Просмотров в теме 4176   Ответов в теме 0   Подписчиков на тему 0   Добавили в закладки 0
Старый 04.06.2012, 10:20 Автор темы   1
Аватар для Bigmac_79
Последняя активность: 21.04.2015 12:00
Поблагодарили: 42 раз(а) в 22 сообщениях
По умолчанию Object/Subject Review: Nitefighter F30C
Nitefighter is a new brand of flashlights coming to the market, and it looks like the F30C is going to be the first model available. Nitefighter flashlights are manufactured by Lumingear Lighting Co., which from what I understand has been dealing in parts in the illumination industry since 2004, and has recently moved to producing their own flashlight brand. The F30C is a multi-mode thrower with several battery options, that hints at some good things coming from Nitefighter in the future.
Thanks to Andy at Lumingear for supplying the F30C for review.
I’ll be reviewing the F30C in two sections: first, I’ll discuss the light objectively (the facts about the light itself), then I’ll discuss the light subjectively (my impressions about the light's performance when used for specific applications). This light seems to be designed to fulfill the role of a small- to mid-sized thrower, so I'll be reviewing it as such. If you have any other specific applications you'd like the light tested for, let me know and I'll see what I can do.
Objective
Here are the specs on the F30C:
from nitefighter.com and the CPFMP F30C Thread:
Features
-Cree XM-L T6 LED-Up to 750lumens;
-Specially designed for Military, Law Enforcement, Self-defense, Hunting,
Search & Rescue and Outdoor activities;
-Uses two CR123A batteries or one 18650 rechargeable Battery;
-Uses three CR123A batteries (with extension tube);
-Two sets of modes, selected by turning the head;
General mode: High- Medium-Low-SOS(Hidden)
Tactical mode: Strobe- Turbo
-Activate SOS function by click the tail button three times within 1.5 seconds in
any general lighting mode;
-Quick Flashing Frequency for Self-Defense;
-Smooth reflector for long beam;
-Ex-tube design for long runtime;
-Aero grade aluminium alloy construction;
-Anti-roll, slip-resistant body design;
-Tactical tail switch with momentary-on function;
-Stainless clip for easy attachment;
-Stainless steel strike bezel adds protection capabilities
-Toughened ultra-clear glass lens with anti-reflective coating;
-Premium Type III hard-anodized anti-abrasive finish;
-Waterproof to IPX-8 standard
Operation
-Press tail switch for ON/OFF;
-Tightening the head to select general model;
-Loose the head to select tactical model;
Specification
-LED: Cree XM-L T6 cool white;
-Max Output: 750 lumens;
-Battery Type: 2xCR123A lithium batteries / 1x18650 Li-on battery / 2x16340 Li-on batteries
3xCR123A lithium batteries (with extension tube)
-Run Time: High -2.5Hrs
Medium-5Hrs
Low- 50Hrs, 75Hrs with ex-tube
Strobe- 2.5Hrs
SOS - 15Hrs
-Color: Grey
-Material:Aero grade aluminium alloy
-Finish: Type III hard anodizing
-Size: Ø25.4mm x 220mm, with ex-tube length: 259mm
-Weight: 210g(w/o battery and ex-tube)
-Standard Accessories: 1xHolster, 1xLanyard, 1xClip, 2x Spare o-rings,1xEx-tube
MRSP:$89
Packaging
The F30C came packaged in this cardboard box with a sticker on the front. The letters "JM" are in marker and probably won't be on the production version, they are my initials .
Inside you find the light in a nice cardboard cradle, with all the accessories stuffed inside the holster.
Here's all the included accessories: extension tube, holster, lanyard, clip, and two o-rings. My review sample also included a rough draft of a user's manual printed on a piece of 8.5x11 plain white pater, which I believe will be updated to something more polished in the production version.
Construction Quality
The F30C feels like it's construction quality is on par with industry standard. Without the extension tube, it can run off 1x18650, 2x16340 or 2xCR123. With the extension tube, it uses 3xCR123 only.
Correction: as jh333233 has pointed out to me, with the extender the F30C *should* be able to use 2x17500 or 2x18500 lithium ion cells, which would give you similar output as 2x16340, but with more run time. I have not tested this, as I don't have any lions that size.
We'll take a look at the outside of the light, from front to back.
The F30C uses a Cree XM-L emitter, T6 bin. The LED is well centered in a smooth reflector, which optimizes the throw of the light, but tends to add rings or other artifacts to the beam. It has a stainless steel, crenelated bezel with some indentations cut out of the inner slant. The crenelations are useful for seeing if the light is on when it's standing head down, or for striking an enemy. The indentations cut along the inside are purely for style.
The body has two flats cut into it, one on each side. One side has the Nitefighter branding, the other side has the model number. The lettering is clearly printed and professional-looking.
The F30C has a cutout-style tail cap, which allows easy access to the switch (from two sides) while still making the light able to tail stand. You can also see that the tail cap has one long hole cut out of one side, and two small holes plus a notch cut out out of the other side. This allows for a large variety of ways to use a lanyard, either the one included or your own style, while still retaining the ability to tail stand if you desire it. Also, the main section of the tail has several large grooves cut into it, giving very good grip on the tail end.
The switch is a forward-clicky style switch, which means that you can press it half way for momentary on, or press it all the way and it will click into a constant-on position.
As mentioned, the F30C can tail stand. However, it's not a completely stable tail stand, because of the sides cut out, so you'll need a very flat surface, and be careful not to bump it.
Now it's time to take it apart.
As you can see, the crenelated bezel is removable, and other than that, nothing else comes apart easily without the use of tools, except at the separation between the head, body, and tail. The F30C uses double o-rings for extra certainty of protection against water, and claims water-resistance to IPX-8 standard (protected from immersion in water beyond 1 meter, not tested for resistance to dust/particles). You can see the results of my submersion testing in the "Performance" section.
Not pictured above: 16340 extender
The crenelated bezel can be unscrewed from the head without too much effort. This leaves the possibility of changing out bezels if desired (for example, a "non-agressive" bezel).
The threads between the head and body are not anodized, because they are part of the electrical circuit, and because of the user interface (which includes loosening or tightening the head), need to make electrical contact even when the head is not tightened fully. A spring in the head serves as the contact for the positive battery terminal, which protects the battery during impacts, and also ensures the use of either button-top or flat-top cells.
All of the body threads are thick and square-cut, which is generally the most robust design, and make screwing or unscrewing the parts easiest. The threads at the read of the body are anodized on the outside, and un-anodized on the rear face, because the tail only needs electrical connection when fully tightened. Anodizing threads helps them last longer, so, if changing batteries frequently, I would advise using removing the tail from the body, instead of the head. Also, you can see here that the walls of the body are respectably thick.
The threads inside the tail cap are anodized, and the base of the inside is bare to make electrical connection with the rear of the body. A spring is used for the negative terminal, which again helps protect the battery during impact.
When an 18650 battery is inserted, it will stick out just a few millimeters (especially if it's closer to actually being an 18700, like my Callie's Kustoms cells).
The F30C includes a clip as a standard accessory, which clips onto the side of the light with a moderate amount of force.
The clip is angled in such a way as to make contact with the body, which should help it hold the light firmly wherever you clip it.
A holster is also a standard accessory, with the Nitefighter brand name printed on a small tag on the side. The holster has a velcro belt strap and a velcro head flap. The F30C fits in the holster head up, but not head down. The F30C can be put into the holster while the extension tube is attached, but I was unable to get the cover flap to close properly in this situation, and the head sticks out significantly further.
Dimensions
Length: 156.3mm (no extender)
Length: ???.?mm (extended)
Head Diameter: 46.9mm
Bo
dy Diameter: 25.3mm
Tail Cap Diameter: 28.1mm
Body Inner Diameter: 19.1mm
User Interface
The UI of the F30C is divided into two states: head tight or head loose. Both have mode memory, so when you turn the light off, next time you turn the light on it will come on in whatever mode you used last. Mode memory also persists between switching between the General and Tactical UI. IE, if you set the F30C to medium on the General UI, then loosen the head and set the Tactical UI to strobe, you can tighten the head and get medium again, then loosen the head again to go back to strobe. SOS mode is "hidden" and excluded from mode memory, so if you turn on SOS mode, then turn the light off, it will come back on in (last used mode or high mode?). To advance from one mode to the next in a sequence, you turn the light off then back on within about 1.5 seconds from entering the mode (essentially a series of clicks turning the light on and off rapidly). You can do this either by the momentary on or constant on function of the tail cap (wither full presses or half presses).
The SOS mode is a little complicated. No matter what mode you start in, it will activate the 4th time you change the mode. Leaving the light on in one mode for a long time will not reset the count, so if you change the mode twice, use the light for a while, then change it two more, it will be in SOS mode. Leaving the light off for a long time will reset the count, so if you change the mode twice, turn the light off and leave it off for a while, then change it two more, it will not be in SOS mode. SOS mode is not memorized. After SOS mode, the light always goes back to High.
UI Summary:
General UI (Head Tight)
High -> Medium -> Low
(No matter where you start, 4 mode is) -> SOS -> (sequence restarts at High)
(SOS is not memorized. While counting to 4, leaving the light off resets the count, leaving the light on does not)
Tactical UI (Head Loose)
Turbo -> Strobe
Here's a video of the UI in action:
Action Shots
Light in Hand (no extender)
Light in Hand (extended)
White Wall
(ISO 100, f/3.3, 1/15")
Turbo, High, Medium, Low
BeamSlice
(ISO 100, f/3.3, 1/10")
As you can see here, the design of the reflector/emitter together focuses the warmer tones of the light towards the center of the beam, and bends the cooler blues and purples to the outside.
Indoor Shots
(ISO 100, f/3.3, 1")
Control, Turbo, High, Medium, Low
Outdoor Shots
Mid-Range Shots (control first)
(ISO 100, f/3.3, 5")
Throw Shots (control first)
Fog Shot
Performance
PWM: I can find no visible or audible trace of pulse-width modulation on any mode.
Reverse Polarity Protection: I can find no evidence to suggest reverse polarity protection, make sure to insert all batteries with the positive terminal facing the head and the negative terminal facing the tail.
Over Discharge Protection: I can find no evidence to suggest built-in over discharge protection. When using lithium ion rechargeable cells, I recommend only using ICR protected cells. If you decide to use IMR unprotected cells, be sure to charge them frequently.
Impact: I dropped the F30C several times from 1-2 meters, and I find no damage to appearance or operation of the light.
Submersion: I put the light under about a foot of water and turned it on/off, switched modes by the tail cap button, and switched modes but loosening/tightening the head (slightly). After taking it back out, I could find no evidence that water penetrated any area of the light.
Heat: After half an hour of constant Turbo, the F30C is warm to the touch, but by no means hot. I believe the heat sinking and dissipation of the F30C are more than adequate to handle the heat generated.
Current Draw
These measurements were taken while using one fresh AW ICR protected 18650.
Low: .024A
Medium: 1.15A
High: 1.61A
Turbo: 1.75A
Runtime
Note: The vertical axis of these charts represents a relative brightness measurement using a home made light box. The horizontal axis is time in hours:minutes:seconds. Runtimes are stated in hours:minutes:seconds. Note: these graphs may have been truncated to show the relevant portion of the data. All tests were done using fresh, protected ICR cells (AW 750mAh 16340's and Callie's Kustoms 3100mAh 18650's).
All Modes
Turbo
1x18650 Callie's Kustoms
-Time until Stepdown: 0:09:14
-Time to 50%: 1:43:48
-Full Runtime:8:33:29
2x16340 AW
-Time until Stepdown 0:09:18
-Time to 50%: n/a
-Full Runtime: 0:34:43
High
-Time to 50%: 2:43:12
-Full Runtime: 8:45:21
2x16340 AW
-Time to 50%: n/a
-Full Runtime: 37:08
Medium
-Time to 50%: 4:52:10
-Full Runtime: 13:08:13
2x16340 AW
-Time to 50%: n/a
-Full Runtime: 0:58:17
Low
-Time to 50%: 66:36:26
-Full Runtime: 190:41:47
2x16340 AW
-Time to 50%: 7:11:13
-Full Runtime: 7:18:53
Subjective Review
General
Quick break down:
+Great throw, tight spot
+Innovative tail cap design
+Quick access to Turbo mode
+Great throw
+Warmer tones concentrated at the hotspot, cooler tones thrown to the edge
+Clip attaches firmly
+Nice style, especially the crenelated bezel
+Automatic stepdown from Turbo mode to prevent overheating
+Good regulation with 2x16340
+Good mode spacing
-SOS mode is a huge pain
-Slightly too large for pocket carry
-No rechageables with the extender
-Poor regulation with 1x18650
The F30C has been a lot of fun to use, I can see that the folks at Nitefighter have put a lot of thought into this light. The light is very comfortable to use, and looks very stylish. The construction of the F30C is great, I appreciate the springs at both battery terminals, and I really like the design of the tail cap.
The UI is good overall. I like the ability to loosen the head to get to Turbo quickly. I almost never have a use for Strobe, but I can use the mode memory to ensure that I always get Turbo when the head is loose. I have one complaint about the UI: the SOS mode is a huge pain. It comes up often when trying to cycle through the general H-M-L sequence, and I have no use for SOS mode. I'm going to recommend to Nitefighter that they either give it a better hiding place, or get rid of it all together.
Otherwise, I have no real complaints about the F30C. It's a little larger than I like for pocket carry (and I have big pockets), but it comes with a perfectly good holster. The only battery configuration you can use with the extender tube is 3xCR123, and I would suggest an 18650 sized extender would be more useful (the output of 2x16340 with a much better run time). I just don't use primaries very often.
I really like the throw on the F30C. It's got a great tight hotspot, with smooth transition into an adequate amount of spill. Previously I kept the SWM T20CS in my bag for a compact thrower, but the F30C gives it a run for it's money.
The F30C has a great feature: automatic thermal stepdown. On Turbo mode, the F30C will automatically step down to High mode after a time, in order to keep the emitter from overheating.
I like the spacing on the modes, the Low is useful if you need to use the light indoors/at close range. The Medium, High, and Turbo seem too closely spaced when you're inside, but outside and at long range they show themselves to be appropriately spaced.
Overall, the F30C is very well put together. In my time using it, I've found it's not really one I like to use inside because of the intense hotspot (it makes it hard to see anything else) but it does wonderful at mid to long range outdoors. I like having the lower modes available, but because this is mostly a long range light, I usually leave it on High, switching to Turbo occasionally for a little extra boost.
Thrower
I don't have too much to say here, other than this is one of the best compact throwers I've seen without an aspheric lens. There are lights with larger reflectors that can throw farther than this one, but if you want a compact one, the F30C is a good bet. As you can see in the beam shots, most of the light is concentrated in the hot spot, with a smooth transition into a little bit of spill. I do like have a bit of spill light, even on a dedicated thrower, so that I can still see the area around me, even when I'm focusing on something far away. As I mentioned before though, I'd rather have the extension tube be 18650 sized, so that when I'm going to be using the light for a while I can increase have increased run times at higher brightness. I just don't have much use for primary (non-rechargeable cells) except as an emergency backup, and as it is, the only battery configuration when using the extender is 3xCR123.
Long Term Impressions
I'll fill this part in after carrying the light for a while. If nothing get's added here, either I find nothing else worth noting about the light, or I end up not using it often.
Bigmac_79 вне форума   Ответить с цитированием Вверх
Andr(Andrey) (24.12.2013)
Время генерации страницы 0.19343 секунды с 15 запросами
