Просмотров в теме 60409   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 06.05.2021, 04:22 Автор темы   81
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
ULTON ST Edge Clone RTA Rebuildable Vape Atomizer w/ Air Pins 2.0ml 22mm $26.59
ULTON ST Edge Clone RTA Rebuildable Tank Vape Atomizer holds 2.0ml capacity with top filling system in 22mm diameter. With 510 threading connection, ULTON ST Edge Clone RTA is compatible with most of your favorite mods, delivering MTL / DL vaping experience. ULTON ST Edge Clone RTA comes with 8 x Airpins, including 1.2mm / 3.0mm Airpins, 0.8mm / 1.0mm / 1.5mm MTL Airpins and 1.8mm / 2.0mm / 2.5mm DL Airpins, which can be exchanged easily without opening RTA.
3FVAPE вне форума   Вверх
Старый 10.05.2021, 05:02 Автор темы   82
3FVAPE
YFTK FeV Flash-e-Vapor VS Dual Clone RTA Rebuildable Tank Vape Atomizer 3.0ml 17mm $21.99
YFTK FeV Flash-e-Vapor VS Dual Clone RTA Rebuildable Tank Vape Atomizer in 17mm diameter is constructed from 316 stainless steel and comes with 3.0ml PSU tank tube. The FeV VS Dual RTA is with bottom refilling system. Comes with 4 air pin screws for airflow adjustable: 1 x sealed / 1 x 1.1mm / 1 x 1.2mm / 1 x 1.4mm.
Original Vandy Vape Pulse BF Squonk Mechanical Box Mod 1 x 18650 / 20700 Original Price $39.99, Now Only $14.99.
Original Vandy Vape Pulse BF Box Mod, an affordable squonk mod for everyone, is powered 1 x 20700 battery, and can be compatible with 18650 by using battery adapter (battery not included). The Pulse BF Box Mod features lockable power switch for safety concern, spring loaded 510 connection, 8ml food grade silicone bottle for squonking and replaceable front and back panels. 3 color: Pink / Ultem / Black + Grey
Original Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit 1 x 18650 / 21700 $124.99
Original Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit consists of a Dovpo X Suicide Mods Abyss 60W Mod and a Refillable Tank Atomizer. Dovpo X Suicide Mods Abyss 60W VW Mod is powered by 1 x 18650 / 21700 battery (Battery not included) with power output of 5~60W. Equipped with Dovpo Chipset, Dovpo X Suicide Mods Abyss Mod comes with the Nautilus Coil adaptor bridge. In addition, Constructed from Aluminum Alloy and Stainless Steel, Dovpo X Suicide Mods Abyss AIO is also compatible with additional bridges for the Caliburn G, EUC, PnP / GTX, Nord Coils and ETHER RBA Bridge (Not included), allowing you to turn AIO kit into a Side by Side device. Dovpo X Suicide Mods Abyss Refillable Tank Atomizer adopts side filling system, delivering you an excellent vaping experience. 7 colors: Mars / Nato / Tidal / Amesthyst / Storm / Onyx / Classic
Mission Tips Whistle V2 Clone Drip Tip w/ Airflow Bores for BB / Billet Box Mod Kit $7.99
Mission Tips Whistle V2 Clone Drip Tip with Airflow Bores is suitable for BB / Billet Box Mod Kit. Mission Tips Whistle V2 Clone Drip Tip is made of stainless steel and POM and comes with swappable airflow bores: 4.6 mm (without drip tip), 4.5mm, 3.5mm, 2.5mm, 1.5mm. 3 optional colors: Red / Yellow / Green
Replacement Button for BB Clone Bellit Box Mod $5.99
The replacement button is made from POM with polished finish. It is suitable for Billet BB Clone Box Mod. 3 optional colors: Red / Yellow / Green. 1 PC / Pack
Старый 11.05.2021, 04:45 Автор темы   83
3FVAPE
Original Damn Vape Mongrel RDA Rebuildable Dripping Vape Atomizer 25.4mm / 26mm Subway Edition Original Price $29.99, Now Only $23.99.
Original Damn Vape Mongrel RDA Subway Edition, a single coil rebuildable dripping vape atomizer / squonker in 25.4mm (stainless steel top cap) or 26mm (glass top cap) diameter, is made by Damn Vape & Deuces Jack (Vaping Insider). Mongrel RDA Subway Edition adopts a dual post deck designed for single coil build, with two terminals per post, easy to operation. Air enters the coil from the bottom through the center hole. Two different airflow inserts are included in the package. Full airflow insert makes air flow freely while restricted airflow insert restricts this flow. Damn Vape Mongrel RDA Subway Edition possesses 9.5mm deep juice wells with 1.5ml capacity, offering plenty of vaping before dripping is needed. With 510 threading connection, Mongrel RDA Subway Edition is suitable for squonking mod. 5 optional colors: Purple / Green / Blue / Red / Pink
Original Damn Vape Mongrel RDA Replacement Build Deck $6.99
Original Damn Vape RDA Deck is designed for Damn Vape Mongrel RDA Rebuildable Dripping Vape Atomizer. 1 PC / Pack
Старый 12.05.2021, 04:57 Автор темы   84
3FVAPE
SXK DotMission Clone RBA Bridge for DotMod DotAIO AIO Pod Original Price $28.9, Now Only $26.9.
SXK DotMission Clone RBA Bridge supports side filling system and comes with Variable airflow controls (1.2mm, 2.1mm, 3.5mm), especially designed for DotMod DotAIO AIO Pod.
Original Vaporesso GTX GO 80 Pod System Pen Vape Starter Kit 3000mAh 5.0ml $25.99
Original Vaporesso GTX GO 80 Pod System Vape Starter Kit, a pen-shaped vape kit, includes 3000mAh GTX GO 80 Pod Mod and 5.0ml GTX Pod 26. GTX GO 80 Pod Mod is powered by a 3000mAh built-in battery, enough to provide the power output of 5~80W. Controlled by intelligent chipset, GTX GO 80 Pod Mod can adjust the power output automatically according to the coil you installed. GTX Pod 26 holds 5.0ml capacity with top filling system and adopts SSS Leak-Resistant Technology, which make it seal comprehensively, saturate properly and store safely juice. With adjustable airflow design, GTX Pod 26 is compatible with GTX series coil, including an RBA finish, only GTX 0.2ohm Mesh Coil included (suggested wattage: 45~60W), delivering an amazing vaping experience.
Original Vaporesso GTX GO 40 Pod System Pen Vape Starter Kit 1500mAh 3.5ml $21.99
Original Vaporesso GTX GO 40 Pod System Vape Starter Kit, a portable pen-shaped pod kit, includes 1500mAh GTX GO 40 Pod Mod and 3.5ml GTX Pod 22. GTX GO 40 Pod Mod is powered by a 1500mAh built-in battery with Type-C 5V / 1A charging, enough fire up to 40W (5~40W). Controlled by upgraded chipset, GTX GO 40 Pod Mod can intelligently adjust the power output according to the coil you installed. GTX Pod 22 holds 3.5ml capacity with top filling system. With adjustable airflow design, GTX Pod 22 is compatible with GTX series coil, including an RBA finish, only GTX 0.6ohm Mesh Coil included (suggested wattage: 20~30W), bringing an excellent vaping experience. GTX 22 Pod Cartridge adopts SSS Leak-Resistant Technology, which make it seal comprehensively, saturate properly and store safely juice.
Original Vaporesso GTX GO 40 Pod Kit Replacement GTX 22 Pod Cartridge 3.5ml $4.99
Original Vaporesso GTX Pod 22 holds 3.5ml capacity with top filling system, designed for Vaporesso GTX GO 40 Pod System Vape Starter Kit. GTX Pod 22 is compatible with GTX series coil (coil not included). GTX 22 Pod Cartridge adopts SSS Leak-Resistant Technology, which make it seal comprehensively, saturate properly and store safely juice. 2 PCS / Pack
Original Vaporesso GTX GO 80 Pod Kit Replacement GTX 26 Pod Cartridge 5.0ml $5.99
Original Vaporesso GTX Pod 26 holds 5.0ml capacity with top filling system, designed for Vaporesso GTX GO 80 Pod System Vape Starter Kit. GTX Pod 26 is compatible with GTX series coil (coil not included). GTX 26 Pod Cartridge adopts SSS Leak-Resistant Technology, which make it seal comprehensively, saturate properly and store safely juice. 2 PCS / Pack
Original ETU Replacement PC Front + Back Cover Panel Plate for Dotaio Mini Vape Pod System Kit $10.9
Original ETU Replacement Front + Back Cover Panel Plate is made of PC, designed for for Dotaio Mini Vape Pod System Kit. 2 PCS / Pack
Light Emergency Signal Rotating Light IP65 Magentic Car Light Traffic Safety Warning Lights $10.99
This safety warning lamp, a small intermittent light, is powered by 6Ir61 9v alkaline battery (not included). This outdoor light aims to be a warning light in traffic emergencies, like in a car breakdown or a car accident and emit a horizontal flash of yellow / white light of 360 degrees, which can reach one kilometer far. With IP65 waterproof and magnetic design, signal rotating light can be put on any metal and plain surface, like on the roof of your car.
Старый 13.05.2021, 04:54 Автор темы   85
3FVAPE
Original Coilology MTL Clapton Ni80 Spool Wire for RDA / RTA / RDTA Vape Atomizer 5.2ohm 28GA / 40GA $5.99
Original Coilology MTL Clapton Spool Wire features 28GA / 40GA gauge and 5.2ohm resistance value per feet, perfect for RBA / RTA / RDA atomizers. Coilology MTL Clapton Ni80 Spool Wire comes in a plethora of options, ranging from, Fused, Framed, and Clapton styles, all especially machine-twisted for a precise weave and high consistency throughout each spool, which will be a good choice for DIY.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT Nord Rebuildable Coil Kit 0.6ohm Original Price $9.99, Now Only $5.99.
Original Wotofo SMRT Nord Rebuildable Coil Kit includes 1 x SMRT Nord Rebuildable Coil, 6 x 0.6ohm Mesh Strip, 6 x Cotton Strip, 1 x Accessory Bag, 1 x Coiling Rod, 1 x User Manual. Wotofo SMRT Nord Rebuildable Coil is interchangeable with SMOK nord Coil series, such as Nord, Nord 2, Fetch mini, Priv N19 kit and so on.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT Nord Meshed-Cotton Set 0.6ohm Original Price $9.99, Now Only $5.99.
Original Wotofo SMRT Nord Meshed-Cotton Set is designed for Wotofo SMRT Nord Rebuildable Coil, including 10 x 0.6ohm Mesh Strip (suggested wattage: 20W), 10 x Cotton Strip. Wotofo SMRT Nord Meshed + Cotton Set firstly need to be installed in Coil shell (not included) to be a complete and usable coil, next perfectly applied in Wotofo SMRT Pod System Starter Kit and Wotofo SMRT Pod Cartridge.
Original Wotofo SMRT Pod Kit /Pod Cartridge Replacement SMRT Nord Rebuildable Coil Pack 0.6ohm Mesh Strip Original Price $14.99, Now Only $9.99.
Original Wotofo SMRT Nord Rebuildable Coil Pack includes 1 x SMRT nord Rebuildable Coil, 6 x 0.6ohm Mesh Strip, 6 x Cotton Strip, 1 x Accessory Bag, 1 x Coiling Rod, 1 x Cutter, 1 x Carry Case, 1 x Cleaning Cloth. Wotofo SMRT nord Rebuildable Coil is interchangeable with SMOK nord Coil series, such as Nord, Nord 2, Fetch mini, Priv N19 kit, etc.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM Rebuildable Coil Kit 0.4ohm / 0.6ohm Original Price $9.99, Now Only $5.99.
Original Wotofo SMRT RPM Rebuildable Coil Kit includes 1 x SMRT RPM Rebuildable Coil, 3 x 0.4ohm Mesh Strip, 3 x 0.6ohm Mesh Strip, 6 x Cotton Strip, 1 x Coiling Rod, 1 x Accessory Bag, 1 x User Manual. SMRT RPM Rebuildable Coil is interchangeable with SMOK RPM Coil series, such as MORPH POD-40, RPM40W, RPM80, RPM80 Pro, ect.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM Meshed-Cotton Set 0.4ohm Original Price $9.99, Now Only $5.99.
Original Wotofo SMRT RPM Meshed-Cotton Set is designed for Wotofo SMRT RPM Rebuildable Coil, including 10 x 0.4ohm Mesh Strip, 10 x Cotton Strip. Wotofo SMRT RPM Mesh + Cotton Set firstly need to be installed in Coil shell (not included) to be a complete and usable coil, next perfectly applied in Wotofo SMRT Pod System Starter Kit and Wotofo SMRT Pod Cartridge. SMRT RPM Meshed-Cotton Set 0.6ohm is also available.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM Rebuildable Coil Pack 0.4ohm / 0.6ohm Original Price $14.99, Now Only $9.99.
Original Wotofo SMRT RPM Rebuildable Coil Pack includes 1 x SMRT RPM Rebuildable Coil, 3 x 0.4ohm Mesh Strip, 3 x 0.6ohm Mesh Strip, 6 x Cotton Strip, 1 x Coiling Rod, 1 x Accessory Bag, 1 x User Manual, 1 x Cutter, 1 x Carry Case, 1 x Cleaning Cloth, 1 x User Manual. Wotofo SMRT RPM Rebuildable Coil is interchangeable with SMOK RPM Coil series, such as MORPH POD-40, RPM40W, RPM80, RPM80 Pro, ect.
Старый 14.05.2021, 05:41 Автор темы   86
3FVAPE
Original OBS Engine 100W VW Mod + Engine S Tank Vape Mod Kit 1 x 18650 / 20700 / 21700 6ml Original Price $55.99, Now Only $45.99.
Original OBS Engine 100W Vape Mod Kit includes an OBS Engine 100W VW Variable Wattage Mod and a 6.0ml Engine S Sub Ohm Tank Atomizer. OBS Engine 100W VW Box Mod is powered by 1 x 18650 / 20700 / 21700 battery (not included) with Type-C charging, enough to provide power output of 100W (5~100W). Equipped with a 0.96 inch LED screen, OBS Engine 100W Mod is constructed from zinc alloy frame and resin battery sleeve. OBS Engine S Sub Ohm Tank Atomizer holds 6.0ml capacity with easy top filling system in 25.5mm diameter. With airflow control system on the bottom and 810 drip tip, OBS Engine S Tank is compatible with the latest E Mesh series coil, like 1 x E1 0.4ohm Mesh Coil (Suggested wattage: 45~55W, Best: 50W), 1 x E2 0.2ohm Mesh Coil (50~70W, 60W) include, bringing you an amazing vaping experience. Two optional frame series: Silver / Gunmetal
Original OBS Engine 100W VW Variable Wattage Vape Box Mod 1 x 18650 / 20700 / 21700 Original Price $38.99, Now Only $30.99.
Original OBS Engine 100W VW Variable Wattage Vape Box Mod is powered by 1 x 18650 / 20700 / 21700 battery (not included) with Type-C charging and power output of 5~100W. OBS Engine 100W VW Mod is constructed from zinc alloy frame and resin battery sleeve. OBS Engine 100W Mod is equipped with a 0.96 inch LED screen, a great VW box mod for your favorite atomizers with 510 threading connection, especially like OBS Engine S Sub Ohm Tank Atomizer. Two optional frame series: Silver / Gunmetal
Original Innokin Endura T22 Pro Pod Vape Mod Kit 3000mAh 4.5ml Endura T22 Pro Tank $39.99
Original Innokin Endura T22 Pro Pod Vape Mod Kit consists of an Endura T22 Pro 3000mAh Pod Mod and a 4.5ml Endura T22 Pro Sub Ohm Tank Atomizer. Innokin Endura T22 Pro Pod Mod is powered by a 3000mAh built-in battery with Type-C charging. Constructed from durable aluminum alloy and zinc alloy, Endura T22 Pro Pod Mod supports 4 level adjustable wattages: 9.5W, 11W, 12.5W, 13.5W, a great pod mod for your own atomizers with 510 threading connection. Innokin ENDURA T22 Pro Sub Ohm Tank Atomizer holds 4.5ml capacity with convenient top filling system. ENDURA T22 Pro Tank is compatible with T18E coils / M18 coils (both not included), absolute delivering an unrivaled vaping experience. Multiple colors for your choice.
Original Innokin GO Z Pen Vape Starter Kit 1500mAh 2.0ml GO Z Sub Ohm Tank $14.99
Original Innokin GO Z Vape Starter Kit includes an Innokin GO S 1500mAh Pen Battery Mod and an 2.0ml Innokin GO Z Sub Ohm Tank Atomizer 22mm. Innokin GO S Pen Mod is powered by a 1500mAh built-in battery and equipped with a tri-color LED indicator for you to check the battery status. Constructed from durable stainless steel, GO S Pen Mod is with a matte textured surface, comfortable to hold it in hand. Controlled by intelligent chipset, Innokin GO S Mod can automatically adjust wattage output according to the coil you installed (coil not included). Innokin GO Z Sub Ohm Tank Atomizer holds 2.0ml capacity with top filling system in 22mm diameter. With airflow adjustment design on the bottom, Innokin GO Z Tank is compatible with Z coil (not included), suitable for most of your favorite mods with 510 threading connection. 5 optional colors: Black / Gun Metal / Silver / Pink / Blue
Original OBS Engine S Sub Ohm Tank Clearomizer Vape Atomizer 6.0ml 25.5mm Original Price $19.99, Now Only $14.99.
Original OBS Engine S Sub Ohm Tank Clearomizer Vape Atomizer holds 6.0ml capacity with easy top filling system in 25.5mm diameter. With airflow control system and 810 drip tip, OBS Engine S Tank is compatible with the latest E Mesh series coil, like 1 x E1 0.4ohm Mesh Coil (Suggested wattage: 45~55W, Best: 50W), 1 x E2 0.2ohm Mesh Coil (50~70W, 60W) included in the package, a great vaping partner for your most of mods with 510 threading connection, like OBS Engine 100W VW Vape Box Mod or a alternative tank for OBS Engine 100W Vape Mod Kit. 3 optional colors: SS / Black / Gun Metal
Original Innokin Endura T22 Pro Sub Ohm Tank Clearomizer Vape Atomizer 4.5ml $12.99
Original Innokin ENDURA T22 Pro Sub Ohm Tank Clearomizer Vape Atomizer holds 4.5ml capacity with convenient top filling system. ENDURA T22 Pro Tank is compatible with T18E Coil / M18 coils (both not included). Innokin ENDURA T22 Tank is with 510 threading connection, thus compatible with most mods, like Innokin Endura T22 Pro Pod Mod and Innokin Endura T22 Pro Pod Mod Kit. 3 optional colors: Silver / Black / Gun Metal
Original Innokin GO Z Sub Ohm Tank Clearomizer Vape Atomizer 2.0ml 20mm $6.99
Original Innokin GO Z Sub Ohm Tank Clearomizer Vape Atomizer holds 2.0ml capacity with slide-to-open top filling system. With airflow adjustment design on the bottom, Innokin GO Z Tank is compatible with Z coil (not included), suitable for most of your favorite mods with 510 threading connection, especially for Innokin GO Z Vape Starter Kit, Innokin GO S Pen Mod. 4 optional colors: Transparent / Pink / Blue / Black
Original OBS Engine 100W Mod Kit / Engine S Tank Atomizer Replacement OBS E1 Coil Head 0.4ohm $11.99
Original OBS E1 Coil Head is with 0.4ohm resistance (suggested wattage: 45~55W, best: 50W), designed for OBS Engine S Sub Ohm Tank Clearomizer Vape Atomizer and OBS Engine 100W Vape Mod Kit. OBS E2 Coil Head 0.2ohm is also available. 5 PCS / Pack
Original Auguse 510 Drip Tip for RBA / RTA / RDA Atomizer $4.99
Original Auguse 510 Drip Tip consists of a PEI mouthpiece, a base and an insert. It is suitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector. Insert diameter: about 3.16mm. 3 optional colors: Brown PEI / Transparent PC / Black PC. 1 PC / Pack
Старый 15.05.2021, 05:15 Автор темы   87
3FVAPE
Original Eleaf iStick Pico Plus Vape Kit 75W VW Box Mod + Melo 4S Sub Ohm Tank 1 x 18650 4.0ml $50.99
Original Eleaf iStick Pico Plus Vape Mod Kit includes an Eleaf iStick Pico Plus 75W VW Box Mod and a 4.0ml Melo 4S Sub Ohm Tank Atomizer. Eleaf iStick Pico Plus 75W VW Box Mod is powered by 1 x 18650 battery (not included) with Type-C charging. Equipped with OLED display screen, Eleaf iStick Pico Plus Mod features all-time stable technology, compatible with atomizers up to 25mm with 510 threading connection. Monitored by smart chipset, Eleaf iStick Pico Plus 75W Mod support VW 1~75W mode, TC 100~315'C mode Bypass mode and has smart coil protection function for no dry hit and purer flavor. Melo 4S Sub Ohm Tank Atomizer holds 4.0ml capacity with top filling system in 25mm diameter. With bottom adjustable airflow system, Melo 4S Tank is compatible with EC-A series coil, which utilizes innovative and reliable AST-Steel inside, 1 x EC-A 0.3ohm Coil, 1 x EC-A 0.5ohm Coil included, for DL / RDL vaping experience.
Original Eleaf iStick Pico Plus 75W VW Variable Wattage Vape Box Mod 1 x 18650 $31.99
Original Eleaf iStick Pico Plus 75W VW Variable Wattage Vape Box Mod is powered by 1 x 18650 battery (not included), enough to fire up to 75W (1~75W). Monitored by smart chipset, Eleaf iStick Pico Plus 75W Mod support VW mode, TC 100~315'C mode Bypass mode and has smart coil protection function for no dry hit and purer flavor. Eleaf iStick Pico Plus Mod features OLED display screen and all-time stable technology, a vaping partner for your favorite atomizers up to 25mm with 510 threading connection, like Eleaf Melo 4S Sub Ohm Tank Atomizer (not included).
Original Voopoo VINCI II 2 Pod System Vape Mod Kit 1500mAh 6.5ml $30.99
Original Voopoo VINCI II 2 Pod System Vape Mod Kit, a button-activated / draw-activated pod kit, includes a Voopoo VINCI II 2 50W Pod Mod AND A 6.2ml VINCI II 2 Pod Cartridge. VINCI II 2 Pod Mod is powered by a 1500mAh built-in battery with power output of 5~50W. Integrated with Gene.AI 2.0 chip, VINCI II Pod Mod provides dual UI screen, puff record, smart and RBA modes and so on. Constructed from zinc alloy, VINCI II 2 50W Pod Mod supports Auto mode and Manual mode and adopts innovative infinite airflow system. VINCI II 2 Pod Cartridge holds 6.5ml capacity with side filling system. VINCI II PCTG Pod Cartridge is compatible with all Voopoo PnP series coil, only 1 x PnP-VM1 Coil 0.3ohm (suggested wattage: 32~40W) and 1 x PnP-TM2 Coil 0.8ohm (12~18W) included.
Original Voopoo VINCI X 2 80W Pod System Vape Mod Kit 1 x 18650 6.5ml $33.99
Original Voopoo VINCI X 2 80W Pod System Vape Mod Kit, a draw, button, draw & button activated pod kit, includes a Voopoo VINCI X 2 80W Pod Mod and a 6.5ml Voopoo VINCI X 2 Pod Cartridge. Voopoo VINCI X 2 80W Pod Mod is powered by 1 x 18650 battery (not included) with Type-C charging. Integrated with 1.08 inch TFT color screen, Voopoo VINCI X 2 Pod Mod is designed with infinite airflow system for great vaping. Monitored by GENE.AI 2.0 chipset, Voopoo VINCI X 2 Pod Mod supports dual different styles UI themes, VW 5~80W mode, Smart, RBA Modes. In addition, equipped with smart wattage detection, the VINCI X 2 will detect the resistance of the coil and deploy a wattage ceiling to prevent the coil from prematurely burning but can be bypassed in RBA mode to select the desired wattage outside of the prescribed wattage range. VINCI X 2 PCTG Pod Cartridge holds 6.5ml capacity with side filling system. VINCI X 2 Pod Cartridge is compatible with all Voopoo PnP series coil, only 1 x 0.3ohm PnP-VM1 Coil (32~40W), 1 x 0.15ohm PnP-VM6 Coil (60~80W) included, for DL vaping experience.
Original Wake RTA Rebuildable Tank Vape Atomizer 3.3ml 24mm Original Price $40, Now Only $7.99.
Original Wake RTA Rebuildable Tank Vape Atomizer holds 3.3ml capacity in 24mm diameter. It is constructed from Matte anodized aluminum (top cap and airflow ring) and gold plated stainless steel (deck, chamber and 510 pin) and acrylic flavor-bore drip tip. The postless build deck supports dual post configuration and is very easy to build.
Original Voopoo VINCI II 2 / VINCI X 2 Pod Mod Kit Replacement Pod Cartridge 6.5ml $6.99
Original Voopoo VINCI Pod Cartridge holds 6.5ml capacity with side filling system, designed for Voopoo VINCI II 2 Pod System Vape Mod Kit and Voopoo VINCI X 2 80W Pod System Vape Mod Kit. Made of PCTG, this Pod Cartridge is compatible with all Voopoo PnP series coil (not included). 2 PCS / Pack
Старый 17.05.2021, 04:48 Автор темы   88
3FVAPE
Original Eleaf Melo 4S Sub Ohm Tank Clearomizer Vape Atomizer 4.0ml 25mm $20.99
Original Eleaf Melo 4S Sub Ohm Tank Clearomizer Vape Atomizer holds 4.0ml capacity with top filling system in 25mm diameter. With 510 threading connection, Eleaf Melo 4S Tank features bottom adjustable airflow system, compatible with most mods, like Eleaf iStick Pico Plus 75W VW Box Mod and Eleaf iStick Pico Plus Kit 75W (not included). Melo 4S Tank is compatible with the newly developed EC-A series coil, EC-A coil which utilizes innovative and reliable AST-Steel inside, 1 x EC-A 0.3ohm Coil, 1 x EC-A 0.5ohm Coil included, delivering an amazing DL / RDL vaping experience. 2 optional colors: Silver / Black
Original Wake RTA, a 24mm rebuildable tank atomizer, holds 3.3ml e-juice capacity. It is constructed from Matte anodized aluminum (top cap and airflow ring) and gold plated stainless steel (deck, chamber and 510 pin). The postless build deck supports dual post configuration and is very easy to build. An acrylic flavor-bore drip tip is included. 3 optional colors: Red / Green / Black
Original Eleaf iStick Pico Plus Mod Kit / Melo 4S Tank Replacement EC-A Coil Head 0.15ohm $12
Original Eleaf EC-A Coil Head is with 0.15ohm resistance, designed for Original Eleaf iStick Pico Plus Vape Mod Kit and Eleaf Melo 4S Sub Ohm Tank Clearomizer Vape Atomizer. EC-A Coil Head 0.3ohm / EC-A Coil Head 0.5ohm are also available. 5 PCS / Pack
Старый 18.05.2021, 05:07 Автор темы   89
3FVAPE
Original Auguse Era Pro RTA Rebuildable Tank Vape Atomizer w/ Air Pin 4.0ml 22mm $35.99
Original Auguse Era Pro RTA Rebuildable Tank Vape Atomizer, a single coil RTA with dual posts design, holds 4.0ml capacity with top filling system in 22mm diameter. Original Auguse Era Pro RTA adopts AFC ring with 7 level airflows: 1.6mm x 3.6mm, 1.8mm, 1.6mm, 1.4mm, 1.2mm, 1.0mm, 0.8mm. In addition, With bottom airflow and side airflow system, Original Auguse Era Pro RTA features 4 customizable airflow sizes for the side airflow: 0.8mm / 1.0mm (Pre-installed) / 1.2mm / Holeless airflow control pin (included) and comes with 3pcs x 1.0mm airflow pin for the bottom airflow, meeting your personal vaping demands. With 510 threading connection, Original Auguse Era Pro RTA comes with 1 x 0.86ohm Coil, 1 x 0.68ohm Coil, a good vaping partner for most of your favorite mods. 2 optional colors: Silver / Black
SXK ST Steam Tuners EDGE Clone RTA Rebuildable Tank Vape Atomizer 2.0ml 22mm Original Price $27.9, Now Only $24.9.
SXK ST Steam Tuners EDGE Clone RTA, the first SteamTuners rebuildable tank vape atomizer, holds 2.0ml capacity with top filling system in 22mm diameter. EDGE has a unique ULTEM Inner Sleeve that doubles as a heat reduction element and a wicking assist marker. In addition, SXK EDGE Clone RTA adopts a unique deck design with one mission, extremely easy for wicking and wiring. SXK EDGE Clone RTA is compatible with 8 center airpins: 0.8mm / 1.0mm / 1.2mm / 1.5mm / 1.8mm / 2.0mm / 2.5mm / 3.0mm (Comes with 1.2mm and 3.0mm, others are not included), delivering MTL / DL vaping experience.
Original Reewape RUOK K8-CV1 0.3ohm Mesh Coil Head for Voopoo Drag MAX/ Drag X /Vinci /Vinci X /Argus Pro/PNP 22 Tank $6.99
Original Reewape RUOK K8-CV1 0.3ohm Mesh Coil Head is compatible with Voopoo PNP Coils (not included) and suitable for Voopoo Drag MAX / Drag X / Drag S, Voopoo Vinci / Vinci X / VINICR, Voopoo ARGUS / ARGUS GT, Voopoo ARGUS X / ARGUS Pro Kit and Voopoo PNP 22 Pod Tank. 4 PCS / Pack
Original Reewape RUOK K8-CS1 0.4ohm Mesh Coil Head for SMOK Nord 2/Nord X /RPM40 /Fetch /Scra P3 /RPM Lite/POZZ-X Kit $6.99
Original Reewape RUOK K8-CS1 0.4ohm Mesh Coil Head is compatible with SMOK RPM coils (not included) and suitable for SMOK Nord 2 / Nord X, SMOK RPM40 / RPM80 / RPM80 Pro, SMOK Fetch / Fetch Pro, SMOK Scra P3 / Scra P5, SMOK Alike, SMOK RPM 2/ RPM 2S / RPM Lite, SMOK POZZ-X Kit. 4 PCS / Pack
SXK EDGE Clone RTA Replacement Extension Tank Tube 2.8ml Original Price $7.9, Now Only $6.5.
SXK Extension Tank Tube with 2.8ml capacity is designed for SXK EDGE Clone RTA Rebuildable Tank Vape Atomizer. Two optional matarial: PEI / PC. 1 PC / Pack
SXK EDGE Clone RTA Replacement MTL Airpin Set 0.8mm / 1.0mm / 1.5mm Original Price $7.9, Now Only $6.5.
SXK MTL Airpin Set includes 0.8mm / 1.0mm / 1.5mm MTL Airpin, designed for SXK EDGE Clone RTA Rebuildable Tank Vape Atomizer. SXK DL Airpin Set 1.8mm / 2.0mm / 2.5mm is also available. 3 PCS / Pack
Original Auguse Era Pro RTA Replacement Decorative Ring $2.99
Original Auguse Decorative Ring is made of anodized aluminum, designed for Auguse Era Pro RTA Rebuildable Tank Vape Atomizer. 5 optional colors: Silver / Red/ Blue / Black / Yellow. 1 PC / Pack
Original Auguse Era Pro RTA Replacement Tank Tube 22mm $3.59
Original Auguse Tank Tube is designed for Auguse Era Pro RTA Rebuildable Tank Vape Atomizer. 4 options: PEI Yellow / PC Transparent / Glass Transparent / Glass Translucent. 1 PC / Pack
Original Auguse Era Pro RTA Replacement SS Airflow Pin Set 1.5mm $4.99
Original Auguse SS Airflow Pin Set including 2 PCS x 1.5mm, is the bigger airflow pins for the side airflow of Auguse Era Pro RTA Rebuildable Tank Vape Atomizer. Auguse SS Airflow Pin Set 1.8mm is also available. 2 PCS / Pack
Старый 19.05.2021, 04:46 Автор темы   90
3FVAPE
"Original ThunderHead Creations Tauren Solo RDA Rebuildable Dripping Atomizer w/ BF Pin 2.0ml 24mm $20.99
Original ThunderHead Creations TAUREN SOLO RDA, an innovative single coil rebuildable tank vape atomizer, comes with unique triple sides with 31-micro air holes, providing the smoothest airflow and intense flavor for vapers. Featuring the stylish appearance TAUREN SOLO RDA always makes it attractive and eye-catching. It is compatible to Tauren MOD. Just get the TAUREN SOLO RDA and enjoy excellent vaping. This RDA comes with bottom feeder pin.
"Original ThunderHead Creations Tauren Solo RDA Replacement Glass Shell $5.99
Original ThunderHead Creations Glass Shell is designed for ThunderHead Creations Tauren Solo RDA Rebuildable Dripping Vape Atomizer. 1 PC / Pack
"Original ThunderHead Creations Tauren MAX RDA Replacement Ceramic Deck $4.99
Original ThunderHead Creations Ceramic Deck is designed for ThunderHead Creations Tauren MAX RDA Rebuildable Dripping Vape Atomizer. 1 PC / Pack
"Original Reewape RS333 510 Acrylic Drip Tip for RBA / RTA / RDA Atomizer $1.89
Original Reewape RS333 510 Drip Tip is made of Acrylic. It is designed for RBA / RTA / RDA atomizer with 510 drip tip connector. 4 optional colors: Translucent Pink / Translucent Blue / Translucent Black / Transparent. 1 PC / Pack
"Original Reewape RS330 810 Drip Tip w/ Air Regulating Ring for RBA / RTA / RDA $1.99
Original Reewape RS330 810 Drip Tip is made of Resin + Steel. RS330 810 Drip Tip features air regulating ring, suitable for RBA / RTA / RDA Vape Atomizer with 810 drip tip connector. 6 colors for your choice. 1 PC / Pack
"Original Reewape RS332 810 Acrylic Drip Tip for RBA / RTA / RDA Atomizer $1.59
Original Reewape RS332 810 Drip Tip is made of Acrylic. RS332 810 Drip Tip is designed for RBA / RTA / RDA atomizer with 810 drip tip connector. 1 PC / Pack
Старый 20.05.2021, 05:30 Автор темы   91
3FVAPE
5AVape Aston Clone RDA BF Squonk Rebuildable Dripping Vape Atomizer 22mm $20.99
5AVape Aston Clone RDA, a low profile flavor oriented Squonk BF RDA, is made of 316 stainless steel in 22mm diameter. The coil is positioned perfectly against asymmetrical airflows. Cotton will be comfortably installed and will take time to swell for optimal nutrition. The sweetness of the airflow and the volume of steam will make the flavors of your e-liquids multiply tenfold. 3 colors: Silver / Matte Silver / Matte Black
Original Innokin Ajax Sub Ohm Tank Clearomizer Vape Atomizer 5.0ml $14.99
The intuitive Innokin Ajax vape tank has a 5.0ml liquid capacity with slide top filling system, easy to use and prevents leakage of electronic liquids. Innokin Ajax tank features dual bottom adjustable airflow for complete control of your inhalation. In addition, Innokin Ajax Sub Ohm Tank Atomizer utilizes the smart wattage identification, matches the wattage output to the installed coil within the Ajax Tank.
Original Sigelei x Suprimo Moonshot RTA Rebuildable Tank Vape Atomizer 2mL 22mm Original Price $35.99, Now Only $7.99.
The Sigelei Moonshot RTA has 2 post deck with VERY LARGE airflow holes on the deck. The top fill design for this RDTA will bring you a happy addition to your collection. Airflow through the Moonshot is manipulated from the elongated cyclops air flow slits located at the base of the tank.
Original Xtar VC4S USB 4-Slot Charger for 18650, 20700, 21700, 26650 Battery $35.99
Original XTAR VC4S USB charger is compatible with 18650, 20700, 21700, 26650 and more batteries. XTAR VC4S USB charger features a bright colorful LCD display, internal resistance detecting, storage mode, grade mode (capacity testing) and much more.
Original ANIX Gemini 2200mAh Dry Herb Vaporizer Kit $23.99
Original ANIX Gemini Vaporizer, a new portable and compact-sized dry herb vape kit, powered by a 2200mAh battery with Type-C charging. ANIX Gemini Vaporizer has an SS306 oven, long/ short mouthpiece sleeves, fully adjustable digital temperature settings, an increased an 0.91 inch OLED screen. Because of its reliable quality, ANIX Gemini has passed strict quality control. This vaporizer features a Stainless Steel Oven with 0.6g dry herb capacity, which has very fast heat-up times and is non-porous. Ovens made from stainless steel are also a lot more durable since this material isn't susceptible to cracks in the case of mechanical shocks or sudden temperature fluctuations. With a reasonably good temperature range of 149~224'C or 300~435'F, there's plenty of potentials to finely tune and control the temperature at which the material vapes. 30 seconds to heat up to 435'F. Come with two mouthpiece sleeves. In addition to the pre-installed short mouthpiece, a longer mouthpiece is also provided. 3 optional colors: Black / Red / Grey
Original Yocan UNI Twist 650mAh Vaporizer Box Mod $26.99
Original Yocan UNI Twist, the first Box Mod that is suitable for various oil atomizers of different diameters range from 6mm to 12mm, is powered by a built-in 650mAh battery with a Type-C charging port on the side, allowing you to keep the UNI Twist upright by charging. This device offers a twist dial for voltage adjustment, mltiple, customized temperature settings as well as the perfect size to take with you all day. It takes all the best things about the UNI and enhances them. It is made of zinc alloy shell, delicate and non-scratch, the size is between UNI and UNI S, durable and portable. You can customize the e-cigarette experience from 1.8V to 4.2V. Just turn the dial to the desired voltage. Yocan UNI Twist supports preheat function for 10 seconds. There are level window, hanging hole, and height adjustment button on the panel between the two twist dials. Specially designed with hanging holes, you can use it with a lanyard or keychain to quickly access the equipment you need. 5 optional colors: Black / Green / Red / Blue / Silver
[Исправлено: 3FVAPE, 20.05.2021 в 05:34]
Старый 21.05.2021, 05:11 Автор темы   92
3FVAPE
Original Steam Crave Hadron Pro DNA 250C 400W VW Box Mod 1600mAh Original Price $199, Now Only $169.99.
Original Steam Crave Hadron Pro DNA 250C Box Mod is powered by a 1600mAh built-in Li-Po 4s battery pack with USB charging, enough to fire up to 400W (1~400W). Monitored by DNA 250C Chipset, Hadron Pro DNA 250C Box Mod supports replay mode, which enables you to capture the flavor and satisfaction of the "perfect puff", and provides the same level of performance and consistency for all subsequent puffs. In addition, Hadron Pro Mod also supports watts boost VW 1~400W and accurate temperature control TC 200~600'F and has a 0.9 inch TFT screen for you to check the data you need. Constructed from Zinc alloy, Hadron Pro DNA 250C VW Box Mod is a great VW box mod for most atomizers with 510 threading connection, like Steam Crave Aromamizer Ragnar RDTA (not included).
Original Steam Crave Hadron Pro Combo Kit DNA 250C Mod +Aromamizer Ragnar RDTA 1600mAh Original Price $249, Now Only $209.99.
Original Steam Crave Hadron Pro Combo Vape Mod Kit is the Steam Crave first DNA 4s LIPO Mod Kit, is consisted of Hadron Pro DNA 250C 400W VW Box Mod and 18ml / 25ml Aromamizer Ragnar RDTA. Steam Crave Hadron Pro DNA 250C Box Mod is powered by a 1600mAh built-in Li-Po 4s battery pack with USB charging, enough to fire up to 400W (1~400W). Monitored by DNA 250C Chipset, Hadron Pro DNA 250C Box Mod supports replay mode, enabling you to capture the flavor and satisfaction of the "perfect puff", and providing the same level of performance and consistency for all subsequent puffs. With advanced Replay Mode, Hadron Pro Mod watts boost VW 1~400W and accurate temperature control TC 200~600'F and has a 0.9 inch TFT screen for you to check the data you need. Steam Crave Aromamizer Ragnar RDTA, a single or dual coil RDTA, holds 18ml / 25ml capacity with top filling system in 35mm diameter. this 35mm RDTA is designed with adjustable side and bottom airflow, 80% of the side airflow and 20% of the bottom, thus creating a smooth and flavorful draw. In addition, Aromamizer Ragnar RDTA adopts postless deck with bottom honeycomb air holes, providing a huge amount of space to draw more flavors from your favorite liquid.
ULTON Rook Clone RPGA Rebuildable Professional Genesis Atomizer w/ BF Pin 3.0ml 22mm Dia $35.99
ULTON Rook Clone RPGA Rebuildable Professional Genesis Atomizer holds 3.0ml capacity in 22mm diameter. ULTON Rook Clone RPGA comes with 2 different bells for mesh and cotton respectively. In addition, this RPGA has external airflow controls, 0.8mm, 1.0mm, 1.2mm, 1.4mm, 1.6mm, 2 x 0.8mm, 2 x 1.0mm, 2 x 1.2mm and 1.5mm slot on the body.
Старый 24.05.2021, 15:33 Автор темы   93
3FVAPE
Authentic Aleader One Lite Pod Kit Replacement Pod Cartridge - 1.4ml (4 PCS) $6.99
Authentic Aleader Pod Cartridge holds 1.4ml capacity, designed for Aleader One Lite Pod System Vape Starter Kit. 4 PCS / Pack
Never Normal Whistle V2 Style 510 Drip Tip for dotMod dotAIO Pod $2.59
Never Normal Whistle V2 Style 510 Drip Tip is suitable for dotMod dotAIO Pod. 1 PC / Pack, multi-color available
510 Drip Tip for RBA / RTA / RDA Atomizer $1.99
This 510 Drip Tip is suitable for RBA / RTA / RDA Atomizer with 510 Drip Tip Set connector.
415 Style 510 Drip Tip Set for RBA / RTA / RDA Vape Atomizer $3.99
415 Four One Five 510 Drip Tip Set is suitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector, including 1 x Drip Tip Base, 1 x PEI Mouthpiece (Brown), 2 x PC Mouthpiece (Translucent Black / Transparent)
Authentic Aleader One Lite Pod System Kit $7.99
Authentic Aleader One Lite Pod System Vape Starter Kit, a compact and portable pod kit, includes an Aleader One Lite 320mAh Pod Mod and a 1.4ml Pod Cartridge.Aleader One Lite Pod Mod is powered by a 320mAh built-in battery and can fire up to 8W.Aleader One Lite Refillable Pod Cartridge holds 1.4ml capacity. Multi-color available
Vapor Giant VG V6S V6 S 2020 RTA Clone $24.99
Vapor Giant VG V6S 2020 clone RTA is made of stainless steel in 23mm diameter. The VG V6 S clone RTA comes with glass tank tube with 5.5ml capacity (pre-installed) and PEI tank tube with 7.0ml capacity (in the package). The V6 S style RTA is with 360 degree removable tank tube.The VG V6 S clone RTA is with top filling system and the liquid control. There are 9 holes in the deck and up to 6 of these 9 holes can be closed with infinitely adjustable Bottom Airflow.
Speed Revolution Clone RDA w/ Bottom Feeder Pin Original Price $14.99, Now Only $5.99.
Speed Revolution clone RDA Rebuildable Dripping Vape Atomizer is constructed from stainless steel and in 18mm diameter. The RDA is with bottom feeder pin for squonk ready. There is no replacement center pin for the RDA.
Bestia Animal Hybrid Vape Mechanical Mod 1 x 18650 / 20700 / 21700 Clone Original Price $14.99, Now Only $10.99.
Bestia Animal clone 18650 Hybrid Mechanical Mod is a hybrid mechanical mod which is constructed from Brass and is powered by 1 x 18650 / 20700 / 21700 battery (not included), with a diameter of 27mm, Bestia Animal clone Mech Mod is equipped with a stylish side switch. This Mod is a beautiful side fire mod with a removable battery adjustable bottom and removable top with delrin insulator. The top insulator creates a barrier for your e-liquid spills so there is much less chance of your juice ending up in your tube.
Bestia Animal 18650 Hybrid Vape Mechanical Mod 1 x 18650 Clone Original Price $14.99, Now Only $9.99.
Bestia Animal clone 18650 Hybrid Mechanical Mod, a hybrid mechanical mod, is powered by 1 x 18650 battery (not included), with a diameter of 24mm, Bestia Animal clone Mech Mod is equipped with a stylish side switch. This Mod is a beautiful side fire mod with a removable battery adjustable bottom and removable top with delrin insulator. The top insulator creates a barrier for your e-liquid spills so there is much less chance of your juice ending up in your tube.
Atto Mechanical Tube Mod Clone Original Price $22.99, Now Only $14.99.
Atto clone mechanical mod is made from Stainless Steel. It is powered by 1 x 18650 / 18350 battery (NOT INCLUDED). The mod is equipped with a MOSFET.
Старый 26.05.2021, 06:58 Автор темы   94
3FVAPE
Original ZQ Essent SE 80W VW Vape Box Mod Original Price $59.99, Now Only $46.99.
original ZQ Vapor Essent SE 80W Mod, It is the most ergonomic box mod that is designed to have a firm grip and makes it comfortable in the palm of your hand. it's have 4 colors Gunmetal, Pacific Blue and Black: upper / lower cover and tube are made from brushed stainless steel, the body is made from aircraft aluminum alloy.
Original Digiflavor Drop Solo RDA V1.5 Rebuildable Dripping Vape Atomizer Original Price $28.99, Now Only $24.99.
The original Digiflavor Drop Solo RDA V1.5 is a single-coil rebuildable dripping atomizer in 22mm diameter with a classic DROP deck. It features side airflow control and adjustable airflow design to bring smooth flavor. Easy coil-feet cutting and easy coil-building will provide you a convenient DIY experience. In addition, you can enjoy great DL & RDL vaping with Drop Solo RDA V1.5.
Original Innokin Coolfire Z80 Box Mod Kit with Zenith II Tank Atomizer $49.99
The Innokin mod kit consist of Innokin Coolfire Z80 Box Mod and Zenith II Tank Atomizer.The primary mode on the interface, FO, extends coil life and boosts flavors using alternating current (ACM) to produce a waveform that runs continuously while you vape. This is made possible by sending an electrical output in two directions across the coil, in a much more precise and efficient way
Original Innokin Zenith II Tank Vape Atomizer 0.8ohm MTL Coil / 0.3ohm RDL Coil $23.99
The original Innokin Zenith II tank vape atomizer features a tighter and smoother MTL vape than previous versions, and coming with outstanding restricted direct lung (RDL) vape. The Zenith II includes two of the newest Z-coils, the 0.8 Ohm flavor maker and the 0.3 Ohm RDL. The Zenith II continues the super simple twist-to-fill top cap and the easy coil replacement system.
Старый 29.05.2021, 11:19 Автор темы   95
3FVAPE
PEI Replacement Frame for dotMod dotAIO SE $85.99
This replacement PEI Frame is suitable for dotMod dotAIO SE Vape Pod System (Not suitable for dotMod dotAIO Frost).
Original Phevanda A2 RTA MTL Air Set - 510 Drip Tip / Air Outer Reducer / 2 x 1.2mm / 2 x 0.9mm Air Reducer / Solid Air Insert $11.99
The original original Phevanda A2 RTA Replacement MTL Air Set, comes with 510 Drip Tip / Air Outer Reducer / 2 PCS Air Reducer (1.2mm) / 2 x Air Reducer (0.9mm) / 1 x Solid Air Insert.
Original Phevanda A2 RTA DL Air Set - 510 Drip Tip / Air Outer Reducer / 2 x 1.2mm / 2 x 0.9mm Air Reducer $10.99
The original original Phevanda A2 RTA Replacement DL Air Set, comes with 510 Drip Tip (4.0mm inner diameter) / Air Outer Reducer (4.0mm inner diameter) / 2 PCS Air Reducer (2 x 1.2mm) / 2 x Air Reducer (2 x 0.9mm)
Original Phevanda A2 RDL RTA Rebuildable Tank Vape Atomizer 4.0ml, 23mm Diameter $39.99
The original Phevanda A2 RDL RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 23mm diameter, the glass tank tube holds 4.0ml capacity. The Phevanda A2 RDL RTA is with top refilling system and bottom airflow control.Comes with RDL Air insert: 2 PCS air reducer (3 x 0.9mm) / 2 PCS air reducer (1.2mm x 3)
Original Digiflavor Torch RTA RGB Breathing Light, 26mm Vape Atomizer Original Price $40, Now Only $25.99.
The original Digiflavor Torch RTA vape Atomizer is Constructed from food-grade material, featuring stylish built-in RGB breathing light, DF Torch RTA lights up the flavor with leakproof Top-to-side Airflow System that enables easy coil-building on innovative Y-shaped electrode pole deck.
Original BP MODS IAIDO DNA 60W Box Mod $149.99
The original BP MODS IAIDO DNA 60W Box Mod is a specialized single 18650 / 18350 battery (not included) switchable VW mod. There are 18350 Adapter and 18650 Adapter for you. And the BP MODS IAIDO Mod has advanced DNA 60 chip inside. So you can get 1~60W adjustable wattage and 200~600'F / 93~315'C adjustable temperature. Moreover, the BP MODS IAIDO Mod is compatible with most 510 atomizer with 24mm diameter. With 96 x 16 OLED screen, the BP MODS IAIDO DNA Mod can clearly display the vaping details. Featuring Type-C 1A fast charging.
Старый 31.05.2021, 12:19 Автор темы   96
3FVAPE
Original Vapefly Galaxies 30W VW Vape Box Mod $29.99
Original Vapefly Galaxies 30W VW Vape Box Mod is powered by a built-in 950mAh battery, it can deliver 5~30W adjustable output power. The rugged mod provides shockproof, dustproof and waterproof. Vapefly Galaxies 30W Box Mod adopts bright monochrome display to clearly show the vaping data. The Mod is charged via USB 5V / 1A. The 3S chip ensures 6 protections for better vaping experience. Vapefly Galaxies 30W Vape Mod is also compatible with Vapefly Galaxies Air Tank for MTL / DL vaping.
Original Vapefly Galaxies 30W Box Mod with Galaxies Air Tank Kit $39.99
Vapefly Galaxies 30W Kit is the smallest rugged mod kit, provides shockproof, dustproof and waterproof. Vapefly Galaxies 30W Mod features built-in 950mAh battery with 30W max output, it would provide a whole day vaping experience. Vapefly Galaxies Air Tank has 2.0ml e-juice capacity and adopts side filling method. The adjustable bottom airflow is suitable for MTL / DL vaping. Galaxies Air Tank is compatible with all Vapefly FreeCore G Series Coil for rich flavor and strong throat-hit.
Original Vapefly Galaxies Air Tank 2.0ml, 0.8ohm / 1.2ohm $14.99
The Original Vapefly Galaxies Air Tank is perfect for Vapefly Galaxies 30W Vape Kit / Vapefly Galaxies Galaxies 30W Vape Box Mod / Vapefly FreeCore Coil. The Vapefly Galaxies Air Tank is compatible with all upcoming FreeCore G series coils. And the Vapefly Galaxies Air Tank comes with Innovative bayonet fit design and simple plug-in coil replacement. Featuring adjustable bottom airflow control system, the Vapefly Galaxies Air Tank supports both MTL and RDL Vaping.
Старый 02.06.2021, 09:34 Автор темы   97
3FVAPE
ShenRay VG Kronos 2 S 2021 clone RDL / MTL RTA Clone Original Price $35.99, Now Only $31.99.
The ShenRay VG Vapor Giant KRONOS 2 S clone RTA is 23mm diameter and can be used with a restrictive DTL or in MTL, it is equipped with a 4.5ml tank. The Kronos 2S clone RTA is designed Made of stainless steel and polycarbonate, The optics of the KRONOS 2S 2 S clone RTA are just as versatile as the airflow. A second polycarbonate tank protection and a second polycarbonate MTL end cap are included. For this rebuildable of simple construction, with a single coil resistance plate, the air circulates directly on the side of the coil, no matter if you go from an airflow for the DTL of 4 x 1.8 mm or those of 2 x 0.8mm for MTL. The Kronos 2S clone RTA thus guarantees silent air intake and intense flavor. The liquid supply will be in the upper part (top cap) to prevent accidental opening and emptying.
Original Wotofo SMRT RPM2 Pod Cartridge Replacement Coil Original Price $9.99, Now Only $5.99.
The Original Wotofo SMRT RPM2 Pod Replacement Coils are perfectly compatible with Wotofo SMRT Pod System Kit with RPM2 Pod Cartridge.
Original Wotofo SMRT Pod Kit Replacement SMRT RPM2 Meshed-Cotton Set Original Price $9.99, Now Only $4.99.
Wotofo nexMESH Extreme: Robust and strong, a vigorously warmer flavor experience, heavy vapor production. 0.20ohm, Best Power: 45~55W
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM2 Rebuildable Coil Pack Original Price $14.99, Now Only $9.99.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM2 Rebuildable Coil Pack Comes with SMRT RPM2 Rebuildable Coil, nexMESH Chill / nexMESH Turbo / nexMESH Extreme mesh coil.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM2 Rebuildable Coil Kit Original Price $9.99, Now Only $4.99.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT RPM2 Rebuildable Coil Kit. Comes with nexMESH Chill / nexMESH Turbo / nexMESH Extreme mesh coil.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT V8 Baby Rebuildable Coil Kit Original Price $9.99, Now Only $4.99.
Original Wotofo SMRT Pod Kit / Pod Cartridge Replacement SMRT V8 Baby Rebuildable Coil Kit. Comes with nexMESH Chill / nexMESH Turbo / nexMESH Extreme mesh coil.
Original Wotofo SMRT RPM2 RBA Coil for Wotofo SMRT Pod System Kit Original Price $9.99, Now Only $5.99.
The SMRT RPM2 RBA Coil is designed especially for the Wotofo SMRT Pod System Kit.
Original Wotofo SMRT RPM2 Pod Cartridge for Wotofo SMRT Pod System Kit - 4.5ml (1 PC) Original Price $5.99, Now Only $2.99.
The Wotofo SMRT Pod Cartridge is the ultimate solution when it comes to ensuring that you can continue enjoying an uninterrupted vaping experience with your Wotofo SMRT Pod System. The simple replacement pod cartridge comes with a 4.5ml capacity and a convenient side filling system. Made using high-quality PCTG material, the Wotofo SMRT Pod Cartridge has been designed specifically for use with the Wotofo SMRT Pod System Starter Kit.
Старый 03.06.2021, 17:12 Автор темы   98
3FVAPE
Original Wotofo SRPNT 24mm DA Rebuildable Dripping Vape Atomizer w/ Squonk Pin Original Price $34.95, Now Only $24.99.
The Authentic Wotofo SRPNT RDA Rebuildable Dripping Vape Atomizer comes with Squonk Pin in 24mm diameter.Meet the SRPNT RDA, the upgraded new member in Wotofo Serpent family! Bold innovation in deck design that guarantees an excellent vape using 5mm ID Claptons.Airflow Holes: Accurate airflow control that offers just the right amount of airflow across the deck.810 Resin Drip Tip: Paired with our 810 resin drip tip whose comfortable rim will improve your vape puff after puff.24mm Deck: The deck is structured to support Besides 5mm ID coils for single build and 3mm ID coils for dual build.
Original Wotofo SRPNT Dual Core Fused Clapton Coil Original Price $4.95, Now Only $2.99.
The Authentic Wotofo SRPNT Dual Core Fused Clapton Coil is made from Ni80 in 0.65ohm resistance. 5mm Inner Diameter. 5 PCS / Pack.
Original Wotofo SRPNT Thick Cotton Strip for RTA / RDA / RDTA Vape Atomizer 5mm (10 PCS) Original Price $4.95, Now Only $3.59.
The Authentic Wotofo SRPNT Thick Cotton Strip is suitable for RTA / RDA / RDTA Vape Atomizer. 5mm diameter and comes with 10 PCS / Pack.
Original Lost Vape Orion DNA GO 40W 950mAh All-in-one Starter Kit Original Price $79, Now Only $39.99.
The Lost Vape Orion DNA GO Kit is the first pod system to utilize a DNA board. The Orion DNA GO not only features safety protections, high efficiency, reliability and durability, but also has highly reputable and precise craftsmanship. The Orion DNA GO features three power output modes and adjustable airflow control to configure your settings for a satisfying mouth-to-lung or direct-lung vape. Once you've found your perfect setting, Replay mode can be activated by simply holding down the adjustment button until the LED indicator turns green. Replay mode is a groundbreaking feature that saves your settings and provides the same level of performance and consistency on all subsequent puffs while preventing dry hits for a truly remarkable vape experience.
Original Tesla Biturbo Mech Mod + Dual RDA Starter Kit Original Price $49.99, Now Only $24.99.
Biturbo Mech is a powerful device that has the ability to fire two RDAs at the same time for greater vapor productions. Users can add two flavors e-liquid into RDAs and enjoy a complex and unique taste. The device is equipped with buttons for channel selection at the bottom, which allows users to choose between using one RDA or two RDAs. And the dual LED lights enables users to know the usage of this device better. All of these are designed to provide you with an unbeatable taste and quality. Innovation leads to changing life!
Original Lost Vape Q Ultra Boost RBA Rebuildable Coil Head for Orion DNA GO / Ultra Pod System Kit / Pod Cartridge Original Price $9.99, Now Only $3.99.
The Q Ultra Boost RBA Rebuildable Coil is perfectly compatible with Lost Vape Orion DNA GO / Q Ultra Kit. Comes with the Ultra Boost RBA deck and accessories bag, perfect for you to build your order coil and enjoy DIY fun
Original AVCT Mesh Coil Kit for Voopoo PnP / Tpp - 0.15ohm, 5 x Cottons, 5 x Ni80 Mesh Original Price $7.99, Now Only $5.99.
The Authentic AVCT Mesh Coil Kit is compatible with Voopoo PnP / Tpp. Comes with 5 x Cottons and 5 x Ni80 Mesh coil.
SXK Delro Style Evolv DNA 60 Chipset 60W TC VW AIO Mod Kit $139
The SXK Delro Style 60W TC VW AIO Mod Kit is built-in 2200mAh battery, The Evolv DNA 60 Chipset supports Wattage adjustable from 1W to 60W. The SXK Delro Style 60W mod kit is compatible with BB accessories.Comes with an Nautilus BVC coil adapter, compatible with Aspire Nautilus coils.
SXK Delro Style 70W EVO 70 Chipset TC VW AIO Mod Kit $98
The SXK Delro Style 70W TC VW AIO Mod Kit is built-in 2200mAh battery, The SEVO 70 Chipset supports Wattage adjustable from 1W to 70W. The SXK Delro Style 70W mod kit is compatible with BB accessories. Comes with an Nautilus BVC coil adapter, compatible with Aspire Nautilus coils.
Original Uwell Havok V1 Pod System Vape Mod Kit $39.18
The authentic Uwell Havok V1 Vape Kit presents an impressive and handsome pod system that is suitable for MTL as well as DTL, or RDL, and therefore meets almost all requirements. The smooth logo and matt surface look exquisite, of course, it is comfortable to hold and feels good in the hand. A resin-style panel is embedded on one side of the device. In addition to the standard power button and a pair of adjustment buttons on the control panel, a 0.96-inch OLED screen for a clear display of all data is added. The upgraded Type-C port is located at the bottom of the device. The battery capacity of the device is 1800mAh with a 65W max output
Original Uwell Havok V1 Pod System / Cartridge Replacement UN2 DTL Coil Heads - 0.25ohm (40~45W) (4 PCS) $10.99
The Authentic Uwell Havok V1 Pod System / Cartridge Replacement UN2 DTL Coil Heads is with 0.25ohm for 40~45W vaping. 4 PCS / Pack
Original Uwell Havok V1 Pod System / Cartridge Replacement UN2 MTL / RDL Coil Heads - 0.6ohm (20~25W) (4 PCS) $10.99
The Authentic Uwell Havok V1 Pod System / Cartridge Replacement UN2 MTL / RDL Coil Heads is with 0.6ohm for 20~25W vaping. 4 PCS / Pack
Original Uwell Havok V1 Pod System Replacement Pod Cartridge + UN2 DTL Coil Heads - 4.0ml, 0.25ohm (40~45W) (4 PC) $6.99
The authentic Uwell Havok V1 Coil Pod Set is a PCTG 4.0ml pod Cartridge, with adjustable airflow for DTL or MTL. Included a single Uwell Havok Coils in a 0.25ohm coil. The Authentic Uwell Havok V1 Pod System / Cartridge Replacement UN2 DTL Coil Heads is with 0.25ohm for 40~45W vaping.
Original Uwell Havok V1 Pod System Replacement Pod Cartridge + UN2 MTL / RDL Coil Heads - 4.0ml, 0.6ohm (20~25W) (1 PC) $6.99
The authentic Uwell Havok V1 Coil Pod Set is a PCTG 4.0ml pod Cartridge, with adjustable airflow for DTL or MTL. Included a single Uwell Havok Coils in a 0.6ohm coil. The Authentic Uwell Havok V1 Pod System / Cartridge Replacement UN2 MTL / RDL Coil Heads is with 0.6ohm for 20~25W vaping.
Старый 04.06.2021, 16:38 Автор темы   99
3FVAPE
Original ThunderHead Creations THC Artemis V1.5 RDTA Rebuildable Dripping Tank Vape Atomizer - 2.0/4.0ml, 24mm, BF Pin Original Price $40.58, Now Only $33.99.
The original ThunderHead Creations THC Artemis RDTA V1.5 comes with postless build deck featuring with strong ceramic clamp system. There are 26 PCS honeycomb airholes from double sides to provide excellent flavor and strong throat hit. Super easy to refill with wide slot design. It also compatible to 2.0ml & 4.0ml capacity in one design.Extra BF pin is offered for daily vaping.
ULTON Gryphus MTL / RDL Mesh / Single Coil RTA Clone - Silver, 26mm Original Price $39.99, Now Only $32.5.
The ULTON Gryphus clone MTL / RDL Mesh / Single Coil RTA Vape Atomizer comes with dual deck (Single coil deck included, mesh coil pre-installed). The Vape atomizer supports top to button airflow system.
ULTON Epic Xent RTA Clone Vape Atomizer All-in-One Full Kit - Silver, 3ml / 6ml, 23mm Diameter Original Price $49.99, Now Only $38.9.
The Epic clone RTA has a diameter of 23mm and with the winding deck offers enough space and, thanks to accessories, is suitable for MTL, DL or mesh. There are no limits to creativity with the Epic RTA. The filling volume in the delivery condition is 3.0ml or 6.0ml (depending on the version). The tank is filled using a top fill system that is suitable for almost all types of bottles
Original Smoant Veer Pod System Kit - 750mAh, 2.3ml, 0.6ohm / 1.2ohm Original Price $21.99, Now Only $14.99.
Smoant Veer is an all-new ultra-lightweight pod system kit that fits comfortably in your hand every time you vape. Veer's fuselage structure is designed with ultra-light material space aluminum, which weighs only 33.5g, which is lighter than a hamburger. Put it in your pocket, you don't feel the presence. With round walls and grooved surfaces.
Replacement Glass Tube for ULTON Epic Clone RTA Vape Atomizer - Translucent, 6.0ml Original Price $4.99, Now Only $2.99.
The Replacement Glass Tube holds 6.0ml capacity and is suitable for ULTON Epic clone RTA Vape Atomizer.
Replacement Glass Tube for ULTON Epic Clone RTA Vape Atomizer - Translucent, 3.0ml Original Price $4.99, Now Only $2.99.
The Replacement Glass Tube holds 3.0ml capacity and is suitable for ULTON Epic clone RTA Vape Atomizer.
Original DEJAVU Pocket Replacement Empty Pod Cartridge Tank Set Original Price $8.9, Now Only $6.9.
original DEJAVU Replacement Empty Pod Cartridge Tank Set is suitable for DEJAVU Pocket 40W VW Variable Wattage AIO Pod System Vape Starter Kit.
Original DEJAVU Pocket Replacement Empty Pod Cartridge Tank Original Price $5.9, Now Only $3.7.
original DEJAVU Replacement Empty Pod Cartridge Tank is suitable for DEJAVU Pocket 40W VW Variable Wattage AIO Pod System Vape Starter Kit.
Original ThunderHead Creations THC Tauren Pro Tool Kit for Vape - Screwdriver + Pliers + Scissors + Tweezers + Coiling Jig Original Price $29.99, Now Only $24.99.
The original THC Tauren Pro Tool Kit is a multi-functional tool kit designed for vape. The kit includes 1 x Professional Screwdriver, 1 x Multifunctional Pliers, 1 x Folding Scissors, 1 x Ceramic Tweezer, 1 x Pointed Tweezer, 1 x Wire Cutter, 1 x Coiling Jig Stick, 1 x Storage Case, 1 x THC Keychain.
Original ThunderHead Creations THC Coil Len Trim Tool Original Price $4.99, Now Only $2.59.
The original ThunderHead Creations THC Coil Len Trim Tool is suitable for THC Artemis RDTA and other RTA / RDTA / RDA Vape Atomizer.
Original ThunderHead Creations THC Artemis V1.5 RDTA Replacement 810 Drip Tip Original Price $4.99, Now Only $2.99.
original ThunderHead Creations THC 810 drip tip is designed for ThunderHead Creations THC Artemis V1.5 RDTA Rebuildable Dripping Vape Atomizer.
Original ThunderHead Creations THC Hand Craft Alien 3-Core Coil - 0.35ohm, Ni80, 28GA x 3 + 36GA (2 PCS) Original Price $7.99, Now Only $5.99.
original ThunderHead Creations THC Hand Craft Alien 3-Core Coil is made from 28GA x 3 + 36GA wire with 0.35ohm resistance, suitable for RTA / RDTA / RDA Vape Atomizer.
Original ThunderHead Creations THC Ni80 4 Core Fused Clapton Wire - 0.3 x 4 + 0.1, 5 feet / Roll Original Price $5.99, Now Only $3.99.
original ThunderHead Creations THC Ni80 4 Core Fused Clapton Wire 0.3 x 4 + 0.1, 5 feet / Roll
Original ThunderHead Creations THC Artemis V1.5 RDTA Replacement Glass Tank Tube - 4.0ml Original Price $2.99, Now Only $1.59.
The original ThunderHead Creations THC Artemis V1.5 RDTA Replacement Glass Tank Tube holds 4.0ml capacity.
Original ThunderHead Creations THC Artemis V1.5 RDTA Replacement Glass Tank Tube - 2.0ml Original Price $2.99, Now Only $1.39.
The original ThunderHead Creations THC Artemis V1.5 RDTA Replacement Glass Tank Tube holds 2.0ml capacity.
Original Smoant Veer Pod System Replacement Empty Pod Cartridge - 2.3ml Original Price $2.99, Now Only $1.99.
The original Smoant VEER pod Cartridge has a capacity of 2.3ml. Its side-filling design can maximum avoid e-liquid leakage and reduce the mess. Install pod in different directions, you will get 2 different airflow and 2 different experience. It is compatible with 0.6ohm Mesh / 1.2ohm Ni80 Baby series Coil (not included).
Старый 06.06.2021, 18:20 Автор темы   100
3FVAPE
Original GeekVape Athena Squonk Mechanical Box Mod + BF RDA Squonker Kit Big Sale Original Price $69.99, Now Only $20.99.
The original Geekvape Athena Squonker Kit consists of Athena Squonk Box Mod and Athena BF RDA.
Aston RDA Clone BF Squonk Rebuildable Dripping Vape Atomizer - 316 Stainless Steel, 22mm Diameter Original Price $10.99, Now Only $8.99.
The Aston clone RDA is a low profile flavor oriented dripper, very easy to use. The Squonk BF RDA is constructed from 316 stainless steel in 22mm diameter. The coil is positioned perfectly against asymmetrical airflows. Cotton will be comfortably installed and will take time to swell for optimal nutrition. The sweetness of the airflow and the volume of steam will make the flavors of your e-liquids multiply tenfold.
Aston RDA Clone BF Squonk Rebuildable Dripping Vape Atomizer - 303 Stainless Steel, 22mm Diameter Original Price $9.99, Now Only $7.99.
The Aston clone RDA is a low profile flavor oriented dripper, very easy to use. The Squonk BF RDA is constructed from 303 stainless steel in 22mm diameter. The coil is positioned perfectly against asymmetrical airflows. Cotton will be comfortably installed and will take time to swell for optimal nutrition. The sweetness of the airflow and the volume of steam will make the flavors of your e-liquids multiply tenfold.
VG Kronos 2 S 2021 RTA Clone Rebuildable Tank Vape Atomizer - 23mm, RDL / MTL, 4.5ml Original Price $30.99, Now Only $22.99.
The VG Vapor Giant KRONOS 2 S clone RTA is 23mm diameter and can be used with a restrictive DTL or in MTL, it is equipped with a 4.5ml tank. The Kronos 2S clone RTA is designed Made of stainless steel and polycarbonate, The optics of the KRONOS 2S 2 S clone RTA are just as versatile as the airflow.
Replacement Screws for dotMod dotAIO Pod Original Price $5.99, Now Only $3.99.
The Replacement Screws is made from stainless steel and is suitable for dotMod dotAIO Pod System.
Original UD Clapton Wire for RBA Vape Atomizer Original Price $8.99, Now Only $5.99.
The original YouDe UD Builder's Choice allows vapers to efficiently build advanced coils without the hassle of wrapping their own. The wire is constructed out of Kanthal A1 and utilizes a fused Clapton design, UD Atomizer DIY Clapton Roll Wire is a high quality replacement wire used for building coils, a perfect choice for DIY lovers.
Original YouDe UD Nichrome Wire for RBA Vape Atomizer Original Price $5.99, Now Only $2.59.
original YouDeUD Nichrome wire, great for building e-cig coils. Versatile and great for use with a standard, variable wattage or variable voltage e-cigarettes. Nichrome wire is renowned for having a high resistance especially great for high temperatures.
Original YouDe UD Twisted Kanthal A1 Heating Wire for RBA Vape Atomizer Original Price $5.99, Now Only $3.89.
The YouDe UD Kanthal A1 Twisted Wire is the high-quality replacement for heating coil, perfect choice for DIY lovers. Twisted wire is two strands of kanthal wire that have been twisted together, this coiling technique provides low resistance and a large surface area to vaporize e-liquid, producing greater amounts of vapor. This twisted wire also adds durability and has good heat resistance properties.
3FVAPE вне форума   Вверх
Время генерации страницы 0.43875 секунды с 15 запросами
