Просмотров в теме 66639   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 12.03.2021, 04:46 Автор темы   41
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
Original Innokin Sceptre 1400mAh Pod System Mod Vape Starter Kit $24.98
Original Innokin Sceptre pod system vape starter kit is powered by a 1400mAh built in battery. With two coils to choose from, a 1.2ohm for MTL Vaping and a 0.5ohm RDL Coil for high wattages, the Sceptre can easily identify and automatically adjust settings for the ultimate vaping experience. With an auto draw and button operation the Sceptre also features Boost Mode which can create more heat and vapor. Rechargeable via the micro USB port, Secptre Pod Kit comes with a 3.0ml refillable pods that are easily replaceable with Innokin's latest Sceptre coils by simply twisting the bottom of the pod to remove and replace the coils. 12 colors for your choice.
Original SMOKTech SMOK Novo 4 Pod Kit / Pod Cartridge Replacement LP1 DC 1.0ohm MTL Coil Head $12.99
Original SMOKTech SMOK LP1 DC 1.0ohm MTL Coil Head is designed for SMOKTech SMOK Novo 4 Pod System Starter Kit and SMOKTech SMOK Novo 4 Pod Cartridge (suggested wattage: 10~15W). It works on a leak-proof vaping experience and brings strong throat-hit and excellent MTL taste. LP1 Meshed 0.8ohm Coil Head and LP1 DC 0.8ohm MTL Coil Head are also available. 5 PCS / Pack
Original Vaporesso Luxe Q Pod System Vape Kit Replacement Pod Cartridge w/ 0.8ohm Mesh Coil 2.0ml $8.99
Original Vaporesso Luxe Q Pod Cartridge with 0.8ohm Mesh Coil Head is designed for Vaporesso Luxe Q Pod System Vape Kit. It holds 2.0ml visible capacity with top filling system. Two options: 0.8ohm / 1.2ohm. 2 PCS / Pack
Original SMOKTech SMOK Novo 4 Pod Kit Replacement Empty Pod Cartridge 2.0ml $5.99
Original NOVO 4 Empty Pod Cartridge is designed for SMOKTech SMOK Novo 4 25W 800mAh Pod System Starter Kit and compatible with LP1 Coils (not included). NOVO 4 Pod Cartridge holds 2.0ml capacity with side filling system. With 3 silicone rings, it can realize No leakage anymore to a great extent. Two colors: Transparent Black / Transparent. 3 PCS / Pack
Original Coilology MTL Fused Clapton Spools Wire for RTA / RDA / RDTA Vape Atomizer 2-30 / 40GA $4.99
Original Coilology MTL Fused Clapton Spools Wire comes with 2-30 / 40GA, 3.74ohm/ft, 10 feet. It is made of Ni80, designed for RTA / RDA / RDTA Vape Atomizer. Coilology MTL Staple Spool Wire features an intuitive way to experiment with exotic coil configurations and distinctive build structures for an advanced rebuildable experience. It can be shaped in different ways, Fused, Framed, and Clapton styles, all special machine-twisted for a precise weave and high consistency throughout each spool. MTL Fused Clapton Spools Wire 4-0.3x0.1 /40GA, 3.06ohm / ft, 10ft is also available.
3FVAPE вне форума   Вверх
Старый 15.03.2021, 05:02 Автор темы   42
3FVAPE
ULTON Rook Clone RPGA Rebuildable Professional Genesis Atomizer w/ BF Pin Silver Mesh / Cotton Deck $35.99
ULTON Rook Clone RPGA Rebuildable Professional Genesis Atomizer holds 3.0ml capacity in 22mm diameter. ULTON Rook Clone RPGA comes with 2 different bells for mesh and cotton respectively. On the body, it has external airflow controls, 0.8mm, 1.0mm, 1.2mm, 1.4mm, 1.6mm, 2 x 0.8mm, 2 x 1.0mm, 2 x 1.2mm and 1.5mm slot, meeting your different demands. With 510 threading connection, this Rebuildable Professional Genesis Atomizer fits for most of mods. Two colors: Matte Silver / Silver
ULTON Skyline R Clone RTA Rebuildable Vape Atomizer w/ 4 RDL Airdisks 22mm Dia $29.9
ULTON Skyline R Clone RTA Rebuildable Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck, a good ideal RTA for your favorite Mods with 510 threading connection. Skyline R Clone RTA comes with 4 Airdisk-Skyline-R RDL Airdisks, 2mm / 1.5 x 3mm / 1.5 x 3.9mm / 2 x 3.9mm Airdisk-Skyline-R RDL, by easy interchange operation without removing the build (plug & play) on the fly. In addition, it is also compatible with Airdisk-Skyline-R MTL Airdisks (Not included), easily switched between RDL and MTL. ULTON Skyline R Clone RTA with MTL Airdisks is also available.
ULTON Skyline R Skyline-R Clone RTA Replacement RDL Airdisks 2.0mm / 1.5 x 3mm / 1.5 x 3.9mm / 2 x 3.9mm $9.99
ULTON RDL Airdisks is designed for ULTON Skyline R Clone RTA Rebuildable Vape Atomizer, including 1 x Airdisk-Skyline-R RDL 2mm, 1 x Airdisk-Skyline-R RDL 1.5 x 3mm, 1 x Airdisk-Skyline-R RDL 1.5 x 3.9mm, 1 x Airdisk-Skyline-R RDL 2 x 3.9mm. ULTON RDL Airdisks MTL Airdisks: 0.8mm / 1.0mm / 1.2mm / 1.5mm is also available. 4 PCS / Pack
ULTON Skyline R Clone RTA Replacement Tank Tube 3.2ml $3.98
ULTON Replacement Glass Tank holds 3.2ml capacity, designed for ULTON Skyline R Clone RTA Rebuildable Vape Atomizer. 2 PCS / Pack
Старый 16.03.2021, 04:51 Автор темы   43
3FVAPE
Original Eleaf iStick Power 2 Kit 80W 5000mAh VW Box Mod + GTL Pod Tank $52.99
Original Eleaf iStick Power 2 Kit includes an Eleaf iStick Power 2 80W VW Box Mod and a 4.5ml GTL Pod Tank. Eleaf iStick Power 2 Box Mod is integrated by a 5000mAh built-in battery, enough to fire up to 80W (1~80W). Equipped with 0.96 inch TFT screen, Eleaf iStick Power 2 Box Mod supports the regular power mode and the easy-to-use smart mode in which the device will intelligently identify your favorite output for the coil you installed. Eleaf GTL Pod Tank holds 4.5ml capacity with bottom filling system. GTL pod tank adopts dual sides airflow control, each side with one big and five tiny holes, ensuring free adjustment of air inflow. With the magnetic connection it is easy to change coil and fill liquid. It is compatible with Eleaf GTL coils, like Eleaf GTL 0.4ohm Coil and GTL 0.8ohm Coil (included), delivering you MTL / DL vaping experience. Four colors: Blue, Red, Dark Brown, Light Brown
Original Eleaf iStick Power 2C Kit 160W VW Box Mod + GTL Pod Tank $51.99
Original Eleaf iStick Power 2C Kit includes an Eleaf iStick Power 2C 160W VW Box Mod and a 4.5ml GTL Pod Tank. Eleaf iStick Power 2C Box Mod is powered by 2 x 18650 batteries (not included), enough to fire up to 160W (1~160W). Equipped with 0.96 inch TFT screen, Eleaf iStick Power 2C Box Mod supports the regular power mode and the easy-to-use smart mode in which the device will intelligently identify your favorite output for the coil you installed. Eleaf GTL Pod Tank holds 4.5ml capacity with convenient bottom filling system. GTL pod tank features dual sides airflow control, each side with one big and five tiny holes, ensuring free adjustments of air inflow. It is compatible with Eleaf GTL coils, like Eleaf GTL 0.4ohm Coil and GTL 0.8ohm Coil (included), bringing you MTL / DL vaping experience. Four colors: Blue, Red, Dark Brown, Light Brown
Старый 17.03.2021, 05:08 Автор темы   44
3FVAPE
Original AIRISTECH Herbva 5G 1000mAh Dry Herb Vaporizer Vape Starter Kit $30.99
Original Airistech Herbva 5G Vaporizer Kit is powered by 1000mAh built-in battery with three adjustable temperatures (390'F / 405'F / 420'F) meeting your different vaping demands. It comes with 2 kinds of mouthpieces, Flat Mouthpiece for portability and Glass Mouthpiece for better taste and the healthy ceramic heating chamber, which produces pure vapor. Herbva 5G Vaporizer Kit will bring you into a new vaporizer generation for its extreme portability, easy operation and great taste. Three colors: Black / White / Red
Original Airistech Mystica II 450mAh Vaporizer Built-in Battery Vape Mod w/ 12mm Diameter Hole for 510 Thread Atomizer $12.99
Original Airistech Mystica II Vaporizer Built-in Battery Vape Mod is powered by a 450 built-in battery. It features a 12mm diameter hole, fit for most atomizers. With magnetic connection, Airistech Mystica II Mod is and designed with oil level view widow to check the oil anytime and compatible with all 510 thread oil atomizers (5ml / 1ml magnetic adopter included, Atomizer not included), fitting your personal style. As a variable voltage vaporizer, it can work well with different voltage according to different oils: 3.4V / 3.7V / 4.0V.
Original Airistech Mystica III 350mAh Vaporizer Built-in Battery Vape Mod w/ 12mm Diameter Hole for 510 Thread Atomizer $13.99
Original Airistech Mystica III Vaporizer Built-in Battery Vape Mod, a pocket sized premium vaporizer pen mod, is powered by a 350mAh built-in battery. It features a 12mm diameter hole, fit for most atomizers. With magnetic connection, Mystica III Mod is compatible with all 510 thread oil atomizers (2 x Magnetic Adapter included, Atomizer not included) and designed with oil level view widow to check the oil anytime, fitting your personal style. As a variable voltage vaporizer, it can work well with different voltage according to different oils: 3.4V / 3.7V / 4.0V. Three colors: Black / White / Blue
Original Airistech Quaser 350mAh Vaporizer Pen Battery Vape Mod $5.99
Original Airistech Quaser Vaporizer Pen Battery Vape Mod is powered by a 350mAh built-in battery with USB charging port and accepts all 510 thread coils (not included). With single control button design, Quaser Vaporizer Battery Mod is easy to begin heating your material. As a variable voltage vaporizer, Quaser Vaporizer battery Mod can work well with different voltage according to different oils: 3.4V / 3.7V / 4.0V. Four Colors: Black / Blue / Red / Rainbow
Original Airistech Quaser 350mAh Vaporizer Pen Vape Kit Quartz Heating Technology $10.99
Original Airistech Quaser 350mAh Vaporizer Pen Vape Kit contains a Quaser Vaporizer Pen Battery Vape Mod and a Qcell atomizer. Airistech Quaser Vaporizer Pen Battery Vape Mod is powered by a 350mAh built-in battery with USB charging port and accepts all 510 thread coils (not included). Quaser Vaporizer battery Mod, as a variable voltage vaporizer, can work well with different voltage according to different oils: 3.4V / 3.7V / 4.0V. With single control button design, Airistech Quaser Vaporizer Battery is easy to begin heating your material. Qcell Atomizer features an innovative dab mouthpiece which has a built-in dab tool to make the dabbing on the go easier. Qcell Atomizer applies patented Quartz Heating Technology to eliminate waste, improve flavor and prevent clogging. It adopts removable heating coil design, which can maximize the surface area to provide even heating, bringing you an excellent vaping experience. Four Colors: Black / Blue / Red / Rainbow
Original Airistech Airis 8 Vaporizer Pen Vape Kit Replacement C2 Dab Coil $8.99
Original Airistech C2 Dab Coil is designed for Airistech Airis 8 Vaporizer Pen Vape Kit. It aims at using with wax concentrates. 5 PCS / Pack
Original Airistech Quaser Vaporizer Kit / Quaser Atomizer Replacement Qcell Quartz Coil $9.99
Original Airistech Qcell Quartz Coil is designed for Airistech Quaser Vaporizer Pen Vape Kit and Airistech Quaser Atomizer. It aims at maximizing the surface area to provide even heating and avoiding heating a quartz banger, bringing a pure taste, big vapor and high adsorption. 5 PCS / Pack
Старый 18.03.2021, 05:01 Автор темы   45
3FVAPE
Original SMOKTech SMOK Arcfox 230W TC VW Mod + TFV18 Sub Ohm Tank Kit $66.99
Original SMOKTech SMOK Arcfox 230W VW Mod Kit includes a SMOK Arcfox 230W VW TC Mod and a 7.5ml SMOK TFV18 Sub Ohm Tank Atomizer. SMOK Arcfox Mod is powered by 2 x 18650 batteries (not included) with Type-C 2A charging and a 0.96 inch screen, enough to provide the maximize output power of 230W (5~230W). Featuring VW mode (5~230W) and TC mode (10~80W), ARCFOX Mod allows you to adjust the current resistance, wattage and voltage to achieve accurate control over power and temperature. SMOK TFV18 Sub Ohm Tank Atomizer holds 7.5ml capacity with top filling system. TFV18 Sub Ohm Tank is designed with the adjustable bottom airflow system and comes with two replaceable meshed coils, TFV18 Meshed 0.33ohm Coil preinstalled and TFV18 Dual Meshed 0.15ohm Coil included, for a DL or RDL vaping experience. Six colors: Prism Chrome, Prism Red, Prism Blue, Prism Gunmetal, Prism Gold, Bright Black
Original SMOKTech SMOK Arcfox 230W TC VW Vape Box Mod $50.99
Original SMOKTech SMOK Arcfox Vape Box Mod is powered by 2 x 18650 batteries (not included) with the range of output power 5~230W. Featuring VW mode (5~230W) and TC mode (10~80W), ARCFOX Mod allows you to adjust the current resistance, wattage and voltage to achieve accurate control over power and temperature. With 510 threading connection, it is compatible with most of your favorite atomizers. Equipped with 0.96 inch TFT screen, it adopts a powerful performance of the chipset to ensure each puff safe and reliable, delivering an amazing vaping experience. Six colors: Prism Chrome, Prism Red, Prism Blue, Prism Gunmetal, Prism Gold, Bright Black
Original Eleaf iStick Power 2 80W 5000mAh VW Vape Box Mod $41.99
Original Eleaf iStick Power 2 Vape Box Mod is powered by a 5000mAh built-in battery with Type-C 2A charging, enough to fire up to 80W (1~80W). Equipped with 0.96 inch TFT screen, Eleaf iStick Power 2 Box Mod supports the regular power mode and the easy-to-use smart mode in which the device will intelligently identify your favorite output for the coil you installed. With 510 threading connection, Eleaf iStick Power 2 Box Mod fits most of your atomizers. Five colors: Blue / Red / Light Brown / Dark Brown / Black
Original Eleaf iStick Power 2C 160W VW Vape Box Mod $41.99
Original Eleaf iStick Power 2C Vape Box Mod is powered by 2 x 18650 batteries (not included) with Type-C 5V / 2A charging, enough to fire up to 160W (1~160W). Equipped with 0.96 inch TFT screen, Eleaf iStick Power 2C Box Mod supports the regular power mode and the easy-to-use smart mode in which the device will intelligently identify your favorite output for the coil you installed. With 510 threading connection, Eleaf iStick Power 2 Box Mod fits most of your atomizers. Five colors: Blue / Red / Light Brown / Dark Brown / Black
Skyline R Clone RTA Rebuildable Vape Atomizer w/ 2 Airdisks 1.0mm / 1.5 x 3mm $23.99
Skyline R Clone RTA Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. Skyline R Clone RTA comes with 2 air disks: 1.0mm and 1.5 x 3 mm with easy interchange operation. In addition, it is also compatible with Airdisk-Skyline-R RDL Airdisks and MTL Airdisks (both not included), easily switched between RDL and MTL. Constructed from SS316, Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck, a good ideal RTA for your favorite Mods with 510 threading connection.
Skyline R Skyline-R Clone RTA Replacement MTL Airdisks $4.59
These MTL Airdisks is designed for Skyline R Clone RTA Rebuildable Vape Atomizer, including 1 x Airdisk-Skyline-R MTL 0.8mm, 1 x Airdisk-Skyline-R MTL 1.0mm, 1 x Airdisk-Skyline-R MTL 1.2mm, 1 x Airdisk-Skyline-R MTL 1.5mm. RDL Airdisks for Skyline R Clone RTA is also available.
Старый 19.03.2021, 05:18 Автор темы   46
3FVAPE
Original VOOPOO Vinci 15W 800mAh Pod System Vape Starter Kit $26.99
Original VOOPOO Vinci Pod System Vape Starter Kit includes a Vinci 800mAh Pod Mod and a 2.0ml Pod Cartridge. Vinci Pod System Mod is powered by an 800mAh built-in battery with steady output power of 15W. Made of zinc alloy, Vinci Pod Mod is designed with an infinite airflow toggle on the body. Vinci Pod Cartridge holds 2.0ml capacity with side filling system. Vinci Pod Visible Cartridge adopts leak-resistant structure. It comes with a 0.8ohm built-in coil, delivering a pure flavor and soft vapor. Seven color in total for your choice.
Coppervape Skyline-R Clone RTA Rebuildable Tank Vape Atomizer w/ 2 x MTL Airdisks 3.2ml 22mm $26.99
Coppervape Skyline-R / Skyline R Clone RTA (Skyline V2) Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. Constructed from SS316, Coppervape Skyline R Clone RTA (Skyline V2) comes with 2 x MTL Airdisks: 1.2mm and 2.0mm, easier to interchange Airdisks without removing the build (plug & play) on the fly. In addition, it is also compatible with Airdisk-Skyline-R RDL Airdisks and MTL Airdisks (both not included), easily switched between RDL and MTL. With 510 threading connection, Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck.
SXK Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer w/ MTL 2.0mm Airdisk 3.2ml 22mm Dia Original Price $27.9, Now Only $24.9.
SXK Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. With 510 threading connection, SXK Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck, a good ideal RTA for your favorite Mods. Constructed from SS316, SXK Skyline R Clone RTA comes with 1 x MTL Airdisk 2.0mm, easier to interchange Airdisks without removing the build (plug & play) on the fly. In addition, it is also compatible with Airdisk-Skyline-R RDL Airdisks and MTL Airdisks (both not included), easily switched between RDL and MTL.
Coppervape Skyline R / Skyline-R Clone RTA Replacement Glass Tank Tube $1.39
Coppervape Replacement Glass Tank Tube holds 3.2ml capacity, designed for Coppervape Skyline R / Skyline-R Clone RTA (Skyline V2) Rebuildable Tank Vape Atomizer. Coppervape tank tube comes in 3 colors and two material: Glass: Translucent Black, Transparent; PEI: Brown 1 PC / Pack
Coppervape Skyline R / Skyline-R Clone RTA Replacement RDL Airdisks Set $3.99
Coppervape RDL Airdisks Set is designed for Coppervape Skyline R / Skyline-R Clone RTA (Skyline V2) Rebuildable Tank Vape Atomizer, including 1 x Airdisk 1.5 x 3mm, 1 x Airdisk 1.5 x 3.9mm, 1 x Airdisk 2 x 3.9mm. Made of SS316, it is a special custom designed and high precision machined part for the Skydeck, which regulates the airflow to your resistance and defines how tight or open is your draw. Coppervape MTL Airdisks Set is also available: 0.8mm / 1.0mm / 1.5mm.
SXK Skyline R / Skyline-R Clone RTA Replacement Rectangle Long Strip Slot RDL Airdisks Set Original Price $8.9, Now Only $7.5.
SXK Replacement Rectangle RDL Airdisks Set is designed for SXK Skyline R / Skyline-R Clone RTA Rebuildable Tank Vape Atomizer, including 1 x Rectangle RDL Airdisk 1.5 x 3.0mm, 1 x Rectangle RDL Airdisk 1.5 x 3.9mm, 1 x Rectangle RDL Airdisk 2 x 3.9mm. SXK Circular Hole MTL Airdisks Set is also available: 0.8mm, 1.0mm, 1.2mm, 1.5mm
Original VOOPOO Vinci 15W Pod Kit Replacement Pod Cartridge w/ 0.8ohm Coil $7.99
Original VOOPOO Vinci Replacement Pod Cartridge with 0.8ohm coil holds 2.0ml capacity, designed for VOOPOO Vinci Pod System Vape Starter Kit. 3 PCS / Pack
Старый 20.03.2021, 05:11 Автор темы   47
3FVAPE
Original Eleaf iStick Power 2 Kit 80W VW Box Mod + GTL Pod Tank 5000mAh $52.99
Original Eleaf iStick Power 2 Kit contains an Eleaf iStick Power 2 80W VW Box Mod and a 4.5ml GTL Pod Tank. Eleaf iStick Power 2 Box Mod is powered by an internal 5000mAh battery with Type-C 5V / 2A charging and 0.96 inch TFT screen, enough to fire up to 80W (1~80W). Monitored by smart Avatar chip, Eleaf iStick Power 2 Box supports not only the regular power mode, but also the easy-to-use smart mode and voltage mode in which it will intelligently recommend your usual settings and the optimum power / voltage for coils you installed. Eleaf GTL Pod Tank holds 4.5ml capacity with convenient bottom filling system. GTL pod tank adopts dual airflow system, each side with one big and five tiny holes, ensuring free adjustments between the maximum and extremely restricted air inflow. With the magnetic connection, it is compatible with Eleaf GTL coils, like Eleaf GTL 0.4ohm Coil (Suggested wattage: 20~30W) and GTL 0.8ohm Coil (12~18W) (included), bringing you RDL & DL vaping experience. Five color: Black / Red / Blue / Light Brown / Dark Brown
Original Eleaf iStick Power 2C Kit 160W VW Box Mod + GTL Pod Tank Avatar Chip $51.99
Original Eleaf iStick Power 2C Kit contains an Eleaf iStick Power 2C 160W VW Box Mod and a 4.5ml GTL Pod Tank. Equipped with 0.96 inch TFT screen, Eleaf iStick Power 2C Box Mod is powered by 2 x 18650 batteries (not included), enough to fire up to 160W (1~160W). Imbedded with smart Avatar chip, Eleaf iStick Power 2C Mod supports not only the regular power mode, but also the easy-to-use smart mode and voltage mode in which it will intelligently recommend your usual settings and the optimum power / voltage for different coils you install. Eleaf GTL Pod Tank holds 4.5ml capacity with convenient bottom filling system. GTL pod tank adopts dual airflow system, each side with one big and five tiny holes. With the magnetic connection, it is compatible with Eleaf GTL coils, like Eleaf GTL 0.4ohm Coil (Suggested wattage: 20~30W) and GTL 0.8ohm Coil (12~18W) (included), bringing you RDL & DL vaping experience. Five color: Black / Red / Blue / Light Brown / Dark Brown
Original ZQ Xtal 520mAh Pod System Vape Starter Kit $20.99
Original ZQ Xtal pod system is powered by a 520mAh built-in battery. Its unique Smart Airflow system lets you enjoy a velvety, smooth-as-silk satisfaction that can beat any kind of cigarettes. It combined Aspire's professional coil testing technology and the extraordinary integration of coil resistance, vapor, temperature, which brings you an Original taste of your favorite e-liquid. Six Colors: Sakura Sunset / Teal / Red / Gun Metal / Blue Pink / Black
Original Vapefly Kriemhild Sub Ohm Tank Rebuildable Meshed Coil Wire + Cotton Set 0.3ohm $6.99
Original Vapefly Kriemhild Rebuildable Meshed Coil Wire + Cotton Set is especially designed for Vapefly Kriemhild Sub Ohm Tank Atomizer, including 10 x 0.3ohm Meshed Coil Wire, 10 x Cotton.
Original Vapefly Kriemhild Sub Ohm Tank Rebuildable Meshed Coil Accessories $8.99
Original Vapefly Kriemhild Rebuildable Meshed Coil Accessories is designed for Vapefly Kriemhild Sub Ohm Tank Atomizer, including 1 x Coil Rod, 1 x Frame, 1 x Positive Plate, 4 x Insulation Rings, 4 x Silicon O-rings. With Kriemhild Rebuildable Meshed Coil Accessories, you can easily turn your Kriemhild Sub Ohm Tank into a rebuildable tank. (Mesh not included)
Replacement Inner Door for dotMod dotAIO Pod $19.99
The Replacement Inner Door is made from Acrylic and is suitable for dotMod dotAIO Pod System Vape Kit. Multiple colors for your choice. 1 PC / Pack
Replacement Small Button for dotMod dotAIO Vape Pod System $5.99
The Replacement Small button is made from POM and is suitable for dotMod dotAIO Vape Pod System. 1 PC / Pack. (Button only, Pod system not included) Multiple colors for your choice.
Replacement Button for dotMod dotAIO Vape Pod System $5.99
The Replacement fire button is made from POM and is suitable for dotMod dotAIO Vape Pod System. 1 PC / Pack. (Button only, Pod system not included) Multiple colors for your choice.
Never Normal Whistle V2 Clone 510 Drip Tip + Button + Small Button for dotMod dotAIO Pod $13.99
The Never Normal Whistle V2 Clone 510 Drip Tip + Button + Small Button Set is made from POM and is suitable for dotMod dotAIO Pod System. Multiple colors for your choice.
Whistle V2 Clone 510 Drip Tip for DotMod DotAIO Pod / Billet BB Box Mod / RDA / RTA / RDTA Vape Atomizer $4.99
The Whistle V2 Clone 510 Drip Tip is made from POM and suitable for DotMod DotAIO Pod System / Billet BB Box Mod Kit / RDA / RTA / RDTA Vape Atomizer. Multiple colors for your choice.
Старый 22.03.2021, 04:44 Автор темы   48
3FVAPE
Original Anlerr TIVA 23W Dry Herb Vaporizer Vape Kit 1000mAh $35.99
Original Anlerr TIVA Dry Herb Vaporizer Vape Kit is integrated with a 1000mAh built-in battery, enough fire up to 23W, baking herb and leaf fully and delivering a pure, taste, smooth airflow. With advanced OLED display, it allows you to adjust temperature range from 300~435'F / 149~224'C in 30s quick heating. Anlerr TIVA Dry Herb Vaporizer comes with ceramic heating chamber and isolated airflow, which ensure it to heat in a short time and deliver smooth airflow. In addition, it has memory function, an ideal portable no combustion vaporizer with big vapor, full baked, pure taste and smooth airflow.
Original Anlerr Pipevape 30W Dry Herb Vaporizer Vape Kit 1000mAh $39.99
Original Anlerr Pipevape 30W Dry Herb Vaporizer Vape Kit, a portable and cool pipe shape vaporizer, is powered by a 1000mAh built-in battery, fire up to 30W. Imbedded with smart chip, it can adjust accurately temperature: 300~435'F / 149~224'C. Equipped with 1.26 inch large OLED display, Anlerr Pipevape Dry Herb Vaporizer is designed with a unique, deep and narrow food-grade ceramic heating chamber, which has enough room to load dry herb for a typical session In addition, it comes with the isolated airflow, delivering a more smooth airflow and quick heating time.
Старый 23.03.2021, 04:59 Автор темы   49
3FVAPE
Original GeekVape Obelisk 120 FC Z Kit 120W 3700mAh VW Mod + Z Tank w/ Fast Charger Original Price $129.9, Now Only $93.99.
Original GeekVape Obelisk 120 FC Z Kit consists of an Obelisk 120 FC Z 120W 3700mAh Mod and a 3.5ml / 5.0ml Z Sub Ohm Tank (Zeus Sub Ohm Tank). GeekVape Obelisk 120 FC Z VW Mod is integrated with a 3700mAh built-in battery, enough to fire up to 120W (5~120W). Obelisk 120 FC Z Mod, as the world's fist vape with safe fast charging, can be fully charged with USB-C Cable in a short time for a long lasting vaping experience. With the upgraded chip, it supports Power / TC-SS / TCR / VPC / Bypass / OTG modes. GeekVape Z Sub Ohm Tank Atomizer holds 3.5ml / 5.0ml capacity with top filling system in 26mm Diameter. Z Tank features direct top airflow and the top-to-bottom airflow to create massive flavor and vapor boost while preserving its leakproof protection element. In addition, it is with quick slide coil design for quick access coil replacement. Z Tank is perfectly compatible with GeekVape Z Series Coils, the high grade KA1 coil, like GeekVape Z 0.4 Coil 0.4ohm (50~60W) and Z 0.2 Coil 0.2ohm (Pre-installed, 70~80W) included. Four colors: Blue, Gunmetal, Black, Silver
Original GeekVape Obelisk 120 FC Z 120W TC VW Variable Wattage Box Mod w/ Fast Charger 3700mAh Original Price $79.9, Now Only $69.99.
Original GeekVape Obelisk 120 FC Z Mod is the world's fist vape with safe fast charging, which can be fully charged with USB-C Cable in a short time for a long vaping experience. Obelisk 120 FC Z VW Mod is powered by a 3700mAh built-in battery with the maximum output power of 120W (5~120W). It is embedded with the upgraded chip to supports Power / TC-SS / TCR / VPC / Bypass / OTG modes. Equipped with 0.96 inch TFT screen, it allows you to easily check the temperature (TC 200~600'F / 100~315'C) and other data you need. With 510 threading connection, it is fit for most of your favorite atomizers. Four colors: Blue, Gunmetal, Black, Silver
Original SMOKTech SMOK MORPH POD-40 40W Pod System Vape Kit 2000mAh 3.7ml $37.99
Original SMOKTech SMOK MORPH POD-40 Pod System Vape Kit includes a MORPH POD-40 40W 2000mAh Pod Mod and a 3.7ml MORPH POD-40 Pod Cartridge. MORPH POD-40 Pod Mod is powered by a 2000mAh built-in battery with Max 1.4A fast charging, enough reach up to 40W (5~40W). SMOK MORPH POD-40 Pod Kit adopts adjustable airflow inlet for MTL and DTL optional vaping experience. SMOK MORPH POD-40 Pod Cartridge holds 3.7ml capacity with top filling system. It is compatible with RPM Coils, RPM Triple Coil 0.6ohm and RPM Mesh 0.4ohm Coil included. 8 colors in total
Original SXK Supbox Box Mod Kit Replacement 510 Atomizer + Pod Cartridge Case Cage Sleeves Original Price $13.9, Now Only $11.99.
The Replacement Case Cage Sleeves set comes with 2 PCS pack. One is for 510 RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer and the other is for Pod Cartridge. It is suitable for Original SXK Supbox Vape Box Mod Kit. Four colors: Blue, Yellow, Red, Orange
Старый 24.03.2021, 04:56 Автор темы   50
3FVAPE
Original Advken Potento 560mAh Pod System Vape Starter Kit 2.5ml 1.2ohm $24.99
Original Advken Potento Pod System Vape Starter Kit, a pod kit with a voltage adjustable knob, is powered by a 560mAh built-in battery. By rotating the bottom potentiometer control knob, Advken Potento Pod can be adjusted voltage from 3.2V to 4.2V for most flawless flavor and effortless vapor. Made of PCTG, Advken Potento pod cartridge with 1.2ohm coil holds 2.5ml E-juice capacity with side filling design.
Original Advken Orcas Pod System Vape Starter Kit 360mAh 2.0ml 1.2ohm $14.99
Original Advken Orcas Pod System Vape Starter Kit contains an Orcas 360mAh Pod Mod and a 2.0 Orcas Pod Cartridge. Advken Orcas Pod System Mod, a draw-activated firing Mod charged via Type-C, is integrated with a 360mAh built-in battery at the steady output power of 10W. Constructed from aluminum alloy, it is designed with LED battery life indicator for you to check the battery level anytime. Advken Orcas Pod Cartridge, a mesh coil pod cartridge with 1.2ohm KA1 coil, holds 2.0ml capacity with side filling system.
Original Advken Orcas Pod Kit Replacement Pod Cartridge w/ 1.2ohm Coil 2.0ml $7.99
Original Advken Orcas Pod Cartridge with 1.2ohm KA1 wire cotton coil holds 2.0ml capacity with side filling system. Made of PCTG, Advken Orcas Pod Cartridge is especially designed for Advken Orcas Pod System Vape Starter Kit. 3 PCS / Pack
SXK Replacement Glass Tank Tube for Skyline-R / Skyline R Clone RTA 3.2ml $1.99
This SXK replacement Glass Tank Tube is especially designed for SXK Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer. Made of Glass, it holds 3.2ml capacity. 1 PC / Pack
Старый 25.03.2021, 04:46 Автор темы   51
3FVAPE
Original Vandy Vape Requiem BF Mechanical Vape Box Mod Kit 1 x 18650 Original Price $55.99, Now Only $42.99.
Original Vandy Vape Requiem BF Mechanical Vape Box Mod Kit, a full mechanical mod kit, consists of a Requiem BF Mod and a BF RDA. Requiem BF Mod is powered by 1 x 18650 battery (not included) with safety switch to lock power button design. Requiem Botton Feeder Mod features silver contact and different alloys for maximum conductivity and comfortable grip. Requiem Squonker Mod has a 6.0ml squonk bottle, which can be filled via 3 different methods. BF RDA Atomizer with a Fused Clapton Coil 0.26ohm is designed with single coil configuration in 24mm diameter. Four colors: Craftsman (Brass), Shadow King, Ghost Samurai, Craftsman (Silver)
Original Digiflavor Drop V1.5 RDA Rebuilable Dripping Vape Atomizer w/ BF Pin Dual Coil Configuration 24mm Original Price $34.99, Now Only $24.99.
Original Digiflavor Drop V1.5 RDA Rebuilable Dripping Vape Atomizer is a dual coil RDA in 24mm diameter. Drop V1.5 RDA features classic drop deck with four large post holes in a rectangular-shaped multi-airslot design, offering DL / RDL vaping experience. DROP RDA V1.5 adopts gold-plated build deck for superior connectivity with dual-coil DIY system. With 510 threading connection, it fits for most of your favorite mods and is also compatible with squonk mods by BF Pin. Multiple colors for your choice.
Original Vandy Vape Requiem BF Kit Replacement Squonker E-Liquid Bottle 6.0ml $3.99
Original Vandy Vape Requiem BF E-Liquid Squonker Bottle is designed for Vandy Vape Requiem BF Mechanical Vape Box Mod Kit. BF E-Liquid Bottle holds 6.0ml capacity and can be filled by three methods, easy for operation. Three colors: Ultem / White / Black. 1 PC / Pack
Original SMOKTech SMOK MORPH POD-40 Pod Kit Replacement Empty Pod Cartridge 3.7ml $5.99
Original SMOKTech SMOK MORPH POD-40 Empty Pod Cartridge is especially designed for SMOKTech SMOK MORPH POD-40 Pod System Vape Kit. MORPH POD-40 Pod Cartridge holds 3.7ml capacity with top filling system and is compatible with RPM Coils (not included). 3 PCS / Pack
Original Auguse Era V2 510 Bevel Drip Tip for RBA / RTA / RDA Vape Atomizer $4.99
Original Auguse Era V2 510 Bevel Drip Tip consists of a mouthpiece and a base. It is uitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector. 1 PC / Pack
Старый 26.03.2021, 04:53 Автор темы   52
3FVAPE
Original Innokin Endura T22 Pro 3000mAh Pod System Vape Mod Kit 2.0ml T18E Pro Tank $33.99
Original Innokin Endura T22 Pro Pod System Vape Mod Kit includes an Endura T22 Pro 3000mAh Pod System Mod and a 2.0ml T18E Pro Tank Atomizer. Endura T22 Pro Pod System Mod, a compact and lightweight mod, is powered by a 3000mAh built-in battery with USB-C 5V / 2A charging, providing four optional output wattages: 9.5W, 11W, 12.5W, 13.5W. T18E Pro Tank Atomizer holds 2.0ml capacity with top slide filling system. It is compatible with all T18E coils and M18 coils series (coils not included). With 510 threading connection, it is fit for most of your favorite mods. Six colors for your choice: Black, Blushed Silver, Steel Grey, Ruby Red, Royal Blue, Rose Gold
Original Uwell Valyrian SE Pod System Vape Starter Kit 1250mAh $39.99
Original Uwell Valyrian SE Pod System Vape Starter Kit consists of a Valyrian SE 1250mAh Pod System Mod and a 3.0ml Valyrian SE Pod Cartridge. Constructed from Aluminum Alloy, Valyrian SE Pod Mod features an airflow valve on the side of the pod, which can be adjusted as you want to pursue a smoother airflow or tighter draw. Valyrian SE Pod System Mod is powered by a 1250mAh internal battery charged via Micro USB to provide the maximum output power of 25W. Valyrian SE Pod Cartridge with 3.0ml capacity is designed with slide with top filling system. Made of PCTG, Valyrian SE Pod Cartridge is compatible with Pro-FOCS coil series (not included) and Valyrian pod coils (Valyrian pod coil 0.6ohm and Valyrian pod coil 1.0ohm (Pre-installed) are included), for a DTL or MTL vaping experience.
Старый 29.03.2021, 04:47 Автор темы   53
3FVAPE
SXK MOBB Mini Clone RBA Rebuildable Atomizer for Billet / BB / Supbox /Bantam Revision w/ 3.5mm Air Pin $25.9
SXK MOBB Mini RBA is pre-installed with 1 x 3.5mm Air Pin, suitable for Billet Box / SXK BB 70W / DNA 60W, SXK Supbox Pro 60W / SXK Supbox 70W and SXK Bantam Revision 30W Mod Kit. 2 colors: Silver / Gold
Original GeekVape Obelisk Sub Ohm Tank Clearomizer Vape Atomizer 5.5ml 25mm Original Price $28.9, Now Only $24.99.
Original GeekVape Obelisk Sub Ohm Tank Clearomizer holds 5.5ml capacity with childproof slide top filling system in 25mm diameter. GeekVape Obelisk Tank features slotted bottom airflow design and 810 drip tip. Obelisk Tank is compatible with GeekVape Z coil series, like Z1 Mesh 0.4ohm Coil (suggested wattage: 60~70W) and Z1 Mesh 0.2ohm Coil (70~80W) included in the package. With 510 threading connection, it is fit for most mods, especially for GeekVape Obelisk 120 FC Z Kit. Six colors: Black / Rainbow / Blue / Gold / Gun Metal / SS
SXK MOBB Mini Style RBA Replacement MTL Air Pin Set - 1.0mm / 1.2mm / 1.5mm / 1.8mm (4 PCS) $10.9
SXK BB MOBB MTL Air Pin Set is designed for SXK MOBB Mini Style RBA, including 1 x 1.0mm MTL Air Pin, 1 x 1.2mm MTL Air Pin, 1 x 1.5mm MTL Air Pin, 1 x 1.8mm MTL Air Pin. SXK MOBB Mini Clone RBA Replacement DL Air Pin Set is also available.
Kontrl Clone Front + Back Door Panel Plates w/ Black Button for dotMod dotAIO Vape Pod System $44.99
The Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a black button for easy operation. Mutiple optional colors for your choice.
Старый 30.03.2021, 05:02 Автор темы   54
3FVAPE
Original FreeMax Onnix 20W Pod System Vape Starter Kit 1100mAh Original Price $29.99, Now Only $22.99.
Original FreeMax Onnix 20W Pod System Vape Starter Kit supportes button activation and draw activation, consisting of an Onnix 20W 1100mAh Pod Mod and a 3.5ml Onnix Pod Cartridge. FreeMax Onnix 20W Pod System Mod is powered by a 1100mAh built-in battery with Type-C 1.5A fast charging to provide three level adjustable power output. Constructed from aluminum alloy, Onnix 20W Pod Mod adopts dual adjustable airflow system, meeting your MTL and RDL vaping needs. FreeMax Onnix Pod Cartridge holds 3.5ml capacity with side filling system. Onnix Pod Cartridge is compatible with Freemax OX coils, Freemax OX Mesh Coil 0.5ohm (Pre-installed) and Freemax OX DVC Coil 1.0ohm included in the package. OX Mesh Coil 0.5ohm with SS904L Mesh structure delivers outstandingly abundant clouds while OX DVC Coil 1.0ohm with dual vertical wire brings a strong throat hit and intense nicotine satisfaction. 6 colors for your choice.
ShenRay Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer w/ Airdisks 3.2ml 22mm $29.99
ShenRay Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. ShenRay Skyline R Clone RTA has double chamber and realtime accessibility on coil build deck, a good ideal RTA for your favorite Mods with 510 threading connection. Constructed from SS316, ShenRay Skyline-R / Skyline R Clone RTA comes with 2 x Airdisks, easier to interchange Airdisks without removing the build (plug & play) on the fly. In addition, it is also compatible with Airdisk-Skyline-R RDL Airdisks and MTL Airdisks (both not included), meeting RDL and MTL vaping demands.
Original FreeMax Onnix 20W Pod Kit / Pod Cartridge Replacement OX DVC Coil Head 1.0ohm $10.99
Original FreeMax OX DVC Coil Head with 1.0ohm resistance is designed for FreeMax Onnix 20W Pod System Vape Starter Kit and FreeMax Onnix 20W Pod Cartridge. It adopts dual vertical coil, bringing a strong throat hit and intense nicotine satisfaction. FreeMax OX Mesh Coil Head 0.5ohm is also available. 5 PCS / Pack
Original FreeMax Onnix 20W Pod Kit Replacement Pod Cartridge $5.99
Original FreeMax Onnix 20W Pod Cartridge holds 3.5ml capacity with side filling system, designed for FreeMax Onnix 20W Pod System Vape Starter Kit. Made of PCTG, Onnix 20W Pod Cartridge is compatible with OX series coils (Not Included) 2 PCS / Pack
ShenRay Skyline-R / Skyline R Clone RTA Replacement PEI Tank Tube 3.2ml $2.99
ShenRay Replacement PEI Tank Tube holds 3.2ml capacity, designed for ShenRay Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer. Replacement Glass Tank Tube is also available. 1 PC / Pack
ShenRay Skyline-R / Skyline R Clone RTA Replacement MTL Airdisks Set $4.99
ShenRay Replacement MTL Airdisks Set is designed for ShenRay Skyline-R / Skyline R Clone RTA Rebuildable Tank Vape Atomizer, including 1 x MTL Airdisk 0.8mm, 1 x MTL Airdisk 1.0mm, 1 x MTL Airdisk 1.5mm. ShenRay DL Airdisk is also available. 3 PCS / Pack
Старый 31.03.2021, 04:40 Автор темы   55
3FVAPE
Original Uwell Yearn Neat 2 Pod System Vape Starter Kit 520mAh 2.0ml $19.99
Original Uwell Yearn Neat 2 Pod System Vape Starter Kit is a draw activated pod kit, including a Yearn Neat 2 520mAh Pod Mod and a 2.0ml Pod Cartridge. Uwell Yearn Neat 2 Pod Mod is powered by a 520mAh built-in battery with Type-C charging, enough to fire up to 12W. Yearn Neat 2 Pod Mod features Uwell exclusive PRO-FOCS flavor testing technology, which enables it to control the heating temperature, manage the material quality and completely restore the e-juice flavor, delivering an amazing vaping experience. Uwell Yearn Neat 2 Pod Cartridge with 0.9ohm mesh coil holds 2.0ml capacity. With magnetized connection, it is easy for operation. 6 colors: Black / Red / Blue / Orange / Green / Grey
Original Advken Wanderlust Lite Pod System Vape Starter Kit 1000mAh 2.0ml Original Price $39.99, Now Only $26.99.
Original Advken Wanderlust Lite Pod System Vape Starter Kit consists of a Wanderlust Lite 1000mAh Pod Mod and a 2.0ml Pod Cartridge. Advken Wanderlust Lite Pod Mod is powered by a 1000mAh built-in battery. With no button, Wanderlust Lite Pod Mod offers fine puffs by indirect inhalation and meets your unique aspiration. Advken Wanderlust Lite Pod Cartridge with ceramic coil 1.4ohm holds 2.0ml capacity with bottom filling system.
Original Uwell Yearn Neat 2 Pod Kit Replacement Pod Cartridge w/ 0.9ohm Mesh Coil 2.0ml $5.99
Original Uwell Yearn Neat 2 Pod Cartridge with 0.9ohm mesh coil is especially designed for Uwell Yearn Neat 2 Pod System Vape Starter Kit with powerful magnetized connection. Made of PCTG, Yearn Neat 2 Pod Cartridge holds 2.0ml capacity. 2 PC / Pack
Original Advken Wanderlust Lite Pod Kit Replacement Pod Cartridge w/ 1.4ohm Ceramic Coil 2.0ml Original Price $13.99, Now Only $9.99.
Original Advken Wanderlust Lite Pod Cartridge with Ceramic Coil 1.4ohm is especially designed for Advken Wanderlust Lite Pod System Vape Starter Kit. It holds 2.0ml capacity with bottom filling system. 3 PCS / Pack
Original ETU Replacement Inner Door for dotMod dotAIO OG / SE Vape Pod System Original Price $10.9, Now Only $9.5.
Original ETU Replacement Inner Door is designed for for dotMod dotAIO OG / SE Vape Pod System. 1 PC / Pack
Старый 01.04.2021, 04:44 Автор темы   56
3FVAPE
Original Dazzvape Ukey Vaporizer Built-in Battery Vape Mod for 510 Thread Atomizer 400mAh $10.99
Original Dazzvape Ukey 400mAh Vaporizer Built-in Battery Vape Mod features 4 level of adjustable voltage: 2.8V / 3.2V / 3.6V / 4.0V, compatible with 0.5ml and 1.0ml capacity of atomizer with 510 threading connection. Constructed from zinc alloy and ABS, Ukey Vaporizer Battery Mod is the best choice of stylish CBD battery, supporting 10 seconds preheating function and smart memory function.
Original Dazzvape Apex Battery w/ USB Charger for eGo and 510 Thread Atomizer 350mAh $5.99
Original Dazzvape Apex Battery with a USB charger is compatible with all eGo and 510 threaded attachments, like 510 threaded Atomizers. With no-button controls design, Dazzvape Apex Battery Dazzvape Apex 350mAh Battery supports 3 level adjustable voltages: 2.7V / 3.4V / 4.0V. By simply screwing on your oil tank or atomizer, Apex Battery makes sure you can enjoy your favorite e-liquids and oil concentrates.
PVC Wrapper Skin Sticker for 18650 Battery (20 PCS) $2.59
The PVC Wrapper Skin Sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. 20 PCS / Pack
Старый 02.04.2021, 04:45 Автор темы   57
3FVAPE
Original Horizon Sakerz Sub Ohm Tank Clearomizer Vape Atomizer 5.0ml / 3.5ml 29.5mm Original Price $39.99, Now Only $27.99.
Original Horizon Sakerz Sub Ohm Tank Clearomizer Vape Atomizer holds 5.0ml / 3.5ml capacity with top filling system in 29.5mm diameter. Due to its top adjustable airflow design and top-to-bottom airflow, Horizon Sakerz Sub Ohm Tank has even better flavor than Falcon 2 and Falcon King Tank. Constructed from stainless steel, Horizon Sakerz Tank comes with two mesh coil heads with quick slide coil exchange design, 2in1 mesh coil 0.17ohm and mesh coil 0.16ohm, delivering a denser cloud and smoother flavor. 6 colors: Black / SS / Rainbow / Blue / Purplish Red / Gun Metal
Replacement Inner Door for dotMod dotAIO Pod (1 PC) $19.99
The Replacement Inner Door is made from Acrylic and is suitable for dotMod dotAIO Pod System Vape Kit. 1 PC / Pack
Original Horizon Sakerz Sub Ohm Tank Replacement Mesh Coil Head 0.17ohm $8.99
Original Horizon Sakerz Mesh Coil Head with 0.17ohm resistance is especially designed for Horizon Sakerz Sub Ohm Tank Clearomizer Vape Atomizer. Horizon Sakerz Mesh Coil 0.16ohm is also available. 3 PCS / Pack
Original Horizon Sakerz Sub Ohm Tank Replacement Glass Tank Tube 5.0ml $2.99
Original Horizon Sakerz Glass Tank Tube holds 5.0ml capacity, designed for Horizon Sakerz Sub Ohm Tank Clearomizer Vape Atomizer. 1 PC / Pack
Старый 05.04.2021, 04:56 Автор темы   58
3FVAPE
Original DEJAVU Pocket 40W VW Variable Wattage AIO Pod System Vape Starter Kit 950mAh Original Price $51.9, Now Only $41.9.
Original DEJAVU Pocket 40W VW AIO Pod System Vape Kit, a compact and portable All-in-One starter kit, is powered by a 950mAh built-in battery, enough to fire up to 40W (5~40W). Monitored by upgraded Ronin X RX40 chip, DJV DEJAVU AIO kit can intelligently adjust the best power and prevent the coil from burning cue to high wattage and has RBA mode for users to use coil with lower resistance. Constructed from aluminum alloy and PCTG, DJV Pocket AIO kit is compatible with RBA coil for (not included) and comes with DB OCC mesh coils: 0.6ohm DB OCC mesh coil and 1.0ohm DB OCC regular coil. DJV Pocket AIO Kit with 2.0ml capacity cartridge adopts side filling system with lateral triple air slots, easy for operation.
Original Demon Killer LTQ Vapor Curer Dry Herb 3-in-1 TC Vaporizer Vape Kit 1500mAh Original Price $119, Now Only $59.99.
Original Demon Killer LTQ Vapor Curer Dry Herb 3-in-1 TC Vaporizer Vape Kit, as a Dry Herb Vaporizer for dry herb, concentrate, flower and oil, is powered by a 1500mAh built-in battery. LTQ Vapor Curer Vaporizer supports two heating methods: temperature mode 140~600'F / 60~315'C and power mode. With power mode, LTQ Vapor Curer Vaporizer normally provides power output of 5~35W. However, when smoking oil, it will directly jump to its dedicated mode 10W (5~11W). In addition, it has a unique filter water tank, which not only produces cool and pure steam but also filters out impurities during the inhalation process. Demon Killer LTQ Vapor Curer Vaporizer comes with stainless steel, ceramic and quartz coils, delivering an amazing vaping experience.
Original DEJAVU Pocket AIO Kit Replacement DB OCC Regular Coil Head 1.0ohm (5 PCS) Original Price $14.9, Now Only $12.9.
Original DEJAVU Pocket DB OCC Regular Coil Head is with 1.0ohm resistance, especially designed for DEJAVU Pocket 40W VW AIO Pod System Vape Kit. DB OCC Mesh Coil Head 0.6ohm is also available. 5 PCS / Pack
Original DEJAVU Pocket AIO Kit Replacement RBA Coil Original Price $17.9, Now Only $15.9.
Original DEJAVU Pocket RBA Coil is especially designed for DJV DEJAVU Pocket 40W VW AIO Pod System Vape Kit, best for DIY lover. 1 PC / Pack
Original Demon Killer LTQ Vapor Curer Vaporizer Kit Replacement Oil Coil Head 1.4ohm (3 PCS) $10.99
Original Demon Killer LTQ Vapor Curer Replacement Oil Coil with 1.4ohm resistance is designed for Demon Killer LTQ Vapor Curer Dry Herb 3-in-1 TC Vaporizer Vape Kit. Demon Killer LTQ Vapor Curer Replacement Concentrate 0.65ohm / Dry Herb Coil 0.4ohm are also available. 3 PCS / Pack
Старый 06.04.2021, 04:35 Автор темы   59
3FVAPE
Original iSMOD II Plus Double Rods + 2600mAh Power Bank Heat Not Burn Vaporizer Vape Kit $74.99
Original iSMOD II Plus Heat Not Burn Vaporizer Vape Kit includes double 160mAh smoking rods and a 2600mAh big power bank with concealed magnetic design, supporting 20~28 sticks continuously when power bank is fully charged. The smoking rod at full battery charging status can support 14 puffs or 260s smoking time. Unlike traditional tobacco, iSMOD II Plus Kit is used with a cartridge and heats tobacco with a built-in ceramic heater with 15s preheating function, delivering a real-smooth taste without the presence of open flames, second-hand smoke, ash and tar. 3 colors: Red / White / Black
Original iSMOD Nano Heat Not Burn Vaporizer Vape Starter Kit 1500mAh $42.99
Original iSMOD Nano Heat Not Burn Vaporizer Vape Kit is powered by a 1500mAh built-in battery, supporting 20 sticks when fully charged with USB charging. iSMOD Nano Kit is designed with one button and LED indicator displaying battery level and temperature, allowing you to just click the switch button to enjoy the smoking. iSMOD Nano Kit has a cartridge ejection system which is easy to remove and clean. Featuring a 15s preheat duration function, iSMOD Nano Kit is compatible with many popular heat sticks (not included) to meet your own vaping demands. 4 colors: Green / Black / Gold / Red
Старый 07.04.2021, 04:44 Автор темы   60
3FVAPE
YFTK Skyline-R Skyline R Clone RTA Rebuildable Tank Atomizer w/ MTL Airdisks / PEI Tube 3.2ml 22mm $27.99
YFTK Skyline-R Skyline R Clone RTA Rebuildable Tank Vape Atomizer holds 3.2ml capacity with top filling system in 22mm diameter. YFTK Skyline-R Clone RTA has double chamber and realtime accessibility on coil build deck. YFTK Skyline-R RTA is compatible with Airdisk-Skyline-R RDL Airdisks and MTL Airdisks (both not included), easily switched between RDL and MTL. In addition, Constructed from SS316, YFTK Skyline R Clone RTA comes with 1 x spare PEI tube and 2 x MTL Airdisks: 1.2mm and 2.0mm, easier to interchange Airdisks without removing the build (plug & play) on the fly, a good ideal RTA for your favorite Mods with 510 threading connection.
Original Hitaste P6 Heat Not Burn Vaporizer Vape Starter Kit 2500mAh $52.99
Original Hitaste P6 Heat Not Burn Vaporizer Vape Starter Kit is powered by a 2500mAh built-in battery, providing smoking 35pcs tobacco sticks when fully charged with USB charging. Equipped with OLED screen, Hitaste P6 Heat Not Burn kit has 15s preheating function to reach adjustable temperature range 200~300'C within adjustable smoking time range 180~360s. In addition, Hitaste P6 heating kit features cylindrical structure, which makes ceramic heating rod stronger, avoids any accident and delivers an even heating and original taste, absolutely a great electronic vape pen kit for heating tobacco sticks.
YFTK Skyline R / Skyline-R RTA Replacement DL Airdisks Set 1.5 x 3mm / 1.5 x 3.9mm / 2 x 3.9mm $5.99
YFTK DL Airdisks Set includes 1 x Airdisk 1.5 x 3mm, 1 x Airdisk 1.5 x 3.9mm, 1 x Airdisk 2 x 3.9mm, designed for YFTK Skyline R / Skyline-R Clone RTA Rebuildable Tank Vape Atomizer. Made of SS316, it is a special custom designed and high precision machined part for the Skydeck, which regulates the airflow to your resistance and defines how tight or open is your draw.
YFTK Skyline R / Skyline-R Clone RTA Replacement MTL Airdisks Set 0.8mm / 1.0mm / 1.5mm $5.99
YFTK MTL Airdisks Set includes 1 x Airdisk 0.8mm, 1 x Airdisk 1.0mm, 1 x Airdisk 1.5mm, designed for YFTK Skyline R / Skyline-R Clone RTA Rebuildable Tank Vape Atomizer. Made of SS316, it is a special custom designed and high precision machined part for the Skydeck, which regulates the airflow to your resistance and defines how tight or open is your draw.
Время генерации страницы 0.32860 секунды с 15 запросами
