Просмотров в теме 260324   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.06.2020, 04:29 Автор темы   661
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Vapeasy Haku Venna RDA Clone with BF Pin(Replica) $24.99
The Vapeasy Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from Titanium Alloy, the base deck and 510 center pin is with 24K gold-plating. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. This RDA comes with bottom feeder pin.
Original ZQ Xtal 520mAh Pod System Kit $18.99
The Original ZQ Xtal pod system is an innovative product, featuring its outstanding taste. Its unique Smart Airflow system lets you enjoy a velvety, smooth-as-silk satisfaction that can beat any kind of cigarettes. It combined Aspire's professional coil testing technology and the extraordinary integration of coil resistance, vapor, temperature. Which brings you an authentic taste of your favorite e-liquid.
Original Vape Mater X50T 50W 2500mAh VW + Clearomizer Atomizer Vape Kit original price $49.99, now only $14.99
The Original Vape Mater X50T vape starter kit contains a 50W VW mod and 22mm atomizer. The Mod is built-in 2500mAh battery and supports wattage adjustable from 7W to 50W. The atomizer is in 22mm dimeter with 2.5ml capacity. The sub ohm tank supports top refilling and bottom air control.
Original Vapor Storm V-PM 40 Vape Pod System Replacement Empty Pod Cartridge(1 PC) $2.99
The Vapor Storm V-PM 40 Replacement Empty Pod Cartridge is designed for Vapor Storm V-PM 40 Pod System Kit.
Original Coilology Sandvik 4 PCS Ni80 Handmade Framed Staple Alien Coils + 10 PCS Shoelace Cotton for Vape Atomizer $8.99
The Original Coilology Sandvik Handmade Staple Alien Coils maintains 4 PCS Coilology Sandvik Handmade Staple Alien Coils and 10 PCS Shoelace cotton.
Original OXVA Origin Vape Pod System Replacement Drip Tip $1.99
This Original OXVA Origin Drip Tip is design for OXVA Origin AIO Pod vape Mod Kit.
Original OXVA Origin Vape Pod System Replacement Detachable Panel Plate $4.99
This Original OXVA Origin Vape Pod System Replacement Detachable Panel Plate is design for OXVA Origin AIO Pod vape Mod Kit.
Original OXVA Origin Vape Pod System Replacement Coil Airflow Ring for UNI 0.5 Mesh Coil / UNI 0.3 Mesh Coil $2.99
OXVA Origin Replacement Airflow Control is designed to be used with the OXVA Origin Pod System. Each one is sold in a single package and is compatible with the OXVA Replacement Coils. The Origin Replacement AFC features a single 7mm by 1.5mm air slot. This slot is fully adjustable, whether open or closed users can dial in their preferred airflow style. Compatible with the Origin Coils: UNI 0.5 Mesh Coil, UNI 0.3 Mesh Coil.
Original ZQ Xtal Vape pod System Pod Cartridge(4 PCS) $9.99
This cartridge was design for ZQ Xtal Pod. have 1.8ml juice capacity. It combined Aspire's professional coil testing technology and the extraordinary integration of coil resistance, vapor, temperature. Which brings you an authentic taste of your favorite e-liquid. 2 PCS / pack.
Original Vapor Storm V-PM 40 Pod System Replacement Coil Heads(5 PCS) $5.99
The Vapor Storm V-PM 40 Replacement 0.6ohm Coil head is designed for Vapor Storm V-PM 40 Pod System Kit.
3FVAPE вне форума   Вверх
Старый 17.06.2020, 04:41 Автор темы   662
3FVAPE
Original Hellvape Dead Rabbit V2 RTA $34.99
The Hellvape Dead Rabbit V2 RTA is an innovative dual-coil RTA with dual airflow systems, including slot and honeycomb airflow for outstanding clouds and flavor creating. The open wall and angled posts are absolutely conducive to reload and cut the coils in an easier way. This RTA can hold 2ml e-liquid and also can be extended to 5ml via extra glass tube. Featuring top airflow and excellent wicking, it has no any dry hits or leaking problems, and the colorful resin 810 drip tip
Original SMOKTech SMOK TFV9 Sub Ohm Tank Clearomizer Vape Atomizer $24.99
SMOKTech SMOK TFV9 Tank uses Bulb Pyrex Glass #1 that measures 28mm in diameter and comes with 6.5ml big e-juice capacity. It is designed with childproof top cap to keep children away from the tank, which not only prevents accidental opening of the top, but also avoids leakage of e-juice. There is a gold-plating pin for TFV9 Tank to increase rub resistance and strengthen electrical conductivity, so you can enjoy better user experience when connecting the tank with a mod. With the large refill slot and central airflow tube, The TFV9 tank will provide more convenient refilling, massive clouds of vapor and excellent taste. TFV9 tank supports the V9 meshed coil that is made of Nichrome and features a large heating contact surface area to produce huge clouds and superb flavor with less heat time. In addition, the full line of V8 Baby Coils (only for the standard version) are also compatible with TFV9 Tank. The slide-to-fill system will provide you simple and secure e-juice refilling. And the leakage problem can be solved with the leak proof slot.
YFTK Dvarw MTL FL Facelift RTA Clone(Replica) $19.99
YFTK Dvarw MTL FL Facelift RTA atomizer Clone is constructed from 316 stainless steel in 22mm diameter and 5ml capacity. The YFTK Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. YFTK Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.4mm for classic mode puff-mouth lungs.
SXK VMM Imperia RTA Clone(Replica) original price $28.90, now only $23.99
The SXK Imperia RTA Rebuildable Tank atomizer Clone is constructed from 316 stainless steel and in 22mm diameter. The glass tank holds 5ml capacity and top refilling system. The SXK Imperia Style RTA is with 6 airflow options 1.6mm / 1.8mm / 2.0mm / 2.2mm / 2.4mm / 2.6mm (With the default preinstalled Air plate). The RTA supports fully adjustable 510 base at 24 different sides (For atty - mod precise alignment)
SXK Dvarw MTL FL Facelift RTA Clone(Replica) original price $23.90, now only $20.99
SXK Dvarw MTL FL Facelift RTA atomizer Clone is constructed from 316 stainless steel in 22mm diameter and 3.5ml capacity. The SXK Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. SXK Dvarw MTL FL Facelift 3.5ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic mode puff-mouth lungs.
SXK Dvarw DL FL Facelift RTA Clone(Replica) original price $23.90, now only $20.99
SXK Dvarw DL FL Facelift RTA atomizer Clone is constructed from 316 stainless steel in 24mm diameter and 6.0ml capacity. The SXK Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. SXK Dvarw MTL FL Facelift 6.0ml RTA Clone has a diameter of 24mm and is supplied airflow insert 2.5mm x 2 for classic mode puff-mouth lungs.
Original Luckinvape BFV Mesh Coil for VOOPOO Vinci / X / R / Drag X / S Vaporesso PM80 SE / Wismec R80 / R40(5 PCS) $6.99
The Original Luckinvape BFV single mesh Coil is designed for VOOPOO Vinci / Vinci X / Vinci R / Drag X / Drag S / Navi Pod System, Vaporesso Target PM80 / Target PM80 SE and Wismec R80 / R40 Pod System. It is a 0.3ohm single mesh coil that supports 32W to 40W.
SXK VMM Imperia RTA Clone Replacement Glass Tank Tube $1.90
The Glass tank is with 5ml capacity and suitable for SXK Imperia RTA Vape Atomizer Clone.
SXK VMM Imperia RTA Clone Replacement Short Ultem Tank Tube + SS Chimney + 510 Drip Tip original price $8.90, now only $6.99
The PEI tank is with 3ml capacity and suitable for SXK Imperia RTA Clone Vape Atomizer. Comes with stainless steel chimney and PEI 510 drip tip.
SXK VMM Imperia RTA Vape Atomizer Clone Replacement DL / MTL Airflow Inserts Air Plates(2 PCS) original price $13.90, now only $9.99
The Airflow Inserts Air Plates are suitable for SXK Imperia RTA Vape Atomizer Clone. One is MTL air plate: 0.8mm / 0.9mm / 1.0mm / 1.1mm / 1.2mm / 1.3mm / 1.4mm / 1.5 mm (8 airflow options starting from strict MTL to loose MTL); and the other is Multi air plate: 3 x 0.9mm / 3 x 1.1mm / 2 x 1.6mm / 2 x 1.8mm / Plus 2 more RDL & DL Slots (6 airflow options for loose MTL to DL)
Старый 18.06.2020, 05:37 Автор темы   663
3FVAPE
Mechlyfe Arcless V2.0 Vape Mechanical Mech Mod original price $79.00, now only $49.98
The Mechlyfe Arcless V2.0 Mech Mod (Copper Version) is the upgrade of Mechlyfe Arcless Mesch mod. It is made from copper and is compatible with 20700, 21700 and 18650 batteries (not included). The Arcless V2.0 Mech Mod adopts the cool black CD pattern button, it will take care of the battery with the self-adjusting battery contact function.
Original Crested Ibis MODS Vape Semi-Mech Mechanical Mod with MOSFET $89.00
The Original Crested Ibis MODS Mod is made from Delrin and Stainless Steel. The mod is built-in MOSFET with low / high resistance, overheating, short circuit, reverse polarity protection. The Mod supports 22mm diameter atomizer. The atmoizer in the image is not included.
Marstech Taifun GX MTL / DL RDTA Clone(Replica) $22.99
The Marstech Typhoon Taifun GX MTL / DL RDTA Clone is constructed from 316 Stainless Steel and Glass material in 23mm Diameter featuring a flavour-focused interchangeable air flow system, easy-build coil winding deck, and SS liquid feeder cables to quickly deliver liquid to the deck down to every last drop in your tank. It also features a modular structure that allows the build deck to be removed from the lower tank and airflow section to allow easy user access to the wicks and the changeable air disks. Moreover, the RDTA supports MTL vaping and DL vaping experience and comes with 4ml E-juice capacity glass tank tube.
ShenRay Dvarw MTL FL Facelift RTA Clone(Replica) $19.99
ShenRay Dvarw MTL FL Facelift RTA atomizer Clone is constructed from 316 stainless steel in 22mm diameter and 5ml capacity. The ShenRay Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. ShenRay Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic style puff-mouth lungs.
Dvarw MTL FL Facelift RTA Clone(Replica) with 5 x Single Coil Inserts $10.99
Dvarw MTL FL Facelift RTA atomizer Clone is constructed from stainless steel in 22mm diameter and 5ml capacity. The Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm for classic mode puff-mouth lungs. Comes with 5 single hole air insert: 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm (pre-installed), 1 x 1.5mm, 1 x 2.0mm
Dvarw MTL FL Facelift RTA Vape Atomizer Clone(Replica) with 5 x Single Hole Inserts + 2 x Spare Tanks $18.99
Dvarw MTL FL Facelift RTA atomizer Clone is constructed from stainless steel in 22mm diameter and 5ml capacity. The Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm classic mode puff-mouth lungs. Comes with 5 single hole air insert: 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm (pre-installed), 1 x 1.5mm, 1 x 2.0mm Comes with 2ml thank section and 3.5ml tank section
YFTK Dvarw MTL FL Facelift RTA atomizer Clone is constructed from 316 stainless steel in 22mm diameter and 3.5ml capacity. The YFTK Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. YFTK Dvarw MTL FL Facelift 3.5ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic mode puff-mouth lungs.
Original Hellvape Dead Rabbit V2 RTA Replacement Straight Glass Tank Tube $2.59
The Straight Glass Tank Tube holds 2ml capacity and is suitable for Hellvape Dead Rabbit V2 RTA Vape Atomizer.
Original Hellvape Dead Rabbit V2 RTA Replacement Bubble Glass Tank Tube $2.99
The bubble Glass Tank Tube holds 5ml capacity and is suitable for Hellvape Dead Rabbit V2 RTA Vape Atomizer.
Original Vandy Vape Berserker V2 RTA Replacement Glass Tank Tube $2.59
The Glass Tank Tube holds 3ml capacity and is suitable for Vandy Vape Berserker V2 RTA Vape Atomizer.
Original Vandy Vape Berserker V2 RTA Replacement PEI Tank Tube $3.59
The PEI Tank Tube holds 3ml capacity and is suitable for Vandy Vape Berserker V2 RTA Vape Atomizer.
Original Vandy Vape Berserker V2 RTA Replacement Airflow Insert Tube - D-1 / 0.8 / 1.0 / 1.4 / 1.6 / 2.0mm (6 PCS)) $3.59
The Vandy Vape Berserker V2 RTA Vape Atomizer Replacement Airflow Insert Tube comes with 6 PCS / pack: D-1 (dual-hole) / 0.8mm / 1.0mm / 1.4mm / 1.6mm / 2.0mm.
Original Vandy Vape Superfine MTL Fused Clapton Coil Wire for RDA RTA Vape Atomizer(10 PCS) $3.99
The Original Vandy Vape Superfine MTL Fused Clapton Coil is made from Ni80 in 30GA x 2 + 38GA, with 0.74ohm resistance and comes with 10 PSC/Pack.
SXK Dvarw DL FL Facelift 24mm RTA Replacement Single Hole Airflow AFC Inserts(2 PCS) original price $5.90, now only $4.99
The SXK Single Hole Airflow AFC Inserts comes with 2 PCS / pack and size in 1 x 2.5mm / 1 x 3.0mm. The AFC inserts are suitable for 24mm Dvarw DL FL Facelift RTA Vape Atomizer.
Старый 18.06.2020, 05:40 Автор темы   664
3FVAPE
SXK Dvarw DL FL Facelift 24mm RTA Replacement Dual-Hole Airflow AFC Inserts(2 PCS) original price $5.90, now only $4.99
The SXK dual Hole Airflow AFC Inserts comes with 2 PCS / pack and size in 2 x 2.0mm / 2 x 3.0mm. The AFC inserts are suitable for 24mm Dvarw DL FL Facelift RTA Vape Atomizer.
SXK Dvarw MTL FL Facelift 22mm RTA Replacement Single Hole Airflow AFC Inserts(4 PCS) original price $11.90, now only $8.99
The SXK Single Hole Airflow AFC Inserts comes with 4 PCS / pack and size in 1 x 0.8mm + 1 x 1.0mm + 1 x 1.5mm + 1 x 2.0mm. The AFC inserts are suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer.
SXK Dvarw MTL FL Facelift 22mm RTA Replacement Dual Hole Airflow AFC Inserts(4 PCS) original price $11.90, now only $8.99
The SXK dual Hole Airflow AFC Inserts comes with 4 PCS / pack and size in 2 x 0.8mm + 2 x 1.2mm + 2 x 1.5mm + 2 x 2.0mm. The AFC inserts are suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer.
SXK Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Triple-Hole Airflow AFC Inserts(2 PCS) original price $5.90, now only $4.99
The SXK Triple Hole Airflow AFC Inserts comes with 2 PCS / pack and size in 3 x 0.6mm + 3 x 0.8mm. The AFC inserts are suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer.
SXK Dvarw DL FL Facelift 24mm RTA Replacement Stainless Steel Top Cap + PC + PEI Tank Tube Kit original price $11.90, now only $8.99
SXK Dvarw DL FL Facelift 24mm RTA vape atomizer replacement tank kit includes 3 parts, stainless steel Top Cap, PC Tank Tube and PEI Tank Tube Kit. The tank tube holds 3.5ml capacity.
SXK Dvarw MTL FL Facelift 22mm RTA Replacement Stainless Steel Top Cap + PC + Glass + PEI Tank Tube Kit original price $11.90, now only $8.99
SXK Dvarw MTL FL Facelift 22mm RTA vape atomizer replacement tank kit includes 4 parts, stainless steel Top Cap, Glass Tank Tube, PC Tank Tube and PEI Tank Tube Kit. The tank tube holds 2.0ml capacity.
SXK Dvarw MTL FL Facelift 22mm RTA vape atomizer replacement tank kit includes 4 parts, stainless steel Top Cap, Glass Tank Tube, PC Tank Tube and PEI Tank Tube Kit. The tank tube holds 5.0ml capacity.
Dvarw MTL FL Facelift 22/24 RTA AFC Inserts(11 PCS) $8.99
The Airflow AFC Inserts comes with 41 PCS / pack and size in 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm, 1 x 1.5mm, 1 x 2.0mm, 2 x 0.8mm, 2 x 1.2mm, 2 x 1.5mm, 2 x 2.0mm, 3 x 0.6mm, 3 x 0.8mm, 1 x Blank. The AFC inserts are suitable for 22mm / 24mm Dvarw MTL FL Facelift RTA Vape Atomizer.
Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section $4.99
The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section is made from stainless steel and glass. The Glass tank holds 2.0ml capacity.
The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section is made from stainless steel and glass. The Glass tank holds 3.5ml capacity.
Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section $5.99
The Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section is made from stainless steel and glass. The Glass tank holds 5.0ml capacity.
YFTK Dvarw MTL FL Facelift 22mm/24mm RTA Replacement Single Hole Airflow AFC Inserts(4 PCS) $8.99
The YFTK Single Hole Airflow AFC Inserts comes with 4 PCS / pack and size in 1 x 0.8mm + 1 x 1.0mm + 1 x 1.5mm + 1 x 2.0mm. The AFC inserts are suitable for 22mm / 24mm Dvarw MTL FL Facelift RTA Vape Atomizer.
YFTK Dvarw MTL FL Facelift 22mm RTA Replacement Dual Hole Airflow AFC Inserts(4 PCS) $8.99
The YFTK dual Hole Airflow AFC Inserts comes with 4 PCS / pack and size in 2 x 0.8mm + 2 x 1.2mm + 2 x 1.5mm + 2 x 2.0mm. The AFC inserts are suitable for 22mm / 24mm Dvarw MTL FL Facelift RTA Vape Atomizer.
YFTK Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Airflow AFC Inserts(3 PCS) $7.99
The YFTK Triple Hole Airflow AFC Inserts comes with 3 PCS / pack and size in 3 x 0.6mm + 3 x 0.8mm + 1 x Blank. The AFC inserts are suitable for 22mm / 24mm Dvarw MTL FL Facelift RTA Vape Atomizer.
YFTK Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section $8.99
The YFTK Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section is made from stainless steel and glass. The Glass tank holds 3.5ml capacity.
The YFTK Dvarw MTL FL Facelift 22mm RTA Vape Atomizer Replacement Tank Tube Section is made from stainless steel and glass. The Glass tank holds 5.0ml capacity.
Старый 18.06.2020, 05:42 Автор темы   665
3FVAPE
Original SMOK RPM 2 Mesh Coil for RPM80, RPM80 Pro, RPM Lite 40W, RPM40, Pozz X, Alike Kit, SCAR-P3, SCAR-P5(5 PCS) $14.99
The SMOKTech SMOK RPM 2 0.16ohm DL Mesh Coil comes with 5 PCS / pack, is suitable for RPM80, RPM80 Pro, RPM Lite 40W, RPM40, Pozz X, Alike Kit, SCAR-P3, SCAR-P5 Pod System Vape Starter Kit
The SMOKTech SMOK RPM 2 0.4ohm MTL Mesh Coil comes with 5 PCS / pack, is suitable for RPM80, RPM80 Pro, RPM Lite 40W, RPM40, Pozz X, Alike Kit, SCAR-P3, SCAR-P5 Pod System Vape Starter Kit
SXK Drip Suit for Ghost 510 Drip Tip Set for RDA / RTA / RDTA Vape Atomizer(6 PCS) original price $32.90, now only $25.99
SXK Drip Suit for Ghost 510 Drip Tip Set is made from Titanium Alloy and is suitable for RDA / RTA / RDTA Vape Atomizer. 6 PCS / pack: 40mm / 23mm / 25mm / 25mm / 23mm / 15mm
Старый 19.06.2020, 05:21 Автор темы   666
3FVAPE
Original Wismec R40 VW Pod System Kit $35.99
The Original Wismec R40 Pod Mod vape starter Kit, featuring an integrated 1700mAh battery, 1W to 40W output range, and can accommodate the Wismec WV Coil Series. Equipped with a bottom filled 3.0mL pod capacity, the R40 Pod Mod Kit can output vapor with less time spent on refilling. In addition, the coils are installed in a press fit manner, facilitating coil replacements by threading them into the bottom coil-based airflow that allows the user to carefully control the airflow intake. Furthermore, the Wismec R40 Pod Mod Kit can accept coils from the WV Coil Series, delivering delicious clouds of vapor at an incredibly fast firing speed. Drawing power from the integrated 1700mAh battery within the zinc-alloy chassis, the R40 Pod Mod Kit clearly displays relevant vaping data to the user via 0.96inch Color Display Screen.
Original Ultroner Sphinx DNA250C 200W TC VW Box Mod $298.90
The Original Ultroner Sphinx DNA250C 200W TC VW Vape Box Mod is powered by Evolv DNA250C Chipset. The box vape mod supports wattage adjustable from 1~ to 200W. The mod supports 2 x 18650 / 20700 / 21700 batteries (not included). The mod supports max. 25mm diameter atomizer
Original VapeSoon DT398 Replacement Drip Tip for GeekVape Aegis Boost Pod System Vape Kit $1.69
The Original VapeSoon DT398 Replacement Drip Tip is made from resin and suitable for GeekVape Aegis Boost Pod System Vape Kit. This drip is in 17mm height, 11.5mm outer diameter and 7mm connector diameter.
Original VapeSoon DT136-D 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Reload Vape Atomizer $1.29
The VapeSoon DT136-D 810 Drip Tip is made of Resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original VapeSoon DT404 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Reload RDA /RTA Vape Atomizer $1.69
The VapeSoon DT404 810 Drip Tip is made of Resin, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original VapeSoon DT410 810 Drip Tip for SMOK TFV8 / TFV12 Tank / Kennedy / Reload RDA Vape Atomizer $1.89
The VapeSoon DT410 810 Drip Tip is made from Resin (mouthpiece) and Stainless Steel (base connector) with 17mm height and 17mm diameter. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original VapeSoon Replacement MTL Coil Head for Joyetech Exceed Edge Vape Kit(5 PCS) $6.80
The Original VapeSoon 1.2 MTL Coil Head is suitable for Joyetech Exceed Edge vape Kit. The 1.2ohm coil supports MTL Vaping. Comes in 5 PCS / Pack.
Original VapeSoon RPM80 RGC Coil Head for SMOK RGC Pod Cartridge, RPM80 Kit, RPM80 Pro Kit, Fetch Pro, RPM160(5 PCS) $7.78
The Original VapeSoon RPM80 RGC Coil Head is in 0.17ohm resistance supports 40W to 80W. It is Suitable for SMOK RGC Pod Cartridge, SMOK RPM80 Kit / RPM80 Pro Kit / Fetch Pro / SMOK RPM160 Pod System Vape Kit
Original VapeSoon Replacement KA1 Coil Head for GeekVape Aegis Boost Pod System Vape Kit(5 PCS) $7.47
The Original VapeSoon Replacement KA1 Coil Head is suitable for GeekVape Aegis Boost Pod System Vape Kit. This coil is in 0.4ohm resistance and supports 25W to 33W. Comes with 5 PCS / Pack.
Original VapeSoon PnP-VM4 Coil Head for Voopoo VINCI X / PnP 20/22 / VINCI AIR / Drag S / Drag X(5 PCS) $7.11
The Original VapeSoon PnP-VM4 0.6ohm Coil Head is Suitable for Voopoo VINCI Kit / VINCI X Kit / Navi Kit / PnP 20 / PnP 22 / VINCI AIR Kit / Drag S Kit / Drag X Kit / Drag Mini Kit / Drag 2 Kit. The coil is 0.6ohm resistance and supports 20W to 28W. Comes in 5 PCS / Pack.
YFTK Replacement Glass Tank Tube for Dvarw MTL FL Facelift RTA 22mm $1.99
The YFTK Replacement 3.5ml Glass Tank Tube is suitable for Dvarw MTL FL Facelift RTA 22mm
The YFTK Replacement 5.0ml Glass Tank Tube is suitable for Dvarw MTL FL Facelift RTA 22mm
SXK Replacement Glass Tank Tube for Dvarw MTL FL Facelift RTA 22mm $1.99
The SXK Replacement 3.5ml Glass Tank Tube is suitable for Dvarw MTL FL Facelift RTA 22mm
The SXK Replacement 5.0ml Glass Tank Tube is suitable for Dvarw MTL FL Facelift RTA 22mm
Original Wismec R40 Pod System Vape Kit Replacement Pod Cartridge(1 PC) $13.99
The Original Wismec R40 Replacement Pod Cartridge is specially designed for Wismec R40 Pod Mod vape Kit. For the convenient filling, the R40 cartridge features a bottom e-liquid filling system and has a maximum capacity of 3ml, silicone plug, no leakage. Also, the R40 pod cartridge is transparent to ensure that you will notice how much juice is left. Featuring the brand-new replaceable WV coils with an adjustable airflow system, the R40 pod cartridge delivers huge vapor and optimal flavor! In addition, the coils are installed in a press-fit manner, facilitating coil replacements by threading them into the bottom coil-based airflow that allows the user to carefully control the airflow intake. With the cleverly designed bottom airflow setting, you can rotate the knurled bottom of each R40 coils to change the air inlet to produce your favorite steam and throat impact sound.
Original SMOKTech SMOK Scar P3 Pod System Vape Kit Replacement RPM Pod Cartridge(3 PCS) $6.99
The Original SMOK Scar P3 Pod System Replacement RPM Pod Cartridge holds 5.5ml and comes with 3 PCS / Pack. The RPM Pod is compatible with all RPM coils.
Original SMOKTech SMOK Scar P3 Pod System Vape Kit Replacement RPM 2 Pod Cartridge(3 PCS) $6.99
The Original SMOK Scar P3 Pod System Replacement RPM 2 Pod Cartridge holds 5.5ml and comes with 3 PCS / Pack. The RPM 2 Pod is compatible with RPM 2 0.16ohm Mech Coil is designed to chase the best flavor
Original SMOKTech SMOK Scar P5 Pod System Vape Kit Replacement RPM Pod Cartridge(3 PCS) $6.99
The Original SMOK Scar P5 Pod System Replacement RPM Pod Cartridge holds 5.5ml and comes with 3 PCS / Pack. The RPM Pod is compatible with all RPM coils.
Original SMOKTech SMOK Scar P5 Pod System Vape Kit Replacement RPM 2 Pod Cartridge(3 PCS) $6.99
The Original SMOK Scar P3 Pod System Replacement RPM 2 Pod Cartridge holds 5.0ml and comes with 3 PCS / Pack. The RPM 2 Pod is compatible with RPM 2 0.16ohm Mech Coil is designed to chase the best flavor
Старый 20.06.2020, 04:26 Автор темы   667
3FVAPE
Original KangerTech Ibar 800mAh Pod System Kit $14.70
The KangerTech Ibar kit is a new pod system combines a 800mAh battery with a 2.0ml refillable pod adopting Kanthal 1.2ohm coil and upgraded organic cotton, designed to provide you pure flavors with great MTL vaping experience. Featuring two power modes: full power output and constant voltage output, Ibar offers a little bit of power flexibility. Smart 15-puff vibration notification will remind you to keep moderate inhale of nicotine.
Original Aspire BP 60 1400mAh Pod System Kit $26.72
The Original Aspire BP 60 Pod System Vape Kit combined only the best aesthetic features of Breeze series, robust performance of mods, and fully tested quality coils to create BP 60 pod mod. With BP 60, you will experience extreme flavor satisfaction comparable to RDAs, dense vapor production with 1-60W output wattage, and precise airflow control.
Original VLADDIN Vantage 11W / 15W DL / MTL 700mAh Pod System Kit $22.00
The Original VLADDIN Vantage Pod vape Starter Kit is created to be a simple and intelligent device for beginners. With 700mAh internal battery, the VLADDIN Vantage provides a long vaping experience. The 1.6ml VLADDIN Vantage Pod has inbuilt coils of 0.8ohm and 1.2ohm, so you are capable of enjoying both MTL and DL vape with VLADDIN Vantage. The VLADDIN Vantage Kit comes with a vape case, bringing an easy way for carrying. You can put a 10ml juice bottle inside. The VLADDIN Vantage will match the suitable power for different pods automatically.
Original FreeMax Maxus 100W TC VW Box Mod + Fireluke 3 Tank Vape Kit Resin Edition $59.99
The Original FreeMax Maxus 100W Kit contains Fireluke 3 tank and Maxus 100W mod. The Fireluke 3 tank is upgraded version of well-known Fireluke 2 Tank. SS904L mesh material and three distinctive steel balls mechanisms are utilized for more stable and more excellent vaping experience, and to avoid potential leaking. The Maxus 100W Mod comes with an OLED display and features an extensive all-rounded list of functions to meet your needs. Uniquely standing out from the rest is its never-seen before feature of enabling the use of battery without regard of polarity, and compatible with 21700 / 20700 / 18650 batteries (not included). Safety features are also packed into the mod to make it the most reliable mod to be paired with a tank superior in comparison to all others in the market.
Original Uwell Yearn 11W 370mAh Pod System Kit $19.99
Original Uwell Yearn has a compact and portable design, which makes can be hided in your hand or fit it in any pocket. And Yearn Cartridge is a disposable pod which has pre-filled e-juice. It adopts a closed pod system and features 1.5ml capacity. The plug-pull replacement method makes the pod swap easier. Besides, the coil offers quick wicking, heats evenly and fully atomizes the juice which gives the best flavor. In addition to this, the built-in 370mAh battery provides a long and stable vapor output. Simply charge using the Micro USB cable. This allows you to enjoy vaping anywhere, anytime!
Original Aspire BP 60 Pod System Vape Kit Replacement Coil Heads(5 PCS) $13.36
The Original Aspire BP 60 Pod System Vape Kit Replacement Coil Head is with 0.3ohm resistance and supports 30W to 40W.
The Original Aspire BP 60 Pod System Vape Kit Replacement Coil Head is with 0.6ohm resistance and supports 15W to 25W.
Original KangerTech Ibar Pod System Vape Kit Replacement Pod Cartridge(3 PCS) $10.99
The Original KangerTech Ibar Pod System Replacement Pod Cartridge holds 2.0ml and 1.2ohm coil.
Original SMOKTech SMOK TFV9 Sub Ohm Tank Replacement Coil Heads(5 PCS) $13.99
The Original SMOK TFV9 Replacement Coils is specially designed for TFV9 Sub Ohm Tank. They are designed for sub-ohm vaping for cloud chasers. The SMOK TFV9 Replacement Coils, which with the gold-plated pin to increase the rub resistance, the SMOK Coils made of nichrome material that features a large heating contact surface area with e-juice, will heat the juice fast
Le Zheng S9 Self Priming Filter Respirator with 5 Spare Filters Anti Bacteria / Virus / COVID-19(1 PC) $9.99
The Dr. Mfyan KN95 Three-Dimensional Protective Mask Particulate Respirator can effectively defend various particles in the air includes PM2.5 dust and bacteria / virus / Coronavirus Disease 2019 (COVID-19). The elastic ear-loops wears easily and comfortable. Comes with 5 PCS KN95 protection level Filters, effectively filtering and protecting from PM2.5 air particulate matter and bacteria. It is suitable for protection against harmful particles such as dust, PM2.5 haze particles, influenza bacteria, droplets and so on.
Старый 22.06.2020, 04:28 Автор темы   668
3FVAPE
AV Lyfe Dimple Hybrid Vape Mechanical Mod Clone $14.99
The AV Lyfe Dimple Hybrid Mechanical Mod Clone is constructed from aluminum (battery tube) and brass (top cap and button). The Dimple mechanical mod Clone is powered by 1 x 18650 battery (not included). Comes with the unique twisted shape, this mod will bring an amazing vaping experience to your vaping life.
Original GAS Mods Kree 24 RTA with 4 Airflow Inserts $30.99
The Original GAS Mods Kree 24 RTA features a dual post build deck for single coil building. The Kree 24mm RTA is with top refilling system and bottom airflow control. It comes with different replaceable airflow control accessories (4.5mm, 4.0mm, 3.5mm, 3.0mm) to bring you plentiful vaping experience.
Original Wizman Stoned Boy Multifunction Vape Kit $159.99
The Wizman Stoned Boy Multifunction Kit features the 3-level mode: Bake, Vape and Dab, which can make you vape or dab easily. Another feature is the modular filter tube for easier cleaning, better taste, healthier dabbing and the gaming control interface with vaping mode and flashing mode. Additional, it can heat up to 300'F in 10 seconds and reach max temperature at 600'F.
Original Yachtvape Pandora MTL RTA Vape Atomizer Replacement Tank Tube $1.99
The glass tank holds 3.5ml capacity and is Suitable for Yachtvape Pandora 30 Plus Airflow Combinations MTL RTA Rebuildable Tank Vape Atomizer.
Original Yachtvape Pandora MTL RTA Vape Atomizer Replacement Drip Tip Set(3 PCS) $4.78
The Drip tip set is made from PC + POM + Acrylic and is Suitable for Yachtvape Pandora 30 Plus Airflow Combinations MTL RTA Rebuildable Tank Vape Atomizer. 3 PCS / Pack
Original Reewape 810 Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $1.99
The Original Reewape RS316SS Resin 810 Drip Tip are suitable for any 810 compatible RDA / RTA / RDTA / Sub ohm Tank vape atomizer. This relatively small drip tip plays an important role in enhancing the vaping experience. It is made of resin and 316 stainless steel. A solid resin construction drip tip assures quality with longevity. The Reewape RS316SS 810 drip tip is 13mm in height and 16mm wide. The double O-Ring helps to uphold a solid connection. Use the Drip Tip contributes a lot in flavor delivery.
Старый 23.06.2020, 05:40 Автор темы   669
3FVAPE
Original SMOKTech SMOK SCAR-18 230W TC VW Box Mod $47.48
The SMOKTech SMOK SCAR-18 VW Vape Box Mod is powered by dual 18650 batteries with 230W max power. The leather and metal inlay design makes it wear-resistant and strong. SMOK SCAR-18 is designed to provide all the horsepower you need with the intelligent onboard chipset IQ-X and fully upgraded components. And there are four modes to meet different needs of effects, flavor and cloud. SCAR-18 supports precise temperature regulation of Nickel, Titanium and Stainless Steel, which allow you to adjust the TCR (temperature sufficient of resistance) value of heating wires to customize the preferred taste. With the IP67 waterproof, IP67 dustproof and shockproof designs, it is more convenient for you to use.
Original Innokin Coolfire Z50 50W 2100mAh VW Box Mod Kit with Zlide Tank $47.99
The Original Innokin Coolfire Z50 VW Kit With Zlide Tube Tank with simple and elegant appearance. The Innokin Coolfire Z50 is the next generation in the internationally bestselling line of Innokin CoolFire vaporizers. And the Innokin Coolfire Z50 Kit comes with large 2100mAh inbuilt battery which provide the high power vaping for you. And the Innokin Coolfire Z50 possesses the 6.0-50.0W adjustable power system. In addition, Innokin Coolfire Z50 Mod is designed for real life that is easy to use with great buttons and a bright OLED screen. You can get 1A fast charging with micro USB and possesses integrated safety protections. The Innokin Zlide Tube Tank comes with the child safety locking system design, and the Innokin Zlide Tube is easy to fill without leakage. With Innokin's bestselling Z-Coils: 1.2ohm coil and 0.8ohm coil for long-lasting life and amazing flavor. And the Innokin Zlide Tube Tank is easy to refill without mess. Just get the Innokin Coolfire Z50 device and enjoy the fantastic vaping.
Original SMOKTech SMOK SCAR-18 230W TC VW Mod Kit with TFV9 Tank $57.98
The SMOKTech SMOK SCAR-18 VW Box Mod Vape Starter Kit consists of SMOK SCAR-18 VW Box Mod and TFV9 Sub Ohm Tank. SCAR-18 Mod Kit is powered by Dual 18650 Batteries with 230W Max. output (Batteries are not included). With a high shock absorption alongside water and dust resistance this is a SMOK SCAR-18 kit that's built to last. Perfect for those always on the go, people who work in labor or just the accident prone among us. As for the SMOK TFV9 Tank is phenomenal and versatile. With an easy and mess-free fill hole and a wide array of coil options this tank is built for maximum flavor and super dense vape clouds. It is primarily a medium power tank but is suited perfectly for Sub Ohm vapers and higher power vapers alike with the wide array of coil options and wattage control. There are multiple protections that ensure your vaping safety such as short circuit protection, over-heating protection, and so on.
Original SMOKTech SMOK SCAR-P5 80W VW Pod System Kit $34.98
The SMOKTech SMOK SCAR-P5 80W VW Mod Pod System Vape Starter Kit, is powered by a Single 18650 battery with Max. 80W Output Power and constructed from Zinc Alloy material, which can deliver flavor from the proprietary pod using RPM Coils. Delivering power in 5~80W range, the SMOK SCAR-P5 can work with any of the coils from the renowned SMOK RPM Coil series, while granting the ability to refill the magnetically held pod at the top. Moreover, SMOK SCAR-P5 Kit features waterproof, shockproof, dustproof and the inventive new coils will bring you the great flavor.
Original SMOKTech SMOK SCAR-P3 80W 2000mAh VW Pod System Kit $35.84
The Original SMOK SCAR-P3 Kit is a kit that features ergonomic leather handle design. It comes with 2000mAh internal battery capacity and supports DTL or MTL vaping for you with different coil. The max power is 80W. There is a responsive tripe button interface for convenient operation. Designed with type-c port, you can enjoy efficient charging. The waterproof, dustproof and shockproof functions will protect your device very well and give you great user experience. More detailed information waiting to be perfected.
SXK Billet Box 70W All-in-One VW TC Box Mod Kit Clone(Replica) with USB Port original price $79.80, now only $72.99
The SXK Billet Box Mod Kit Clone is constructed from aluminum and acrylic with an all-in-one design. This version supports temperature control: 200~600'F / 100~300'C. This mod comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor.
Original OFRF NexMesh Replacement Ni80 Coil for NexMesh Sub-Ohm Tank(2 PCS) $7.99
OFRF NexMesh Coil is designed for powerful taste experience combined with Ni80 mesh coil. The NexMesh Ni80 conical mesh coil inclines to throw you massive vapor and fantastic flavor with the resistance of 0.15ohm. Buy it right now and have an awesome taste. 2 PCS in a pack.
Original Innokin Prism S Replacement Coil Head for Prism T20S Tank, EZ.WATT Kit, Endura T20-S Vape Kit(5 PCS) $9.99
The replacement Prism S coil features 0.8ohm resistance, It is suitable for authentic Innokin EZ.WATT Kit / Prism T20S tank atomizer. This product comes with 5 PCS in 1 pack.
Original Innokin Proton Ajax Replacement Coils Heads for Ajax Tank / MVP5 Starter Kit / Proton Mini Starter Kit(5PCS) $8.99
The Original Innokin Ajax Coil is designed for Innokin Ajax Tank Atomizer. Its coil resistance is 0.35ohm. It is suitable for Innokin Ajax Tank / Innokin MVP5 Starter Kit / Innokin Proton Mini Starter Kit.
The Original Innokin Ajax Coil is designed for Innokin Ajax Tank Atomizer. Its coil resistance is 0.16ohm. It is suitable for Innokin Ajax Tank / Innokin MVP5 Starter Kit / Innokin Proton Mini Starter Kit.
Original SMOKTech SMOK RPM SC 1.0ohm Coil for RPM40, Fetch Mini, RPM80, Fetch Pro, Nord 2, Alike, RPM160 Vape Kit(5 PCS) $13.99
The SMOK RPM SC 1.0ohm Coil is Suitable for SMOK RPM40, SMOK Fetch Mini, SMOK RPM80, SMOK Fetch Pro, SMOK Nord 2, SMOK Alike, SMOK RPM160.
PVC Wrappers Skin Sticker for 20700 / 21700 Battery(20 PCS) $1.99
The PVC Wrappers Skin Sticker is designed for 20700 / 21700 Batteries. 20 PCS / Pack.
810 to 510 Drip Tip Conversion Adapter Connector for SMOK TFV8 Tank Vape Atomizer(1 PC) $2.59
The 510 Drip Tip Adapter Connector is made of stainless steel material is suitable for SMOK TFV8 Tank as a replacement part. With this adapter, you can use the standard 510 drip tip in your TFV8 Tank.
Старый 24.06.2020, 05:07 Автор темы   670
3FVAPE
Original FreeMax Fireluke 3 Sub Ohm Tank Clearomizer Vape Atomizer $26.99
The Original FreeMax Fireluke 3 Tank is a sub-ohm tank made of resin and stainless steel, combining a beautiful look with a sturdy design. The FireLuke 3 Tank features a 5mL maximum capacity, easily accessible via top-fill for ergonomic access. The FreeMax Fireluke 3 Tank's top cap's design integrates three metal balls to have better friction when accessing the top fill system, prevent accident loosening and leakage. To add vape juice to the 5mL reservoir, push the top cap open from a red mark which exposes an effortless filling port. The replacement glass tube provided with a honeycomb surface designed, which is exquisite and eye-catching. The key achievement lies within the new updated FireLuke Mesh Coils (904L X1 / X2 / X3 / X4). The coil tech is also updated to FM COILTECH4.0 with military-grade SS904L mesh material and tea fiber cotton for the ultimate in wicking, saturation, and even heating. The FireLuke 3 Tank is with the easily adjustable bottom airflow slots.
Original FreeMax M Pro 2 Sub Ohm Tank Clearomizer Vape Atomizer $27.99
Original FreeMax M Pro 2 Tank is with upgraded Top-Fill Mechanism and the latest generation of FM COILTECH 4.0 mesh coil technology. The diameter of M Pro 2 Tank is 25mm, and the tank capacity can fill up to 5ml of your favorite electronic juice. M Pro 2 Tank is slide-to-open top-fill design but is added with 3 steel balls to increase the friction when slide to open the top cap. FreeMax M Pro 2 Tank is made of resin and stainless steel structure. M Pro 2 Tank is compatible with the mesh coil newly made with FreeMax CoilTech 4.0 coil tech, composed of new metal material SS904L and tea fiber cotton for more stable vaping experience and refreshing flavors.
Dvarw MTL FL Facelift RTA Vape Atomizer Clone(Replica) with 11 x Air Inserts + 2 x Spare Tanks $22.99
Dvarw MTL FL Facelift RTA atomizer Clone is constructed from stainless steel in 22mm diameter and 5ml capacity. The Dvarw FL RTA contains an improved base, which now allows easy attachment of Clapton spirals. The single coil base itself allows you to experiment with an inexhaustible number of different builds and tune the taste expression exactly according to you. Dvarw MTL FL Facelift 5.0ml RTA Clone has a diameter of 22mm and is supplied airflow insert 1.2mm for classic mode puff-mouth lungs. The Airflow AFC Inserts comes with 11 PCS and size in 1 x 0.8mm, 1 x 1.0mm, 1 x 1.2mm (pre-installed), 1 x 1.5mm, 1 x 2.0mm, 2 x 0.8mm, 2 x 1.2mm, 2 x 1.5mm, 2 x 2.0mm, 3 x 0.6mm, 3 x 0.8mm, 1 x Blank. Comes with 2ml thank section and 3.5ml tank section
Dvarw MTL FL Facelift RTA Clone(Replica) with 11 x Air Inserts $14.99
Original FreeMax Maxus 200W TC VW Box Mod + M Pro 2 Tank Atomizer Vape Kit $64.99
FreeMax Maxus 200W Kit is a device with a variety of powerful functions. The body is made of sturdy and durable zinc alloy, with a multi-element color panel to convey visual impact. Operated by an oversized firing mechanism and two-button adjustments, an accompanying OLED screen provides a large display matrix for essential information at a quick glance. Equipped with Smart-Load Technology, the FreeMaX MAXUS Mod is powered by a single or dual batteries in any configuration (battery not included). The Maxus 200W mod can transmit at up to 200W and is equipped with advanced FM CHIP-MAXUS 1.0 Chipset, at near-instantaneous speeds, delivering clouds of tasty vapor at the press of a button. Maxus 200W also supports multiple output modes, including Power, VPC, Bypass, Temperature Control (TC), and Temperature Coefficient of Resistance (TCR), designed to carefully tailor vapor output to the user's personal preference. The FreeMax M Pro 2 Tank is the updated version of the legend M Pro tank, which is the World's First Double, Triple, Quad, Quint Mesh Coil sub-ohm tank, superior cloud, flavor and coil longevity. M Pro 2 Tank can hold 5mL capacity. The coil provided. M Pro 2 Tank is compatible with the mesh coil newly made with FreeMax CoilTech 4.0 coil tech, composed of new metal material SS904L and tea fiber cotton, can to atomize every single E-liquid molecule and achieve the most exquisite of the restored flavor.
Original Reewape T1 510 Drip Tip Mouthpiece Kit for Vape Atomizers $5.93
The Original Reewape T1 510 Drip Tip Mouthpiece Kit is suitable for Vape Atomizers compatible with 510 drip tips. The 510 drip tips comes 1 Stainless Steel Base and 4 Resin Mouthpieces.
Original Reewape T2 510 Drip Tip Mouthpiece Kit for Vape Atomizers $5.93
The Original Reewape T2 510 Drip Tip Mouthpiece Kit is suitable for Vape Atomizers compatible with 510 drip tips. The 510 drip tips comes 1 Stainless Steel Base and 4 Resin Mouthpieces.
Старый 28.06.2020, 04:27 Автор темы   671
3FVAPE
SXK Insider DB Killer 70W TC VW Stealth Vape Box Mod Clone(Replica) original price $56.90, now only $52.90
The SXK Insider DB Killer 70W TC VW Variable Wattage Stealth Vape Box Mod Clone is made from brushed 316 stainless steel and ABS carbon. The mod is powered by 1 x 18650 battery (not included) and supports wattage adjustable from 5W to 70W, temperature control (200~600'F / 100~300'C). The SXK Insider is compatible with 22mm / 24mm vape atomizer (recommended 22mm)
Original Exvape eXpromizer TCX DL RDTA Replacement Mesh Coils Sheet(10 PCS) $4.28
This Mesh Coil is suitable for Exvape eXpromizer TCX DL RDTA, Mesh KA1 0.15ohm coil. 10 PCS / Pack
This Mesh Coil is suitable for Exvape eXpromizer TCX DL RDTA, Mesh Ni80 0.18ohm coil. 10 PCS / Pack
This Mesh Coil is suitable for Exvape eXpromizer TCX DL RDTA, Mesh KA1 0.2ohm coil. 10 PCS / Pack
SXK Insider DB Killer 70W TC VW Vape Box Mod Clone Replacement Fire Button + Wattage Bottom(2 PCS) original price $9.90, now only $7.99
The Fire Button and Adjustable Wattage Bottom is suitable for SXK Insider DB Killer 70W Vape box Mod Clone. The wattage up and down button are 2-in-1.
SXK Insider DB Killer 70W TC VW Vape Box Mod Clone Replacement knurled 18650 Battery Tube original price $14.90, now only $10.99
The Replacement knurled 18650 Battery Tube is made from Stainless Steel and suitable for SXK Insider DB Killer 70W TC VW Vape Box Mod Clone. Holds 1 x 18650 battery (not included)
Replacement 510 Drip Tip for Flash e-Vapor V4.5 / V4.5S+ RTA $1.99
The 510 drip tip is made from PC and is suitable for Flash e-Vapor V4.5 / V4.5S+ RTA, and other atomizer compatible with 510 drip tip.
Replacement 510 Drip Tip + Top Cap + Chimney + Tank Kit for Flash e-Vapor V4.5 / V4.5S+ RTA $6.99
The 510 drip tip + Top Cap + stainless steel Chimney + Tank Kit is Suitable for Flash e-Vapor V4.5 / V4.5S+ RTA
Старый 29.06.2020, 04:22 Автор темы   672
3FVAPE
Original OFRF NexMesh Sub-Ohm Tank Atomizer Vape Clearomizer original price $34.99, now only $25.99
OFRF NexMesh Sub-Ohm Tank is the first conical mesh coil tank powered by NexMesh coil. It arms with large capacity of 4ml that is able to vape longer. With being equipped with A1 and 316L mesh coils, thicker mesh weave and smoother airflow would be massively given. The coil comes with double cotton design that elevates the flavor to a new level. What is more, the dual vapor compression system really shows you richer and fresher flavor that you have not experienced before.
Original Voopoo PnP Empty Pod Cartridge for Drag S / Drag X Vape Kit(2 PCS) $7.99
The Voopoo PnP Empty Pod Cartridge holds 4.5ml capacity and is suitable for Drag S / Drag X pod system Vape Kit. 2 PCS / Pack
Original Smoant 510 Adapter Connector for Knight Pod System Vape Mod $3.99
The Smoant 510 Adapter is suitable for Smoant Knight 80 RBA Pod Mod Kit, it can match the most 510 thread RTA / RDA / RDTA / Sub ohm tank vape atomizer in the market.
Silver Flower Resin 810 Drip Tip for RDA / RTA / SMOK TFV8 / TFV 12 Tank Vape Atomizer $2.59
This 810 drip tip is made from Resin and is Compatible with SMOK TFV8 & SMOK TFV12 Tanks.
510 Wide Bore Drip Tip for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer $2.99
The 510 Wide Bore Drip Tip made from carbon fiber (mouthpiece) and stainless steel (510 base connector), and it is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
Original Vandy Vape SS316L Mesh Wire for Mesh RDA / RTA / RDTA Vape Atomizer(5 Feet) $3.99
The original Vandy Vape SS316L Mesh Wire 400mesh features elasticity that you can build easily with twist and braid. Designed for RDA / RTA / RDTA / RBA Vape atomizers.
Старый 30.06.2020, 04:29 Автор темы   673
3FVAPE
Original Dovpo College DNA60 60W TC VW Box Mod $125.00
The Original Dovpo College DNA60 Mod is a compact side by side style box mod that is a collaboration with Dovpo and Deer Vape. The device is made of durable and lightweight aluminum alloy. Side by side design with both unique and ergonomics, it fits perfectly in your hand. Delicately processed make every part of College DNA60 looking striking. The front panel of Dovpo College DNA60 Mod has a large fire button and two smaller adjustment keys, while the monochrome display is located at the bottom of the device. The Dovpo College DNA60 box mod is powered by 1 x 18650 battery (not included) and can be operated through the top battery cover to easily replace the battery. The USB port supports to charge and update. A full charging cycle will take 2 to 3 hours. The 510 threading connector adjacent to the battery cap is compatible with atomizers up to a decent 24mm. No overhang, it can meet you all your needs. Dovpo College DNA60 box mod utilizes the Evolv DNA60 Chip to bring you better battery efficiency, can support a maximum power of 60W, with temperature control, synchronous rectification, and reliable protection. Evolv DNA60 chip is a powerful and advanced Chipset - maximum battery life, minimal heat generation, power efficiency, user friendly, and maximizing user protection. Improving all levels of user vape experiences by every puff.
Original FreeMax 904L M1 Mesh Coil Head for M Pro 2 Tank / M Pro Tank Vape Atomizer / Maxus 200W Kit(3 PCS) original price $10.99, now only $9.99
The Original FreeMax 904L M1 Mesh Coil is compatible with M Pro 2 Tank, M Pro Tank and Maxus 200W Kit. It utilizes the latest FM COILTECH 4.0. Made of 95% Tea Fiber Cotton plus 5% Organic Cotton, It will provide you great vaping experience. M1 Mesh Coil 0.15ohm (40~70W). 3 PCS / Pack.
Original FreeMax 904L M2 Mesh Coil Head for M Pro 2 Tank / M Pro Tank Vape Atomizer / Maxus 200W Kit(3 PCS) original price $13.99, now only $10.99
The Original FreeMax 904L M2 Mesh Coil is compatible with M Pro 2 Tank, M Pro Tank and Maxus 200W Kit. It utilizes the latest FM COILTECH 4.0. Made of 95% Tea Fiber Cotton plus 5% Organic Cotton, It will provide you great vaping experience. M2 Mesh Coil 0.2ohm (60~90W). 3 PCS / Pack.
Original FreeMax 904L M3 Mesh Coil Head for M Pro 2 Tank / M Pro Tank Vape Atomizer / Maxus 200W Kit(3 PCS) original price $15.99, now only $11.99
The Original FreeMax 904L M3 Mesh Coil is compatible with M Pro 2 Tank, M Pro Tank and Maxus 200W Kit. It utilizes the latest FM COILTECH 4.0. Made of 95% Tea Fiber Cotton plus 5% Organic Cotton, It will provide you great vaping experience. M3 Mesh Coil 0.15ohm (80~110W). 3 PCS / Pack.
Original FreeMax 904L M4 Mesh Coil Head for M Pro 2 Tank / M Pro Tank Vape Atomizer / Maxus 200W Kit(3 PCS) original price $17.99, now only $12.99
The Original FreeMax 904L M4 Mesh Coil is compatible with M Pro 2 Tank, M Pro Tank and Maxus 200W Kit. It utilizes the latest FM COILTECH 4.0. Made of 95% Tea Fiber Cotton plus 5% Organic Cotton, It will provide you great vaping experience. M4 Mesh Coil 0.15ohm (70~110W). 3 PCS / Pack.
Original FreeMax Fireluke 3 Vape Atomizer Replacement Bubble Glass Tank Tube(1 PC) $2.99
The Original FreeMax Replacement Bubble Glass Tank Tube holds 5.0ml capacity and is suitable for FreeMax Fireluke 3 Sub Ohm Tank Vape Atomizer.
Original FreeMax M Pro 2 Vape Atomizer Replacement Bubble Glass Tank Tube(1 PC) $3.99
The Original FreeMax Replacement Bubble Glass Tank Tube holds 5.0ml capacity and is suitable for FreeMax M Pro 2 Sub Ohm Tank Vape Atomizer.
Старый 01.07.2020, 04:35 Автор темы   674
3FVAPE
The Stealth Vape Mechanical Mod Clone(Replica) $14.99
The Stealth Mechanical Mod Clone is made from copper and powered by 1 x 18650 battery. The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 4 vent holes on the top of the Stealth mod.
Innokin Zlide Sub Ohm Tank Atomizer Vape Clearomizer $19.99
The Innokin Zlide tank is compatible with the entire Z-coil line and maintains the same easy and clean coil replacement system you've come to love from the Zenith. Removing the mouthpiece first allows the top cap to slide open. With the mouth piece in place, the cap is locked closed. The tank can also be unscrewed in order to clean the inside or replace the glass tank section. The top slider can also be disassembled to replace the silicone seal.
The Stealth Mechanical Mod Clone(Replica) + Battle RDA Clone(Replica) Vape Kit $22.99
The Stealth Mechanical Mod Clone is made from Copper and powered by 1 x 18650 battery. The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 4 vent holes on the top of the Stealth mod. The Complyfe Battle RDA Clone is constructed from stainless steel dual-post deck, copper top cap and drip tip.
Original Innokin Replacement Drip Tip for 22mm / 24mm Zlide Sub Ohm Tank Vape Atomizer $2.99
This Drip Tip with child protection for 22mm / 24mm Innokin Zlide Atomizer. Made of high quality material, the Innokin Zlide drip tip is durable to use. Moreover, it is equipped with heat insulation function.
Original Innokin Plexus Z Replacement Coil Head for Zenith MTL Tank / Zlide D22 Tank Vape Atomizer(5 PCS) $8.99
The Plexus Z Coil features 1.0ohm coil resistance and comes with organic cotton, which is compatible with Innokin Zenith MTL Tank, Innokin Zenith D22 Tank, Innokin ZLIDE Tank, Innokin ZLIDE D22 Tank (Part of the Innokin ADEPT Kit). 5 PCS / Pack.
SXK Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System(2 PCS) original price $41.90, now only $38.90
The SXK Replacement Front and Back Door Panel Plates is made from Stabilized Wood and suitable for dotMod dotAIO Vape Pod System 2 PCS / Pack
Старый 02.07.2020, 04:27 Автор темы   675
3FVAPE
Original Vaporesso SWAG II 2 80W VW Box Mod $31.68
The Vaporesso SWAG II 80W VW Box Mod is powered by Single 18650 battery (Not included), the maximum output can reach up to 80W and equipped with a high-quality 0.91-inch OLED screen. Furthermore, the AXON Chip inside brings you the incredible PULSE mode, giving you ultimate vaping experience and next-level comfort. In the pulse mode, AXON will continuously hit you throughout your puff (every 0.02s) - not just from the initial fire - bringing you more powerful, flavorful clouds with every puff.
Original Vaporesso SWAG II 80W VW Box Mod with NRG PE Tank Atomizer Vape Kit $43.91
The Vaporesso SWAG II Kit consists of 80W SWAG II Battery Box Mod and NRG PE MINI Tank atomizer. The SWAG II Mod Kit is powered by single 18650 battery. (Not included) By adopting a special formulated rubber coating, it is now even lighter and more durable, with a hand feel that will give you next level comfort. Equipped with AXON Chip, the SWAG II Kit brings you the incredible Pulse mode, giving you 5x more power in every inhalation. The upgraded GT4 Meshed coil brings dual meshed cores to increase contact area giving denser more flavorful clouds.
Original Artery MT4 11W 480mAh Pod System Kit original price $27.99, now only $8.99
The Original Artery MT4 Kit is a pod system vape starter kit. It is an easy to use and ultra-low-priced entry-level MTL Pod System device. Artery MT4 adopts ultra-lightweight design, the whole body weighs only 25g, put it in your pocket and you can hardly feel its existence. With the compact design and lightweight, the MT4 is ultra-portable to go with. Artery MT4 equipment surface with the special texture, it offers you visual pleasure and more grabbing. Baking Varnish with UV covered to make the sure durable finish. Artery MT4 is powered by a built-in 480mAh battery and is charged through the Micro USB port on the side. There is no button on the body, using the draw-activated mechanism. Artery MT4 can side refilling up to 2.0mL of liquid on the inside of a dedicated refillable pod. Artery MT4 Pod utilizing the same coil material as Pal SE, and it delivers much too fresh and dense flavor by every exhale. Parallel kanthal A1 wire and seagrass fiber cotton + fine tuned airflow system to offer a great flavor. With the flavor boost tech & super affordable price & ultra-portability.
Original Artery PAL LT 11W 700mAh Pod System Kit original price $29.99, now only $14.99
YFTK Diamond Acrylic Tank Tube + Stainless Steel Chimney for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer $7.99
The YFTK Diamond Acrylic Tank Tube and Stainless Steel Chimney Kit is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The tank tube holds 4.0ml capacity.
Original Artery MT4 Pod System Kit Replacement Pod Cartridge with 1.3ohm Coil(3 PCS) $7.99
The Artery MT4 Pod Cartridge is with 2.0ml capacity and is refilling via the side-fill system and securely closed with a silicone stopper. The Kanthal Coil creates an authentic taste with dense vapor.
Original Artery PAL LT Pod System Kit Replacement Pod Cartridge with 1.3ohm Coil(3 PCS) $8.99
The Artery Pal LT Pod Cartridge is with 2.0ml capacity and is refilling via the side-fill system and securely closed with a silicone stopper. The Kanthal Coil creates an authentic taste with dense vapor.
Старый 03.07.2020, 04:23 Автор темы   676
3FVAPE
Original Kizoku Unlimit DL RTA with Prebuild Coil $35.99
The Original Kizoku Unlimit DL RTA is a promising and multifaceted DIY atomizer. Its variably adjustable construction deck is the highlight of the RTA and can also be used to build really large windings (up to 8mm) without any problems. It stands for a lot of steam, where the taste is not neglected. The adjustable airflow ensures optimal airflow and keeps the temperature pleasantly cool. A total of 3.5ml (with DIY deck) liquid can be taken up. The filling is very simple from above. Its length is 55mm (DIY deck) or 41mm (with pre-made coils) and the diameter is 24mm.
Original Vaporesso XROS 11/16W 800mAh Pod System Kit $23.99
The Original Vaporesso XROS Pod is a unique vape that brings you an unparalleled customizable experience. By adopting well-developed Mesh pods and an adjustable airflow control system, XROS maximizes the effectiveness of flavor and nicotine satisfaction. The mighty power of an 800mAh battery is built into a slim body with a classic stainless design. With Type-C fast charge, it only takes 45mins to be fully charged. Single hand refilling with a visible pod enhances your entire experience, especially with the ability to vape by auto-draw or press-to-fire with the dual-firing mechanism. VAPORESSO XROS, an outstanding invention devoted to crossing the limits of the existing MTL devices.
Original Vaporesso XROS Pod System Kit Replacement Pod Cartridge with 1.2ohm Mesh Coil(2 PCS) $6.99
The Original Vaporesso XROS replacement Pod Cartridge It holds 2ml e-juice capacity for daily vaping. And it comes with top filling system and visible window design to bring you great convenience. Besides, it adopts adjustable airflow toggle that maximizes the effectiveness of flavor and nicotine satisfaction to cover your needs. Comes with 1.2ohm mesh coil.
Старый 06.07.2020, 05:00 Автор темы   677
3FVAPE
Replacement Acrylic Tank Tube + Stainless Steel Chimney for Dvarw MTL FL Facelift 22mm RTA $5.99
The Acrylic Tank Tube and Stainless Steel Chimney Kit is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The tank tube holds 4.0ml capacity.
The Acrylic Tank Tube and Stainless Steel Chimney Kit is suitable for Dvarw MTL FL Facelift 22mm RTA Vape Atomizer. The tank tube holds 3.5ml capacity.
Original OBS Cube Tank Vape Atomizer Replacement Glass Tube $1.99
The Original OBS Cube Tank Vape Atomizer Replacement Regular Glass Tube holds 4.0ml capacity.
Original Aleader 810 Drip Tip A Set for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer(8 PCS) $8.99
The Original Aleader 810 Drip Tip A Set is made from resin and is suitable for RDA / RTA / RDTA Tank vape atomizer. 8 PCS / Pack
Original Aleader 810 Drip Tip Set for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer(10 PCS) $10.99
The Original Aleader 810 Drip Tip Set is made from resin and is suitable for RDA / RTA / RDTA Tank vape atomizer. 10 PCS / Pack
Original Aleader 810 / 510 Drip Tip Set for RDA / RTA / RDTA Sub Ohm Tank Vape Atomizer(10 PCS) $8.99
The Original Aleader 810 + 510 Drip Tip Set is made from resin and is suitable for RDA / RTA / RDTA Tank vape atomizer. 10 PCS / Pack
Original Kumiho K2 Zn-alloy Fast Charge Sync Type-C Cable for Samsung Galaxy Note 10 Plus / Note 10 / S10e / S10 Plus(100cm) $3.99
The Original Kumiho K2 Zn-alloy Fast Charge Sync Type-C Cable is suitable for Huawei Mate20, P20, P30, P40 Pro Lite and Samsung Galaxy Note 10 Plus / Note 10 / S10e / S10 Plus, and other Type-C device. Braided, Extreme Durability: With a tested 10000+ bend lifespan, this USB C to USB A charging cable is far more dependable than others in its price range. Micro USB Extensive Compatibility: Work with All Type-C devices, such as Mate20, P20, P30, P40 Pro The most flexible, powerful nylon braided fabric with superior aluminum housing make USB charging cable more durable and tangle free. This Cable is with 2.4A charging current.
Original Kumiho K2 Zn-alloy Fast Charge Sync Micro-USB Cable for Android Cell Phone / Tablet PC(100cm) $3.99
Original Kumiho K2 Zn-alloy Fast Charge Sync Micro-USB Cable for Android device / cellphone / tablet PC. Braided, Extreme Durability: With a tested 10000+ bend lifespan, this USB charging cable is far more dependable than others in its price range. Micro USB Extensive Compatibility: Work with All Micro-USB devices The most flexible, powerful nylon braided fabric with superior aluminum housing make USB charging cable more durable and tangle free.
Original Kumiho K2 Zn-alloy Lightning Fast Charge Sync Cable for iPhone 7 / 8 / X / XS / XR / 11(100cm) $3.99
The Original Kumiho K2 Zn-alloy Lightning Fast Charge Sync Cable is suitable for iPhone 7 / 8 / X / XS / XR / 11 with 100cm length. Braided, Extreme Durability: With a tested 10000+ bend lifespan, this USB C to USB A charging cable is far more dependable than others in its price range. The most flexible, powerful nylon braided fabric with superior aluminum housing make USB charging cable more durable and tangle free. This Cable is with 2.4A charging current.
Старый 07.07.2020, 04:30 Автор темы   678
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Asvape Hita 30W 1000mAh Mech Mod Pod Kit original price $39.99, now only $29.99
The Original Asvape Hita Kit is a pod device based on a mechanical mod design. It combines pod and mechanical design. The retro appearance of the mechanical lever combines the high-quality flavor of the POD device, which is portable and safe to operate. Asvape Hita Mech Pod Kit is powered by a built-in 1000mAh battery with max 30W output, which can easily support your long term requirement. And use Type-C charging port for fast charging, faster and safer, 1h can be fully charged, extra-long battery life. In addition, the intelligence chipset Reekbox developed by Asvape, which can automatically identify different coil resistance and match the best output power. Create perfect fogging effects, whether you are just getting started or advanced players can quickly master. Asvape Hita Mech Pod Kit also features indicator light with the fire button always inform the user as to the current battery levels. Asvape Hita Mech Pod comes with 3ml capacity. Convenient filling of juice liquid by opening the side silicone plug. Equipped side air inlet adjustment. The set comes with two mesh coils for DTL and MTL vaping. Asvape Hita is also compatible with RBA coil for DIY vaping. (RBA Coil is not included).
Original Steam Crave Single Coil Deck for Aromamizer Plus V1 / V2 RDTA Vape Atomizer $10.99
The Original Steam Crave Replacement Single Coil building RBA Deck is made of stainless steel and it is compatible with Steam Crave Aromamizer Plus V1 / V2 RDTA Vape Atomizer as a replacement part.
ShenRay Taifun Typhoon GX MTL/DL RDTA Clone Replacement Tank Tube + Conversion Kit $4.59
The ShenRay Taifun Typhoon GX MTL/DL RDTA Clone Replacement Tank Tube is made from PSU in 2.0ml. Comes with stainless steel 2.0 Conversion Kit.
ShenRay Airdisks Air Disk Air Intake Kit for Taifun Typhoon GX RDTA(3 PCS) $4.99
The ShenRay replacement Airdisks Air Disk Air Intake Kit is suitable for Taifun Typhoon GX RDTA vape atomizer. Comes with 3 PCS / Pack: 3 x 1.2mm + 1 x 1.2mm + Closed.
ShenRay Taifun Typhoon GX MTL/DL RDTA Clone Replacement Tank Tube + Conversion Kit $4.99
The ShenRay Taifun Typhoon GX MTL/DL RDTA Clone Replacement Tank Tube is made from PSU in 4.0ml. Comes with stainless steel 4.0 Conversion Kit.
3FVAPE вне форума   Вверх
Старый 08.07.2020, 05:12 Автор темы   679
3FVAPE
Original VOOPOO Argus Air 25W 900mAh VW Pod System Kit $31.99
Argus Air Pod System Vape Kit contains two different pods: the standard cartridge for 0.6ohm and above PnP coils, and the 0.8ohm pod cartridge with a built-in coil to meet different cloud and flavor requirements. Both pods have a capacity of 3.8ml, filling liquid through the side. 3.8ml side filling the strong magnetic cartridge, newly upgraded design and manufacturing process, effectively prevent oil leakage, more convenient and hygienic use. When using the standard cartridge, try to rotate the atomizer 180 degree and insert it. Argus Air will bring unparalleled comfort to MTL and RDL. Argus Air compatible with PnP Series Coils. PnP series coil has a wide range of models to choose from. We suggest that ARGUS Air use coils with resistance values of 0.6ohm and above to obtain the most comfortable suction experience. Argus Air Kit comes with the latest design PnP-TM1 coil of the PnP series, PnP-TM1 adopting alloying technology, it was inlaid with multi-layer compound cotton inside, remarkably reduce re-filling frequency and make vaping more soothing.
Original VOOPOO Argus GT 160W TC VW Box Mod + PnP Pod Tank Vape Kit $49.99
VOOPOO Argus GT Kit comes with VOOPOO PNP Pod Tank. The tank can hold up to 4.5ml of your favorite electronic juice, and refill the juice from the bottom of the Pod by twisting 510 base. With the addition of a 510 base, PnP Pod Tank fits almost all your VOOPOO devices. PnP Pod Tank not only matches with a rich flavor of PnP coil but also has a PCTG material that is more drop-proof than glass in the outdoor. Argus GT is equipped with two dedicated coils. PnP-VM5 0.2ohm and PnP-VM6 0.15ohm, the strongest combination of the PnP series. Argus GT is compatible with all PnP coils including RBA, just pull and push, you can enjoy different vaping experience, fast and affordable. In addition, PNP Pod Tank has an innovative infinite airflow system. Turn 510 base for airflow adjustment.
Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System(2 PCS) $10.99
The Replacement Front and Back Door Panel Plates is made from PCTG and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) 2 PCS / Pack
SXK Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System(2 PCS) original price $31.90, now only $23.99
The SXK Replacement Front and Back Door Panel Plates is made from PEI and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) 2 PCS / Pack
Original VOOPOO Argus Air Pod System Vape Replacement Empty Pod Standard Cartridge(2 PCS) $6.99
The Original VOOPOO Argus Air Pod System Vape Replacement Empty Pod Standard Cartridge holds 3.8ml and recommend using PnP coils of 0.6ohm and above (coils not included). Powerful Magnet and Keeps It Simple: 3.8ml side filling the strong magnetic cartridge, newly upgraded design and manufacturing process, effectively prevent oil leakage, more convenient and hygienic use.
Original VOOPOO Argus Air Pod System Vape Replacement Pod Cartridge with 0.8ohm MTL Coil(2 PCS) $8.99
The Original VOOPOO Argus Air Pod System Vape Replacement Pod Cartridge holds 3.8ml and built-in 0.8ohm coil for MTL vaping. Powerful Magnet and Keeps It Simple: 3.8ml side filling the strong magnetic cartridge, newly upgraded design and manufacturing process, effectively prevent oil leakage, more convenient and hygienic use.
SXK Replacement Front + Back Cover Panel Plate for DNA 60W / 70W Billet Box Vape Box Mod Clone original price $22.90, now only $14.99
The Replacement Cover Panel is made from acrylic, and is designed for Billet Box mod Kit / SXK Billet Box 70W / DNA60W Box Mod Vape kit Clone. This cover panel comes with 2 pieces (front and back).
SXK Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System(2 PCS) original price $19.90, now only $14.99
The SXK Replacement Front and Back Door Panel Plates is made from acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included) 2 PCS / Pack
Старый 09.07.2020, 04:25 Автор темы   680
3FVAPE
Original Vandy Vape Pulse V2 II 95W TC VW BF Squonk Squeeze Vape Box Mod original price $64.99, now only $49.99
The Original Vandy Vape Pulse V2 II 95W TC VW BF Squonk Squeeze Vape Box Mod is the latest in the Pulse line, culminating the best aspects of previous versions, and incorporating the same waterproof technology from the Swell Mod. Weve created an excellent bottom fill system for the bottle, that keeps it locked in place, and directly in line with the 510 to eliminate potential issues with plumbing inside the mod to transfer juice from one side to the other. With refined lines and ergonomics, this Pulse has everything youve been asking for!
Original Vandy Vape Pulse V2 II 95W Vape Box Mod Replacement Squonk Squeeze Refilling Bottle $7.99
The Original Vandy Vape Pulse V2 II Bottle is special designed for Vandy Vape Pulse V2 95W BF Bottom Feeder Squonk Squeeze Vape Box Mod. The refilling bottle is with 7ml big liquid capacity and supports your daily vaping.
Время генерации страницы 0.49320 секунды с 15 запросами
