Просмотров в теме 60322   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 08.04.2021, 04:49 Автор темы   61
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
Stratum V4M Matte Clone 100W VW Variable Wattage Box Mod YiHi SX485J Chip Original Price $149.99, Now Only $129.99.
Stratum V4M Matte Clone 100W VW Box Mod is powered by 1 x 18650 battery (not included) with Mirco USB charging, enough to provide the maximum power output of 100W. Monitored by YiHi SX485J Chip, Stratum V4M Matte supports VW 5~100W / TC (NI200, SS, TI 212~572'F, 100~300'C) / Taste / TCR and Bypass mode. Equipped with 0.96 inch TFT screen, Stratum V4M Matte Box Mod adopts the new OLC 510 connection, which allows you to adjust your atomizers airflow position for a better vaping experience by rotating the outer ring of the connector, compatible with atomizer up to 24mm diameter.
Original SMOKTech SMOK Stick G15 Pod System Vape Starter Kit 700mAh $16.99
Original SMOKTech SMOK Stick G15 Pod System Vape Starter Kit, as a draw-activated pod kit, consists of a SMOK Stick G15 700mAh Pod System Mod and a 2.0ml Stick G15 Pod Cartridge with 0.8ohm MTL coil. SMOK Stick G15 Pod System Mod is powered by a 700mAh built-in battery with the power range 3~15W. SMOK Stick G15 Pod Cartridge with DC 0.8ohm MTL coil holds 2.0ml capacity with side filling system, absolutely delivering a great MTL vaping experience. 7 colors for your choice.
Original Pluscig K8 Heat Not Burn Vaporizer Vape Starter Kit 3500mAh $45.99
Original Pluscig K8 Heat Not Burn Vaporizer Vape Starter Kit, an ideal heating kit designed for heating tobacco sticks, is powered by a 3500mAh built-in battery, enough smoking up to 40~50 cartridge when fully charged by Type-C. Pluscig K8 vape kit is designed with knob, by switching simple operation to set three different gear temperatures: 280'C / 355'C / 380'C. Pluscig K8 heating kit features ceramic needle heating, a 360 degree uniform and rapid heating, cleaning mode and vibration reminder function, delivering pure taste and dense cloud. 2 colors: Black / White
Original Auguse MTL / DTL V2 RTA Replacement DTL Air Disk $3.99
Original Auguse Replacement DTL Air Disk is designed for Auguse MTL / DTL V2 RTA Rebuildable Tank Vape Atomizer, which cooperates AFC Electrodes (not included), bringing you an amazing DTL vaping experience. 2 colors: Black / Silver. 1 PC / Pack
Original Auguse MTL / DTL V2 RTA Replacement AFC Electrode 0.8mm for MTL Air Disk $2.99
Original Auguse AFC Electrode 0.8mm is designed for Auguse MTL / DTL V2 RTA Rebuildable Tank Vape Atomizer, which is installed on Auguse MTL / DTL V2 RTA building deck and then cooperates with MTL Air Disk to bring an amazing MTL vaping experience. AFC Electrode for DTL is also available. 1 PC / Pack
3FVAPE вне форума   Вверх
Старый 09.04.2021, 04:48 Автор темы   62
3FVAPE
Original Oumier Wasp Nano Stick Pod System Mod + Wasp Nano RDA Vape Starter Kit 2000mAh 22mm Original Price $36.9, Now Only $28.99.
Original Oumier Wasp Nano Stick Pod System Vape Starter Kit, a mechanical mod kit, consists of a Wasp Nano Stick 2000mAh Pod System Mod and a 22mm Wasp Nano RDA. Wasp Nano Stick Pod System Mod is powered by a 2000mAh built-in battery with Type-C fast charging, featuring colorful flashing LED system. With 510 threading connection, Wasp Nano Stick Pod Mod is fit for most of your favorite atomizer, a good choice for you to satisfy your salt-nic vaping needs. Wasp Nano RDA in 22mm diameter adopts single coil building deck, side airflow design and unique coil locking design, providing massive clouds and pure flavor. 3 colors: Black / SS / Gold
YFTK Flash e-Vapor V4.5S+ Clone RTA Replacement Glass Bell Cap + Chimney 2.0ml $10.99
YFTK replacement bell cap + chimney kit is designed for YFTK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. Two optional capacities: 2.0ml / 3.5ml. 1 PC / Pack
Replacement Top Cap + Bottom Plate for Armor Mech V2 Clone BF Mech Mod $6.99
This replacement Top cap + Bottom plate is designed for Armor Mech V2 Clone Mechanical Box Vape Mod to match 22mm or 24mm diameter atomizer. 1 PC / Pack
YFTK Flash e-Vapor V4.5S+ Clone RTA Replacement Glass Tank Tube 2.0ml $1.99
YFTK replacement glass tank tube is designed for YFTK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. Two optional capacities: 2.0ml / 3.5ml. 1 PC / Pack
Старый 12.04.2021, 05:11 Автор темы   63
3FVAPE
Original GeekVape Z Max Sub Ohm Tank Clearomizer Vape Atomizer 4.0ml / 2.0ml 32mm Diameter Original Price $36.99, Now Only $31.99.
Original Geekvape Z Max Sub Ohm Tank Clearomizer Vape Atomizer holds 4.0ml / 2.0ml capacity with easy top filling in 32mm diameter. Geekvape Z Max Tank adopts direct top airflow and high dynamic top to bottom airflow, which allows air flow from the side inlets easily to reach the coil for tasted flavor. Geekvape Z Max Sub Ohm Tank is compatible with Geekvape M series coils, a max size coil for broadening the contact surface between air and liquid, 1 x Geekvape M series coils 0.14ohm (60~80W) and 1 x M series coils 0.2ohm (70~85W) included, fit for most of your favorite mods with 510 threading connection. 6 colors: Rainbow / Blue / Gold / Black / Silver / Gun Metal
Original Innokin T18E Pro Tank Clearomizer Vape Atomizerr 2.0ml $13.99
Original Innokin T18E Pro Tank Clearomizer Vape Atomizerr holds 2.0ml capacity with sliding top filling system. Innokin T18E Pro Tank is compatible with Innokin T18E coils, 1 x T18E coil 1.7ohm (pre-installed) and 1 x T18E coil 1.5ohm included in the package. With 510 threading connection, T18E Pro Tank can be paired with a wide range of mods, especially with Innokin Endura T22 Pro Pod System Vape Mod Kit. 3 colors: Gun Metal / SS / Black
Original Innokin T18E Coil Head for T18E Pro Tank / Endura T22 Pro Vape Kit 1.7ohm $8.99
Original Innokin T18E Coil Head is with 1.7ohm resistance, designed for Innokin T18E Pro Tank and Innokin Endura T22 Pro Pod System Vape Mod Kit. 5 PCS / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement Glass Tank Tube Pack (3 PCS) $9
Original Dovpo x Suicide Mods Abyss AIO Glass Pack is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, including 1 x smoked glass tank tube, 1 x clear glass tank tube and 1 x Ultem tank tube. 3 PCS / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement 18650 Battery Tube $6
Original Dovpo x Suicide Mods Abyss AIO 18650 Battery Tube holds 1 x 18650 battery (not included), designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit. 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement Side-By-Side Kit $12.5
Original Dovpo x Suicide Mods Abyss AIO Side-By-Side Kit is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit for changing this AIO mod into a side by side SBS mod, including 1 x 18650 Cap, 1 x 21700 Cap, 1 x 510 Connector. With 510 connector, you are allowed to use a wide range of atomizers you like. 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement Square Button Kit $7.5
Original Dovpo x Suicide Mods Abyss AIO Square Button Kit is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, enabling you to customize Abyss AIO mod by swapping original fire button for a new color and new shape.
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement Drip Tip Pack $7.99
Original Dovpo x Suicide Mods Abyss AIO Drip Tip Pack is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, including 1 x drip tip base, 1 x short mouthpiece, 1 x long mouthpiece, 1 x whistle mouthpiece.
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement PNP / GTX Bridge for PNP / GTX Coils $7.5
Original Dovpo x Suicide Mods Abyss AIO PNP/ GTX Bridge is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, which can be installed in the Abyss Tank to make Abyss AIO Mod compatible with VOOPOO PNP / Vaporesso GTX Coils (not included). 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement EUC Bridge for Vaporesso EUC coils $6
Original Dovpo x Suicide Mods Abyss AIO EUC Bridge is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, which can be installed in the Abyss Tank to make Abyss AIO Mod compatible with Vaporesso EUC coils (not included). 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement G-Coil Bridge for Caliburn G coils $6
Original Dovpo x Suicide Mods Abyss AIO G-Coil Bridge is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, which can be installed in the Abyss Tank to make Abyss AIO Mod compatible with Uwell Caliburn G coils (not included). 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Replacement Nord Bridge for Smok Nord coils $5
Original Dovpo x Suicide Mods Abyss AIO Nord Bridge is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, which can be installed in the Abyss Tank to make Abyss AIO Mod compatible with Smok Nord coils (not included). 1 PC / Pack
Original Dovpo x Suicide Mods Abyss AIO 60W Kit Bridge Pack $21
Original Dovpo x Suicide Mods Abyss AIO Nord Bridge is designed for Dovpo X Suicide Mods Abyss 60W VW SBS AIO Mod Kit, including 1 x PNP/ GTX Bridge for all PNP/GTX coils, 1 x EUC Bridge for Vaporesso EUC coils, 1 x G-Coil Bridge for Caliburn G coils, 1 x Nord Bridge for Smok Nord coils. These bridge can be installed in the Abyss Tank to make Abyss AIO Mod compatible with all PNP/GTX coils. (coils totally not included). 4 PCS / Pack
Старый 13.04.2021, 04:51 Автор темы   64
3FVAPE
Original asMODus Minikin 2 180W 1.0" Touch Screen TC VW Variable Wattage Box Mod 2 x 18650 Original Price $88.99, Now Only $34.99.
Original asMODus Minikin 2 180W Box Mod monitored by asMODus GX-180-HT Chipset, is powered by 2 x 18650 batteries (not included), enabling it support VW 5~180W / TC (Ni / Ti / SS) 212~572'F / TCR modes. Minikin 2 features a new wattage cap of 180 watts and touch screen support. Minikin 2 Mod utilizes newly updated firmware which displays the following information on its LED screen: Individual battery charge, resistance of the atomizers, volts being used to fire at desired wattage, a puff counter, the duration of the fire, and which mode you are in. The Minikin 2 features a redesigned body that was designed to be exceptionally comfortable to hold. The asMODus logo has been re-positioned to the back of the device and the USB port has been moved the front of the device as the battery door has been remodeled to add magnetic closure. 15 vent holes have been added to the base of the device which allows for maximized heat dissipation.
SXK BB Clone 70W All-in-One VW Variable Wattage Box Mod Kit w/ USB Port & 2021 Logo Original Price $350, Now Only $75.99.
The SXK BB Clone Box Mod Kit with 2021 Logo is constructed from aluminum with an all-in-one design. This mod comes with Nautilus coil adaptor. This BB Box comes with USB port for charging only.
SXK 415 Clone 510 Drip Tip Set for RBA / RTA / RDA Vape Atomizer Original Price $11.9, Now Only $9.5.
SXK 415 Four One Five 510 Drip Tip Set includes 1 x Drip Tip Base, 1 x PEI Mouthpiece (Brown), 2 x PC Mouthpiece (Translucent Black / White), suitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector,
Original Vapesoon Silicone Protective Case Sleeve for Uwell Caliburn KOKO Prime Pod Kit $1.99
Original Vapesoon Protective Case Sleeve is made of Silicone and is suitable for protect Uwell Caliburn KOKO Prime 15W Pod System Kit. 1 PC / Pack
Старый 14.04.2021, 05:20 Автор темы   65
3FVAPE
Original ThunderHead Creations Tauren MAX RDA Rebuildable Dripping Vape Atomizer w/ BF Pin 25mm Original Price $39.9, Now Only $28.99.
Original ThunderHead Creations Tauren MAX RDA Rebuildable Dripping Vape Atomizer is an upgraded postless dual coil RDA in 25mm diameter. ThunderHead Creations Tauren MAX RDA features innovative 3D honeycomb airflow system, 26 pieces airholes from triple sides to be as cloud chaser for an excellent flavor and strong throat hit. Tauren MAX RDA applies an innovative ceramic build deck, creative dual ceramic clamp system, absolutely a great RDA for your favorite mods with 510 threading connection, like Tauren Mech and Tauren Max Mech.
Original asMODus Minikin 2 180W TC VW Variable Wattage Box Mod features 1.0" Touch Screen, easy for operation. asMODus Minikin 2 180W 1.0" Touch Screen TC VW Box Mod The Minikin is powered by 2 x 18650 batteries (not included) with power output 5~180W and adjustable temperature 212~572'F. The Minikin 2 is monitored by a GX-180-HT chip which incorporates the same battery power saving capabilities as its predecessors but features a new wattage cap of 180 watts and touch screen support! The Minikin 2 utilizes newly updated firmware which displays the following information on its LED screen: Individual battery charge, resistance of the atomizers, volts being used to fire at desired wattage, a puff counter, the duration of the fire, and which mode you are in. The Minikin 2 features a redesigned body that was designed to be exceptionally comfortable to hold. The asMODus logo has been re-positioned to the back of the device and the USB port has been moved the front of the device as the battery door has been remodeled to add magnetic closure. 15 vent holes have been added to the base of the device which allows for maximized heat dissipation. 6 colors: Purple, Army Green, Pink, Red, Gun Metal, Marble
Replacement PC Frame for dotMod dotAIO Vape Pod System $56.99
This replacement PC Frame is designed for dotMod dotAIO Vape Pod System. Image for reference only, inner pannel and chipset are not included.
Replacement POM Button for BB Clone Box Mod $5.99
The replacement button is made from POM with polished finish, suitable for Billet BB Clone Box Mod. 2 Colors: Pink / White
Mission Tips Whistle V2 Clone 510 Drip Tip w/ Airflow Bores for RBA / RTA / RDA Atomizer $7.99
Mission Tips Whistle V2 Clone 510 Drip Tip is is made of stainless steel and POM, suitable for RBA / RTA / RDA Atomizer and Integrated AIO Mod Kit with 510 drip tip connector, like Billet Box. Mission Tips Whistle V2 Clone 510 Drip Tip comes with swappable aiflow bores: 4.6 mm (without drip tip), 4.5mm, 3.5mm, 2.5mm, 1.5mm. 4 colors: Brown, Pink, White, Black
Never Normal Whistle V2 Clone 510 PMMA Drip Tip for dotMod dotAIO Pod $5.99
Never Normal Whistle V2 Clone 510 Drip Tip is made of PMMA, suitable for dotMod dotAIO Pod. 1 PC / Pack
Original ThunderHead Creations Tauren MAX RDA Replacement Ceramic Block $4.99
Original ThunderHead Creations Ceramic Block is designed for ThunderHead Creations Tauren MAX RDA Rebuildable Dripping Vape Atomizer. 1 PC / Pack
Original ThunderHead Creations Tauren MAX RDA Replacement 810 Drip Tip $3.99
Original ThunderHead Creations 810 drip tip is designed for ThunderHead Creations Tauren MAX RDA Rebuildable Dripping Vape Atomizer. 2 colors: Black Ring / Silver Ring. 1 PC / Pack
Original ThunderHead Creations Hand Craft 3-Core Fused Clapton Coil 0.25ohm Ni80 26GA x 3 + 38GA $4.99
Original ThunderHead Creations Hand Craft 3-Core Fused Clapton Coil is made from 26GA x 3 + 38GA wire with 0.25ohm resistance, suitable for RTA / RDTA / RDA Vape Atomizer. Comes in 2 PCS coils in one tube, 5 tubes in one box, totally 10 PCS / Coils. ThunderHead Creations Hand Craft Alien 3-Core Coil 0.35ohm 28GA x 3 + 36GA is also available.
[Исправлено: 3FVAPE, 14.04.2021 в 06:31]
Старый 15.04.2021, 05:04 Автор темы   66
3FVAPE
Original Vandy Vape Rath RDA Rebuildable Dripping Vape Atomizer Single / Dual Coil Configuration 24mm Original Price $35.99, Now Only $27.99.
Original Vandy Vape Rath RDA Rebuildable Dripping Vape Atomizer, a RDA supporting single / dual coil configuration in 24mm diameter. Vandy Vape Rath RDA adopts various airflow adjustment methods, meeting your different vaping demands. In addition, Rath RDA features deep groove with 2.0ml large e-liquid storage and ceramic + / - electrodes. With 510 threading connection, Rath RDA is fit for most of your favorite mods, mechanical mod or BF squonker. 4 colors: Rainbow, Black, Gun Metal, SS
Original Uwell Crown V 5 200W TC VW Box Mod + Crown V Tank Atomizer Vape Kit 2 x 18650 29mm $79.99
Original Uwell Crown V 5 200W TC VW Vape Box Mod Kit consists of an Uwell Crown V 5 200W TC VW Box Mod and a 5.0ml Uwell Crown V Sub Ohm Tank Atomizer. Uwell Crown V 5 Box Mod is powered by 2 x 18650 batteries with Type-C fast charging, enough fire up to 200W (5~200W). Equipped with a 0.96-inch TFT color screen, Uwell Crown V 5 Mod supports power mode and TCR mode, which provide stable output and match coil of different TC material. Uwell Crown V 5 Sub Ohm Tank Atomizer holds 5.0ml capacity with top filling system in 29mm diameter. Crown V 5 Tank Atomizer features Uwell exclusive Pro-Focs flavor testing technology, which can properly control the heating temperature, strictly manage the material quality and completely restores the e-juice flavor, deliver a great vaping experience. Crown V Tank adopts patented self cleaning technology, which can absorb the e-juice in the condensation holder through regular usage and vaporize it to reduce juice leakage and lessen the cleaning frequency. 3 Colors: Blue / Red / Black
Original asMODus Xeneo 80W VW Pod System Vape Mod Kit 1 x 18650 Original Price $44, Now Only $32.99.
Original asMODus Xeneo 80W VW Pod System Vape Mod Kit, a compact and portable pod kit, includes an asMODus Xeneo Mod and an asMODus Pod Cartridge. Equipped with display screen, asMODus Xeneo Pod Mod is powered by 1 x 18650 battery (not included) with USB charging, enough to provide a maximum power output of 80W (5~80W). asMODus Pod Cartridge features bottom adjustable airflow control and comes with 1 x Xeneo Mesh Coil 0.4ohm and 1 x Xeneo Vertical Coil 1.1ohm. 4 Colors: Red, White, Black, Silver
Original HuoQi The King of Spades 200W TC VW Vape Box Mod 2 x 18650 Original Price $49.99, Now Only $24.99.
Original HuoQi The King of Spades 200W TC VW Vape Box Mod is powered by 2 x 18650 batteries (not included) with Micro USB charging, enough to fire up to 200W (10~200W). Equipped with a screen, The King of Spades 200W Mod is suitable for most of your favorite atomizers with 510 threading connection. 2 Colors: White / Black
Original iSmoka Eleaf iJust VV Mod + BDC Atomizer Vape Kit 1 x 18650 /18350 23mm Original Price $29.99, Now Only $14.99.
Original iSmoka Eleaf VV Vape Mod Kit includes an Eleaf VV Vape Mod and a 3.7ml Eleaf BDC Bottom Dual Coil Tank Atomizer. Eleaf VV Vape Mod features its telescopic battery tube, which enables it to fit into all batteries of 18- series, like 18650 / 18350 battery (battery not included) with Micro USB charging. In addition, iSmoka Eleaf VV Mod has the function of adjusting voltage 3.7~4.8V, delivering you different experiences. Bottom Dual Coil BDC Tank Atomizer holds 3.7ml capacity with bottom filling system in 23mm Diameter. BDC Atomizer constitutes two coil, 1 x BDC Atomizer Coil Head 1.8ohm and 1 x BDC Atomizer Coil Head 1.6ohm included in the package, a great deal enhancing the effectiveness of vaporization and bringing you different experiences. BDC atomizer head ensures the large amount of vape under low voltage, no burning taste under high voltage and no leakage. BDC atomizer head is similar to BBC Atomizer head in size and appearance, so it is also able fit into Mini BCC, BCC Mega and iKit. (not included)
Original Vandy Vape Rath RDA Replacement Ceramic Electrodes $1.99
Original Vandy Vape Ceramic Components Accessories Kit including 2 x Ceramic + / - Electrodes, is designed for Vandy Vape Rath RDA Rebuildable Dripping Vape Atomizer. 2 PCS / Pack
Старый 16.04.2021, 05:05 Автор темы   67
3FVAPE
Original Advken Wanderlust Lite 2 Pod System Vape Starter Kit 1000mAh 2.0ml Original Price $35.99, Now Only $24.99.
Original Advken Wanderlust Lite 2 Pod System Vape Starter Kit is a draw-activated pod kit, consisting of Wanderlust Lite 2 1000mAh Pod Mod and a 2.0ml Pod Cartridge with 1.2ohm coil.Advken Wanderlust Lite 2 Pod Mod is powered by a 1000mAh built-in battery with Micro USB charging. Constructed from Aluminum Alloy, Wanderlust Lite 2 Pod Mod is designed with intelligence indicator, showing the battery status (yellow: 3.5~3.7V, red: 3.2~3.5V, green: 3.7~4.7V). Advken Wanderlust Lite 2 Pod Cartridge with 1.2ohm mesh coil holds 2.0ml capacity with bottom refilling system. Advken Wanderlust Lite 2 adopts dual airways design, bringing a great vaping experience. 3 colors: Gun Metal / Gold / Rainbow
Original iSmoka Eleaf iJust VV Mod + BDC Atomizer Vape Kit1 x 18650 /18350 23mm Dia Original Price $29.99, Now Only $14.99.
Original iSmoka Eleaf VV Vape Mod Kit consists of an Eleaf VV Vape Mod and a 3.7ml Eleaf BDC Tank Atomizer. Eleaf VV Vape Mod features its telescopic battery tube, which enables it to fit into all batteries of 18- series, like 18650 / 18350 battery (battery not included) with Micro USB charging. In addition, iSmoka Eleaf VV Mod is with adjustable voltage 3.7~4.8V, delivering you different experiences of puff-taking. BDC Bottom Dual Coil Tank Atomizer in 23mm Diameter holds 3.7ml capacity with bottom filling system. BDC Atomizer constitutes two coil, 1 x BDC Atomizer Coil Head 1.8ohm and 1 x BDC Atomizer Coil Head 1.6ohm included in the package, a great deal enhancing the effectiveness of vaporization and bringing you different experiences. BDC atomizer head ensures the large amount of vape under low voltage, no burning taste under high voltage and no leakage. BDC atomizer head is similar to BBC Atomizer head in size and appearance, so it is also able fit into Mini BCC, BCC Mega and iKit. (not included) 2 colors: Light Gun / Silver
Original Advken Wanderlust Lite 2 Pod Kit Replacement Pod Cartridge w/ 1.4ohm Ceramic Coil 2.0ml Original Price $14.99, Now Only $8.99.
Original Advken Wanderlust Lite 2 Replacement Pod Cartridge is pre-installed with 1.4ohm Ceramic Coil, designed for Advken Wanderlust Lite 2 Pod System Vape Starter Kit. Advken Wanderlust Lite 2 Pod Cartridge holds 2.0ml capacity with bottom refilling system. Wanderlust Lite 2 Replacement Pod Cartridge with 1.2ohm coil is also available. 3 PCS / Pack
Original ThunderHead Creations THC Tauren MAX RDA Replacement Accessories Kit $3.99
Original ThunderHead Creations Replacement Accessories Kit is designed for ThunderHead Creations THC Tauren MAX RDA Rebuildable Dripping Vape Atomizer, including 1 x BF Pin, 2 x 3 Core Fused Clapton Coils 0.25ohm, 1 x Spare M4 Hex Screw, 2 x Spare M4 Slot Screws, 1 x Star Socket Screw Wrench, 1 x Allen Key, 1 x Slot Screwdriver, 1 x Coil Leg Trim Tool, 1 x Set of Spare O-rings. Enjoy the DIY Fun
Старый 17.04.2021, 04:57 Автор темы   68
3FVAPE
Original Hellvape Arez 120 TC VW Vape Box Mod 1 x 21700 / 20700 / 18650 Original Price $79.9, Now Only $54.99.
Original Hellvape Arez 120 TC VW Vape Box Mod is powered by 1 x 21700 / 20700 / 18650 battery (battery not included, 18650 Battery Adapter included) with the power output 5~120W. Hellvape Arez 120 Mod adopts unibody design, engraved by CNC machine from a single block of metal. Constructed from aluminum alloy and stainless steel, Hellvape Arez 120W Box Mod with 0.96 inch OLED screen is fit for most atomizers with 510 threading connection. Monitored by Top-level Onboard Chipset, Hellvape Arez 120W Mod has outstanding performance, delivering a great vaping experience.
Original Koguovape Loki 60W TC VW Vape Box Mod 1 x 18650 $87.99
Original Koguovape Loki 60W TC VW Vape Box Mod, an ergonomic VW box mod, is powered by 1 x 18650 battery (not included), enough to fire up to 60W (1~60W). Monitored by smart chipset, Koguovape Loki 60W Mod supports VW 1~60W, TC (Ni / SS / TI) 200~600'F / 100~315'C modes. Equipped with 0.91 inch OLED screen, Koguovape Loki 60W Box Mod is designed with Dual side fire buttons, perfectly compatible with 24mm Atomizers with 510 threading connection.
SXK Flash e-Vapor V4.5S+ Clone RTA Replacement Improved Build Deck Base 22.5mm Diameter Original Price $16.9, Now Only $14.5.
SXK Replacement Improved Build Deck Base is designed for SXK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. This improved building deck is easier for you to wire and wick, bringing denser cloud and tasted flavor. 1 PC / Pack
Старый 19.04.2021, 05:03 Автор темы   69
3FVAPE
Original SMOKTech SMOK Gram-25 Mod + Gram-16 Tank Atomizer Vape Kit 900mAh 2ml $28.99
Original SMOKTech SMOK Gram-25 Vape Mod Kit includes a SMOK Gram-25 900mAh Mod and a 2.0ml Gram-16 Tank Atomizer with 0.6ohm coil. SMOK Gram-25 Mod is powered by a 900mAh built-in battery with Type-C charging, to provide the power output of 1~25W. Equipped with a LED indicator and a 0.69 inch OLED screen, SMOK Gram-25 Mod can be impaired with any atomizers with 510 threading connection. SMOK Gram-16 Sub Ohm Tank Vape Atomizer holds 2.0ml capacity with top filling system in 16mm diameter. With straight-through airflow design, Gram-16 Tank is compatible with Smok G16 DC Coils, 2 x G16 DC 0.6ohm coil included (one pre-installed), absolutely bringing a smooth flavor.
Original SMOKTech SMOK Gram-16 Sub Ohm Tank Clearomizer Vape Atomizer 2.0ml 16mm $14.99
Original SMOKTech SMOK Gram-16 Sub Ohm Tank Vape Atomizer holds 2.0ml capacity with top filling system in 16mm diameter. With straight-through airflow design, Gram-16 Tank is compatible with Smok G16 DC Coils, 2 x G16 DC 0.6ohm coil included (one pre-installed), absolutely giving an extremely smooth flavor. With 510 threading connection, Gram-16 Tank Atomizer can accommodate most of your favorite mods, especially for SMOKTech SMOK Gram-25 Box Mod.
Original Mars H5 Mechanical Vape Box Mod 2 x 18650 Original Price $49.99, Now Only $14.99.
Original Mars H5 Mechanical Vape Box Mod is powered by 2 x 18650 batteries (not included). Constructed from stainless steel and aluminum, Mars H5 Mech Mod conducts well, due to its copper connecting contacts. With 510 threading connection, Mars H5 Vape Box Mod is recommended to accommodate atomizer with 0.2~0.35ohm coil but below 0.15ohm coil is prohibited.
Original ETU Replacement Inner Door for dotMod dotAIO OG / SE Vape Pod System $10.9
Original ETU Replacement Inner Door is designed for for dotMod dotAIO OG / SE Vape Pod System. 1 PC / Pack
Original SMOKTech SMOK Gram-25 Mod Kit / Gram-16 Tank Replacement G16 Coil Head 0.6ohm $8.99
Original SMOKTech SMOK G16 Coil Head with DC 0.6ohm resistance (suggested wattage: 15~25W) is designed for SMOKTech SMOK Gram-25 Vape Mod Kit and SMOKTech SMOK Gram-16 Sub Ohm Tank Vape Atomizer. 3 PCS / Pack
Старый 20.04.2021, 04:40 Автор темы   70
3FVAPE
Reload SRTA Clone S RTA Rebuildable Tank Vape Atomizer 2.5ml / 4.5ml 24.5mm $13.99
Reload SRTA Clone S RTA Rebuildable Tank Vape Atomizer in 24.5mm diameter holds 2.5ml / 4.5ml capacity with top filling system. Constructed from Stainless Steel, Reload 24.5mm RTA features dual adjustable bottom airflow and 810 drip tip, delivering a great vaping experience. With 510 threading connection, Reload SRTA Clone S RTA applies a simple single coil configuration with threaded bottom ring for quick access to build deck, fit for most of your favorite mods. 3 optional colors: Black, Silver, Gold
Original Yocan Apex Mini Concentrate Vaporizer Wax Pen Kit 380mAh $14.75
Original Yocan Apex Mini Concentrate Vaporizer Wax Pen Kit, a compact pen-shaped vaporizer kit, is powered by a 350mAh built-in battery with USB charging. Apex Mini Kit can preserve the flavor compounds in your material and prolong the initial taste longer than other traditional wax pen and comes with QDC coil, absolutely delivering a great vaping experience. Yocan Apex Mini Vaporizer features three variable voltages: White: 3.4V / Blue: 3.8V / Green: 4.2V set by clicking the button 3 times quickly. When you press the button, Yocan Apex Mini VV Wax Pen Kit will heat the coil at the voltage you set for 4 seconds. And then Yocan Apex Mini modulates from 2.5V to the voltage you select for the rest of the heating cycle. 6 optional colors: Black, Sakura Pink, Apple Green, Azure Green, Champagne Gold, Silver
Original ETU Replacement PC Inner Panel for Dotaio Mini Vape Pod System Kit $9.9
Original ETU Replacement Inner Panel is made of PC, designed for Dotaio Mini Vape Pod System Kit. 1 PC / Pack Please note: This ETU Replacement Inner Panel is not suitable for dotMod dotAIO Pod. 3 optional color: Transparent, Translucent Yellow, Translucent Blue.
Original ETU Replacement PC Front + Back Cover Panel Plate for Dotaio Mini Vape Pod System Kit $10.9
Original ETU Replacement Front + Back Cover Panel Plate is made of PC, designed for for Dotaio Mini Vape Pod System Kit. 2 PCS / Pack Please note: This ETU Replacement Front + Back Cover Panel Plate is not suitable for dotMod dotAIO Pod. 2 optional colors: Transparent, Translucent Yellow.
Старый 21.04.2021, 04:43 Автор темы   71
3FVAPE
Four One Five 415 S61 Genesis Atomizer Clone RDTA Rebuildable Dripping Tank Atomizer 22mm $20.99
The Four One Five 415 S61 Genesis Atomizer Clone RDTA Rebuildable Dripping Tank Atomizer is constructed from stainless steel and PEI tank tube in 22mm diameter. The Four One Five S61 Genesis Atomizer Clone RDTA is designed with single coil building deck and airflow adjustable. 415 S61 RDTA is designed for dry flavor, hard throat hit.
Original Vapesoon VSP Refillable Pod System Vape Starter Kit 550mAh 2.0ml $13.99
Original Vapesoon VSP Refillable Pod System Vape Starter Kit is a draw-activated refillable pod kit, including a Vapesoon VSP 5500mAh Battery Mod and a 2.0ml VSP Refillable Pod Cartridge with 1.2ohm MTL ceramic coil. Vapesoon VSP battery Mod is powered by a 500mAh built-in battery with Micro-USB charging. Constructed from stainless steel, Vapesoon VSP Mod is a compact and portable pod mod for carrying out. Vapesoon VSP Refillable Pod Cartridge with 2.0ml capacity is pre-installed with a 1.2ohm MTL ceramic coil, delivering you pure taste and dense cloud. 2 colors: Blue Purple / Black
Kontrl Clone Acrylic Front + Back Door Panel Plates for BB / Billet Box Vape Mod Kit $46.99
Kontrl Clone Front + Back Door Panel Plates is made from Acrylic and suitable for BB / Billet Box Vape Mod Kit. 2 PCS / Pack
Original GeekVape Z Max Sub Ohm Tank Replacement M0.14 Coil Head KA1 0.14ohm Original Price $14.9, Now Only $10.99.
Original GeekVape M0.14 Coil Head is with 0.14ohm resistance (suggested wattage: 60~80W), designed for GeekVape Z Max Sub Ohm Tank Vape Atomizer. 5 PCS / Pack. GeekVape M0.3 Dual Coil 0.3ohm / M0.2 Trible Coil 0.2ohm / M0.15 Quadra Coil 0.15ohm are also available.
Старый 22.04.2021, 05:08 Автор темы   72
3FVAPE
Original Ambition Mods Converter 50W SBS Side-by-Side Box Mod 1 x 18350 / 18650 $79.99
Original Ambition Mods Converter SBS Side-by-Side Vape Box Mod is powered by 1 x 18350 / 18650 battery (battery not included), enough to fire up to 50W (1~50W). Constructed from aluminum and stainless steel, Converter SBS Box Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes. Equipped with 0.49 inch OLED screen, Converter Box Mod 50W can be feasibly switched from mechanical mod to box mod, compatible with atomizers up to 23mm.
Original Ambition Mods Converter 50W VW Variable Wattage Tube Mod 1 x 18350 / 18650 $53.99
Original Ambition Mods Converter 50W VW Variable Wattage Vape Tube Mod is powered by 1 x 18350 / 18650 battery (battery not included, 18650 Adaptor Tube included), providing the power output of 1~50W. Constructed from aluminum and stainless steel, Converter Tube Mod 50W can be feasibly switched from a good mechanical mod to box mod, compatible with your favorite atomizers with 510 threading connection. Equipped with 0.49 inch OLED screen, Converter Tube Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes.
Original GeekVape Obelisk 60 AIO All-in-One Vape Mod Kit 2200mAh 4ml Original Price $46.9, Now Only $39.99.
Original GeekVape Obelisk 60 AIO All-in-One Vape Mod Kit, a united design all-in-one AIO kit, is powered by a 2200mAh built-in battery with Type-C charging. Obelisk 60 AIO is monitored by intelligent power-control chip, supporting VW voltage adjustment mode 5~60W and TC temperature control mode 200~600'F / 100~315'C, delivering a magical vaping experience. GeekVape Obelisk 60 AIO Kit comes with a 4.0ml pod cartridge connected via convenient magic click. GeekVape Obelisk 60 Pod Cartridge features industry-leading and consistent Z top airflow system for precisely controlling the airflow and zero leakage. In addition, it also is compatible with GeekVape P series coils, GeekVape P Coil 0.4ohm (pre-installed) and GeekVape P Coil 0.5ohm included, bringing massive clouds and tasted flavor. 3 colors: Blue / Green / Black
Original Ambition Mods Converter Box Mod / Tube Mod Replacement Adaptor Kit $32.99
Original Ambition Mods Converter Adaptor Kit is designed for Converter Box Mod / Tube Mod, which enable to turn Converter Tube Mod into Converter SBS Side-by-Side Box Mod.
Original SMOKTech SMOK Novo 4 Pod Kit / Pod Cartridge Replacement LP1 Meshed 1.2ohm Coil Head $12.99
Original SMOKTech SMOK LP1 Meshed 1.2ohm Coil Head is designed for SMOKTech SMOK Novo 4 Pod System Starter Kit and SMOKTech SMOK Novo 4 Pod Cartridge (suggested wattage: 10~15W). It is with enlarged contact area for better atomization, delivering a leak-proof vaping experience. LP1 Meshed 0.8ohm Coil Head / LP1 DC 0.8ohm MTL Coil Head are alos available. 5 PCS / Pack
Старый 23.04.2021, 04:59 Автор темы   73
3FVAPE
Original Wotofo MDura Pro 230W TC VW Variable Wattage Vape Box Mod 2 x 18650 Original Price $59.95, Now Only $45.99.
Original Wotofo MDura Pro 230W TC VW Variable Wattage Vape Box Mod is powered by 2 x 18650 batteries (not included), providing the power out of 5~230W. Monitored by intelligent nexChip, MDura Pro 230W Box Mod has VW variable wattage Mode 5~230W and TC temperature control Mode 200~600'F / 100~315'C. Equipped with easy-to-use 1.2 inch TFT screen, MDura Pro 230W Mod is compatible with most of your favorite atomizers with 510 threading connection, like nexMESH Pro Sub Ohm Tank (not included). 5 colors: Retro Red, King Kong Orange, King Kong Blue, King Kong Red, King Kong Black
Original Wotofo MDura Pro 230W TC VW Box Mod + nexMESH Pro Tank Vape Kit 2 x 18650 Original Price $79.95, Now Only $59.99.
Original Wotofo MDura Pro 230W Vape Box Mod Kit consists of a MDura Pro 230W TC VW Box Mod and a 6.0ml nexMESH Pro Sub Ohm Tank Atomizer. Wotofo MDura Pro Box Mod is powered by 2 x 18650 batteries (not included), enough to fire up tp 230W (5~230W). Equipped with easy-to-use 1.2 inch TFT screen, MDura Pro 230W Mod is an ideal VW box mod for your favorite atomizers with 510 threading connection. Monitored by intelligent nexChip, MDura Pro 230W Vape Box Mod supports powerful VW Mode 5~230W and TC Mode 200~600'F / 100~315'C. Wotofo nexMESH Pro Sub Ohm Tank Vape Atomizer holds 6.0ml capacity with top filling system in 24mm diameter. With 810 drip tip, nexMESH Pro Tank adopts adjustable bottom airflow, delivering an awesome vaping experience. nexMESH Pro Tank adopts mesh coil and parallel coil combo core, 1 x H15 Mesh & Parallel Coil (pre-installed) and1 x H12 Clapton Mesh Coil Head included. 5 colors: Retro Red, King Kong Orange, King Kong Blue, King Kong Red, King Kong Black
ShenRay Four One Five 415 S61 Genesis Clone RDTA Rebuildable Dripping Tank Vape Atomizer 22mm $23.99
ShenRay Four One Five 415 S61 Genesis Clone RDTA Rebuildable Dripping Tank Vape Atomizer is made of 316 stainless steel in 22 diameter. With 510 threading connection, ShenRay 415 S61 Genesis Clone RDTA adopts airflow adjustable (1.0mm, 1.2mm, 1.0 x 1.2mm) and dual-pole deck for single coil building.
YFTK Flash e-Vapor V4.5S+ Clone RTA Replacement PCTG Bell Cap 3.5ml $8.99
YFTK Replacement PCTG Bell Cap holds 3.5ml capacity, designed for YFTK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack
ShenRay Four One Five 415 S61 Genesis Clone RDTA Replacement PEI Tank Tube 2.0ml 22mm $2.99
ShenRay PEI Tank Tube is designed for ShenRay Four One Five 415 S61 Genesis Clone RDTA Rebuildable Dripping Tank Vape Atomizer. This ShenRay Tank Tube holds 2.0ml capacity. 1 PC / Pack
Старый 25.04.2021, 05:04 Автор темы   74
3FVAPE
SXK Link'D NFG Clone RBTA Bridge Tank for SXK BB / Billet Box 316SS + PC 3.5ml $49.9
SXK Link'D NFG Clone RBTA Bridge Tank, a rebuildable atomizer, is designed for Billet Box / SXK BB. Made of 316 stainless steel and PC tank tube, The RBA holds 3.5ml capacity. SXK Link'D NFG Clone RBTA Bridge Tank adopts a 2 post deck design and an adjustable air inlet using inserts. Comes with 5 Airflow insert sizes: 1.0 / 1.5 / 2.0 / 2.5 / 3.0mm and 2 chimneys for both DL and MTL vape Clones.
Original Joyetech eGo Pod System Vape Starter Kit 1000mAh 2.0ml AST Cartridge $14.99
Original Joyetech eGo Pod System Vape Starter Kit, a draw-activated Pod kit, consists of a 1000mAh Joyetech eGo Pod Mod and a 2.0ml AST Cartridge. Joyetech eGo Pod Mod is powered by a 1000mAh built-in battery with a stable output voltage of 3.7V. Designed with no button, Joyetech eGo Pod Mod is controlled by Avatar IC 1.0 chip, thus enabling it to be more consistent, low power consumption and more reliable. Joyetech eGo AST Cartridge holds 2.0ml capacity with side filling system. Equipped with innovative directional airflow, Joyetech eGo Pod Cartridge comes with a coil made of super austenitic stainless steel (AST steel) for a longer lifespan and better flavor and a super boosting flavor and throat hit. 4 colors: Metal Black / Fuchsia Pink / Jungle Green / Sapphire Blue
Original Pluscig V10 Heat Not Burn Vaporizer Vape Pen Starter Kit 900mAh $24.99
Original Pluscig V10 Heat Not Burn Vaporizer Vape Pen Starter Kit is powered by a 900mAh built-in battery, providing about 10~15 heatsticks after fully charged. Monitored by intelligent chip, Pluscig V10 Heat Not Burn Starter Kit will automatically turn off without any operation within 10 minutes. 5 colors: White / Red / Pink / Blue / Black
Original XTAR VC2S Charger for 3.6V / 3.7V Li-ion /IMR/INR/ICR 18350, 18500, 18650, 18700, 20700, 21700, 26650 Batteries, etc. $24.99
Original XTAR VC2S Charger not only is compatible with different kinds and sizes of most batteries like 3.6V/3.7V Li-ion / IMR / INR / ICR from 10440 to 26650: 10440, 14500, 14650, 16340, 17335, 17500, 17670, 18350, 18490, 18500, 18650, 20700, 21700, 22650, 25500, 26650 and 1.2V Ni-MH Ni-CD AAA AA A SC C D but also can be a portable power bank for your any electronic devices. With 0V activation function, XTAR VC2S Charger can bring over-discharged batteries back to life. Equipped with VA LCD screen display, XTAR VC2S Charger is easy for you to check the date you need.
Original Vaporesso Swag PX80 Pod Mod Kit Replacement 510 Adapter $4.29
Original Vaporesso 510 Adapter is designed for Vaporesso Swag PX80 Vape Box Mod Kit and Vaporesso Swag PX80 80W VW Variable Wattage Box Mod to accommodate a wide range of atomizers with 510 threading connection. Made of durable stainless steel, Vaporesso 510 Adapter adopts gold-plated contacts, thus ensuring a firm connection with Swag PX80 mod and maintaining good electrical conductivity. 1 PC / Pack
Старый 26.04.2021, 04:54 Автор темы   75
3FVAPE
Cabeo Clone MTL RTA Rebuildable Tank Vape Atomizer 2.0ml 24mm $23.99
Cabeo Clone MTL RTA Rebuildable Tank Vape Atomizer, a MTL RTA with single coil building deck, holds 2.0ml capacity in 24mm diameter. Cabeo Clone MTL RTA Atomizer features adjustable airflow control, absolutely delivering a great MTL mouth-to-lung vaping experience. Constructed from stainless steel, Cabeo Clone MTL RTA comes with 1 x 510 drip tip connecting ring and is compatible with most of your favorite mods with 510 threading connection, thus meeting with different personal demands.
Original ZQ Xtal Pro 30W Pod System Vape Starter Kit 1000mAh 3.0ml $25.99
Original ZQ Xtal Pro 30W Pod System Vape Starter Kit, a button-activated / draw-activated pod kit, consists of a ZQ Xtal Pro 1000mAh Pod Mod and a 3.0ml Pod Cartridge. ZQ Xtal Pro Pod Mod is integrated with a 1000mAh built-in battery with the power output of 1~30W. Equipped with a 0.69 inch display screen, ZQ Xtal Pro Pod Mod adopts a unique Smart Airflow system and Aspire's professional coil testing technology, delivering a smooth-as-silk flavor. ZQ Xtal Pro Pod Cartridge holds 3.0ml capacity with convenient side filling system.
Original GeekVape Obelisk 60 AIO Kit Replacement Pod Cartridge w/ 0.4ohm & 0.5ohm Coils 4.0ml $10.99
Original GeekVape Obelisk 60 Pod Cartridge holds 4.0ml capacity, designed for GeekVape Obelisk 60 AIO All-in-One Vape Mod Kit. Obelisk 60 Pod Cartridge comes with 1 x GeekVape P0.4 Coil (0.4ohm, suggested wattage: 50~60W) and 1 x GeekVape P0.5 Coil (0.5ohm, 40~50W), meeting your different demands. 1 PC / Pack
Original asMODus Xeneo 80W Pod Mod Kit / Pod Cartridge Replacement Coil Head 0.4ohm $11.99
Original asMODus Xeneo Coil Head is with 0.4ohm resistance, designed for asMODus Xeneo Pod Cartridge and asMODus Xeneo 80W VW Pod System Vape Mod Kit. 5 PCS / Pack
Original asMODus Xeneo 80W Pod Mod Kit / Pod Cartridge Replacement RBA Coil Head $9.99
Original asMODus Xeneo RBA Coil Head is compatible with asMODus Xeneo 80W VW Pod System Vape Mod Kit and asMODus Xeneo Pod Cartridge. 1 PC / Pack
Original ZQ Xtal Pro Pod System Kit / Pod Cartridge Replacement Regular Coil Head 1.0ml $10.99
Original ZQ Xtal Pro Regular Coil Head is with 1.0ohm resistance (suggested wattage: 12~15W), designed for ZQ Xtal Pro 30W Pod System Vape Starter Kit and ZQ Xtal Pro Pod Cartridge. 5 PCS / Pack
Original ZQ Xtal Pro Pod System Kit Replacement Pod Cartridge 3.0ml $2.99
Original ZQ Xtal Pro Pod Cartridge holds 3.0ml capacity with side filling system, designed for ZQ Xtal Pro 30W Pod System Vape Starter Kit. 1 PC / Pack
Старый 27.04.2021, 04:31 Автор темы   76
3FVAPE
Replacement Front + Back Door Panel Plates for Dotaio Mini Vape Pod System Kit (2 PCS) $14.99
The Replacement Door Panel Plates includes a Front Door Panel and a Back Door Panel, suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). 4 colors: Frost Green, Frost Red, Frost Blue, Frost Yellow, Frost Clear
Старый 28.04.2021, 04:38 Автор темы   77
3FVAPE
Original VOOPOO VMATE 17W Pod System Vape Starter Kit 900mAh 3.0ml $19.99
Original VOOPOO VMATE 17W Pod System Vape Starter Kit, a portable draw-activated pod kit, consists of a VMATE 900mAh Pod Mod and a 3.0ml VMATE Pod Cartridge. VOOPOO VMATE Pod Mod is powered by an internal 900mAh battery with Type-C 5V / 1A charging, enough to fire up to 17W. Constructed from durable aluminum alloy, VOOPOO VMATE Pod Mod is a small-sized, concise pod mod without button. VOOPOO VMATE Pod Cartridge holds 3.0ml capacity with side-filling system, connected with the mod via powerful magnetic suction and buckle double reinforcement. Made of PCTG, VMATE Pod Cartridge with 0.7ohm coil adopts 360 degree fully-fit designed and has an independent and one-way condensate space. 4 colors: Silver / Green / Red / Space Gray
YFTK Flash e-Vapor V4.5S+ Clone RTA Replacement PEI Bell Cap 4.0ml $8.99
YFTK Replacement PEI Bell Cap holds 4.0ml capacity, designed for YFTK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. 3 colors: Translucent / Translucent Black / Brown. 1 PC / Pack
Старый 29.04.2021, 05:06 Автор темы   78
3FVAPE
Original Geekvape Aegis Nano 30W Pod System Vape Starter Kit 800mAh 2.0ml Original Price $35.5, Now Only $29.99.
Original GeekVape Aegis Nano 30W Pod System Vape Starter Kit consists of a Aegis Nano 30W 800mAh Pod Mod and a 2.0ml Pod Cartridge. Geekvape Aegis Nano Pod Mod is powered by a 800mAh built-in battery with the maximum power output of 30W (5~30W) and temperature control of 100~315'C / 200~600'F. Equipped With industry-leading Geekvape tri-proof technology and a 0.69 inch display, Geekvape Aegis Nano Pod Mod features adjustable airflow switch and auto output adjustment function, bringing an amazing flavor. Geekvape Aegis Nano Pod Cartridge holds 2.0ml capacity with top filling system. Aegis Nano Pod Cartridge is pre-installed with 0.6ohm (suggested wattage: 20~25W) for a great vaping experience. 6 Colors: Red, Yellow, Light Blue, Camo Blue, Camo Green, Camo Silver
Original GeekVape L200 Kit 200W VW Aegis Legend 2 Box Mod + Z Tank Vape Atomizer 2 x 18650 5.5ml Original Price $84.8, Now Only $64.99.
Original GeekVape L200 Aegis Legend 2 Vape Box Mod Kit consists of a GeekVape Aegis Legend 2 200W VW Box Mod and a 5.5ml GeekVape Zeus Z Sub Ohm Tank Atomizer. GeekVape Aegis Legend 2 Box Mod is powered by 2 x 18650 batteries (not included) with Type-C charging, enough to provide the power output of 5~200W. With upgraded Tri-proof technology, Geekvape L200 (Aegis Legend 2) 200W Mod is designed with a 1.08-inch TFT color full screen. GeekVape Zeus Sub Ohm 2021 Tank holds 5.5ml capacity with top filling system. With direct top airflow and top-to-bottom airflow, Geekvape Z Tank is compatible with Geekvape Z Series Coil, like 1 x Geekvape Z coil 0.2ohm / 0.25ohm (included), creating an awesome vaping experience. 6 colors: Silver, Navy Rainbow, Navy Red, Navy Blue, Grey, Black
Original GeekVape Z50 50W Mod + Z Nano Tank Atomizer Vape Mod Kit 2000mAh 2.0ml/3.5ml 22mm Original Price $63.5, Now Only $53.99.
Original GeekVape Z50 Vape Mod Kit includes a GeekVape Z50 50W 2000mAh Mod and 2.0ml / 3.5ml GeekVape Zeus Z Nano Sub Ohm Tank Atomizer 22mm. GeekVape Z50 Mod is powered by a 2000mAh built-in battery, enought to fire up to 50W. Equipped with a TFT screen, GeekVape Z50 50W Mod is a great box mod for most of atomizers with 510 threading connection. GeekVape Zeus Nano Sub Ohm Tank Atomizer holds 3.5ml / 2.0ml capacity with leakproof top filling system in 22mm diameter. Z Nano Tank features top-to-bottom airflow system and is compatible with Geekvape B series coils, like Geekvape B series coil 0.6ohm (12~25W) and Geekvape B series coil 0.3ohm (pre-installed, suggested wattage: 30~38W) included, delivering a big cloud, smooth flavor, and strong throat hit. 4 colors: Silver, Gun Metal, Rainbow, Black
Original GeekVape L200 Aegis Legend 2 200W VW Variable Wattage Vape Box Mod 2 x 18650 Original Price $62.6, Now Only $49.99.
Original GeekVape L200 Aegis Legend 2 Vape Box Mod is powered by 2 x 18650 batteries (not included) with Type-C charging, enough to fire up to 200W (5~200W). Featuring 1.08-inch TFT color full screen, Geekvape L200 (Aegis Legend 2) 200W Mod adopts upgraded Tri-proof Technology: P68 Rating shockproof, dustproof and waterproof. With 510 threading connection, GeekVape Aegis Legend 2 Box Mod is a good VW box mod for most of your favorite atomizers, like Geekvape Zeus Z Sub Ohm Tank Atomizer (not included). 6 colors: Silver, Navy Rainbow, Navy Red, Navy Blue, Grey, Black
Старый 30.04.2021, 05:10 Автор темы   79
3FVAPE
Original GeekVape Z50 50W VW Variable Wattage Vape Box Mod 2000mAh Original Price $49.99, Now Only $38.99.
Original GeekVape Z50 Vape Box Mod is powered by a 2000mAh built-in battery with the power output of 5~50W. Equipped with a 0.96 inch OLED color display, GeekVape Z50 Mod supports Power mode and Bypass mode, a good VW box mod for most of your favorite atomizer with 510 threading connection, like GeekVape Zeus Nano Sub Ohm Tank Atomizer (not included). 4 colors: Black / Rainbow / Gun Metal / Silver
Original SMOKTech SMOK RPM 4 60W Pod System Vape Starter Kit 1650mAh 5.0ml $32.99
Original SMOKTech SMOK RPM 4 60W Pod System Vape Mod Kit includes a SMOK RPM 4 60W 1650mAh Pod Mod and a 5.0ml SMOK RPM 4 Pod Cartridge. SMOK RPM 4 Pod Mod is powered by a 1650mAh built-in battery with the power output of 5~60W. With a 0.96 inch TFT display, SMOK RPM 4 Pod Mod adopts stepless airflow adjustment design for superb DL / RDL vaping styles. SMOK RPM 4 Pod Cartridge holds 5.0ml capacity with side filling system. There are two kinds of pod cartridge compatible with different types of coils, RPM 4 LP2 Pod cartridge for two LP2 coils and RPM 4 RPM Pod cartridge for all RPM coils. Multiple colors for your choice.
Original FreeMax Marvos T 80W Pod System Vape Starter Kit 3000mAh 4.5ml Original Price $44.99, Now Only $26.99.
Original FreeMax Marvos T 80W Pod System Vape Starter Kit consists of a FreeMax Marvos T 80W 3000mAh Pod System Mod and a 4.5 Marvos T Pod Cartridge. FreeMax Marvos T 80W Pod Mod is powered by a 3000mAh built-in battery with 3-level adjustable power output 20~80W. Monitored by FM Chip 2.0, FreeMax Marvos T Pod System Mod adopts two-side airflow control system, delivering a smart, fast, stable vaping experience. FreeMax Marvos T Pod Cartridge holds 4.5ml capacity with bottom filling system. Marvos T DTL Pod Cartridge is compatible with FreeMax MS mesh coil series, MS coil featuring industry-leading mesh coil technology FM COILTECH4.0, 1 x FreeMax MS Mesh Coil 0.15ohm (suggested wattage: 60~80W), 1 x FreeMax MS Mesh Coil 0.25ohm (40~55W) included, delivering abundant clouds and marvelous flavors. 4 colors: Grey, Blue, Red, Blue
Original GeekVape Aegis Nano 30W Pod Kit Replacement Pod Cartridge w/ 0.6ohm Coil 2.0ml $7.2
Original Geekvape Aegis Nano Pod Cartridge is with 0.6ohm coil, designed for GeekVape Aegis Nano 30W Pod System Vape Starter Kit. Aegis Nano Pod Cartridge holds 2.0ml capacity with convenient top filling system. It is pre-installed with 0.6ohm (suggested wattage: 20~25W), bringing a great vaping experience. Pod Cartridge w/ 1.2ohm Coil is also available. 2 PCS / Pack
Original FreeMax Marvos T 80W Pod Kit Replacement PCTG DTL Pod Cartridge 4.5ml Original Price $9.99, Now Only $3.99.
Original FreeMax Marvos DTL Pod Cartridge is designed for FreeMax Marvos T 80W Pod System Vape Starter Kit. Marvos T Pod Cartridge holds 4.5ml capacity with bottom filling system. Based on FreeMax Fireluke series. Two types: PCTG / Glass. 1 PC / Pack
Original FreeMax Marvos T 80W Pod Kit Replacement MS Mesh Coil Head 0.15ml Original Price $14.99, Now Only $11.99.
Original FreeMax Marvos T 80W Pod Kit Replacement MS Mesh Coil Head is with 0.15ohm resistance (suggested wattage: 60~80W), designed for designed for FreeMax Marvos T 80W Pod System Vape Starter Kit. FreeMax MS Mesh Coil Head 0.25ohm is also available. 5 PCS / Pack
Старый 05.05.2021, 05:44 Автор темы   80
3FVAPE
Coilturd Clone RDA Rebuildable Dripping Vape Atomizer w/ BF Pin 24mm Dia $8.99
Coilturd Clone RDA Rebuildable Dripping Vape Atomizer in 24mm diameter adopts optional single or dual coil configuration and comes with 2 x AFC rings with different airflow, meeting your different vaping demands. Coilturd Clone RDA is suitable for most of your favorite mods with 510 threading connection, like Mechanical Mod, BF Squonker and other box mod. 2 optional colors: Silver / Black
Skyline R / Skyline-R Clone RTA Rebuildable Tank Vape Atomizer w/ 4 MTL Airdisks 3.2ml 22mm Dia $23.65
Skyline R / Skyline-R Clone RTA Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. Constructed from SS316, Skyline R Clone RTA comes with 4 Airdisk-Skyline-R MTL, 0.8mm / 1.0mm (pre-installed) / 1.2mm / 1.5mm, easier to interchange Airdisks without removing the build (plug & play) on the fly. Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck, a good ideal RTA for your favorite mods with 510 threading connection. In addition, Skyline-R Clone RTA is also compatible with Airdisk-Skyline-R RDL Airdisks (Not included), easily switched between RDL and MTL.
YFTK Flash e-Vapor V4.5S+ Clone RTA Replacement PEI Bell Cap $9.99
YFTK Replacement PEI Bell Cap holds 4.0ml capacity, designed for YFTK Flash e-Vapor V4.5S+ Clone RTA Rebuildable Tank Vape Atomizer. 4 optional colors: Translucent Black / Translucent / Brown / Translucent Knurl / Brown Knurl
Original SMOKTech SMOK RPM 4 Pod Mod Kit Replacement RPM Empty Pod Cartridge 4.5ml $6.99
Original SMOKTech SMOK RPM 4 RPM Empty Pod Cartridge is designed for SMOKTech SMOK RPM 4 60W Pod System Vape Mod Kit, compatible with all RPM coils (coil not included). SMOK RPM 4 Pod Cartridge holds 5.0ml capacity with side filling system. SMOK RPM 4 LP2 Empty Pod Cartridge is also avialable. 3 PCS / Pack
Original SMOKTech SMOK RPM 4 Pod Mod Kit / LP2 Pod Cartridge Replacement LP2 DC 0.6ohm Coil Head $13.99
Original SMOKTech SMOK LP2 DC 0.6ohm Coil Head is designed for SMOKTech SMOK RPM 4 60W Pod System Vape Mod Kit and SMOKTech SMOK RPM 4 LP2 Pod Cartridge (suggested wattage: 15~25W). LP2 Meshed 0.23ohm DL Coil Head is also available. 5 PCS / Pack
Время генерации страницы 0.33356 секунды с 15 запросами
