Просмотров в теме 3857   Ответов в теме 1   Подписчиков на тему 1   Добавили в закладки 0
Старый 09.05.2014, 19:42 Автор темы   1
Модератор своих разделов
Аватар для HKJ
По умолчанию Test/Review of Efest IMR18350 700mAh (Purple) 2014
Official specifications:
  • Capacity: 700mAh
  • Min. Capacity: 670mAh
  • Nominal voltage: 3,7V
  • Charge voltage: 4,2V ± 0,05
  • Discharge voltage: 3,0V
  • Max. discharge current: 11A (15C)
  • Max. charge current: 0,7A (1C)
  • Positive pole: Flat Top
  • Protection circuit (BMS): no (unprotected)
  • Chemical composition: LiMn (IMR)
  • Diameter: 18,25mm ± 0,1
  • Height: 34,75mm ± 0,1
  • Weight: 22g ± 1
  • Charging methode: CC-CV
Efest has made a range of very high current batteries (Purple), this is the 18350 sized one.
The cells has very good tracking between them and does also handle the load very nicely.
Conclusion
This cell has very impressive high current capability, but do not get it if you want a lot of capacity.
It looks like a good cell.
Notes and links
The batteries was supplied by Akkuteile.de for review.
Comparison to other LiIon batteries
vvvoland (09.05.2014)
Старый 18.05.2014, 06:06   2
vvvoland
Последняя активность: 28.10.2018 13:54
Сказал(а) спасибо: 589
Поблагодарили: 1071 раз(а) в 299 сообщениях
По умолчанию Re: Test/Review of Efest IMR18350 700mAh (Purple) 2014
Thank you very much!
finished my tests, the results are very similar
reference HKJ
vvvoland вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.08148 секунды с 15 запросами
