254984
749
45
Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
Вторая часть обсуждений.
Первая часть тут: https://forum.fonarevka.ru/... ------------------------------------------ http://www.cpfmarketplace.c... Обновление фонарика CRELANT Specifications • LED: CREE XM-L2 LED • Maximum output: 1160 lumens (ANSI FL-1 standard) • High efficient constant current circuit and output-luminance • Microcontroller drive circuit • Tactical High Mode • Working voltage: 2.8 - 6 VDC • Battery Types Supported: 3 x 18650 • Runtime: High output at 3A: 1160 lumens max for 145 minutes. Mid output at 1A: 368 lumens max for 420 minutes. Low output at 0.3A: 138 lumens max for 21 hours • Mil. Spec. Type 3 hard anodized aircraft grade 6063 aluminum alloy • Color: Black • Ergonomic grip with anti-roll design • Tactical forward tail cap switch • High performance aluminum smooth reflector with concentrated beam shot • Waterproof: IPX-8 Standard • Lens: Toughened ultra-clear coated and anti-abrasive glass • Candle function with ability to stand on tail cap • Dimensions: Length 187mm, Head Diameter 65mm • Weight: 483g excluding battery • Accessories: Lanyard, spare o-ring Features - Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search& Rescue and Outdoorsman - Side switch with infinite brightness system - Stainless steel retaining ring on the bezel protects the head from drops and impacts. - CREE New XM-L2 LED - Max output of up to 1160 lumens with an effective range of 720 meters - New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability - Newly designed high efficiency broad voltage drive circuit maintains constant brightness and maximal runtime - IPX-8 standard waterproof
uV3, странный путь развития - фонарики у всех одинаковые, остаётся только маркетингом мухлевать?
трол. |
blindnick, я не знаю, что там было в прошлой версии фонарика.
Может светодиод XM-L на XM-L2 заменили, может ещё какие-то положительные изменения, не обязательно значительные. Даже небольшие улучшения - это хорошо. А насчет похожести - так это рынок насыщен, производители конкурируют ценами и разными фишками. Нам (покупателям) это только на руку.
Да ну. Или ANSI FL-1 standard или 3A: 1160 lumens. И фишки у Креланта как-то неинтересные.
Сказал(а) спасибо: 5056
Мне кажется, что тоже фонари как-то унифицируются ))
Авторизованный Хемуль
Регистрация: 25.05.2010 Последняя активность: 18.05.2022 16:30
Сказал(а) спасибо: 985
МеДВАдь
Видишь свет в конце туннеля!? [Исправлено: ДВА, 22.05.2013 в 17:40] |
Желаю странного
Регистрация: 11.03.2011 Последняя активность: 18.09.2025 09:13
Скорее кромы. Мы вроде его обсуждали же?
А у малиновой девочки взгляд откровенней, чем сталь клинка. Мои:Surefire C2 x2, M6LT, EB2T-A-TAN, U2, E2DL, L1, L2, Z2L, HS1-B-SL, G2X Pro x2, G2-YL, E1L, E1E-BK, E2E, M951, M952; FiveMega M4 z46, Leef P6T LF HO-M6R; Solarforce L2m, L2X, L4X x3; PeakLogan 17500/AA 219; StreamLight Sidewinder II; Fenix LD10; EagleTac G25C2, Olight smini cu; Convoy M1; YLP Panda2CRI, Enot500 x2, Swift |
Регистрация: 04.05.2012 Последняя активность: 30.06.2019 03:33
Сказал(а) спасибо: 256
Интересный ИМХО фонарик с DX.
11 люмен,линза.Обозначен как детский.Мол с рассеянным от линзы светом и 11 люменами сложно нанести вред детским глазам,с намеком на то,что мелкие засранцы любят в глаз засветить. Сабж выглядит не плохо,возможно благодаря фотографу и освещению.Цена в 15 долларов не велика,но и не детская. |
Фонарики с настройкой режимов через Bluetooth:
http://www.fasttech.com/pro... http://www.fasttech.com/pro... |
Иех!
Регистрация: 16.01.2013 Последняя активность: 30.09.2024 13:45
Сказал(а) спасибо: 1083
Поблагодарили: 486 раз(а) в 345 сообщениях
Крутотень!
______________________ __
Регистрация: 04.02.2011 Последняя активность: 26.01.2022 12:36
Иех!
Да ну, попрограммировать "онлайн" отлично!
Шурик с шуриком
ужасть какой ма
как-нибудь заглючит и взорвется в руках |
Иех!
[Исправлено: abcom, 23.05.2013 в 19:46] |
