118253
240
47
101
Регистрация: 29.09.2013 Последняя активность: 27.09.2025 02:21
Сказал(а) спасибо: 579
I think consumer should care about that but not manufacturer. If you use standard battery everything will be alright. The rest depends on your brains. Цитата:
Raise your banner! Make Panda Great Again!
[Исправлено: Reyden, 09.07.2019 в 12:22] |
102
Регистрация: 05.07.2019 Последняя активность: 04.11.2024 12:39
Поблагодарили: 10 раз(а) в 4 сообщениях
![]() I meant there should be a way to disable it (manually i suppose) for cells which aren't compatible. Seedback is the effect of a peltier module producing electricity when one side is hot and the other cool. They are inefficient, but in the winter the camp fire is on many long hours when there is no sun for solar and you need a flashlight the most. Also a reason to use external battery pack of course, to keep it warm under the clothes. I love devices which have a lot of adaptability and redundancy. With my experience outdoors this becomes very useful quite often. For example at the moment I carry with me a lii-100 charger stripped down to pcb and wires. Magnetic terminals. With this I can charge 18650, 16340 but also camera battery with needle adapters. Also I can drain these batteries to charge the phone for example. I love it's usefullness! |
103
Регистрация: 11.08.2011 Последняя активность: Сегодня 00:08
Записей в дневнике: 1 Сказал(а) спасибо: 2721
Поблагодарили: 12662 раз(а) в 4590 сообщениях
Reyden, это все довольно специфичные требования для производителя нацеленного на широкие массы. Плата зарядки в панде легко меняется. Логичнее выпустить мелкую серию продвинутых плат для желающих для самостоятельной замены.
| Поблагодарили: 4 раз(а) |
104
Is quick charge not appealing to masses? Powerbank? I think they help to sell the product.
But very importantly you need a good interface, friends have been put off from my fenix annoying interface. |
Reyden (09.07.2019)
105
[Исправлено: Reyden, 09.07.2019 в 19:34] |
106
Регистрация: 08.03.2011 Последняя активность: Сегодня 03:33
![]() Ну так прекрасно же, значит тем более ЯЛу не надо отнимать ваш хлеб - те 20 человек, кому это надо, смогут купить такие платы/кастом у вас
| Поблагодарили: 2 раз(а) |
AEDe (09.07.2019), Witchdoctor (10.07.2019)
107
108
И чтобы никаких быстрых зарядок в следующей панде ![]() We could proceed discussion with those who are interested in the topic below or here, no matter. I'll share some details later. Prototype will be ready in August, I want to test it with solar panels and different Fast Charge adapters to determine what charging settings is better. https://forum.fonarevka.ru/... [Исправлено: Reyden, 10.07.2019 в 10:11] |
109
Reyden, в планах именно , отдельная плата зарядки, которую можно вставить не меняя основного драйвера?или?..
110
https://forum.fonarevka.ru/... [Исправлено: Reyden, 10.07.2019 в 12:18] |
fnksb (10.07.2019)
111
Reyden, дрйверы не зависимые будут на каждый диод? Родную плату придется в расход пускать?
Если удастся свести переделку к разборке, отпаиванию старой , припаиванию новой, то очень интересно будет шт на 5 таких модулей слету желающих найду по знакомым... |
112
Да, 2 драйвера распаянные одном текстолите по размерам светомодуля. В планах оставить родную плату отпаяв с нее все детали кроме диодов, таким образом сохранится преимущество direct connect и проводимость медной подложки. Думаю не составит труда сделать вариант чистой замены драйвера без переделки старого, что упростит кастомизацию, однако придется пожертвовать медной подложкой. Много всего хочется сделать, у меня уже больше месяца фонарик лежит в разобранном состоянии.
[Исправлено: Reyden, 10.07.2019 в 13:02] |
113
Reyden, уничтожать родную плату не хотелось бы конечно. Может 2 16мм DTP звезды? Они как раз по размеру и не сильно меньше по плошади.
114
https://intl-outdoor.com/no... [Исправлено: Reyden, 10.07.2019 в 16:14] |
115
Reyden, логику не совсем понял , под диоды же дырки в текстолите?
Все DTP звезды что я видел 1.5-1.6мм. Более толстая звезда приведет к тому что от стекл над тирками нужно отказаться. Резон в этом есть т.к. они тонкие и фиг достанешь если что. (У меня уже 2 разбились ![]() Если за мощностью не гнаться и ограничиться 1.5А на диод. То есть на virence интересные звезды 10мм*1мм , под ничиа Е21, Е17. Но это уже экзотика... [Исправлено: AEDe, 10.07.2019 в 15:50] |
116
Ну да, прикручиваем звезду с диодом, сверху устанавливаем драйвер с дырками под led.
Отказ от стекла приведет к ухудшению герметичности. Гладкая тирка будет в царапинах. [Исправлено: Reyden, 10.07.2019 в 16:21] |
117
Особо не зачем, в принципе пригодиться может, но тут скорее сложность в переделке. Сдуть все детали, напаять новые диоды. припаять эту звезду к новому драйверу. Если на просто сменить один модуль на другой тыкнув 3 раза паяльником я желающих знаю и найду, то на такое нужно и времени больше и опыта соответственно желающих явно меньше будет.
первое нет , а второе да. Палка о двух концах ни то, ни другое не идеально. [Исправлено: AEDe, 10.07.2019 в 17:31] |
118
Можно не отпаивать, оставить не светомодуле. |
120
Отпаиваем со светомодуля все кроме led. Поверх накладываем драйвер на текстолите с дырками под led.
Я себе поставлю миниатюрные omron как в мышке. Чего хочет народ я не знаю, ни разу не слышал пожеланий по кнопкам. |
