2850 0 0 0 |
20.04.2014, 15:16 | 1 |
Регистрация: 04.01.2013 Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
*** Pictures *** Blackshadow Terminator (4*XM-L T6 NW)
Hello guys, Terminator arrived few days ago..
The BlackShadow Terminator is an LED flashlight with four CREE XM-L U2 LEDs for up to 3500 lumens on max output. The light is controlled by a switch conveniently located on the attached handle and is powered by four 18650 batteries (not included). - Dimensions: 132mm (Length), 69mm (diameter of head), 93mm (Height) - Weight: 395g (Without Battery) - Three outputs (XM-L U2): 3500 lumens (1h10m) - 1500 lumens (2h40m) - 400 lumens (11h25m) - Accessories: Tactical parachute-cord, Spare O-ring, User manual and Warranty card. - Stainless steel bezels - Impact-resistant optical tempered glass lens with anti-reflective coating - Heat sink fins - Aluminum alloy body with abrasion-resistant surface finish anti slip rhombic knurling - Design offers a decent overall grip - Aluminum alloy tail cap with rhombic knurling, can tail stand - Four premium CREE XM-L U2 LEDs, rated Max 3500-lumen output - Custom designed metal reflector offers perfect beam profile. - High-performance push button switch. Slightly click the switch to turn on the flashlight and change the brightness mode among High-Mid-Low-OFF. Pressing and hold the switch for more than 1 second to turn on or off Strobe mode. - Power indicating system: The indicator light is green when the power is available, it will change into red and flash three times every second when the power is low. - The indicator light will flash when the flashlight in on standby state, which will help you to find it easily in deep dark or complex environment. - You can completely shut off the power to save the energy, by loosening the head a half turn if in long periods of inactivity. - Built in digital control system, powered by 4 pcs 18650 batteries (not included) First impressions Pro - Very nice build quality, similar than other top chinese brands - Perfect anodizing, no scratch etc. (HA Type-II) - Smooth thread - Clean reflectors, lens with perfectly centered leds - Beautiful neutral white tint - Excellent beam quality, very good balance (throw-flood) - Hidden strobe mode - Temperature control - can run 1, 2 or 3 pcs 18650 battery (not only 4pcs) - Relatively small size with awesome output Con - no memory - visible pwm flickering low and medium mode (high mode is perfect, no pwm!), but when I use outdoor, the pwm is not too annoying, especially medium mode. other - simple UI, 3 modes, but not too user friendly, always low-medium-high-off candle lamp, Terminator review http://www.candlepowerforum... Beamshots (I will add more pictures later) Click images for higher res Blackshadow vs Xeno F42 V2 R5nw Blackshadow vs Sunwayman T20CS Blackshadow vs Spark SL6S-740NW Blackshadow vs Nitecore MT26 Blackshadow vs Nitecore :sssh: Blackshadow vs Fenix TK35 U2 Blackshadow vs Olight SR51 Blackshadow vs Armytek Barracuda Modes more pictures coming soon |
