD10; EagleTac G25C2, Olight smini cu; Convoy M1; YLP Panda2CRI, Enot500 x2, Swift |
sasha6464 (09.06.2012)
Сказал(а) спасибо: 12
Сказал(а) спасибо: 414
Shadowww,
Panasonic NCR18650A внутри
Регистрация: 06.01.2012 Последняя активность: 21.07.2012 16:05
Сказал(а) спасибо: 28
извиняюсь
panasonic CGR18650CH |
это в orbtronic 3100 стоят NCR18650A
Я так понял, самые мощные из IMR - Orbtronic 2250mAh?
А такое счастье где есть? (сорри за офтоп) |
