3819 0 0 0 |
21.04.2011, 08:58 | 1 |
Регистрация: 25.06.2010 Последняя активность: 23.08.2013 16:00 Адрес: NJ, USA
Поблагодарили: 104 раз(а) в 43 сообщениях
eGear X-Flare Pro Focus Control HL-400 (Preview w/pics & initial runtime)
I've been pining for a MOAH (Mother of all Headlamps, or at least as close to it as fiscally possible) for a while now and two non-custom ones in particular that I really like are the Silva Alpha 6 & Petzl Ultra. However, one look at the asking price for each and I needed to adopt the stance of "Look but don't touch!" (as with a lot of the nicer things in life).
Recently I came across the X-Flare Pro and after a bit of seraching, landed one for an excellent deal. Here is a preview of this headlamp (I'll convert into full review as time allows). Relevant specs from Mfg site Case Material: High-Impact ABS Plastic Size HxWxD: Headlamp: 3.7" x 2.6" x 3" Battery Case: 1.2" x 3" x 1.7" Weight w/batteries: 12.4 oz. Bulb: 3x Rebel 100 White LEDs Brightness: Up to 375 lumens Modes & run time: High: 25 min Medium: 1 hour Low: 9 hours Flashing: 80 hours Beam Distance: 360 feet Battery: 4.8V 2200mAh Ni-MH rechargeable Water Resistance: Water resistant IPX4 The light features a triumvirate of Rebel 100's: There is a nice big rotary knob that selects one of 4 modes and always in this order: H - M - L - SOS: Nice chunk of heat-sinking w/vents all around: Beam width is just over 18" at a distance of 2 ft from the wall and IMO, I think this should qualify for the flood list even though it's just a tad under 60 deg. (I measured 50). The beam is just a tad smaller all around than the Pixa 3's flood mode. (T: 1/13" | B: 1/80") The beam is reminiscent of the HL501 and nearly flawless except from some imperfections around the outer edges due to the three Rebel 100's. My initial impressions are that this is a very bright, solid and well crafted HL and certainly ranks as one of the better bang for the buck especially considering it comes with rechargeable batteries & charger. EDIT: Initial run time test. x = time in min. / y = relative output The blue test was flawed and cut short as the lamp was getting quite hot so I turned on a fan, thus the upward trend starting around 30 min. The red test was conducted with a fan on at get go. So it looks like runtime on H (provided it can be kept cool enough) is regulated at just over an hour and then it goes into some weird PWM mode which was also cut short due to the 10K data point limit on my light meter. While the red line seems to portray that the lamp is ramping up and down, to my eyes it's actually steady at roughly a thrid to quarter of output on H. Will rerun this again in the future. More to come... Cheers, Tim |
