217738 822 2 0 |
05.01.2021, 08:54 | 821 |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02 Адрес: Shenzhen
Re: 3FVape - New products & Deals Update
SXK Four One Five 415 RTA Ultima Clone 22mm Rebuildable Tank Atomizer Original Price $25.9, Now Only $23.9.
SXK Four One Five 415 Clone RTA Ultima Rebuildable Tank Atomizer holds a 2.0ml e-juice capacity with top filling system in 22mm diameter. It is made of 316 Stainless Steel (body) and PCTG (Tank tube). It supports MTL / RDL air flow ring, bringing your excellent vaping experience. KF Kayfun Lite Plus RTA Clone 22mm Rebuildable Tank Atomizer w/ Spare PC Tank Tube Kit $14.66 KayFun KF Lite Plus Clone RTA Rebuildable Tank Atomizer holds a 4.0ml e-juice capacity with bottom filling system. Constructed from stainless steel, it features infinitely adjustable AEROKON airflow control Original Vapefly Optima Pod System 80W Pod System Vape Mod Kit Original Price $35.99, Now Only $26.99. Vapefly Optima Pod Mod Kit consists of a 80W Pod Mod and a 3.5ml Pod Cartridge. Original Steam Crave Aromamizer Titan V2 RDTA 41mm Rebuildable Dripping Tank Atomizer Original Price $79.99, Now Only $66.99. The Original Steam Crave Titan V2 RDTA Rebuildable Dripping Tank Atomizer is with Upgraded airflow and juice flow and Newest Postless deck for both parallel and series building. The Titan V2 RDTA holds 20ml / 32ml capacity with different glass tank tube. SXK Four One Five 415 RTA Ultima Clone Replacement Tank Tube Original Price $8.9, Now Only $6.5. This replacement tank tube holds 4.0ml e-juice capacity. It is made of PEI and especially designed for SXK Four One Five 415 Clone RTA Ultima Rebuildable Tank Atomizer. SXK Four One Five 415 RTA Ultima Clone Replacement Top Filling Cap Original Price $6.9, Now Only $5.5. This replacement top filling cap is made of 316 stainless steel, especially designed for SXK Four One Five 415 Clone RTA Ultima Rebuildable Tank Atomizer. Replacement PEI Tank Tube + MTL Drip Tip for KayFun KF Lite Plus 2021 RTA $4.31 The replacement top cap tank tube + drip tip are made of PEI material and are suitable for Kayfun KF Lite Plus 2021 RTA Rebuildable Tank Vape Atomizer. |
06.01.2021, 09:11 | 822 |
Original Innokin Sceptre 1400mAh Pod System Mod Vape Starter Kit $18.99
The Original Innokin Sceptre pod system vape starter kit is a 1400mAh built in battery device suited for new vapers looking for a small yet compact device. With two coils to choose from, a 1.2ohm for MTL Vaping and a 0.5ohm RDL Coil for high wattages, the Sceptre can easily identify between the two and automatically adjust your settings for the ultimate vaping experience. With an auto draw and button operation the Sceptre also features Boost Mode which can create more heat and vapor. Never Normal Whistle V2 510 Drip Tip + Button + Small Button Clone for dotMod dotAIO Pod $14.99 The Never Normal Whistle V2 Style 510 Drip Tip + Button + Small Button Set is made from PMMA and is suitable for dotMod dotAIO Pod System. Original Asvape Hita 30W Kit / Hita Ink Kit Replacement Mesh Coil Head $9.99 The Original Asvape Hita Replacement Mesh Coil Head is especially designed for Asvape Hita Hita 30W Kit / Hita Ink Kit / Pod Cartridge. It features 1.2ohm coil resistance. 5 PCS / PACK Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement 510 Drip Tip $9.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement 510 Drip Tip is made of PEI, suitable for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Air Intake Pins - 1.4mm $5.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement air intake pins is made of 316 Stainless Steel and KFM in 1.4mm diameter, bringing you to reach ideal draw experience. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. 2 PCS / PACK Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Air Intake Pins - 1.6mm $5.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement air intake pins is made of 316 Stainless Steel and KFM in 1.6mm diameter, bringing you to reach ideal draw experience. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. 2 PCS / PACK Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Black 4.0mL $7.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of PC. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - Black 2.0mL $7.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of PC. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - PEI, 4.0ml $10.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 4.0ml e-juice capacity, made of PEI. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer. Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Replacement Tank Tube - PEI, 2.0ml $10.99 The Original Ambition Mods and The Vaping Gentlemen Club Bishop replacement tank tube holds 2.0ml e-juice capacity, made of PEI. It is especially designed for Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Vape Atomizer |
