4340
Модератор своих разделов
Регистрация: 03.07.2010 Последняя активность: 10.10.2022 08:53
Orbtronic 18650 3600mAh (Black)
![]() Official specifications:
![]() This is the next increase in battery capacity, from 3400mAh to 3600mAh, this is not a huge increase. With my test conditions (Discharge to 2.8 volt), I do not get 200mAh more capacity, more like 100mAh. The cell used can be discharged down to 2.5 volt, in my test I only discharges to 2.8 volt, i.e. I do not measure the full capacity. But then, not all lights will be able to use the full capacity. ![]() Orbtronic uses a very nice packing for this battery. ![]() ![]() ![]() ![]() Due to the protection the battery cannot deliver 7A continuous. ![]() ![]() ![]() ![]() ![]() ![]() Conclusion When comparing this battery to the 3400mAh cell, the new battery has slight higher voltage and slightly higher capacity, this is not a revolution in any way, just a small improvement. Being based on a Panasonic cell the battery is, of course, a very good battery. Notes and links The battery was supplied by Orbtronic for review. How is the test done and how to read the charts How is a protected LiIon battery constructed More about button top and flat top batteries
My website with reviews of charges, batteries and other stuff: http://www.lygte-info.dk/ |
| Поблагодарили: 5 раз(а) |
Admin (28.11.2013), Alex TG (29.11.2013), Peli (28.11.2013), Tamagotchi (28.11.2013), vvvoland (28.11.2013)
Регистрация: 25.04.2013 Последняя активность: 28.10.2018 13:54
Сказал(а) спасибо: 589
Поблагодарили: 1071 раз(а) в 299 сообщениях
Hi
Thanks for the test! there are no plans to make a comparator for energy (Wh) ? |
Сказал(а) спасибо: 12
![]() ©SpaceCowboy from BLF Quite nice improvement IMO Edit: it looks like SpaceCowboy is PR agent of Orbtronic and he deliberately chose weakest protected 3400mAh there is. Here's a comparison with Keeppower 3400mAh: Отредактировано: похоже, что SpaceCowboy - пиарщик Orbtronic'а, и он специально выбрал самую херовую батарейку на 3400mAh. Вот сравнение с Keeppower 3400mAh: ![]() Уже не впечатляет.
[Исправлено: Shadowww, 29.11.2013 в 04:03] |
