2859 0 1 0 |
15.09.2015, 17:23 | 1 |
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53 Адрес: Copenhagen, Denmark
Поблагодарили: 2982 раз(а) в 1024 сообщениях
Test/Review of Keeppower 18500 2000mAh (Black) 2015
Official specifications:
These cells from Keeppower have very good capacity for 18500 cells, but are not for very high load. Very nice discharge curves with good tracking and constant capacity up to 3A. The 7A trace is cut short due to the protection kicking in. Conclusion This is very good batteries for their size for lower current applications, but if you have the size 18650 is better. Two of these cells has about the same length and voltage as 3xCR123, the diameter is larger and the capacity is higher. Notes and links The batteries was supplied by Keeppower for review. CR123A and rechargeable substitutes How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries Compare to 18650 and other batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
Сумской (16.09.2015)
