343040
960
51
Регистрация: 21.06.2010 Последняя активность: 13.03.2025 02:18
Сказал(а) спасибо: 21
Регистрация: 01.11.2010 Последняя активность: 06.07.2011 15:16
Новые фонари на диоде Philips SST-90:
Olight SR90 Intimidator Specifications Utilizes Luminus SST-90 LED, 30W, lifetime 60,000 hours. Output & Runtime: Two brightness levels and strobe mode High Mode: 2200 Lumens / 70Minutes Low Mode: 700 Lumens / 6 Hours Strobe: 2200 Lumens / 10 Hz / 150 Minutes Max throw: 1000 meters. Anti-shattering ultra clear lens, anti-scratching, anti-reflective coated lens with 99% effective transmission Excellent three-dimensional heat dissipation ability Advanced digital power management system Weatherproof: IPX-68 Water/Dust rating Battery pack: 6 x18650 (7.2v, 6.6A) Dimensions: Length:336mm (13.23”) Bezel Diameter: 100mm(3.94”) Weight: 1580g (With battery pack) Accessories: Includes one strap, one charger, one operator’s manual, one O-ring. Color: Black, Hard Anodized finish. Mil-spec: MIL-STD-810F Features Rechargeable integrated battery pack handle with 6x18650 lithium-ion batteries (7.2v, 6.6A). Rechargeable socket on the tail. The charger's input voltage is 100V-240V ~ 0.5A Four indicator lights on the tail for indicating the batteries condition: 1 indicator on: 20% -40% power remains 2 indicators on: 40% -60% power remains 3 indicators on: 60% -80% power remains 4 indicators on: 85%+ power remains No indicators means batteries with less than 20% power remains and need charging Olight SR91 Luminus SST-90 3-Mode 1500-Lumen Rechargeable LED Flashlight Features - Brand New Olight SR91 Luminus SST-90 3-Mode 1500-Lumen Rechargeable LED Flashlight - Compact and high quality portable design - Rechargeable battery pack with built-in 6x18650 batteries (7.2v, 6.6A). Rechargeable socket on the tail - Super bright, modern and novelty design. - Super Strong anti-Reflect coating lens,99% effective transmission - Four indicators on the tail for indicating the batteries condition: 1.1 indicators on: 20%-40% power remains 2.2 indicators on: 40%-60% power remains 3.3 indicators on: 60%-80% power remains 4.4 indicators on: 85%+ power remains 5. No indicators on means batteries with less than 20% power remains and need charging - Excellent tridimensional heat dissipation ability - Easy touching switch on the head for turning on/off the light and transfering modes - Special designed charger, Removable and adjustable strap. - Two charging methods: 1. with the whole torch, 2. Only the battery tube - Mil-spec: MIL-STD-810F - Highly water resistant to IPX-8 - Anti-shattering ultra clear lens, anti-scratching - Tough and rugged body offering firm grip - Advanced digital power management system TrustFire X6 5mode Luminus SST-90 Description: Color ark Gray Compact and portable design TrustFire X6 SST-90 Luminus LED Flashlight 5 modes: Hi (5000mA 2300LM) > Mid (3000mA 1200LM) > Low (1750mA 600LM) > Fast Strobe Come with original Holster Glass lens and aluminum smooth reflector cup Powered by 3x18650 batteries (not included) Durable Aluminum Alloy housing Constant current circuit, voltage range is 7.4~11V, 11V max ON/OFF power switch by pressing the end of the torch body Perfect fit for home maintenance, outdoor activities, hiking, night fishing, camping, caving, hunting etc TrustFire X6 Luminus SST-50 5-Mode 2300 Lumens LED Flashlight with Memory Specification: Lens diameter: 80.0mm Length: 355.0mm Weight (including the Rope): 925.0g Flydragon MS2010 Fei Long SST-90 MS2010 Features: · Manufactured from the finest aluminum with HAIII coating · Utilizes Luminus SST-90 LED, W65S-F11-GN100, Color temp 6500k · Output 1900-2100 lumens · Working voltage 6v-12v (Max 15v), Current 7A +/-10% · Output & Runtime: Max mode - 2100 Lumens / 70Minutes (18650 2400mAh x6) · Powered by 6x 18650 for full power. For backup, can run 6x AA in emergency · Adjustable brightness by rotatary switch with lock · Max throw: 1000 meters (Optional wide lens for short distance search) · Weatherproof for rainy day and outdoor heavy duty environment · Anti-shattering ultra clear lens, anti-scratching, anti-reflective coated lens with 99% effective transmission Excellent tridimensional heat dissipation ability · Size : Length 252mm, Diameter 60mm (Bezel) / 46mm (Tail) · Weight 580g [Исправлено: Lotos1961, 03.11.2010 в 01:59] |
Дорогие коллеги, предлагаю выписывать в эту тему все новые фонари, ну кроме очень уж дешевых китайчиков.Это может быть полезно как ветеранам, так и новичкам. Для начала предлагаю посмотреть на эту новинку http://www.sunwayman.com/ht...
[Исправлено: sasha6464, 29.06.2012 в 22:00] |
А-а-а-а-ааа!!! Где денег взять на всё?
![]() http://www.nitecore.com/pro...
sasha6464 (30.06.2012)
Есть виды на жену миллионера?
![]() Ну или банк с очень слабой охраной?
Желаю странного
Регистрация: 11.03.2011 Последняя активность: 18.09.2025 09:13
А у малиновой девочки взгляд откровенней, чем сталь клинка. Мои:Surefire C2 x2, M6LT, EB2T-A-TAN, U2, E2DL, L1, L2, Z2L, HS1-B-SL, G2X Pro x2, G2-YL, E1L, E1E-BK, E2E, M951, M952; FiveMega M4 z46, Leef P6T LF HO-M6R; Solarforce L2m, L2X, L4X x3; PeakLogan 17500/AA 219; StreamLight Sidewinder II; Fenix LD10; EagleTac G25C2, Olight smini cu; Convoy M1; YLP Panda2CRI, Enot500 x2, Swift |
Сказал(а) спасибо: 1055
Да, господа, отставать начинаем....
Регистрация: 25.08.2010 Последняя активность: 04.03.2019 20:02
Записей в дневнике: 2 Сказал(а) спасибо: 157
Я все засматриваюсь на санвеймен V11R. Яркость шурфаера М6 с его же рантаймом в 20 минут в супер компактном размере с плавной регулировкой яркости магнитным кольцом. Мега тусклый мунлайт. С другой стороны драйвер не шибко эффективный на слабых режимах и вообще очень странный драйвер. Был бы он без кнопки и покороче хотя бы миллиметров на 5... С другой стороны есть аналогичный джетбим у которого как раз кнопки нет, но дизайн похуже (не нравится мне этот стальной безель), зато мунлайт еще тускнее. Обзоров его не видел, но полагаю что драйвер там хуже чем в санвеймене, джетбим драйверы никогда делать не умел, да что там говорить, джетбим всегда во главу угла ставил внешний вид а технической грамотностью конструкции никогда не отличался. Чего стоят только первые рапторы с дырой прямо под светодиодом. Джет ни за что не куплю. Эх, нет в жизни совершенста...
Пару лет назад казалось что будущее за фонарями с программируемыми режимами, вроде предатора например, а сейчас вон китайцы доросли до магнитных колец с плавной регулировкой, и кому нужны теперь эти программируемые режимы?
Люменов много не бывает
Мега-забавный девайс
Да так, ностальгирую я, вспоминаются те времена когда я прочитал на ганзе про этот фонарь, он тогда мне казался безумно ярким, а теперь аналогичный по яркости фонарь в ладошке умещается и стоит сто баксов. В те времена не было не то что хмелей а даже мц-е и п7, XR-E Q5 был вершиной совершенства, и такие уровни яркости в компактном (по тем временам) фонаре казались чем-то нереальным. Сейчас-то конечно он уже ни при чем.
Желаю странного
А так..как вам идея лампового E2E на 1000 люмен(:? |
Регистрация: 08.01.2011 Последняя активность: 02.02.2017 21:53
Сказал(а) спасибо: 64
Поблагодарили: 247 раз(а) в 39 сообщениях
17
![]() Регистрация: 13.11.2010 Последняя активность: 05.01.2026 22:32
Записей в дневнике: 4 Сказал(а) спасибо: 1072
Да о чём вы?
Есть реальная потребность в long-throw EDC? C холодным светом? С крышкой на полтора витка резьбы? Без приёма 18350? С клипсой, прикрученной крестовой отвёрткой? Продолжу. Стальное безельное кольцо утоплено ниже алюминиевых зубцов. ![]() Цитата:
Комплектация поражает воображение ![]() Очередная поделка за 40 баксов, чему умиляться-то?
ויאמר אלהים יהי אור ויהי אור׃ [Исправлено: dsche, 30.06.2012 в 11:14] |
Регистрация: 25.11.2011 Последняя активность: 09.04.2025 16:51
Сказал(а) спасибо: 151
Поблагодарили: 121 раз(а) в 82 сообщениях
Приятным дизайном, интересной резьбой, двусторонней клипсой и кнопками как у микроволновки :-) Хороший фонарик получился.
Для своих сорока баксов нормальные фонари, без чудес
Забавно, что именно selfbuilt не вполне удовлетворился ) Цитата:
20
Народ!
Чот тема грозит свалиться в холивар или срач, она вроде начиналась как "про новинки". Кто, где, что увидел. А обсуждение качества изготовления и недостатки предлагается оставить до реальных (а не инженерных и тестовых) образцов.
LEV-UA (30.06.2012)
