16234 47 11 1 |
12.11.2015, 21:28 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Charger ML-102 V9.0 2015
This charger is a very small 18650 charger, it need an external USB power source to charge, and can also work as a USB charger / power bank. It only charges one battery at a time. The charger has been on the market a long time with frequent updates and not all updates successful. First time I looked at it, it was good, second time it was bad, third time it was fine again and this time? I got the charger in a envelope without any accessories. The charger has a micro usb connector for power input. And a usb connector for usb output power. As a new function the charger has a "fuel gauge", the number of green leds inside the charger shows how much power is in the battery. This gauge lights up when a battery is put into the charger. When charging one led in the gauge will flash the rest will show charge state, when discharging (i.e. used as power bank) it will only show charge state there is no flashing. The battery slot is fixed length with a tight spring at the minus end. Only unprotected 18650 will fit. It might be possible to charge smaller sizes with the use of spacers, but the battery and spaces must be very close to 65 mm length together. The charger can only handle 65 mm long batteries, this means unprotected batteries. Inside the charger The charger is easy to open, only four screws must be removed and it can be pulled apart. The top side of the board. Everything is basically controlled by one chip. The bottom side of the board. Measurements
At first glance it looks like a CC/CV charge curve with a high termination current. Both the charge voltage and termination current is fairly high, this gives a fast charge and the two probles balances each other out to give a good final voltage. The problem is that the charger measures voltage with current off and then terminates when it reaches 4.2 volt, this is not the correct algorithm for LiIon batteries. Because termination is voltage controlled, the termination current will vary with the battery. Simulating a weak charger made the ML102 charge the battery with reduced current, i.e. longer charge time, but it did termination when battery was full. M1: 30,8°C, M2: 29,1°C, HS1: 32,4°C This charger runs very cool when charging. The charger is a fairly dumb charger, this means fast initialization. When the charger reach the CV phase it will start using pulses to measure the battery voltage. This is not a real CC/CV charge. There is nearly 5 minutes between the measuring pulses. Measurements on USB power
The usb output can deliver 1.4A with a new battery before reducing the output, overload protection kicks in at about 2.1A. When the charger is powered the usb output is depend on the external power usb supply. Notice the lower voltage and higher current capability (Overload protection must be handled by external usb power supply). It can also charge while usb output is active, but charge current will depend on usb load. It works very fine at 0.5A load, good efficiency and stable voltage until the battery is discharged and automatic disconnected. Same with 1A load. The output drops slightly the last few minutes. With 1.2A load the charger has problems when the battery runs down, this means significantly shorter runtime. With 0.5A load the noise is very low at 10mV rms and 38mVpp. The noise is basically the same at 1A load at 11mV rms and 38mVpp. Conclusion I am not really impressed with this last update to the charger. The charging algorithm is not the recommended for LiIon and goes outside the specified charging parameters. I expect it to work fine, but probably costing a small amount of lifetime for the LiIon cells. The power meter is a nice addition. The usb output works very well up to 1A, at higher current it will have trouble when the battery is nearly empty. The possiblity to pass power from usb input to output is useful, but the low voltage may be an issue. Due to the strange charging algorithm I will only give it a final rating of acceptable. Notes Here is an explanation on how I did the above charge curves: How do I test a charger Read more about how I test USB power supplies and chargers
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
13.11.2015, 01:08 | 2 |
Регистрация: 08.12.2013 Последняя активность: 26.02.2024 23:55 Адрес: Spain
Сказал(а) спасибо: 86
Поблагодарили: 191 раз(а) в 151 сообщениях
Re: Test/Review of Charger ML-102 V9.0 2015
HKJ, Perhaps old chargers on ETA6002(like ml-101 v6, that hasn't overcharge bug) is more reliable for charging lion?
P.S. I'm really happy that I didn't received ML102 v9 from Everbuying))) Great job, thank you! [Исправлено: wxp, 13.11.2015 в 01:10] |
13.11.2015, 01:50 | 3 |
Регистрация: 08.03.2011 Последняя активность: Вчера 22:42 Адрес: Питер
Записей в дневнике: 4 Сказал(а) спасибо: 15428
Поблагодарили: 33398 раз(а) в 12448 сообщениях
Таки испортили ML-102, печально.
[Исправлено: fnksb, 13.11.2015 в 03:00] |
13.11.2015, 02:23 | 4 |
13.11.2015, 04:07 | 5 |
Регистрация: 07.09.2015 Последняя активность: 21.11.2020 14:11 Адрес: Спб
Сказал(а) спасибо: 95
Поблагодарили: 121 раз(а) в 78 сообщениях
Вот слушай теперь форум... "хорошая зарядка", говорили они.
joshwo (16.12.2015)
13.11.2015, 07:59 | 6 |
Регистрация: 13.10.2013 Последняя активность: 05.03.2020 07:59
Блин, а я заказал ML-10 Version 9, позавчера на фасттеке, с парой аккумуляторов. Ну да ладно, это туристически-походный повербанк будет, смирюсь с меньшей жизнью лития.
13.11.2015, 08:03 | 7 |
Регистрация: 11.08.2011 Последняя активность: Вчера 21:41 Адрес: Дубна
Записей в дневнике: 1 Сказал(а) спасибо: 2533
Поблагодарили: 11406 раз(а) в 4185 сообщениях
crea7or, а что в не плохого? 4$ ,заряжает ,разряжает. А как отступление от CC/CV влияет на жизнь батарейки особо не известно, то есть за обозримое время не сдохнет.
13.11.2015, 19:00 | 8 |
Ветеринар Фонаревки
Сказал(а) спасибо: 9643
Поблагодарили: 2234 раз(а) в 1451 сообщениях
обидно другое, было хорошо ,хотели сделать лучше получилось как всегда хуже
In Fino verytas |
13.11.2015, 19:26 | 9 |
13.11.2015, 19:28 | 10 |
Ветеринар Фонаревки
13.11.2015, 19:53 | 11 | |
То есть реальный заряд идет рывками до 4.30 То есть вместо классического СС/CV "доводим до 4.2 и плавно снижаем ток" получилось "доходим до 4.10, а дальше рывками заливаем, получая до 4.30 в процессе". |
13.11.2015, 19:56 | 12 |
13.11.2015, 21:16 | 14 |
Ну зато заряжает на треть быстрее по времени.
14.11.2015, 13:08 | 15 |
Регистрация: 27.05.2011 Последняя активность: Вчера 21:03 Адрес: Россия, Пермский край
Сказал(а) спасибо: 5939
Поблагодарили: 32753 раз(а) в 15181 сообщениях
сейчас все больше и больше зарядок пытаются обойти ограничения классического метода СС/СV, которые придуманы вовсе не для безопасности и долгой жизни аккумулятора, а являются просто следствием простоты алгоритма и его аппаратной реализации.
добивать малым током до конечного напряжения, или немного превысить напряжение на клеммах, при том что эдс аккумулятора не будет превышена - какая разница? зато время заряда сократилось, и получены заветные 4,2в, а не 4.15-4.18, которые так огорчают многих. вот только контроль раз в 5 минут - несколько странно. ведь ничто не мешает контролировать несколько раз в минуту. |
fnksb (14.11.2015)
14.11.2015, 13:49 | 16 |
galex, проблема в том, что никто из присутствующих не разбирается в литиевых аккумуляторах настолько, чтобы уверенно сказать "вот этот алгоритм безопасен" или "вот этот алгоритм ускоряет деградацию только на 1% и его рационально использовать".
Китайцы, штампующие зарядки, тоже почти наверняка не разбираются Если б панасоник такую зарядку выпустил и сказал "вот, новый алгоритм, ускорение заряда ценой незначительной деградации" - другое дело |
14.11.2015, 14:00 | 17 |
напряжение повышается за счет падения напряжения на внутреннем сопротивлении, потенциалы электродов ведь не будут превышены. а ускорение деградации вызывается именно этим. так что с чего бы ему быть?
безвозмездно на форуме уже как минимум пару раз выкладывались ссылки на зарубежные научные труды по отказу от классики. единственный сдерживающий фактор - всего лишь цена. это надо разрабатывать новые контроллеры и тп. мало кто из гигантов захочет брать на себя риск официаьлно объявить об отказе от даташитных методов. их же потом поток возвратов завалит от пользователей, которые убили свои аккумляторы например глубоким разрядом, но у которых есть новая зарядка, игнорирующая официальные рекомендации вековой давности [Исправлено: galex, 14.11.2015 в 14:04] |
14.11.2015, 14:03 | 18 |
Это ж литий. Он от всего деградирует. Он вообще по жизни деградирует - где-то быстрее, где-то медленнее
Поблагодарили: 4 раз(а) |
14.11.2015, 14:05 | 19 |
14.11.2015, 14:17 | 20 |
Регистрация: 12.05.2014 Последняя активность: 24.04.2024 23:28 Адрес: Долгопрудный-Лобня-Москва
Записей в дневнике: 1 Сказал(а) спасибо: 790
Поблагодарили: 752 раз(а) в 539 сообщениях
Мне надо было зарядить сразу несколько акков, а моя VP2 в отъезде.
Использовал 4 шт Ml102 ver 9. Акки были SAMSUNG розовые на 2600мА (новые из магазина), разброс напряжений 4,19-4,23.
фонари Zebralight |
