6938 2 1 0 |
07.12.2010, 08:34 | 1 |
Регистрация: 26.06.2010 Последняя активность: 26.08.2011 11:52 Адрес: China
Olight SR50 outdoor pictures review,more than 100 pictures
These pictures were taken by ethen from shoudian.com, Thanks for him hard work , if you want copy the picture , please contact him .
SR50 Intimidator Flashlights Specification LED: Luminus SST-50 Materials: Aircraft grade aluminum with black type III hard anodized finish. Output and runtime: Two brightness levels and strobe mode High mode: 800 Lumens / 1.5 Hours, Low mode: 200 Lumens / 10 Hours Strobe: 10 Hz / 3 Hours Battery: 6 x CR123A batteries or RCR123A(Runtime will reduce) Dimension: Length 185mm/7.28” Bezel diameter 63mm / 2.48” Weight: 396g / 13.97oz (Excluding batteries) Accessories: Includes one holster, one lanyard, two o-ring, one operator's manual Color: Black Features Max output 800 Lumens Smooth reflector offers max 700 Meters long throw Excellent tridimensional heat dissipation ability Easy touching side switch for turning on/off the light and transferring modes Access to strobe directly Auto-memorize level used last time. Mil-spec: MIL-STD-810F Highly water resistant to IPX-8 Anti-shattering ultra clear lens, anti-scratching, anti-slip function. Tough and rugged body with noblest knurling offering firmly grip Stand firmly on tail for releasing your hand when in illumination. Relatively portable size for easy carry and grip with super power Operation Presses the side button switch to active the lights. A fast double press will active 10Hz strobe. Press and hold the side switch for 3 seconds will transfer the mode. Package a flashlight , one holster, one lanyard, two o-ring, one operator's manual III hard anodized , Compact and portable handheld design Good quality SST-50 LED lanyard hole tailcaps Powered by 6*Cr123A batteries or 6*16340 batteries , not support 3*18650 battery . Recently there have a good news that Olight company was redesign this light and can support 2*18650 batteries, and it will release this month . Nice SMO Reflector , and nice beamshot Size compare Reflector lens and O-ring Switch mode Right: high mode High Low Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE Left: Olight SR50 sst-50 Right: Ultrafire C8 MCE 30meters Low 30meters High 100meters low 100meters High |
07.12.2010, 17:18 | 2 |
Re: Olight SR50 outdoor pictures review,more than 100 pictures
А мне нравится... Добротный обзор...
07.12.2010, 20:22 | 3 |
Интересный фонарик, но стенки головы кажутся тонкими. При падении можно и стекло разбить погнув корпус.
