60645
210
141
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
MK2 Special Cipher Mechanical Mod Clone Original Price $29.99, Now Only $25.99.
The MK2 Special Cipher Clone Mechanical Mod is made from Brass and Delrin. The diameter of top cap is 26mm to fit most of atomizers. The Mechanical mod is powered by 1 x 18650 battery (not included) and with pushbutton locking system. ![]() Original Geekvape S100 Aegis Solo 2 100W Box Mod Original Price $61.49, Now Only $41.99. The original GeekVape S100 Box Mod is powered by an external 18650 single battery (not included), support up to 100W output. Type-C charging port with flip cover greatly guarantees the safety of this mod and simplifies the charging operation to a certain extent. This mod also uses an accidental press protection design to avoid coil over-burning or mod over-heating caused by accidental press. The 2nd Gen of GeekVape Tri-proof Tech gives this mod IP68 rating water & dust resistance and a higher level of shock resistance. 1.08 inches big screen can let every detail of the product be reflected on the screen, providing a better visual experience for you. ![]() Original GeekVape M100 Aegis Mini 2 100W Box Mod Original Price $71.99, Now Only $48.99. The original GeekVape M100 Box Mod is equipped with a battery of 2500mAh and supports up to 100W stable output. This mod benefits from the 2nd Gen of GeekVape Tri-proof Tech and therefore has IP68 rating water & dust resistance and a higher level of shock-resistance can provide you with more effective protection in harsher environments. You can take this M100 box mod with you everywhere. This GeekVape integrated battery mod has a reduced size but still has a large 1.08-inch screen. Reading your vaping parameters will be done quickly and clearly. The design of the shell successfully combines leather and stainless steel, giving this mod an unparalleled temperament. ![]() Original GeekVape Z Sub Ohm 2021 Tank Vape Atomizer Original Price $40.49, Now Only $26.99. The original GeekVape Z Sub Ohm 2021 Tank is new for 2021 and is perfect for when you are on the go for GeekVape S100 Kit, it is also compatible with GeekVape Z series Coils, including Z0.15, Z0.2, Z0.25, DC and Z0.4 (coils not included). Capable of 5.5ml vape juice, it offers you such a huge capacity thrilled to vape. In terms of its top filling system, allowing you to refill e-liquid easily and fairly avoid leakage. As well as its adjustable airflow equipped with a larger filling hole, GeekVape Z Sub Ohm 2021 Tank makes it more unobstructed and helps you to enjoy vaping more conveniently and indulgently. ![]() Original ETU Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System Original Price $19.9, Now Only $14.9. The original ETU Replacement Front and Back Door Panel Plates is made from PC and suitable for dotMod dotAIO Vape Pod System. 2 PCS / Pack
142
Original FreeMax Marvos S 80W Mod Kit with Marvos DTL Pod Tank Atomizer Original Price $79.99, Now Only $49.99.
Original FreeMax Marvos S 80W Pod Vape Mod Kit is made of Zinc alloy & stainless steel & leather with aesthetics and great grip. FreeMax Marvos S is powered by single 18650 battery (not included) with max 80W output. Marvos S features 0.9 inch TFT screen, easy to operate, and applied VW, VPC, Bypass modes to meet different needs. Paired with FreeMax Marvos DTL Pod Tank, it has 4.5ml capacity for long time use and MS mesh coil with adjustable side airflow for DL. ![]() Original FreeMax Marvos PCTG DTL Empty Pod Cartridge Original Price $20.99, Now Only $14.99. The Marvos DTL Empty Pod Cartridge is suitable for FreeMax Marvos S 80W Mod Kit. Freemax Marvos Cartridge is designed especially for the FreeMax Marvos T 80W Kit. According to different manufacturing materials, two pod types are provided: PCTG DTL Pod and Glass DTL Pod. For those who do not like to use plastic, you can buy an optional glass pod. Both pods have a capacity of 4.5ml, which can be easily refilled. Featuring a bottom refill stoppered by a silicone plug. You need to remove the pod first, turn it upside down and open the silicone plug for filling. The top of the pod features a wide 810 sized drip tip which specially designed for DTL vaping needs. The innovative V-shaped groove design on the 810 drip tip can significantly prevent spitting back and effectively reduce the chance of any leaking. Marvos DTL Pod is compatible with the newly designed MS Mesh Coils, which enhances the flavor and brings an excellent DTL vaping experience. Plug and unplug to change the coil, quite easy and convenient. The powerful magnet at the bottom of the Marvos DTL Pod ensures a perfect match with the mod. 1pc each pack. ![]() Original FreeMax Marvos Glass DTL Empty Pod Cartridge Original Price $20.99, Now Only $14.99. The Marvos DTL Empty Pod Cartridge is suitable for FreeMax Marvos S 80W Mod Kit & FreeMax Marvos T 80W Kit ![]() Original GeekVape Poseiton P Sub Ohm Tank Atomizer Original Price $29.9, Now Only $24.99. Original GeekVape Poseiton Tank is an innovation based on Zeus Tank. GeekVape P Sub Ohm Tank features middle airflow leakproof system and three airway airflow control for precise airflow control. GeekVape P Tank has double-layer liquid chamber with shock-proof glass tube and is compatible with GeekVape Z series coils. GeekVape P is easy to refill from the top. ![]() Original Digiflavor Siren G MTL Tank Atomizer Original Price $26.98, Now Only $21.99. The Original Digiflavor Siren G MTL Tank holds 4.0ml e-juice capacity. It comes with leakproof top cap and 22mm anti-lock deck. With precise and slide-to-adjust linear airflow setting, Digiflavor Siren G MTL Tank creates smoother flavor for both MTL and RDL. Digiflavor Siren G MTL Tank Atomizer delivers multiple airflow adjustments with the flavor booster GeekVape G Series Coil.
143
Orange SXK BB 60W Billet Box Clone Box Mod Kit w/ USB Port, Evolv DNA 60 Original Price $119.8, Now Only $114.8.
The SXK BB Clone mod is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. ![]() Blue SXK BB 60W Billet Box Clone Box Mod Kit w/ USB Port, Evolv DNA 60 Original Price $119.8, Now Only $114.8. ![]() Silver SXK Delro Clone 70W TC VW AIO Mod Kit - 1~70W, 2200mAh, SEVO 70 Chipset Original Price $129, Now Only $98. The SXK Delro Clone 70W TC VW AIO Mod Kit is built-in 2200mAh battery, The SEVO 70 Chipset supports Wattage adjustable from 1W to 70W. The SXK Delro Style 70W mod kit is compatible with BB accessories. Comes with an Nautilus BVC coil adapter, compatible with Aspire Nautilus coils. ![]() Gun Metal SXK Delro AIO Clone 70W Mod Kit - 1~70W, 2200mAh, SEVO 70 Chipset Original Price $129, Now Only $98. ![]() Black Tripod RTA Clone Rebuildable Tank Atomize Original Price $18.99, Now Only $14.99. The Black Tripod RTA Clone is constructed from 316 stainless steel. The Tripod RTA Clone features 22mm diameter and 2ml juice capacity. ![]() Original Digiflavor S G MTL Tube Mod - 1 x 18350 / 18650 Original Price $41.99, Now Only $27.99. Digiflavor S G MTL Tube Mod is designed for S G MTL Tube Kit / Siren G MTL Tank. Digiflavor S G Tube Mod is compatible with 18650 and 18350 batteries (not included) and can meet the need of all-day use. This mod adopts an accidental press protection design to protect from mistouch. The innovative 3-level adjustable power output can achieve a low-med-high level flavor adjustment, allowing people to experience a different taste. S G Tube Mod can also automatically recognize the coil resistance and match the most suitable power output. ![]() SXK Delro AIO Mod Kit Replacement Door Cover Panel Plate Clone Original Price $20.99, Now Only $14.99. The SXK Delre AIO Mod Kit Replacement Door Cover Panel Plate comes with 2 PCS / Pack. ![]() Original Oumier Wasp King RDA 24mm BF Rebuildable Dripping Atomizer Original Price $31.49, Now Only $20.99. Oumier Wasp King RDA is with an adjustable swirl airflow and dual slotted airflow control are wonderful features, allowing you to fine-tune the airflow that balances between flavor and vapor. It also has a replaceable coil design, making use of two types of coil options that come included, which contain mesh and wire coil, giving you a longer life span and durable RDA. It comes with BF pin to be compatible with squonk BF MOD and is undoubtedly easy to remove and install from MOD via its incredible humanized groove design.
144
Imitation Ivory Penon V2 60W Box Mod Clone - 1~60W, 1 x 18650 Original Price $229.99, Now Only $209.99.
The Penon V2 60W VW Vape Box Mod Clone is made from Imitation Ivory. The Penon V2 Style Box Mod is powered by 60W chipset supports variable wattage from 1W to 60W. The Penon V2 Style Box Mod is powered by 1 x 18650 battery (not included) and supports maximum 22mm diameter atomizer. ![]() Original Vaporesso Target 80 Mod Kit with GTX Pod Tank 26 Original Price $39.99, Now Only $33.99. Original Vaporesso TARGET 80 is the new 80W Vape Pod Kit supports variable wattage from 5W to 80W. The triangular TARGET 80 MOD body is more ultra-durable and suited to the outdoors. Its rugged appearance outside and the hi-tech Axon Chip inside are combined perfectly to provide an awesome DTL vaping experience outdoors. ![]() Original Voopoo Drag X Pro 100W Pod 18650 / 21700 Mod Kit with TPP X Pod Original Price $57.99, Now Only $37.99. Original VoopooDrag X Pro mod Kit adopts the upgraded GENE.FAN 3.0 chip, it provides explosive power, stable flavor and rich intelligent functions. With Auto / Manual mode and toggle switch (On / Off button), you can feel the top performance. Drag X Pro supports Smart / RBA to satisfy every vaper. The new TPP X Pod Cartridge is designed with 360 degree infinite airflow system and bottom airflow to maximize the atomization efficiency. It brings more precise airflow control and super cloud. The air holes are specially designed for MTL experience to enjoy smooth and rich flavor. The magnetic suction pod provides easy and sanitary way of filling e-juice. TPP X Pod is compatible with all TPP / PnP coils (not included). ![]() Original Voopoo Drag S Pro Pod 3000mAh Mod Kit with TPP X Pod Original Price $59.99, Now Only $39.99. Original Voopoo Drag S Pro Kit contains a Max 80W Output Mod with 3000mAh battery capacity and a 5.5ml TPP X Pod cartridge. It not only provides the top performance with a toggle switch (on / off button), but also retains the traditional On / Off function of pressing five times. Drag S Pro increases the output voltage to 8.5V, which makes it bring more steady flavor even when the battery is about to run out. In addition, the new GENE.FAN 3.0 chip brings more powerful cloud and more stable flavor for it. Designed with SMART / RBA. Drag S Pro will satisfy different vaping needs, Button and Auto mode are also available for you to choose. There is a new airway layout to avoid direct contact with e-liquid. The new TPP X Pod is adapted to the most powerful coil of TPP platform and is added a 510 base. Drag S Pro will present more precise airflow control and super cloud with the combination of 360 Degree infinite airflow system and bottom airflow. There is also the air holes designed for MTL vaping. Drag S Pro Kit is compatible with all TPP / PnP Coils (not included).
145
Original Dovpo Blotto Single Coil RTA 23.5mm Rebuildable Tank Atomizer Original Price $48.99, Now Only $36.5.
The Original Dovpo Blotto Single Coil RTA vape atomizer comes with 23.5mm diameter & 2.8ml straight glass / 5.0ml bubble glass. Dovpo Blotto Single Coil RTA combines 272 degree airflow & strengthened AFC ring & base to offer dual diffusion airflow for the smoothest draw. Blotto Single Coil RTA is easy to build single coil and refill. ![]() Original Asvape Prolog 200W 2 x 18650 VW Box Mod Original Price $103.5, Now Only $69.99. Original Asvape Prolog VW Vape Box Mod is compact and easy to carry, suitable for various occasions. This mod is also equipped with a clear electronic screen to display the data of this mod. It is powered by dual 18650 batteries (not included), can provide up to 200 watts of power output. And it has a Type-C charging function, allowing you to use it for a long time without worrying about battery drain. Asvape Prolog Box Mod has two modes, VW and TC, allowing you to easily adjust current resistance, wattage, and voltage to achieve precise control of power and temperature. And the powerful performance of the mod ensures each puff is safe and reliable. The universal 510 Connecter can be matched with your favorite atomizer. ![]() Stratum V4 100W VW Box Mod Clone Stabwood Version with YiHi SX485J Original Price $289.99, Now Only $249.99. Stratum V4 Clone 100W VW Variable Wattage Box Mod is powered by 1 x 18650 battery (not included) with Micro USB charging, enough fire up to 100W (5~100W). Monitored by YiHi SX485J Chip, Stratum V4 supports VW 5~100W / TC (NI200, SS, TI 212~572'F, 100~300'C) / Taste / TCR and Bypass mode.
146
Original FreeMax Onnix 2 15W Pod System Vape Starter Kit - 900mAh, 2.0ml ,0.8ohm / 1.0ohm Original Price $34.99, Now Only $24.99.
Original FreeMax Onnix 2 15W Kit is a 15W compact pod system with 2.0ml pod cartridge and smart battery with automatic resistance recognition for high-strength MTL vaping needs. FreeMax Onnix 2 15W Kit adopts a new generation of UV transfer technology and achieves a perfect overlay effect of different optical films and coating textures, therefore the kit is featured with higher reflection performance for more variable pattern effects. Powered by a 900mAh internal battery with Type-C and 1.5A fast charging, just take 60 minutes to charge from 1% to 100% ![]() Original FreeMax Onnix 2 Pod System Replacement Empty Pod Cartridge - 2.0ml (2 PCS) Original Price $14.99, Now Only $8.99. The FreeMax Onnix 2 Pod Cartridge has an e-liquid capacity of 2.0ml, which is super easy to refill and the strong magnets ensure a quick and perfect match. Featuring FM SaltCoilTech 3.0 technology, OX DVC series Coils uses a dual vertical coil and tea fiber cotton formula, bring a strong throat hit and intense nicotine satisfaction, the 100% flavor categories for Nic Salt & Freebase E-liquids. Onnix 2 15W Kit is perfect for MTL vaping and born for high strength: 6~12mg freebase & 20~50mg nic salt. Compatible with 0.5ohm / 0.8ohm / 1.0ohm / 1.2ohm / 1.5ohm FreeMax OX Coil (not included) ![]() Dispensing Blunt Syringe Needle Tip for E-liquid Syringe E-juice Injector Refilling Tool - Green, SS, 14 Gauge / 38mm (5 PCS) Original Price $2.99, Now Only $1.59. The Dispensing Blunt Syringe Needle Tip is made of Stainless Steel material in 38mm length and 14GA, which is suitable for E-liquid Syringe E-juice Injector Refilling Tool. The needles is blunt, which can avoid accidental injuries. The long needle can go deeper into a bottle and draw up e-juice easily. The short one is tailored for CE2 / CE3 cartomizers to refill e-juice. They are not compatible with e-juice bottles and the long needle can not be used to inject e-juice into CE2 / CE3 cartomizer.
147
Original Vaporesso TARGET 80 VW Box Mod Original Price $60.99, Now Only $49.99.
Original Vaporesso TARGET 80 VW Vape Box Mod boasts a compact and outstanding design, it comes with a largely 3000mAh integrated battery that pushes up to 80-watts, which satisfies you all-day use. Whats more, to vape more often, it provides a Type-C port, which improves the performance and output of the device without bearing any trouble during the process. With its extraordinary 0.96" TFT display screen that takes updated UI, you will be able to view your current battery, amount of puffs, and how much power the device has. Along with its 510 connection, it is undoubtedly easy to match your Preference. The fact is that TARGET 80 Box Mod is compatible with VAPORESSO GTX POD TANK and also the classic NRG S and GTX Tanks (tanks not included) ![]() Original Rincoe Jellybox Nano Pod System Mod Kit Original Price $59.99, Now Only $35.99. The Original Rincoe Jellybox Nano Pod System Vape Mod Kit maintains a compact design, constructed with a zinc alloy body and satin material finish and a PCTG tank section for durable construction. It has a range of coil options between 0.3ohm and 3.0ohm, and has two types of coils to choose from: Mesh 1.0ohm Coil and Mesh 0.5 Ohm Coil. Powered by 1000mAh Built-in Battery, and you can expect a full day of vaping pleasure when using a Type-C USB port, which allows 5V / 1A Type C charging specification. Rincoe Jellybox Nano Pod cartridge holds up to 2.8ml of E-liquid, you can refill all sorts of different juices you want, satisfying both nic salt e-liquid and freebase e-liquid. ![]() Original Vaporesso GTX 26 Pod Tank - 5.0ml, 0.2ohm / 0.3ohm Mesh Coil (1 PC) Original Price $20.99, Now Only $13.99. Original Vaporesso GTX 26 Pod Tank is a pre-filled and refillable tank that is capable of holding up to 5.0ml of E-liquid which is equipped with a 510 connection that can quick removal and replacement. When it comes to the filling system, it has a threaded top fill system that fairly prevents any potential leakage. It is adapted to the most powerful coil of the GTX platform, including 0.2ohm coil and 0.3ohm mesh coil, and matches with GTX 26 Pod and Vaporesso Target 80 box mod.
148
Original Koguovape Jane 60W Box Mod - VW 1~60W, 1 x 18650, Resin Original Price $89.99, Now Only $57.99.
Original Koguovape Jane 60W VW Vape Box Mod is powered by single 18650 battery (not included) with max 60W output. Koguovape Jane 60W Mod applied dual side fire buttons and features 0.91 inch OLED screen to show vaping data clearly. And Koguovape Jane is compatible with 24mm 510 tank vape atomizer perfectly. ![]() Original Exvape Expromizer V1.4 MTL RTA Rebuildable Tank Atomizer Limited Edition - 2.0ml / 4.0ml / 6.0ml, 23mm Original Price $58.99, Now Only $46.99. The Original Exvape Expromizer V1.4 RTA Limited Edition, the upgrade version of the Expromizer V1 RTA vape atomizer, is constructed of Stainless Steel / PC / POM with 23mm diameter. Expromizer V1.4 RTA Limited Edition has easy to wind single-coil deck. Exvape Expromizer V1.4 RTA included the tank expansion kit, three optional drip tips and 4 different tank variants to offer 8 different tank combinations. Expromizer V1.4 MTL RTA applied top filling design. Expromizer V1.4 has 6 airflow pins to adjust airflow more precisely for perfect draw and flavor. Its top cap has a bayonet lock. Both the top cap and the airflow ring have knurling to provide a good grip. ![]() Original Exvape Expromizer V1.4 RTA Replacement Cotton Laces - (30 PCS) Original Price $6.99, Now Only $4.99. The Original Expromizer V1.4 Cotton Laces are perfectly compatible with Exvape Expromizer V1.4 MTL RTA vape atomizer. It comes with 30 PCS / Pack. ![]() Original Exvape Expromizer V1.4 RTA Replacement Cotton Rope - (5 Meters) Original Price $6.99, Now Only $4.99. The Original Expromizer V1.4 Cotton Ropes are perfectly compatible with Exvape Expromizer V1.4 MTL RTA vape atomizer. It is in 5 meters length. ![]() Original Exvape Expromizer V1.4 RTA Replacement PC Tank Tube Original Price $5.99, Now Only $3.99. The Original Expromizer V1.4 PC Tank Tube is designed for Exvape Expromizer V1.4 RTA vape atomizer. ![]() Original Exvape Expromizer V1.4 RTA Replacement PEI Tube and Drip Tip Set Original Price $7.99, Now Only $5.99. The Original Expromizer V1.4 RTA PEI Tube and Drip Tip Set is designed for Exvape Expromizer V1.4 RTA vape atomizer. ![]() Original Exvape Expromizer V1.4 RTA Replacement O-Rings Original Price $2.99, Now Only $1.29. Those Original Expromizer V1.4 O Rings are perfectly compatible with Exvape Expromizer V1.4 MTL RTA vape atomizer.
149
Original Lost Vape Thelema Quest 200W Box Mod Original Price $69.99, Now Only $51.99.
The Original Lost Vape THELEMA Quest 200W VW Vape Box Mod, featuring the Quest 2.0 Chipset, 5~200W output range, and uses a pair of high-amp 18650 batteries (not included). Delivering up to 200W output, thanks to the Quest 2.0 Chipset, the Thelema Quest Mod can also access a temperature control suite to deliver a carefully tailored output. ![]() Original Lost Vape Thelema Quest 200W Box Mod Kit with UB Pro Pod Tank Original Price $79.99, Now Only $59.99. The Original Lost Vape THELEMA QUEST 200W VW vape box mod Kit, featuring dual 18650 batteries (not included), 5~200W output range, and is paired with the UB Pro Pod Tank. Outfitted with the QUEST 2.0 Chipset, the THELEMA Quest Kit has a wattage output range of 5~200W and offers a temperature control suite for those that prefer a tailored vapor output. Paired with the UB Pro Pod Tank, the Lost Vape THELEMA Quest Kit utilizes coils from the UB Pro Coil Series, delivering massive flavor and vapor from your favorite e-Juice, holding up to 5.0ml within the side-filled pod. ![]() Original Advken OWL Pro Sub Ohm Tank Clearomizer Atomizer 29mm Diameter Original Price $30.99, Now Only $28.99. Original Advken OWL Pro Sub Ohm Tank Vape atomizer is absolutely resupplied by its upgraded 5.0ml vape juice capacity based on its top filling design, matching your mood of all-day vaping enough and further prevent leakage. OWL Pro continues the premium texture of stainless steel and ergonomic rounded design that comforts your fingertips, and adapts an 810 replaceable drip tip, with its sleek and ergonomic mouthpiece to the bottom, which has an innate appearance to satisfy you. It is compatible with two types of coils of 0.2ohm and 0.4ohm. They will let you feel the massive cloud with incredible flavors.
150
SXK Cloud 2 MTL RTA Clone 22mm Rebuildable Tank Atomizer Original Price $29.99, Now Only $25.9.
The SXK Cloud 2 Clone MTL RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 22mm diameter and PC Tank tube holds 3.5ml capacity.The deck is dual-pole design for single coil building. The air adjustment ring supplies 3 options: each air hole in the ring has a diameter of 1.2mm. ![]() MK2 Special Brass Soon Integral Cipher Clone Mechanical Mod - Silver, Chroming Brass + Delrin, 1 x 18650 Original Price $33.99, Now Only $26.99. The MK2 Special Brass Soon Integral Cipher Clone Mechanical Mod is made from Brass and Delrin. The diameter of top cap is 26mm to fit most of atomizers. The Mechanical mod is powered by 1 x 18650 battery (not included) and with pushbutton locking system. ![]() MK2 Special Brass Soon Integral Cipher Clone Mechanical Mod - Black Gold, Brass + Delrin, 1 x 18650 Original Price $33.99, Now Only $26.99. The MK2 Special Brass Soon Integral Cipher Clone Mechanical Mod is made from Brass and Delrin. The diameter of top cap is 26mm to fit most of atomizers. The Mechanical mod is powered by 1 x 18650 battery (not included) and with pushbutton locking system.
151
SXK Cloud 2 Clone RTA Replacement PC Tank Tube + Top Cap - Translucent, 3.5ml Original Price $6.9, Now Only $5.5.
SXK Cloud 2 Clone RTA Vape Atomizer Replacement Tank Tube and top cap is made from PC and holds 3.5ml capacity. ![]() SXK Cloud 2 Clone RTA Replacement PEI Tank Tube + Top Cap - Brown, 3.5ml Original Price $8.9, Now Only $6.9. SXK Cloud 2 Clone RTA Vape Atomizer Replacement Tank Tube and top cap is made from PEI and holds 3.5ml capacity. ![]() SXK Cloud 2 Clone RTA Replacement PEI Chimney - Brown (1 PC) Original Price $8.9, Now Only $6.9. The SXK Cloud 2 Clone RTA vape atomizer Replacement Chimney is made from PEI and comes with 1 PC / Pack. ![]() Original Dovpo Blotto Single Coil RTA Replacement Tank Tube - Bubble PCTG, 5.0ml Original Price $4.99, Now Only $3.59. The Original Dovpo Blotto Single Coil RTA vape atomizer Replacement Bubble Tank Tube is made from PCTG and holds 5.0ml. ![]() Original Dovpo Blotto Single Coil RTA Replacement Glass Tank Tube - Bubble Glass, 5.0ml Original Price $4.99, Now Only $2.69. The Original Dovpo Blotto Single Coil RTA vape atomizer Replacement Bubble Tank Tube is made from Glass and holds 5.0ml. ![]() Original Dovpo Blotto Single Coil RTA Replacement Glass Tank Tube - Straight Glass, 2.0ml Original Price $4.99, Now Only $2.59. The Original Dovpo Blotto Single Coil RTA vape atomizer Replacement Straight Tank Tube is made from Glass and holds 2.0ml.
152
Original Ultroner Kamo Pod Kit Original Price $32.9, Now Only $27.9.
The Original Ultroner Kamo Pod System Vape Starter Kit is built-in 1400mAh capacity and with USB Type C charging port The pod cartridge holds 4.0ml capacity and compatible with DEJAVU Pocket AIO Kit 0.6hom and 1.0ohm coils (included). ![]() Original Vandy Vape Kylin M Pro RTA Rebuildable Tank Atomizer - 6.0ml / 8.0ml, 24.22mm Diameter Original Price $61.49, Now Only $39.99. The Original Vandy Vape Kylin M Pro RTA vape atomizer provides a large 8.0ml bubble grass to refill the vape juice that offers the simplest and most sanitary way by its top filling system, have a long vaping session is a piece of cake. It also pondering its anti-Leak design to further prevent leakage. It exudes elegance with its meticulous and crafted mouthpiece, paired with its top airflow ring, you will have an awesome and exciting throat hit and vaping experience. Kylin M Pro RTA accepts a range of M class coils that generates a massive vapor. ![]() Original Ultroner Kamo Pod System Replacement Pod Cartridge Original Price $5.9, Now Only $3.9. The Original Ultroner Replacement Pod Cartridge is suitable for Ultroner Kamo Pod System. Is is compatible with DEJAVU Pocket AIO Kit 0.6hom and 1.0ohm coils (coils not included). ![]() Original Rincoe Jellybox Nano Replacement Empty Pod Cartridge - Full Clear, 2.8ml (1 PC) Original Price $4.99, Now Only $2.99. The Original Rincoe Jellybox Nano replacement pod Cartridge has an impressive 2.8ml vape juice capacity, allowing you to experience a longer session between refills, and has a Translucent shell, which allows you to check the situation of vape juice. For an optimized mouth-to-lung experience, there is a 1.0ohm mesh Coil available for nic salt e-liquid that offers you a wonderful flavor and vapor output, another type of coil is 0.5ohm mesh coil that makes you enjoy RDL vaping by using freebase e-juice, all of them optimize for both taste and longevity. It is also fit for biscuity Rincoe Jellybox Nano pod system mod kit. ![]() Original Rincoe Jellybox Nano Replacement 1.0ohm, MTL Vaping Mesh Coil Original Price $11.99, Now Only $7.59. Original Jellybox Nano Coil is compatible with Rincoe Jellybox Nano Kit / Pod cartridge. The mesh 1.0ohm coil is suitable for MTL vaping (nic salt e-liquid). 3 PCS / pack. ![]() Original Rincoe Jellybox Nano Pod Replacement 0.5ohm, RDL Vaping Mesh Coil Original Price $12.99, Now Only $7.99. Original Jellybox Nano Coil is compatible with Rincoe Jellybox Nano Kit / Pod cartridge. The mesh 0.5ohm coil is suitable for RDL vaping (freebase e-liquid). 3 PCS / pack.
153
Original Eleaf iSolo S 80W Box Mod 1800mAh Original Price $53.99, Now Only $35.99.
Original Eleaf iSolo S 80W VW Vape Box Mod is equipped with a large capacity battery of 1800mAh, which can fully extend the use time of this mod. It can be charged through the type-c port, which is very convenient. And It supports up to 80W power output, bringing you a wonderful vaping experience. At the same time, it has a clear electronic display. You can adjust the wattage you need by pressing the button. ![]() Original Eleaf iSolo S with GX Tank Kit Original Price $73.49, Now Only $48.99. Original Eleaf iSolo S Kit is shallower than most modern phones. With its 1800mAh built-in battery and 5.0ml vape juice capacity available for a variety of e-liquids, iSolo S absolutely guarantees the persistence of vaping and helps you have a fascinating vaping experience. iSolo S takes advantage of AST technology that brings a faster heating-up speed, mellow and original flavor. Depending on this technology coupled with GX coil brings you the smart coil protection. the device will refuse to output when it detects the lack of e-juice, protecting the coil from dry hit and have a longer coil lifespan. It also provides a type-c port to satisfy your vaping experience without bearing any hassle during the process. the max output can be up to 80W, which offers a stronger power for it. As well as its 4.5mm wider filling hole diameter, it can give you a deeper throat threat. ![]() Original Eleaf GX Tank Atomizer Original Price $20.99, Now Only $14.99. Original Eleaf GX Tank, fit for Eleaf iSolo S Kit, has 5.0ml e-liquid capacity that can satisfy your long-term use. Eleaf GX Tank is compatible with brand new GX 0.2ohm / 0.5ohm Coil for rich and abundant cloud. ![]() Original Eleaf GX Replacement Coil Head for GX Tank - 0.5ohm (AST, 25~45W) (4 PCS) Original Price $14.99, Now Only $8.99. The Original Eleaf GX Coil GX 0.5ohm Coil. It is an upgraded coil to enjoy an amazing flavor and dense vapor. The coil is compatible with Eleaf iSolo S Kit 1500mAh / GX Tank. ![]() Original Eleaf GX Replacement Coil Head for GX Tank - 0.2ohm (AST, 50~80W) (4 PCS) Original Price $14.99, Now Only $8.99. The Original Eleaf GX Coil GX 0.2ohm Coil. It is an upgraded coil to enjoy an amazing flavor and dense vapor. The coil is compatible with Eleaf iSolo S Kit 1500mAh / GX Tank.
154
Original SMOK Morph S Pod-80 80W Pod System Vape Starter Kit - Black Carbon Fiber, VW 5~80W, 1 x 18650, 5.0ml, 0.23ohm / 0.4ohm Original Price $45.99, Now Only $37.99.
Original Morph S Pod-80 Kit is powered by a single 18650 battery (not included), bringing you up to 80W of power to your satisfaction. Along with the stability of 4.1V voltage output, which optimizes the output and brings a more stable flavor even when the battery is about to run out. Relying on 1.5A charging current, 2 hours is the limitation to charging the battery from zero to full. It is capable of 5ml vape juice capacity, playing with a toggle-Clone air switch to adjust the airflow via dual air inlets, this versatile LP2 pod achieves the ideal vaping Clone with the most mellow flavor for MTL, RDL, and DL vaping needs. ![]() Original SMOKTech SMOK Morph Pod-80 80W Pod System Vape Starter Kit - Grey, VW 5~80W, 3000mAh, 5.0ml, 0.23ohm / 0.4ohm Original Price $50.99, Now Only $39.99. he Original SMOK Morph Pod-80 Kit becomes a monstrosity because of its gigantic 3000mAh integrated battery, bringing you up to 80W of power to your satisfaction. Along with the stability of 4.1V voltage output, which optimizes the output and brings a more stable flavor even when the battery is about to run out. Relying on 1.5A charging current, 2 hours is the limitation to charging the battery from zero to full. It is capable of 5ml vape juice capacity, playing with a toggle-Clone air switch to adjust the airflow via dual air inlets, this versatile LP2 pod achieves the ideal vaping Clone with the most mellow flavor for MTL, RDL, and DL vaping needs. ![]() Original SMOKTech SMOK Morph POD-80 LP2 Empty Pod Cartridge for Morph Pod-80 / Morph S Pod-80 Kit - 5.0ml (3 PCS) Original Price $11.99, Now Only $7.99. Original SMOKTech SMOK Morph POD-80 LP2 Pod Cartridge comes with an impressive 5ml vape juice capacity, allowing you to have a longer vaping experience between refills via its top filling system. This constructed pod is equipped with strong magnets to prevent further leaking. LP2 Pod is compatible with all LP2 coils (not included), SMOK Morph Pod-80, and Morph S Pod-80 Kit, becoming an indispensable part of your vaping time. ![]() 5AVape Cloud 2 Clone RTA Replacement Drip Tip Original Price $5.59, Now Only $3.59. 5AVape Cloud 2 Clone RTA Vape Atomizer Replacement Drip Tip is made from PEI. ![]() 5AVape Cloud 2 Clone RTA Replacement PEI Tank Tube 3.5ml Original Price $5.99, Now Only $3.99. 5AVape Cloud 2 Clone RTA Vape Atomizer Replacement Tank Tube is made from PEI and holds 3.5ml capacity. ![]() 5AVape Cloud 2 Clone RTA Replacement PC Tank Tube 3.5ml Original Price $5.99, Now Only $3.39. 5AVape Cloud 2 Clone RTA Vape Atomizer Replacement Tank Tube is made from PC and holds 3.5ml capacity. ![]() 5AVape Cloud 2 Clone RTA Replacement Stainelss Steel Top Cap Original Price $6.99, Now Only $4.59. The 5AVape Cloud 2 Clone RTA vape atomizer Replacement Top Cap is made from stainelss steel and comes with 1 PC / Pack. ![]() 5AVape Cloud 2 Clone RTA Replacement PEI Top Cap Original Price $5.99, Now Only $3.59. The 5AVape Cloud 2 Clone RTA vape atomizer Replacement Top Cap is made from PEI and comes with 1 PC / Pack. ![]() 5AVape Cloud 2 Clone RTA Replacement PEI Top Filling Cap Original Price $5.99, Now Only $3.59. The 5AVape Cloud 2 Clone RTA vape atomizer Replacement Top Filling Cap with filling port is made from PEI and comes with 1 PC / Pack. ![]() 5AVape Cloud 2 Clone RTA Replacement PEI Chimney Original Price $6.99, Now Only $4.99. The 5AVape Cloud 2 Clone RTA vape atomizer Replacement Chimney is made from PEI and comes with 1 PC / Pack.
155
Original MR.JUSTRIGHT1 & Wotofo Profile PS Dual Mesh RDA Rebuildable Dripping Atomizer The Original Wotofo & MR.JUSTRIGHT1 Profile PS Dual Mesh RDA Rebuildable Dripping Vape Atomizer is made from stainless steel in 28.5mm diameter. Wanna level up your single-mesh vape? Enter the Profile PS Dual Mesh RDA! Once again, collaborated with Mrjustright1 in hope to bring excellent vape to vapers!
The Original Wotofo & MR.JUSTRIGHT1 Profile PS Dual Mesh RDA Rebuildable Dripping Vape Atomizer is made from stainless steel in 28.5mm diameter. Wanna level up your single-mesh vape? Enter the Profile PS Dual Mesh RDA! Once again, collaborated with Mrjustright1 in hope to bring excellent vape to vapers! ![]() Original Hellvape Dead Rabbit R Tank Vape Atomizer Original Hellvape Dead Rabbit R Tank boasts a 5ml vape juice capacity and modifies the structure of its bottom airflow system and a condensed chamber aimed at a more delicate flavor. A 0.2ohm resistant value is recommended to the power range of 50 to 60W. One pack of R coil contains 10 stock coils, allowing you to rebuild your coil 10 times. Compared to the regular coil, it can save 75% cost and enjoy more joy by rebuilding your own tank. it also adds a 510 drip tip that conforms to human mechanics, whats more, it utilizes a strong PCTG plastic material to ensure a superior level of durability. Original Hellvape Dead Rabbit R Tank boasts a 5ml vape juice capacity and modifies the structure of its bottom airflow system and a condensed chamber aimed at a more delicate flavor. A 0.2ohm resistant value is recommended to the power range of 50 to 60W. One pack of R coil contains 10 stock coils, allowing you to rebuild your coil 10 times. Compared to the regular coil, it can save 75% cost and enjoy more joy by rebuilding your own tank. it also adds a 510 drip tip that conforms to human mechanics, whats more, it utilizes a strong PCTG plastic material to ensure a superior level of durability. ![]() Original Wotofo Mesh Prebuilt Wire Kanthal A1 0.3ohm The Original Wotofo Mesh Prebuilt Wire is made from kanthal A1 and in 0.3ohm resistance (suitable for 30~40W). 10 PCS / Pack The Original Wotofo Mesh Prebuilt Wire is made from kanthal A1 and in 0.3ohm resistance (suitable for 30~40W). 10 PCS / Pack ![]() Original Hellvape Dead Rabbit R Tank Replacement Cotton + Mesh Coil Kit Original Hellvape Dead Rabbit R Tank vape atomizer replacement Coil has 10 stock coils a pack, allowing you to replace them 10 times. With this coil suit, you can save around 75% cost that is compared to buying a single. it offers 10 cottons and 10 wires in each pack. Original Hellvape Dead Rabbit R Tank vape atomizer replacement Coil has 10 stock coils a pack, allowing you to replace them 10 times. With this coil suit, you can save around 75% cost that is compared to buying a single. it offers 10 cottons and 10 wires in each pack. ![]() Original Hellvape Dead Rabbit R Tank Replacement Bubble Glass Tank Tube 6.5mL The Original Hellvape Dead Rabbit R Tank RTA Vape Atomizer Replacement Bubble Glass tank Tube holds 6.5ml capacity. The Original Hellvape Dead Rabbit R Tank RTA Vape Atomizer Replacement Bubble Glass tank Tube holds 6.5ml capacity. ![]() Original Hellvape Dead Rabbit R Tank Replacement Straight Glass Tank Tube 5mL The Original Hellvape Dead Rabbit R Tank RTA Vape Atomizer Replacement straight Glass tank Tube holds 5ml capacity. The Original Hellvape Dead Rabbit R Tank RTA Vape Atomizer Replacement straight Glass tank Tube holds 5ml capacity.
156
Mini 80 TC VW 1 x 18650 Box Mod Original Price $29.99, Now Only $14.99.
The mini 80W TC vape box mod supports output wattage from 5W to 80W. The highlight is the Screen shows battery condition, resistance, wattage and voltage. The voltage is adjustable vary from 3.3V to 4.2V according to your vaping habit. ![]() Vapor Flask VF V3 40W VW Box Mod Clone - 2 x 18650 Original Price $29.99, Now Only $14.99. The Vapor Flask VF V3 Clone box mod is constructed from aluminum with touch feeling design, the hand feeling is very comfortable. The output wattage range is from 1W to 40W. The mod comes with top screen display and is suitable for 22mm diameter atomizer. It is powered by 2 x 18650 batteries (parallel, not included). ![]() Original Sigelei 100W Plus 0.95" OLED Variable Wattage APV Box Mod Original Price $29.99, Now Only $14.99. The updated Sigelei 100W Plus is redesigned to look better with no sharp corners. The updated pin is spring loaded so you don't have to manually adjust anymore. The battery cover does not have screw holes and is replaced by 2 magnets on top and bottom. This way, you don't need to pull out a screwdriver to change your batteries. It utilizes the same dependable Yihi Chip that allows you to go up to 100W. The 100W Plus also includes a silicone sleeve to protect the device. There is a thin film on the LCD display screen that can be peeled off for those who see scratches on their LCD display screen when they receive their product. ![]() Mk MODS Dotcircuit Set Drip Tip, Fire Button, VV Button for dotMod dotAIO Original Price $79.99, Now Only $60.99. The Dotcircuit set is made from titanium and Contents 1 x 510 drip tip, 1 x fire button, 1 x VV button, 1 x fire button ring, O rings, The Dotcircuit set is suitable for dotMod dotAIO Vape Pod System. ![]() Kontrl V2 Kontrl Mag Front + Back Door Panel Plates Clone w/ Button for dotMod dotAIO Original Price $79.99, Now Only $60.99. The Kontrl V2 Kontrl Mag Clone Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a button for easy operation. ![]() Original Vandy Vape Kylin M Pro RTA Replacement Bubble Glass Tank Tube - 8ml Original Price $4.99, Now Only $3.99. Original Vandy Vape Kylin M Pro RTA Replacement Bubble Glass Tank Tube holds 8ml capacity and is suitable for Vandy Vape Kylin M Pro RTA Vape Atomizer. ![]() Original Vandy Vape Kylin M Pro RTA Replacement Straight Glass Tank Tube - 6ml Original Price $3.99, Now Only $2.59. Original Vandy Vape Kylin M Pro RTA Replacement Straight Glass Tank Tube holds 6ml capacity and is suitable for Vandy Vape Kylin M Pro RTA Vape Atomizer.
157
Original Ambition Mods Ripley MTL / RDL RDTA Rebuildable Dripping Tank Atomizer 22mm Diameter Original Price $58.99, Now Only $44.99.
Ambition Mods Ripley MTL RDL RDTA vape atomizer is with the same double opposed airflow system of the Bishop RTA is re-proposed, further increasing the possibilities by also inserting Air Pins with a wider flow. This system allows to obtain a high turbulence inside the chamber and therefore an excellent aromatic performance, while maintaining a laminar flow in intake and exhaust. ![]() Original Ambition Mods Ripley MTL / RDL RDTA Replacement 316L Mesh 325 Wire Mesh Original Price $3.99, Now Only $1.99. The Original Ambition Mods Ripley MTL / RDL RDTA Vape Atomizer Replacement 316L Mesh 325 wire mesh comes with 4 PCS / Pack. 2 PCS in 52.5 x 21.5mm and 2 PCS 34.5 x 21.5mm. ![]() Original Ambition Mods Ripley MTL / RDL RDTA Replacement Tank Tube Original Price $5.99, Now Only $3.99. The Original Ambition Mods Ripley MTL / RDL RDTA vape atomizer replacement tank tube is made from Glass and holds 3.2ml capacity. ![]() Original Ambition Mods Ripley MTL / RDL RDTA Replacement Top Cap Original Price $18.99, Now Only $13.99. The Original Ambition Mods Ripley MTL / RDL RDTA Vape Atomizer Replacement Top Cap. This top cap offers the opportunity to give your atomizer a new look. ![]() Original Ambition Mods Ripley MTL / RDL RDTA Replacement Stainless Steel Wicks Original Price $5.99, Now Only $3.59. The Original Ambition Mods Ripley MTL / RDL RDTA vape atomizer replacement wicks is made of sturdy stainless steel, these stainless steel wicks in the form of Xylema's capillary tubes were explicitly designed for the Ambition Mods Ripley MTL / RDL RDTA to ensure a constant flow of liquid and to enable Original vaping pleasure. ![]() Original Ambition Mods Ripley MTL / RDL RDTA 2.0mm Replacement Air Pin Original Price $4.99, Now Only $2.99. The Original Ambition Mods Ripley MTL / RDL RDTA Vape atomizer Air Pin is with 2.0mm diameter. The Ambition Mods Air Pin for the Ripley MTL / RDL RDTA makes the airflow directly through the side openings on the top cap onto the built-in mesh wire mesh. ![]() Original Ambition Mods Ripley MTL / RDL RDTA Replacement Combi Tank Tube Original Price $5.99, Now Only $3.99. Original Ambition Mods Ripley MTL / RDL RDTA Vape atomizer replacement Combi Tank is made of durable 316 stainless steel and high-strength glass.
158
Original BP Mods Pioneer Insider MTL / DL RBA Tank for BB Billet Box / Sunbox Zero Naga / SXK Supbox Boro Mod Original Price $79.99, Now Only $59.99.
The Original BP Mods Pioneer Insider is a tank that can be compatible with Boro (Billet Box) tanks, such as Billet Box, Sunbox Zero Naga or SXK Supbox. BPMods Pionner Insider is an affordable premium tank that can be used as both MTL and tight DL and will be transferred to Billete. ![]() Original Hippovape B'adapt Pro SBS 100W TC VW Box Mod Original Price $44.99, Now Only $39.99. The Original Hippovape B'adapt Pro 100W VW Vape SBS Side by side Box Mod is powered by single 21700 / 18650 / 20700 battery (not included) with type-C charging and can fire up to 100W output. The Hippovape B'adapt Pro 100W Mod is equipped with 0.96 inch LCD display screen to show vaping data clearly. And Hippovape B'adapt Pro supports Watt Mode / Volt mode / Temp mode / Bypass mode to meet different needs. ![]() Original Oumier Wasp Nano RTA 2 24mm Wasp Nano V2 Rebuildable Tank Atomizer Original Price $28.99, Now Only $18.99. Original Oumier Wasp Nano RTA 2 polishes and upgrades its vape juice capacity of 2ml. What differs from the Wasp Nano RTA is that it can support expansion to 3.8ml. Additionally, it modifies the structure of its side airflow system via an adjustable ring to significantly fine-tune your airflow with its 24mm diameter. Super and high-quality stainless steel adapted, bringing the premium and comfortable texture, stylish appearance, and durable construction. It maintains an 810 drip tip that is easy to install and uneasy to fall off. Once installing on your kit, you will such this tiny RTA has a huge effect on your vaping journey. ![]() Original GeekVape Z MTL Sub ohm Tank Atomizer Original Price $29.8, Now Only $24.99. Original GeekVape Z MTL Tank vape Atomizer is especially designed for MTL vaping. It features top airflow system to provide MTL vapors with precise airflow control. The Z-level leakproof design can effectively prevent leakage. With top filling system, Z MTL Tank holds 2ml e-juice capacity and adopts stylish hollow-carved "Z"s Tank design to check the e-liquid window. It also uses the metallic shell to become more resistant to breaking. Z MTL Tank is compatible with GeekVape A Series Coil to bring you dense flavor and satisfying throat-hit. ![]() YFTK Hurricane Junior RTA Clone 22mm Rebuildable Tank Atomizer Original Price $19.99, Now Only $14.99. The YFTK Hurricane Junior Clone RTA is constructed from 316 Stainless Steel. The Hurricane Junior Clone RTA features 2ml e-liquid capacity, dual post design and bigger juice channels. The juice control ring support mouth to lung vaping experience. ![]() Original BP Mods Pro Vape Cotton Original Price $5.99, Now Only $3.99. The Original BP Mods Pro Vape Cotton is premium 100% organic long staple cotton. It features fast wicking speed, fast flavor switching, high absorbing capacity, high temperature resistance. Tough fibers with less flocks, and High temperature resistance.
159
5AVape Four One Five 415 RTA Ultima Clone Rebuildable Tank Atomizer Original Price $29.99, Now Only $23.99.
5AVape Four One Five 415 RTA Ultima Clone Rebuildable Tank Atomizer tiene una capacidad de e-juice de 2,0 ml con un sistema de llenado superior en 22 mm de diámetro. Está hecho de acero inoxidable 316 (cuerpo) y PEI (tubo del tanque). Es compatible con el anillo de flujo de aire MTL / RDL, lo que le brinda una excelente experiencia de vapeo. ![]() 5AVape Four One Five 415 RTA Ultima Clone Replacement PC Tank Tube Original Price $5.99, Now Only $3.99. El 5AVape Four One Five 415 RTA Ultima Clone Reemplazo del tanque de tubo está hecho de PC y tiene una capacidad de 2.0 ml. ![]() Original YouDe UD Double Deck Vapor Pocket for DIY RBA / RDA / RTA - Nylon Original Price $39.99, Now Only $29.99. El YouDe UD Double Deck Vapor Pocket tiene innumerables bolsillos para guardar su equipo de vape y mantenerlos seguros y reforzados en la parte delantera y trasera para su protección, no hay necesidad de preocuparse si su equipo estará sano y salvo. Con los dos bolsillos grandes proporcionados, algunas personas pueden colocar toda su colección de vape aquí. Un asa en la parte superior del bolsillo para vapeo de dos pisos de YouDe UD permite viajar y manejar fácilmente. Entonces, la próxima vez que planee ir a algún lugar con una buena cantidad de equipo, no olvide recoger este estuche.
160
Bestia Mods Furia Mechanical Tube Clone 18650 / 20700 / 21700 Tube Mod Original Price $29.99, Now Only $20.99.
The Bestia Mods Furia Mechanical Mod Clone is made from Brass and with black ring. The Furia Tube Mod Clone is powered by 1 x 18650 / 20700 / 21700 battery (not included). The Furia 18650 / 20700 / 21700 Tube Mod is with side fire and venting cap on bottom. ![]() Original Damn Vape Nitrous+ RDA 22mm Rebuildable Dripping Atomizer With BF Pin Original Price $34.99, Now Only $24.99. The original Damn Vape NItrous 22mm RDA atomizer, featuring a 1.5mL deep juice wells, elevated postless build deck, and single or dual coil configuration. Constructed from durable stainless steel, the rebuildable dripping atomizer is one of the smallest available on the market, measuring in at a 22mm diameter with 1.5mL deep juice well. Using an elevated build deck with 4 deck based terminals, the Nitrous RDA can install a single or dual coil configuration, offering two top caps to accommodate each coil configuration with differing airflows to cater to the installed coil configuration.
