11983
![]() Регистрация: 30.08.2011 Последняя активность: 22.10.2011 05:19
180 Lumens’ Output, Elegant Lighting Tool
--CREE R5-- ![]() SUNWAYMAN R20A is one practical compact flashlight model designed with elegant exterior, graceful lines and great hand-feel, as well as the considerate grip-ring for anti-rolling and easy grip. Fitted with CREE R5 LED, max output up to 180 lumens, this light maintains both high output and long runtime. Equipped with superior circuit, when the light is turned on, slightly depress the tail cap switch for 4 cycled output modes including one police strobe mode, plus a memory function. Elegant design, stable structure, superior circuit, and practical functions - the R20A is an ideal lighting tool for home use, outdoor activities, and work etc. ![]() ![]() Elegant Design, Graceful Lines R20A is designed with elegant exterior, graceful lines and great hand-feel. Stainless steel retaining ring on the top protects the light from drops and impacts; Grip-ring elaborately made for anti-rolling and easy grip. ![]() ![]() Four Practical Output Modes R20A is equipped with high efficiency, superior circuit. When the light is turned on, slightly depress the tail cap switch for 4 cycled output modes including one police strobe mode for emergency use. ![]() Considerate Memory Function Utilizes memory function, the R20A will memorize the last mode of the light before you turn it off, when you turn on the light again, the mode will be the most recent one used. ![]() CREE R5 LED, Output up to 180 Lumens Fitted with CREE R5 LED, max output reaches 180 lumens, extended runtime of up to 2 hours when using good quality rechargeable battery; this light maintains both high output and long runtime. Features ● CREE R5 LED, with a lifetime of up to 50,000 hours; ● Three levels of constant output, one police strobe mode (below is the output and runtime of using two 2600mAH Ni-MH batteries) Three levels of constant output: 180 Lumens (2hrs)- 37 Lumens (50 hrs)- 4 Lumens (200 hrs) Police Strobe mode: 180 Lumens ● Reverse Tail Cap Switch, fully depress the switch to turn on the light, and depress it halfway for different outputs ● Constant current circuit, constant output ● Memory Function, automatically memorize the most recent used mode before turning off the light ● Uses two 1.5V AA (Alkaline, Ni-MH, Lithium) batteries ● Electronic reverse battery protection, no need to worry about battery reversal, effectively protect flashlight ● High quality reflector maintains great throw distance and spread with an ideal beam pattern ● Dimension: 147mm (length) x 24mm (head diameter) ● Weight: 57g(battery excluded) ● Aerospace-grade aluminum alloy ● Military Specification Type III- hard anodized body ● Waterproof, in accordance with IPX-8 standard ● Ultra-clear tempered glass lens resists scratches and impacts ● Included Accessories: O-ring, rubber cap, lanyard, holster Remarks: Product specifications are subject to change without prior notice; Please always refer to our home page for most updated specifications.
Sunwayman Team SUNWAYMAN / SUNWAYFOTO www.sunwayman.com www.sunwayfoto.com We Care.... Customer First!! |
Администратор
Сказал(а) спасибо: 4330
Спасибо за информацию!
Регистрация: 10.06.2010 Последняя активность: 04.11.2025 21:38
Записей в дневнике: 1 Сказал(а) спасибо: 59
I bought a flashlight, but it lacks the memory modes, and the average of the bright little different light, and always included a minimum, which at first glance, a lot more than 5 fluorescent, it is substandard?
I use Duracell batteries
Электроника - наука о контактах! |
