158971
254
32
Регистрация: 21.10.2011 Последняя активность: 17.11.2018 09:26
Сказал(а) спасибо: 80
• LED: Cree XM-L Neutral White (Norminal CCT 4200K) • User Selectable Levels: 3 main level (High, Medium and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of the High (H2) can be further configured to different brightness levels or strobes. • Light Output o High: H1 361Lm with 645Lm turbo in the first 3 min (2.3 hrs) or H2 146Lm (7 hrs) / 232Lm (4 hrs) /361Lm (2.4 hrs) / 4Hz Strobe o Medium: M1 56Lm (18 hrs) or M2 18Lm (50 hrs) o Low: L1 2.4Lm (280 hrs) or L2 0.09Lm (80 days) o Runtimes are tested using Panasonic NCR18650 (2900mAH) batteries. Light output are out the front (OTF) values. All levels are current regulated. • Operating Voltage Range: 2.7V - 4.2V • Battery: One 18650 size (up to 67mm long) 3.6/3.7V Li-ion rechargeable battery. Batteries are not included in the package. • Parasitic Drain: Negligible (equivalent to 12 years) • Beam Type o 80 degree spill o 12 degree hot spot • Dimensions o Head Diameter: 0.95 inch (24.2 mm) o Length: 3.9 inch (99 mm) • Weight o 1.4 oz (39 gram) • Features o Automatic stepping down from High to Medium, and from Medium to Low when the battery capacity is low o Builtin over-discharging protection with 2.7V cutoff o Electronic soft-touch switch o Smart user interface provides fast and easy access to all brightness levels o Precision machined unibody casing from premium grade Alcoa aluminum bar stock o Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing, providing unblocked thermal paths to most of the surface area. o Durable natural hard anodized finish (Type III Class I) o Ultra clear lens with anti-reflection coatings on both sides o Orange peel textured reflector o Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain o Waterproof to IPX8 (2 meters, 30 minutes) Упаковка зебры стандартная – рыжая картонка, которую сложно раздавить, и это очень радует с учетом нашей почты умеющей преподносить сюрпризы. Внутри лежит сам фонарь, мурзилка, налобное крепление и запасные уплотнительные резинки черного цвета. Беря в руки, ощущаешь легкость, она кажется невесомой для своих размеров (весы показали 35гр, а с аккумулятором панасоник 2900 – 80гр). Фонарь получился немного долговязый, на мой взгляд, идеальна по дизайну 31 модель. Цвет стандартный оливковый для всех зебр, только отличаются оттенком. Анодирование качественное равномерное, единственное тон крышки более темный, чем корпуса. На крышку нанесена насечка, которая намертво цепляется в пальцы. Корпус весь ребристый, необходимо для сегментной фиксации налобного крепления, также в глаза бросаются 2 проточки под клипсу (которой, кстати, нет в стандартной комплектации, а ведь могли бы положить). Тыльная сторона головы покрыта 8 ребрами, они ей очень нужны для рассеивания большого количества тепла в турбо режиме. Кнопка тугая четкая не допускающая случайных нажатий, покрыта бархатистой резной на которой, есть обозначение выключателя. Кнопка обрамлена металлической вставкой. Но при использовании фонаря на морозе будут проблемы с управление фонарем в толстых теплых перчатках. В последнее время на качество зебр появляется много нареканий, в данном образце проблем не замечено, диод установлен по центру, рефлектор слабо мятый, при свечении не обнаружено «полумесяцев» и прочей ереси. Секло имеет просветление, и под углом отдает фиолетовым отблеском. Внутри все чистенько, без пылинок. Плюсовой и минусовой контакты – пружины. Для разрыва питания, чтобы кнопка случайно не нажалась можно чуть открутить крышку. Что касается угла рассеивания – сделано 2 кадра: 1)от стекла 2) от предполагаемой оси диода. Свет очень приятный отдает домашней обстановкой, он больше нейтрально-теплый, чем нейтральный. Максимальный режим просто отличный, нейтрального света очень много, даже головой особо вертеть не надо за счет большого угла рассеивания. Налобное крепление удобное, правда, при использовании ярких режимов тепло буде передаться на лоб. Для любителей более равномерного света стоит обратить внимание на версию с приставкой «F» Стоит отметить, что аккумулятор без защиты гремит при тряске, а с защитой хоть он и влазит, но крышка закручивается туго. Если плата защиты тонкая, то ее может продавить пружина. Максимальный режим 645 люмен ограничен тремя минутами и происходит сброс на 361 люмен. За что люблю зебру, так это за честность, время работы от аккумулятора официальное совпадает с реальными значениями +- несколько минут. Люксы
бимы 4 сек 5,6 исо100 бб 5200(дс) сток Low Medium High сток Low Medium High 6 двойных кликов
а потом было это
Sunwayman Thrunite Fenix и прочие по выгодной цене [Исправлено: ssr, 14.05.2012 в 16:28] |
| Поблагодарили: 51 раз(а) |
по большому счету без разницы, куда что, вариантов много)
Очень часто сетуют на форуме на отсутствие клипсы у налобного фонаря. А она вообще для чего?
Просто у моего H30, который я покупал года 3 назад, в комплекте была клипса. До сих пор валяется где-то в шкафу, ни разу не пользовался. |
Регистрация: 06.01.2012 Последняя активность: 21.07.2012 16:05
Сказал(а) спасибо: 28
и полуфонарь
![]() чур ногами по лицу не бить |
не, я рос на классике, змей горыныч, соловей разбойник и прочие натуралистичные персонажи, никаких полупроводников в моем воспитании не замечено
Alex K, а откуда же такая ненависть к Зебрам? Вот к примеру мне не нравятся налобники от Феникса или горячо любимого Вами Спарка. Так я практически и не захожу в темы, которые им посвящены - мне они просто не интересны.
А из Вас зеброфобия так и хлыщет во всех темах, посвященных фонарям этой фирмы. |
расслабьтесь, ничего из меня не хлыщет. просто ваша реакция очень предсказуема, и прямо таки провоцирует.
а так мне пофиг в общем то. нравится полосатый ишак, ну и здорово! |
зебры как раз и интересны что они не совсем налобники, точнее не только, только налобник мне не нужет а вот фонарик с возможностью налобника эт да, поэтому и интересна клипса, к примеру на нагрудный карман
комуто может на ширинке нравится носить) коль флуд пошел |
Alex K, а также спасибо доброму человеку за возможность теста
пс в фонаре есть косяк! жду ответа производителя после разжуем тут зря заразу похвалил |
Flashlight surgeon
А я свое мнение оставлю.
В моих руках была почти вся линейка зебры, чем то сам лично пользовался, что то просто тестировал. Я достаточно активный ночной аутдорщик, частенько приходиться и работать с фонариком. Скажу, что пока для себя не вижу более актуальной модельки, чем H600w. Очень приятный свет по температуре, широкая засветка, много режимов и достаточный запас по яркости, компактность, вес, рантаймы, встроенная защита, необычный дизайн и вполне гуманный ценник.
| Поблагодарили: 4 раз(а) |
Регистрация: 10.10.2011 Последняя активность: 18.06.2025 18:15
Сказал(а) спасибо: 17
Мда... В последнее время что-то много нареканий на зебру. Ну раз запрос отправили производителю, значит что-то серьезное. Может намекнёте, а то ответа от них неделю ждать.
2. Поясните пожалуйста. Задавал вопрос владельцам на этом форуме, ответили что совершенно на свет не влияет. 3. Про кнопку тоже. Непривычно да, но пользоваться не мешает. Дело привычки. |
vitnikav (30.04.2012)
Gaffer
Конечно поворотный переключатель как на пецелях был бы удобнее, но и габариты бы выросли. Может когда нибудь добавят магнитное кольцо скраю? Это было бы крайне интересно, но больше похоже на фантастику( А вообще действительно одна из самых удобных моделей за свои деньги. Из рюкзака не выкладываю никогда.
20
2. В чем неудобство? На практике я не замечаю того, что он не посередине. И при этом за счет того что он не посередине удалось значительно снизить габариты фонаря. Лично для меня габариты фонаря намного важнее, чем теоретическое знание того, что диод находится не по центру, и которое на практике мне ничем не мешает. 3. Удобно или не удобно, вещь сугубо субъективная. Я никакого дискомфорта не ощущаю. [Исправлено: PinkFloyd, 30.04.2012 в 10:21] |
