Просмотров в теме 60310   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 09.09.2021, 05:39 Автор темы   161
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
Original SMOKTech SMOK Solus 16W Pod Kit Original Price $18.99, Now Only $14.99.
The Original SMOK Solus Pod System Vape Starter Kit is a super portable pod system kit designed with button-free vaping device. It comes with 700mAh built-in battery and the battery can be recharged via micro USB charging port. There is a blue light on the front of the device to inform you of the current state. You can remove and install the pod cartridge effortlessly with solid magnetic connection. Solus Pod Kit is equipped with a meshed 0.9ohm pod cartridge of 3.0ml e-juice capacity, which will offer you pure MTL flavor. The duck-billed mouthpiece makes the leakage less.
Original BMOR Sober 15W Pod Mod Kit Original Price $17.99, Now Only $11.99.
Original BMOR Sober Pod System Vape Kit is built-in a powerful 650mAh integrated battery that takes a 3.6V steady voltage output, consistently pushing power for your kit. Sober has a draw-activated firing mechanism thus eliminating a need for any buttons, simply and conveniently. It applies to the magnetic suction and a buckle triple reinforcement for quick removal and replacement. Based on its 4.0ml vape juice capacity coupled with a 0.8ohm meshed coil, making it more efficient to heat up and delivering scrumptious flavor and vapor. It is sought-after due to its intriguing CMF design that absolutely worth becoming your vaping partner.
Original SMOKTech SMOK Solus Replacement Pod Cartridge Original Price $14.99, Now Only $8.99.
SMOK Solus Replacement Pod Cartridge contains 0.9ohm meshed Coil for the purest MTL flavor. With the solid magnetic connection, the removal and installation is easy. The duck-billed mouthpiece brings you the most Original flavor. The PCTG Pod of 3ml e-juice capacity is also portable and eye-catching.
Original BMOR Sober Replacement Empty Pod Cartridge Original Price $5.99, Now Only $3.99.
Original BMOR Sober Replacement Pod Cartridge is with 4.0ml vape juice capacity, paired with the 0.8ohm meshed coil (not included), the extreme flavor it generate with every puff you take will excite you. Whats more, it company with a magnetic suction and a buckle triple reinforcement, making it strong in your kit. It is compatible with BMOR Sober Pod Kit.
Original BMOR Sober Pod Kit Replacement Coil Head Original Price $14.99, Now Only $9.99.
Original BMOR Sober Coil is specially designed for BMOR Sober Pod Kit, associating with the BMOR Sober pod cartridge and resistance value of 0.8ohm is faithful to maximize its best effectiveness to generate the rich cloud and smooth flavor.
3FVAPE вне форума   Вверх
Старый 10.09.2021, 05:49 Автор темы   162
3FVAPE
Original YIHI SXmini MK Pro Air Pod Kit Original Price $26.99, Now Only $17.99.
Original YIHI SXmini MK Pro Air Pod System Vape starter Kit signatures a 2ml refillable vape juice capacity that is visible to check your e-liquid. The ergonomic mouthpiece creates a tight friction sleek that brings a comfortable feeling when you are vaping, satisfying both MTL and RDTL vaping needs. No more sticky thread to screw on or off, it offers a magnetic connection for time-saving and delivering power.
Старый 11.09.2021, 06:38 Автор темы   163
3FVAPE
Sigelei 100W APV Box Mod - 2 x 18650 Original Price $29.99, Now Only $14.99.
The Sigelei 100W is powered by 2 x 18650 Batteries and the Wattage is adjustable in 0.1W increments up to 50 Watts. After 50 Watts, it will be adjustable in 1.0W increments.
Vapor Flask VF V3 40W Box Mod Clone Original Price $29.99, Now Only $14.99.
The Vapor Flask VF V3 Clone box mod is constructed from aluminum with touch feeling design, the hand feeling is very comfortable. The output wattage range is from 1W to 40W. The mod comes with top screen display and is suitable for 22mm diameter atomizer. It is powered by 2 x 18650 batteries (parallel, not included).
Original FreeMax Marvos 60W Pod Mod Kit Original Price $69.99, Now Only $46.99.
Original Freemax Marvos 60W Kit, is precisely forged Zinc Alloy and top-class Liquid Silicone Rubber combined for portable carry and comfortable grip. Marvos 60W Kit utilizes a real 2000mAh internal battery, with Type-C USB port and 2A fast charging function, it only takes 90 minutes to charge from 1% to 100%, which makes your device always have the power you need for a full day's use. The 0.96-inch color TFT display screen provides 5 color for options, just press Fire Button & Down (-) Button for 1 second to select your desired color. Features a smart FM chip for 0.001s speed-up ignition, and brings 3 smart modes that can automatically recognize resistance and match with a suitable wattage. By the way, the bypass mode is also compatible with RBA Mode. Moreover, Marvos 60W Kit adopts military-grade tri-proof technology, the IP67 Dust-Resistance and Water-Resistance and a high level of Shock-Resistance; (Protected against the effects of temporary immersion between 15cm and 1m. Duration of test 30 minutes.)
Original HorizonTech Durandal 85W Mod Kit Original Price $79.99, Now Only $59.99.
The Original HorizonTech Durandal Kit is built-in 30000mAh battery and supports maximum 85W output. The Box Mod has No-load Protection, Overtime Protection, Short circuit/low resistance protection, Load Voltage Protection, High temperature protection, Over Charging Protection, USB Type-C fast Charging.
Original HorizonTech Durandal Replacement Pod cartridge Original Price $14.99, Now Only $12.99.
The Durandal Pod cartridge is designed especially for the HorizonTech Durandal Vape Mod Kit, coming with 4ml e-juice capacity.
Original HorizonTech Durandal Replacement Coil Head Original Price $14.99, Now Only $11.99.
The Durandal Replacement Coils is perfectly compatible with HorizonTech Durandal Vape Mod Kit / Pod cartridge
Старый 14.09.2021, 10:35 Автор темы   164
3FVAPE
Original Steam Crave Hadron Plus DNA250C 200W Box Mod Original Price $174.99, Now Only $142.99.
Original Steam Crave Hadron Plus DNA250C Mod performs outstanding due to its dual 21700 rechargeable batteries (not included) coupled with the maximum 200W output wattage. Thanks to this DNA 250C chipset, it has three types of intriguing vaping modes: Replay Mode is convenient to display the most suitable and stellar flavor for you. Watts Boost Mode is a gospel to get a faster fire and stronger power delivery. Accurate Temperature Control is aimed to prevent the damage of coil and offer stable performance. Packed with a USB charging cable, it meticulously considers the built-in onboard charging and has a fast charging technology for on-the-go use. With its all-around protection, which contains Low Resistance Protection, Onboard Reverse Polarity Protection, atomizer protection, short circuit protection, overheat protection, low voltage step down protection, virtually certain your security during the process of vaping.
Original Steam Crave Hadron Plus DNA250C 200W Box Mod Advanced Kit with Plus V2 RDTA Original Price $236.99, Now Only $190.99.
Original Steam Crave Hadron Plus DNA250C Vape Box Mod Kit has a removable PLUS V2 RDTA that has two capacity options, including 8ml vape juice (standard form), it acts itself to be a versatile tank as both an RTA and as an RDTA. The air airflow is adjustable via the ring on the side, associated with a single-coil postless deck, pleasing you with the pure taste and the smooth vapor.
Artchanic Arti 60W Box Mod Clone Delrin Original Price $79.99, Now Only $60.99.
The Artchanic Arti Clone 60W TC VW Vape Box Mod is constructed from Delrin and 316 stainless steel. The Box Mod supports wattage adjustable from 1W to 60W and temperature control mode. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output.
Artchanic Arti 60W Box Mod Clone Aluminum Original Price $86.99, Now Only $66.99.
The Artchanic Arti Clone 60W TC VW Vape Box Mod is constructed from Aluminum and 316 stainless steel. The Box Mod supports wattage adjustable from 1W to 60W and temperature control mode. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output.
Старый 15.09.2021, 06:44 Автор темы   165
3FVAPE
Original Cthulhu Tube Mod II Semi-Mechanical, 1 x 18350 / 18650 Original Price $49.99, Now Only $35.99.
Original Cthulhu Tube Mod II 2 V2 is a new mechanical mod which is powered by 18650 / 18350 battery (not included). Cthulhu Tube II mod is compatible with 22mm / 24mm vape atomizer perfectly. Cthulhu Tube 2 Mod is elegant and compact mech mod with bottom mechanical switch and mechanical lock ring.
MK MODS Glow in the Dark Button Ring Clone for DotMod Dotaio Pod Original Price $7.99, Now Only $4.99.
The MK MODS Style Glow in the Dark Button Ring is suitable for DotMod Dotaio Pod System. It is Compatible with DotMod Dotaio Mini Pod System as used with DotMod Dotaio button
Старый 16.09.2021, 14:07 Автор темы   166
3FVAPE
SXK Mission Clone Replacement Switch + Back & Front Panel Kit for Billet Box Original Price $39.9, Now Only $37.
The SXK Mission Clone Replacement Switch + Back & Front Panel Kit are suitable for SXK BB Clone / BB DNA60 60W / BB Clone 70W Mod Kit. It is made of acrylic.
Hussar Gobby RTA Clone Rebuildable Tank Atomizer Original Price $25.99, Now Only $20.99.
Hussar Gobby Clone RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 22mm diameter and holds 4.5ml capacity. The Gobby Clone RTA supports Interchangeable angle-adjustable airflow, you can change the way the air hits the coil. The atomizer supports juice flow control: Fully Open, Fully closed for leakproof filling.
Original Asvape Hita Ink 40W Pod Kit Original Price $36.99, Now Only $30.99.
Original Asvape Hita Ink Pod System Vape Mod Kit inherits the classic Clone of Asvape strider. Asvape Hita Ink Pod Kit is powered by built-in 1500mAh battery with adjustable wattage of 5~40W. Asvape Hita Ink features self-developed ReekBox chip to identify the coil resistance and match the power automatically and OLED screen to display the detailed vaping data. Asvape Hita Ink Pod cartridge has 3.0ml capacity and 0.3ohm mesh coil for DTL vaping, 1.0ohm for MTL vaping.
Original Asvape Vulcan Plus Replacement Pod Cartridge Original Price $8.99, Now Only $6.99.
The Original Asvape Vulcan Plus Pod System Replacement Pod Cartridge holds 3.0ml capacity and comes with 1.2ohm /0.7ohm coil.
Старый 17.09.2021, 07:31 Автор темы   167
3FVAPE
Stratum Balance 60W Box Mod Clone - Silver + White, Juma Original Price $199.99, Now Only $179.99.
The Stratum Balance Clone 60W TC VW Vape Box Mod is made from Juma (made in Germany) and Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The Box Mod is Compatible with 24mm diameter vape atomizer. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output.
Original Wismec Reuleaux RX G 100W Box Mod Original Price $45.29, Now Only $39.99.
Original Wismec Reuleaux RX G Vape Box Mod introduces cyberpunk design to make it cool and stylish. It is powered by an external 18650 replaceable battery (not included) with 100W max output. The AI Tech can automatically match the best power and record your usual setting. With 5V / 2A USB Type-C fast charging, it ensures that Reuleaux RX G is always charged and at the ready.
Original Wismec Reuleaux RX G 100W Box Mod Kit Original Price $65.03, Now Only $59.99.
Original Wismec Reuleaux RX G Vape Mod kit introduces cyberpunk design to make it unique and eye-catching. It features a single 18650 replaceable battery (not included) with 100W max output. The AI Tech can automatically match the best power and record your usual setting. With 5V / 2A USB Type-C fast charging, it ensures that Reuleaux RX G is always charged and at the ready. It can also work with Reuleaux RX G Tank which is designed with top filling system and adjustable bottom airflow. In addition, Reuleaux RX G Tank has the e-juice capacity of 4.7ml and is fit for Wismec WX 0.2ohm / 0.5ohm coil which is made of AST steel materials.
Original Vaporesso Zero 2 Pod Kit Original Price $29.99, Now Only $25.99.
Original Vaporesso Zero 2 Pod System Vape Kit fits becomes a practical investment for you since you have this large 800mAh internal battery, changing just for 45 mins with a type-c cable, vaping all time when you travel and on the go. Especially, speaking for 1.0ohm Mesh Pod cartridge and a 1.3ohm CCELL Pod cartridge available for 3.0ml vape juice in standard form, it affects your vaping session once you fill your e-juice, which displays a larger capacity that compares to the old version.
Original Vaporesso Zero 2 Replacement Pod Cartridge Original Price $9.99, Now Only $7.99.
Original Vaporesso Zero 2 Pod Cartridge is suitable for Vaporesso Zero 2 Pod system Vape Kit, Evolved from the old Zero Pod cartridge, it shows off a larger 3.0ml vape juice capacity couple with its unique PTF (press-to-fill) filling system, which is reliable for leakage-proof and has simple operation to refill your e-juice by only two steps.
Старый 18.09.2021, 10:44 Автор темы   168
3FVAPE
4.32 EVO MTL RTA Clone 22mm Rebuildable Tank Atomizer Original Price $29.9, Now Only $25.5.
The 4.32 EVO Clone 22mm MTL RTA is with orbital adjustment of the air flow through an internal ring nut. By continuing to rotate the toothed ring after reaching the limit switch, the internal one will also rotate. The MTL RTA is perfect on Side by Side type box mods. Hypoallergenic internal air filter that silences the shot and reduces the turbulence of the intake air, creating a pleasant contrast even with the largest holes, washable even when the tank is full.
Original Uwell Caliburn AK2 15W Pod Kit Original Price $32.99, Now Only $26.99.
Original Uwell Caliburn AK2 Kit is a pod system kit with built-in 520mAh battery capacity. It comes with the meshed-H 0.9ohm pod cartridge that can hold 2ml e-juice capacity. And the Caliburn A2 Pod Cartridge can be applied to Caliburn AK2 Kit, too. There is a window for you to check the level of e-juice. It can be charged with USB type-c charging port.
Старый 22.09.2021, 12:56 Автор темы   169
3FVAPE
Original BD Vape Precisio Pro 24 RTA Damascus Limited Edition - 24mm, MTL / RDL Original Price $199, Now Only $169.
Original BD Vape Precisio Pro 24 RTA Damascus Limited Edition is in 24mm diameter and Ultem tank tube holds 4.5ml capacity. BD Vape Precisio Pro 24 RTA is single coil building and supports MTL / RDL Vaping.
Stratum Balance 60W Box Mod Clone White Juma Original Price $199.99, Now Only $179.99.
The Stratum Balance Clone 60W TC VW Vape Box Mod is made from Juma (made in Germany) and 316 Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The Box Mod is Compatible with 24mm diameter vape atomizer. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output.
Original BD Vape Precisio Pro 24 RTA - 24mm MTL / RDL Original Price $59.99, Now Only $44.
Original BD Vape Precisio Pro 24 RTA is made from stainless steel in 24mm diameter and Ultem tank tube holds 4.5ml capacity. BD Vape Precisio Pro 24 RTA is single coil building and supports MTL / RDL Vaping.
Старый 23.09.2021, 05:33 Автор темы   170
3FVAPE
Original Auguse EraAio for DotMod dotAIO Mod, Era Aio RBA Rebuildable Tank w/ Pins Original Price $48.99, Now Only $39.99.
The Original Auguse EraAio Era Aio RBA Rebuildable Tank is suitable for DotMod dotAIO Pod System. Comes with 6 PCS air pins 0.8 / 1.0 / 1.2 / 1.5 / 1.8 / 2.0mm. The RBA is single coil deck and simple structure for easy to build. The air intake can be adjustable without removing the heating wire. The heating wire can be replaced as there is oil in the tank.
SXK Hussar Gobby RTA Clone 4.5ml, 22mm Rebuildable Tank Atomizer Original Price $27.9, Now Only $24.9.
SXK Hussar Gobby Clone RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 22mm diameter and holds 4.5ml capacity. The Gobby Clone RTA supports Interchangeable angle-adjustable airflow, you can change the way the air hits the coil. The atomizer supports juice flow control: Fully Open, Fully closed for leakproof filling.
SXK Hussar Gobby RTA Replacement Drip Tip Clone Original Price $4.9, Now Only $3.9.
The SXK Hussar Gobby Clone RTA Replacement Drip Tip is made from PEI (mouthpiece) and Stainless Steel (base).
SXK Hussar Gobby RTA Replacement Tank Tube Clone Original Price $8.9, Now Only $6.9.
The SXK Hussar Gobby Clone RTA Vape Atomizer Replacement Tank Tube is made from PEI and holds 4.5ml capacity.
SXK Hussar Gobby RTA Replacement Air Pins Clone Original Price $9.9, Now Only $8.9.
The SXK Hussar Gobby Clone RTA Replacement Air Pins comes with 6 PCS / Pack. Size: 1.0mm x 2 holes, 1.5mm x 2 holes, 2.0mm x 2 holes, 1.5mm x 4mm slot, 2.0mm x 4.0mm slot, 2.5mm x 4.0mm slot.
Старый 24.09.2021, 05:28 Автор темы   171
3FVAPE
SXK BB 60W All-in-One Box Mod Kit Clone w/ USB Port - White, Evolv DNA 60, with Logo Original Price $119.8, Now Only $114.8.
The SXK BB Clone mod is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This BB Box comes with USB port for firmware upgrading, setting modification and user customization via software. This BB Box with Logo.
Original Hellvape Wirice Launcher Mini Tank Atomizer - 23mm Diameter Original Price $29.99, Now Only $25.99.
Original Hellvape Wirice Launcher Mini Tank utilizes the unique top-loading coil system for easy to use and sanitary. Rotate the drip tip base, and directly put your coil into the tank from the top of the tank, tighten the drip tip base clockwise for the end. Instead of replacing the coil via the bottom, these awesome steps that remove coils even with a full tank not only fairly decrease the potential of liquid leak-proof, but also increase the contact area for the T3-01 and T3-02 coils, on the other hand, it efficiently increases the heating speed and performance. Targeted to an MTL experience, Launcher Mini Tank signatures 3.0mL capacity, 5ml extra bulb glass tube for an even more impressive flavor. It will be widely acclaimed for the Knurled grip, acting to remove the top cap and refill easily. The airflow is adjustable depending on the preference of the vapor, contributing to accurately control the airflow for a pure vapor. One pain point is meticulously considered for adding a 510 thread, making it durable to weather the wear and tear.
Original Hellvape Wirice Launcher Mini Tank Replacement T3-02 Regular Coil Original Price $7.99, Now Only $5.99.
The Original Hellvape Wirice Launcher Mini Tank Vape Atomizer Replacement T3-02 Regular Coil is made from KA1 wire and in 1.2ohm resistance 3 PCS/ Pack
Original Hellvape Wirice Launcher Mini Tank Replacement T3-01 Mesh Coil Original Price $7.99, Now Only $5.99.
The Original Hellvape Wirice Launcher Mini Tank Vape Atomizer Replacement T3-01 Mesh Coil is made from KA1 wire and in 0.7ohm resistance. 3 PCS/ Pack
Original Hellvape Wirice Launcher Mini Tank Replacement Glass Tank Tube Original Price $2.99, Now Only $1.99.
The Original Hellvape Wirice Launcher Mini Tank Vape Atomizer Replacement Glass Tank Tube holds 3ml capacity.
Старый 25.09.2021, 06:15 Автор темы   172
3FVAPE
Original Lost Vape Cyborg Quest 100W Box Mod Original Price $69.99, Now Only $54.99.
The Original Lost Vape Cyborg Quest 100W TC VW Vape Box Mod comes with special-shaped look to show your personality. Lostvape Cyborg Quest 100W Vape box mod is powered by single 21700 / 20700 / 18650 battery (not included) with Type-C fast charging and can fires up to 100W output. Lost Vape Cyborg Quest features Quest 2.0 chip with 5 modes: wattage mode / VPC Mode / Bypass Mode / Voltage and 3 User Records (Normal coil, TC coil and RBA).
Original Lost Vape Cyborg Quest 100W Kit with UB Pro Pod Tank Original Price $79.99, Now Only $63.99.
The Original Lost Vape Cyborg Quest 100W TC VW Vape Box Mod Kit comes with special-shaped look to show your personality. Lostvape Cyborg Quest 100W Vape box mod is powered by single 21700 / 20700 / 18650 battery (not included) with Type-C fast charging and can fires up to 100W output. Lost Vape Cyborg Quest features Quest 2.0 chip with 5 modes: wattage mode / VPC Mode / Bypass Mode / Voltage and 3 User Records (Normal coil, TC coil and RBA).
Original SMOKTech SMOK Novo 2S Pod Kit 20W Original Price $29.99, Now Only $25.99.
The Original SMOKTech SMOK Novo 2S Pod System Vape Kit is auto mode that directly vape by the mouthpiece. Depend on the unique bilateral u-shaped airflow channel, airflow access to two insets from the side of the Novo 2 pod cartridge, creating infinite fresh air and bringing you unprecedented vapor and flavor experience according to your actual MTL vaping needs. The Novo 2 pod cartridge caters to 1.8ml e-juice, and one perfect essential point is that it is equipped with some small grooves around the body of the electrode, to some extent, it locks the condensate that generated during the vaping, and fairly accomplishes the purpose to stem the leaking efficiently. The Novo 2 pod cartridge is available for a single mesh coil, and purposefully built the 0.9ohm coil that consists of multiple octagons to achieve a faster speed and a larger heating area, ensuring that every drop plays its maximum effort for a pure and top-tier flavor.
Original SMOKTech SMOK Nord Pro Pod Kit 25W Original Price $35.99, Now Only $28.99.
The Original SMOKTech SMOK Nord Pro Pod System Vape Kit takes intention to innovate its coil for faster heating and speed, as well as efficiency. The two new PRO meshed coils enliven your imagination during the vaping experience and create the ultimate feeling if you are be favored by DL or MTL styles, even if you are a beginner or a veteran. According to prime the coil. Firstly, add a few drops of e-juice to each wicking hole, then, to ensure to fully saturate the center, you should drip a drop or two inside the head of the coil, finally, install your coil into the pod. The versatile Nord Pro pod cartridge sizes 3.3ml vape juice capacity, and what is worthy to appreciate is that it has a smart detection to check your pod and incorporate short circuit protection for your vaping time, better fitting your device status. It is accessible and user-friendly, and also retains the responsibility to offer the Child-resistant pod, balancing both safety and leak-proof, avoiding children open the pod at the accident.
Original SMOKTech SMOK Nord Pro Replacement Empty Pod Cartridge Original Price $9.99, Now Only $7.99.
Original SMOKTech SMOK Nord Pro Pod Cartridge is suitable for SMOK Nord Pro Pod System Vape Kit. It holds 3.3ml e-juice capacity and easy side filling system. Nord Pro Empty Pod Cartridge features child-resistant design to guarantee safer use. It is also designed with two different-sized air inlets on both sides, which can introduce different amounts of air to suit your preference. SMOK Nord Pro empty Pod Cartridge is compatible with Nord Pro-Meshed 0.6ohm DL Coil and 0.9ohm MTL Coil to bring you excellent flavor. What's more, Nord regular 0.6ohm Coil, Nord DC 0.8ohm MTL Coil, Nord Mesh-MTL 0.8ohm Coil, Nord 0.6ohm Mesh Coil, and Nord 1.4ohm regular Coil are also supported. Empty Pod Cartridge, coils not included
Старый 27.09.2021, 06:43 Автор темы   173
3FVAPE
Original Yachtvape x Mike Vapes Eclipse RTA Replacement Extension Kit Eclipse RTA 3.5ml Straight / 5ml Bubble Tank Original Price $14.99, Now Only $9.
The Yachtvape x Mike Vapes Eclipse RTA Replacement Extension Kit includes stainless steel chimney and 3.5ml / 5ml glass tank tube.
Billet Box BB Box Clone Replacement Front + Back Cover Panel Plate Original Price $34.99, Now Only $24.99.
The Replacement Cover Panel is made from acrylic, and is designed for Billet Box mod Kit / SXK BB Clone 70W / DNA60W Box Mod Vape kit. This cover panel comes with 2 pieces (front and back).
Billet Box BB Box Clone Replacement 4-in-1 Inner Set + Front / Back Plate Original Price $69.99, Now Only $56.99.
The Replacement 4-in-1 Inner Set is made from aluminum and the front and back plate is made from acrylic. They are suitable for Billet Box mod Kit / SXK BB Clone 70W / DNA60W Box Mod Vape kit.
Billet Box BB Box Clone Replacement 4-in-1 Inner Set Original Price $59.99, Now Only $45.99.
The Replacement 4-in-1 Inner Set is made from aluminum, and is designed for Billet Box mod Kit / SXK BB Clone 70W / DNA60W Box Mod Vape kit.
Original Voopoo Doric 20 Pod Kit Original Price $35.99, Now Only $25.99.
The Original VOOPOO Doric 20 Pod Mod Kit displays the modern intelligence atomization technology that brings you an indulgent experience both visual and physical. Doric is the first group of products to adapt the ITO platform. With its continuous effort, creation for one year to research and unveil the new Innovative Delicious Optimization solution (ITO) platform,
Original Voopoo Doric 20 Kit Replacement IPO Pod Cartridge Original Price $10.99, Now Only $6.99.
The IPO Pod Cartridge is designed especially for the Voopoo Doric 20 Kit, coming with 2ml e-juice capacity.
Original Voopoo Doric 20 Pod Replacement ITO M3 Coil Original Price $17.99, Now Only $13.99.
The ITO Coil is in 1.2ohm resistance and compatible with Voopoo Doric 20 Kit.
Original Voopoo ITO M2 Coil for Doric 20 Pod Kit Original Price $17.99, Now Only $13.99.
The ITO Coil is in 1.0ohm resistance and compatible with Voopoo Doric 20 Kit.
Original Voopoo Doric 60 Pod Kit Original Price $38.99, Now Only $28.99.
The Original VOOPOO Doric 60 Pod Mod Kit borns by the inspiration of the ancient elegant Greek architecture, playing the VOOPOO teams best efforts to some extent, and adjusting for thousands of times, it finally comes with the Doric 60. impressed by the aesthetic and slim architecture, the mod is eye-catching by inheriting the ancient Greek pillar's slender characteristics. The pod sizes a 4.5ml vape juice capacity, refilled via the bottom inlet, replacing by a magnetic suction, no hassle for the tedious steps. It is compatible with all the PNP coil family that allows checking the coil resistance once installation to protect your coil security.
Original SMOKTech SMOK Nord Pro Replacement 0.6ohm Meshed Coil Original Price $14.99, Now Only $10.99.
Original SMOKTech SMOK Nord Pro Coil is the new star for the SMOK coil series, it immediately acclaims the coil for its advantage of performance, heating speed, flavor delivery, and area contact. The Nord pro-meshed 0.6ohm DL Mesh coil is best for 20W, and is aimed at DL vaping experience. It is suitable for the Nord Pro Kit. It will maximum their effort for boost flavor and vapor.
Original SMOKTech SMOK Nord Pro Replacement 0.9ohm Meshed Coil Original Price $14.99, Now Only $10.99.
Original SMOKTech SMOK Nord Pro Coil is the new star for the SMOK coil series, it immediately acclaims the coil for its advantage of performance, heating speed, flavor delivery, and area contact. The Nord pro-meshed 0.9ohm MTL Mesh coil is best for 15W, which targets MTL vaping, consistently bringing a delicious flavor and balancing heat distribution for every drop. It is suitable for the Nord Pro Kit. It will maximum their effort for boost flavor and vapor.
Старый 28.09.2021, 07:03 Автор темы   174
3FVAPE
Original OXVA Arbiter 2 RTA Rebuildable Tank Atomizer Original Price $44.99, Now Only $33.99.
The Original OXVA Arbiter 2 RTA Vape Atomizer becomes an outstanding RTA for its top-to-bottom fanned airflow, allowing air to flow through the glass several circles to make the resulting cloud purer and flavor smoother. On the other hand, it sets an advance of honeycomb airflow and researches out the new fanned airflow to unlock the airflow, giving you an exceptional full-bodied flavor.
Original Damn Vape Nitrous RDA Replacement Beauty Ring Original Price $12.99, Now Only $7.99.
The Original Damn Vape Replacement Beauty Ring is suitable for Nitrous RDA vape atomizer.
Original Damn Vape Nitrous RDA Replacement Wide Bore 810 Drip Tip Original Price $8.99, Now Only $4.99.
The Original Damn Vape Replacement Wide Bore 810 Drip Tip is made from resin and is suitable for Nitrous RDA vape atomizer.
Старый 29.09.2021, 03:05 Автор темы   175
3FVAPE
Original Vandy Vape Pyro V4 RDTA Pyro IV Rebuildable Dripping Tank Atomizer Precio original $34.99, Ahora sólo $29.99.
The original Vandy Vape Pyro V4 RDTA vape atomizer shines with its new air path design, helping air has smoother circle access the RDTA, generating intense vapor, bringing an unforgettable aftertaste, and inspiring feeling of comfort and indulgence.
Original Lost Vape Grus V2 100W TC VW Box Mod Precio original $69.99, Ahora sólo $46.99.
The original Lost Vape Grus 100W VW TC Vape Box Mod is powered by single 21700 / 20700 / 18650 battery (not included) with max 100W output.
Original Lost Vape Grus V2 100W Mod Kit with UB Pro Pod Precio original $79.99, Ahora sólo $55.99.
The original Lost Vape Grus 100W TC VW Vape Box Mod Kit has a beautiful Grus Mod (usually leather or wood), plus the latest Sub Ohm Pod Tank to form a powerful and compact vape starter kit.
Replacement Frame for dotMod dotAIO SE Precio original $59.99, Ahora sólo $55.99.
This replacement PC Frame is only suitable for dotMod dotAIO SE Vape
Ivant Tip Clone 510 Drip Tip for RDA / RTA / RDTA Precio original $3.99, Ahora sólo $2.59.
The Ivant 510 Drip Tip Clone is made from stainless steel (base) + POM (mouthpiece) and is suitable for RDA / RTA / RDTA Vape Atomizer.
Старый 06.10.2021, 17:36 Автор темы   176
3FVAPE
Original Voopoo Drag 3 177W Mod Kit with TPP-X Pod Tank Original Price $79.99, Now Only $59.99.
Original Airistech Mystica II 450mAh Vaporizer Built-in Battery Vape Mod, a pocket sized premium vaporizer pen mod, features a 12mm diameter hole, fit for most atomizers. With magnetic connection, Airistech Mystica II Mod is compatible with all 510 thread oil atomizers (5ml / 1ml magnetic adopter included, Atomizer not included) and designed with oil level view widow to check the oil anytime, fitting your personal style. As a variable voltage vaporizer, it can work well with different voltage according to different oils: 3.4V / 3.7V / 4.0V.
Original Uwell Aeglos Empty Tank Pod Cartridge w/ 510 Adapter Base + 6 Coils Original Price $18.99, Now Only $14.99.
Original Uwell AEGLOS TANKPOD Tank consists of a Empty Pod Cartridge + 510 adapter base with affordable cost, and can suit most box mods. It is compatible with UN2-Series 6 coils (included) which can satisfy all vapers' needs. It supports both MTL / DL vaping by progressive airflow adjustment. Moreover, the Tank is lightweight and durable, so you can effortlessly pick it up & put it down.
Original Uwell Aeglos Empty Tank Pod Cartridge w/ 510 Adapter Base Original Price $10.99, Now Only $7.99.
Original Uwell AEGLOS TANKPOD Tank consists of a Empty Pod Cartridge + 510 adapter base with affordable cost, and can suit most box mods. It is compatible with UN2-Series 6 coils (not included) which can satisfy all vapers' needs. It supports both MTL / DL vaping by progressive airflow adjustment. Moreover, the Tank is lightweight and durable, so you can effortlessly pick it up & put it down.
Старый 09.10.2021, 11:24 Автор темы   177
3FVAPE
10-6
SXK BB 70W Box Mod Kit Clone w/ USB Port - White, with 2021 Logo Original Price $85, Now Only $77.99.
The SXK BB Clone Box Mod Kit is constructed from aluminum with an all-in-one design. This mod comes with Nautilus coil adaptor.
Original Vapelustion Hannya II 230W Box Mod Original Price $69.99, Now Only $56.99.
The Original Vapelustion Hannya II 230W VW Vape Box Mod, upgraded version of original Hannia Mod, is more lightweight. Vapelustion Hannya II is powered by dual 18650 batteries (not included) with max 230W output. Vapelustion Hannya 2 Box Mod supports Type-C charging and 0.015s instant ignition. And Vapelustion Hannya II Mod also has 4 different replacement magnetic art panels for more exquisite.
Original Vapelustion Hannya Nano Pro 13.6W Pod Kit Original Price $39.99, Now Only $31.99.
The Original Vapelustion Hannya Nano Pro Pod System Vape Kit, a stylish pod kit, works with built-in 700mAh battery with 13.6W output. Vapelustion Hannya Nano Pro Pod Kit has 4 different magnetic art panels and features 2 different airflows.
SXK Replacement Front + Back Cover Panel Plate for Billet Box Original Price $22.9, Now Only $21.9.
SXK Screen Plate + Button Plate Set for Billet Box Original Price $15.9, Now Only $11.9.
This SXK replacement accessories set are suitable for Billet / SXK BB 60W / 70W box mod kit. This set includes Screen Plate + Button Plate. The Panel Set adopts sandblasting technology.
Original Vapelustion Hannya Nano Pro Replacement Pod homeridge Original Price $14.99, Now Only $8.99.
The Original Vapelustion Hannya Nano Pro Pod homeridge is designed especially for the Vapelustion Hannya Nano Pro Pod System Kit, coming with 2ml e-juice capacity.
Старый 11.10.2021, 11:45 Автор темы   178
3FVAPE
Typhoon Taifun GT One RTA Clone Improved Version Full Kit Original Price $29.99, Now Only $22.99.
The Typhoon Taifun GT One Clone RTA Rebuildable Tank Vape Atomizer Improved Version Full Kit is in 23mm diameter and holds 4.3ml capacity. The Taifun GT One Clone RTA Vape Atomizer comes with 4 PCS Air Inserts: 0.8mm, 1.0mm, 1.5mm, 1.8mm.
Bestia Mods Furia Clone Mechanical Mod Replacement PEI Ring - Brown Original Price $5.99, Now Only $3.99.
The decorative ring is made from PEI and is suitable for Bestia Mods Furia Clone Mechanical Mod.
Original Yachtvape x Mike Vapes Eclipse RTA 3.5ml Replacement Bubble Glass Tank Tube Original Price $3.99, Now Only $2.99.
Original Yachtvape x Mike Vapes Eclipse RTA Replacement Bubble Glass Tank Tube holds 3.5ml capacity.
Original Yachtvape x Mike Vapes Eclipse RTA 2.0ml Replacement Straight Glass Tank Tube Original Price $2.99, Now Only $1.99.
Original Yachtvape x Mike Vapes Eclipse RTA Replacement Straight Glass Tank Tube holds 2.0ml capacity.
Original Yachtvape x Mike Vapes Eclipse RTA Replacement Extension Kit Original Price $14.99, Now Only $9.
The Original Yachtvape x Mike Vapes Eclipse RTA Replacement Extension Kit includes stainless steel chimney and 3.5ml / 5ml glass tank tube.
Original Yachtvape x Mike Vapes Eclipse RTA Extension Kit 5.0ml Replacement Bubble Glass Tank Tube Original Price $3.99, Now Only $2.99.
The Original Yachtvape x Mike Vapes Eclipse RTA Extension Kit Replacement Bubble Glass Tank Tube holds 5.0ml capacity. This glass tank tube is used with Extension Kit and suitable for Yachtvape x Mike Vapes Eclipse RTA Vape Atomizer.
Original Yachtvape x Mike Vapes Eclipse RTA Extension Kit 3.5ml Replacement Straight Glass Tank Tube Original Price $2.99, Now Only $1.99.
The Original Yachtvape x Mike Vapes Eclipse RTA Extension Kit Replacement Straight Glass Tank Tube holds 3.5ml capacity. This glass tank tube is used with Extension Kit and suitable for Yachtvape x Mike Vapes Eclipse RTA Vape Atomizer.
Старый 12.10.2021, 06:23 Автор темы   179
3FVAPE
Cloud 2 MTL RTA Clone Rebuildable Tank Vape Atomizer Original Price $39.99, Now Only $31.99.
The Cloud 2 Style MTL RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 22mm diameter and PC Tank tube holds 3.5ml capacity. The deck is dual-pole design for single coil building. The air adjustment ring supplies 3 options: each air hole in the ring has a diameter of 1.2mm.
Cloud 2 RTA Clone Replacement PEI Tank Tube 3.5ml Original Price $7.99, Now Only $5.99.
The Cloud 2 Style RTA vape atomizer Replacement Tank Tube is made from PEI and holds 3.5ml capacity.
Cloud 2 RTA Clone Replacement PEI Chimney Original Price $7.99, Now Only $5.99.
The Cloud 2 Style RTA vape atomizer Replacement Chimney is made from PEI and comes with 1 PC / Pack.
Replacement Frame for dotMod dotAIO SE Pod System Original Price $59.99, Now Only $55.99.
This replacement Delrin Frame is only suitable for dotMod dotAIO SE Vape Pod System.
Replacement Screw Set Kit for Billet Box / SXK BB Clone Original Price $10.99, Now Only $7.99.
The Replacement Screw Set Kit is suitable for Billet / SXK BB 70W / DNA 60W Box Mod Kit. They are used as replacement parts to fix your BB box mod and make your BB box mod look nice, which is made from stainless steel material. The Kit includes 9 PCS Screws
Старый 13.10.2021, 06:56 Автор темы   180
3FVAPE
Original Hippovape B'adapt Pro 100W SBS Box Mod - Amber Clear, 1~100W, 100~315'C / 200~600'F, 1 x 18650/20700/21700 Original Price $44.99, Now Only $39.99.
The Original Hippovape B'adapt Pro 100W VW Vape SBS Side by side Box Mod is powered by single 21700 / 18650 / 20700 battery (not included) with type-C charging and can fire up to 100W output. The Hippovape B'adapt Pro 100W Mod is equipped with 0.96 inch LCD display screen to show vaping data clearly. And Hippovape B'adapt Pro supports Watt Mode / Volt mode / Temp mode / Bypass mode to meet different needs.
Original Vapefly Kriemhild 80W Box Mod - 1 x 18650 / 20700 / 21700 Original Price $81.99, Now Only $62.99.
Original Vapefly Kriemhild 80W Box Mod features security alarm system and 3S chip protections to guarantee the Mod's safe use. It supports 3 types of batteries: 18650 / 20700 / 21700 (not included). With 80W max output and Type-C fast charging, Kriemhild 80W Vape Mod can fully meet your daily needs. It is compatible with Vapefly Gunther Sub Ohm Tank. In addition, equipped with 510 connector, it is also adapt to most of Tanks. There are VW/Bypass output mode for your option. The 0.49 Inch OLED screen can clearly show you the status.
Original Vapefly Kriemhild 80W Box Mod + Gunther Sub Ohm Tank Kit Original Price $91.99, Now Only $81.99.
Original Vapefly Kriemhild 80W VW Box Vape Mod Kit is composed of Kriemhild 80W Box Mod and Gunther Sub Ohm Tank. One of the innovative features of it is the Security Alarm System contributed by German 103 Team. When the chip detects a risk, the buzzer will send an alert to the user, such as Short Circuit Alarm, Overheat Alarm, 10s Vaping Alarm. Besides, the 3S chip also provides some safety protections: Over-heat Protection, Reversed Battery Connection Protection, Over-current Protection and so on. Kriemhild 80W supports single 18650 / 20700 / 21700 battery and comes with Type-C fast charging port. Gunther Sub Ohm Tank is designed with U-shaped top airflow to bring smooth, quiet and leakproof vaping. Compatible with FreeCore? K series coils (Kriemhild II Coil) and Kriemhild II RMC, it will provide excellent flavor for you. Gunther Sub Ohm Tank can be refilled by top filling system and hold 3.5ml or 5ml e-juice capacity.
Original Vapefly Gunther Sub Ohm Tank Original Price $39.99, Now Only $29.99.
Original Vapefly Gunther Sub Ohm Tank vape atomizer is designed with U-shaped top airflow to bring smooth, quiet and leakproof vaping. Compatible with FreeCore? K series coils (Kriemhild II Coil) and Kriemhild II RMC, it will provide excellent flavor for you. Gunther Sub Ohm Tank can be refilled by top filling system and hold 3.5ml or 5ml e-juice capacity.
Время генерации страницы 0.31057 секунды с 15 запросами
