63745
210
181
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
5AVape Typhoon Taifun GT One RTA Clone Rebuildable Tank Atomizer Original Price $29.99, Now Only $24.99.
The 5AVape Typhoon Taifun GT One Clone RTA Rebuildable Tank Vape Atomizer Improved Version Full Kit is in 23mm diameter and holds 4.3ml capacity. The 5AVape Taifun GT One Clone RTA Vape Atomizer comes with 1.2mm air pin. ![]() Original Hippovape B'adapt Pro 100W SBS Box Mod - Red Brown Original Price $44.99, Now Only $39.99. The Original Hippovape B'adapt Pro 100W VW Vape SBS Side by side Box Mod is powered by single 21700 / 18650 / 20700 battery (not included) with type-C charging and can fire up to 100W output. The Hippovape B'adapt Pro 100W Mod is equipped with 0.96 inch LCD display screen to show vaping data clearly. And Hippovape B'adapt Pro supports Watt Mode / Volt mode / Temp mode / Bypass mode to meet different needs. ![]() Original Pioneer4you IPV U710 80W Box Mod Original Price $69.99, Now Only $54.99. Original Pioneer4you IPV U710 VW Vape Box Mod is constructed of zinc alloy, aluminum and plastic with ergonomic shape. IPV U710 Vape Box Mod is powered by single 18650 battery (not included) with max 80W output and 2A Type-C quick charging. IPV U710 features waterproof and powerful YiHi SX710 chipset with 3 preset flavor curves (soft, normal, Hard) and 3 freely adjustable EQ Flavor Curves (Curve Mode). And IPV U710 Mod is equipped with 0.96 inch TFT color screen to show vaping data and compatible with up to 24mm diameter tanks. ![]() Original Pioneer4you iPV V200 200W YiHi SX531 Box Mod Original Price $69.99, Now Only $54.99. Original Pioneer4You iPV V200 VW Vape Box Mod is made of zinc alloy, anodized aluminum, and ABS, which is strong and durable. Pioneer4You iPV V200 Mod uses dual 18650 batteries (not included) and the maximum output power is 200W. The iPV V200 Mod is powered by the waterproof YIHI SX531 chip. This makes the iPV V200 Mod not only has a fast-charging function but also has a certain waterproof effect, which provides protection for your safe use. Using the 0.96 inches TFT screen, you can clearly see the vaping data. Five flavor curves can be customized on the smart device side, namely Soft, Normal, Strong, custom SXi-EQ curves, EQ1-EQ3. ![]() 5AVape Taifun GT One Clone RTA Replacement Air Insert Pins - 0.8mm, 1.0mm, 1.5mm, 1.8mm Original Price $7.99, Now Only $4.99. The 5AVape Taifun GT One Clone RTA Replacement Air Insert Pins comes 4PCS / Pack, with size: 0.8mm, 1.0mm, 1.5mm, 1.8mm. ![]() DEV Whistle V3 Drip Tip + Button + Small Button Clone for dotMod dotAIO Pod Original Price $20.99, Now Only $14.99. The DEV Whistle V3 Clone Drip Tip + Button + Small Button Set is made from POM and is suitable for dotMod dotAIO Pod System.
182
Original FreeMax Marvos 80W Pod Mod Kit Original Price $54.99, Now Only $46.99.
Original FreeMax Marvos 80W Kit is the fourth kit following the Marvos series. It facilitates the use-friend and freely MTL vaping experience for its side airflow control, available for all the MS platforms, it escorts with the infinite air via the coil and works properly both distinguishing the kit to arise the stellar taste, making you indulge it. Paying attention to relatively zero-leakage experience, it utilizes an 810 drip tip, which prevents spit back. Additionally, Marvos is upgraded and innovated for increasing the pass-through air and vapor spontaneously. ![]() Original FreeMax Marvos RTA Pod Cartridge Original Price $24.99, Now Only $14.99. Original FreeMax Marvos RTA Pod cartridge acts as the FreeMax's first rebuildable pod cartridge, which fits all of Marvos series products. It comes with a 3.5ml vape juice capacity, you can fill your e-juice via the bottom insert. Pared with its two-side & top airflow control, you can personalize the airflow that you want, which can bring a delicate flavor and immerse the cloud, experiencing double pleasure. Designed for DTL vaping, it is equipped with a V-shaped groove 810 Drip Tip, replaceable and simple to remove.
183
Original GeekVape Wenax S-C Pod System Kit Original Price $29.9, Now Only $22.9.
Original GeekVape Wenax S-C Pod System Vape Kit is designed with stunning colors to become delicate and eye-catching. It is powered by built-in 1100mAh battery with Type-C fast charging. GeekVape Wenax S-C Kit features 3-level adjustable output, auto activation and firing button ignition. It has 2ml e-juice capacity and improved pod cartridge for better MTL vaping. It is also compatible with GeekVape G Series 0.6ohm Coil / 1.2ohm Mesh Coil to deliver you the smooth flavor. ![]() Lanyard with Kumiho Logo + 4 Silicon Rings Original Price $3.99, Now Only $2.59. The Lanyard with Kumiho Logo Come with 4 PCS Silicon Rings in 14mm / 16mm / 20mm / 40mm diameter. It is suitable for different size pod system / mechanical mod. 1 PC lanyard will be shipped in random color. Lanyard with Yumi Logo + 4 Silicon Rings Original Price $3.99, Now Only $2.59. The Lanyard with Yumi Logo Come with 4 PCS Silicon Rings in 14mm / 16mm / 20mm / 40mm diameter. It is suitable for different size pod system / mechanical mod. 1 PC lanyard will be shipped in random color. |
184
Original Hellvape Organic Cotton for RBA / RTA / RDA / RDTA Vape Atomizer - 17g Original Price $7.99, Now Only $4.99.
The original Hellvape Organic Cotton is a 100% natural, organic, Unbleached, pesticide free wicking material suitable for all RDA & RTA vape atomizer applications. Hellvape organic cotton has a superior absorption rate for rich dense and flavorful vapor, makes wicking easy and requires no 'break-in' time since it is tasteless and odorless, and if used correctly can last up to two times longer compared to other brands. ![]() Original Hellvape Shoelace Organic Cotton for RDA / RTA / RDTA Vape Atomizer - (40 PCS) Original Price $9.99, Now Only $6.99. The original Hellvape Shoelace Organic Cotton is a 100% natural, organic, Unbleached, pesticide free wicking material suitable for all RDA & RTA vape atomizer applications. Hellvape organic cotton has a superior absorption rate for rich dense and flavorful vapor, makes wicking easy and requires no 'break-in' time since it is tasteless and odorless, and if used correctly can last up to two times longer compared to other brands.
185
Original Voopoo Drag Nano 2 Pod System Stater Kit Original Price $33.99, Now Only $28.99.
Original Voopoo Drag Nano 2 Pod System Vape Starter Kit is designed with small but powerful body. It is powered by built-in 800mAh battery with 20W max output. There are smart match or 3 adjustable power modes for your option. The 3-color LED lights can clearly show you the output power and battery status. The seven protections can guarantee the safe use of the Kit. Drag Nano 2 Kit has 2ml e-juice capacity and visible pod cartridge. It also features top filling system, which is easy to refill and leak-resistant. The innovative infinite airflow system can better suit your preference and deliver you the most Original flavor. In addition, it adopts the super sensitive atomizer and powerful Gene chip to make super fast ignition. Drag Nano 2 Kit is compatible with VINCI Pod Cartridge. It also equipped with two Pods of 0.8ohm and 1.2ohm to bring you different but excellent vaping experience. ![]() Original Voopoo Drag Nano 2 Pod Replacement Pod Cartridge 0.8ohm Original Price $14.99, Now Only $7.99. The Original Voopoo Drag Nano 2 Pod System Replacement Pod Cartridge holds 2.0ml capacity and built-in 0.8ohm resistance coil. 3 PCS / Pack ![]() Original Voopoo Drag Nano 2 Pod Replacement Pod Cartridge 1.2ohm Original Price $14.99, Now Only $7.99. The Original Voopoo Drag Nano 2 Pod System Replacement Pod Cartridge holds 2.0ml capacity and built-in 1.2ohm resistance coil. 3 PCS / Pack
186
Original Dovpo Riva 200W TC VW Box Mod 2 x 18650 Original Price $69.99, Now Only $52.99.
The original Dovpo Riva 200 VW Vape Box Mod, made of Zinc Alloy & Leather, is powered by dual 18650 batteries (not included) with max 200W output. The 510 connector is made of stainless steel and is not in the center. Riva Mod has a hinged battery door at the bottom. The front of the mod is equipped with a set of the standard controls-a circular start button, 0.96 full-color TFT screen, three keys, and a Type-C port. Dovpo Riva 200 supports VW / Power, TC, VV modes for different needs. ![]() Original GeekVape Aegis B100 Boost Pro Max 100W Pod System Mod Kit Original Price $69.99, Now Only $49.99. The original GeekVape B100 Boost Pro Max 100W Pod System Vape Mod Kit is powered by 1 x 21700 battery (not included) supports wattage adjustable from 5W to 100W. The GeekVape B100 is with an upgraded Gen 2 three-inlet airflow control. Exceptionally durable body with IP67 water & dust resistance.
187
Original Cthulhu RBA AIO Box Single 18650 Mod Kit Original Price $98, Now Only $79.99.
The Original Cthulhu RBA AIO Box Mod Kit is powered by 1 x 18650 battery (not included) and supports VW from 1W to 60W. The Cthulhu RBA AIO Box Mod Kit is compatible with Billet Box Drip tip adapter and Boro Tanks. The Cthulhu RBA AIO Box Mod Kit comes with 6.0ml tank and air flow inserts: 0.8mm, 1.2mm, 1.6mm, 2mm. ![]() Original Vaporesso Target 200 Box Mod Dual 18650 Original Price $65.99, Now Only $46.99. The Vaporesso Target 200 Vape box Mod is powered by 2 x 18650 batteries (not included) and supports wattage adjustable from 5W to 220W. ![]() Original Vaporesso Target 100 Box Mod Single 18650 / 21700 Original Price $55.99, Now Only $40.99. The Vaporesso Target 100 Vape box Mod is powered by 1 x 18650 / 21700 battery (not included) and supports wattage adjustable from 5W to 100W. ![]() Original Vaporesso Target 80 Box Mod - 3000mAh, 5~80W Original Price $59.99, Now Only $43.99. The Vaporesso Target 80 Vape box Mod is built-in 3000mAh battery and supports wattage adjustable from 5W to 80W. ![]() SXK Typhoon Taifun GT One Clone RTA Rebuildable Tank Atomizer Original Price $27.9, Now Only $24.9. The SXK Typhoon Taifun GT One Clone RTA Rebuildable Tank Vape Atomizer is in 23mm diameter and holds 4.3ml capacity. The SXK Taifun GT One Clone RTA Vape Atomizer comes with 0.8mm,1.0mm,1.2mm, 1.5mm,1.8mm air pins. ![]() SXK Typhoon Taifun GT One Clone RTA Replacement Top Filling Kit Original Price $15.9, Now Only $13.9. The SXK Typhoon Taifun GT One Clone RTA Replacement Top Filling Kit is made from 316 Stainless Steel. ![]() SXK Typhoon Taifun GT One Clone RTA Replacement Short Tank Tube Kit Original Price $15.9, Now Only $13.9. The SXK Typhoon Taifun GT One Clone RTA Replacement Short Tank Tube Kit contains 2.0ml PCTG tank tube and 316 Stainless Steel chimney. ![]() Stabilized Wood SXK Replacement Front + Back Door Panel Plates for dotMod dotAIO Original Price $41.9, Now Only $37.9. The SXK Replacement Front and Back Door Panel Plates is made from Stabilized Wood and suitable for dotMod dotAIO Vape Pod System ![]() Original Asvape Arya 200W Box Mod - 2 x 18650 Original Price $69.99, Now Only $55.99. Original Asvape ARYA VW Vape box Mod is powered by dual 18650 batteries (not included) with a 1.2A USB Type C port for charging. Output wise this is rated as 5~200W and there are lots of user modes to choose from! You can have Variable Wattage, Variable Voltage, Smart Mode, Temperature Control, TCR, Custom Curve mode and Bypass. Can to meet different vaping needs. All of your vaping data is displayed on the stunning 0.96 in color screen which also has 6 different color themes. ![]() Original Vaporesso Target 200 Mod Kit with iTANK Original Price $75.99, Now Only $57.99. The Original Vaporesso Target 200 Mod Kit contains Target 200 VW Vape box mod and iTANK Atomizer. The Vaporesso Target 200 Vape box Mod is powered by 2 x 18650 batteries (not included) and supports wattage adjustable from 5W to 220W. The iTANK Atomizer holds 8ml capacity and with 0.2ohm / 0.4ohm mesh coil. ![]() Original Vaporesso Target 100 Mod Kit with iTANK Original Price $69.99, Now Only $50.99. The Original Vaporesso Target 100 Mod Kit contains Target 100 VW Vape box mod and iTANK Atomizer. The Vaporesso Target 100 Vape box Mod is powered by 1 x 18650 / 21700 battery (not included) and supports wattage adjustable from 5W to 100W. The iTANK Atomizer holds 5ml capacity and with 0.2ohm / 0.4ohm mesh coil. ![]() Original Vaporesso Target 80 Mod Kit with iTANK Original Price $69.99, Now Only $54.99. The Original Vaporesso Target 80 Mod Kit contains Target 80 VW Vape box mod and iTANK Atomizer. The Vaporesso Target 80 Vape box Mod is built-in 3000mAh battery and supports wattage adjustable from 5W to 80W. The iTANK Atomizer holds 5ml capacity and with 0.2ohm / 0.4ohm mesh coil. ![]() Original Vaporesso iTank Atomizer 5mL Original Price $29.99, Now Only $21.99. Original Vaporesso iTank 24.5mm Sub-Ohm Tank is one of best sub-ohm tank from Vaporesso, providing a threaded top-fill, dual bottom airflow ring, and the utilization of the GTi Coil (0.2ohm and 0.4ohm). Formed from durable stainless steel, the ITANK has Pyrex glass reinforcement to prevent breaking during light and moderate falls. The Vaporesso GTi Coil System utilizes the combination of cotton and flax materials for a long-lasting yet flavorful performance with the following coil options: 0.2ohm Meshed (60~75W), 0.4ohm MESH (50~60W). At the top of the Vaporesso iTANK Sub-Ohm Tank is a threaded top fill system, designed for fast and easy refills by removing the top cap to reveal a generously fill port, so it allows the tank to hold up to 5ML (Straight Tube) of juice within the Pyrex glass. ![]() Original Vaporesso iTank Atomizer 8ml Original Price $30.99, Now Only $23.99. Original Vaporesso iTank 24.5mm Sub-Ohm Tank is one of best sub-ohm tank from Vaporesso, providing a threaded top-fill, dual bottom airflow ring, and the utilization of the GTi Coil (0.2ohm and 0.4ohm). Formed from durable stainless steel, the ITANK has Pyrex glass reinforcement to prevent breaking during light and moderate falls. The Vaporesso GTi Coil System utilizes the combination of cotton and flax materials for a long-lasting yet flavorful performance with the following coil options: 0.2ohm Meshed (60~75W), 0.4ohm MESH (50~60W). At the top of the Vaporesso iTANK Sub-Ohm Tank is a threaded top fill system, designed for fast and easy refills by removing the top cap to reveal a generously fill port, so it allows the tank to hold up to 8mL (Bubble Glass Tube) of juice within the Pyrex glass. ![]() Original Vaporesso iTank Replacement GTi Mesh Coil - 0.4ohm (50~60W) Original Price $14.99, Now Only $11.99. This GTi Replacement Coil is perfectly compatible with Vaporesso iTank vape Atomizer. ![]() Original Vaporesso iTank Replacement GTi Mesh Coil - 0.2ohm (60~75W) Original Price $14.99, Now Only $11.99. This GTi Replacement Coil is perfectly compatible with Vaporesso iTank vape Atomizer.
188
Original SMOKTech SMOK R-KISS 2 200W Box Mod Kit with TFV18 Mini Tank Original Price $74.99, Now Only $59.99.
Original SMOKTech SMOK R-KISS 2 VW Vape Box Mod Kit has elevated your quality of vaping to an absolutely new level to facilitate your daily use. It can capture your infinite airflow, accessing the 3 large slots, airflow is tripled and increases the admission velocity, which advances the awesome taste that inhales directly alongside the generous amount of cloud. Comes with a 6.5ml vape juice capacity, this large capacity reduces the hassle of refilling and has a long-lasting vape once filling. Pressing the button and turning the top cap are two necessary steps to fill your e-juice into the tank, which ensure sanitation and leakage proof. Add the conductive copper for its 5 braces on the base, which can ramp up time and realize the possibility of circle heating, increasing the heating efficiency and power transmission. Require the V18 mini mesh coil of 0.2ohm, this coil has a high-quality heating speed and cotton contact for discreet and less harsh vaping. ![]() Original Lost Vape Ursa Nano Pod System Vape Kit Original Price $29.99, Now Only $23.99. Original Lost Vape Ursa Nano Pod System Vape Kit is decorated with a change color relying on the light and angle you can see, such as geometric, gridded and streamlined patterns covered at front and back, sitting comfortable and ultra-portable. With looks and technology, it promotes itself by the goal of flavors and cloud that coupled with the adjustable airflow control button, allowing you to personalize your MTL style that you can. As mentioned, Ursa Nano provides a 2.5ml vape juice capacity and matches most of the nic-salts to purse the good throat hit for the veterans. According to consistently and countless tests, the ergonomic and sleek drip tip is a closed unit with the structure of stemming your e-liquid and has a clean hand. To offer minimal fuss and a maximum flavor, it is equipped with two resistant coils for blowing humongous vapor and exciting sweetness. ![]() Original Lost Vape Ursa Nano Replacement Pod Cartridge - 2.5ml, 1.0ohm Original Price $14.99, Now Only $9.99. Original Lost Vape Ursa Nano Pod Cartridge acts as the most suitable pod cartridge for the Lost Vape Ursa Nano Pod System Vape kit, you could not suppress the nicotine caving with its 2.5ml for it's vape juice, can capture the purest and gratifying flavor for you, and is built-in the all-in-one URSA NANO pod cartridge, which contacts the e-liquid efficiently and produces ideal vapor. It is made of clear material and can easily refill via the side filling slot. ![]() Original Lost Vape Ursa Nano Replacement Pod Cartridge - 2.5ml, 0.8ohm Original Price $14.99, Now Only $9.99. Original Lost Vape Ursa Nano Pod Cartridge acts as the most suitable pod cartridge for the Lost Vape Ursa Nano Pod System Vape kit, you could not suppress the nicotine caving with its 2.5ml for it's vape juice, can capture the purest and gratifying flavor for you, and is built-in the all-in-one URSA NANO pod cartridge, which contacts the e-liquid efficiently and produces ideal vapor. It is made of clear material and can easily refill via the side filling slot
189
Original Timesvape Heavy Hitter Mechanical Mod - 1 x 20700 / 21700 Original Price $70, Now Only $65.99.
The Timesvape Heavy Hitter Mechanical mod is a made-in-heaven collaboration, designed by Heavy Metal Vapor and TenaciousTXVapes and made by Timesvape, features a gold-plated copper contact and floating battery setting. The Heavy Hitter Mod is a sure win for Mech heads. Three great minds have joined forces to create what could arguably be the toughest affordable mech mod on the market today. ![]() Original OXVA Vativ 100W Full Mod Kit with Unione PnM Tank Atomizer Original Price $85, Now Only $75.99. The Original OXVA Vativ super mod breaks the boundaries of mod technologies, The Kit included OXVA Vativ mod, Unione PnM Tank & Vativ Pod. OXVA Vativ mod is the first slide pod mod all over the world, lossless switching between pod mod and 510 mod by the unique slideway design. Vativ mod features Buck-boost chipset with super fast fire (<0.002s) and advanced VPC mode (set the percentage increasement or decreasement of each 0.5s within the first 2.5s). OXVA Vativ Super Mod is powered by single 18650 battery with real 100W output. OXVA Unione PnM Tank has 4ml/5ml Pyrex Glass tube for purer flavor and is compatible with Uniplus coils. Unione PnM Tank adopts magnetic connection to change coils in seconds and bottom adjustable airflow system for top flavor. ![]() Original OXVA Unione PnM Tank Replacement Bubble Glass Tank Tube 5ml Original Price $5.99, Now Only $3.99. Original OXVA Unione PnM Tank Replacement Glass Tube is designed for Unione PnM Tank. It features 5ml capacity. ![]() Original OXVA Unione PnM Tank Replacement Straight Glass Tank Tube 4ml Original Price $4.99, Now Only $2.99. Original OXVA Unione PnM Tank Replacement Glass Tube is designed for Unione PnM Tank. It features 4ml capacity. ![]() Original OXVA Uniplus Replacement Coil Original Price $19.99, Now Only $14.99. Original OXVA UniPlus Coil is specially designed for OXVA Unione PnM Standard Tank and OXVA VATIV Full Kit Standard Version. The mesh coil provides Super pure flavor.
190
Original Hellvape Dead Rabbit 3 RDA - Dual Coil, with BF Pin, 24mm Diameter Original Price $30.99, Now Only $25.99.
Original Hellvape Dead Rabbit 3 RDA Vape Atomizer offers flexible and adjustable round posts for coil cutting. Upgraded quickly and easily, this design has ample space for your coil, which takes into account that your coil has a larger surface area to contact your e-liquid fully and warms it efficiently. This optimized deck allows your air to smoother for the fluffy clouds. It leads the light in two types of airflow, which results in a different experience for your air chase and comes with a delicate flavor. Considered more satisfying, it is refilled by a side filling system and is designed for quick vape juice transferring. Connect with a gold-plated 510 pin, it is uneasy to slip and firm for your kit. ![]() Original SMOKTech SMOK R-KISS 2 200W Box Mod - 2 x 18650 Original Price $74.99, Now Only $49.99. Original SMOKTech SMOK R-KISS 2 VW Vape Box Mod has the most impressive IQ-S chip, which is reliable for power transmission and security. It is easy to get your hand around it once you are looking for the ideal mod for its 1.3 inch TFT color screen, it has plenty of theme color, whichever you choose is complementary down to your preference and mood. R-KISS 2 is available for the range of 5W~200W output to adjust and personalize your vaping experience, powered by a dual 18650 batteries (not included), it provides you an enduring satisfaction and is ideal for simple carrying and replacement, which is why it is the most popular with vapers who want to for its convenience and performance. The lateral fire key adapts the kit seamlessly and has a roomy operation area, rapid reaction, which results in the ultimate sensation when you vape. ![]() Original ThunderHead Creations THC Tauren MAX RDA w/ BF Pin Glass Version Original Price $38.5, Now Only $25.99. Original ThunderHead Creations THC Tauren MAX RDA Rebuildable Dripping Vape Atomizer with glass top cap (shell), an upgraded postless dual coil RDA in 27mm diameter. THC Tauren MAX RDA adopts innovative 3D honeycomb airflow system, 26 pieces airholes from triple sides to be as cloud chaser for an excellent flavor and strong throat hit. ThunderHead Creations Tauren MAX RDA features innovative ceramic build deck, creative dual ceramic clamp system, absolutely a great RDA for your favorite mods with 510 threading connection, like Tauren Mech and Tauren Max Mech mod. Comes with BF Pin. ![]() Original ThunderHead Creations THC Tauren Max RDA Replacement Glass Shell Top Cap Original Price $9.99, Now Only $5.99. Those Max RDA Atomizer Glass Shell top cap is perfectly compatible with ThunderHead Creations THC Tauren Max RDA Vape Atomizer.
191
Typhoon Taifun GT One RTA Clone Rebuildable Tank Vape Atomizer - Black Original Price $29.99, Now Only $22.99.
The Typhoon Taifun GT One Style RTA Rebuildable Tank Vape Atomizer is in 23mm diameter and holds 4.3ml capacity. The Taifun GT One Style RTA Vape Atomizer comes with 4 PCS Air Inserts: 0.8mm, 1.0mm, 1.5mm, 1.8mm. ![]() Replacement Front + Back Cover Panel Plate for BB Bilet Box Original Price $34.99, Now Only $24.99. The Replacement Cover Panel is made from acrylic, and is designed for Billet Box mod Kit / SXK BB Style 70W / DNA60W Box Mod Vape kit. This cover panel comes with 2 pieces (front and back).
192
Original Rincoe Jellybox Nano Pod Kit - Blue Clear Original Price $59.99, Now Only $25.99.
The Original Rincoe Jellybox Nano Pod System Vape Mod Kit maintains a compact design, constructed with a zinc alloy body and satin material finish and a PCTG tank section for durable construction. It has a range of coil options between 0.3ohm and 3.0ohm, and has two types of coils to choose from: Mesh 1.0ohm Coil and Mesh 0.5 Ohm Coil. Powered by 1000mAh Built-in Battery, and you can expect a full day of vaping pleasure when using a Type-C USB port, which allows 5V / 1A Type C charging specification. Rincoe Jellybox Nano Pod cartridge holds up to 2.8ml of E-liquid, you can refill all sorts of different juices you want, satisfying both nic salt e-liquid and freebase e-liquid. ![]() Original Ambition Mods 2.0 510 Adapter Connector for BB 60W / 70W / Billet Box Mod Original Price $14.99, Now Only $10.99. The Original Ambition Mods 2.0 510 Adaptor Connector is made from 304 stainless steel with golden plated center pin. It is suitable for SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit. With this 510 adapter, you can use your 510 RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer on your SXK BB DNA 60W / 70W / Billet Box Mod Vape Kit. ![]() Original Ambition Mods Boro Tank for Billet / SXK BB Box Mod Kit Original Price $12.99, Now Only $8.99. The Original Ambition Mods Boro Tank is suitable for Billet / SXK BB Box Mod Kit.
193
Original ThunderHead Creations THC MTL RTA Pro Rebuildable Tank Atomizer Original Price $46.9, Now Only $31.99.
Original ThunderHead Creations THC MTL RTA Pro is made from stainless steel and glass in 22mm Diameter. It features the Tauren unique 360 degree stepless airflow with markable control system as well as micro honeycomb airflow underneath the coil to offer you extremely great flavor. Super easy for single coil building and wicking benefit from the simple two post building deck design. ![]() Original ThunderHead Creations THC MTL RTA Lite Rebuildable Tank Atomizer Original Price $36.9, Now Only $26.99. Original ThunderHead Creations THC MTL RTA Lite is made from stainless steel and glass in 22mm Diameter. It features the Tauren unique 360 degree stepless airflow with markable control system as well as micro honeycomb airflow underneath the coil to offer you extremely great flavor. Super easy for single coil building and wicking benefit from the simple two post building deck design.
194
Original Dovpo MVV M VV II 280W VV Variable Voltage Box Mod Original Price $39.99, Now Only $32.99.
Original Dovpo M VV II Box Mod is made of PC + Zinc Alloy, and powered by dual 18650 batteries (Not Included) ,It features 1.0V to 8.0V voltage range, maximum 280W power wattage, and it has new aesthetic colorful look and a built-in USB Type-C port inside the box, battery reversal protection, a LED indicator that can show the life span of the battery. The thread type is 510 thread. ![]() Original ThunderHead Creations THC Tauren Beast Tool Kit Original Price $24.99, Now Only $18.99. The Original Thunderhead Creations THC Tauren Beast tool kit by is a super compact kit with all of the tools needed for your coil building needs. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Shoelaces Cotton Original Price $8.99, Now Only $6.99. The Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Shoelaces Cotton Single Baby Head is in 75mm length and comes with 25 PCS / Pack. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Fused Clapton Coil Original Price $6.99, Now Only $4.99. Original ThunderHead Creations THC Fused Clapton Coil is made from 30GA x 2 + 38GA wire with 0.6ohm resistance, suitable for RTA / RDTA / RDA Vape Atomizer. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Ni80 2-Core Baby Alien Coil Original Price $7.99, Now Only $5.99. The Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Diagonal Ni80 2-Core Baby Alien Coil 28GA comes with 2 PCS / Pack. 0. 3 x 2 + 0.1 x 2.5, 0.4ohm ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Ni80 2-Core Baby Alien Coil Original Price $7.99, Now Only $5.99. The Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Parallel Ni80 2-Core Baby Alien Coil 28GA comes with 2 PCS / Pack. 0. 3 x 2 + 0.1 x 2.5, 0.4ohm ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Long 510 Drip Tip Original Price $6.99, Now Only $4.99. The Original ThunderHead Creations Replacement long 510 Drip Tip is suitable for THC Tauren Elite MTL RTA vape atomizer. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Short 510 Drip Tip Original Price $3.99, Now Only $2.59. The Original ThunderHead Creations Replacement Short 510 Drip Tip is suitable for THC Tauren Elite MTL RTA vape atomizer. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Armor with PC Shell Original Price $7.99, Now Only $5.99. Original ThunderHead Creations THC Tauren Elite MTL RTA Pro / Lite Replacement Armor with PC Shell is made from stainless steel and PC. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Bubble Glass Tube - 4.0ml Original Price $3.99, Now Only $2.99. The Original ThunderHead Creations TCH Tauren Elite MTL RTA Pro / Lite Replacement bubble glass tank tube holds 4.0ml capacity. 1 PC / Pack. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Replacement Straight Glass Tube - 2.0ml Original Price $2.99, Now Only $1.99. The Original ThunderHead Creations TCH Tauren Elite MTL RTA Pro / Lite Replacement straight glass tank tube holds 2.0ml capacity. 1 PC / Pack. ![]() Original ThunderHead Creations THC Tauren Elite MTL RTA Multiple Airflow Inserts Set - 0.8/1.0/1.2/1.5/1.8/2.0/7 x 1.0mm (7PCS) Original Price $6.99, Now Only $4.99. The Original ThunderHead Creations TCH Tauren Elite MTL RTA Pro / Lite Replacement Multiple Airflow Inserts Set comes with 7 PCS: 0.8mm / 1.0mm / 1.2mm / 1.5mm / 1.8mm / 2.0mm / 7 x 1.0mm. ![]() Replacement Short Tank Kit for Taifun GTR Style RTA Vape Atomizer Original Price $7.99, Now Only $5.99. The Replacement Short Tank Kit is made from stainless teel and glass and suitable for Taifun GTR Style RTA Vape Atomizer. The short tank kit holds 2.0ml capacity and with top refilling system. ![]() Original Original Cthulhu Tube Mod II 2 V2 Mod Replacement MOSFET Chip Original Price $10.99, Now Only $8.99. The replacement chip is suitable for Original Cthulhu Tube Mod II 2 V2 Mod. ![]() Original Horizon Sakerz Sub Ohm Tank Replacement Coil Head Original Price $10.99, Now Only $8.99. Original Horizon Sakerz Coil Head with 0.4ohm resistance is especially designed for Horizon Sakerz Sub Ohm Tank Clearomizer Vape Atomizer. 3 PCS / Pack
195
Monarchy Replacement Drip Tip Clone for SXK BB / Billet Box Mod Kit Original Price $9.99, Now Only $6.99.
The Monarchy Replacement Drip Tip Clone is made from stainless steel and is suitable for SXK BB 70W / 60W / Billet Box Mod Kit. ![]() Original MK Mods Replacement Drip Tip + Button for SXK BB / Billet Box Mod Kit Original Price $59.99, Now Only $45.99. The Original MK Mods Replacement Drip Tip and Button set is made from Titanium and is suitable for SXK BB 70W / 60W / Billet Box Mod Kit.
196
197
Original Ambition Mods Molen Bridge RBA for SXK BB / Billet Box / 2.0 AIO Mod Original Price $35.99, Now Only $27.99.
The original Ambition Mods Molen Bridge RBA is Suitable for SXK BB / Billet Box / 2.0 AIO Mod. It will convert your Boro Tank from Ambition Mods for RBA use. The Molen Bridge RBA comes 1 x Air Pin 1.2mm (pre-installed) / 1 x Air Pin 2.0mm / 1 x Air Pin 3.0mm. ![]() ULTON Typhoon Taifun GT One Clone RTA Improved Version Full Kit Rebuildable Tank Vape Atomizer Original Price $39.99, Now Only $34.99. The ULTON Typhoon Taifun GT One Clone RTA Rebuildable Tank Vape Atomizer Improved Version Full Kit is in 23mm diameter and holds 4.3ml capacity. The Taifun GT One Clone RTA Vape Atomizer comes with 4 PCS Air Inserts: 0.8mm, 1.0mm, 1.5mm, 1.8mm ![]() ULTON Taifun GT One RTA Clone Replacement Air Insert Pins - 0.8mm, 1.0mm, 1.5mm, 1.8mm Original Price $6.99, Now Only $5.49. The ULTON Taifun GT One Clone RTA Replacement Air Insert Pins comes 4PCS / Pack, with size: 0.8mm, 1.0mm, 1.5mm, 1.8mm. ![]() ULTON Taifun GT One RTA Clone Replacement PCTG Tank Tube Original Price $5.99, Now Only $3.99. The ULTON Taifun GT One Clone RTA Replacement Tank Tube is made from PCTG and holds 4.3ml capacity.
198
Original KSL Vapor Hibou MTL Tank Vape Atomizer 22mm Diameter Original Price $29.99, Now Only $24.99.
The KSL Vapor HIBOU is a MTL vaping tank atomizer. Vaping in MTL means to first take a puff of vape in your mouth, before inhaling, similar to a traditional cigarette. Because we can count a considerable number of e-liquids on the market, the HIBOU is supplied with 2 coils of different values adapted to the liquid of your choice. The 0.6ohm coil is suitable for vaping e-liquids with a nicotine level ranging from 0mg to 12mg and a wattage set between 15W and 23W. The coil 1.2ohm is suitable for vaping e-liquids with a high nicotine level often ranging from 20W to 40mg/ml (also known as nicotine salts) with a wattage set between 7W and 11W. An RBA is also provided for vapers wishing to build their own coil and therefore enjoy a vape tailored to their liking. The HIBOU can be plugged onto any box that allows you to set the wattage manually. ![]() Original KSL Vapor Hibou Replacement Coil - 0.6ohm Original Price $14.99, Now Only $9.99. The Original KSL Vapor Hibou Replacement Coils 0.6ohm is perfectly compatible with KSL Vapor Hibou MTL Tank vape atomizer. ![]() Original KSL Vapor Hibou Replacement Coil - 1.2ohm Original Price $14.99, Now Only $9.99. The Original KSL Vapor Hibou Replacement Coils 1.2ohm is perfectly compatible with KSL Vapor Hibou MTL Tank vape atomizer. ![]() Original Yachtvape Prebuilt Coil Framed Staple - 2-28/4-.1 x 3/36, Ni80, 0.3ohm (10 PCS) Original Price $7.99, Now Only $5.99. The Framed Staple coils made by Yachtvape that come with the Eclipse DTL RTA Tank, ideal for the Eclipse, but also for any DTL RTA.Weighing in at 0.3Ohms per coil - this pack contains 10 Coils.Made from Ni80 with dimensions: -2-28/41.1 x 3/36 and an internal diameter of 3mm.These coils (as anyone who tried one with their Yachtvape Eclipse DTL RTA will know) have absolutely excellent flavor and vape production, yet cost a lot less than similar style coils on the market.
199
Original Aspire SkyStar 210W TC VW Box Mod Original Price $55, Now Only $25.99.
The Aspire SkyStar is a dual 18650 battery 210 watt mod with a 1.3 inch touch screen with every function you have come to expect from Aspire. Wattage / Voltage / BYPASS / TC (Ni, Ti, SS, M1, M2, M3) and CPS (Customizable Power Settings). Its sensuous curves make it very ergonomic in the hand and easy to operate all the functions with just one hand, and an absolute joy to hold. ![]() Vapeasy Luca creation 4C Tank MTL RTA Clone Rebuildable Vape Atomizer Original Price $39.99, Now Only $29.99. The Vapeasy Luca creation 4C Tank Clone MTL RTA Rebuildable Vape Atomizer is made from 316 stainless steel in 22mm diameter and PEI tank tube holds 3ml capacity. The 4C Tank Clone MTL RTA is with bottom airflow (1mm / 1,2mm / 1,7mm). ![]() Scalpel MTL RTA Clone Rebuildable Tank Atomizer Original Price $29.99, Now Only $25.99. The Scalpel Clone MTL RTA Rebuildable Tank Vape Atomizer is made from 316 stainless steel in 22mm diameter and PEI tube holds 3.3ml capacity. The RTA is with 6 different sizes of airflow on top cap. ![]() Original Hippovape Halo Stick Pod System Kit Original Price $19.99, Now Only $14.99. Original Hippovape Halo Stick Pod System Vape Kit is powered by built-in 850mAh battery with USB Type-C charging port. It is equipped with 0.9ohm mesh/regular Coil to bring you different vaping satisfaction. The 0.9ohm mesh Coil for freebase e-liquid can be refilled at least 7 times while the 0.9ohm regular Coil for nic salt e-liquid can be refilled at least 3 times without losing flavor. Halo Stick Pod Kit features 2.5ml e-juice capacity and adjustable airflow control system. It has visible and transparent juice level to avoid dry hit effectively.
200
Original BP Mods Pioneer DotRBA MTL / RDL RBA Tank for DotMod dotAIO Mod Original Price $59.99, Now Only $44.99.
The Original BP Mods Pioneer DotRBA MTL / RDL RBA Tank is suitable for DotMod dotAIO Mod. The Pioneer DotRBA MTL / RDL RBA is for single coil building and comes with 6 airflow pins 0.8 / 1.0 / 1.2 / 1.5 / 2.0 / 2.5 / 3.0mm for MTL / RDL vaping.
