Просмотров в теме 2383   Ответов в теме 0   Подписчиков на тему 1   Добавили в закладки 0
Старый 19.12.2014, 19:23 Автор темы   1
Модератор своих разделов
Аватар для HKJ
Поблагодарили: 2984 раз(а) в 1024 сообщениях
По умолчанию Test/Review of AWT IMR18350 800mAh (Yellow)
Official specifications:
  • Type: IMR (Li-Mn) High Drain Unprotected
  • Model: 18350 (800mAh) Flat Top
  • Nominal Voltage: 3.7v
  • Max Current Output: 10.5A
  • Length: 35mm
  • Diameter: 18mm
  • Cycle Life: 500 Cycles
  • Max Charging Rate: 4.5amps
This is a high current 18350 battery.
There is a small difference in capacity on the two tested batteries. The batteries can handle up to 7A, but 10A does not look good.
Conclusion
Being a high capacity battery it does not set record in capacity, but compared to other high current batteries both the capacity and current handling is good.
Notes and links
The batteries was supplied by AWT for a review.
Comparison to other LiIon batteries
alexsav (21.12.2014)
Время генерации страницы 0.07695 секунды с 15 запросами
