21747 41 3 0 |
28.06.2012, 16:34 | 1 |
Zebralight sc31w миниобзор
Наконец пришла Зебра sc31w с офсайта (правда, пришли две, но в разных упаковках). Доставлена довольно оперативно, практически за две недели ( заказана 13.06, отправлена 15.06, получил на руки 26.06). Что могу сказать: влюбился с первого взгляда, она даже меньше, чем ожидал, и просто няшка-красавица.
Вот инфа с офсайта: Main Features and Specifications LED: Cree XP-G Neutral White (norminal CCT 4200 K) User Selectable Modes: 3 (High, Medium and Low). Each mode can be configured to one of the two sub-levels. Light Output High: H1 189 Lm (0.9 hrs) or H2 103 Lm (2 hrs) / 4Hz Strobe Medium: M1 37 Lm (12 hrs) or M2 21 Lm (23 hrs) Low: L1 4.3 Lm (3.7 days) or L2 0.4 Lm (21 days) Light output are out the front (OTF) values. Runtime tests are done using Panasonic CR123A lithium batteries. Runtimes are usually much shorter with rechargeable RCR123 (16340) batteries, especially with protected 16340s that have higher discharge cut off voltage. Battery: One CR123A lithium primary or RCR123 Li-ion rechargeable. Batteries are not included in the package. Battery Shelf Life: Over 3 years under parasitic drain Beam Type 80 degree spill beam spread 11 degree (3.8 feet at 20 feet) hot spot Dimensions Diameter: 0.85 inch (22 mm) Length: 2.60 inch (67 mm) Weight 1.1 oz (30.5 gram) with clip, without battery or headband Features Electronic soft-touch switch, with a 200,000 cycle operating life Smart user interface provides fast and easy access to all brightness levels Precision machined casing from premium grade Alcoa aluminum bar stock Durable natural hard anodized finish (Type III Class I) SCHOTT ultra clear lens with anti-reflection coatings on both sides Orange peel textured reflector Glow In The Dark (GITD) silicone ring near the tail cap Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain Waterproof to IPX8 (2 meters, 30 minutes) Комплектация стандартная: коробка, сам фонарь. инструкция, 2 запасных кольца, ремень налобного крепления. Анодирование однородное, цвет ближе к светло-серому с легким оливковым оттенком. На анодировании в районе задней крышки еле заметный скол (первое фото во втором ряду)в обоих фонарях(придираюсь), в остальном - идеал. Резьба треугольная, не сильно мелкая, изначально смазана и качественно анодирована, думаю, с герметичностью проблем не будет. Традиционно для зебр голова не разборная, возле плюсового контакта плата драйвера не защищена (осторожно с мокрыми руками при замене элемента).Пайка везде аккуратная, придраться не к чему, хвостовой колпачок внутри тоже сделан аккуратно, хвостовая пружина в меру тугая, передняя пружина тоже есть. Диод расположен идеально и традиционно для младших зебр без шайбы вокруг него (тоже придираюсь). Рефлектор текстурированный (апельсиновая корка), без сколов и пыли, стекло с антибликовым покрытием с двух сторон, царапин нет, пыли изнутри тоже нет. Клипса хромирована, немного туговата, прикручена винтами к хвосту (не к колпачку). В отличие от моей 50-й зебры, радиатор цельный (нет пробела под клипсой). С одной стороны, для теплоотвода хорошо, наверное, но для цепляния при помощи клипсы к карману не очень удобно, приходится оттягивать клипсу. иначе цепляются ребра радиатора. Кнопка чуть туже, чем у 50-й, нажимается легко и тактильно включение чувствуется ощутимее, чем у 50-й. По свету: Свет теплый, но без излишней желтизны. При сравнении с 50-й зеброй светит сильнее, хотспот четче и больше, боковая засветка такая же. При сравнении с Sunwayman M10R: хотспот сравним, боковая засветка намного шире. Дальность - чуть больше 100м, но разборчиво чуть поменьше. Ни в хотспоте, ни в засветке артефактов и пятен нет, все идеально и равномерно. Рантайм проверю позже. По режимам: тут почти все стандартно для зебр: Один клик (из выключенного фонаря) - высокая группа режимов Два клика (из выключенного фонаря) - средняя группа режимов Небольшое удержание из любого положения - малая группа режимов Длительное удержание из любого положения - перебор групп режимов. Переключение режимов внутри группы - двойной клик. Шестикратный двойной клик в высшей группе - строб и переключение (однократным нажатием) высоких режимов, кроме турбо. Вот здесь есть небольшая фишка: на офсайте указано, что в высшей группе находится турбо 189 люмен, строб 189 люмен и высокий режим 103 люмена, в действительности присутствует еще режим где-то люмен 70-80. Мелочь, а приятно. Цифры указывать не буду, они приведены выше с офсайта. Честно говоря, фонарь просто очаровал, просто тонет в руке, но держать удобно (выемка клипсы ложится на указательный палец и не дает соскользнуть, чему способствует и нескользкое покрытие), при таких габаритах светит просто волшебно. При желании можно вместо клипсы прикрутить кольцо, будет наключником. На налобном креплении (справа или слева) держится хорошо, регулировать можно и по горизонтали (поворотом на резинке), и по вертикали (просто перемещением вверх-вниз), но, конечно, лучше для этих целей походит именно налобник. Плюсы: Небольшой размер Высокое качество изготовления Удобство режимов Хорошо светит Хорошее анодирование Ест практически любые CR123 Очень удобен в руке Хороший теплоотвод, при этом нагревается не очень скоро и не очень сильно Минусы (небольшие и некритичные): Не очень удобно цеплять к карману нет защиты в районе плюсового контакта нет шайбы вокруг диода неразборная голова при экстриме нужно отворачивать хвост во избежание непроизвольного включения в кармане ДОПОЛНЕНИЕ: 5 июля повел тест на рантайм 31-й зебры ну и еще пару тестов: тест первый 31-я включена на максимум, стоит литиевый аккумулятор AW 750mAh. Так как тест проводится в помещении при жаре 32 градуса, на фонарь направлен вентилятор (страховка). Зебра проработала на максимуме 52 минуты 45секунд, после чего отключилась совсем, без всяких переходов. Итого мы имеем вполне честный рантайм, не дотянувший до заявленного 1 минуту 15 секунд. Под вентилятором зебра была совсем холодной, без вентилятора нагрелась за 10 минут примерно до 70 градусов, больше не пробовал. Остальные режимы, думаю, проверять нет смысла, да и времени нужно очень много. тест второй 31-я включена в режим 103 люмена и положена в карман. На улице все те же 32 градуса. После 45-50 минут катания в маршрутках зебра была извлечена из кармана. На ощупь нагрелась до градусов 65-70. тест третий 31-я включена на максимум, на улице 32 градуса, я нахожусь в тени. Нагрев почувствовал уже через две минуты, через 10 минут температура достигла где-то 50-ти градусов, после чего поднималась уже очень медленно и устаканилась примерно на 70-ти градусах и больше не поднималась. тест четвертый 31-я на максимуме, на улице 32 градуса, я в движении, нахожусь на солнце, есть небольшой ветерок. После нагрева примерно до 60 градусов температура устаканилась. В результате тестов утверждаю, что рантайм у зебры честный и максимальный режим не является турбо, а именно максимальным, и ограничений нет ни по времени, ни по нагреву (в разумных пределах, то есть не стоит ложить в карман включенный на максимуме фонарь.) Кстати, отвечаю на вопрос агента Смита по поводу нажимания кнопки в кармане: если Вы в экстриме, кнопка в камане нажмется стопудово, поэтому отворачивать хвост нужно (2-4мм хватит), если Вы просто ходите по улице и не носите в кармане с ней ключи, она не нажмется. Не думаю, что это критично. И по режимам: максимальный отличается от режима в 103 люмена не так уж и заметно, поэтому рекомендую использовать именно его. И рекомендую использовать литиевый аккумулятор AW, а не китайцы с дутыми амперчасами, тогда и рантайм будет честным. Только сейчас увидел то, чего раньше не замечал, не обращал внимания: рантайм на моих испытаниях ПРЕВЫШАЕТ заявленное зеброй время. Ведь на офсайте написано, что испытания проводились при помощи батареек панасоник, а не аккумуляторов, которые, как известно, имеют меньшую емкость, чем батареи. Так что зебра не преувеличила, а приуменьшила рантайм фонаря На фото: На бимшоте по порядку: Zebralight sc 31w (максимум 189 люмен), Sunwayman M10R (максимум), Zebralight sc50w (максимум 169 люмен), Zebralight sc600w (430 люмен), Fenix E15 (максимум 140 люмен) [Исправлено: sasha6464, 24.07.2012 в 16:01] Причина: добавление информации и правка ошибок |
Поблагодарили: 14 раз(а) |
72-patrona (30.07.2012), agent_smith (28.06.2012), blindnick (28.06.2012), bys7458 (21.08.2012), Enn (06.07.2012), GoBliNuke (06.07.2012), havoc (07.07.2012), Mihalich (28.06.2012), Qwertus (28.06.2012), rezhik (28.11.2012), Rocklight (24.07.2012), Romanko (28.06.2012), Voffka Sever (05.01.2013), ФанКол (30.09.2020)
28.06.2012, 17:21 | 2 |
Регистрация: 04.05.2012 Последняя активность: 30.06.2019 03:33
Сказал(а) спасибо: 256
Re: Zebralight sc31w миниобзор
Спасибо за обзор,фонарь понравился еще больше.
Тут как я понял,турбо режим временем не ограничен?Жду рантаймы. |
28.06.2012, 17:22 | 3 |
какие продуманные инженеры в зебре - чтоб пальцы не скользили по голове, когда кнопку нажимаешь, нарезали приятсвенные рёбра ))
трол. |
28.06.2012, 17:39 | 4 |
28.06.2012, 17:57 | 5 |
28.06.2012, 20:30 | 6 |
sasha6464, клипса к тушке отдельно идёт?
28.06.2012, 22:02 | 7 |
28.06.2012, 22:38 | 8 |
А вот это про запас что ли идёт?
28.06.2012, 22:52 | 9 |
Съемные клипсы у налобников, у той же Н31, например
29.06.2012, 01:49 | 10 |
Мне бы не хватило по мои личным ощущениям.Уж больно темная улица "крадет" люмены.Для помещений-да,сотка более чем.Если турбо у сабжа ограничивается 5 минутами и сильным нагревом,то фонарь наверное не для меня((
Хотя на официальном вроде не сказано,что есть какие то ограничения в турбо. [Исправлено: agent_smith, 29.06.2012 в 01:52] |
29.06.2012, 12:36 | 11 |
06.07.2012, 12:25 | 12 |
В первый пост добавлена инфа об небольшом тестировании 31-й зебры
[Исправлено: sasha6464, 06.07.2012 в 12:32] |
06.07.2012, 16:51 | 14 |
Регистрация: 22.11.2011 Последняя активность: 13.11.2020 16:01
Сказал(а) спасибо: 534
Поблагодарили: 247 раз(а) в 138 сообщениях
Глупый вопрос можно?
А аккум 18350 в нее никак не встанет? |
06.07.2012, 17:24 | 15 |
Сказал(а) спасибо: 1116
Поблагодарили: 1650 раз(а) в 958 сообщениях
ограничений как и в 51-ых там нет на турбо. Те же 200 люменов только более честные чем у холодной н51 за счет питания 3V
07.07.2012, 11:49 | 17 |
Добавил довольно интересный факт
07.07.2012, 15:55 | 18 |
07.07.2012, 16:06 | 19 |
Так тем более хорошо, что на аккумах получается так, как зеброй заявлено на батареях. Ура!
ps:сори за невнимательность. [Исправлено: sasha6464, 07.07.2012 в 16:09] |
09.07.2012, 13:05 | 20 |
