Просмотров в теме 260326   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.12.2019, 05:00 Автор темы   541
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
200W Sub Ohm Tank Vape Atomizer Clearomizer original price$20.99, now only$4.99
200W Sub Ohm Tank Atomizer Clearomizer is constructed from Stainless Steel (body) and Glass (tank) in 24mm diameter. It comes with 4ml e-juice capacity and 0.3ohm coil resistance. The 200W Sub Ohm Tank Atomizer supports bottom airflow control and top refilling.
Recoil Rebel RDA Clone with BF Pin + A Spare SS Dual Hole Top Cap original price$9.99, now only$4.99
The Recoil Rebel RDA Clone is constructed from stainless steel in 25mm diameter. This deck features stair style dual post and has a lot of open space for building. The cap has two options (one dual hole cap, one quad hole cap) that allow for several airflow configurations. A removable knurled wide bore drip tip is included. This RDA comes with bottom feeder / BF / Squonk Pin.
Vapeasy Vauban RDA Clone with BF Pin $14.99
The Vapeasy Vauban RDA Rebuildable Dripping Vape Atomizer Clone is constructed from 316 stainless steel and PEI / Ultem air duct inserts. The RDA comes with bottom feeder / BF Pin for squonk mods. The tiny RDA is in 22mm diameter and with middle airflow adjustable. The Vauban RDA Clone is with single coil design and easy to mount coil. The air ducts allow optimal cooling of the coil and are interchangeable. Choosing the appropriate air duct, matched to the coil mount and heating power to get precise and unaltered flavors. Fine adjustment of the air flow is further possible by rotating the top cap. The Vauban atomizer Clone offers interchangeable PEI air duct inserts, supports efficient in Mouth to Lung (MTL) as in DTL draw, you have the choice between savoring your e-liquid in the mouth or producing a consistent cloud of vape.
Original ThinkVape OMEGA AIO 30W 1200mAh VW Box Mod Pod System Vape Starter Kit original price$29.90, now only$20.99
The Think Vape OMEGA AIO 30W VW Box Mod Pod System Vape Starter Kit is powered by built-in 1200mAh battery to support long time vaping. And OMEGA supports VW mode with the range of from 5W to 30W. Thinkvape OMEGA Kit is equipped with 0.69 inch LED screen to show the vaping data and comes with a 3ml e-juice capacity cartridge, a 0.3ohm mesh coil and a 0.6ohm mesh coil. Think Vape OMEGA is also compatible with 1.0ohm regular DC coil and RBA coil for DIY fun. Thinkvape OMEGA pod features easy top filling design.
9-Gear Steampunk Hand Spinner Fidget Toy Focus EDC for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$8.99
The frame of this spinner is aluminum and with 9 brass gears. The EDC Hand Fidget Tri-Spinner Focus Toy is very comfortable. It has perfect balanced weights and smooth surface. The Hand Fidget Tri-Spinner Focus Toy is a perfect fidget toy to keep your hands busy or to just play with.
Fidget Spinner Toy Hand Spinners Stress and Anxiety Relief Toy Focus for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$4.99
The Fidget Spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun in one hand by using the other hand to rapidly spin it from small continuous strikes. With practice, advanced users can hold, spin and stop the spinner using only one hand. Up to 5 minutes Spin Time with one strike! This high precision spinner is made from high quality materials that are durable and long lasting. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers, helps to relieve stress, focus the mind and kill time.
Hand Spinner Fidget Toy Relieves Anxiety Boredom for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$4.99
The Fidget Spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun in one hand by using the other hand to rapidly spin it from small continuous strikes. With practice, advanced users can hold, spin and stop the spinner using only one hand. Up to 5 minutes Spin Time with one strike! This high precision spinner is made from high quality materials that are durable and long lasting. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers.helps to relieve stress, focus the mind and kill time.
Hand Spinner Fidget Toy Relieves Anxiety and Boredom Skull for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$5.99
The frame of this spinner is made of Stainless Steel. The Fidget Spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun in one hand by using the other hand to rapidly spin it from small continuous strikes. With practice, advanced users can hold, spin and stop the spinner using only one hand. Up to 5 minutes Spin Time with one strike! This high precision spinner is made from high quality materials that are durable and long lasting. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers.helps to relieve stress, focus the mind and kill time.
Moon Drop Fidget Hand Spinner Desk Toy Clone with Magnets Gravity on Moon / Mars /Earth(3 PCS) original price$20.99, now only$10.99
The Moon Drop is made with the latest cutting edge technology using precision CNC machining to ensure the perfect quality to every unit. The body is crafted from Aerospace grade Aluminum which is very durable and light weight. Moon Drop is a pretty cool way to learn about amazing physics laws and science facts in our Universe and share them with others. It is much more exciting to actually see and feel the process instead of only hearing theory and numbers. Moon Drop is magnetic- stack them together and discover more ways to play. Whether you are at home, at school, or at the workplace, you can flip it, slide it, spin it and fidget any way you like. Each Moon Drop comes with beautiful desktop stand. It is pocket sized and perfectly fits in a palm so you can take it anywhere you go. Moon Drop is a great way to keep focus, help reduce stress and anxiety.
Starss Tri Bar Hand Spinner Fidget Toy for Adults and Kids of ADHD / Anxiety / OCD original price$20.99, now only$6.99
The Hand Spinner is a high-precision, hand spinning device made from various metals using an automated computer numerical control (CNC) milling process. The hand spinner provides the user with a calming effect and focus. Designed by USA,made in China. The size of this Hand Spinner is suitable perfectly for Adults and Kids.
3FVAPE вне форума   Вверх
Старый 16.12.2019, 05:05 Автор темы   542
3FVAPE
Starss Triangle Hand Spinner Toy Relieves Anxiety and Boredom Gear for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$6.99
MOKURU Tabletop Rolling Stick Toy Fidget Spinner Release Anxiety Attention Stress Clone for Kids / Adult original price$20.99, now only$2.99
MOKURU is an amazing desk toy crafted with quality beech wood. It has a simple design with endless possibilities that will test your creativity and dexterity. Play with MOKURU for fun or sharpen your skills and style to become a master. You can even play MOKURU with friends. Its totally up to you!
Tri Fidget Hand Spinner Work Ultra Fast Bearings Fidget Toy for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$2.99
Triangle Hand Spinner Fidget Toy Relieves Anxiety and Boredom for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$4.99
Triangle Hand Spinner Fidget Toy / Bottle-opener Relieves Anxiety and Boredom for ADHD / OCD Sufferers original price$20.99, now only$6.99
The Fidget Spinner is made of high quality stainless steel material, can be used as a bottle opener. High Speed R188 bearing provides long spin times, smooth spins, and long-lasting durability. Flick and spin for hours with just one hand or both. Or set on a table, hold steady with a finger on the cap, give it your best flick, and time your spins about 2~4 minutes. The removable caps have a concave design (curved inward) that allows for easy and secure grip, and anti-dust desigh to protect the bearings. Great gift for those that like to fidget, or those with anxiety, stress, focus issues, ADHD, autism, or for those that just enjoy spinners for fun!
Triangle Hand Spinner Fidget Toy Relieves Anxiety and Boredom for ADHD / Anxiety / OCD Sufferers original price$20.99, now only$5.99
V2 EDC Triangle Hand Spinner Fidget Toy Relieves Anxiety and Boredom for ADHD original price$20.99, now only$4.99
V2 EDC Triangle Hand Spinner Fidget Toy is great for fidgety hands which may help people to quit smoking and decrease stress. It is easy to carry, small in size, simple to play and also effective for attracting attention.
200W Sub Ohm Tank Atomizer Clearomizer Replacement Coil Head original price$10.99, now only$1.99
The Replacement Coil Head is specially designed for 200W Sub Ohm Tank Atomizer Clearomizer as a replacement part, it features 0.3ohm coil resistance.
Original SMOKTech SMOK RGC Cartridge / SMOK RPM80 Pod Vape Kit Replacement Conical Mesh Coil Head $3.99
The SMOK RGC Coil is designed for SMOK RPM80 Pod Mod Kit and SMOK RGC Pod Cartridge. SMOK RGC Replacement coil is a new RGC conical mesh designed based on the technology of innovative heating element technology - nexMesh technology, which is designed for a powerful, warm throat hit with massive vapor and amazing flavor. The unique conical structure can maximize the bottom of the airflow inlet and condense the vapor as it flows through the coil to the drip tip, creating an unparalleled burst of flavor. At the resistance of 0.17ohm, which is compatible with both e-liquid and nicotine salt, the coil delivers a fast heating rate, intense vapor production, and superb flavor output.
Original SMOKTech RPM80 RPM Pod Vape Kit Replacement Cartridge Compatible with All RPM40 Coils $3.59
The SMOKTech SMOK RPM80 RPM Replacement Pod Cartridge is designed for SMOK RPM80 Pod Mod Kit, which features 5ml oversized e-juice capacity, meet your long-term vape use. RPM80 RPM Pod is compatible with all RPM40 coils to maximize coil compatibility and meet diverse vaping needs. What's more, the pod is transparent, so you know exactly how much is left and when to refill the pod.
Original SMOKTech RPM80 RGC Pod Vape Kit Replacement Cartridge Compatible with RGC 0.17ohm Coil $3.99
The SMOKTech SMOK RPM80 RGC Replacement Pod Cartridge is designed for SMOK RPM80 Pod Mod Kit, which features 5ml oversized e-juice capacity, meet your long-term vape use. It is worth mentioning that, RPM80 RGC Pod is SMOK's first pod with adjustable airflow. Just like an atomizer, the adjustable airflow ring at the bottom can be rotated to adjust the air input. On the other hand, the RPM80 RGC Pod is compatible with RGC conical mesh coil to provide better steam generation and flavor. What's more, the pod is transparent, so you know exactly how much is left and when to refill the pod.
Старый 16.12.2019, 05:07 Автор темы   543
3FVAPE
Original ThinkVape OMEGA AIO 30W Pod Vape Kit Replacement Cartridge $6.99
The ThinkVape OMEGA Replacement Cartridge is designed for ThinkVape OMEGA AIO 30W Pod System Vape Kit, it is made of PCTG material.
Original ThinkVape OMEGA Pod System Vape Kit / Cartridge Replacement Regular DC Coil Head(5 PCS) $8.99
The ThinkVape OMEGA Replacement Regula DC Coil Head is designed for ThinkVape OMEGA AIO 30W Pod System Vape Kit as a replacement part, it features 1.0ohm coil resistance. 5 PCS / Pack.
Original ThinkVape OMEGA AIO 30W Pod System Vape Kit / Cartridge Replacement RBA Coil Head $4.99
The ThinkVape OMEGA Replacement RBA Coil Head is designed for ThinkVape OMEGA AIO 30W Pod System Vape Kit as a replacement part. It fits for DIY lovers.
Original Reewape RUOK Replacement RBA Coil Head with 510 Connector Adapter for Voopoo VINCI / VINCI X Pod System Kit $4.99
The Reewape Ruok RBA Coil is specially designed for DIY lovers, it comes with two-post build deck and single coil building design. It is perfectly compatible with the Voopoo VINCI and VINCI X Mod Pod System Vape Kit.
Original Reewape RUOK Replacement RBA Coil Head with 510 Connector Adapter for Geekavpe Aegis Boost Pod System Kit $4.99
The Reewape Ruok RBA Coil is specially designed for DIY lovers, it comes with two-post build deck and single coil building design. It is perfectly compatible with the Geekavpe Aegis Boost Mod Pod System Vape Kit.
Старый 17.12.2019, 04:36 Автор темы   544
3FVAPE
Original Vapefly Kriemhlid 200W VW Box Vape Mod $89.99
The Vapefly Kriemhild VW Box Vape Mod, adopting type-C port for fast charging, it is powered by 18650, 20700 and 21700 batteries (Not included) with 200W max output. And it is equipped with a 1.33 inch TFT display screen, which will show you details. Furthermore, it has multiple protections that ensure your vaping safety.
Original Vapefly Kriemhild Sub Ohm Tank Vape Atomizer Clearomizer $52.99
The Kriemhild Sub Ohm Tank, a third charity project by Vapefly and German 103, which is constructed from Stainless Steel (body) and Glass (tank), it comes with 5ml e-juice capacity with self-closing e-liquid holes to avoid leakage, which is large enough to provide you with long time vaping. And it adopts easy top filling design with changeable silicon of filling port and child lock. What's more, it utilizes bottom airflow to bring you fabulous flavor. Furthermore, it is compatible with 3 types of coil, like Ni80 mesh coil, 0.15ohm Triple mesh coil (50~80W) and 0.2ohm single mesh coil (50~80W). It will give you a fantastic and comfortable vaping experience. Compatible with Vapefly Kriemhild 200W Starter Kit and Vapefly Kriemhild 200W TC Box Mod (Not included), the Kriemhild Tank will bring you an amazing vaping with intense flavor and huge cloud.
Original Vapefly Kriemhlid 200W VW Box Mod Starter Vape Kit with Sub Ohm Tank $129.99
The Vapefly Kriemhild Kit - the queen of sub ohm kit - is a third charity project by Vapefly and German 103. Vapefly Kriemhild Kit consists of Vapefly Kriemhild VW Box Mod Battery and Kriemhild Sub Ohm Tank Atomizer. Adopting type-C port for fast charging, it is powered by 18650, 20700 and 21700 batteries (Not included) with 200W max output. It features 5ml large e-juice capacity with easy top filling design. And it is equipped with a 1.33 inch TFT display screen, which will show you details. What's more, it supports 3 types of coil to bring you excellent flavor, like 0.2ohm single coil, 0.2ohm dual coil and 0.15ohm triple mesh coil. Furthermore, it utilizes bottom airflow to meet your individual demands better. Importantly, it has multiple protections that ensure your vaping safety.
Origional VOOPOO VINCI 40W 1500mAh VW Mod Pod System Vape Starter Kit(Standard Edition) $30.49
The VOOPOO VINCI Mod Pod Kit consists of the 1500mAh built-in battery mod and visible pod cartridge which both comes with a unique appearance design. The VINCI mod is constructed from zinc alloy material which is decorated with various pattern panels to give you a different sense of vision. And the cuboid shape design will not make you feel any uncomfortable but suitable for gripping in hand on the contrary. Moreover, the common buttons and 0.96" inch TFT colorful screen are both equipped to provide you more information you want. With the up / down button, you can adjust the output wattage from 5W to 40W; with the fire button, you can select the mode suits you the best between Manual mode and Auto mode. Furthermore, the brand-new GENE.AI chipset also makes its debut which aims to provide you more secure and more comfortable user experience like automatically adjust the most suitable wattage for you when a new coil installed. The pod cartridge is made of PCTG material. Transparent appearance design aims to make you know the level of juice inside easily. The 5.5ml large juice capacity also satisfies your daily use. And the new PnP mesh coil series is your best partner for you DL vaping needs. Simple installation methods and perfect performance both give you the best user experience and ultimate vaping experience.
Original Starss ICON Pod System Vape Kit Replacement Cartridge with 2.0ohm Coil(4 PCS) $9.99
The Starss ICON Replacement Pod Cartridge is designed for Starss ICON Pod System Vape Kit. It features 2.0ml juice capacity and comes with a 2.0ohm Coil. 4 PCS / Pack.
Original Vapefly Kriemhild 200W VW Box Mod Vape Kit / Tank Replacement Ni80 Triple Mesh Coil Head(3 PCS) $15.99
The Vapefly Kriemhild Replacement Triple Mesh Coil is designed for Vapefly Kriemhild 200W VW Box Mod Starter Vape Kit and Kriemhild Tank as a replacement part, it features 0.15ohm coil resistance and power range from 50W to 80W. 3 PCS / Pack.
Original Vapefly Kriemhild 200W VW Box Mod Vape Kit / Tank Replacement KA1 Dual Mesh Coil Head(3 PCS) $14.99
The Vapefly Kriemhild Replacement Dual Mesh Coil is designed for Vapefly Kriemhild 200W VW Box Mod Starter Vape Kit and Kriemhild Tank as a replacement part, it features 0.2ohm coil resistance. 3 PCS / Pack.
Original Vapefly Kriemhild 200W VW Box Mod Vape Kit / Tank Replacement Ni80 Single Mesh Coil Head(3 PCS) $13.99
The Vapefly Kriemhild Replacement Single Mesh Coil is designed for Vapefly Kriemhild 200W VW Box Mod Starter Vape Kit and Kriemhild Tank as a replacement part, it features 0.2ohm coil resistance and power range from 50W to 80W. 3 PCS / Pack.
Original Vapefly Kriemhild 200W VW Box Mod Vape Kit / Tank Replacement Straight Tank Tube $2.99
The Vapefly Kriemhild Replacement Straight Tank Tube is designed for Vapefly Kriemhild 200W VW Box Mod Starter Vape Kit and Kriemhild Tank as a replacement part, it is made of glass material and features 5ml juice capacity.
Original Reewape 510 Thread Adapter for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $4.99
The Reewape 510 Thread Adapter is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you.
Старый 18.12.2019, 04:49 Автор темы   545
3FVAPE
Hussar RTA V1.5 Clone $13.99
The Hussar RTA V1.5 Clone is constructed from Stainless Steel in 22mm diameter. The RTA comes with 2 post build deck design, it supports bottom airflow adjustable control and top filling system.
Original Voopoo Navi 40W 1500mAh VW Mod Pod Triple Airflow System Vape Kit $35.99
The Voopoo Navi VW Box Mod Pod Triple Airflow System Vape Starter Kit is combining multiple functions in one innovative mod pod device. The excellent performance makes it stand out. The Voopoo Navi is made of premium Zinc Alloy plus diamond dazzle color craft resin panels, beautiful and stylish. Powered by a built-in 1500mAh battery, the Voopoo Navi integrates with the advanced GENE.AI Chip, featuring a wide output range from 5W to 40W. It is worth mentioning that GENE.AI may be the smartest chip in electronic cigarettes, standing out by intelligent coil matching features, PUFF mode, and other functions. Voopoo Navi also comes with a 0.96-inch screen to clearly display vape data. As for the tank, it features a 3.8ml e-juice capacity, easy top refilling, and newly upgraded magnetic oil suction device. The NAVI comes with standard 0.45ohm and 0.6ohm coil, brings you the best experience of smooth flavors and big clouds. It also supports all coils in the PnP series. One of the outstanding features of the Voopoo Navi pod kit is the innovative triple airflow system, with a fixed airway, an adjustable airway, and a pneumatic independent airway three-port. When vaping NAVI, you can choose between airflow start or button start, with three innovative air ports, you can feel the charm of this mouthfeel device regardless of oral or pulmonary suction. In addition, Voopoo Navi Mod Pod Kit by virtue of innovation of independent airway, it's a more accurate air intake mode and more abundant air intake. And it prevents core-burning from occurring due to insufficient gas intake. Seven safety protection brings a safer and more comfortable vape experience.
Original SMOKTech SMOK RPM80 80W 3000mAh VW Mod Pod System Vape Starter Kit with IQ-80 Chip $33.99
The SMOKTech SMOK RPM80 Mod Pod Kit is powered by 3000mAh Built-in Battery with 80W max output power. With the cuboid-shaped design and intuitive resin material cover, comfortable to grip and with quality looks. Adopts the 0.96-inch colorful display and the concise and informative user interface for the carefree vaping experience. the SMOK RPM80 Device with the newest IQ-80 chipset offers a variety of intelligent features and functional protections that allows the RPM 80 fires up to 80W, you can press the Up and Down buttons to adjust the working wattage to get the preferred effect, and the fast charging system allows the battery will be fully charged in a short time. There are two Pods available: the RPM Pod and RGC Pod, both of them can hold 5ml e-juice, the RPM Pod is compatible with all RPM Coils to maximize coil compatibility and meet diverse vaping needs. And the RPM80 RGC Pod is SMOK first Pod with the adjustable airflow design, the adjustable airflow ring at the bottom can be rotated to adjust the intake freely. What's more, there are two new Coils available, the RGC Conical Mesh Coil and RGC RBA. the RGC Conical Mesh Coil powered by nexMesh technology, designed for the powerful, warm throat hit with massive vapor and amazing flavor. the unique conical structure can maximize the bottom of the airflow inlet and condense the vapor as it flows through the coil to the drip tip, creating an unparalleled burst of flavor.
Original ATVS Xipod 650mAh Temperature-controlled and Anti-dry Burning Pod System Vape Kit $17.99
The ATVS Xipod Temperature-controlled and Anti-dry Burning Pod System Vape Starter Kit is constructed from Zinc Alloy and PCTG material, which comes with light weight in a tiny size, and it is durable. ATVS Xipod Kit utilizes 1.0ohm cotton coil, has stable heat conduction of cotton coil which brings purer taste. Powered by built-in 650mAh lithium battery, Xipod kit has long standby time for your daily vaping. Xipod supports 3 types of temperature range: 200'C / 240'C / 270'C.
Original Vladdin Boqpod 400mAh Pod System Vape Starter Kit + Pod Cartridge $39.99
The Vladdin boqpod is Vladdin Global Ltd. and boqpod tech's first-ever co-branded product, which is powered by 400mAh built-in Battery and comes with 1.0ml juice capacity pod and 1.1ohm Microporous Ceramic Coil. The pod system features a convenient and fully responsive auto-activated airflow switch. And the unique leak-proof pod design allows for optimal use and preservation of the devices' main structure. Multiple camouflage design options with Double-sided magnetic panels make the Boqpod more than just stylish. The 2-in-1 airflow structure keeps liquid and air separated, which along with the storage tank for leaked liquid, improves the product lifecycle. In addition, the unique spit back-proof airflow design provides you with a better vaping experience. More importantly, the Vladdin boqpod kit applying the world's first inlaid mesh coil. The AX ceramic coil combines the advantages of ceramic and metal mesh technologies, ensuring a more pure and flavorful vape experience. Multiple protections applied to provide you a stable and secure vaping experience.
Original Vaporesso Target PM80 80W VW Mod Pod Kit / Cartridge DTL GTX NiCr Mesh Coil Head(5 PCS) $10.99
The Vaporesso Replacement DTL GTX NiCr Mesh Coil Head is designed for Vaporesso Target PM80 80W 2000mAh Sub Ohm DTL VW Mod Pod System Vape Starter Kit / Cartridge. It features 0.2ohm Coil Resistance and power range from 45W to 60W.
The Vaporesso Replacement DTL GTX NiCr Mesh Coil Head is designed for Vaporesso Target PM80 80W 2000mAh Sub Ohm DTL VW Mod Pod System Vape Starter Kit / Cartridge. It features 0.3ohm Coil Resistance and power range from 32W to 45W.
Original SMOKTech SMOK RPM80 / RPM80 Pro Pod System Vape Kit Replacement RGC RBA Clapton Fe-Cr /NiCr Coil Head $5.99
The SMOKTech Replacement RGC RBA Clapton Coil Head is made of Fe-Cr and NiCr material, which is compatible with SMOK RPM80 80W Pod System Vape Kit / SMOK RPM80 Pro Pod System Vape Kit. It features 0.6ohm Coil Resistance.
Original Vaporesso Target PM80 80W VW Mod Pod Vape Kit Replacement Cartridge(2 PCS) $5.99
The Vaporesso Replacement Pod Cartridge is made of PCTG material and designed for Vaporesso Target PM80 80W 2000mAh Sub Ohm DTL VW Mod Pod System Vape Starter Kit. It is compatible with DTL GTX NiCr Mesh Coil Heads (Not included) and comes with 4ml juice capacity. 2 PCS / Pack.
Original ATVS Xipod Pod System Vape Kit Replacement Cartridge with 1.0ohm Ceramic Coil(2 PCS) $6.99
The ATVS Replacement Pod Cartridge is made of PCTG material and designed for ATVS Xipod Pod System Vape Starter Kit. It supports either ceramic coil or cotton coil for different vaping experience. It comes with a 1.0ohm Ceramic Coil and 2ml juice capacity. 2 PCS / Pack.
Старый 19.12.2019, 04:44 Автор темы   546
3FVAPE
YFTK In'Ax V5 DL RTA Clone $29.99
The YFTK In'Ax V5 DL RTA Clone is constructed from 316 Stainless Steel (body) and PC (tank tube) in 22mm Diameter. The RTA supports DL vaping experience and it comes with a 3ml e-juice capacity tank tube and adjustable air-hole that meet your individual vapor need.
Original ThinkVape ZETA AIO 60W VW Box Mod Pod System Vape Starter Kit original price$59.90, now only$38.99
The ThinkVape ZETA Pod Kit is powered by single 18650 batteries (No included), it delivers a maximum output of 60W, along with three modes available to choose, including Power / Bypass / NI / SS. The ThinkVape ZETA replacement pod Cartridge is constructed from Food Grade PCTG material. The pod cartridge of ZETA Pod Kit comes with 3ml e-liquid capacity and multiple coils for your different demand. And it also supports RBA coil for DIY lovers. (RBA Coil not included)
Original ATVS Sirius 30W 1000mAh VW Box Mod Pod System Vape Starter Kit $24.99
The ATVS Sirius Box Mod Kit is a variable wattage box mod kit, it is powered by 1000mAh rechargeable battery with output wattage range from 5W to 30W. The Mod Kit is constructed from Acrylic and Aluminum Alloy. ATVS Sirius comes with two types of coil: 0.6ohm mesh coil and 1.0ohm regular coil and a 2.0ml refillable pod cartridge that can meet your all day long vaping experience.
Steam Tuners Replacement Bell Cap Clone for Dvarw MTL RTA Vape Atomizer $4.99
The Steam Tuners Replacement Bell Cap Clone is made from PMMA, which is compatible with Steam Tuners Dvarw MTL RTA Vape Atomizer Clone. The cap is 22mm diameter. The bell cap has a 3.5ml juice capacity.
Firebird Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $3.99
The Firebird 510 Replacement Drip Tip is made of Stainless Steel and POM and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape RW-AS283 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape RW-AS283 Replacement 510 Drip Tip is made of resin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape RW-AS284 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape RW-AS284 Replacement 510 Drip Tip is made of resin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape RW-AS286 Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape RW-AS286 Replacement 510 Drip Tip is made of resin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape RW-AS285 Replacement 510 MTL Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape RW-AS285 Replacement 510 MTL Drip Tip is made of resin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
YFTK Replacement Diamond Top Cap Tank Tube + Chimney for Flash e-Vapor V4 / V4.5 RTA Vape Atomizer Clone $5.99
The YFTK replacement PC Diamond Top Cap Tank Tube and 316 Stainless Steel Chimney is suitable for Flash e-Vapor V4 / V4.5 RTA Vape Atomizer Clone. It comes with 5ml juice capacity.
Original Reewape 510 Thread Adapter for SMOKTech SMOK RPM40 Pod System Vape Kit $3.99
The Reewape 510 Thread Adapter is designed for SMOK RPM40 Pod System Vape Kit, it can switch your SMOK RPM40 Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The 510 thread adapter includes: outer black part is made of Aluminum Alloy Plating, middle part (thread) is made of Stainless Steel.
The Reewape 510 Thread Adapter is designed for SMOK RPM40 Pod System Vape Kit, it can switch your SMOK RPM40 Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The 510 thread adapter includes: outer housing part is made of Aluminum Alloy, middle part (510 threading connection) is made of Stainless Steel.
Original Reewape 510 Thread Adapter for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $3.99
Старый 20.12.2019, 04:32 Автор темы   547
3FVAPE
Original Hugo Vapor URUS 100W TC VW Box Vape Mod $31.99
The Hugo Vapor URUS Mod can be compatible with 18650, 20700, 21700 batteries (Not included) and the maximum output can reach 100W. It utilizes Nylonfibre frame, which makes the mod very light-weight for easy carry. The atomizer resistance supported is from 0.06 to 3ohm. With multiple working modes, including VW, Bypass, TC (Ni, Ti, SS), VTC and Preheat, URUS Mod will bring you a lot of fun on vaping.
Original Hugo Vapor Rader ECO 200W VW Box Vape Mod $28.99
The Hugo Vapor Rader Eco Mod, powered by dual 18650 batteries (Not included) with 200W max output, is the newly designed box mod from Hugo Vapor. The Rader Eco supports Variable Voltage, Variable Wattage, Bypass and Curve Heating output Mode. Equipped with the 0.96inch OLED screen, the Hugo Vapor Rader Eco Mod will bring you great vaping experience.
Original Hugo Vapor Conqueror 2200mAh TC Herb Vaporizer Vape Starter Kit $24.99
The Original Hugo Vapor Conqueror Kit is a herb vaporizer kit used for dry herb and other dry things for vapor. With a 2200mAh built-in battery, it has a large battery capacity and the battery can be recharge with the micro USB charger easily. The Hugo Vapor Conqueror Kit features light weight and attractive appearance, it is easy and portable to carry with you.
Original Hugo Vapor Submarine 850mAh TC Pod System Vaporizer Vape Starter Kit $14.99
The Hugo Vapor Submarine Kit, with an 850mAh built-in battery, is a Pod System with the one button operation, it features a full LED with temperature control, battery life indicator, and an all-ceramic heating chamber. There are 3 shift temperature control: 200'C, 220'C, 240'C. 10 small openings to limit the heating of the battery and a central LED indicating the remaining level of autonomy. Designed for use in MTL (Mouth-to-lung), the Submarine Pod System will work with pods containing 0.7ohm coils. Once switched on, there is no need for the switch, the system only turns on during inhalation. With the small size, the Hugo Vapor Submarine Pod System Kit is compact on your hand.
Original Vapelustion Hannya Nano 600mAh Pod System Vape Starter Kit with 2 Paired Pannels original price$36.99, now only$27.99
The Vapelustion Hannya Nano Pod System Vape Starter Kit comes with a traditional classic body, which means the possibility of infinite change. Hannya Nano is constructed from Plastic and Metal material, it is powered by 600mAh Built-in Battery and comes with a 2ml e-juice capacity refillable pod cartridge and 1.2ohm resistance coil. It continues the unremitting spirit of hannya mod black and white nano that comes with different themes metal panel, each of which is accompanied by a lanyard with the same theme.
Старый 23.12.2019, 04:34 Автор темы   548
3FVAPE
Original Gas Mods G.R.1 GR1 S RDA with BF Pin original price$24.99, now only$13.99
The Gas Mods G.R.1 GR1 S RDA is constructed from Stainless Steel and POM in 22mm Diameter. The G.R.1 S has air-holes that support middle airflow adjustable, it can meet your different vapor cloud needs.
Original Gas Mods Kree RTA with A Spare PC Tank Tube original price$29.99, now only$20.99
The Gas Mods Kree RTA is constructed from Stainless Steel and Glass in 22mm Diameter. The RTA (2.5mm airflow inside) comes with a dual terminal build deck that is easy building and a 3.5ml e-juice capacity tube. Furthermore, the RTA comes with 5 airflow inserts (Inner Diameer: 2.0mm, 1.5mm, 1.2mm, 1.0mm, 0.8mm) and a 510 adapter. Kree RTA supports middle airflow adjustable control.
Original Wismec R80 80W VW Mod Pod System Vape Starter Kit $28.99
The Wismec R80 VW Mod Pod System Vape Kit is a portable and multifunctional device that can be used as both a Pod Mod kit or a regular Mod kit. With the help of an atomizer adapter (Not included), R80 is compatible with regular tanks. Inspired by the Reuleaux triangle, the unique shape of R80 brings you a quite comfortable hand feeling. It is mini that the R80 kit can be taken anywhere. R80 pod kit is powered by a replaceable 18650 cell structure innovatively (Not included), offering you a 80W high power output and longer-lasting. And the Wismec R80 adopts USB-C port this time, making charging faster than ever. What's more, there is no need to worry about the direction when you insert the USB-C cable. Another major attraction of the R80 pod vape kit is its humanized battery cover open way. By rotating the buckle, you can replace the 18650 battery quickly and easily. You can also unscrew the battery cover with a coin. Besides, the Cover cap on the top of the machine effectively prevents leakage and dust. And the ergonomic design mouthpiece could perfectly fit your mouth and offer a better user experience. It is worth mentioning that, for the first time, Wismec applied a 0.96-inch TFT screen to the pod mod. The changeable display colors make it outstanding. The Wismec R80 Pod cartridge has a large capacity of 4ml, which can store a large amount of e-juice for long-term vaping. The whole cartridge is transparent and visible, vapers can notice the e-liquid remaining level whenever and wherever. R80 comes with KTR Mesh 0.3ohm coil and NiCr 0.8ohm coil, bringing vapers huge vapor cloud and optimal flavor. R80 will be your priority whatever in appearance or function.
Original Smoant Charon Baby 750mAh Pod System Vape Starter Kit original price$36.99, now only$18.99
The Smoant Charon Baby Pod System Vape Kit with innovative CPR technology, featuring a colorful and durable stunning finish and will leave no fingerprinter on it. Powered by 750mAh built-in battery, Charon baby is charged by the lanyard USB type-C cable and it has three colors LED lights to indicate the battery status and comes with two types of coil: 0.6ohm Mesh Coil (15W) and 1.2ohm Ni80 Coil (10W) and a 2.0ml e-juice capacity pod cartridge with side refilling system to meet your different vaping needs. What's more, Charon Baby is compatible with Battlestar baby coils and cartridges.
Original Reewape AS287SS Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $1.99
The Reewape AS287SS Replacement 510 Drip Tip is made of resin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Reewape AS289 Replacement 810 Drip Tip for 528 Goon / Reload / Kennedy /Wotofo Profile/Battle RDA $1.99
The Reewape AS289 Replacement 810 drip tip is made of resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Старый 24.12.2019, 05:05 Автор темы   549
3FVAPE
Original Asmodus Lustro 200W Touch Screen TC VW Vape Box Mod original price$79.95, now only$38.99
The original Asmodus Lustro Box Mod is a versatile regulated mod powered by dual 18650 batteries (not included), which can reach maximum output to 200W. With a capacitive touch screen, the operation on Lustro is very easy to vapers. Working with the latest GX-200-HUT chipset, Lustro Box Mod provides high performance in all aspects. The Curve output mode allows for detailed customization of the firing curve. The Lustro Box Mod will bring you the most comfortable vaping experience.
Original Artery PAL SE 20W 700mAh MTL Pod System Vape Starter Kit $26.99
The Artery PAL SE MTL Pod System Vape Starter Kit, an elaborately designed MTL Pod kit, it is constructed from Zinc Alloy and PCTG material and features the seagrass fiber cotton purify technology pod which can restore into 99% original flavor of the e-juice and it is more healthy. PAL SE is powered by 700mAh built-in battery with 20W Max Output Power and comes with 2ml e-juice capacity pod cartridge to ensure the long-lasting vaping and it can be fully charged by convenient Type-C port within 40 mins. With the LED indicator, you can know the battery level in vaping or charging easily. Furthermore, there are multiple protections that ensure your vaping safety.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit / Vape Mod Kit - 8mm Diameter (10 PCS) $1.59
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 8mm Diameter. It needs to be used by connecting with Neutral Lanyard.(Lanyard is not included). 10 PCS / Pack.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit /Vape Mod Kit - 13mm Diameter (10 PCS) $1.69
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 13mm Diameter. It needs to be used by connecting with Neutral Lanyard.(Lanyard is not included). 10 PCS / Pack.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit /Vape Mod Kit - 20mm Diameter (10 PCS) $1.79
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 20mm Diameter. It needs to be used by connecting with Neutral Lanyard.(Lanyard is not included). 10 PCS / Pack.
Replacement Neutral Lanyard with Connector for E-Cigarette / Pod Vape Kit / Vape Mod Kit $1.29
The Neutral Lanyard with Connector is made of Bamboo Fiber material, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit. It is compatible with Neutral Silicone Ring.(Neutral Silicone Ring is not included). The Lanyard with "cell phone loop" so that it also can be attached to the USB stick, vape device, whistles, keys, ID badge, or phone. The lanyard can be worn around the neck.The stick is then firmly attached to the lanyard. It can be removed and clipped on as often as you like.
Replacement Disposable Silicone Taste Cap for Juul / Puff / Hide Pod Vape Kit(10 PCS) $1.19
The Replacement Disposable Silicone Taste Cap is suitable for Juul Pod Vape Kit / Puff Pod Vape Kit / Hide Pod Vape Kit as a replacement part, it is made of silicone material. 10 PCS / Pack.
Replacement Disposable 510 Drip Tip for RDA / RTA / RDTA / Clearomizer / Sub Ohm Tank(10 PCS) $1.19
The Disposable Replacement 510 Drip Tip is made of Silicone. It is suitable for RDA / RTA / RDTA / Clearomizer Vape Atomizer and can fit most atomizers or cartomizers with 510 connectors. 10 PCS / Pack.
Replacement Disposable 810 Drip Tip for 528 Goon / Reload / Kennedy / Wotofo Profile / Battle RDA(10 PCS) $1.19
The Disposable 810 Drip Tip is made of silicone. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. 10 PCS / Pack.
Старый 24.12.2019, 05:05 Автор темы   550
3FVAPE
Replacement Disposable Silicone Taste Cap for Uwell Caliburn / Caliburn KOKO Pod Vape Kit(10 PCS) $1.39
The Replacement Disposable Silicone Taste Cap is suitable for Uwell Caliburn Pod Vape Kit / Caliburn KOKO Pod Vape Kit as a replacement part, it is made of silicone material. 10 PCS / Pack.
Replacement Disposable Silicone Taste Cap with 9.2mm Inside Diameter for Pod Vape Kit /Vape Mod Kit with 510 Tip(10 PCS) $1.19
The Replacement Disposable Silicone Taste Cap with 9.2mm Inside Diameter is suitable for most of Pod Vape Kit / Vape Mod Kit with 510 Tip as a replacement part, it is made of silicone material. 10 PCS / Pack.
Replacement Disposable Silicone Taste Cap for Relx Alpha / Voopoo VINCI / VINCI X / SMOK RPM 40 Pod Vape Kit(10 PCS) $1.19
The Replacement Disposable Silicone Taste Cap is suitable for Relx Alpha Pod Vape Kit / Voopoo VINCI Pod Vape Kit / VINCI X Pod Vape Kit / SMOK RPM 40 Pod Vape Kit as a replacement part, it is made of silicone material. 10 PCS / Pack.
Replacement Silicone Dust Cap for Relx Alpha / Caliburn Flat Rod-Shaped Pod System Vape Kit $1.09
The Replacement Silicone Dust Cap is suitable for Relx Alpha / Caliburn Flat Rod-Shaped Pod Vape Kit as a replacement part, it is made of silicone material.
Original Artery PAL SE MTL Pod Vape Kit Replacement Cartridge with 1.4ohm Coil(3 PCS) (Standard Version) original price$12.90, now only$7.99
The PAL SE Pod Cartridge is designed for Artery PAL SE MTL Pod System Vape Starter Kit as a replacement part, it comes with 2ml e-juice capacity and 1.4ohm resistance coil. Adopting the sea grass fiber cotton and purify technology, it will provide 99% original flavor and is more healthier. 3 PCS / Pack.
Original Artery PAL SE MTL Pod Vape Kit Replacement Cartridge with 1.0ohm Coil(3 PCS) (Standard Version) original price$12.90, now only$7.99
The PAL SE Pod Cartridge is designed for Artery PAL SE MTL Pod System Vape Starter Kit as a replacement part, it comes with 2ml e-juice capacity and 1.0ohm resistance coil. Adopting the sea grass fiber cotton and purify technology, it will provide 99% original flavor and is more healthier. 3 PCS / Pack.
Hussar RTA V1.5 Tank Vape Atomizer Clone Replacement Top Cap Tank Tube + Drip Tip $3.99
The Replacement Top Cap Tank Tube and Drip Tip are designed for Hussar Style RTA V1.5 Tank Vape Atomizer as a replacement part. They are made of PC material. The top cap tank tube is 22.5mm height and 22mm diameter, the drip tip is 14mm height and 9.5mm outer diameter.
Original Yachtvape Replacement RBA Deck Coil Head with 510 Connector Adapter for GeekVape Aegis Boost Pod Vape Kit $5.99
The Yachtvape RBA Deck Coil Head is specially designed for DIY lovers, it comes with two-post build deck and single coil building design. It is perfectly compatible with the Geekvape Aegis Boost Mod Pod System Vape Kit.
Original OMEKA 510 Thread Adapter with Spring-Loaded Center Pin for SMOK RPM 40W Pod Vape Kit $3.99
The OMEKA 510 Thread Adapter is designed for SMOK RPM Pod System Vape Kit, it can switch your SMOK RPM Pod Mod to a normal 40W Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The OMEKA 510 Thread Adapter is made of POM (Outer Housing) and Brass & Gold Plating (510 Threading Connector). As for this 510 threading connector, it comes with a special Spring-Loaded 510 Center Pin design that can be fitted for 510 drip tip with different lengths.
Старый 25.12.2019, 04:52 Автор темы   551
3FVAPE
Original ShenRay FENRIS RDTA $45.00
The ShenRay FENRIS RDTA Rebuildable Dripping Tank Vape Atomizer is constructed from 316 Stainless Steel (body) and Glass (tank tube) in 25mm Diameter and 71mm Height. The FENRIS RDTA comes with a super large 10ml e-juice capacity tank tube that can provide you a sufficient completely capacity to meet your all day long vaping. Also, FENRIS comes with 5 airflow adjustable holes in two sides (1.0mm, 1.2mm) that can keep a fluent airflow control and meet your different vapor needs. What's more, FENRIS supports top refilling system and top airflow adjustable control.
Original Hugo Vapor Delta 2200mAh Ceramic Pot Heating Dry Herb Vaporizer Vape Starter Kit $14.99
The Hugo Vapor Delta Ceramic Pot Heating Dry Herb Vaporizer Vape Starter Kit is powered by 2200mAh built-in battery and it has three pressure regulations that can switch three different temperature to meet your different vaping needs.
Original Rincoe Manto Pro 228W TC VW Box Vape Mod Kit with Metis RDA Atomizer $25.99
The Rincoe Manto Pro RDA Kit consists of Manto Pro 228W Mod and Metis RDA Atomizer. It is an ergonomically designed powerful beast. The Manto Pro Mod is powered by dual 18650 batteries (Not included), which are powerful enough to provide long durability with sufficient power, and it constructed from lightweight PC material with anti-shock functionality, lightweight in a tiny size for an ergonomic offering. The internal chipset features 228W of maximum output which provides multiple types of protections to ensure your vaping safety. What's more, Manto Pro supports Power / VW / TC (Ni200 / Ti / SS) / Bypass modes to meet your different vaping needs. On the other hand, Rincoe Metis RDA in 24mm diameter comes with dual coil build deck which is easy to build and wick for dense flavor. It features a gold plated 510 contact pin, and comes with a wide bore 810 drip tip providing you massive cloud.
Original VapeSoon Replacement RPM Mesh Coil Head for SMOK RPM40 /RPM80 Pod System Vape Kit(5 PCS) $6.99
The VapeSoon Replacement RPM Mesh Coil Head is specially designed for SMOK RPM40 Pod Kit / SMOK RPM80 Pod Kit as a replacement part. It features 0.4ohm coil resistance and is recommended to be used at 25W (Best). 5 PCS / Pack.
Original VapeSoon Replacement RPM Triple Coil Head for SMOK RPM40 / RPM80 Pod Vape Kit(5 PCS) $6.99
The VapeSoon Replacement RPM Triple Coil Head is specially designed for SMOK RPM40 Pod Kit / SMOK RPM80 Pod Kit as a replacement part. It features 0.6ohm coil resistance and is recommended to be used at 25W (Best). 5 PCS / Pack.
Original VapeSoon Replacement RPM SC Coil Head for SMOK RPM40 / RPM80 Pod System Vape Kit(5 PCS) $6.99
The VapeSoon Replacement RPM SC Coil Head is specially designed for SMOK RPM40 Pod Kit / SMOK RPM80 Pod Kit as a replacement part. It features 1.0ohm coil resistance and is recommended to be used at 14W (Best). 5 PCS / Pack.
Original VapeSoon Replacement RPM Quartz Coil Head for SMOK RPM40 / RPM80 Pod Vape Kit(5 PCS) $6.99
The VapeSoon Replacement RPM Quartz Coil Head is specially designed for SMOK RPM40 Pod Kit / SMOK RPM80 Pod Kit as a replacement part. It features 1.2ohm coil resistance and is recommended to be used at 12W (Best). 5 PCS / Pack.
Original VapeSoon Replacement Regular Coil Head for Lost Vape Lyra Pod System Vape Kit $8.99
The VapeSoon Replacement Regular Coil Head is specially designed for Lost Vape Lyra Pod Kit as a replacement part. It features 1.2ohm coil resistance. 5 PCS / Pack.
Original VapeSoon Replacement Mesh Coil Head for Lost Vape Lyra Pod System Vape Kit $8.99
The VapeSoon Replacement Mesh Coil Head is specially designed for Lost Vape Lyra Pod Kit as a replacement part. It features 0.6ohm coil resistance. 5 PCS / Pack.
Original VapeSoon Replacement QF Meshed Coil Head for Vaporesso Skrr Sub Ohm Tank(50~80W) $2.59
The VapeSoon Replacement QF Meshed Coil Head is specially designed for Vaporesso Skrr Sub Ohm Tank as a replacement part. It features 0.2ohm coil resistance and power range from 50W to 80W (Best: 65~75W).
Original VapeSoon Replacement QF Strips Coil Head for Vaporesso Skrr Sub Ohm Tank $2.59
The VapeSoon Replacement QF Strips Coil Head is specially designed for Vaporesso Skrr Sub Ohm Tank as a replacement part. It features 0.15ohm coil resistance and power range from 50W to 80W (Best: 65~75W).
Original VapeSoon Replacement EX-M Coil Head for Joyetech EXCEED Grip Pod System Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement EX-M Coil Head is specially designed for Joyetech EXCEED Grip Pod System Vape Kit as a replacement part. It features 0.4ohm coil resistance and power range from 10W to 13W. 5 PCS / Pack.
Original VapeSoon Replacement Ceramic Coil Head for SMOK Nord / Trinity Alpha /Fetch Mini Pod Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Ceramic Coil Head is specially designed for SMOK Nord / Trinity Alpha / Fetch Mini Pod System Vape Kit as a replacement part. It features 1.4ohm coil resistance. 5 PCS / Pack.
Старый 25.12.2019, 04:56 Автор темы   552
3FVAPE
Original VapeSoon Replacement Regular Coil Head for SMOK Nord / Trinity Alpha /Fetch Mini Pod Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Regular Coil Head is specially designed for SMOK Nord / Trinity Alpha / Fetch Mini Pod System Vape Kit as a replacement part. It features 1.4ohm coil resistance. 5 PCS / Pack.
Original VapeSoon Replacement Mesh Coil Head for SMOK Nord / Trinity Alpha / Fetch Mini Pod Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Mesh Coil Head is specially designed for SMOK Nord / Trinity Alpha / Fetch Mini Pod System Vape Kit as a replacement part. It features 0.6ohm coil resistance. 5 PCS / Pack.
Original VapeSoon Replacement Mesh-MTL Coil Head for SMOK Nord / Trinity Alpha/Fetch Mini Pod Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Mesh-MTL Coil Head is specially designed for SMOK Nord / Trinity Alpha / Fetch Mini Pod System Vape Kit as a replacement part. It features 0.8ohm coil resistance. 5 PCS / Pack.
Original VapeSoon Replacement Mesh Coil Head for Artery PAL II Pod System Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Mesh Coil Head is specially designed for Artery PAL II Pod System Vape Kit as a replacement part. It features 0.6ohm coil resistance and power range from 15W to 23W. 5 PCS / Pack.
Original VapeSoon Replacement Regular Coil Head for Artery PAL II Pod System Vape Kit(5 PCS) $5.99
The VapeSoon Replacement Replacement Regular Coil Head is specially designed for Artery PAL II Pod System Vape Kit as a replacement part. It features 1.2ohm coil resistance and power range from 7W to 12W. 5 PCS / Pack.
The VapeSoon Replacement Replacement Regular Coil Head is specially designed for Artery PAL II Pod System Vape Kit as a replacement part. It features 1.0ohm coil resistance and power range from 9W to 13.5W. 5 PCS / Pack.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit / Vape Mod Kit(5 PCS) $1.09
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material in 13mm diameter, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 8mm Diameter. It needs to be used by connecting with Neutral Lanyard. (Lanyard is not included). 5 PCS / Pack.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit / Vape Mod Kit(5 PCS) $0.99
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material in 8mm diameter, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 8mm Diameter. It needs to be used by connecting with Neutral Lanyard. (Lanyard is not included). 5 PCS / Pack.
Replacement Neutral Silicone Ring with Lanyard Connector for E-Cigarette / Pod Kit / Vape Mod Kit(5 PCS) $1.49
The Neutral Silicone Ring with Lanyard Connector is made of Silicone material in 20mm diameter, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit in 8mm Diameter. It needs to be used by connecting with Neutral Lanyard. (Lanyard is not included). 5 PCS / Pack.
Старый 26.12.2019, 04:29 Автор темы   553
3FVAPE
Original Chill C-Pod 550mAh Pod System Vape Kit with Bluetooth & Camera Control $21.99
The Chill C-Pod System Vape Kit is constructed from Aluminum Alloy + Stainless Steel material, which is powered by 550mAh built-in battery and comes with a 1.4ohm resistance coil that can meet your all day long vaping experience. It is worthy that C-Pod is quipped with Bluetooth and camera control function that can connect your phone device to take a photo or record a video.
Original Oukitel Hero 13W 850mAh AIO Pod System Vape Starter Kit $22.99
The Oukitel Hero AIO Pod System Vape Kit has elegant appearance and ultrathin body. It is powered by 850mAh built-in battery. With air switch and fire button design, you can direct vape by inhaling or press the button, two ways to start vaping. Oukitel Hero comes with a pod cartridge of 2ml capacity and 1.2ohm cotton dual core to deliver the true flavor of liquid in double, and it support regular liquid or nicotine salt. What's more, it features motor vibration reminder function for easy operation, this pod vape kit is perfect suit for beginners.
Original IJOY Jupiter 70W VW Box Mod Pod System Vape Starter Kit original price$37.99, now only$30.99
The IJOY Jupiter Pod System Vape Starter Kit is constructed from Aluminium, Zinc Alloy and Leather with elegant and modern outlook, adopting the leading-edge UNIV chipset. Jupiter is powered by single 18650 battery (Not included) with max 70W power output, and supports one-day vaping. It has a pod cartridge of 5ml e-juice capacity with bottom refilling design. Also, it comes with two types of coil: J1 0.2ohm mesh coil and J2 0.6ohm mesh coil for massive clouds and optimal flavor. Equipped with a 0.96 inch TFT color screen, the JOY Jupiter will bring you great vaping!
Original Oukitel Hero Pod System Vape Kit Replacement Cartridge with 1.2ohm Cotton Dual-Core(3 PCS) $8.99
The Oukitel Replacement Cartridge is designed for Oukitel Hero Pod System Vape Kit, which comes with 2ml e-juice capacity and features 1.2ohm Cotton Dual-Core Coil. 3 PCS / Pack.
Original IJOY Jupiter Pod System Vape Kit Replacement Cartridge with 0.2ohm Mesh Coil $7.89
The IJOY Replacement Cartridge is designed for IJOY Jupiter Pod System Vape Kit, which comes with 5ml e-juice capacity and features 0.2ohm Mesh Coil.
Original IJOY Jupiter Pod System Vape Kit / Cartridge Replacement Mesh-J2 Coil Head(3 PCS) $6.29
The IJOY Replacement Mesh-J2 Coil Head is designed for IJOY Jupiter Pod System Vape Kit, which features 0.6ohm coil resistance and power range from 20W to 30W. 3 PCS / Pack.
Original IJOY Jupiter Pod System Vape Kit / Cartridge Replacement Mesh-J1 Coil Head(3 PCS) $6.29
The IJOY Replacement Mesh-J1 Coil Head is designed for IJOY Jupiter Pod System Vape Kit, which features 0.2ohm coil resistance and power range from 40W to 60W. 3 PCS / Pack.
Original IJOY Jupiter Pod System Vape Kit / Cartridge Replacement Mesh-RBA-J3 Coil Head with 510 Adapter $6.29
The IJOY Replacement Mesh-RBA-J3 Coil Head is designed for IJOY Jupiter Pod System Vape Kit, which is recommended to be use with 0.1~1.5ohm resistance. It comes with a 510 Adapter and fits for DIY vaping lovers.
Replacement Bump Anti Slip Silicone Band for E-Cigarette / Pod Kit / Vape Mod Kit - 19mm Diameter (5 PCS) $2.59
The Bump Anti Slip Band is made of Silicone material in 19mm diameter, it is suitable for most of E-Cigarette / Pod Vape Kit / Vape Mod Kit and designed for 19mm diameter glass tank, RBA or RTA, RDA and Tube Mod.. The vape band is a necessary accessory for any and ALL vapers, especially glass tank users. Not only does it keep your device stylish and looking awesome, they also serve a purpose. The bands can help protect glass tanks from breaking in case of a fall. They are also wonderful for when those darn threads just don't want to come loose. Pop a band on there and loosen it with ease. 5 PCS / Pack.
510 Thread Adapter Connector for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $3.99
The 510 Thread Adapter is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI / VINCI R / VINCI X Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The 510 Thread Adapter is made of POM (Outer Housing) and Stainless Steel (510 Threading Connector).
Старый 27.12.2019, 04:31 Автор темы   554
3FVAPE
Original Timesvape Dreamer V1.5 Hybrid Mechanical Mech Vape Mod original price$74.99, now only$59.99
The Timesvape Dreamer V1.5 Mechanical Mod is constructed from copper material. Dreamer V1.5 is powered by 1 x 18650 / 20700 / 21700 Batteries (Not included). The tube itself is 27mm at its widest point, tapering to 25mm at the top. The tube is reversible, so you can customize the grip to suit your preferences. The copper contact pin is also silver-plated for a perfect connection every time. Which compare with dreamer mod, there are some improvements: 1. Add the pressure relief hole; 2. Use the constant button; 3. The 18650 adapter make improvements; 4. Add an insulator inside top more safe; For dreamer mod if use constant button also can work well.
Original UKERI Magik 50W 1500mAh VW Box Mod Pod System Vape Starter Kit(Standard Version) $27.99
The UKERI Magik VW Box Mod Pod System Vape Starter Kit is powered by built-in 1500mAh battery with a wider power range from 8W to 50W to ensure powerful and durable vaping for all day long, you can easily find your favorite taste with more power choices. As a beautiful beast, MAGIK produces huge vapor production, and you can bring it to a cloud vapor competition. Magik Kit comes with a pod cartridge of 5.5ml e-juice capacity. What's more, Magik Kit comes with two types of mesh coils: V1 0.3ohm Mesh Coil and S1 0.3ohm Mesh Coil. And the UKERI Magik Cartridge is compatible with Voopoo VINCI / VINCI R / VINCI X Mod. At the same time, the UKERI V1 / S1 Mesh Coils can be used for SMOK RPM40 Cartridge and Voopoo VINCI / VINCI R / VINCI X Cartridge. Upgraded material and design, both mesh coils are perfect for better flavor experience and huge vapor production. Transparent design to make every drop of e-liquid visible and side filling port makes it super easy to refill.
Original VOOPOO PnP 22 AIO 50W 2000mAh Pen Vape Starter Kit(Standard Version) $30.99
The VOOPOO PnP 22 AIO Vape Kit is a brand new PEN KIT devices. PnP 22 AIO Kit has a perfect mixture of the compact and delicate pole equipment with the advantages of PnP series atomization core, strong and vigorous. Furthermore, the function of intelligent identification of atomization core and automatic matching of power makes them the most reliable equippment for the players who pursue fashion and the new players. The PnP 22 AIO Kit is equipped with PnP-VM1 0.3ohm atomization core and also matches PnP atomization core. Everyone can find their own taste with it. On the other hand, PnP 20 AIO Kit is powered by 2000mAh lithium battery, large battery capacity, long lasting endurance and it supports 5V / 1A quick charge, and can be fully charged within 2 hours. PnP 22 AIO Kit comes with top refilling system that makes refill conveniently and fastly. There are five safety protections that can ensure your vaping safety.
Original UKERI Magik Pod System Vape Kit Replacement Cartridge w/o Coil(Standard Version) $3.99
The UKERI Replacement Cartridge is designed for UKERI Magik Pod System Vape Kit as a replacement part, which comes with 5.5ml e-juice capacity. It is compatible with UKERI Replacement V1 Mesh Coil / S1 Mesh Coil (Coils are not included).
Original UKERI Magik Pod System Vape Kit / Cartridge Replacement S1 Mesh Coil Head(5 PCS) $10.99
The UKERI Replacement S1 Mesh Coil Head is designed for UKERI Magik Pod System Vape Kit or Cartridge as a replacement part, which features 0.3ohm coil resistance and power range from 20W to 50W.
Original UKERI Magik Pod System Vape Kit / Cartridge Replacement V1 Mesh Coil Head(5 PCS) $10.99
The UKERI Replacement V1 Mesh Coil Head is designed for UKERI Magik Pod System Vape Kit or Cartridge as a replacement part, which features 0.3ohm coil resistance and power range from 25W to 50W.
Original Vivismoke Gentle Organic Cotton Threads for RBA / RDA / RTA / RDTA Vape Atomizer(20 PCS) $1.99
The Vivismoke Gentle Organic Cotton Threads are made of Pharma Grade 100% tasteless cotton wick and are suitable for RBA / RTA / RDA / RDTA Vape Atomizer as a replacement part. The Cotton Threads are suitable for Coils in 2.5~3.0mm Diameter.
Replacement Top Cap Tank Tube + Drip Tip for SXK HOLY Patibulum RTA Clone/ Vapeasy Patibulum MTL RTA Clone $3.99
The Replacement Top Cap Tank Tube + Drip Tip are made of PC material and they are suitable for SXK HOLY Patibulum RTA Vape Atomizer Clone/ Vapeasy Patibulum MTL RTA Vape Atomizer Clone as replacement parts.
Старый 28.12.2019, 04:34 Автор темы   555
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original FreeMax GEMM DTL Disposable Sub Ohm Tank Vape Clearomizer(2 PCS) $6.99
The FreeMax GEMM DTL Disposable Sub Ohm Tank Vape Clearomizer comes with 0.5ohm DTL Mesh Coil that power range from 15W to 25W and 2ml e-juice capacity. 2 PCS / Pack.
Original FreeMax GEMM 25W 1300mAh MTL / DTL Box Mod Pod System Vape Starter Kit $20.99
The Freemax GEMM 25W Box Mod Pod System Vape Kit consists of Freemax GEMM 25W Box Mod and Freemax GEMM Replacement Tank, which is powered by 1300mAh built-in battery and the mod device provides clear picture of your battery life through four levels battery life indicator. The GEMM tank comes with 0.5ohm or 1.0ohm mesh coil, and 2ml e-juice capacity to satisfy your needs of DTL or MTL, freebase or nicotine salt e-juice vaping experience. Furthermore, GEMM 25W Box Kit features the latest FM CoilTech 3.1, and the pod is able to be refilled up to 20 times, much more than its kind with more stable flavor maintenance. It reveals every single taste from e-liquid of both nicotine salt and freebase with FM CoilTech 3.1. What's more, the military grade SS904L and exclusive Tea Fiber Cotton make it more stable and durable with impressive flavors as always. You will find it easy and smooth to adjust the airflow control to the line part. Just a light tap and then enjoy the amazing vaping experience!
Original Innokin Kroma R 80W DTL / MTL VW Mod Vape Starter Kit with Zlide Tank $45.99
The Innokin Kroma R Zlide Kit is a powerful and compact vape mod device that consists of an Innokin Kroma R VV VW Box Mod and an Innokin Zlide Tank. And it is also compatible with Innokin Ajax Tank (Not included). Compact, stylish and sleek, the Kroma-R is crafted with premium quality Zinc alloy material. Featuring an ergonomic design with a textured grip, the Kroma-R fits perfectly into your hand. Powered by single 18650 batteries (Not included), it has 80W high power, which can definitely satisfy the vapor chaser. Just push the lock to open the high-quality spring-loaded battery door and quickly replace the 18650 battery. The Kroma-R features 2A Micro-USB quick charge and integrated safety protections. In addition, the Kroma R Mod uses Innokin's proprietary chip with the most diverse features and all the most popular working modes. Enjoy great vaping with Wottoge (6~80W) and Voltage (1~7.5V) outputs and Soft, Normal and Boost Modes. On the full control panel, the Kroma-R top-quality fire button is satisfying to click and integrated into the bright OLED screen. All important information is clearly displayed on the screen including battery charge, wattage / voltage, coil resistance, puff count, voltage out and wattage lock. As for the Innokin Zlide Tank, it features 4ml / 2ml e-juice capacity and features a convenient retractable top-fill design that is secured by a dripper locking system. What' s more, the Kroma-R is great for big cloud DTL vaping with the Ajax tank or enjoy intense MTL flavors with the full line of Z-coils and Platform series tanks. Upgrade to a superior vape experience with the Innokin Kroma-R!
Original Reewape AS291 Replacement 810 Drip Tip for SMOK TFV8/TFV12 Tank/Kennedy/Battle RDA $1.99
The Reewape AS291 810 Replacement drip tip is made of Stainless Steel and Carbon Fiber, it is suitable for SMOK TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Vivismoke Gentle Fused Clapton MTL Kanthal A1 Heating Wire(3 Meters) $3.99
The Vivismoke Gentle Fused Clapton Heating Resistance MTL Wire is perfect for RBA / RTA / RDA atomizers. The wire is made of Kanthal A1. It features 32GA x 3 + 40GA gauge and 5.21ohm resistance value per feet, which will be a good choice for DIY.
Original Vivismoke Gentle Fused Clapton MTL 316SS Heating Wire(3 Meters) $3.99
The Vivismoke Gentle Fused Clapton Heating Resistance MTL Wire is perfect for RBA / RTA / RDA atomizers. The wire is made of 316 Stainless Steel. It features 30GA x 3 + 40GA gauge and 1.89ohm resistance value per feet, which will be a good choice for DIY.
Original Vivismoke Gentle Fused Clapton MTL Ni80 Heating Wire(3 Meters) $4.29
The Vivismoke Gentle Fused Clapton Heating Resistance MTL Wire is perfect for RBA / RTA / RDA atomizers. The wire is made of Ni80. It features 32GA x 3 + 40GA gauge and 4.03ohm resistance value per feet, which will be a good choice for DIY.
Старый 31.12.2019, 04:48 Автор темы   556
3FVAPE
Original AIRISTECH Nico 6.8W 450mAh Pod System Vaporizer Vape Starter Kit with 14 x 5.7mm Pod Adapter $14.99
The Airistech Nico Pod System, with the ultra-portable design, the Nico Kit is powered by built-in 450mAh battery and max output 6.8W, pressing the button to adjust the working voltage from 2.9V / 3.7V / 4.2V. The voltage selected is indicated by the color of the LED light around the power button. The Airistech Pod can hold 1.0ml e-juice and built-in 1.5ohm quartz coil, the patent Qcell Quartz coil technology will reduce the waste, improves flavor and prevents clogging, will bring you the purest flavor. The Pod with side e-juice refill design and silicone stopper, easy to inject your favorite e-juice without leaking. First time filling the pod, wait 3 minutes for the liquid to soak into the coil. the packing comes with the 14 x 5.7mm pod adapter, which allows the Airistech Nico compatible with various pods.
Original Kiriner Deimos 30W 950mAh MTL / DTL Pod System Vape Starter Kit $22.99
The Kiriner Deimos Pod System Vape Kit is constructed from stainless steel frame with luxurious panels and powered by 950mAh Built-in Battery with maxium output 30W. Deimos Kit has a 3 levels of power adjustment from low, medium to high. Deimos is compatible with both freebase nicotine liquid or nicotine salt. Also, it supports adjustable airflow for mouth-to-lung (MTL) and direct-lung vaping (DTL).
Dispensing Blunt Syringe Needle Tip for E-liquid Syringe E-juice Injector Refilling Tool $0.39
The Dispensing Blunt Syringe Needle Tip is made of Stainless Steel material in 25.4mm length and 14GA, which is suitable for E-liquid Syringe E-juice Injector Refilling Tool. The needles is blunt, which can avoid accidental injuries. The long needle can go deeper into a bottle and draw up e-juice easily. The short one is tailored for CE2 / CE3 cartomizers to refill e-juice. They are not compatible with e-juice bottles and the long needle can not be used to inject e-juice into CE2 / CE3 cartomizer.
Dispensing Blunt Syringe Needle Tip for E-liquid Syringe E-juice Injector Refilling Tool $0.69
The Dispensing Blunt Syringe Needle Tip is made of Stainless Steel material in 30mm length and 16GA, which is suitable for E-liquid Syringe E-juice Injector Refilling Tool. The needles is blunt, which can avoid accidental injuries. The long needle can go deeper into a bottle and draw up e-juice easily. The short one is tailored for CE2 / CE3 cartomizers to refill e-juice. They are not compatible with e-juice bottles and the long needle can not be used to inject e-juice into CE2 / CE3 cartomizer.
Dispensing Blunt Syringe Needle Tip for E-liquid Syringe E-juice Injector Refilling Tool $0.99
The Dispensing Blunt Syringe Needle Tip is made of Stainless Steel material in 55mm length and 18GA, which is suitable for E-liquid Syringe E-juice Injector Refilling Tool. The needles is blunt, which can avoid accidental injuries. The long needle can go deeper into a bottle and draw up e-juice easily. The short one is tailored for CE2 / CE3 cartomizers to refill e-juice. They are not compatible with e-juice bottles and the long needle can not be used to inject e-juice into CE2 / CE3 cartomizer.
Dispensing Blunt Syringe Needle Tip for E-liquid Syringe E-juice Injector Refilling Tool $0.29
The Dispensing Blunt Syringe Needle Tip is made of Stainless Steel material in 25.4mm length and 21GA, which is suitable for E-liquid Syringe E-juice Injector Refilling Tool. The needles is blunt, which can avoid accidental injuries. The long needle can go deeper into a bottle and draw up e-juice easily. The short one is tailored for CE2 / CE3 cartomizers to refill e-juice. They are not compatible with e-juice bottles and the long needle can not be used to inject e-juice into CE2 / CE3 cartomizer.
Replacement Wide Bore 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type A $1.99
The Replacement Wide Bore 510 Drip Tip is made of delrin and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Replacement Wide Bore 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type B $1.99
Replacement Wide Bore 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type C $1.99
Replacement Wide Bore 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer - Type D $1.99
Original Kiriner Deimos Pod System Vape Kit Replacement Cartridge with 1.2ohm Mesh Coil(2 PCS) $6.99
The Kiriner Deimos Replacement Cartridge is designed for Kiriner Deimos Pod System Vape Kit as a replacement part. It features 2.5ml e-juice capacity and comes with 1.2ohm mesh coil. 2 PCS / Pack.
Original Kiriner Deimos Pod System Vape Kit Replacement Cartridge with 0.6ohm Mesh Coil(2 PCS) $6.99
The Kiriner Deimos Replacement Cartridge is designed for Kiriner Deimos Pod System Vape Kit as a replacement part. It features 2.5ml e-juice capacity and comes with 0.6ohm mesh coil. 2 PCS / Pack.
3FVAPE вне форума   Вверх
Старый 02.01.2020, 05:10 Автор темы   557
3FVAPE
Original Innokin Kroma-R Zlide 80W VW Box Vape Mod $35.99
The Innokin Kroma R Zlide Mod is powered by single 18650 battery (Not included), Kroma R has 80W high power, which can definitely satisfy the vapor chaser. In addition, the Kroma R Mod uses Innokin's proprietary chip with the most diverse features and all the most popular working modes. Enjoy great vaping with Wattage (6~80W) and Voltage (1~7.5V) outputs and Soft, Normal and Boost Modes. All important information is clearly displayed on the bright OLED screen including battery charge, wattage / voltage, coil resistance, puff count, voltage out and wattage lock. The Kroma-R features 2A Micro-USB quick charge and integrated safety protections.
Original Steel Vape Phoenix Mechanical Squonk Box Mod + RDA Vape Kit original price$44.99, now only$14.99
The original Steel Vape Phoenix Squonker Kit consists of Steel Vape Phoenix Squonk Box Mod and Phoenix BF RDA. Mod: The original Steel Vape Phoenix Box Mod is a bottom feeder squonk mechanical box mod with 7.5ml food grade silicone squonk bottle. It is powered by one single 20700 battery or 18650 battery with fireproof PC adapter tube. The back cover panel can be attached to the mod with 5 magnets on each side. RDA: The Steel Vape Phoenix BF RDA is a 24mm dripper constructed from aluminum cap and stainless steel base. The deck features dual post design and top mounted screws for easy single coil building. The airflow is adjustable via the dual airholes at the bottom. Standard 810 PEI drip tip is included.
Original Steel Vape Phoenix Mechanical Bottom Feeder Squonk Box Vape Mod original price$39.99, now only$12.99
Original Steel Vape Sebone Hybrid Mechanical Mod + RDA Vape Kit original price$40.99, now only$14.99
The original Steel Vape Sebone mechanical mod kit consists of Sebone mech mod and Sebone RDA.
Original Steel Vape Sanctuary Mechanical Box Vape Mod original price$39.99, now only$14.99
The original Steel Vape Sanctuary Box Mod is an unregulated device with Mosfet chip to make it safe when vaping. It is powered by dual 18650 batteries (not included) in parallel. The mod supports resistance at between 0.1 and 3ohms. The 510 connetor is spring loaded and there is no overhang with even 26mm atomizer.
Original Steel Vape Aurora 80W VW Box Mod Vape Kit with Sub Ohm Tank Clearomizer original price$37.99, now only$14.99
The original Steel Vape Aurora VW Box Mod Vape Kit consists of Aurora VW Box Mod and a Sub Ohm Tank Clearomizer. Aurora Mod Kit is constructed from Stainless Steel and ABS material. It is powered by 1 x 18650 Battery (Not included) with output wattage range from 5W to 80W and it comes with a 3.0ml e-juice capacity tank for refilling.
Original MadaoTech Airforce One V2 RDA original price$14.99, now only$4.99
The MadaoTech Airforce One V2 RDA Rebuildable Dripping Atomizer is made of Stainless Steel. It comes with 2 posts design. This RDA features a 3.5ml capacity and 23mm diameter.
Original Steel Vape Compass RDA original price$18.99, now only$4.99
The Steel Vape Compass RDA is constructed from Stainless Steel and Alumunum in 25mm diameter. The RDA comes with two cap design: one stainless steel cap that show your big vaping clouds; another aluminum AFC cap that can make you enjoy your flavor taste. Roulette style for coil-building, total different from traditional coil-screwing huge space and manual roulette style for building coils.
Original Steel Vape ECG Bottom Feeder RDA with BF Pin original price$25.99, now only$4.99
The Steel Vape ECG Bottom Feeder RDA is constructed from Stainless Steel in 24mm diameter. The RDA comes with two clamp style posts in 45 degrees angle, easy build 1 or 2 coils. Circle PEI insulator around bottom, reduce power waste and cap temperature. Adjustable four cyclic admission airhole,smoother airflow control, atomizer working more comprehensive, meanwhile airflow cooling effect to bottom. 15 round holes inside the upper of the center cap, cluster effect function, filtration and reduction vape temperature, retention and condensation steam, making vape stronger and flavor better
Original Steel Vape EX RDA original price$22.99, now only$5.99
The Steel Vape EX RDA is with innovative one post unlimited build deck and 150 degree flip cap, magnetic function, fun of vapor. The RDA is adjustable airflow control from the bottom. The EX RDA supports three type of drip tips and comes with 510 drip tip adapter.
Старый 02.01.2020, 05:14 Автор темы   558
3FVAPE
Original Steel Vape Tailspin RDTA original price$22.99, now only$6.99
The Steel Vape Tailspin RDTA is a 25mm atomizer which can be used as either RDA or RTA. The deck features dual post design with two post holes at each post, side filling port for easy refilling, 6mm deep juice well, AFC drip tip cap to adjust side airflow. Resin and POM drip tip are included.
Original Innokin GO S 13W 1500mAh Vape Pen Starter Kit with MTL Tank Atomizer $26.99
The Innokin GO S Vape Pen Kit consists of GO S 1500mAh Mod Device and GO S MTL Tank Atomizer, which is a slim all-in-one pen-style vape kit, which made of stainless steel and PCTG plastic with lightweight dimensions, with a matte textured surface. Powered by 1500mAh inbuilt battery and maintain a constant 13W battery output, the Innokin GO S Kit provides you an all-day-long vaping experience. Charged with micro-USB, the GO S features a tri-color battery capacity indicator and integrated safety protections. One-button ignition activation, easy operation. As for Innokin GO S Tank, it is a tank used as MTL (mouth to lung) vape and can hold 2ml e-juice. It also features a 'slide to open' top-fill with a silicone seal. The tank operates for direct to lung vaping with the included specially designed 1.6ohm coil, with heads are made with organic cotton and wood-pulp wicking, it will create the intense flavors and bring you a healthy vape experience.
Original Lost Vape Prana 12W 500mAh Pod System Vape Starter Kit $26.99
The Lost Vape Prana Pod System, heralding a compact dimunitive shape, is powered by 500mAh rechargeable battery, and comes paired with a 1.0ml refillable pod with an integrated 1.0ohm coil. Constructed from quality zinc-alloy, the chassis is impervious to light falls and drops, mitigating damage to the proprietary chipset within. Housed inside is a 500mAh rechargeable battery, providing ample power to fire the 1.0ohm coil, vaporizing the contents to create delicious vapor from your favorite E-juice or nicotine salts. Holding up to 1.0ml within the refillable pod, the PRANA Pod System is the next vaping pod system that should be added to the collection, delivering a compact portable profile and exquisite vapor output that is perfect for those looking for discretion or love vaping on-the-go.
Kindbright Replacement 510 Drip Tip for RDA / RTA / RDTA / Sub-Ohm Tank Vape Atomizer $3.99
The Kindbright Replacement 510 Drip Tip is made of stainless steel and it is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Original Lost Vape Prana Pod System Vape Kit Replacement Empty Cartridge $5.99
The Lost Vape Prana Pod Cartridge is designed for Lost Vape Prana Pod System Vape Kit as a replacement, which features 1.0ml e-juice capacity.
Старый 03.01.2020, 04:50 Автор темы   559
3FVAPE
SXK Mission XV KRMA GEN Bridge RBA Atomizer Clone with 5 Airflow Reducers for SXK BB / Billet Box Mod Vape Kit original price$19.90, now only$17.99
The SXK Mission XV KRMA GEN Bridge Clone is compatible with Billet Box Mod Vape Kit, which is made of 316 Stainless Steel. It comes with 5 Airflow Reducers (Inner Hole Diameter: 1.0mm, 1.5mm, 2.0mm, 2.5mm, 3.0mm) and a PEEK insulators. The Bridge features a fully adjustable airflow system to suit open airflow to mouth to lung (MTL) vaping users.
Original ULTRONER Gather MTL / DTL RDA / RDTA Dripping Tank Vape Atomizer original price$45.00, now only$34.99
The ULTRONER Gather RDA / RDTA Rebuildable Dripping Tank Vape Atomizer is constructed from stainless steel and stabwood material in 37mm height (RDTA) / 30mm height (RDA) and 22mm diameter. The Atomizer is convertible between RDA and RDTA modes, it supports bottom feeding for Squonk mods. It comes with changeable airflow inserts with 3 different sizes that suitable for MTL and DTL vape. Also, the RDA / RDTA atomizer supports top filling and bottom fill options. Furthermore, it comes with a stabwood accent ring to add an original look, ultem drip tip and transparent tank section.
Original Justfog Q16 Pro 900mAh Mod Battery Vape Starter Kit with Sub Ohm Tank Clearomizer $25.99
The Justfog Q16 Pro Vape Starter Kit consists of Q16 Pro Clearomizer and Q16 Pro Battery, which is a pro version of JUSTFOG Q16 Kit, it is constructed from Anodized-AI and PC material, and comes with lightness and elegant body that is portable to be on the go. Powered by 900mAh built-in battery, the Justfog Q16 Pro provides an all-day-long vape to vapors. The easy top refilling system ensures an anti-leak vape. The Justfog Q16 Pro has a 4-level voltage adjustment range from 3.5V to 4.4V. As for the tank, the adjustable airflow system can perfectly meet your different vapor needs. The constant voltage output of Justfog Q16 Pro brings a stable performance to the users. Justfog Q16 Pro is equipped with multiple protections such as temperature control and short-circuit prevention, which will offer a comfortable and safe vaping experience.
Original VapeSoon Replacement RPM DC Coil Head for SMOK RPM40 Pod System Vape Kit(5 PCS) $6.79
The VapeSoon RPM DC Coil Head is designed for SMOKTech SMOK RPM40 Pod System Vape Kit as a replacement part, the DC Coil is made of brass material, it features 0.8ohm coil resistance and the best output power is 16W. 5 PCS / Pack.
Original VapeSoon Replacement RPM RBA Coil Head for SMOKTech SMOK RPM40 / Fetch Mini Pod System Vape Kit $5.09
The VapeSoon RPM RBA Coil Head is designed for SMOKTech SMOK RPM40 / Fetch Mini Pod System Vape Kit as a replacement part, the RBA Coil is made of brass material, it fits for DIY vaping lovers.
Original VapeSoon Replacement PnP-VM1 Coil Head for Voopoo VINCI / VINCI R / VINCI X Pod Kit(5 PCS) $7.09
The VapeSoon Replacement PnP-VM1 Coil Head is designed for VOOPOO VINCI Pod System Vape Kit as a replacement part, the PnP-VM1 Coil is made of brass material, it features 0.3ohm coil resistance and output power range from 32W to 40W. 5 PCS / Pack.
Original VapeSoon PnP-R1 MTL Regular Coil for DRAG Baby / FIND Trio / VINCI / VINCI R / VINCI X Kit(5 PCS) $7.09
The VapeSoon Replacement PnP-R1 MTL Regular Coil Head is designed for VOOPOO VINCI DRAG Baby / FIND Trio / VINCI / VINCI R / VINCI X Pod System Vape Kit as a replacement part, the PnP-R1 Coil is made of brass material, it features 0.8ohm coil resistance and output power range from 12W to 18W. 5 PCS / Pack.
Original VapeSoon Replacement PnP-M1 Coil Head for Voopoo VINCI / VINCI R / VINCI X Pod Vape Kit(5 PCS) $7.09
The VapeSoon Replacement PnP-M1 Coil Head is designed for VOOPOO VINCI / VINCI R / VINCI X Pod System Vape Kit as a replacement part, the PnP-M1 Coil is made of brass material, it features 0.45ohm coil resistance and output power range from 28W to 35W. 5 PCS / Pack.
Original VapeSoon PnP-C1 MTL Ceramic Coil for Voopoo Finic P18 Aio/Drag Baby Trio/Find S Trio Kit(5 PCS) $7.09
The VapeSoon Replacement PnP-C1 MTL Ceramic Coil Head is designed for VOOPOO Finic P18 Aio / Drag Baby Trio / Find S Trio Pod / VINCI / VINCI X / VINCI R System Vape Kit as a replacement part, the PnP-C1 Coil is made of brass material, it features 1.2ohm coil resistance and output power range from 10W to 15W. 5 PCS / Pack.
Original VapeSoon PnP-M2 Half-DL Mesh Coil for Voopoo DRAG Baby/FIND Trio/VINCI/VINCI R/VINCI X(5 PCS) $7.09
The VapeSoon Replacement PnP-M2 Half-DL Single Mesh Coil Head is designed for VOOPOO DRAG Baby/FIND Trio / VINCI / VINCI R / VINCI X Pod System Vape Kit as a replacement part, the PnP-M2 Half-DL Single Mesh Coil is made of brass material, it features 0.6ohm coil resistance and output power range from 20W to 28W. 5 PCS / Pack.
Original VapeSoon 510 Thread Adapter Connector for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $2.79
The VapeSoon 510 Thread Adapter Connector is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI / VINCI R / VINCI X Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The 510 Thread Adapter is made of POM (Outer Housing).
Original VapeSoon 510 Thread Adapter Connector for SMOKTech SMOK RPM40 Pod System Vape Kit $2.89
The VapeSoon 510 Thread Adapter Connector is designed for SMOKTech SMOK RPM40 Pod System Vape Kit, it can switch your SMOKTech SMOK RPM40 Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. The 510 Thread Adapter is made of POM (Outer Housing).
Старый 06.01.2020, 04:36 Автор темы   560
3FVAPE
Original Reewape 510 Thread Adapter Connector for Voopoo VINCI / VINCI R / VINCI X Pod System Kit(Magnetic Version) $3.99
The Reewape 510 Thread Adapter Connector is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it can switch your Voopoo VINCI Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you. This is Magnetic Version.
510 Thread Adapter Connector for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit $3.59
The 510 Thread Adapter Connector is designed for Voopoo VINCI / VINCI R / VINCI X Pod System Vape Kit, it is made of resin (outer housing) and brass (510 threading connector) and can switch your Voopoo VINCI Pod Mod to a normal Pod Mod which can be fitted to any 510 thread atomizer that provide more choice for you.
Original SMOKTech SMOK Fetch Pro 80W Pod Vape Kit Replacement Empty RPM Cartridge w/o Coils(3 PCS) $6.99
The SMOK Fetch Pro Pod Cartridge is specially designed for the SMOK Fetch Pro Pod System Vape Kit, which is born for the vapor and flavor. SMOK Fetch Pro Replacement Pods Cartridge offering a 4.3ml for use with SMOK RPM Coils (Coil not included). The Fetch Pro Pod cartridge feature a silicone stoppered side fill system, dual slotted bottom pod-based adjustable airflow control, and can be paired with a myriad of coils from the SMOK RPM Coil Series to help create flavored vapor in either an MTL or DTL output, depending on the type of coil installed. In addition, Fetch Pro RPM pod and is designed with adjustable airflow. Just like an atomizer, the adjustable airflow ring at the bottom can be rotated to adjust the air input. What's more, the Fetch Pro RPM Pod is compatible with all RPM40 coils to maximize coil compatibility and meet diverse vaping needs. The pods also perfectly match the Fetch Pro device via a magnet connection.
Original SMOKTech SMOK Fetch Pro 80W Pod Vape Kit Replacement Empty RGC Cartridge w/o Coils(3 PCS) $6.99
The SMOK Fetch Pro Pod Cartridge is specially designed for the SMOK Fetch Pro Pod System Vape Kit, which is born for the vapor and flavor. SMOK Fetch Pro Replacement Pods Cartridge offering a 4.0ml e-juice capacity for use with SMOK RGC Coils (coil not included). The Fetch Pro Pod cartridge feature a silicone stoppered side fill system, dual slotted bottom pod-based adjustable airflow control, and can be paired with a myriad of coils from the SMOK RGC Coil Series to help create flavored vapor in either an MTL or DTL output, depending on the type of coil installed. In addition, Fetch Pro RGC pod are both designed with adjustable airflow. Just like an atomizer, the adjustable airflow ring at the bottom can be rotated to adjust the air input. The pods also perfectly match the Fetch Pro device via a magnet connection.
Original Vapelustion Hannya Nano Pod System Vape Kit Replacement Cartridge with 1.2ohm Coil(2 PCS) $6.49
The Vapelustion Replacement Cartridge is designed for Vapelustion Hannya Nano Pod System Vape Kit as a replacement part, which features 2.0ml e-juice capacity and comes with 1.2ohm resistance coil. It can be refilled 5 to 6 times. 2 PCS / Pack.
Original Vapelustion Hannya Nano Pod System Vape Kit Replacement Panels(2 PCS) $8.25
The Vapelustion Hannya Nano Replacement Panel is designed for Vapelustion Hannya Nano Pod System Vape Kit as a replacement part. 2 PCS / Pack.
Original SMOKTech SMOK Fetch Pro 80W VW Mod Pod System Vape Starter Kit $34.99
The SMOK Fetch Pro Pod System Vape Kit is a versatile, light and delicate appearance Mod Pod kit. The overall body size is 20 percents smaller than similar products in the vape market, providing good portability and feel. SMOK Fetch Pro Mod Pod kit is powered by a single 18650 battery (Not included) to support long-time vaping. What's more, it employs USB Type-C that provides reliable power and fast transfer speed. The battery cap is push-pull for easier battery replacement. In addition, Fetch Pro is equipped with the newly developed core unit that enables the adjustable power from 5W to 80W. You can switch from intense cloud to light cloud according to your preference. There is a Large Firing Bar Button on the side of the fuselage. The large sidebar button offers a wider pressing area for better interaction. What's more, the SMOK Fetch Pro pod vape kit is equipped with a 0.96 inch TFT screen to show detail vaping data.
Время генерации страницы 0.60304 секунды с 15 запросами
