3348 0 0 0 |
20.05.2014, 14:15 | 1 |
Регистрация: 04.01.2013 Последняя активность: 29.09.2015 22:48
Поблагодарили: 85 раз(а) в 24 сообщениях
Foursevens Maelstrom MMU-X3 (3*XM-L2, 1600lm) pictures, impressions
Hello guys, one of the smallest triple led flashlight arrived few weeks ago, this is one of my favourite flashlight now, I made some pics, and I would like to share my impressions also
Official, Features Strike-Bezel Current regulation Thermal regulation Smart circuit for rechargeable batteries Reverse-polarity protection Specifications Dimensions: Length: 5.6 inches (14.2cm), Body diameter: 1.3 inches (3.3cm) / Head diameter: 1.8 inches (4.6cm), Weight (without batteries): 5.6 oz (158.76g) Led emitter: (3) CREE XM-L2 Power source: 1*26650 Voltage range: 3V-4.2V Spot beam: Angle: 12 degrees / Diameter at 3 meters: 620mm Flood beam: Angle: 90 degrees / Diameter at 1 meter: 2 meters Britghtness levels: Low: 200 lumens, 11 hrs / High: 1600 lumens, 2.5 hrs Reflector: Smooth Body material: Type-III hard-anodized aircraft-grade aluminum Bezel material: Type-III hard-anodized aluminum strike-bezel Lens material: Optical-grade glass lens, sapphire coating, antireflective coating Included accessories: Spare-o-rings, holster (Battery and Battery Charger NOT included) The Maelstrom MMU-X3 features a simple, two-mode interface that takes only a few seconds to master. To start, please make sure the MMU-X3 battery is inserted with the positive side (+) toward the head. Then, tighten the tailcap fully down and the MMU-X3 will turn on. Loosen the tailcap a half-turn, and the MMU-X3 will turn off. The MMU-X3 tailcap has a pressure-style switch. When the tailcap is loosened a half-turn, simply press the button on the back to activate the light. The switching mechanism is momentary, which means when you stop pressing on the button, the MMU-X3 will turn off. To 'lock' the MMU-X3 on, simply tighten the tailcap fully down again. To switch between the high and low output modes, turn the MMU-X3 off, and then turn it on again within 1 second. Any time the MMU-X3 is turned on within 1 second of being turned off, it will automatically switch to the next mode. However, if you leave the MMU-X3 off for 2 seconds or longer, it will "memorize" the last mode used. See the examples below: Example 1: ON (High mode) — OFF (1 Second) — ON (Low mode) Example 2: ON (High mode) — OFF (2 Seconds) — ON (High mode) My impressions Pros - High build quality, with very nice semi-matte black anodizing. Looking better than earlier Foursevens flashlights! (I have an MMX with burst mode, but MMU-X3 anodizing looks different, looking better) - Scratch free anodizing - Very nice design, comfortable in hand - Well lubricated thread and o-ring - Dust free reflector, lens - Awesome output (1600lm) from a relative small flashlight - NO irritating pwm flickering! - The battery is not rattle in tube - Nice beam with lots of spill, similar as Jetbeam DDR30, but without rings - Simple UI, only two mode, if you need you can change modes with one hand - MMU-X3 comes with thermal control, not a simple "3-5 mins timer" - Low output (200lm) is ideal for many situations, I think, that was a good choice - Good quality "hard" holster Cons - no real cons for me Other comments - I hope neutral white version will be available in future my tips Recommended batteries: Foursevens Protected 26650, 4000mAh, Keeppower Protected 26650 (4500mAh) Recommended charger(s): Foursevens LifePO4/Li-ion charger (V4) (if you are an EU customer you need EU plug adapter for this charger, or you can use this charger with USB cable/adapter), XTAR SP1/SP2 (faster charge current, max. 2A) my pictures, more pics coming soon, incl outdoor beamshots with Fenix LD41 (XM-L2 U2) and Fenix TK35 U2 with Jetbeam DDR30 and Fenix RC40 Jetbeam SRA40, Skilhunt K26 (26650) Olight S15, S10-L2, S20-L2 -------------------------- ISO100, F2.8, 2.0s, WB Daylight, distance ~20m Maelstrom MMU-X3 vs Nitecore P12 Malestrom MMU-X3 vs Microfire M2C Malestrom MMU-X3 vs Microfire M2C Malestrom MMU-X3 vs Fenix PD35 ISO100, F2.8, 1.3s Maelstrom MMU-X3 vs Jetbeam DDR26 Maelstrom MMU-X3 vs Olight M22 Maelstrom MMU-X3 vs Fenix TK76 (spot) Maelstrom MMU-X3 vs Fenix TK76 ISO100, F2.8, 0.8s Fenix TK75, TK76 Olight SR96, Fenix RC40 Jetbeam DDR30, Maelstrom MMU-X3 |
