Просмотров в теме 260404   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 09.12.2020, 15:01 Автор темы   801
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original SXK Unit Tank Unitank / Uni Tank for SXK Supbox / Supbox Pro Box Mod Kit / SXK BB - Acrylic, 5.0ml, New Version Original Price $8.9, Now Only $5.99.
The Original SXK Unit Tank / Unitank / Uni Tank is made from Acrylic with 5.0ml capacity. The new version is compatible most of the BB RBA Bridge. The New Version is new refilling port, and the parting line is upper than the old one.
The Tank is suitable for SXK Supbox / Supbox Pro / Billet Box Mod Kit / SXK BB 60W / 70W Vape Box Mod Kit
SXK BY-kA V9 MTL RTA Nano Set Clone Original Price $29.8, Now Only $27.5.
The SXK BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer Nano Version holds 3.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping. This is the Nano Version in 3.0ml.
Original VXV Soulmate RTA Pod Cartridge for Voopoo Drag S / X / MAX / ARGUS Pro Original Price $29.99, Now Only $24.99.
The Original VXV Soulmate RTA Pod Cartridge is suitable for the adjustable bottom airflow of Voopoo Drag series and Argus Pro (Voopoo Drag S / X / MAX / ARGUS Pro Pod System). The VXV RTA Pod is with single coil building deck and holds 2.5ml capacity. The bottom refilling port is on the bottom with silicone plug.
Original VXV Soulmate RTA Pod Replacement Tank Tube + 510 Drip Tip Original Price $9.99, Now Only $7.99.
The Original VXV Replacement Tank Tube and 510 Drip Tip is suitable for Soulmate RTA Pod Cartridge.
SXK Replacement Standard Set Chimney + Tank Tube for KA V9 clone RTA 5.0ml Original Price $14.9, Now Only $12.5.
The SXK Replacement Standard Set including Chimney and Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity.
SXK Replacement PEI Long Tank Tube for KA V9 clone RTA - 5.0ml Original Price $7.9, Now Only $6.5.
The SXK Replacement PEI Long Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity.
SXK Replacement PEI Tank Tube for KA V9 clone RTA - 3.0ml Original Price $6.9, Now Only $5.5.
The SXK Replacement PEI Tank Tube is suitable for KA V9 clone RTA and holds 3.0ml capacity.
3FVAPE вне форума   Вверх
Старый 10.12.2020, 12:02 Автор темы   802
3FVAPE
AV MIP5 Stackable Mechanical Mod Clone $20.99
The AV M1P5 Style mechanical mod comes with the mod only or with the stackable tube extension, powered by 1 / 2 x 18650 battery (not included). The AV MIP5 Style Mechanical Mod is with adjustable magnetic bottom firing button.
Replacement Resin 810 Drip Tip w/ O-Ring $1.79
The Replacement 810 Drip Tip is made from resin and comes with silicone O-Rings. It is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
Original VAPJOY DIY Rebuild Kit for Caliburn G Coil - 0.8ohm, A1 Mesh Coil (10 PCS) + Cotton (20 PCS) $3.99
The Original VAPJOY DIY Rebuild Kit is suitable for Uwell Caliburn G coil. Comes with 10 PCS Mesh coil and 20 PCS Cotton.
Original OBS Pluck Tank Atomizer - 3.5ml, 1.0ohm / 0.4ohm $9.99
The Original OBS Pluck Pod Cartridge Atomizer consists of a transparent pod cartridge and an atomizer 510 base with an air ring. has an integrated proprietary drip tip, which can be slid back and forth through the top filling system to expose the filling port and close firmly. Two OM coils and replacements are readily available included. Perfect for RDL (restricted direct lung) and MTL (mouth to lung) vaping.
Старый 11.12.2020, 13:26 Автор темы   803
3FVAPE
YFTK Squape A[rise] Squ Arise clone RTA - Black $29.99
YFTK SQuape A Rise Squ A[rise] clone RTA Vape Atomizer is made from 316 stainless steel and PSU. The 24mm RTA holds 4.0ml and supports DL / MTL Vaping.The Air Discs diameter: 1 x 1mm / 2 x 0.8mm / 3 x 0.8mm / 4 x 0.8mm.This Squ A[rise] Arise clone RTA supports to convince both as Direct to lung (DL) and Mouth to lung (MTL). The easily convert from DL to MTL and thus offers you complete flexibility.Comes with chimney air reducer.
Original Wotofo Profile M RTA Rebuildable Tank Vape Atomizer Original Price $37.95, Now Only $26.99.
The Original Wotofo Profile M RTA is a Mesh RTA Rebuildable Tank Vape Atomizer. The 24.5mm Mesh RTA is with stylish 810 drip tip on the easy-to-use push-open clone top cap, and the liquid filling hole is hidden under the top cap. The Mesh RTA comes with two tank tubes, the standard glass tube has a capacity of 3.1ml, while the spare PCTG bubble glass tube has a capacity of 4.0ml. Use push-open clone top cap to fill e-juice quickly and cleanly from above. Wotofo Profile M RTA adopts a postless build deck with an open fixture structure that ensures easy installation of mesh coil. Profile M RTA can utilize single coil / mesh sheet coils, side secured via Phillips screws, and is also compatible with nexMESH series steel mesh which is suitable for Profile / Profile Unity. And it has a well-designed top airflow system. The air passes through the continuously adjustable top AFC. With a porous honeycomb air outlet, this makes Profile M RTA almost completely leak-proof. The air can flow perfectly and evenly in the mesh hole, and force the flavor and vapor to be produced.
AV Able clone Vape Mechanical Mod $14.99
The AV Able clone mechanical mod is made from brass and aluminum. It is powered by 1 x 18650 battery (not included). The adjustable brass bottom-fire button with opposing earth magnet will be very easy for you to use. Carbon fiber sleeve for better heat dissipation.
AV Able clone Vape Mechanical Mod + Apocalypse GEN 2 clone RDA Kit $20.99
The Mechanical Mod Kit consists of AV Able clone mechanical mod and Apocalypse Gen 2 clone RDA.
The Apocalypse Gen 2 clone RDA is with clamp design and has a massive 13mm space in each clamp which provides space for mounting the most complex and insane coil builds. The RDA is constructed from aluminum (cap) and stainless steel (base). Coupled with the 4mm deep juice well, 21mm build deck, durable post clamps and extended post screws, the Apocalypse Gen 2 clone RDA is a builder's dream.
Original Wotofo Profile M RTA Replacement NexMESH Clapton S Mesh Coil $4.99
The Original Wotofo NexMESH Clapton S Mesh Coil is made from Ni80 and A1 in 0.15ohm resistance. The Mesh-clone Clapton coil is mixed with Ni80 and A1, brings Maximized Performance,
Perfect for Wotofo Profile M RTA, 5 PCS / Pack
Original Wotofo Profile M RTA Replacement PCTG Tank Tube $1.99
The Original Wotofo Profile M RTA Replacement Tank Tube is made from PCTG and holds 4.0ml capacity.
Original Wotofo Profile M RTA Replacement Glass Tank Tube $1.99
The Original Wotofo Profile M RTA Replacement Tank Tube is made from Glass and holds 3.1ml capacity.
Original Wotofo Profile M RTA Replacement 810 Drip Tip $2.99
The Original Wotofo Replacement 810 Drip Tip is made from resin and suitable for Profile M RTA Mesh RTA Vape atomizer. This Wotofo 810 drip tip is also compatible with other vape atomizer with 810 connection.
Старый 12.12.2020, 14:23 Автор темы   804
3FVAPE
Original Dovpo Riva DNA250C 200W Box Mod $149.99
The original DOVPO Riva DNA250C Vape Box Mod is powered by dual 18650 batteries (not included) mod features the EVOLV DNA 250C chipset to ensure the great performance from fast firing speed to various of advanced settings. On the appearance, DOVPO utilizes real leather with zinc alloy for the first time, results the great combination of great feeling and aesthetic. In a word, this DOVPO Riva DNA250C Mod is absolutely the competitor you can't be discounted.
Original SXK ETU for Supbox / Billet / BB / Bantam Revision - Compatible with SMOKTech SMOK RPM Series Coil Original Price $9.9, Now Only $8.6.
The SXK ETU is including PC Tank, Stainless Steel Connector and POM Base. The SXK ETU is Compatible with SMOKTech SMOK RPM Series Coil heads. It is suitable for Billet Box / SXK BB 70W / DNA 60W, SXK Supbox Pro 60W / SXK Supbox 70W and SXK Bantam Revision 30W Mo
Старый 14.12.2020, 13:19 Автор темы   805
3FVAPE
Original YDDZ A1 510 Thread Adapter Connector for dotMod dotAIO $8.89
The YDDZ A1 510 Thread Adapter Connector is designed for dotMod dotAIO Pod System Vape Kit as a replacement part, which is made from POM (white Part) and Stainless Steel (Silver Part). With this 510 adapter, you can use 510 atomizer (RTA / RDA / RDTA / Tank) on your dotMod dotAIO Pod System.
Original YIHI SXmini SL Class 100W SX485J TC VW Box Mod Original Price $174.99, Now Only $59.99.
The Original YiHi SXmini SL Class SX485J 100W vape Box Mod is the next luxurious device from YiHi's unrivaled line-up, powered by 18650 / 20700 / 21700 battery (not included) platform with a premium frame chassis and high-end grip design. The high-end impression is complemented with ergonomic construction design, making the SXmini SL Class a phenomenal all-day vape option.
Original Oumier Blade TC VW Box Mod $45.99
The Original Oumier Blade is a high-power vape box mod with advanced technology and powerful performance. It supports IP67 waterproof and comes with an integrated 1.3" TFT screen with multi-touch support. Adopts ergonomic and durable shell design, made of high-quality materials. The box mod adjustment buttons have been integrated with the color touch screen, which is easy to use and the body is simpler and smoother.
Original Innokin EQ Fltr Pod System Heating Kit $25.99
The Original Innokin EQ FLTR Pod System is specially designed for smokers who want to quit smoking. This easy-to-use pod system has a filter similar to a cigarette.
Старый 15.12.2020, 12:06 Автор темы   806
3FVAPE
ULTON SHU MTL RTA Clone $26.59
The ULTON SHU Style MTL RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel and glass tank. The 22mm RTA holds 4.0ml capacity. The SHU Style RTA is with 0.8mm / 1.0mm / 1.2mm / 1.5mm air pins for MTL Vaping. The SHU Style RTA is with dual pole for single coil building.
Original Curdo Odin Mini 30W Pod System Kit Original Price $29.99, Now Only $14.99.
The original Curdo Odin Mini Pod System is powered by a 650mAh built-in battery with max 30W output, and comes standard with 1.0ohm mesh coil pod cartridge, designed to deliver the best flavor for the vaping style. In addition, Odin Mini allows you to access all basic vaping data through a 0.87-inch OLED screen. Innovation keeps changing the vaping experience
Replacement PCTG Tank Tube for ULTON Dotshell / DotMission Style RBA $4.59
The tank tube is made from PCTG and is Suitable for ULTON Dotshell / DotMission Style RBA.
Replacement Tank Tube for Flash e-Vapor V4.5 / V4.5S+ RTA $9.99
The Replacement Tank Tube is made from stainless steel and glass, and t is suitable for Flash e-Vapor V4.5 / V4.5S+ RTA. The 23mm tank tube holds 3.0ml capacity.
Original Curdo Odin Mini Replacement Pod Cartridge $7.99
The original Odin Mini Pod Cartridge is suitable for the Curdo Odin Mini Pod System Kit. The Pod Cartridge is with 2.0ml capacity and with translucent design, side filling system, with a dustproof cap, Built-in 1.0ohm mesh coil in cartridge to deliver the best flavor.
Старый 16.12.2020, 16:52 Автор темы   807
3FVAPE
Original Lost Vape Ursa Quest Multi Pod Mod Kit 100W Box Mod + Ursa Pro Pod Tank $49.99
Original Lost Vape Ursa Quest Multi Kit is with the best flavor as a sub-ohm tank, and has the same powerful power as a box mod, and has a compact size. The Ursa Quest Multi Kit adopts a stronger zinc alloy with a chassis made of genuine leather and solid wood to form an elegant and luxurious perfect artwork. Ursa Quest Mod is powered by 1 x 21700, 20700, or 18650 battery (not included) for power supply. When using 21700 batteries, the maximum output power of the kit is 100 watts. The package includes an adapter sleeve for using 18650 batteries. Hight wattage to stay strong and powerful for all-day vaping. The built-in high-performance Quest chipset provides various steam modes, such as Variable Wattage, Variable Voltage, TC, and Bypass, as well as VPC mode for setting your own performance curve and Boost mode with three different intensities. Three additional boost levels, two vape Clones, and three user records to provide a highly customized vaping experience.
Original VOOPOO Argus X 80W Pod System Vape Mod Kit $31.99
The Original VOOPOO Argus X Pod System is the external single battery version of Argus Pro, which has the same manufacturing craft and performance, almost the same compact body size. The combination of the innovative chipset, modern USB Type-C charging, and extensive PnP coil compatibility including RBA perfectly showcases this excellent kit. Argus X is powered by a single 18650 battery (not included), which can provide you with the versatility you need for a Pod Mod device. Open the cover at the bottom to install the battery. On the adjacent side of the mod, you find the firing button, a vibrant display screen, up and down adjustment buttons, and a conveniently located USB Type-C port. Powered by the upgraded GENE.TT Chipset, this new system allows you to unlock new levels, based on the cloud size of each puff you take. This smart chipset supports an ultra-fast firing speed of 0.001s, a maximum output power of 80W, and a coil auto-recognition system.
SXK Perseus RTA Clone 22mm Diameter Original Price $29.9, Now Only $27.5.
SXK Perseus Clone RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel and glass. The Perseus Clone RTA comes spare glass holder for holding 2.0ml / 4.0ml capacity. The SXK Perseus Clone RTA comes with unique EXIT PIN.
SXK Perseus RTA Replacement Air Pin Clone - 1.0mm / 1.2mm / 2.0mm (3 PCS) Original Price $7.9, Now Only $5.9.
The Air Pin comes with 3 Size: 1.0mm / 1.2mm / 2.0mm and suitable for SXK Perseus Clone RTA
SXK Perseus RTA Replacement PEI Tank Tube Clone Original Price $5.9, Now Only $4.5.
The SXK Replacement Tank Tube is made from PEI and suitable for Perseus Clone RTA.
SXK Perseus RTA Replacement Glass Tank Tube Clone Original Price $2.5, Now Only $1.5.
The SXK Replacement Tank Tube is made from Glass and suitable for Perseus Clone RTA.
Старый 17.12.2020, 17:12 Автор темы   808
3FVAPE
VG Extreme V2 RTA Clone 23mm $21.99
The VG Extreme V2 clone RTA Rebuildable Tank Vape Atomizer is in 23mm diameter and holds 6.5ml capacity. The VG Extreme V2 clone RTA supports dual / single coil building and DL / RDL / MTL Vape. The airflow control is adjustable via Air Pins, Winding is supplied air from three sides (frontal, bottom, diagonal top).
SXK In'Ax Carto V2 RBA Clone for BB / Supbox /Bantam Revision Original Price $29.9, Now Only $26.5.
The SXK In'Ax Carto V2 clone RBA is a rebuildable Genisis Atomizer, with center-mesh wicking and standard Carto dimensions that fits in to any application that fits this form factor. It is suitable for Billet Box / SXK BB 70W / DNA 60W, SXK Supbox Pro 60W / SXK Supbox 70W and SXK Bantam Revision 30W Mod Kit.
3.5ml Replacement Tank Tube + Chimney + 510 Drip Tip for Flash e-Vapor V4.5S $5.99
The Replacement bell cap kit includes PC Tank Tube, Stainless Steel Chimney and PC 510 Drip Tip. It is suitable for Flash e-Vapor V4.5S clone RTA Tank vape atomizer. The tank tube holds 3.5ml capacity.
2.5ml Replacement Tank Tube + Chimney + 510 Drip Tip for Flash e-Vapor V4.5S $5.99
The Replacement bell cap kit includes PC Tank Tube, Stainless Steel Chimney and PC 510 Drip Tip. It is suitable for Flash e-Vapor V4.5S clone RTA Tank vape atomizer. The tank tube holds 2.5ml capacity.
Flash e-Vapor Style 510 Drip Tip $3.99
The Flash e-Vapor clone 510 Drip Tip is made from PEI (mouthpiece) and Stainless steel (base). The 510 drip tip is suitable for RDA / RTA / RDTA Vape Atomizer.
Старый 18.12.2020, 16:30 Автор темы   809
3FVAPE
Original ThunderHead Creations THC Tauren MTL RTA 24mm Original Price $41.9, Now Only $30.99.
ThunderHead Creations THC Tauren MTL RTA comes with a brand new airflow design hopes to bring a revolution to the MTL industry.Featuring with 61 PCS precise air holes hit the coil directly in a small chamber to offer you top-notch flavor.
ULTON SHU MTL RTA Clone Rebuildable Tank Atomizer 23mm $26.59
The ULTON SHU Style MTL RTA Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel and glass tank. The 23mm RTA holds 4.0ml capacity. The SHU Style RTA is with 0.8mm / 1.0mm / 1.2mm / 1.5mm air pins for MTL Vaping. The SHU Style RTA is with dual pole for single coil building.
Original Asmodus Dachi 2-in-1 80W VW Mod Pod System Vape Starter Kit Original Price $39.9, Now Only $29.99.
The authentic Asmodus Dachi is a 2 in 1 Pod System Vape Mod Kit with a novel design. Pod mod have become super fashionable as they're designed to deliver mod like performance in the form of a super portable pod system. Asmodus Dachi 2 in 1 Pod Mod Kit has arc design on both sides and the compact structure with matte panel is fairly comfortable to hold. Above the main body of the device is the airflow hole, and in the middle is the fire button. There is a display screen under the button. Asmodus Dachi 2 in 1 Pod Mod Kit is powered by a replaceable 18650 high rate battery (not included) and can fire up to 80W of output power. Asmodus Dachi Pod has a capacity of 4.0ml and is compatible with three types of coils to meet your vaping needs.
Original ThunderHead Creations THC 100% Organic Premium Cotton $4.99
The Authentic ThunderHead Creations THC 100% Organic Premium single head shoelace Cotton is in 55mm length and 3mm diameter. The cotton is suitable for THC Artemis RDTA / Tauren MTL RTA and other RTA / RDTA / RDA Vape Atomizer.
Original ThunderHead Creations THC Tauren MTL RTA Replacement Ni80 MTL Fused Clapton Coil - 0.6ohm, 28GA x 2 + 38GA (10 PCS) $4.99
The Authentic ThunderHead Creations THC MTL Fused Clapton Coil is made from 28GA x 2 + 38GA wire in 0.6ohm resistance. It is suitable for THC Tauren MTL RTA and other RTA / RDTA / RDA Vape Atomizer.
Comes in 2 PCS coils in one tube, 5 tubes in one box, totally 10 PCS / Coils
Original ThunderHead Creations THC Tauren MTL RTA Replacement Glass Tank Tube - Transparent $1.39
The Authentic ThunderHead Creations THC Tauren MTL RTA Replacement Tank tube is made from glass. The glass tank is suitable for Tauren MTL RTA Vape Atomizer.
Original ThunderHead Creations THC Tauren MTL RTA Replacement Long 510 Drip Tip w/ Adapter - Black + Silver $3.99
The Authentic ThunderHead Creations THC Tauren MTL RTA Replacement long 510 Drip Tip is made from POM and stainless steel. The 510 drip tip comes with adapter and is best for Tauren MTL RTA Vape Atomizer.
Original ThunderHead Creations THC Tauren MTL RTA Replacement Short 510 Drip Tip - Black $1.99
The Authentic ThunderHead Creations THC Tauren MTL RTA Replacement Short 510 Drip Tip is made from POM. The 510 drip tip is best for Tauren MTL RTA Vape Atomizer.
Original Asmodus Dachi 2 in 1 Pod Mod Vape Kit Replacement Coil Heads $10.59
Authentic Asmodus Dachi 2 in 1 Pod System Mod Vape Kit Replacement Coil Heads is with 1.2ohm resistance and supports 10~15W. 0.15ohm resistance and supports 40~80W. 0.5ohm resistance and supports 20~40W.
510 Adapter Connector for GeekVape Aegis Hero Pod System Vape Kit $4.99
The 510 Adapter Connector is suitable for GeekVape Aegis Hero Pod System Vape Kit Vape Kit. It can switch your GeekVape Aegis Hero Pod System to a normal box mod to use any 510 thread RTA / RDA / RDTA / Sub Ohm Tank Vape atomizer.
Original Innokin EQ Fltr Replacement Pod Cartridge - 2.0ml (1 PC) $4.99
The EQ Fltr Pod Cartridge is designed especially for the Innokin EQ Fltr Heating Kit.
Original Innokin EQ Fltr Pod System Replacement Filter Tip $2.59
The Authentic Innokin EQ Fltr Pod System Replacement Filter Tip comes with 10 PCS / Pack.
Старый 21.12.2020, 10:37 Автор темы   810
3FVAPE
SXK Penodat V2 MTL RTA Clone Rebuildable Tank Vape atomizer Original Price $29.9, Now Only $27.5.
The SXK Penodat V2 clone MTL RTA Rebuildable Tank Vape Atomizer is made from 316 stainless steel and PC Tank. The SXK Penodat V2 Style MTL RTA is in 22mm diameter and holds 2.5ml capacity. The SXK Penodat V2 Style MTL RTA is with convenient top refilling system and comes with 3 PCS MTL sub-coil AFC: 3 x 1mm / 1 x 1mm / 1 x 1.5 mm.
SXK Penodat V2 Clone MTL RTA Replacement 4.0ml Tank Tube + Chimney Original Price $10.9, Now Only $8.5.
The SXK Replacement 4.0ml PC Tank Tube and Stainless Steel Chimney is suitable for Penodat V2 clone MTL RTA Vape atomizer.
Original GeekVape Wenax C1 Pod System Vape Kit $22.9
Geekvape Wenax C1 kit 3ml is a very simple pod, with a designer look in a flat format.A single button adorns this kit, which suggests that it will be very easy to use, certainly for a high PG vape.Modern USB type C recharging, single side filling.
Original Lost Vape UB Pro P1 P3 Replacement Mesh Coil Head for Ursa Pro Pod Tank / Ursa Quest Multi Kit $7.99
Those Ursa UB Pro Replacement Coils are designed especially for the Lost Vape Ursa UB Pro Pod Tank.
Original Lost Vape Replacement RBA Coil Deck for Ursa Pro Pod Tank / Ursa Quest Multi Kit $8.99
The Ursa Pro RBA Deck is designed especially for the Lost Vape Ursa UB Pro Pod Tank.
Original Lost Vape Replacement Mesh Coil Head for Ursa Pod Tank / Ursa Quest Multi Kit $10.99
Those Ursa UB Replacement Coils are designed especially for the Lost Vape Ursa UB Tank.
Original Lost Vape Replacement RBA Coil Deck for Ursa Pod Tank / Ursa Quest Multi Kit $7.99
The Ursa Pod Tank RBA Deck is designed especially for the Lost Vape Ursa UB Pod Tank.
Original Lost Vape Air Flow Control Base for Ursa Quest Multi Kit $5.99
The Air Flow Control Base is designed especially for the Lost Vape Ursa Quest Multi Kit.
Original Lost Vape 510 Adaptor for Ursa UB Pro Tank / Ursa UB Tank $7.99
The 510 Adaptor is designed especially for the Lost Vape Ursa UB Pro Tank, Ursa UB Tank.
Original Lost Vape Ursa UB Pod Tank 6ml for Ursa Quest Kit Replacement $5.99
Lost Vape Ursa Pod Tank is designed for Lost Vape Ursa Quest Kit 100W. Lost Vape Ursa Pod Tank made of PCTG with replaceable drip-tip and refill in a comfortable lateral/high position,which can hold 6ml of e-juice,the 6ml Ursa Pod Cartridge uses an 510 drip tip and is designed to accommodate all the UB coil series and the UB RBA base.
Original Lost Vape Ursa UB Pro Pod Tank 7ml for Ursa Quest Multi Kit $5.99
Lost Vape Ursa Pro Pod Tank is designed for Lost Vape Ursa Quest Kit 100W. Lost Vape Ursa Pro Pod Tank made of PCTG with replaceable drip-tip and refill in a comfortable lateral/high position,which can hold 7ml of e-juice,the 7ml Ursa Pro Pod Cartridge uses an 810 drip tip and is designed to house the new UB Pro Coil series and the new Ursa Pro RBA. Ursa Pro Pod Tank is divided into an airflow slot and an upper part cartridge.
Старый 22.12.2020, 14:16 Автор темы   811
3FVAPE
5AVAPE Flexy 60W Side by Side SBS TC VW Box Mod $50.99
The 5AVAPE Flexy Clone Side-by-Side SBS 60W TC VW Vape Box Mod is made from stainless steel and aluminum. The SBS Mod supports 18350 / 18650 battery configuration (battery not included). The VW mod supports variable wattage from 1W to 60W. And the Side-by-Side box mod supports 22mm / 23mm diameter vape atomizers.
Original Digiflavor Z1 SBS Kit 80W Box Mod + Siren 3 GTA Original Price $79.99, Now Only $59.99.
Original Digiflavor Z1 SBS Kit consists of the Z1 SBS (Side By Side) mod and the Siren 3 GTA.the Z1 SBS Kit is described as an artwork, and while that may be a slight exaggeration, this tiny mod does look great. That’s due to the incredible chassis with stabwood or shell panels that are available in a black abalone shell, black stabwood, silver-gray scallop shell, and silver-gray stabwood.And, the Digiflavor Z1 SBS is small, portable, and stealthy. You see, it looks to be about the size of a credit card, so you can literally vape anywhere without anyone noticing. And, the mod’s contours and panel make it ergonomic, resulting in an unrivaled experience in the palm of your hand.
SXK EVL Dot Spot Polycarbonate Clone RBA Bridge for DotMod DotAIO AIO Pod Original Price $26.9, Now Only $23.5.
The SXK EVL Dot Spot Clone RBA is a bridge for the DotMod DotAIO AIO Pod. The Dot Spot Clone RBA is made of 316 stainless steel and polycarbonate to holds 2.0ml capacity. The tank has a refilling port on the side with silicone stopper.
ULTON Squape Arise Clone RTA Rebuildable Tank Vape Atomizer 24mm $34.5
ULTON Squape Arise Clone RTA Vape Atomizer is made from 316 stainless steel and PSU. The 24mm RTA holds 4.0ml and supports DL / MTL Vaping.
The Air Discs diameter: 1 x 1mm / 2 x 0.8mm / 3 x 0.8mm / 4 x 0.8mm.This Squ Arise Clone RTA supports to convince both as Direct to lung (DL) and Mouth to lung (MTL). The easily convert from DL to MTL and thus offers you complete flexibility.
SXK EVL Dot Spot Clone RBA Bridge Replacement Polycarbonate Replacement Tank Tube Original Price $6.8, Now Only $5.5.
The SXK EVL Dot Spot Clone RBA Bridge Replacement Tank Tube is made form Polycarbonate (PC) and holds 2.0ml capacity.
SXK EVL Dot Spot Clone RBA Bridge Replacement Ultem PEI Tank Tube Original Price $9.9, Now Only $8.5.
The SXK EVL Dot Spot Clone RBA Bridge Replacement Tank Tube is made form Ultem and holds 2.0ml capacity.
Original Auguse CG V2 510 Drip Tip $3.99
Original Auguse CG V2 510 drip tip consists of a mouthpiece and a base. It is suitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector.
Fuji Duck Clone 510 Drip Tip $3.99
Fuji Duck Clone 510 drip tip is made from acrylic and suitable for RBA / RTA / RDA Vape Atomizer with 510 drip tip connector.
Старый 23.12.2020, 17:12 Автор темы   812
3FVAPE
ShenRay KF Lite Plus RTA Clone Kayfun Lite Plus Rebuildable Tank Atomizer 24mm $19.99
ShenRay KF Lite Plus clone RTA Rebuildable Tank Atomizer consists of a tank, chimney and a MTL drip tip. It holds a capacity of 4ml with a bottom filling system.
Kayfun Lite Plus RTA Clone KF Lite Plus Rebuildable Tank Vape Atomizer $13.99
KF Lite Plus clone RTA Rebuildable Tank Atomizer consists of a tank, chimney and a MTL drip tip. It holds a 4ml e-juice capacity with a bottom filling system.
Uwell Valyrian 2 Pro Sub Ohm Tank Clearomizer Vape Atomizer Original Price $49.69, Now Only $33.99.
Uwell Valyrian 2 Pro Tank, the latest innovative product, features the following aspects: 32mm diameter, expanded air passage to increase airflow inflow, 810 drip tip and 8ml e-juice capacity, optimized flip top cap to provide a large amount of clouds. Valyrian 2 Pro Tank is made of mildly impact-resistant stainless steel and heat-resistant glass to maintain durability.
Original Cthulhu Single Coil Building Deck Pro for 510 Thread Atomizer $13.99
The original Cthulhu Coil Building Stand Pro with 39.5 diameter is helpful when you are wicking and building the RBA tanks. The original Cthulhu Coil Building Stand Pro is made from 304 food-grade steel and compatible with Atomizers and tanks with 510 threading connection.
Старый 24.12.2020, 13:11 Автор темы   813
3FVAPE
SXK Kayfun Lite Plus 2021 KF Lite 2021 Style RTA Rebuildable Tank Vape Atomizer 22mm Original Price $29.9, Now Only $27.5.
The KF Lite Plus SXK KayFun Lite Plus 2021 KF 2021 Clone RTA Rebuildable Tank Vape Atomizer is construction from 316 stainless steel in 22mm Diameter. The KF 2021 RTA hold 2.0ml capacity and comes with 4.0ml Extension Tank. The SXK KF Lite Plus Clone RTA is with Infinitely adjustable AEROKON Airflow-Control and 360 degrees PSU tank window. Comes with MTL drip tip and MTL Pro Upgrade Pin for MTL vaping.
Original Vsticking VK280 Pod System Vape Starter Kit $18.9
The Original Vsticking VK280 Pod System Vape Starter Kit consists of Vsticking VK280 Device and a refillable pod Catridge. Vsticking VK280 Device is made from Aluminum Alloy, which makes the device more durable and gives a comfortable hand feeling.
Original Vsticking VK280 Refillable Pod Cartridge for VK280 Pod Kit $8.99
The Original Vsticking VK280 Refillable Pod Cartridge consists of the anti-dust lid, E-liquid filling hole and Bottom cover, made from PCTG. It comes with a 1.6ml refillable pod cartridge. The Original Vsticking VK280 Refillable Pod Cartridge is especially designed for the Vsticking VK280 Pod Kit. 2 PCS / Pack
Original Coilology Tri-Core Fused Clapton Prebuilt Coil Ni80 $2.99
The Original Coilology Tri-Core Fused Clapton Prebuilt Coil 3-28 / 36GA is made from Ni80 in 0.32ohm resistance. It is suitable for RTA / RDA /RTDA Vape Atomizer. 10 PCS / Pack
Старый 25.12.2020, 06:33 Автор темы   814
3FVAPE
Original YDDZ T1 MTL RTA Rebuildable Tank Vape Atomizer $21.99
The Original YDDZ T1 MTL RTA Rebuildable Tank Vape Atomizer holds 2.0ml capacity in 22mm diameter. The YDDZ T1 MTL RTA 22mm RTA comes with 4.0ml glass tank tube and top cap. YDDZ T1 MTL RTA supports top refilling system and supports dual bottom airflow control adjustable
Original Vaporesso Swag PX80 Kit 80W Box Mod + Swag 4ml Pod Tank $39.99
Vaporesso Swag PX80 Box Mod Kit consists of SWAG PX80 80W Box Mod and Swag 4ml Pod Tank. SWAG PX80 Box Mod is powered by one single 18650 battery (Not Included) with the maximum 80W power output to provides consistent flavor through the GTX coil adopted pod, bringing the end to mess-free coil replacing with the capability of smooth adjustable airflow.Swag PX80 Pod Cartridge holds 4ml capacity. It is compatible with GTX coils.
Original Vaporesso Swag PX80 Mod Kit Replacement Pod Cartridge - 4.0ml (2 PCS) $7.99
The Original Vaporesso Swag PX80 Pod Cartridge is especially designed for Swag PX80 Mod Kit. It holds 4ml capacity. Vaporesso Swag PX80 Cartridge is compatible with GTX coils (not included), bringing the end to mess-free coil replacing with the capability of smooth adjustable airflow. It features improved anti-leaking system with triple-silicon structure and E-liquid self-circulating system. The coil is easy and clean replaced without emptying Pod.
Старый 26.12.2020, 12:21 Автор темы   815
3FVAPE
Original Innokin Sceptre 1400mAh Pod Kit $20.99
The Original Innokin Sceptre pod system vape starter kit is a 1400mAh built in battery device suited for new vapers looking for a small yet compact device. With two coils to choose from, a 1.2ohm for MTL Vaping and a 0.5ohm RDL Coil for high wattages, the Sceptre can easily identify between the two and automatically adjust your settings for the ultimate vaping experience. With an auto draw and button operation the Sceptre also features Boost Mode which can create more heat and vapor.
Original Innokin Sceptre Pod Kit $5.99
The Original Innokin Replacement Pod Cartridge is compatible with Sceptre Pod System Vape Kit. Comes with 0.65ohm MTL Coil Head and holds 3.0ml capacity.
Original Asvape Hita Pod Vape Kit / Hita Ink Kit Replacement Empty Pod Cartridge $3.99
The Original Asvape Hita Replacement Empty Pod Cartridge is especially designed for Asvape Hita Pod Vape Kit / Hita Ink Kit as a replacement part. The Cartridge comes with 3.0ml E-juice capacity and features leak-proof side refill system. (Coils are not included).
Original Asvape Hita Pod Vape Kit / Hita Ink Kit Replacement Mesh Coil Head $10.99
The Original Asvape Hita Replacement Mesh Coil Head is especially designed for Asvape Asvape Hita Pod Vape Kit / Hita Ink Kit / Pod Cartridge. It features 0.6ohm coil resistance. 5 PCS / PACK
Original Vapefly Jester Pod Kit / Vapefly Jester Pod Cartridge Replacement Coil Head $3.99
Original Vapefly Jester Replacement Coil is specifically designed for the Vapefly Jester Pod Cartridge and Vapefly Jester Rebuildable Dripping Pod Kit. The mesh coil comes with 0.5ohm resistance, bringing you better flavor. The regular coil features 1.2ohm resistance.
Original Innokin Sceptre Pod Mod Kit Replacement MTL Coil Head $5.99
The Original Innokin Sceptre Replacement Coils are compatible only with the Innokin Sceptre Pod Mod Starter Kit. Original Innokin Sceptre Replacement Coils comes with 0.65ohn resistance, suggested wattage is 10~12.5W. It is perfect for your MTL vaping experience. 5 PCS / PACK
Replacement Bubble Tank Tube for Vandy Vape Kylin Mini RTA $1.69
The Replacement Bubble Tank Tube is suitable for Vandy Vape Kylin Mini RTA Rebuildable Tank Vape Atomizer. It holds a capacity of 5ml.
Replacement Bubble Tank Tube for Hellvape Fat Rabbit Sub Ohm Tank $1.69
The Replacement Bubble Tank Tube is suitable for Hellvape Fat Rabbit Sub Ohm Tank Vape Atomizer. It holds a capacity of 5ml.
Replacement Bubble Tank Tube for Hellvape Dead Rabbit V2 RTA $1.69
The Replacement Bubble Tank Tube is suitable for Hellvape Dead Rabbit V2 RTA Rebuildable Tank Vape Atomizer. It holds a capacity of 5ml.
Replacement Bubble Tank Tube for Augvape Intake Sub Ohm Tank $1.69
The Replacement Bubble Tank Tube is suitable for Augvape Intake Sub Ohm Tank Vape Atomizer. It holds a capacity of 5ml.
Старый 28.12.2020, 14:21 Автор темы   816
3FVAPE
YFTK KF Lite Plus 2021 KF 2021 Clone RTA Rebuildable Tank Vape Atomizer w/ 4.0ml Extension Tank $23.99
The YFTK KF Lite Plus 2021 KF 2021 clone RTA Rebuildable Tank Vape Atomizer is construction from 316 stainless steel in 22mm Diameter. The KF 2021 RTA holds 2.0ml capacity and comes with 4.0ml Extension Tank. The YFTK KF Lite Plus clone RTA is with Infinitely adjustable AEROKON Airflow-Control and 360 degrees PSU tank window. Comes with MTL drip tip and MTL Pro Upgrade Pin for MTL vaping.
YFTK KF Lite Plus 2021 RTA Replacement Single Coil Deck for KF Lite 2019 Clone RTA $6.99
The YFTK KF Lite Plus 2021 RTA Replacement Single Coil Deck is made from 316 stainless steel. With this 2021 deck, you can switch you KF Lite 2019 clone RTA in to KF Lite Plus 2021 RTA. It is compatible with 22mm and 24mm KF Lite 2019 clone RTA
YFTK AEROKON Airflow Control Insert + 510 Pin for KF Lite Plus 2021 RTA $2.99
YFTK Aerokon Replacement Airflow Control Insert is made from 316 Stainless Steel (Surgical Grade). It is suitable for YFTK KF Lite Plus 2021 RTA Rebuildable Tank Vape Atomizer.
Replacement Front + Back Cover Panel Plate for DNA 60W / 70W BB Clone Vape Box Mod - Fluo-Orange, Acrylic $22.99
The Replacement Cover Panel is made from acrylic, and is designed for Billet Box mod Kit / SXK BB clone 70W / DNA60W Box Mod Vape kit. This cover panel comes with 2 pieces (front and back).
510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.79
The 510 drip tip is made from Stainless Steel and is suitable for any atomizer compatible with 510 drip tip.
WAVE Clone MTL 510 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.89
The KF WAVE clone clone MTL 510 Drip tip is made from Stainless Steel with diamond lathed surface, extremely smooth for a very comfortable and pleasant vape experience. Compliments the KF Lite, Prime, and Mini V3 nicely but will look amazing on just about any atomizer with a standard 510 drip tip compatible.
Старый 29.12.2020, 12:54 Автор темы   817
3FVAPE
SXK Scud TT TC VW Box Mod Clone - Random Color, Evolv DNA 60 Chipset Original Price $199.9, Now Only $185.9.
The SXK Scud TT Clone TC VW Box Mod is made from Stabilized Wood in Random Color The SXK Scud TT Clone Box Mod is powered by Evolv DNA 60 Chipset. The SXK Scud TT box Mod is compatible with 22mm diameter atomizer. Powered by 1 x 18650 battery (not included).
Armor Mech V2 BF Bottom Feeder Squonk Clone $53.99
The Armor Mech V2 Clone Mechanical Box Vape Mod is a BF Squonk Mechanical Mod, which comes with side fire button, and custom bottle system. A 24mm inset catch cup surrounds the 510 connector, and an included matching 22mm insert ring allows users to seat either a 22mm or 24mm diameter atomizer into the top plate, or flip the ring for a completely flush mounting surface for larger diameter atomizers and beauty rings.
SXK Scud TT Style Box Mod Replacement 510 Ring for 24mm Atomizer Original Price $9.9, Now Only $8.5.
The SXK Scud TT Clone Box Mod Replacement 510 Ring is made from stainless steel and compatible with 24mm Atomizer.
SXK Scud TT Style Box Mod Replacement knurl 510 Ring for 22mm Atomizer Original Price $9.9, Now Only $8.5.
The SXK Scud TT Clone Box Mod Replacement knurl 510 Ring is made from Stainless Steel and compatible with 22mm Atomizer.
Original Yachtvape Claymore RDA Replacement Top Cap + Drip Tip $8.99
The Replacement Top Cap and Drip Tip is suitable for Original Yachtvape Claymore RDA vape atomizer.
Старый 30.12.2020, 15:12 Автор темы   818
3FVAPE
ULTON DotMission RBA Bridge Clone for DotMod DotAIO AIO Pod $28.9
ULTON DotMission clone RBA Bridge is especially designed for DotMod DotAIO AIO Pod. It supports side filling system and comes with Variable airflow controls (1.2mm, 2.1mm, 3.5mm).
Original Augvape FOXY ONE 120W Starter Kit w/ INTAKE Sub Ohm Tank $49.99
Augvape FOXY ONE 120W Starter Kit consists of Augvape FOXY ONE 120W Box Mod and Augvape INTAKE Sub ohm Tank vape atomizer.Augvape FOXY ONE 120W Mod is powered by a single 20700 / 21700 / 18650 battery (The battery is not included) and capable of a firing up to 120W (5~120W).Augvape INTAKE Sub Ohm Tank comes with INTAKE new innovative mesh coil made of super SS 890L with more resistance to oxidation and corrosion.
Original Vaporesso Orca Solo Plus AIO 1200mAh Pod System Vape Starter Kit $20.99
Vaporesso Orca Solo Plus AIO Pod System Starter Kit consists of a 1200mAh Mod and a 2ml Pod Cartridge.Vaporesso Orca Solo Plus AIO Pod System Mod is powered by a 1200mAh built-in battery for your lasting vaping experience. Vaporesso Orca Solo Plus AIO Pod Cartridge holds 2ml E-juice capacity and is compatible with OC Meshed 0.6ohm Coil and OC CCELL 1.3ohm Coil.
23mm VG Extreme V2 RTA Rebuildable Tank Atomizer Clone $23.99
Original Vandy Vape Triple Fused Clapton Wire Coil 28GA x 3 + 38GA, Ni80 (10 Ft) $4.99
Vandy Vape Triple Fused Clapton Wire is made of high-quality Ni80 material with resistance of 1.58ohm / ft. It is suitable for RTA / RDA / RTDA Vape Atomizer. The length of one pack is 10ft.
Старый 31.12.2020, 11:56 Автор темы   819
3FVAPE
Original Digiflavor Z1 SBS 80W Box Mod $49.9
Digiflavor Z1 SBS Mod is a compact and beautiful Side By Side box mod, which fits perfectly in the hand and is easy to operate. The Digiflavor Z1 SBS Mod is powered by a single 18650 battery (Not included), which is inserted into the battery tube from above and secured with a convenient cover. The output power of Z1 SBS Mod in classic VW mode is up to 80 watts (5~80W),
The Authentic Oumier Blade is a high-power vape box mod with advanced technology and powerful performance. It supports IP67 waterproof and comes with an integrated 1.3" TFT screen with multi-touch support. Adopts ergonomic and durable shell design, made of high-quality materials. The box mod adjustment buttons have been integrated with the color touch screen, which is easy to use and the body is simpler and smoother.
Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Atomizer - 4.0ml $50.99
Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Atomizer is made of SS316 (Deck, Chamber, Top Cap) and PC (Drip Tip) and glass (Tank Tube). It holds 4.0ml capacity in 22mm diameter. It is ideal for Akira Box Mod but also suitable for any Box Mod with 510 threading connection.This one is with 4mL capacity
Original Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Atomizer - 2.0ml $49.99
Ambition Mods and The Vaping Gentlemen Club Bishop MTL RTA Rebuildable Tank Atomizer is made of SS316 (Deck, Chamber, Top Cap) and PC (Drip Tip) and glass (Tank Tube). It holds 4.0ml capacity in 22mm diameter. It is ideal for Akira Box Mod but also suitable for any Box Mod with 510 threading connection.This one is with 2mL capacity
Старый 04.01.2021, 18:12 Автор темы   820
3FVAPE
Vapeasy BY-kA V9 MTL RTA Rebuildable Tank Atomizer Clone w/ 5.0ml Tank Tube Kit $32.99
The Vapeasy BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer Nano Version holds 3.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping.This is the Nano Version in 3.0ml. Comes with Standard Set including Chimney and Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity.
SXK BY-kA V9 MTL RTA Rebuildable Tank Atomizer Clone Full Set 5.0ml + 3.0ml, 22mm $35.99
The SXK BY-kA V.9 V9 MTL RTA Rebuildable Tank Atomizer Nano Version holds 3.0ml capacity and in 22mm Diameter. The BY-kA V.9 V9 MTL RTA is with top refilling system for easy refilling and bottom airflow adjustable for MTL Vaping.This is the Nano Version in 3.0ml. Comes with Standard Set including Chimney and Tank Tube is suitable for KA V9 clone RTA and holds 5.0ml capacity.
VWM Integra MTL / DL RTA Clone Rebuildable Tank Vape Atomizer 22mm $24.99
The VWM Integra clone MTL / DL RTA is a 22mm rebuildable tank atomizer with 4.2ml of juice capacity. It is constructed from 316 stainless steel (body) and PC (tank tube). It features recessed build deck, reduced evaporation chamber, and various side airflow combinations from tight MTL to restricted DL with the stock AFC ring.
Original Innokin Prism T18II Sub Ohm Tank Vape Atomizer 18mm $10.99
The Innokin Prism T18II tank is a simple mouth-to-lung tank, compatible with Innokin's most popular and most widely available Prism T18 coils. It holds 2.5ml of e-liquid, and has an unscrewable top cap for easy refilling.
Original Innokin Replacement Coil Head for Prism T18 / T22 / Prism T18II $7.99
Original Innokin Prism Replacement Coils are designed for Innokin Prism T18 / T22 / Prism T18II Atomizer and Innokin Prism T18 / T22 / Prism T18II Starter Kit. It comes with pure organic cotton, bringing your better vaping experience. 5 PCS / Pack
Replacement Bubble Tank Tube for Uwell Valyrian 2 Sub Ohm Tank Atomizer 6mL $1.69
This Replacement Bubble Tank Tube is especially designed for Uwell Valyrian 2 sub ohm tank atomizer. It features 6.0ml tank capacity.
Время генерации страницы 0.33118 секунды с 15 запросами
