14979
22
![]() Регистрация: 28.07.2011 Последняя активность: 10.12.2014 12:07
Записей в дневнике: 1 Сказал(а) спасибо: 1
Поблагодарили: 17 раз(а) в 7 сообщениях
New XENO torch released! Model No. XENO S3A--the slimmest 18650 flashlight in the world
with hidden functional output modes-Strobe-SOS-Local Beacon with detachable enhanced 3D 360 degree encircled clip, with stainless steel strike bezel on tail ![]() ![]() ![]() ![]() ![]() Brief spec. Model No.: XENO S3A Material: Type-III Hard-anodized Al-alloy, Gun gray Reflector: OP Clip: detachable 3D clip (with arched design on the top of clip to enhance the elasticity, with 40 degree tilt at tail, easy for people to load/remove torch from belt, cap edge,etc.) Tail-cap strike bezel: stainless steel( can stand up at tail) Output: Normal output modes: High-low-ultra low (High mode is the default mode after 3 seconds light-off) Hidden functional modes: the sequence:Strobe-SOS-Local Beacon (half-press more than 3 times on any normal mode, u will enter into hidden functional modes) Max output: 300lms(Cree XM-L 1B U2)/1000mA Max burning time: 100hours Switch: reverse clicky switch Battery: protected 18650 Li-ion battery*1 or 18650 Li-ion cell*1, or CR123A*2 Size: Diameter 21.5, length: 111mm Net Weight: 50g Standard spare parts: O-rings*2 and Switch*1 The advantages of this torch: 1. The slimmest 18650 flashlight in the world, maybe it's the shortest 18650 with reverse switch. 2. Quality&Elegant appearance with quality parts built-in. 3. detachable 3D clip (it's unique, quality, enhanced, powerful, beautiful, comfortable clip u never found in market. XENO costs 1 year to design&re-design&revise&sample&re-sample a quality clip, it's a masterpiece of XENO! must provide good experience to any people, it's worthy for u to wait.) 3. 3 types of Color temp. optional: cool white, neutral white, warm white 4. Hidden Functional output modes XENO S3A is a compact&small size EDC torch, with quality&elegant design, it fits wide range of group buys. Compared repeated-buy, dissatisfied-design bargain, Considering long-time usage, XENO S3A must be winner in price, quality,design. |
Регистрация: 08.03.2011 Последняя активность: Сегодня 20:22
Записей в дневнике: 4 Сказал(а) спасибо: 17714
Поблагодарили: 40003 раз(а) в 14795 сообщениях
E03 переполз на 18650 и обзавелся клипсой
![]() Но вот это High-low-ultra low (High mode is the default mode after 3 seconds light-off) для EDC мягко говоря неудобно
Спасибо. Т.е. старт всегда с максимума. Печаль.
Регистрация: 13.05.2012 Последняя активность: 01.12.2025 10:59
Сказал(а) спасибо: 61
На офсайте появилась версия V2 http://xenoled.com/en/Flash... c накаткой на корпусе, какие еще отличия от v1 и где можно купить V2?
Hi, Sir. please check following info:
The main differences between S3A V2 and S3A V1: 1. XENO S3A V2 with knurling on body to enhance the grip, V1 without it. 2. The squence of normal output modes changed to Low-Ultra low-High in S3A V2, the S3A V1 with the squence High-Low-Ultra low. 3. The logo slightly changed on XENO S3A V2, it looks more clear and succinct than V1's . [IMG] [/IMG]Цитата:
a1936911620 (25.07.2012)
Регистрация: 29.12.2010 Последняя активность: 14.01.2025 21:56
Сказал(а) спасибо: 343
скорее лучше старт с минимума, между средним и максимальным разницы почти нет и в темноте гарантируется ослепление самого себя.
Выявленные недостатки: 1. клипсу надо из металла на 0.2-0.4 мм толще, слишком мягкая. Идеал клипсы-fenix pd32 2. нужен гладкий отражатель 3. если укоротить корпус на 5мм для питания только от незащищенных 18650 то это будет самый компактный фонарик в мире после H600 to XENOled: 1. where i can buy V2? from hkequipment.net i got V1 2. the pocket clip must be slightly thicker 3. SMO reflector give the best throughput. The Anti-Reflection coatings on both sides of lens adding approx. 3-5% of light output, but smooth reflector addind 10% light output 4. the output modes must be changes Ultra low-Low-High thanks |
Желаю странного
Регистрация: 11.03.2011 Последняя активность: 18.09.2025 09:13
Но зачем?
А у малиновой девочки взгляд откровенней, чем сталь клинка. Мои:Surefire C2 x2, M6LT, EB2T-A-TAN, U2, E2DL, L1, L2, Z2L, HS1-B-SL, G2X Pro x2, G2-YL, E1L, E1E-BK, E2E, M951, M952; FiveMega M4 z46, Leef P6T LF HO-M6R; Solarforce L2m, L2X, L4X x3; PeakLogan 17500/AA 219; StreamLight Sidewinder II; Fenix LD10; EagleTac G25C2, Olight smini cu; Convoy M1; YLP Panda2CRI, Enot500 x2, Swift |
Thank u!
Регистрация: 28.02.2011 Последняя активность: 18.11.2016 15:55
Сказал(а) спасибо: 19
Поблагодарили: 65 раз(а) в 31 сообщениях
И после Nitecore EC2, который в длину также всего 99 mm. http://www.nitecore.co.uk/e... |
Length: 99mm Head Diameter: 25.4mm Tail Diameter: 24mm Weight: 59g (without battery)
Hello there |
Желаю странного
Он намекает, что сабж дофига тоньше найткорки. |
17
В том и дело, что не дофига, около 3мм разница всего, учитывая разницу в длине это хороший показатель.
По сути это единственное достоинство данного фонаря, которое никто даже не пытается оспорить. ))
XENO S3A:
20
Hi
Thanks for your attention on XENO torches. please let me summarize the difference below: XENO S3A *]Light output (U2): 300lms (Max Output is 1000mA, no problem for us to set a higher current to get higher output, however, we emphasize on reliability/stability use of XENO torches, emphasize on good user experience(higher max current will lead to hotter surface, maybe people can't afford it for long time 2hours+), so we set max current at 1000mA.)[*]Runtime: 2.5hrs High (on High Mode with high output 300lms), 100hrs low (OTF20lms/100hrs)[*]Beam Distance: 65M (head bezel dia. of S3A is 21.5mm, slimmer than EC2, so S3A is equipped with shallower reflector, get a shorter beam distance. )[*]Peak Beam Intensity: [B]1300cd [*]Impact Resistance: 1M [*]Water Resistance: IPX-7, 1M. (the rating of Impact resistance/water resistance must be measured by clients to determine what's the max. degree S3A can afford.. we always give XENO torches conservative data according to ANSI Standard) ) [*]Length: 111mm (S3A with reverse clicky switch on tailcap (this type switch will enhance the ability of drop of torches), and there have a stainless steel strike bezel on tailcap, it's useful for tactical defence, and beautiful as a decoration on S3A.) Nitecore EC2: Light output (XP-G): 320 lms (output 320lms on turbo mode with running time 3 minites, output 220lms on high mode) Runtime: 2+hrs (on high mode 220lms) 220hrs low (2 lumens on low mode) Beam Distance: 150M (with a larger head bezel dia. 25.4mm, can get longer beam distance) Peak Beam Intensity: 5650cd Impact Resistance: 1.5M Water Resistance: IPX-8, 2M. Length: 99mm (with electrical switch can shorten the length) Цитата:
