9095 14 4 1 |
18.12.2015, 14:10 | 1 |
Регистрация: 01.08.2011 Последняя активность: 09.06.2017 16:17 Адрес: South Korea
Сказал(а) спасибо: 4
Поблагодарили: 401 раз(а) в 86 сообщениях
Lumintop Tool AAA Copper 'Shipping version' (Nichia 219B, 1xAAA) Review
Lumintop has released the Tool AAA Copper version, compatible with AAA sized Ni-MH, Alkaline and Lithium battery. The packaging is special. I found the light in vacuum-packed, cute plastic case with two o-rings and keychain. There is a small thin pad for protecting the body against scratch due to the pocket clip. As expected, the main reason for the light in vacuum-packed is to prevent oxidation of the body surface. This is almost the final production pack. . . Manufacturer Specifications from user manual : • Utilizes High CRI Nichia 219 LED or CREE XP-G2 (R5) LED with 50,000-hour lifetime • Output mode/Runtime : - CREE-Type : High : 110 lumens / 30 Minutes, Mid : 32 lumens / 10 hours, Low : 5 Lumens / 60 hours - NICHIA-Type : High : 80 lumens / 30 Minutes, Mid : 18 lumens / 10 hours, Low : 3 Lumens / 60 hours • Modes : Mid-Low-High ; Two ways to change modes: press the clicky switch or tighten/loose the head • Runs on : 1 x AAA (NOT included) (10440 Not Supported) • Dimensions : Length : 3.2" (81.5mm) ; Head Diameter : 0.57" (14.5mm) ; Body Diameter : 0.57"(14.5mm) ; Weight : 1.06oz(30g) (excluding battery) • Max Beam Intensity and Distance - CREE-Type : 553cd, 47 meters - NICHIA-Type : 304cd, 32 meters • High-efficiency digitally regulated circuit to maintain a constant brightness as battery life diminishes • Solid billet ultra conductive pure copper construction with polish finish, and packed in vacuum package preserve polished finish • Glow in the Dark front O-ring around reflector • Precision micro-textured reflector creates smooth, optimized beam • Double-side AR coated, tempered window resists impact and thermal shock, maximizes light transmission (99% light transmittance) • Reverse polarity protection to protect from improper battery installation • Multi-Function, clicky switch provides one-handed operation and easy access to all functions • High quality detachable stainless steel reversible clip makes it durable and keeps a firm grip on your pocket or hat • Impact resistance to 1.5 meters and waterproof in accordance with IPX-8 (submersible to 2 meters) • Market applications include, but are not limited to everyday carry, keychain, gift, emergency, security, hardware/tool and many other uses • Operation : Click the tail switch to turn on/off; when the light is on, press the switch to select brightness (Mid-Low-High) ; or tighten/loose the head to change modes . . The whole body is pure copper with polishing finish and no flaws on my sample. The head was nicely engraved with manufacturer and model name. The knurling is present over the head, body tube and tailcap. The light has a tail switch. Fit and finish look good. . . The light has 3 parts. The pocket clip works as a good anti-roll device as well. . . The head has a clean looking cylindrical design with a knurling band. The light has no reverse polarity protection function to protect from incorrect battery installation (i.e., you should be careful when inserting battery into the body tube). There is a GITD green o-ring present in the head, along with a orange peel reflector. You will see the nicely engraved model name on the head. . . The light uses AR coating lens where the purple hue is reflected on it. The light comes with a textured reflector (OP) and uses a Nichia 219B emitter. Centering of the emitters was pretty good on my sample. Note that you can choose Cree XP-G2 R5 version as well. . . The pocket clip looks sturdy and hold onto the light very securely. It is reversible, allowing both head-up or head-down. Note that the head and tailcap are reversible on the battery tube, so you can switch the direction of the clip by simply exchanging the head and tailcap. There is no risk the light might catch on something and be pulled off. . . The battery tube is mostly covered in typical diamond shaped knurling. With the pocket clip attached, overall grip is acceptable. The wall thickness of the body is 1.1mm, which is not so thick for the class. . . The screw threads are triangular-cut of good quality. As supplied, threads are not lubricated. But, screw threads action is smooth with no cross-threading or squeaking in my sample. . . The light uses a reverse clicky. The silicon switch cap protrudes out the tail end. The switch has stiff tension with average travel. The light has two attachment points for lanyard or split-ring. which prevents tailstanding. . . User Interface Turn the light on-off by the reverse clicky switch (i.e., click and release to turn on-off). You can advance through modes by a partial soft-press of the switch (or rapid off-on). Alternatively, you can loosen-tighten the head to move through modes when switched on at the tailcap. Mode sequence is Med. -> Low -> High, in repeating sequence. The light always defaults to Med. if it is off for more than three second or four. There is no mode memory. You can lock the light by loosening the head slightly. There are no strobe modes. . . From left to right, Panasonic Eneloop AAA (750mAh), Fenix E99 Ti (XP-E2), Ultratac K18 (XP-G2 S2), Skillhunt Ramble-I (XP-E R2). Lumintop Tool AAA Copper (Nichia 219B). . . Measured Dimensions . . The Tool AAA Copper is not a very small and lightweight light, as it has a tail switch with pure copper body. But it's good size to hold and use. You can use it as an EDC light. Overall build quality is very high. . . PWM The light shows no sign of PWM at all output levels. I notice there is no buzzing sound at any levels. . . Runtime The runtime to fall to 10% of its initial output from 30 seconds after the point the light is first turned on (i.e., based on ANSI FL-1) for High is as follows : The light maintains perfectly flat regulation for an extended period, followed by a dropping off. As expected, Eneloop AAA (900mAh) gives you the longest runtime. Note that 10440 li-ion is not officially supported (i.e, working voltage is 0.9~1.5V). Output-runtime efficiency seems good, as expect for a current-controlled light. . . Beamshot 1. White door beamshot (about 50cm from the white door) on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/8.0, 1/25sec, Auto white balance . . - ISO125, F/8.0, 1/100sec, Auto white balance . . - ISO125, F/8.0, 1/800sec, Auto white balance . . - ISO125, F/8.0, 1/2000sec, Auto white balance' The light shows good beam quality. The beam has a neutral white tint. . . 2. 3.5m Indoor Beamshot on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/2.8, 1/10sec, Auto white balance . . The above pictures make it look like all lights are not brighter than they actually are. . . 3. 7.0m Indoor Beamshot on max. output on 1xPanasonic Eneloop AAA (750mAh) - ISO125, F/2.8, 1/10sec, Auto white balance . . The above pictures make it look like all lights are not brighter than they actually are. . . Overall Impressions • Build quality is very high • Heavier than this class of light due to the copper body • Oxidation will slowly change the body color, but still will be classy • The light can't tailstand • Anti-roll indentations on the body • Physical lockout function (i.e.,head) • No reverse polarity protection function • 10440 Li-ion is not supported • No mode memory (always turns on in Med.) • True Moonlight mode is not available • No flickering due to PWM and no buzzing sound at any outputs (i.e., current-controlled circuit) • Output-runtime efficiency seems good • Overall beam tint is nice neutral white Lumintop Tool AAA Copper provided by Lumintop for review. [Исправлено: candle lamp, 21.12.2015 в 14:52] Причина: Manufacturer's website link |
18.12.2015, 14:14 | 2 |
смотритель маяка
Регистрация: 11.03.2013 Последняя активность: 15.11.2023 09:17 Адрес: Калининец
Сказал(а) спасибо: 257
Поблагодарили: 524 раз(а) в 307 сообщениях
Re: Lumintop Tool AAA Copper 'Shipping version' (Nichia 219B, 1xAAA) Review
Какие симпотичные картинки....
19.12.2015, 09:00 | 3 |
вечный n00b
Регистрация: 29.11.2012 Последняя активность: 14.08.2023 21:24 Адрес: 63RU TLT My Pleasantville
Записей в дневнике: 2 Сказал(а) спасибо: 5257
Поблагодарили: 1338 раз(а) в 918 сообщениях
19.12.2015, 13:13 | 4 |
19.12.2015, 13:35 | 5 |
вечный n00b
19.12.2015, 15:48 | 6 |
19.12.2015, 22:03 | 7 |
вечный n00b
Yeah, it's not rather cheap. ))
19.12.2015, 22:29 | 8 |
Регистрация: 04.06.2013 Последняя активность: Сегодня 13:32 Адрес: СПб
Сказал(а) спасибо: 469
Поблагодарили: 4588 раз(а) в 1609 сообщениях
20.12.2015, 10:16 | 9 |
вечный n00b
19.05.2016, 10:00 | 10 |
Регистрация: 23.09.2013 Последняя активность: 19.07.2019 01:54
Сказал(а) спасибо: 125
Однааааааако! Даже не знал, что начали хайкри наключники делать толком. Дешевле не нашелся нигде?
22.09.2016, 23:55 | 11 |
24.09.2016, 19:46 | 12 |
вечный n00b
вот потемнее больше нравится, жду когда мой благородно потемнеет до цвета виски )))
24.09.2016, 23:07 | 13 |
25.09.2016, 08:26 | 14 |
вечный n00b
а чем принудительно? если не секрет )))
25.09.2016, 11:40 | 15 |
В парах аммиака. Литровая банка, на дне бумажную салфетку и крышку от бутылки. На крышку фонарь вертикально. На бумагу пару миллилитров 10% раствора нашатыря из аптеки. Сверху крышка. На фото выдержка час при 25 градусах. Можно было и поменьше. Эффект заметен с 10 минут. Сначала лучше помыть с простым мылом, вытереть и досушить. Если уже в пятнах - они будут отличаться.
Поблагодарили: 3 раз(а) |
