19608
![]() Регистрация: 30.08.2011 Последняя активность: 22.10.2011 05:19
728 Lumens Rechargeable Fully Variable Magnetic Control Flashlight
--CREE XM_L T6-- ![]() ![]() ![]() V60C, the first rechargeable model manufactured by SUNWAYMAN, utilizes brand-new soft contact charging system, reliable charging base, simply plug & charge, very easy and convenient. This light possesses the innovative multi-functional fully variable magnetic control ring, which utilizes a brand-new structure. The technology used in the new magnetic control ring surpasses even the traditional fully variable circuit. The V60C perfectly integrates the super-low standby current, wide range of output (5 to 728 lumens), and Strobe mode together, while providing a great hand-feel and easy to use interface, plus the ergonomically designed charging system, this moderate size high-end flashlight is an ideal lighting tool for outdoor activities, industrial and mining enterprises, police and law enforcement personnel. ![]() Patented Charging System V60C utilizes brand-new soft contact charging system, exquisitely designed charging base with stable structure, simply plug & charge, very easy and convenient. ![]() Fully Variable Magnetic Control System Since SUNWAYMAN entered the market, its innovative and humanized magnetic control user interface has become the brand’s symbol. This time, with persistent effort, the V60C succeeds to bring the fully variable magnetic control technique to another level, it perfectly integrates the super-low standby current, 5 to 728 lumens ranged output and strobe mode in one light, great hand-feel and easy to use. ![]() ![]() CREE T6 LED, Output Up to 728 Lumens Fitted with CREE XM-L T6 high power LED, the V60C generates up to 728 lumens’ output, combined with the fully variable technique and high-efficiency optical system, this light is ideal for different lighting circumstances. ![]() ![]() Creative Power Supply System V60C’s creative power supply system will bring brand-new experience to you! Newly designed battery carrier, load batteries correctly, you can insert the battery carrier in the flashlight with either end, no need to worry about reverse battery; Broad-voltage design, compatible with 3x18650 or 6xCR123A batteries (when using 16340, the light CANNOT be charged by the flashlight charging base). Features ● CREE XM-L T6 LED, with a lifetime of 50,000 hours; ● Digital Sensor Magnetic Control system - slightly twist the Rotator Ring from left to right to select your desired mode ranging from 5 to 728 lumens, super-low standby mode, or a strobe function;Hidden SOS Mode: when the light is at Strobe mode, twist the rotator ring to the Max output and back to the strobe within 2 seconds, the SOS mode is activated; twist the ring away from the SOS mode and stay for more than 2 seconds, the Strobe Mode is resumed and SOS is hidden. Max Output: 728 Lumens (2hrs) Min Output: 5 Lumen (150hrs) Strobe: 728 Lumens SOS ● Constant current circuit, constant output ● Effective range of 395 meters ● Uses 3 x 18650 batteries (V60C charging base can be applied to charge the batteries); or 6 x CR123A primary batteries; or 6 x 16340 rechargeable batteries, but V60C charging base must NOT be applied to the 16340! ● Working voltage: 5.5~25.2V ● High quality reflector maintains great throw distance and spread with an ideal beam pattern ● Dimension: 165mm (length) x 57mm (head diameter) x 45mm (body diameter) ● Weight: 354.6g(battery excluded) ● Aerospace-grade aluminum alloy ● Military Specification Type III- hard anodized body ● Waterproof, in accordance with IPX-8 standard ● Ultra-clear tempered glass lens resists scratches and impacts ● Tail stand capable- can be used as a candle ● Included Accessories: lanyard, O-ring, holster Remarks: Product specifications are subject to change without prior notice; Please always refer to our home page for most updated specifications.
Sunwayman Team SUNWAYMAN / SUNWAYFOTO www.sunwayman.com www.sunwayfoto.com We Care.... Customer First!! [Исправлено: serj_32, 30.08.2011 в 13:42] Причина: поправил картинки |
| Поблагодарили: 3 раз(а) |
Интересный фонарик для автолюбителей. Как раз того плана на днях друг искал
Регистрация: 07.07.2010 Последняя активность: 09.06.2020 10:48
Сказал(а) спасибо: 59
Поблагодарили: 220 раз(а) в 87 сообщениях
Хороший. Сильно задумался о приобретении.
[Исправлено: Пехота, 30.08.2011 в 14:29] |
Буду брать
Регистрация: 30.06.2011 Последняя активность: 16.09.2025 17:24
Сказал(а) спасибо: 978
Поблагодарили: 217 раз(а) в 144 сообщениях
Прожектор... интересной какой ценник на это чудо будет?
Юридическая помощь в оффлайн или дистанционно хороший-адвокат.рф |
несущий свет в массы
Регистрация: 11.05.2011 Последняя активность: 20.09.2016 00:48
Сказал(а) спасибо: 137
Поблагодарили: 580 раз(а) в 125 сообщениях
спорный по удобству -судя пок артинке естественно-дизайн и размер корпуса....
★★★★★★★ Больше обзоров тут ★★★★★★★ |
