Просмотров в теме 3803   Ответов в теме 0   Подписчиков на тему 2   Добавили в закладки 0
Старый 17.06.2016, 19:46 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Samsung ICR18650-26J 2600mAh (Pink)
Official specifications:
  • Nominal capacity: 2600mAh
  • Minimum capacity: 2550mAh
  • Nominal voltage: 3,6V
  • Charge voltage: 4,20V±0,05V
  • Maximum charge current: 2C 5,2A
  • Minimum discharge voltage: 2,75V
  • Chemistry: LiNiCoMnO2
  • Diameter: 18,20mm ± 0,05
  • Length: 64,80mm ± 0,05
  • Weight: 45g ± 0,01
One of the 2600mAh cells from Samsung.
The discharge curves has very good tracking. From the curves it is also obvious that the cell cannot do 10A.
Conclusion
This cell is probably an upgrade to the ICR18650-26H cell, but there is basically no performance difference.
I.e. this is also a very good cell for a standard 2600mAh cell.
Notes and links
Андрей Светлов (18.06.2016), Ходэн (18.06.2016)
Время генерации страницы 0.08356 секунды с 15 запросами
