Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original VO Tech VIA 240W TC VW Variable Wattage Box Mod Original Price $78.99, Now Only $68.99
The Original VO Tech VIA Box Mod is a power beast which can fire up to 240W with dual 18650 batteries (NOT INCLUDED). It supports Power, Bypass and Temp mode, and in TC mode, Ni, Ti and SS316 Coil are supported. The resistance range is from 0.1 to 2.0ohm. This item also has other colors to choose. ![]() Original Avidvape Throne 200W TC VW Variable Wattage Squonk Box Mod Original Price $74.99, Now Only $43.99 The Original Avidvape Throne Squonker Mod is a new innovation of squonker mod. Smaller size and brilliant looking bring wonderful feeling when you handle it. Maximum wattage can be up to 200W with dual 18650 batteries (NOT INCLUDED). Using 0.96 inch display, the Throne supports 3 operating modes except Power mode, which are VPC mode, Temperature Control mode and Bypass mode. The resistance range is from 0.05 to 3.0ohm. This item also has other colors to choose. ![]() Original Avidvape Ghost Inhale 200W TC VW Variable Wattage Box Mod Original Price $65.99, Now Only $42.29 TheOriginal Avidvape Ghost Inhale Box Mod is a versatile regulated mod that can fire up to 200W with dual 18650 batteries (NOT INCLUDED). Using 0.96 inch display, the Throne supports 3 operating modes except Power mode, which are VPC mode, Temperature Control mode and Bypass mode. The resistance range is from 0.05 to 3.0ohm. This item also has other colors to choose. ![]() Original Avidvape Ghost Inhale RDA Rebuildable Dripping Atomizer with BF Pin Original Price $32.99, Now Only $23.99 The Original Avidvape Ghost Inhale RDA is a new innovation RDA. It comes with 2 screw holes upside and a fixed screw clamp post below, avoiding coils broken efficiently as well as fixed the coils while you screw your coils into the holes. Airflow comes from the adjustable upswept bottom airflow hole and 2 sides airflow hole, which enlarge the flavor and provide cloud chasing experience. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Reload X RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $9.99, Now Only $6.99 The Reload X RDA Clone is a 24mm RDA constructed from stainless steel. It features a quad terminal postless deck designed for dual coil configurations and dual adjustable top-down bottom airflow system that minimizes leakage while providing intense flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() VG M5 MTL RTA Rebuildable Tank Atomizer Clone $20.99 The VG M5 MTL RTA Clone is a 23mm diameter rebuildable tank atomizer, made from 316 stainless steel (deck and top cap) and PEI (tank). It comes with small inner diameter drip tip for the best MTL draft. It has dual posts design for easy single coil building. What's more, it features 5ml capacity that can meet your daily vaping need, and the top fill system makes refilling e-juice quickly and simply. ![]() Doomsday Mechanical Mod Clone + Axis GE RDA Kit Clone $24.89 The Doomsday Mech Kit Clone consists of Doomsday Mechanical Mod Clone and Axis GE RDA Clone. This item also has other colors to choose. Mod: The Doomsday Mechanical Mod Clone features well machined Delrin body with Ultem fire button and brass battery tube. It is a full mechanic parallel mod with magnetic switch. The mod is powered by dual 18650 batteries (NOT INCLUDED). RDA: The Axis GE RDA Clone is a 24mm RDA constructed from stainless steel. It features a unique T post build deck for dual coil builds. The side and bottom airflow will bring optimal flavor. Ultem wide bore drip tip is included. ![]() Original TRX TRXTERS Mechanical Mod Kit Original Price $74.00, Now Only $63.99 The Original TRX TRXTERS Mechanical Mod Kit, designed by World Champion Tricksters, is a competition mech kit with attractive appearance. The mod features side venting holes for battery safe, and side fire button at bottom, which is ergonomically designed for playing tricks. The RDA comes with wide side airflow, bringing great cloud-chasing experience. The mod is powered by single 18650 battery (not included). This item also has other colors to choose. ![]() Original Serisvape Cavalry V2 Mechanical Mod + RDA Kit Original Price $49.90, Now Only $40.99 The Original Serisvape Cavalry V2 Mod Kit consists of Serisvape Cavalry V2 mech mod and Serisvape Cavalry V2 RDA. This item also has other colors to choose. Mod: The Serisvape Cavalry V2 Mod is a 28mm mech mod that features No-thread designed connection, which reduces the resistance and makes the mod more convenient for users. The button can be locked to prevent mis-firing. Powered by single 18650 battery (NOT INCLUDED), this mod will bring you nice vaping experience. RDA: The Serisvape Cavalry V2 RDA is constructed from brass (top cap) and stainless steel (base). It has slick deck and post, which is suitable for single coil builds. The adjustable slant airflow and dome top cap provide concentrated flavor. The silver plated contact pin provides great conductivity. Bottom feeder pin is included. ![]() Original Avidvape Throne 200W TC VW Variable Wattage Squonk Box Mod + RDA Kit Original Price $85.99, Now Only $51.19 The Original Avidvape Throne Squonker Kit consists of Avidvape Throne Squonker Mod and Throne RDA. This item also has other colors to choose. Mod: The Original Avidvape Throne Squonker Mod is a new innovation of squonker mod. Smaller size and brilliant looking bring wonderful feeling when you handle it. Maximum wattage can be up to 200W with dual 18650 batteries (NOT INCLUDED). Using 0.96 inch display, the Throne supports 3 operating modes except Power mode, which are VPC mode, Temperature Control mode and Bypass mode. The resistance range is from 0.05 to 3.0ohm. RDA: The Original Avidvape Throne RDA is a 24mm RDA constructed from stainless steel. It has a triple post build deck for dual coil builds. The top cap can be rotated to adjust the side airflow. 810 ultem drip tip is included. This RDA comes with bottom feeder pin. ![]() Original Vapesoon Replacement Bubble Tank Tube for SMOK TFV12 Prince Tank $1.99 The replacement bubble glass tank is suitable for Original SMOK TFV12 Prince Tank. It has 8ml of juice capacity. This item also has other Version to choose. ![]() |
GLM EVO Hybrid Mechanical Mod Clone $14.99
The GLM EVO Mechanical Mod Clone is a 24mm mech mod with hybrid top cap for more power hit. It is constructed from copper. The fire button is activated by spring. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Ulton Mecanic Hybrid Mechanical Mod Clone $24.90 The Ulton Mecanic Mechanical Mod Clone is a 25mm mech mod with hybrid top cap for more power hit. It is constructed from 316 stainless steel. It features 4 point contact system and soft pressure point for comfortable activation. The recessed button can reduce risk of auto firing. The mod is powered by single 18650 / 20650 / 20700 / 21700 battery (NOT INCLUDED). ![]() Original Steam Crave Titan PWM VV Variable Voltage Box Mod $53.99 The Original Steam Crave Titan PWM Mod is a quad 18650 variable voltage box mod. Powered by quad 18650 batteries (NOT INCLUDED) in parallel / series, this mod can provide maximum output to 300W, which is very powerful. By Rotating the fire button you can adjust the voltage, and it comes with lock function. Besides, the mod has multiple protections to give you a safe vaping experience. The atomizer is for reference only, NOT INCLUDED. ![]() Original Nikola Niagara 200W VW Variable Wattage Squonk Box Mod Original Price $69.90, Now Only $49.99 The Original Nikola Niagara Squonk Box Mod is a high end regulated squonk device that features 200W maximum output with dual 18650 batteries (NOT INCLUDED). The mod comes with various modes for your options. The resistance range is from 0.1 to 3ohm. The silicone bottle has 6ml of juice capacity. This item also has other colors to choose. ![]() Original UltimaVape Banaspati Hybrid Mechanical Mod Original Price $105.00, Now Only $85.00 The Original UltimaVape Banaspati Mechanical Mod is a 26mm hard-hitting competition mod. It is made from full copper material and sterling silver contact. Powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), the Banaspati Mod will provide aggressive power hit to meet your cloud-chasing need. The hybrid top cap can be adjusted to fit different size battery. The Cluch style button, which is neither spring nor magnet, gives you great feedback when pressing. This item also has other colors to choose. ![]() Original GAS Mods ***** S RDA Rebuildable Dripping Atomizer $35.99 The Original GAS Mods ***** S RDA is the newest rebuildable atomzier from GAS Mods. [img]http://www.3fvape.com/212103-home_default/authentic-gas-mods-*****-s-rda-rebuildable-dripping-atomizer-black-stainless-steel.jpg[/img] Original Phevanda Bell MTL RDA Rebuildable Dripping Atomizer with BF Pin $35.99 The Original Phevanda Bell RDA is a new innovation of MTL RDA from Phevanda Vape. It comes with a single coil build deck, well-designed top cap and adjustable top airflow. It is also compatible with squonk mods. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() SOB RDTA Rebuildable Dripping Tank Atomizer Clone $7.89 The SOB RDTA Clone is a 25mm rebuildable tank that is constructed from stainless steel and Ultem. The build deck is classic Velocity style dual post design, supporting dual coil builds. The side airflow is adjustable. The PEI tank can hole about 2ml of juice. PEI drip tip is included. ![]() Ulton Raven V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $13.90 The Ulton Raven V2 RDA Clone is a 22mm BF RDA constructed from 316 stainless steel. It features simple but wide dual post build deck and adjustable top airflow, which can reduce the leakage. Wide bore Delrin drip tip is included. This RDA comes with bottom feeder pin. ![]() Original Steam Crave Glaz RDSA Rebuildable Dripping Squonking Atomizer with BF Pin $27.99 The Original Steam Crave Glaz RDSA is a rebuildable dripping / squonking atomizer with 30mm diameter size. The Modular style deck is designed for postless and series. The RDA comes with a glass top cap for flavorful and warm vaping. With the bottom angled airflow, airflow travels to coil for maximum flavor production. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Steam Crave Glaz RTA Rebuildable Tank Atomizer $35.59 The Original Steam Crave Glaz RTA is a 31mm super huge rebuildable tank with 7ml of juice capacity. Using unique glass chamber / chimney section, the tank features brand new postless build deck and special bottom angled airflow design. The Semi restrictive airflow is for ultimate flavor chasing experience. This item also has other colors to choose. ![]() Original Steam Crave Replacement Glass Tank Tube for Glaz RDSA $6.99 The replacement glass tank tube is suitable for Steam Crave Glaz RDSA. This product comes with 2 PCS in 1 pack. ![]() Original Steam Crave Replacement Glass Tank Tube for Glaz RTA $4.99 The replacement glass tank tube is suitable for Steam Crave Glaz RTA. This product comes with 2 PCS in 1 pack. ![]() Original Steam Crave Replacement Glass Chamber for Glaz RTA $5.99 The replacement glass chamber is suitable for Steam Crave Glaz RTA. This product comes with 2 PCS in 1 pack. ![]() Original Steam Crave Replacement Deck for Glaz RTA $10.99 The replacement deck is suitable for Steam Crave Glaz RTA. ![]() |
Kindbright Machete Mechanical Mod Clone $38.99
The Kindbright Machete Mechanical Mod Clone is constructed from stainless steel. It features full engraved body, which is aesthetic and eye-catching. Powered by single 18650 battery (NOT INCLUDED), it will provide you great cloud-chasing experience. The mod will be shipped with random engraving. This item also has other colors to choose. ![]() Original Famovape Yup RDA Rebuildable Dripping Atomizer with BF Pin $28.99 The Original Famovape Yup BF RDA is the first 24mm RDA that features Y-shaped build deck. The unique Y deck design with quad gold plated posts makes coil building really easy. Comes with adjustable side airflow, this RDA will bring pure flavor and massive clouds. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Willie Vapor COO TS RDA Rebuildable Dripping Atomzier Original Price $14.99, Now Only $7.99 The Original Willie Vapor COO TS RDA is a 30mm RDA that comes with Velocity style build deck for dual coil builds and adjustable 9-airhole side airflow system. It comes with another cap (included) with 3-airslot design. The juice well is 6mm deep. POM and stainless steel drip tips are included. This item also has other colors to choose. ![]() Original Vaptio Capt'n 220W TC VW Variable Wattage Box Mod + Tank Kit $58.79 The Original Vaptio Capt'n Kit consists for Vaptio Capt'n Mod and Vaptio Capt'n Tank. This item also has other colors to choose. Mod: The Original Vaptio Capt'n Mod has a zinc-alloy frame and IML panel body. The design never wears off and the colors stay vibrant. Powered by dual 18650 batteries (NOT INCLUDED), the mod can reach maximum output to 220W. Fire it up to the maximum throttle in only 0.005 seconds. Go as low as 0.1ohm resistance in bypass mode. It has 6 intelligent output modes, you can enjoy customizable modes and smart modes to enhance your high watt vaping experience. Tank: The Capt'n tank is a 24.5mm tank that improves the Frogman coil technology by adding a larger area for airflow. It has larger 4ml tank capacity. Newly patented anti-leak design products your mod circuitry from the rare occasional times your tank may leak. ![]() Original Innokin Kroma-A 75W 2000mAh TC VW Variable Wattage Box Mod + Zenith Tank Kit $68.99 The Innokin Kroma-A Kit consists of Innokin Kroma-A Mod and Zenith Tank. This item also has other colors to choose. Mod: The Innokin Kroma-A Mod has a built-in 2000mAh battery to provide maximum output to 75W. It also support temperature control with SS316, ni200 and Ti coils. With precise output, the Innokin Kroma-A Mod will provide you the best of MTL and DTL vaping experience. Tank: The Zenith Tank is a 4ml tank with convenient top fill twist design without leaking and adjustable bottom airflow control. It supports 0.8ohm Kanthal coil (15~18W), and 1.6ohm Kanthal coil (10~14W). ![]() Spider Man 510 Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer Clone $3.59 The replacement 510 drip tip is made from resin (mouthpiece), stainless steel (base) and silicone (cover). It is suitable for all atomizers that fit 510 drip tip. It comes with silicone cover to protect the mouthpiece from dust. This item also has other Version to choose. ![]() YFTK Replacement 510 Drip Tip + Top Cap Kit for Haku Venna RDA $7.99 The replacement 510 drip tip and top cap is made from PC and is suitable for YFTK Haku Venna RDA. ![]() |
Original Justfog Q16 J-Easy 9 900mAh Battery Mod $19.99
The Original Justfog Q16 J-Easy 9 Battery Mod is a convenient device with built-in 900mAh battery and 510 threading connection. The battery works with constant output voltage. The recommended resistance is from 1.0 to 3.0ohm. This item also has other colors to choose. ![]() Broadside Mechanical Mod Clone $14.99 The Broadside Mechanical Mod Clone is constructed from brass and powered by 1 x 18650 battery (NOT INCLUDED). Mechanical button is with 3 points of contact, no springs or magnets needed to help to reduce hot buttons and misfires. This item also has other colors to choose. Please note: This mechanical mod is without Organic Solderability Preservative Process. It will be oxidized easily. ![]() Broadside Stacked Mechanical Mod Clone $25.99 The Broadside Mechanical Mod Clone is constructed from brass and is stackable. It is powered by 2 x 18650 battery (NOT INCLUDED). Mechanical button is with 3 points of contact, no springs or magnets needed to help to reduce hot buttons and misfires. This item also has other colors to choose. ![]() Original Asmodus Oni 167W DNA250 TC VW Variable Wattage Box Mod Original Price $119.95, Now Only $90.99 The Original Asmodus Oni 167W Mod is powered by Official Evolv DNA250 Chip. Powered by dual 18650 batteries (NOT INCLUDED), the mod can reach maximum output to 167W. By exchanging the batteries to a LiPo battery pack (NOT INCLUDED), with the help of Escribe software, the mod can be boosted to 250W. This item also has other colors to choose. ![]() Kindbright Culverin RDA Rebuildable Dripping Atomizer Clone $10.99 The Kindbright Culverin RDA Clone is a 25mm atty constructed from stainless steel. The deck features dual post with teardrop post hole design. The positive pin is copper made, while the negative is SS. The side airflow offers great flavor and massive vapor production. This item also has other colors to choose. ![]() Coppervape Caiman V.4 MTL RDA Rebuildable Dripping Atomizer Clone $14.99 The Caiman V.4 RDA Clone is a 22mm RDA designed for MTL vaping. Constructed from 316 stainless steel, it comes with dual posts for single coil building. The RDA has 6 airholes at bottom for adjustable airflow. The airflow can be fully closed or opened. Besides, the airflow control pin can be replaced with different one for different experience. Comes with 3 airflow pins: 1.7mm, 2.3mm and 3.2mm (pre-installed). ![]() Ulton Parvum RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.79 The Ulton Parvum RDA Clone is a 22mm RDA constructed from 316 stainless steel. It features reduced chamber for intense flavor, special design to saturate the cotton directly, leaf-proof, and totally 4 caps to satisfy your need on Tight MTL / Loose MTL / Restricted DTL / Pure DTL. This RDA comes with bottom feeder pin. ![]() JuggerKnot RTA Rebuildable Tank Atomzier Clone $25.89 The JuggerKnot RTA Clone is a 24mm RTA with 4ml of juice capacity. It was made in 1:1 scale. The build deck is postless with quad terminals for single or dual coil building. The top airflow will bring great flavor. It is easy to refill from the top and there is no leaking problem. The tank comes with 1 x glass tank, 1 x Ultem tank and 1 x Ultem fat tank. This item also has other colors to choose. ![]() Fatality RTA Rebuildable Tank Atomizer Clone $29.39 The Fatality RTA Clone is a 1:1 scale RTA with 28mm diameter and 4ml of juice capacity. It features side terminal postless deck and adjustable quad airflow. The unique airflow adjustment allows you to control the top and bottom airflow separately. Spare Ultem tank and drip tip is included. This item also has other colors to choose. ![]() YFTK Replacement Drip Tip + Top Cap Kit for O-Atty X RDA Clone $5.99 The replacement 510 drip tip and top cap are made from POM and are suitable for YFTK O-Atty X RDA Clone. ![]() YFTK O-Atty X RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99 The YFTK O-Atty X RDA Clone is a 22mm RDA with leak-resistant design and flawless machining. Constructed from 316 stainless steel, this RDA comes with dual post build deck for single coil builds. Ultem drip tip is included. This RDA comes with bottom feeder pin. ![]() Original Justfog Q14 900mAh Compact Kit $19.99 The Original Justfog Q14 Compact Kit is a convenient starter kit with built-in 900mAh battery, 1.8ml of tank capacity and 1.6ohm coil head (6~12W). The battery works with constant output voltage. The recommended resistance is from 1.0 to 3.0ohm. This item also has other colors to choose. ![]() Original Justfog J-Easy 9 900mAh Mod + Q16 Clearomizer Starter Kit $24.39 The Original Justfog Q16 Starter Kit consists of J-Easy 9 Battery and Q16 Clearomizer. It is a convenient starter kit with built-in 900mAh battery, 2.0ml of tank capacity and 1.6ohm coil head (6~12W). The battery works with constant output voltage. The recommended resistance is from 1.0 to 3.0ohm. This item also has other colors to choose. ![]() Original Justfog Minifit 370mAh Pod System Starter Kit $14.99 The Original Justfog Minifit Pod System Starter Kit features thumb-size that allows you to carry and vape even easier. It is constructed from PC and zinc alloy. It has a built-in 370mAh battery and is rechargeable via micro USB port. The pod has 1.5ml capacity and 1.6ohm coil. This item also has other colors to choose. ![]() Kindbright Nato Mechanical Mod Clone + Culverin RDA Kit Clone $30.59 The Kindbright Nato Mech Kit Clone consists of Kindbright Nato Mechanical Mod Clone and Kindbright Culverin RDA Clone. This item also has other colors to choose. Mod: The Kindbright Nato Mechanical Mod Clone is a 25mm tube mod with non-hybrid top cap. It is constructed from stainless steel. The fire button comes with unique design, which is solid marble that gives you great feedback. The switch is spring loaded. The mech mod is compatible with a single 18650 / 20650 / 20700 / 21700 battery (NOT INCLUDED). RDA: The Kindbright Culverin RDA Clone is a 25mm atty constructed from stainless steel. The deck features dual post with teardrop post hole design. The positive pin is copper made, while the negative is SS. The side airflow offers great flavor and massive vapor production. ![]() Original Justfog Replacement Drip Tip for Q16 Starter Kit / Q16 Clearomizer $1.59 The black Delrin drip tip is suitable for Original Justfog Q16 Starter Kit / Q16 Clearomizer. ![]() Original Justfog Replacement Tank Tube for Q14 Starter Kit / Q14 Clearomizer $1.99 The replacement Pyrex glass is suitable for Original Justfog Q14 Starter Kit / Q14 Clearomizer. This item also has other Version to choose. ![]() Original Justfog Replacement Coil Head for Q14 / Q16 Starter Kit $5.99 The replacement coil head has 1.2ohm resistance and is suitable for Original Justfog P16A / P14A / Q16 / Q14 / S14 / G14 / C14 clearomizer. This product comes with 5 PCS in 1 pack. This item also has other Version to choose. ![]() Coppervape Replacement Top Cap for Caiman V.4 MTL RDA Clone $1.99 The replacement top cap is made from PC and is suitable for Coppervape Caiman V.4 MTL RDA Clone. ![]() |
Enforcer Hybrid Mechanical Mod Clone $26.99
The Enforcer mechanical mod Clone is a 30mm mech mod with hybrid connection. It is constructed from brass. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). The fire button is activated by magnets. This item also has other colors to choose. ![]() Original Ystar Beethoven RTA Rebuildable Tank Atomizer Original Price $44.99, Now Only $26.99 The Original Ystar Beethoven RTA is a dual coil version RTA with the innovative leak-proof adjustable bottom airflow system, airflow transferring from the bottom to the top to maintain great flavor. It features a 24.7mm diameter, 5.5ml e-juice capacity tank, and stainless steel postless build deck. Single color resin material from o-ring to drip tip, mini deck space and big bubble tube not only bring incredible heat insulation, but also look wonderful and beautiful style on every colors. This item also has other colors to choose. ![]() YFTK O-Atty X RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99 The YFTK O-Atty X RDA Clone is a 22mm RDA with leak-resistant design and flawless machining. Constructed from 316 stainless steel, this RDA comes with dual post build deck for single coil builds. Delrin drip tip is included. This RDA comes with bottom feeder pin. ![]() Coppervape Skyfall RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99 The Coppervape Skyfall RDA Clone is constructed from 316 stainless steel. It features single coil build deck and adjustable side airflow. The airflow set is replaceable for different needs. This RDA comes with bottom feeder pin. ![]() YFTK Skyfall RDA Rebuildable Dripping Atomizer Clone with BF Pin $21.99 The YFTK Skyfall RDA Clone is constructed from 316 stainless steel. Built at 1:1 scale, it features single coil build deck and adjustable side airflow. The airflow set is replaceable for different needs. This RDA comes with bottom feeder pin. ![]() Original Desire Mad 108W TC VW Variable Wattage Box Mod + M-Tank Kit Original Price $85.00, Now Only $61.99 The Original Desire Mad Kit consists of Desire Mad Mod and Desire M-Tank. This item also has other colors to choose. Mod: The Original Desire Mad Mod is a versatile regulated device that is powered by single 18650 / 20700 battery (NOT INCLUDED) and can fire up to 108W. The mod has several modes to satisfy different needs, including VW, TC (Ni / Ti / SS / TCR), PMG (Power Multiple Graph) modes. The resistance range is from 0.08 to 3ohm. Tank: The Original Desire M-Tank is a 25mm tank atomizer with 3ml of juice capacity. It features easy slipper top refill and adjustable bottom airflow. The included coil has 0.2ohm resistance. ![]() Original Vandy Vape Simple EX Squonk Box Mod + EX RDA Kit Original Price $59.99, Now Only $44.89 The Original Vandy Vape Simple EX Squonk Kit consists of Simple EX Squonk Mod and Simple EX RDA. This item also has other colors to choose. Mod: The Original Vandy Vape Simple EX Squonk Mod is the first rebuildable Nic salt device that can adjust voltage from 3.3 to 4.5V. It is compact and small size as a pod system and is powered by built in battery. The silicone bottle has 4ml of juice capacity. The resistance range is from 0.8 to 3.0ohm. RDA: The EX RDA is a 21mm RDA with single coil build deck and 6 adjustable airflow specially designed for Nic salt. The airhole size are 0.6mm, 0.8mm, 1.0mm, 1.5mm, 2.0mm and 2.5mm. The RDA has leak-proof 510 connector. ![]() Original ThunderHead Creations THC Ni90 28GA Heating Resistance Wire for RDA / RTA $2.59 The Original ThunderHead Creations Ni90 28GA Heating Resistance Wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nichrome 90. It features 28GA, 0.3mm diameter, which will be a good choice for DIY. This item also has other Version to choose. ![]() Original ThunderHead Creations THC Jax Tool Kit for Vape $11.49 The Original THC Jax Tool Kit is a multi-functional tool kit designed for vape. The kit includes 1 x Multifunctional Screwdriver, 1 x Diagonal Pliers, 1 x Folding Scissors, 1 x Ceramic Tweezer, 1 x Coiling Jig Stick, 1 x Kanthal Wire, 2 x Organic Cotton, and 1 x Black Storage Case. ![]() SXK Replacement Front + Back Cover Panel for Billet Box Mod Clone Original Price $22.90, Now Only $14.99 The Replacement Cover Panel is made from resin, and is designed for SXK Billet Box 70W / DNA60W Box Mod Clone. This cover panel comes with 2 pieces (front and back). This product is not suitable for SXK Billet Box (Purple Color). Can also be used on YFTK Billet Box Mod Clone. The color and pattern may vary, this product will be shipped with random pattern. More options than what's on the image. ![]() |
Original SXmini SL Class 100W SX485J TC VW Mod $174.99
The Original SXmini SL Class Mod is powered by YiHi SX485J chip and can provide maximum output to 80W with single 18650 and 100W with single 20700 / 21700 (BATTERY NOT INCLUDED). The high-end device supports variable wattage and Joule, and comes with several functional modes and protections. The joystick control allows user to adjust settings with ease. This item also has other colors to choose. ![]() Original Madmax 99.96 Hybrid Mechanical Mod Original Price $119.90, Now Only $69.79 The Original Madmax 99.96 Mods mech mod is constructed from 99.96% purity copper, which has very low internal resistance. It comes with two springs (loose / tight) and two fire buttons (Able / Rogue style) for different needs. The middle tube can be reversed. The 99.96 mech mod is a durable and high-performance mod for cloud chasing. ![]() Original Rig Mod World Wide Model 41 RDA Rebuildable Dripping Atomzier with BF Pin Original Price $49.99, Now Only $27.79 The Original Rig Mod World Wide Model 41 RDA is a 25mm BF RDA that features dual post spring-loaded clamp build deck, redirected bottom airflow and 810 drip tip compatible. The Model 41 is designed to accompany flat coils and a bottom feed pin making this RDA ideal for build enthusiasts with squonk devices. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Coil Father King RDA Rebuildable Dripping Atomzier with BF Pin $7.99 The Original Coil Father King RDA is a 24mm BF RDA constructed from aluminum (top cap) and stainless steel (base). The build deck features quad posts design for easy coil building. The airslots on both sides are angled for side airflow. The knurled top cap makes airflow adjustment easy. The RDA comes with resin and Delrin 810 drip tip. The resin drip tip is in random color. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original CoilART UME U-1 240mAh Pod System Starter Kit $27.90 The Original CoilArt UME U-1 Pod System Kit is a super portable and compact device that features 0.8ml juice capacity and 240mah built-in battery. Remnant battery capacity is indicated by the LED indication light. You can simply activate it without any button, just a drag can do it. This item also has other colors to choose. ![]() Kindbright Replacement Tank Tube for Sherman V3 RTA Clone $1.59 The replacement glass tank tube has 4ml of juice capacity and is suitable for 25mm Kindbright Sherman V3 RTA Clone. ![]() Original Aspire Replacement Pod Cartridge for Breeze 2 Starter Kit Original Price $10.00, Now Only $6.59 The replacement pod cartridge comes with 3ml of juice capacity and 0.6ohm resistance. It is suitable for Original Aspire Breeze 2 Pod System Kit. ![]() Original Vapesoon Replacement Coil Heads for SMOK Vape Pen / Vape Pen Plus Clearomizer $6.99 The Vapesoon Replacement Coil Heads has 0.3ohm resistance and is suitable for Original SMOKTech SMOK Vape Pen / Vape Pen Plus Clearomizer. This product comes with 5 PCS in 1 pack. This item also has other Version to choose. ![]() |
SOB Hybrid Mechanical Mod Clone $13.49
The SOB Mechanical Mod Clone features black chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). ![]() Enforcer Hybrid Mechanical Mod Clone $26.99 The Enforcer mechanical mod Clone is a 30mm mech mod with hybrid connection. It is constructed from brass. The mod is powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED). The fire button is activated by magnets. ![]() Original Hotcig RSQ 80W Squonk TC VW Variable Wattage Box Mod Original Price $74.99, Now Only $49.89 The Original Hotcig RSQ 80W Squonk Box Mod is a high-end regulated device with squonking features. Equipped with an advanced HM chipset, the mod is capable of outputting up to 80W. The RSQ has full temperature control suite for advanced vapers. The silicone bottle sits beside the 18650 battery (battery not included), which can hold about 7ml e-juice. There is a breathing RGB LED light that makes the mod much cooler. This item also has other colors to choose. ![]() Squid Industries Double Barrel V2.1 150W VW Variable Wattage Box Mod Original Price $95.00, Now Only $89.99 The Original Squid Industries Double Barrel V2.1 mod combines exciting updates with the simple but powerful features of the original Double Barrel. Measuring only 3.5" high and about the size of the two 18650 high amp batteries that power it (BATTERY NOT INCLUDED), the Double Barrel has a sleek and compact chassis reinforced by stainless steel, ensuring only the best build quality and durability. Version 2.1 now comes with a new 0.47 top OLED display with indicators for wattage levels, atomizer resistance, and battery life. The Double Barrel now also has a power output from 5 to 150W. The Double Barrel is controlled by a single multi-function, tactile firing button coupled with a surrounding dial for wattage adjustment. The advanced chipset of the Double Barrel V2.1 allows for steady voltage output with Reverse Polarity Protection, Overheat Protection, and Short Circuit Protection. The Double Barrel V2.1 is a no-frills, classic mod for vapers who want a device that takes the most crucial features of a modern regulator mod and does them better than everything else out there. This item also has other colors to choose. ![]() Original Freemax Mesh Pro Sub Ohm Tank Clearomizer $24.39 The Original Freemax Mesh Pro Tank is a 25mm tank with 5ml / 6ml capacity. With Double and Triple Mesh Coil technology, the Freemax Mesh Pro is able to support higher wattage output even at 80~110 watts with much larger clouds. However, it doesn't mean that it will compromise the flavor like those cloud blowing tanks do. In the other hand, the Freemax Mesh Pro is the first sub ohm tank with so great flavor that youd never experienced before even with RDA. This item also has other colors to choose. ![]() Original Horizon Falcon Sub Ohm Tank Clearomizer $28.99 The Original Horizon Falcon tank is the latest sub ohm tank from HorizonTech, with 25mm diameter, which features a large 7ml e-juice capacity. It is comes with a preinstalled M2 0.16ohm (70~80W) coil head and a replacement M1 0.15ohm (70+/- 10W) coil head. Designed as top filling system and bottom airflow control system to bring you large vapors. It comes with 4 different coils for option: the F1 coil, which is a 0.2 ohm parallel coil head, rated at 80W, with a liquid guiding element of 70% organic cotton and 30% wood pulp, the F2 coil, which is a 0.2 ohm parallel coil head, rated at 80W, with a liquid guiding element of natural flax fiber, the F3 coil, which is a 0.2 ohm parallel coil head, rated at 70W, with a liquid guiding element of flax fiber and flax paper, and finally the M1, a 0.15 ohm mesh coil head, rated at 70W, with a liquid guiding element of 70% organic cotton and 30% wood pulp. This item also has other colors to choose. ![]() ShenRay Noble RDA Rebuildable Dripping Atomzier Clone $16.90 The ShenRay Noble RDA is a 25mm RDA that features postless build deck design, bottom airlflow system and spit back defuser. It comes with a glass tube to replace and a standard 810 drip tip with 4-way AFC fins. This item also has other colors to choose. ![]() Original Cthulhu Zathog RDA Rebuildable Dripping Atomzier with BF Pin $27.79 The Original Cthulhu Zathog RDA is a project by Vaping with Oen and Cthulhu MOD. It is a 30mm RDA which features adjustable 45 degree side airflow and top air flow, efficient independent U-shape airflow channel. The U-shape design is based on Morten Oens airflow analysis. It is a flavor monster for high power vaping and the recommend power is from 100 to 250W. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original VXV Soulmate RTA Rebuildable Tank Atomizer Original Price $38.00, Now Only $31.99 The Original VXV Soulmate RBA is a 24mm RTA that features Gear-top fill cap, 2-piece chimney section, dual juice well design, Ultem tank sections and adjustable bottom airflow. The offset post holes allow for easy coil installation. Dual juice well design allows for efficient wicking and leak resistance. It comes with AFC ring at bottom for adjustable bottom airflow. This item also has other colors to choose. ![]() Original Willie Vapor COO TS RDA Rebuildable Dripping Atomzier $14.99 The Original Willie Vapor COO TS RDA is a 30mm RDA that comes with Velocity style build deck for dual coil builds and adjustable 9-airhole side airflow system. It comes with another cap (included) with 3-airslot design. The juice well is 6mm deep. POM and stainless steel drip tips are included. This item also has other colors to choose. ![]() Layercake RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The LC1 LayerCake RDA Clone is an innovative rebuildable atomizer utilizing a dual-layer center clamp post in the build deck. It's post provides ample room for unabated exploratory coil building. Installed coils are keep cool by the signature dual skinny slots bringing in plenty of airflow. The LayerCake CSMNT V2 RDA Clone also includes a 810 drip tip that can be interchanged for any other of your favorite 810 tips. This RDA comes with bottom feeder pin for Squonker mod. This item also has other colors to choose. ![]() Reload X RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Reload X RDA Clone is a 24mm RDA constructed from stainless steel. It features a quad terminal postless deck designed for dual coil configurations and dual adjustable top-down bottom airflow system that minimizes leakage while providing intense flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Advken Replacement Tank Tube for Manta MTL RTA $1.99 The replacement glass tank tube has 2ml of juice capacity and is suitable for Original Advken Manta MTL RTA. This item also has other Capacity to choose. ![]() Original Freemax Replacement Kanthal Single Mesh Coil Head for Mesh Pro Tank $9.59 The Freemax Replacement Kanthal Single Mesh Coil Head head comes with 0.15ohm resistance for 40 to 70W wattage output. It is suitable for Original Freemax Mesh Pro / Fireluke / Fireluke Pro Tank. This product comes with 3 PCS in 1 pack. This item also has other Version to choose. ![]() Original Freemax Replacement Kanthal Double Mesh Coil Head for Mesh Pro Tank $10.89 The Freemax Replacement Kanthal Double Mesh Coil Head head comes with 0.2ohm resistance for 60 to 90W wattage output. It is suitable for Original Freemax Mesh Pro / Fireluke / Fireluke Pro Tank. This product comes with 3 PCS in 1 pack. This item also has other Version to choose. ![]() |
SOB Uno Bersikulo Hybrid Mechanical Mod Clone $13.49
The SOB Uno Bersikulo Mechanical Mod Clone features black POM chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Ulton Kali RDA Rebuildable Dripping Atomzier Clone with BF Pin + Spare Caps $18.09 The Ulton Kali RDA Clone is a 25mm rebuildable squonk atomizer with postless build deck and quad side terminals for easy single or dual coil builds. The airflow can be adjusted by rotating the top cap. There are triple airholes at both sides of the cap. PEI and PC top cap set are included. ![]() SXK Haku Venna RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99 The SXK Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. This RDA comes with bottom feeder pin. ![]() SXK Skyfall RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $19.90, Now Only $18.90 The SXK Skyfall RDA Clone is constructed from 316 stainless steel. It features single coil build deck and adjustable side airflow. The airflow set is replaceable for different needs. This RDA comes with bottom feeder pin. ![]() Original IJOY Diamond Bae 1400mAh 45W Box Mod + VPC Unipod Kit $75.99 The Original IJOY Diamond VPC Kit consists of IJOY Diamond Bae Box Mod and VPC Unipod. This item also has other colors to choose. Mod: The Original Diamond Bae Mod is a compact device with built in 1400mAh battery and 45W maximum output. The resistance range is from 0.05 to 3.0ohm. Pod: The VPC Unipod Cartridge has 2ml of juice capacity and features side refill design. It comes with 510 threads which makes it be compatible with most box mods. ![]() Original SMOKTech SMOK Novo 450mAh Pod System Starter Kit $25.69 The Original SMOK Novo Kit is a small size pod system kit with cobra covered at front and back. It has built-in 450mAh battery, powerful enough to give you expected vapor. Its mouthpiece is ergonomically designed, which can fit your mouth perfectly. And there are two pods included in this kit, both of which have 2ml capacity, you can drip your favorite e-liquid into them. This item also has other colors to choose. ![]() Original SMOKTech SMOK E-PRIV 230W TC VW Variable Wattage Mod + TFV12 Prince Tank Kit $63.19 The SMOK E-PRIV Kit consists of SMOK E-PRIV Mod and TFV12 Prince Tank. This item also has other colors to choose. Mod: Inspired by the powerful engine of world's top-class racing cars, SMOK launches another stunning box mod, E-Priv. SMOK E-Priv uses two 18650 batteries (NOT INCLUDED) as its power source to supply up to 230W output. It supports many working modes like VW / TC (Ti / Ni / SS) / Memory Mode. The resistance range is from 0.1 to 2.5ohm (VW) / 0.05 to 2ohm. Tank: The Original SMOK TFV12 Prince Tank from SMOKTech is not only a powerful one but also an all-round sub ohm tank for daily use. The tank adopts 2 newest coils: V12 Prince Dual Mesh and V12 Prince Max Mesh, all of which bring unprecedented heating area and heating speed. It also has newly designed crown-style body and colorful Cobra resin drip tip. Besides, it uses convex glass tube, which effectively enlarged the capacity to 8ml. ![]() SOB Uno Bersikulo Hybrid Mechanical Mod Clone + Outlaw RDA Kit Clone $21.99 The SOB Uno Bersikulo Mech Kit Clone consists of Uno Bersikulo Mech mod Clone and Outlaw RDA Clone. This item also has other colors to choose. Mod: The SOB Uno Bersikulo Mechanical Mod Clone features black POM chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). RDA: The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. The heat resistant POM drip tip can protect your mouth from heat. ![]() Coppervape Chimney Height Adjustment Key Chain for Spica Pro MTL RTA $2.99 This key chain is a special 3mm Allen key made from aluminum and is used to adjust the chimney height of Coppervape Spica Pro MTL RTA Clone. ![]() Coppervape Replacement Tight Airflow Pins for Spica Pro MTL RTA $1.99 This replacement tight airflow pins are made from 316 stainless steel and is suitable for Coppervape Spica Pro MTL RTA Clone. This product comes with 2 PCS of airflow pins, one 3-leaved, one 5-leaved. ![]() YFTK Replacement Top Cap for Haku Venna RDA Clone $5.99 The replacement top cap is made from PC and is suitable for YFTK Haku Venna RDA Clone. This item also has other colors to choose. ![]() Coppervape Key Chain + Tight Airflow Pins + Tank Tube Kit for Spica Pro MTL RTA $5.99 This kit includes one chimney height adjustment key chain, two tight airflow pins and one PC tank tube for Coppervape Spica Pro MTL RTA Clone. ![]() |
Original Vandy Vape Pulse BF 80W TC VW Squonk Box Mod with Vandy Chip Original Price $70.00, Now Only $49.99
The Original Vandy Vape Pulse BF 80W Squonk Box Mod is a collaboration by VandyVape and Tony B. The new Pulse BF Mod is no longer a mechanical mod, but a regulated mod. With 80W maximum output and 8ml bottom feeder bottle, Pulse BF 80W Mod will bring you better squonking experience. The mod is powered by a single 18650 (adapter included) or 20700 battery (battery not included). The Pulse BF 80W Box Mod is with Original Vandy Chip. Vandy chip is with higher cost performance than Gene chip, saving about 30% than previous. It’s with more functions of BYPASS and energy saving mode under Low Voltage situation. Furthermore, Vandy chip consists of Top-grade IC at affordable costs. This item also has other colors to choose. ![]() Original Vandy Vape Pulse BF 80W TC VW Box Mod with 30ml Refill Bottle $75.00 The Original Vandy Vape Pulse BF 80W Squonk Box Mod is a collaboration by VandyVape and Tony B. The new Pulse BF Mod is no longer a mechanical mod, but a regulated mod. With 80W maximum output and 8ml bottom feeder bottle, Pulse BF 80W Mod will bring you better squonking experience. The mod is powered by a single 18650 (adapter included) or 20700 battery (battery not included). The Pulse BF 80W Box Mod is with Original Vandy Chip. Vandy chip is with higher cost performance than Gene chip, saving about 30% than previous. It’s with more functions of BYPASS and energy saving mode under Low Voltage situation. Furthermore, Vandy chip consists of Top-grade IC at affordable costs. This mod comes with a 30ml refilling bottle. This item also has other colors to choose. ![]() Original Oumier TRX RDA Rebuildable Dripping Atomizer $42.99 The Original Oumier TRX RDA, designed by world champion tricksters, is a 24mm RDA for cloud chasing. It comes with dual posts build deck for easy coil installation and has a deep juice well. With the adjustable airflow, the Oumier TRX RDA will bring you optimal flavor and massive clouds. This item also has other colors to choose. ![]() Original Oumier WASP Nano RDTA Rebuildable Dripping Tank Atomizer $14.99 The Original Oumier WASP Nano RDTA is a rebuildable atomizer designed based on WASP Nano RDA, and comes with a 2ml tank to become a rebuildable dripping tank atomizer. WASP Nano RDTA features 22mm diameter, large build deck for single coil building, and direct side airflow design to ensure fabulous vaping experience. This RDTA is compatible with 510 drip tip. This item also has other colors to choose. ![]() Original Ystar Shake 380mAh Pod System Starter Kit $19.90 The Original YSTAR SHAKE Pod System kit is a compact size device constructed from aluminum alloy and PC for portable and lightweight. It is powered by a built-in 380mAh battery to satisfy your daily need. The Shake kit is refillable and is suitable for THC / CBD oil, Nic salt and all kinds of Juice. Adjust the voltages when you shake it heavily, the voltages range is from 3.2 to 4.2V. This item also has other colors to choose. ![]() Original Snowwolf O-100 100W TC VW Squonk Box Mod + RDA Kit $58.99 The SnowWolf O-100 100W Squonk Kit consists of SnowWolf O-100 Box Mod and SnowWolf BF RDA. This item also has other colors to choose. Mod: The SnowWolf O-100 100W Squonk Mod is the latest advanced squonk mod with luxurious design elements, featuring performance versatility with full temperature control suite and a 7ml capacity bottle. The smart chipset allows SnowWolf O-100 to fire up to 100W with single 18650 / 20700 / 21700 battery (NOT INCLUDED). The SnowWolf O-100 Squonk Box Mod is sturdily constructed with heavy-duty Zinc Alloy frame with magnetized panels in a range of visually striking designs. RDA: The SnowWolf BF RDA has a 24mm base and a dual-post deck with single terminal in each for a flavor-focused single coil configuration. Air enters via large adjustable dual airholes that can fully open for maximum customizability or with the provided tiny airslots for a MTL-orientated air channel. ![]() Original ThunderHead Creations THC Replacement Squonk Bottle for Thunder Storm BF Mod / Kit $2.99 The replacement squonk bottle is made from silicone and has 8ml of juice capacity. It is suitable for Original ThunderHead Creations THC Thunder Storm BF Mod / Kit. ![]() Original ThunderHead Creations THC Replacement Fire Button for Tauren Mech Mod $12.99 The replacement fire button is made from brass. It is suitable for Original ThunderHead Creations THC Tauren Mech Mod. This item also has other colors to choose. ![]() Original Vapjoy Ni90 Heating Resistance Wire $4.95 The Original Vapjoy Ni90 heating resistance wire is perfect for RBA / RTA / RDA atomizers. The wire is made from Nickel Ni90. It comes with 26GA x 30 feet, which will be a good choice for DIY. This item also has other Version to choose. ![]() |
B2K RSA V5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99
The B2K RSA V5 RDA Clone is a 24mm RSA & RDA which has postless build deck for single coil builds. It is easy to mount coils with such structure. The side airflow will bring you smooth, quiet and extremely flavorful vape experience. This item also has other colors to choose. ![]() Original Hellvape Drop Dead RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $29.99 The Original Hellvape Drop Dead RDA is an epic collaboration by Hellvape, Vapin' Heathen, and TVC The Vapor Chronicles, creating a rebuildable masterpiece based on the designs of two of the best selling atomizers of the past year, the Hellvape Dead Rabbit RDA and Digiflavor DROP RDA. The Drop Dead RDA feature Drop style deck and Dead Rabbit style top cap, which brings fantastic chemistry, performing greatly in flavor and cloud production. This item also has other colors to choose. ![]() Armageddon MFG Apocalypse GEN 2 RDA Rebuildable Dripping Atomizer Original Price $79.99, Now Only $35.99 The Apocalypse Gen 2 RDA by Armageddon MFG is the first generation of the Apocolypse RDA. The clamp design has a massive space in each clamp which provides space for mounting the most complex and insane coil builds. Coupled with the deep juice well, large build deck, durable post clamps and extended post screws, the Apocalypse is a builder's dream. The unique teardrop shape airflow control provides extra customization and the sleeve has the "APOCALYPSE" logo engraved into one side and the Gas Mask Logo etched on the opposite side. This item also has other Version to choose. ![]() Original Wismec Motiv 2 500mAh Pod System Starter Kit $20.99 The Original Wismec Motiv 2 Pod System Kit, a new all-in-one pod style setup, boasts its convenient filling solution and improved leak prevention. The Motiv 2 features an intuitive refillable cartridge with 3ml capacity and is powered by built-in 500mAh battery. This item also has other colors to choose. ![]() Original Uwell Whirl 20 700mAh Starter Kit $29.99 The Original Uwell Whirl 20 Kit, constructed of stainless steel, is a slim and light pen-style vape device. Equipped with built-in 700mAh battery, it supports voltage range from 3 to 3.8V and maximum wattage up to 25W. With a 2ml tank capacity and 0.6 +/- 0.1ohm resistance range, the tank also features plug-n-pull coil replacement design and bottom filling, and the pro-FOCS flavor testing technology from UWELL offers you amazing both mouth-to-lung vape and restricted direct-to-lung vaping. This item also has other colors to choose. ![]() Original Uwell Whirl 22 1600mAh Starter Kit $32.99 The Original Uwell Whirl 22 Kit, constructed of stainless steel, is a slim and light pen-style vape device. Equipped with built-in 1600mAh battery, it supports voltage range from 3 to 3.8V and maximum wattage up to 25W. With a 2ml tank capacity and 0.6 +/- 0.1ohm resistance range, the tank also features plug-n-pull coil replacement design and bottom filling, and the pro-FOCS flavor testing technology from UWELL offers you amazing both mouth-to-lung vape and restricted direct-to-lung vaping. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.69 The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose. ![]() Vapeasy Display Base Stand for RDA / RTA / Sub Ohm Tank Atomizer $4.99 The Vapeasy display base stand is made out of aluminum. It is suitable for all size atomziers. Fingerprints and scratches are not easy to be left on this stand. And the curve design holds e-juice, preventing your table being flooded with liquid. The thread is specially designed and will not get any atomizer stuck. This item also has other colors to choose. ![]() |
Original Eleaf Saurobox 220W TC VW Variable Wattage Box Mod $55.99
The Original Eleaf Saurobox Box Mod is a new high performance mod by Eleaf, coupled with an aesthetically attractive design that covers its whole body with a special kind of resin material. Not only beautiful and luxurious, this kind of resin material also makes the Saurobox ultra light in weight and easy to hold and carry. Powered by dual 18650 batteries (NOT INCLUDED), the Saurobox can fire up to 220 watts and presents a clear and bright 0.96-inch TFT color display. The Saurobox also has features including user-friendly firmware, 2A quick charge and balance charging capabilities. This item also has other colors to choose. ![]() Kindbright Monad V2 RTA Rebuildable Tank Atomzier Clone $18.99 The Kindbright Monad V2 RTA Clone is a 22mm rebuildable tank atomizer made from 316 stainless steel and has 2.9ml of juice capacity. The build deck comes with single post for single coil builds. The RDA has dual 0.8mm airflow on the side. ![]() Original GAS Mods ***** S RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.99, Now Only $29.99 The Original GAS Mods ***** S RDA is the newest rebuildable atomzier from GAS Mods. It features 22mm diameter, single coil build deck, and 3mm by 4mm bottom airflow. This RDA comes with bottom feeder pin. This item also has other colors to choose. [img]http://www.3fvape.com/214362-home_default/authentic-gas-mods-*****-s-rda-rebuildable-dripping-atomizer-w-bf-pin-black-pei-stainless-steel-22mm-diameter.jpg[/img] SXK Monarchy RDA Rebuildable Dripping Atomizer with BF Pin Original Price $17.90, Now Only $13.99 The SXK Monarchy RDA is a 22mm RDA constructed from 316 stainless steel. It comes with black Delrin removable drip tip, single post build deck and side airflow system. This RDA is squonk-ready. This RDA comes with bottom feeder pin and decorative ring. ![]() Original Eleaf Saurobox 220W TC VW Variable Wattage Box Mod + ELLO Duro Tank Kit $69.99 The Original Eleaf Saurobox Kit consists of Eleaf Saurobox Box Mod and Eleaf ELLO Duro Tank. This item also has other colors to choose. Mod: The Original Eleaf Saurobox Box Mod is a new high performance mod by Eleaf, coupled with an aesthetically attractive design that covers its whole body with a special kind of resin material. Not only beautiful and luxurious, this kind of resin material also makes the Saurobox ultra light in weight and easy to hold and carry. Powered by dual 18650 batteries (NOT INCLUDED), the Saurobox can fire up to 220 watts and presents a clear and bright 0.96-inch TFT color display. The Saurobox also has features including user-friendly firmware, 2A quick charge and balance charging capabilities. Tank: ELLO Duro, a new member of Eleaf ELLO family, features all-new reimagined Net and Multihole coil technologies which present unprecedented vaping experience with ultra flavorful taste and huge clouds and have a longer lifespan. To fill the tank, you just need to slide the drip tip back to reveal the fill port. The tank has 6.5ml of juice capacity. ![]() Original Steam Crave Titan PWM VV Variable Voltage Box Mod + Aromamizer Titan RDTA Kit Original Price $124.99, Now Only $109.99 The Original Steam Crave Titan PWM Kit consists of Steam Crave Titan PWM Mod and Steam Crave Aromamizer Titan RDTA. This item also has other colors to choose. Mod: The Original Steam Crave Titan PWM Mod is a quad 18650 variable voltage box mod. Powered by quad 18650 batteries (NOT INCLUDED) in parallel / series, this mod can provide maximum output to 300W, which is very powerful. By Rotating the fire button you can adjust the voltage, and it comes with lock function. Besides, the mod has multiple protections to give you a safe vaping experience. Tank: The Original Steam Crave Aromamizer Titan RDTA is so amazing as it has 41mm diameter and maximum 28ml capacity! The Innovative Lego modular build deck allows you to build coils on postless, Velocity, or Series style deck, which offers vapers a great change to build various configurations. The tank can be switched from 28ml to 18ml, or you can use it as RDA, which has a 4.5ml juice well. Titan will bring you great fun for endless coil building and fantastic vaping experience. ![]() Original Shield Cig Ceramic Tweezers for E-Cigarette $3.49 The Shield Cig Ceramic Tweezers is Multi-functional E-cig DIY tool with advanced stainless steel body and ceramic tip. The Ceramic Tweezer can be used to tweak the coil while firing and the tip is heat resistant up to 1600'C. This item also has other Version to choose. ![]() Original HJ Grapefruit E-juice Liquid for E-cigarette $6.99 The HJ E-juice Liquid comes with the grapefruit flavor. It comes with 50ml e-juice, and 70% VG / 30% PG. This item also has other Flavor to choose. ![]() Original Shield Cig Beta Coefficient Nic Salt E-juice Liquid $8.99 The Shield Cig Beta Coefficient E-juice Liquid comes with the tobacco flavor. It is Nic salt juice that comes with 30ml capacity,and 70% VG / 30% PG. It is recommended for pod system kit. This item also has other Version to choose. ![]() |
Original Rincoe Manto 228W TC VW Variable Wattage Box Mod $52.59
The Original Rincoe Manto 228W TC Mod is a dual 18650 battery device capable of 228W (BATTERY NOT INCLUDED). Its small size and rounded edges makes it very comfortable in the hand. It features a 2.0 inch TFT color screen with 3D feel display. Its IML device panel makes the device feel solid and look stylish. Whats more, Rincoe Manto fires almost instantly with only 0.002s. This item also has other colors to choose. ![]() Original Omeka MSM Phoebe RDA Rebuildable Dripping Atomizer Original Price $30.00, Now Only $13.99 The Original Omeka MSM Phoebe RDA is a 24mm RDA that comes with dual post build deck for dual coil builds and adjustable bottom airflow, which allows air travels from the bottom to top, bringing optimal flavor and massive vapor production. Delrin drip tip is included. This item also has other colors to choose. ![]() Original Omeka MSM Taste RDA Rebuildable Dripping Atomizer with BF Pin Original Price $30.00, Now Only $20.99 The Original Omeka MSM Taste RDA is a 24mm RDA that features postless build deck and side airflow system. The middle cap can be replaced for single or dual coil builds. It has an extra PC cap for different experience. Black Delrin 810 drip tip and 510 drip tip adapter are included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original 5GVape Leopard RDTA Rebuildable Dripping Tank Atomizer $26.99 The Original 5GVape Leopard RDTA is a 24mm rebuildable tank atomizer with 4ml of juice capacity. The RDTA has a dual coil build deck for easy building and top / bottom airflow system for great flavor and cloud production. This item also has other colors to choose. ![]() Original Asvape Zeta MTL RTA Rebuildable Tank Atomizer $25.99 The Original Asvape Zeta MTL RTA is a 22mm RTA which supports high nicotine content to deliver excellent flavor, featuring adjustable bottom airflow and easy top filling to bring convenient vaping for you. The tank has 2.5ml capacity that will meet your daily needs. This item also has other colors to choose. ![]() Original Afk Studio Easy One EDA RDA Rebuildable Dripping Atomizer $28.99 The AFK Studio Easy One EDA RDA is 24mm Easy Dripping Atomizer which comes with replaceable deck with coils and wicks, making it convenient to use without any building. The 0.15ohm finished atomizer coil can be replaced in just 3 seconds and will bring you great flavor. The Easy One EDA RDA was designed for maximizing flavor and vapor production in an easy to build design for anyone looking for a smooth and stylish rebuildable atomizer. This item also has other colors to choose. ![]() Original Rincoe Ceto 370mAh Pod System Starter Kit $21.89 The Original Rincoe Ceto Pod System Kit features and ultra-thin form factor making it your best choice for an on-the-go stealth device. It is designed to fit your hands. There is no fire button, you can just insert the pod and start to vape. The Ceto has built-in 370mAh batter with safe output and it can be charged via the Micro USB port. The pod is refillable with 2ml of juice capacity and the coil has 1.3ohm resistance. This item also has other colors to choose. ![]() YFTK Replacement Drip Tip + Top Cap Kit for O-Atty X RDA Clone $5.99 The replacement 510 drip tip and top cap are made from PC and are suitable for YFTK O-Atty X RDA Clone. This item also has other Version to choose. ![]() Original SMOKTech SMOK V12 Prince Dual Mesh Coil for TFV12 Prince Tank $13.99 The SMOK V12 Prince Dual Mesh Coil features larger heating area and faster heating speed. It comes with 0.2ohm dual coils and works well at 50~80W, best 65~75W. This product comes with 3 PCS in 1 pack. This item also has other Version to choose. ![]() Original Afk Studio Replacement Coil for Easy One EDA RDA $12.99 The replacement coil has 0.15ohm resistance. It comes with a deck and pre-built dual coils and wicks. It is suitable for Original Afk Studio Easy One EDA RDA. This product comes with 2 PCS in 1 pack. ![]() |
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Original Smiss Warrior X75 75W TC VW Variable Wattage Box Mod $39.19
The Original Smiss Warrior X75 Box Mod is a single 18650 battery box mod (BATTERY NOT INCLUDED) capable of firing up to a max output of 75W. Smiss Warrior X75 is ergonomically designed and comes with high quality leather for better touch feeling. The versatile device has multiple working modes, including POWER, SS, Ti1, Ni200, TCR and Taste. This item also has other colors to choose. ![]() Original Asmodus Luna 80W Squonk Box Mod Original Price $99.95, Now Only $88.99 The Original Asmodus Luna Squonker box mod, a collaboration by Ultroner and Asmodus, is a single-battery unregulated Squonker mod with protection. The Asmodus Luna is constructed of 6063 aluminum alloy and Stabilized wood. The internal bottle has 6ml of juice capacity. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original GeekVape Creed RTA Rebuildable Tank Atomizer $25.99 The Original Geekvape Greed RTA is a rebuildable tank atomizer features 6.5ml and 4.5ml e-juice capacity. It is constructed from food grade Stainless Steel and glass. The dual adjustable bottom airflow can be adjusted easily, also will bring you amazing flavor taste. This item also has other colors to choose. ![]() Original Aspire Revvo Mini Sub Ohm Tank Clearomizer $25.59 The Original Aspire Revvo Mini Tank is a more compact version of the original Revvo tank, lower profile and slimmer than the original one. It still uses the legendary ARC radial coil for awesome flavor and vapor production, but now in an even more compact package to fit slimmer mods. The tank comes with 22mm diameter and 2ml of juice capacity. This item also has other colors to choose. ![]() Original Hugsvape Theseus RDA Rebuildable Dripping Atomizer with BF Pin $20.99 The Original Hugsvape Theseus RDA is a 22mm BF RDA that has an easy-to-build single coil deck and dot airflow for smooth and flavorful vaping experience. The RDA is squonk-ready and can be compatible with the mainstream squonk box mod in the market. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Vandy Vape Pyro V2 RDTA Rebuildable Dripping Tank Atomizer with BF Pin Original Price $36.99, Now Only $26.99 The Original Vandy Vape Pyro V2 RDTA is a 24mm BF rebuildable tank atomizer. It is the upgraded version of Pyro 24 RDTA. The Vandy Vape Pyro V2 features leak-proof top airflow design, top fill and bottom feed, mixed airflow intake system and easy-to-build deck. It comes with 4ml of juice capacity. This item also has other colors to choose. ![]() Original Hellvape Dead Rabbit RTA Rebuildable Tank Atomizer $21.90 The Original Hellvape Dead Rabbit RTA Tank Atomizer is the brand new RTA tank, which is a collaboration by Vapin' Heathen and Hellvape. Dead Rabbit RTA features large e-juice capacity and top airflow system for large vapor without e-juice leakage. Dead Rabbit RTA has an easy coil build deck offering a fantastic option for those after excellent performance from a rebuildable tank. There is Dead Rabbit Logo on the chamber. 810 wide bore drip tip is included. ![]() Original GeekVape Nova 200W TC VW Variable Wattage Box Mod Kit $64.99 The GeekVape Nova Kit is a newly designed dual battery box mod that is capable of 200W maximum output. It has beautiful resin panel and comes with multiple modes and protections. This item also has other colors to choose. ![]() Original Aspire Cygnet 80W VW Variable Wattage Box Mod + Revvo Mini Tank Kit Original Price $64.99, Now Only $54.89 The Aspire Cygnet Revvo Kit consists of Aspire Cygnet Mod and Revvo Mini Tank. This item also has other colors to choose. Mod: The Aspire Cygnet mod is powered by a single replaceable 18650 battery, with a maximum wattage output of 80W. It is a highly portable mod that supports Variable Voltage, Variable Wattage and Bypass modes. It's simple in design and has a fire button, 2 adjustment buttons combined to make navigating the mod super easy. Tank: The Original Aspire Revvo Mini Tank is a more compact version of the original Revvo tank, lower profile and slimmer than the original one. It still uses the legendary ARC radial coil for awesome flavor and vapor production, but now in an even more compact package to fit slimmer mods. The tank comes with 22mm diameter and 2ml of juice capacity. ![]() SXK Billet Box 70W All-in-One Box Mod Kit Clone with USB Port $75.00 The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This Billet Box comes with USB port for firmware upgrading and charging. This item also has other colors to choose. ![]() |
Original Asmodus Lustro 200W Touch Screen TC VW Variable Wattage Box Mod Kodama Edition $349.95
The Original Asmodus Lustro Box Mod is a versatile regulated mod powered by dual 18650 batteries (NOT INCLUDED), which can reach maximum output to 200W. With a capacitive touch screen, the operation on Lustro is very easy to vapers. Working with the latest GX-200-HUT chipset, Lustro Box Mod provides high performance in all aspects. The Curve output mode allows for detailed customization of the firing curve. The Lustro Box Mod will bring you the most comfortable vaping experience. ![]() Original Asmodus Pumper-18 Squonk Mechanical Box Mod Original Price $119.95, Now Only $112.59 The Original Asmodus Pumper 18 squonk mod is a single battery mod that is an adaptation of the Luna, and the Spruzza. The body resembles the Luna form factor and the squonk bottle was derived from the spruzza. The body was made more round to make the mod more ergonomic making the Pumper comfortable to fire with the thumb or pointer finger. It is constructed of high grade stainless steel and luxurious stabilized wood for a lightweight and beautiful design. The button proudly holds the ASMODUS wheel logo and is recessed to better help the user from auto firing. The Pumper squonk bottle has an 8ml liquid capacity. The bottle removal system is amazingly easy to use. This mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Asmodus Pumper-20/21 Squonk Mechanical Box Mod Original Price $139.95, Now Only $128.99 The Original Asmodus Pumper 20/21 squonk mod is a single battery mod that is an adaptation of the Luna, and the Spruzza. The body resembles the Luna form factor and the squonk bottle was derived from the spruzza. The body was made more round to make the mod more ergonomic making the Pumper comfortable to fire with the thumb or pointer finger. It is constructed of high grade stainless steel and luxurious stabilized wood for a lightweight and beautiful design. The button proudly holds the ASMODUS wheel logo and is recessed to better help the user from auto firing. The Pumper squonk bottle has an 8ml liquid capacity. The bottle removal system is amazingly easy to use. This mod is powered by single 20700 / 21700 battery (NOT INCLUDED). This item also has other colors to choose. ![]() Original Asmodus EOS 180W Touch Screen TC VW Variable Wattage Box Mod Original Price $129.95, Now Only $109.99 The Original Asmodus EOS 180w Box mod is a collaboration between Asmodus and Ultroner. The EOS comes with a lightweight and smaller body structure for those who like an easy-to-carry mod. The EOS is constructed of 6063 aluminum along with the luxurious Stabilized wood. There are 2 removable doors, one to access the batteries and the other door for customizable purposes. The EOS box mod is using the well-known GX-180-UT that still has all the features the Minikin v2 such as, Wattage, Curve, TFR, TCR, and a responsive touch screen. The EOS is also firmware upgradeable via micro USB port. The mod is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose. ![]() Original Asmodus Helve V1.5 TC VW Variable Wattage Box Mod Original Price $84.95, Now Only $52.99 The Asmodus Helve V1.5 Mod was fully designed in the USA and was crafted with comfort in mind. Its body was contoured to fit perfectly in your hands for a great vaping experience. The Helve is powered by a GX-150-H2 chip. This all new chip set retains its hyper power saving capabilities which will elongate the users battery life (at an average of 15~30% times longer than any other dual battery mods) and will make you feel as if your mod had three batteries in it all while being boosted to 150W. The mod was proportioned to prevent it from being top heavy when an atomizer is set to the device. The Helve is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose. ![]() Original Wotofo Warrior RDA Rebuildable Dripping Atomzier with BF Pin Original Price $33.90, Now Only $23.99 The Original Wotofo Warrior RDA was designed by JMT Elite together with Wotofo. The 25mm dual coil RDA is the most coil-friendly RDA incorporated with the profound wisdom of coiling. The Warrior RDA features a domed top cap which has a great deal of structural strength and functions to compress air as to enhance flavor. There are two sets of beehive style air holes (3 lines a set with 8 holes for each line) symmetrically positioned on two sides of the Warrior RDA sleeve. There are two clamp posts with 4 screws on the top to fix the coils. The overall chamber is relatively short but the space is large enough for proper vaporization. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original VGOD PRO Mech 2 Hybrid Mechanical Mod + Elite RDA Kit Original Price $95.00, Now Only $78.99 The Original VGOD PRO Mech 2 Kit consists of VGOD PRO Mech 2 Mod and VGOD Elite RDA. This item also has other colors to choose. Mod: The No.1 Mech Mod from VGOD, VGOD PRO Mech 2 is a hard-hitting and high-end hybrid mod, which is born for cloud-chasing. Boasting unique aesthetics and innovation, the PRO Mech 2 introduces a CNC machined Delrin comfort touch chassis and the consistent firing of the TriCon switch system. The PRO Mech 2 delivers hard hitting performance while maintaining comfort and dependability. The mod is powered by single 18650 battery (not included). RDA: The Original VGOD Elite RDA is born for cloud chasers and trick players. It is a 24mm diameter rebuildable dripping atomizer with the best features and high grade materials. The deck features dual post for easy building, with 2mm holes. The bottom airflow brings massive vapor clouds. Heat resistant Delrin drip tip protects mouth from heat. ![]() SXK Replacement Cover Panel for Billet Box Mod Clone Original Price $22.90, Now Only $20.19 The Replacement Cover Panel is made from resin, and is designed for SXK Billet Box 70W / DNA60W Box Mod Clone. This cover panel comes with 2 pieces (front and back). This product comes with random color pattern due to resin material. ![]() Original Wotofo 22mm Conversion Cap for Recurve RDA Original Price $12.99, Now Only $8.99 This Conversion Cap Kit is made for the purpose of converting your 24mm Recurve RDA into a 22mm buddy. Reserving the same adjustable air inlet design but providing a straight cap wall for different preferences. The kit includes a removable decoration ring to give a choice of 24mm look if you like. And the word "RECURVE" is engraved at the bottom of the cap, and on the ring as well. This item also has other colors to choose. ![]() Original Asmodus Replacement Bottle for Pumper 18/21 Squonk Box Mod Original Price $19.95, Now Only $17.99 The replacement bottle has 8ml of juice capacity and is suitable for Original Asmodus Pumper 18/21 Squonk Box Mod. This item also has other colors to choose. ![]() |
Purge Maelstrom Hybrid Mechanical Mod Clone $25.99
The Purge Maelstrom Mech mod Clone is constructed from brass and comes with hybrid top cap for more power hit. It is powered by single 18650 battery (NOT INCLUDED). The mod comes with logo. This item also has other colors to choose. ![]() Purge Truck Hybrid Mechanical Mod Clone $24.59 The Purge Truck Mech mod Clone is constructed from brass and comes with hybrid top cap for more power hit. It is powered by single 18650 battery (NOT INCLUDED). The mod features full knurled body and comes with logo. This item also has other colors to choose. ![]() Original Lost Vape Paranormal DNA250C 200W TC VW Box Mod Original Price $149.00, Now Only $118.89 The Original Lost Vape Paranormal DNA250C Box Mod adopts the most advanced chip from Evolv, the DNA250C chip. Paranormal DNA250C Mod features Replay mode, which allows vapers to select their own perfect vape and save to replay it over and over. Powered by dual 18650 batteries (not included), the Paranormal can be varied from 1 to 200W. The On-the-Go function of DNA250C allows Paranormal DNA250C to act like a power bank. ![]() Kindbright Haku Venna RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99 The Kindbright Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original GeekVape Creed RTA Rebuildable Tank Atomizer Original Price $36.99, Now Only $25.99 The Original Geekvape Creed RTA is a rebuildable tank atomizer features 6.5ml and 4.5ml e-juice capacity. It is constructed from food grade Stainless Steel and glass. The Creed comes with three interchangeable airflow system providing variety of airflow options that produces outstanding flavor. Easy to build deck and comes with a 6.5ml Bubble glass expansion for larger juice capacity. This item also has other colors to choose. ![]() Original Snowwolf Mfeng Limited Edition 200W TC VW Variable Wattage Mod + Mfeng Tank Kit Original Price $81.99, Now Only $76.69 The Original Snowwolf Mfeng Kit Limited Edition consists of Snowwolf Mfeng Limited Edition Mod and Mfeng Sub Ohm Tank. This item also has other colors to choose. The Original Snowwolf Mfeng Limited Edition Mod is a high-class versatile regulated mod with 1.3inch TFT colorful screen and friendly interface. Powered by dual 18650 batteries (NOT INCLUDED), the Mfeng mod can reach 200W maximum output. With a brand new chipset, Mfeng allows you to choose different modes to meet your needs. Together with 6ml Mfeng Sub Ohm Tank, the Snowwolf Mfeng Kit will bring you excellent vaping experience. ![]() Original Vandy Vape Fused Clapton Coil $4.89 The Original Vandy Vape Fused Clapton Coil features 26GA (A1) x 2 + 36GA (Ni80) wires and 0.43ohm resistance. It is suitable for RDA / RTA DIY coil building. This product comes with 10 PCS in 1 pack. This item also has other Version to choose. ![]() Original Vandy Vape Nippers for DIY Coil Building $2.59 The Original Vandy Vape Nippers is made from durable stainless steel and is suitable for DIY coil building. ![]() Original Vandy Vape Folding Scissors for DIY Coil Building $2.59 The Original Vandy Vape folding scissors is made from durable stainless steel and is suitable for DIY coil building. ![]() Original Vandy Vape Ceramic Tweezers for DIY Coil Building $4.09 The Original Vandy Vape Tweezers is made from durable stainless steel and ceramic and is suitable for DIY coil building. ![]() Original Vandy Vape Diagonal Pliers for DIY Coil Building $5.19 The Original Vandy Vape Diagonal Pliers is made from durable stainless steel and plastic and is suitable for DIY coil building. ![]() SXK Replacement 510 Drip Tip + Top Cap + Decorative Ring Kit for Haku Venna RDA Clone Original Price $9.50, Now Only $7.59 The replacement 510 drip tip, top cap and decorative ring are made from PEI. They are suitable for SXK Haku Venna RDA Clone. ![]() Kindbright Replacement Top Cap for Haku Venna RDA Clone $6.99 The replacement top cap is made from PEI and is suitable for Kindbright Haku Venna RDA Clone. This item also has other colors to choose. ![]() Kindbright Replacement 510 Drip Tip + Top Cap + Decorative Ring Kit for Haku Venna RDA Clone $9.59 The replacement 510 drip tip is made from POM, top cap and decorative ring are made from PEI. They are suitable for Kindbright Haku Venna RDA Clone. This item also has other colors to choose. ![]() |
BDside Nashed Mechanical Tube Mod Clone $18.99
The BDside Nashed Mech Mod Clone is constructed from brass and comes with 25mm diameter. It comes with non-spring and non-magnet design, which helps reduce hot button and misfires. The mod is powered by single 18650 / 20700 battery (NOT INCLUDED). A Delrin 18650 battery adapter is included. This item also has other colors to choose. ![]() Original GeekVape Nova 200W TC VW Variable Wattage Box Mod Original Price $63.99, Now Only $46.59 The Nova mod is a high-performance device that powers up to 200W with dual 18650 batteries (NOT INCLUDED). Powered by the advanced AS chipset that has unmatched speed and power. Designed with elegant aesthetics, Nova is built with premium quality aluminum alloy and beautifully crafted resin, delivering an exquisite contrast that portrays simplicity and elegance. This item also has other colors to choose. ![]() Original Desire X-Mini 108W TC VW Variable Wattage Box Mod $49.99 The Original Desire X-Mini Box Mod is a smaller version of Desire X Mod. The X-Mini is powered by a temperature control chip, allowing for even the most advanced vapers to find the optimal vape experience that suits them. Powered by single 21700 battery cell (NOT INCLUDED), the Desire X-Mini also comes with a sleeved 18650 adapter. This advanced mod comes with many safe features that would guarantee a safe vaping for users. This item also has other colors to choose. ![]() Original Asmodus Colossal 80W TC VW Variable Wattage Box Mod $59.95 The Original Asmodus Colossal 80W Mod is a beast of a single battery mod (BATTERY NOT INCLUDED) that is perfect for when you are on the go. This petite mod features an advanced chipset with a new and improved UI and is sure to impress due to the incredible portability combined with the massive power. The Colossal features a full firing mode suite, including variable voltage, curve mode, temperature control presets for Ni200 nickel, titanium, and stainless steel heating elements as well as adjustable TCR and TFR modes. The Colossal also utilizes an Asmodus developed "battery safe connection" on the positive battery port which provides a safer, more secure connection by encasing the port with a plastic rim which forces the battery to stay in place. A USB port (for firmware updating) has been implemented as well to ensure that your mod is always up to date. This item also has other colors to choose. ![]() Original Vapefly Galaxies MTL Squonk RDTA Rebuildable Dripping Tank Atomizer with BF Pin Original Price $43.49, Now Only $24.59 The Original Galaxies MTL Squonk RDTA is an innovation of RDTA that features wide selection to fit different MTL vaping needs, and both top filling and bottom feeding without leakage. It is a 22mm RDTA and has 2ml of juice capacity. The bottom and side airflow channels makes 360 degrees surrounding airflow. There are 6 options airflow control and unique limitless screw AFC system, which offer wide selection for MTL vaping. This RDTA comes with bottom feeder pin. This item also has other colors to choose. ![]() |
Vapeasy Jazz RDA Rebuildable Dripping Atomzier Clone with BF Pin $13.99
The Vapeasy Jazz RDA Clone is a 22mm BF RDA made from 316 stainless steel. The RDA has sandblasting finish. It comes with innovative 6 clamps deck which offers a variety of possibilities for building coils in a very simple way. It has triple airflow on both side for great flavor. This RDA comes with bottom feeder pin. ![]() Original Fumytech Purely GT Sub Ohm Tank Clearomizer Original Price $18.90, Now Only $8.59 The Fumytech Purely GT Tank is a 22mm clearomizer with 3.8ml of juice capacity. It is compatible with 0.2ohm Ni200 coil and 0.5ohm Kanthal coil. The tank comes with 2 air intake holes. ![]() Original Fumytech Purtank 2 Sub Ohm Tank Clearomizer Original Price $18.90, Now Only $8.99 The Fumytech Purtank 2 Tank is a 19mm clearomizer with 3.2ml of juice capacity. It is compatible with Purely 0.7ohm / Purely 0.9ohm coil / Purely plus BVC 0.7ohm coil. The tank comes with adjustable airflow and gold 510 connector pin. This item also has other Version to choose. ![]() Original Fumytech Purelytank 2 Sub Ohm Tank Clearomizer Original Price $15.90, Now Only $10.99 The Fumytech Purelytank 2 Tank is a 16.5mm clearomizer with 3ml of juice capacity. It is compatible with 0.7ohm and 0.9ohm coil. The tank comes with a special leakage preventing cup structure inside the air inlet and magnetic connecting structure on the base. ![]() Original Fumytech Mini Fumytank 3 Sub Ohm Tank Clearomizer Original Price $18.90, Now Only $9.99 The Fumytech Mini Fumytank 3 Tank is a clearomizer with 2.5ml of juice capacity. It is compatible with Mini Fumytank 3 Coil, which is 1.0ohm resistance. The coil works well at 6~30W, and best at 14~22W. This item also has other colors to choose. ![]() Original Fumytech Rose MTL RTA Rebuildable Tank Atomizer Limited Edition Original Price $49.90, Now Only $29.99 The Original Fumytech Rose MTL RTA, designed for mouth-to-lung vaping, is a 24mm tank with 3.5ml juice capacity. It features threaded top filling, dual post build deck, and fully adjustable bottom airflow, with totally 8 airholes for configuration. With the domed chamber and 3mm bore POM drip tip, this tank will bring you smooth vapor and pure flavor. ![]() Original Fumytech Vendetta RDA Rebuildable Dripping Atomizer Original Price $35.90, Now Only $21.99 The Original Fumytech Vendetta RDA is a 24mm RDA made of stainless steel. It features the Vendetta guy design and clamp style dual post deck. The RDA comes with side airflow system. Gold plated 510 pin provides great conductivity. ![]() ShenRay B2K RSA V5 RDA Rebuildable Dripping Atomizer Clone with BF Pin $22.59 The ShenRay B2K RSA V5 RDA Clone is a 24mm RSA & RDA which has postless build deck for single coil builds. It is easy to mount coils with such structure. The side airflow will bring you smooth, quiet and extremely flavorful vape experience. It comes with 4 caps, decorative rings and drip tips. ![]() Original Fumytech Purely 2 1650mAh Starter Kit Original Price $35.90, Now Only $21.99 The Original Fumytech Purely 2 Kit is a compact starter kit for those who are looking for simple and convenient vape device. It has built-in 1650mAh battery and 3.2ml atomizer capacity. The tank supports Purely 0.7ohm / 0.9ohm coil / Purely Plus BVC 0.7ohm coil. This item also has other Atomizer Capacity to choose. ![]() Original Fumytech Purely Pocket 2300mAh Starter Kit Original Price $56.90, Now Only $34.99 The Original Fumytech Purely Pocket Kit consists of Purely Pocket 2300mAh battery and Purelytank II Tank. The kit is really easy to use, just one button to turn on / off and vape. It comes with tank visible structure and no leakage design. The tank has 3ml of juice capacity and there are 2 coils for options, 0.7ohm and 0.9ohm. The tank has magnetic connecting structure on the base for convenient connection. This item also has other colors to choose. ![]() Original Fumytech Vapomix All-in-One Starter Kit Original Price $129.00, Now Only $55.99 The Original Fumytech Vapomix Kit is the first vaporizer in this entire vape market which combining medicinal herbs and e-liquid together so that you can experience otherworldly flavors. You can easily adjust the temperature by pressing the plus or minus button. It comes with Eco-Friendly Ceramic design for the heating chamber, and a stainless steel heating tank for paste stuff. It is so convenient for you with changeable two 18650 batteries (BATTERIES NOT INCLUDED) to insure that you can use it whenever you want, and it also offers USB charge as to make your vape life easier and more enjoyable. This item also has other colors to choose. ![]() Vapeasy Replacement 510 Drip Tip + Top Cap Kit for Jazz RDA Clone $5.99 The replacement 510 drip tip and top cap are made from PC and is suitable for Vapeasy Jazz RDA Clone. This item also has other colors to choose. ![]() Original Fumytech Replacement Coil for Purely Tank Original Price $16.90, Now Only $7.99 The replacement coil has 0.7ohm resistance and works well at 6~25W. It is suitable for Original Fumytech Purely Tank. This product comes with 5 PCS in 1 pack. This item also has other Version to choose. ![]() Original Fumytech Replacement Ni200 Coil for Purely GT Tank Original Price $18.90, Now Only $7.69 The replacement Ni200 coil has 0.2ohm resistance and is suitable for Original Fumytech Purely GT Tank. This product comes with 5 PCS in 1 pack. This item also has other colors to choose. ![]() |
Original Tesla Invader IV 280W VV Variable Voltage Box Mod Original Price $73.90, Now Only $48.49
The Original Tesla Invader 4 Box Mod is made of aluminum alloy with sandblasting oxidation process to made the mod look perfect. It adopts an advanced chipset that can support low resistance low to 0.08ohm. Powered by dual 18650 / 20700 / 21700 batteries (NOT INCLUDED), the mod can adjust voltage from 3 to 8V and reach maximum output to 280W. This item also has other colors to choose. ![]() Original Lost Vape Triade DNA250C 300W TC VW Variable Wattage Box Mod Original Price $149.00, Now Only $123.89 After the Paranormal DNA250C Mod, Lost Vape brings us another DNA250C Mod, the Lost Vape Triade DNA250C, which is powered by triple 18650 batteries (NOT INCLUDED) and can fire up to 300W. The DNA250C chip features unique Replay mode, which allows vapers to select their own perfect vape and save to replay it over and over. This item also has other colors to choose. ![]() Original Advken Manta Sub Ohm Tank Atomizer Original Price $39.99, Now Only $26.69 The Originalc Advken Manta Tank is a 24mm sub ohm tank with 5ml large e-juice capacity. Besides, the tank features sliding top cap for easy top filling and adjustable bottom airflow. It comes with 0.16ohm and 0.2ohm Mesh Coil, which would bring you different vaping experience. This item also has other colors to choose. ![]() Vital RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Vital RDA Clone with in 24mm diameters is constructed from stainless steel. The build deck comes with dual post design for single and dual coil building. It features teardrop airflow, engraved pattern and locking cap that prevents the e-juice from leaking. Removable 810 wide bore drip tip and bottom feeder pin are included. The resin drip tip will be in random color. More color than what's on the image. ![]() Original Oumier Wasp Nano Mini RDA Rebuildable Dripping Atomizer with BF Pin $13.49 The Original Oumier Wasp Nano Mini RDA is constructed from stainless steel in 22mm diameter. The Original Oumier Wasp Nano Mini RDA is with large build deck design for single coil build. This RDA has direct side airflow design to ensure fabulous vaping experience. The RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Ironsmith Furnace RDA Rebuildable Dripping Atomizer with BF Pin Original Price $49.50, Now Only $31.99 The Original Ironsmith Furnace RDA is a 22mm squonk RDA that features single coil build deck and concealed side array airflow. It comes with a single coil build deck for single round wire or premade coil. The double layer barrels is heat-resistant. 510 PEI drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original OBS Engine 2 RTA Rebuildable Tank Atomizer Limited Edition Original Price $36.99, Now Only $28.49 The Original OBS Engine II RTA, the updated version of OBS Engine RTA, is a dual coil RTA with 5ml of juice capacity. It is easy to build dual coils on this build deck. The Engine 2 also features the precise design of air circulation system to concentrate the vapor and enhance the flavor. ![]() Vapeasy Pico Femto BF RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $19.99, Now Only $10.99 The Vapeasy Pico Femto BF RDA is a 22mm single coil squonk ready RDA with direct bottom airflow, which provides a rich and silky vapor production in MTL to Semi-DL setup. There is a crank shaped narrow juice path hidden beneath the deck, which will prevent the juice leaking. According to the manufacturer's information, Vapeasy will produce this product at 1:1 scale as scheduled, and 3FVAPE is convinced that we will get the first batch of this product in China. As for Vapeasy, it has been appreciated that their product has almost the same quality as SJMY. ![]() Vapeasy Biatch BF RDTA Rebuildable Tank Atomizer Clone with PEI Tank + 510 Drip Tip $14.99 The Vapeasy Biatch RDTA Clone is a 22mm single coil RDTA which integrates the build deck and tank as one piece. Constructed from 316 stainless steel (top cap, deck) and PC (tank), the RDTA has been designed to combine the best of PitBull and Doggystyle into a convenient and compact BF atomizer. The side airflow air slot is 5mm by 1.2mm, which is adjustable. The postless build deck allows single coil building. The tank has about 1.5ml of juice capacity. The replacement tank tube and drip tip is made from PEI. The tube is 22mm in diameter and with 1.5ml of juice capacity. The 510 drip tip is 9mm in height. This RDTA comes with bottom feeder pin. ![]() Original Joyetech eGo AIO 1500mAh 10th Anniversary Limited Edition Starter Kit $22.99 Being all-in-one style, this eGo AIO is as user-friendly as its first version but is a special edition of Joyetech 10th anniversary. Featuring vibrant LED tank lights and 1500mAh internal battery to pair with the anti-leaking TFTA structure. SS316-0.6ohm head, with stainless steel coil, supports mouth-to-lung inhale, creating great vaping experience of nice taste and vapor clouds. Beside the child lock design, a wealth of safety protection measures is included. The Joyetech eGo AIO is simple and easy to use. Good for both starters and experienced vapers. This item also has other colors to choose. ![]() SXK Billet Box 60W All-in-One Box Mod Kit Clone with USB Port Original Price $109.00, Now Only $100.99 The SXK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This Billet Box comes with USB port for firmware upgrading, setting modification and user customization via software. This item also has other colors to choose. ![]() Original Tesla Invader IV 280W VV Variable Voltage Box Mod + RDA Kit with 20700 Battery Original Price $95.90, Now Only $65.59 The Tesla Invader IV Kit consists of Tesla Invader IV Box Mod and Tesla Invader IV RDA. The Original Tesla Invader 4 Box Mod is made of aluminum alloy with sandblasting oxidation process to made the mod look perfect. It adopts an advanced chipset that can support low resistance low to 0.08ohm. Powered by dual 18650 / 20700 / 21700 batteries, the mod can adjust voltage from 3 to 8V and reach maximum output to 280W. Please note: this kit comes with 2 x 20700 batteries. This item also has other Version to choose. ![]() |
Coil Father Hades Squonk Mechanical Box Mod Clone $18.99
The Coil Father Hades Squonk Box Mod Clone is made from Resin with a 7ml silicone bottle. It is powered by a single 18650 battery (NOT INCLUDED). With a flip-type magnetic battery door, it is easy to take off. The mod is compact and fits your palm perfectly, it will bring you great squonking experience. The color may vary a bit due to resin material. ![]() Original FLHS Tiger Squonk Mechanical Box Mod $64.99 The Original FLHS Tiger Mech mod is a 20700 squonk box mod with stunning tiger pattern on the battery door. Made from durable Bakelite material, it is powered by single 20700 battery (NOT INCLUDED). This mod will bring you excellent squonking experience. ![]() Original Vapefly x German 103 Team Core RTA Rebuildable Tank Atomizer Original Price $38.49, Now Only $26.99 The Original Vapefly x German 103 Team Core RTA is a 25mm rebuildable tank atomizer that features powerful "Q" airflow system which delivery great flavor without heat and a super easy-to-build deck for single or dual coil builds. The tank comes with 2ml standard glass and 4ml bubble glass for your option. It is a cloud monster indeed. About German 103 Team: German 103 design Team is organized by Martin Hartkopf & Vapefly. Martin is professional in vaping and reviewing vaping gears for many years known as dampfwolke. He always want to communicated to the vaping community for people's healthy and better experience. So he called up a group of people who are enthusiastic in vaping and have the same aim to search vapers needs, and think out great ideas to create better atomizer. They are 103 members in this group, almost all the members come from German. It is so-called German 103 Team. This item also has other colors to choose. ![]() Original ThunderHead Creations THC Tauren Vaper Cap $14.99 The vaper cap from ThunderHead Creations THC is a cool accessory for all the vapers. This item also has other colors to choose. ![]() Original Shield Cig Adjustable 510 Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $3.79 The replacement 510 drip tip is made from resin and stainless steel. It is suitable for all atomizers that fit 510 drip tip. The drip tip height is adjustable from 14mm to 17mm. This drip tip will be shipped with random pattern / logo on it (1 piece). More options than what's on the image. This item also has other colors to choose. ![]() Original Shield Cig Adjustable 810 Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $3.99 The replacement 810 drip tip is made from resin with 11mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. The drip tip height is adjustable from 11mm to 15mm. This drip tip will be shipped with random pattern / logo on it (1 piece). More options than what's on the image. This item also has other colors to choose. ![]() Coppervape Replacement 510 Drip Tip for Skyfall RDA Clone $1.59 The replacement 510 drip tip is made from POM. It is designed for Coppervape Skyfall RDA Clone, but is also suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose. ![]() Coppervape Replacement Top Cap for Skyfall RDA Clone $3.59 The replacement top cap is made from PC and is suitable for Coppervape Skyfall RDA Clone. This item also has other colors to choose. ![]() Original Wotofo Replacement 810 Drip Tip for Recurve RDA $3.99 The replacement 810 drip tip is made from acrylic and is suitable for Original Wotofo Recurve RDA. This item also has other colors to choose. ![]() Coil Father Replacement BF Bottle for Hades Squonk Box Mod Clone $2.99 The replacement squonk bottle is made from silicone and is suitable for Coil Father Hades Squonk Box Mod Clone. It has 7ml of juice capacity. ![]() Original Vapefly Replacement Bubble Glass Tank Tube for Core RTA Original Price $3.00, Now Only $2.29 The replacement bubble glass tank has 4ml of juice capacity and is suitable for the Core RTA by Vapefly & German 103 Team. This item also has other colors to choose. ![]() |
AV Aileron Hybrid Mechanical Tube Mod Clone $25.49
The AV Aileron Mechanical Tube Mod Clone is a 24mm mech mod made from brass. It comes with hybrid top cap and spring fire button. It is powered by single 18650 battery (NOT INLCUDED). This item also has other colors to choose. ![]() AV Kane Hybrid Mechanical Tube Mod Clone $21.99 The AV Kane Mechanical Tube Mod Clone is a mech mod made from brass. It comes with hybrid top cap and magnetic fire button. It is powered by single 20700 battery (NOT INLCUDED). ![]() US1 V2 RDA Rebuildable Dripping Atomizer Clone $9.59 The US1 V2 RDA Clone is a 24mm RDA made from stainless steel. The deck comes with dual posts, which has large holes for fancy coil builds. The airflow is adjustable for optimal flavor. The RDA comes with extra cap. This item also has other colors to choose. ![]() Kindbright Centurion V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $21.99 The Kindbright Centurion V2 RDA Clone is a 30mm BF RDA made from 316 stainless steel. It is a large RDA with triple-post build deck for dual coil builds. The airflow is adjustable for optimal flavor. The RDA comes with 2 extra caps and 1 PEI drip tip. This RDA comes with bottom feeder pin. ![]() Original GeekVape Cerberus Sub Ohm Tank Clearomizer Original Price $33.90, Now Only $20.99 The Original GeekVape Cerberus sub ohm tank is optimized by the ultimate Super Mesh coil that maximizes heating contact surface area in order to provide maximum flavor and large vapor production. Super Mesh Coils are compatible with Aero Mesh tank too. The tank comes with 27mm diameter and 4ml of juice capacity. This item also has other colors to choose. ![]() Original UltimaVape Banaspati RDA Rebuildable Dripping Atomizer with BF Pin Original Price $35.00, Now Only $29.99 The Original UltimaVape Banaspati RDA is a 24mm RDA designed for cloud chasing. The dual posts design allow dual coil builds and the post holes are large for fancy coils. The 510 connector pin is gold plated for better conductivity. The side airflow is adjustable for optimal flavor. Ultem 810 drip tip is included. This RDA comes with bottom feeder pin. ![]() Tab RSA RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.50 The Tab RSA RDA Clone is a 22mm rebuildable squonking atomizer constructed from 316 stainless steel. It features innovative wicking method around the positive pole and 360-degree surrounding airflow. This RDA comes with bottom feeder pin. ![]() Vapor Giant v5 M RTA Rebuildable Tank Atomizer Clone $33.50 The Vapor Giant v5 M RTA Clone is a 25mm rebuildable tank atomizer with 8ml of juice capacity. It features dual post build deck for single coil builds and lockable liquid control function. The adjustable bottom airflow will bring great flavor to every puff. ![]() Original Hugsvape Coil Trimming Tool for DIY Building $1.99 The Original Hugsvape Coil Trimming Tool is a convenient tool for perfect coil builds. First, measure the post width, then put the coil into the corresponding slots, finally cut the leads. ![]() Original Fumytech Micro USB Cable Original Price $4.50, Now Only $2.59 The Original Fumytech Micro USB Cable 1A is suitable for e-cig mods and other digital devices. This item also has 2A fast charging to choose. ![]() Original Fumytech USB Wall Charger Adaptor Original Price $5.90, Now Only $3.69 The Original Fumytech USB Wall Charger Adaptor is suitable for e-cig mods and other digital devices. This adaptor is US plug.and also has EU Plug to choose. ![]() Original Fumytech Screwdriver Original Price $6.90, Now Only $4.99 The Original Fumytech screwdriver comes with 4 different bits, which are PH00, 2.5, H1.27 and H1.50. ![]() Original Fumytech Multiscrew Box Original Price $12.90, Now Only $8.99 The Original Fumytech Multiscrew Box comes with 8 different screws for your options. ![]() Original Fumytech Unikase M Multi-functional Case Bag for E-Cigarette Original Price $13.90, Now Only $9.99 The Fumytech Unikase is a multi-functional, multi-purpose adjustable case for all of your gear. Carry your mods, atomizers, e-juice, wicking supplies, tools, and so much more. Everything you need for vaping can now be carried in one convenient case. The Fumytech Unikase closes together with a high-quality zipper for easy access. The inside is lined with cushioning material for your delicate items, while the exterior shell is firmer to provide increased protection. This item also has other Version to choose. ![]() Original Fumytech Unikase Deluxe XL Multi-functional Case Bag for E-Cigarette Original Price $34.90, Now Only $28.99 The Fumytech Unikase Deluxe is brilliantly designed with a series of adjustable elastic straps on one side of the case, and a large mesh pocket on the other. The elastic straps can be made to fit virtually any item you want to securely carry. The expandable straps firmly hold your precious vape gear in place, virtually eliminating the risk of the shifting around while in motion. The large pocket on the other side of the Fumytech Unikase Deluxe is designed with mesh netting making it semi-transparent to allow you to easily see the contents inside. The strap portion of the Unikase Deluxe is perfect for batteries, MODs, APVs, clearomizers, RBAs, tanks, tools, glass e-liquid bottles, and virtually anything else you want to keep in place while on the go. The Fumytech Unikase Deluxe closes together with a high-quality zipper for easy access. The inside is lined with cushioning material for your delicate items, while the exterior shell is firmer to provide increased protection. The synthetic leather materials used in this exterior shell makes it both fashion and deluxe. To give it more easy to carry, Fumytech present an shoulder strap along with the case. Buckle the metal carabiner in the edge of the exterior zipper. You can carry it with your shoulder. This item also has other colors to choose. ![]() Original Fumytech Purely DIY Kit for Coil Building Original Price $29.99, Now Only $26.59 The Original Fumytech Purely DIY Kit is a multi-functional tool kit designed for vape. The kit includes 1 x Multifunctional Screwdriver, 1 x Diagonal Pliers, 1 x Folding Scissors, 1 x Ceramic Tweezers, 1 x Coiling Jig Kit, and 1 x Cotton. ![]() AV Stealth Top Cap Clone for Battle RDA Clone $5.99 The AV Stealth Cap Clone is made from aluminum and suitable for Battle style deck. This item also has other colors to choose. ![]() [Исправлено: 3FVAPE, 25.07.2018 в 05:21] |
