Просмотров в теме 48373   Ответов в теме 83   Подписчиков на тему 9   Добавили в закладки 1
Старый 16.10.2011, 04:38 Автор темы   1
Аватар для selfbuilt
Последняя активность: 10.11.2015 10:40
Wink2 Xeno G42 XM-L (1x18650/2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO and more!
Warning: pic heavy, as usual.
The new G42 XM-L is the latest high-output "thrower" light from Xeno. Having earned a lot of kudos for their 1xAA E03 offering, how does this higher-end light compare? Let's find out …
Manufacturer's Specifications:
  • LED: Cree XM-L @ 2A (High)
  • LED Options*]1) XM-L 1B U2 Cool White 5000-8300K, Max Output 605 lumens
  • 2) XM-L 4C T5 Neutral White 3700-5000K, Max Output 535 lumens
  • 3) XM-L 7B T4 Warm White 2600-3700K, Max Output 510 lumens
  • Mil-spec Type III Hard-Anodized Gun Gray
  • Large, deep highly polished aluminum reflector
  • Powered by 1×18650, 1×17670 or 2x CR123 (no RCR123/16340)
  • Linear LED driver, No PWM
  • 3-Stage driver: High, Medium, Low
  • Double Gold plated springs (Shock proof)
  • Tactical Forward clicky switch with silver plated contacts
  • Brass LED heatsink / driver housing
  • Built in pocket / bag clip
  • Multiple Lanyard attachment options
  • Size: 6.3″ (160mm) 1.8″ (46.5mm bezel)
  • Weight: 9oz (256g, w/o battery)
  • Crush test: Survived being driven over by a 1.7 Ton SUV
  • Waterproof test: Survived 10M pressure test
  • Anti-roll design
  • This light can tail stand
  • Glow ring around the reflector and lens
  • Silicon rubber glow clicky switch boot
  • Includes: Xeno Lanyard made from 550 paracord, Nylon Wrist lanyard, Spare rubber O-rings, Spare forward clicky switch, Packed in a Gift box
  • MSRP: ~$93
Packaging is fairly basic (I wouldn't really call this a gift box ), but the number of accessories are reasonable. Along with light (with lanyard ring and sturdy clip attached), you get an extended-length paracord lanyard, simple nylon lanyard, extra o-rings, extra switch and manual.
From left to right: Redilast Protected 18650; Xeno G42, Thrunite Scorpion V2 Turbo; Lumintop TD15X, P16X; 4Sevens X7; ArmyTek Predator
All dimensions are given with no batteries installed:
Xeno G42: Weight: 224.3g, Length 161mm, Width (bezel) 46.6mm
4Sevens X7: Weight 146.9g, Length: 151.5mm, Width (bezel): 38.7mm
Scorpion V2 with Turbo Head: Weight: 188.3g, Length: 171mm, Width: 41.0 (bezel), 37.0mm (tailcap grip ring)
TD-15X: Weight 150.3g (no batteries), Length 147.3mm, Width: 37.8mm (bezel)
The overall weight and dimensions of the G42 are typically slightly larger than most "thrower" class XM-L lights. I would expect above-average throw, given the size of the reflector.
The G42 has a very distinctive design, with a more rakish appearance than most lights.
Let start with overall build – the G42 has a lot of raised concentric rings around the body of the light (presumably to help with grip). There is a built-in clip that seems quite sturdy and high quality. It is apparently removable, but you have to completely disassemble the light to do it (i.e. remove the pill, etc.), which is not recommended.
Light has excellent quality anodizing, in a dark grey finish that is very reminiscent of recent Sunwayman and JetBeam lights. There are two bands of knurling, one around the bezel and one around the tailcap. Both are fairly aggressive. I would say that grip is definitely good with this light!
Light features stainless steel bezel and tailcap rings (flat on the bezel, scalloped on the tailcap).
Some distinctive features for lanyard attachment:
The G42 has a LOT of places to attach a lanyard, both on the removable ring, and built-in to the body/tailcap housing.
The G42 also has a lot of labels, although most of these are fairly inconspicuous, as you can see above.
Fairly traditional tailcap switch (forward clicky), in a solid tailcap end piece. Note the square-cut screw threads, fully anodized for tailcap lock-out.
There is also a spring in the head, allowing you to use the newer high-capacity flat-top 18650 cells. All my flat-top 18650 cells worked fine in the light.
User Interface
The G42 uses a forward tailcap clicky - press and release for momentary on, click for locked on.
Mode switching is controlled by rapidly flashing the tailcap when the light if off. Sequence is Hi - Med – Lo, in repeating sequence. Just press further for locked-on activation once you find the mode you want.
For a more detailed examination of the build and user interface, please see my video overview:
Video was recorded in 480p, but YouTube defaults to 360p. Once the video is running, you can click on the 360p icon in the lower right-hand corner, and select the higher 480p option, or even run full-screen.
No PWM/Strobe
There is no sign of PWM that I can see, at any output level. Either they are using a frequency that is too high for me to detect, or the light is actually current-controlled as claimed.
There are no strobe/SOS modes on the G42.
Beamshots:
The new G42 uses a Cree XM-L emitter, well centered on my sample. My sample came with the Cool White version of the XM-L, but Neutral White and Warm White are also available. Reflector is smooth and deep, likely to produce good throw.
And now the white-wall beamshots. All lights are on max output, on 1x18650. Lights are about ~0.75 meter from a white wall (with the camera ~1.25 meters back from the wall). Automatic white balance on the camera, to minimize tint differences.
The G42 definitely has good throw for this class light, as expected for such a large and deep reflector. There is a definite wide corona around the hotspot, which shows some minor tint-shifting.
Outdoor beamshots will be coming soon … check back for updates.
Testing Method:
All my output numbers are relative for my home-made light box setup, a la Quickbeam's flashlightreviews.com method. You can directly compare all my relative output values from different reviews - i.e. an output value of "10" in one graph is the same as "10" in another. All runtimes are done under a cooling fan, except for any extended run Lo/Min modes (i.e. >12 hours) which are done without cooling.
I have recently devised a method for converting my lightbox relative output values (ROV) to estimated Lumens. See my How to convert Selfbuilt's Lighbox values to Lumens thread for more info.
Throw/Output Summary Chart:
Effective November 2010, I have revised my summary tables to match with the current ANSI FL-1 standard for flashlight testing. Please see http://www.sliderule.ca/FL1... for a description of the terms used in these tables.
Even though the G42 is not driven as hard as some of my other recent XM-L lights, throw on 1x18650 is top-of-the-class. It even manages to slightly out-throw the Thrunite Scorpion V2 Turbo (although the difference is negligible).
Note that Xeno doesn't report ANSI FL-1 values, but their OTF estimate for this emitter (605 lumens) is not too far off from my initial activation estimate of ~560 lumens.
Output/Runtime Comparison:
The G42 is fully regulated on both 1x18650 and 2xCR123A (note 2xRCR not supported, which may have something to do with it). Runtime is reasonable, and consistent with Xeno reported specs on a 2600mAh battery.
Potential Issues
Light is larger and heavier than most in this class, with a lot more ridge detail and grip elements than typical.
2xRCR (16340) Li-ion is not supported.
No holster is supplied.
Preliminary Observations
The G42 is an impressive-looking light – I don't think I've seen anything with quite this must ridge detail and extra styling.
Build is substantial and high quality, with a lot of nice touches. You can see careful attention to detail has gone into the light, although I do consider it a bit over-built on some of the design elements (i.e. there are a lot ridges, rings and lanyard attachment points). While external styling is in the eye of the beholder, there is no doubt that this is a solid light – the significant mass suggests excellent heatsinking, and grip is obviously good.
Aside from the build elements, the really distinctive feature of the light is the reflector – it has the best throwing beam I've seen for an 18650-class XM-L-based light. One feature of Xeno I really like is the availability of multiple tint bins (in this case Cool White U2, but Neutral White T5 and Warm White T4 are also available).
Max output is quite reasonable for the class, and runtime performance (fully-regulated pattern) is perfectly acceptable. Interface is straight-forward and easy to use. Mode spacing makes sense to me, with a fairly bright Med mode (i.e., really a battery-saving Med-Hi mode), and a relatively low Lo mode for extremely long-lasting runtime. There are no blinky SOS/strobe modes with the G42.
There are certainly smaller, more floody-style, 18650-based XM-L lights out there. But if you are in the market for throw, the G42 certainly warrants your consideration.
Xeno G42 provided by TacticalHID.com for review.
selfbuilt вне форума   Ответить с цитированием Вверх
harman (16.10.2011), npomokoji (21.11.2011), путч (09.02.2013)
Старый 16.10.2011, 05:14   2
Последняя активность: 31.10.2025 21:49
Сказал(а) спасибо: 719
Поблагодарили: 2341 раз(а) в 1348 сообщениях
По умолчанию Re: Xeno G42 XM-L (1x18650/2xCR123A) Review: RUNTIMES, BEAMSHOTS, VIDEO and more!
Симпатичный фонарик, и я так понимаю что у XENO свой вариант в конструкции, корпус и башка - одно целое, интересное решение.
Старый 16.10.2011, 09:58   3
harman
Последняя активность: 17.02.2021 16:24
Сказал(а) спасибо: 91
Поблагодарили: 37 раз(а) в 16 сообщениях
Судя по графикам, полная стабилизация от 18650 - это радует. Очень интересный фонарь. Спасибо за обзор.
harman вне форума   Ответить с цитированием Вверх
Старый 16.10.2011, 10:04   4
John Jack
Аватар для John Jack
Записей в дневнике: 18
Сказал(а) спасибо: 1790
Корпус и голова явно раздельны. Иначе как они клипсу ставили? Но голова впечатляет, массивная и ребристая.
Драйвер линейный, корпус хорош, тёплая версия есть, дальнобойность впечатляет. Буду хотеть, мне как раз такого не хватало.
Спасибо за обзор!
Старый 16.10.2011, 16:55   5
bag
офонаревший
Аватар для bag
Последняя активность: 18.06.2023 12:24
Сказал(а) спасибо: 6
Поблагодарили: 29 раз(а) в 18 сообщениях
Да. Внимательнный осмотр показывает, что голова и тело соединяются на уровне клипсы. Но руками мне эту часть раскрутить не удалось (да и в инструкции ни слова, про разделение в этом месте). А зажимать в тисках и крутить ключем пока фонарь не оброс естественными подряпинами, жаба не позволяет.
Кстати примерно 1/3 длинннннны - это рефлектор. Диод стоит примерно посередине между местом крепления клипсы и толстым ребром (с дырочкой).
Инструментально яркость не мерял (не чем), но на глаз фонарик слегка дальнобойней чем мой TR-1200 HA-III 5*Cree Q5-WC, хотя общее количество света меньше (у меня neutral white).
От свежезаряженной 18650 потребляет
Hi: 2A (ровно)
Mid: 1A (ровно)
Lo: 30-40mA (так как включается с максимума мерял на пределе 10A, и точность на малом токе низкая).
[Исправлено: bag, 16.10.2011 в 17:14]
bag вне форума   Ответить с цитированием Вверх
Старый 16.10.2011, 21:02   6
Form
Аватар для Form
Последняя активность: 19.01.2018 09:10
Сказал(а) спасибо: 216
Поблагодарили: 70 раз(а) в 38 сообщениях
Спасибо, обзор великолепный, как всегда. Фонарю не хватает режима на 70-80 люмен, этакого low-mid.
Form вне форума   Ответить с цитированием Вверх
Старый 17.10.2011, 00:07   7
John Jack
Опять насчёт тёплой версии. На сайте производителя эта версия есть, с фотографиями и описанием. Но в продаже её нет, ни на tacticalhid, ни на hkequipment. Где её искать или когда ждать?
Старый 17.10.2011, 00:46   8
bag
офонаревший
Аватар для bag
Я свои XENы (нейтральный G42 и теплый E03) брал у dlm-led.com, именно в тех оттенках как и хотел. Цена на теплый у них написана (есть-ли теплый G42 в наличии - не интересовался). С доставкой для меня вообще было все замечательно: вечеромднем деньги, утром стульяфонари
Посмотреть сообщение Сообщение от Form :
Это да. На глаз средний и максимальный не сильно отличаются, а если не знаешь какой включен - то по яркости не всегда угадаешь без переключения туда-сюда. Зато слабый правильный - им можно светить вплотную на что-то и не щуриться (хотя конечно для дальнобоя это не самое важное применение).
Старый 19.10.2011, 21:39   9
Mitt
Аватар для Mitt
Последняя активность: 06.05.2022 18:25
Сказал(а) спасибо: 10
Поблагодарили: 10 раз(а) в 3 сообщениях
Посмотреть сообщение Сообщение от bag :
Не,в тиски не надо.У меня Xeno G5,как я понимаю конструкция у них одинаковая с G42, и для разборки надо открутив безель, вывернуть Т-образный диодный модуль,который своими закраинами и прижимает голову,а уже потом откручивать саму голову.
[Исправлено: Mitt, 19.10.2011 в 21:46]
Mitt вне форума   Ответить с цитированием Вверх
Старый 03.11.2011, 23:18   10
John Jack
Тёплая версия появилась на hkequipment.net, за те же 95$.
http://www.hkequipment.net/...
Старый 21.11.2011, 04:53   11
npomokoji
Аватар для npomokoji
Последняя активность: 12.03.2023 10:25
Сказал(а) спасибо: 13
Отправить сообщение для npomokoji с помощью ICQ Отправить сообщение для npomokoji с помощью Skype™
интересный фонарик
В планах сфокусировать солнце
npomokoji вне форума   Ответить с цитированием Вверх
Старый 06.12.2011, 04:34   12
bag
офонаревший
Аватар для bag
Сравнительные картинки G42 и TR-1200
Расстояние (по спутниковым фоткам) до домов: слева 100m, по-центру-вдали 200m, справа 60m
Старый 08.12.2011, 15:12   13
npomokoji
А я к F42 присматриваюсь, т.к. он подешевле, а формфактор без клипсы мне больше нравится. Вот думаю тёплый прикупить и заообзорить
Старый 08.12.2011, 16:22   14
bag
офонаревший
Аватар для bag
Посмотреть сообщение Сообщение от npomokoji :
Я тоже думал над теплым, но решил, что дальнобою это не нужно. Ну и теплый XM-L E03 (в плане цвета) меня не впечатлил. Пока самый лучший теплый, у меня в quark warm white. Вот тут три разных XML-я (E03, G42, RRT0) и quark (XP-G).
А G42 и F42 вроде с одинаковым рефлектором, но разными диодами/режимами
XENO G42 V2:
измеренный максимальный световой поток (диод CREE XM-L 1B U2): 605 люмен
длительность свечения без подзарядки (батарея 186500 li-ion 2600 mAh): 605 люмен - 1,1 часа / 330 люмен - 2,5 часа / 60 люмен - 100 часов
XENO F42 V2
измеренный максимальный световой поток (диод CREE XM-L 1B T6): 560 люмен
длительность свечения без подзарядки (батарея 186500 li-ion 2600 mAh): 560 люмен - 1 час / 214 люмен - 4 часа / 45 люмен - 100 часов
Хотя 560/605 визуально. наверное. не различимы.
Старый 22.01.2012, 22:06   15
Alex4479666
Не ветеран фонарёвки
Аватар для Alex4479666
Сказал(а) спасибо: 3306
А какой максимальный размер аккумов 18650 подходит для XENO G42 V2 ?? А то вот собрался его покупать, а аккумы у меня всякие разнофаеры. Вот такие подойдут? http://www.ebay.com/itm/2X-...
Длина 69.78mm, диаметр 18.5mm
Старый 23.01.2012, 00:36   16
bag
офонаревший
Аватар для bag
Внутренний диаметр трубки с батарейкой - 19mm. Мой Soshine Li-ion 18650 Protected Battery: 2800mAh имеет заметные зазоры по бокам. Про длиннннннну сказать сложней, но моему soshine можно добавить еще 3 магнитика (по 1mm) общей длиной 3mm. То есть ваши:
Должны поместиться, хотя возможно и на пределе.
Alex4479666 (25.01.2012)
Старый 23.01.2012, 14:52   17
Alex4479666
Кстати как вам этот аккумулятор? Просто думаю лучше его наверно заказать, он хоть точно подходит.
Старый 31.01.2012, 12:01   18
Alex89105
Последняя активность: 06.09.2012 15:36
Цитата: Сообщение от bag Soshine Li-ion 18650 Protected Battery: 2800mAh Кстати как вам этот аккумулятор? Просто думаю лучше его наверно заказать, он хоть точно подходит.
Я себе заказал Redilast 3100 http://redilast.com/index.p...
В отличие от Soshine у меня заряжается на 2 часа дольше...
Alex89105 вне форума   Ответить с цитированием Вверх
Старый 04.07.2012, 05:42   19
Нерв
Параноик
Аватар для Нерв
Последняя активность: 21.05.2019 22:19
Сказал(а) спасибо: 117
Поблагодарили: 33 раз(а) в 27 сообщениях
Ох, как мени ломает. Хочу что-нибудь, но чтоб красиво с головой от него. Вот причина. Смотреть с 7-ой минуты Скажите, это можно вылечить Xeno-й?
Что меня не устраивает в Xeno? - Нет экономичного режима, как в EagleTac G25C2 , и его же удобного переключения.
Что меня не устраивает в EagleTac G25C2 ? - Мятый рефлектор.
Налобное: Petzl MYO XP, Fenix HP10, Spark ST5-150CW
Подствольно-походное: Armytek Predator v.2 R4 5/24, Xeno F42 v.2, Fenix LD41, Fenix LD40
Наключник: Quark Mini ML
Нестандарт: хозбыт ФПС-4/6C(акб Дельта сдох), ЭРА КА16М(+з/у 4.2В), свечи 100штх3
[Исправлено: Нерв, 04.07.2012 в 05:46]
Нерв вне форума   Ответить с цитированием Вверх
Старый 05.07.2012, 01:43   20
Нерв
Параноик
Аватар для Нерв
Кто уже приобрёл, подскажите пожалуйста размеры средней части, та что между воображаемым грип-упором и головой. Длину и диаметр. Надо с креплениями не промахнуться.
Это там пружина на головном контакте?
Усилие хорошее?
Время генерации страницы 0.18055 секунды с 15 запросами
