11502 14 6 1 |
09.12.2014, 12:03 | 1 |
Регистрация: 08.08.2011 Последняя активность: 19.04.2024 11:51
Поблагодарили: 133 раз(а) в 44 сообщениях
NEW release! SKILHUNT H02C RGBW Colorful headlamp
Hello everyone,
Good news! NEW release! SKILHUNT H02C RGBW Powerful headlamp. Specification: LED: CREE XML-Color LED Weight:56g(excluded battery) Power:1*18650 battery Rated range:3V ~ 4.2V Dimension: Length:110mm/4.33 inch Head diameter:25mm /0.98 inch Body diameter:22.8mm Lens:P.T.I.R Lens Color:Black Waterproof to IPX-8 Impact Resistant:1.5 Meters Accessories:Opetator´s manual, Warranty card, Spare O-rings, Magnet replace O-ring, Lanyard, Clip, Headband Optional accessories: Battery, Charger Wight light modes: / Runtime: Turbo 260 LED Lumens / 2 Hours and 30 Mins High 140 LED Lumens / 5 Hours Med 50 LED Lumens / 12 Hours Low 2 LED Lumens / 480 Hours SOS 260 LED Lumens / 5 Hours Beacon 260 LED Lumens / 5 Hours Color light Red Green Blue DWL 620-630 nm 520-535 nm 450-465 nm OUTPUT Hi 100/ Lo25 LED lumens Hi 150/ Lo 30 LED lumens Hi 30/ Lo 5 LED lumens Runtime Hi 3.0/ Lo 18 Hours Hi 2.5/ Lo 18 Hours Hi 2.5/ Lo 18 Hours Easy and Trusty user interface operation: 1. When the flashlight was OFF status: - Click the side switch to White Mode brightness level, cycle as Lo - Mid- Hi - Turbo. Quickly double press side switch to Color High Mode.(Double press back to White light mode.) - Hold press the side switch 0.5 second to Color High Mode, cycle as Red - Green - Blue. Quickly double press side switch to White Mode.(Double press back to Color High mode.) - Quickly double press side switch to Color Low Mode. Double press to specical mode, cycle as SOS - Beacon. (Double press back to Color Low mode.) When the flashlight was ON (any mode) status: - Hold press the side switch 0.5 second, turn off the flashlight. Low voltage indication: When the battery voltage drop down, the light will blink three times every 2 minutes. Features: 1. Super bright & lastest CREE XML-Color LED, High-Performance, High-Efficiency and energy conservation. 2. P.T.I.R Lens, Efficiency reflection, perfect beamshot. 3. Four output levels and Strobe, suitable for different environment. 4. Flat tail with strong magnet to secure to ferrous surfaces. 5. Rugged indestructible aluminum body with anti-scratching type III hard anodization. 6. Multi-level dissipating heat design, excellent heat dissipation. Flashlight head integrated construction, high thermal conductivity. 7. Side mode switch button to transferring mode, user friendly inerface to adjust output. 8. High efficiency driver circuit. 9. Reverse polarity protection, to protect from improper battery installation. 10. Low-voltage indication, the light will flash when the battery is low, remind user replace the battery on time. 11. Engineered anti-slip knurling for a tightly firm grip. 12. Dual recoil absoring springs, bettery impact resistance. 13. Tail stand as a candle-light. 14. Tail hang hole design for lanyard use, to prevent accidental dropping. Details [Исправлено: skilhunt, 11.12.2014 в 05:06] |
Поблагодарили: 3 раз(а) |
09.12.2014, 12:09 | 2 |
Регистрация: 25.11.2013 Последняя активность: 02.12.2020 22:19 Адрес: Краснодар
Сказал(а) спасибо: 519
Поблагодарили: 142 раз(а) в 91 сообщениях
Re: NEW release! SKILHUNT H02C RGBW Powerful headlamp
Интересно! А не будет ли хот спот не правильной формы из-за того, что кристаллы смещены относительно оси?
09.12.2014, 12:17 | 3 |
Шурик с шуриком
Регистрация: 03.07.2011 Последняя активность: 27.01.2024 21:46
Поблагодарили: 2601 раз(а) в 1436 сообщениях
На иглтаке таком так и есть, кривые споты
только у меня в игнор-листе полный список форумных садомитов |
Burlaew (09.12.2014)
22.12.2014, 04:38 | 4 |
Регистрация: 16.04.2014 Последняя активность: 25.03.2020 05:51 Адрес: Самара, Сухая Самарка
Сказал(а) спасибо: 359
Поблагодарили: 181 раз(а) в 114 сообщениях
[Исправлено: Valerianis, 22.12.2014 в 04:40] |
23.12.2014, 14:33 | 5 |
Регистрация: 13.08.2013 Последняя активность: 13.03.2016 07:28 Адрес: Пермь
Сказал(а) спасибо: 764
Поблагодарили: 557 раз(а) в 210 сообщениях
Очень интересная новинка, только непонятно, диод какой группы С2 или С3.
Ко мне уже едет сабж, так что обязательно сделаю обзор. |
23.01.2015, 11:48 | 6 |
Сказал(а) спасибо: 1116
Поблагодарили: 1650 раз(а) в 958 сообщениях
Забавный конечно фонарь. Особенно система управления веселит. Не так логична как на зебре но запоминается быстро.
Хот спот кривой во всех цветах, что ожидаемо. Но не так страшно в практике ИМХО. Пищит на малых режимах сильно. Цвета сочные и ядреные. Лезут все акки даже кипповеры с сейко защитой. Мне кажется, есле бы был режим со стробом перебирающим цвета, был бы мега праздничный фонарь! Жаль что нет такого, строб и сос белый. Хотя строб более похож на маяк, не агрессивный и спокойный. Ждем зебру с таким диодом... Избаловала конечно меня зебра своим выбором режимов. Точнее количеством, а тут их прямо в 4 раза больше нужно. Нужно отметить что такого ядреного синего я в фонарях еще не видал. Ни с фильтром не на индикаторных пендотактиках. Тут он прям вах вах. Жаль что сейчас зима. Хотя и так в лесу с этим цветом прям кусок пандоры и наави вокруг шныряют, не важно что в сугробах. Так и ждешь шестиногого чудовища из за дерева... В общем с эмоциональной точки зренияможно прировнять этот фонарь к походу в кино. [Исправлено: Rocklight, 23.01.2015 в 11:59] |
23.01.2015, 12:03 | 7 | ||
Пока вижу применение только как тактик со своим ярким красным цветом, ну и в основном как сигнальный фонарь. |
Tarans (22.03.2017)
23.01.2015, 12:22 | 8 |
Да, два режима на цветных маловато.
Синий таки интересен в плане позабавить детей. Многие белые вещи начинают подсвечиваться. Может быть таки карты при нем читать будет легче, это буду проверять позже. Свет красный у него не сказать чтоб прям сильно яркий. Моя полосатая н32r его пересвечивает. Хотя понятно что рефлектор дальше бъет. Но сумммрно по ощущениям в зебре 100 люмен весят больше чем в скиле. [Исправлено: Rocklight, 23.01.2015 в 12:25] |
23.01.2015, 13:23 | 9 |
23.01.2015, 13:57 | 10 | |
Регистрация: 26.10.2012 Последняя активность: 21.09.2015 16:05 Адрес: Екатеринбург
Сказал(а) спасибо: 32
Поблагодарили: 65 раз(а) в 21 сообщениях
OUTPUT Hi 100/ Lo 25 LED lumens - красный Hi 150/ Lo 30 LED lumens - зеленый Hi 30/ Lo 5 LED lumens - синий
Магазин хороших фонариков www.lumenbox.ru |
23.01.2015, 14:00 | 11 |
[nick="Lumenbox.ru"] да именно так. В реальном экземпляре тоже.
Только управление замудренное. Выход в минимальные цветные с выключенного фонаря двойным кликом. |
Valerianis (23.01.2015)
13.11.2016, 22:21 | 12 |
don't fuck my brains
Регистрация: 18.05.2013 Последняя активность: 26.01.2024 14:02 Адрес: МО
Сказал(а) спасибо: 634
А случаем внутрь не заглядывали, расчленёнку не производили? Драйверок там такое же недоразумение как в обычных H02, Т образный - из двух плат составлен?
Или другой конфигурации, просто круглый как в H03?
Zebralight H51c, EagleTac G25C2 NW, Skilhunt H03R/H03 NW, Roche M170 v2 U2-1A, Eagle Eye x2r nw (3C), Skilhunt H02C, M43 S4 3D/2В/5D2 [Исправлено: GAME OVER, 13.11.2016 в 22:24] Причина: Потому что "профессор". |
14.11.2016, 11:10 | 13 | |
Хотя фонарь уникальный и единственный в своем роде!
Фонарей много не бывает! |
GAME OVER (14.11.2016)
14.11.2016, 20:27 | 14 |
Rocklight, Тоже заказал, себе в подарок к НГ.
Разберу гляну, выложу фото, по всему тырнету нету фотки расчленёнки этого фонаря, действитно уникальный.. Подозреваю что может быть другой, по разводке должен сильно отличатся, может и конфигурация платы другая, драйвер может быть даже двух этажный. Таки 8 точек подключения вместо двух. PS и таки он другой, вот что нашёл, правда только одна сторона, но понять можно что разводка сильно другая. Взял здесь http://www.forolinternas.co... Вот фотка обычного H02 [Исправлено: GAME OVER, 14.11.2016 в 22:03] Причина: Потому что "профессор". |
