Просмотров в теме 260362   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 04.01.2019, 05:58 Автор темы   281
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vandy Vape AP Apollo 20W 900mAh VV Variable Voltage Box Mod $33.99
The Original Vandy Vape AP Mod, also called Vandy Vape Apollo Mod, is a waterproof mod with variable voltage function. The mod utilizes TPE material and features IP66 waterproof, which can provide extreme water, shock and dust protections. Powered by built-in 900mAh battery, the mod can work from 3.2 to 4.0 voltages. The AP Mod will give you extreme vaping experience. This item also has other colors to choose.
Original OBS Cheetah 3 III RDA Rebuildable Dripping Atomizer with BF Pin $24.99
The OBS Cheetah 3 RDA is an updated dual coils RDA atomizer with 25mm diameter and is constructed from durable stainless steel. OBS Cheetah 3 features a super big build deck with much space for easy dual coils building. The juice well is deep and thus can hold large amount of e-juice. With the adjustable middle airflow, Cheetah III RDA is definitely a vapor beast for cloud chaser.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Original Asvape Touch 12W 500mAh Pod System Starter Kit $59.99
The Original Asvape Touch Pod System Kit is an innovative kit with a 2.0inch touch-screen. It comes with a 1.5ml refillable pod, which is easy to fill the E-juice. The smarter chip in TOUCH will intelligently record vaping data from every status. There is three kinds of taste modes and four themes (including one customized theme). Three kinds of taste modes include Soft Mode, Standard Mode and Strong Mode. It has high level of safety with short-circuit protection, overheat protection, low voltage protection and hardware reset function. This item also has other colors to choose.
Original SXmini Mi Class 13W 400mAh YiHi SX290 Pod System Starter Kit $41.99
The Original SXmini Mi Class Pod System Kit is powered by YiHi SX290 chipset, bringing great performance for your vaping. It has a 1.8ml pod cartridge with 1.0ohm resistance ceramic coil. The mod is powered by built-in 400mAh battery. The working power range is from 7 to 13W. This item also has other colors to choose.
Original Lost Vape Orion Q 17W 950mAh Pod System Starter Kit $49.00
The Original Lost Vape Orion Q (Orion Quest) is made without the DNA Go board, which makes it much more affordable while retaining Lost Vape's precise craftsmanship and most of the same great features as the Lost Vape Orion DNA GO. With the removal of the DNA board and power adjustment button, the Lost Vape Orion Q offers a much simpler vape experience with its one button design. Featuring the same safety protections and a 950mAh rechargeable LiPo battery as the original, the Lost Vape Orion Q utilizes a 2ml refillable pods that lock into the battery. In addition, the Orion Q retains the multi-colored LED battery life indicator to check the current battery level with a quick glance.
This kit comes with a pod cartridge. This item also has other colors to choose.
Original Asvape Replacement Pod Cartridge for Touch Pod System Kit $9.99
The Asvape Touch Replacement Pod Cartridge features 1.6ohm resistance and 1.5ml of juice capacity. It is suitable for Original Asvape Touch Pod System Kit.
This product comes with 3 PCS in 1 pack.
Original SXmini Replacement Pod Cartridge for Mi Class Pod System Kit $4.99
The SXmini Mi Class Replacement Pod Cartridge features 1.0ohm resistance and 1.8ml of juice capacity. It is suitable for Original SXmini Mi Class Pod System Kit.
Original Lost Vape Replacement KTR Pod Cartridge for Orion Q Pod System Kit $10.99
The Lost Vape Orion Q Replacement KTR Pod Cartridge features 1.0ohm resistance and 2ml of juice capacity. It is suitable for Original Lost Vape Orion Q Pod System Kit.
This product comes with 2 PCS in 1 pack.
3FVAPE вне форума   Вверх
Старый 07.01.2019, 05:30 Автор темы   282
3FVAPE
Comp Lyfe Magnum Saw Mechanical Tube Mod Clone with Extra Tube $28.99
The Complyfe Magnum Saw Tube Mod Clone is a mechanical mod which is constructed from brass. It is powered by single 18650 / 20700 battery (NOT INCLUDED). The fire button is activated by magnets. The mod comes with extra tube for exchange. This item also has other colors to choose.
Original Eleaf Elven 15W 360mAh Pod System Starter Kit $14.79
The Elven is a new sleekly designed pod vape by Eleaf, having beautiful and durable metallic finishes. You'll get different air inflows from the Elven by inserting its cartridge into the battery in two ways. This pod features an easy side-fill solution and is leakage-free. The Elven is quite simple to use for its no-button feature that automatically initiates when you inhale. Offering great convenience and portability, Eleaf Elven pod is a great option for vapers on the go or simply looking for an easy to use vape. This item also has other colors to choose.
Original Wismec SINUOUS V80 80W TC VW Box Mod + Amor NSE Tank Kit $45.90
The Wismec SINUOUS V80 Kit consists of Wismec SINUOUS V80 Mod and Wismec Amor NSE Tank. This item also has other colors to choose.
Mod:
Being compact and portable, the SINUOUS V80 with semitransparent body is sleekly designed and crafted. Powered by single 18650 battery (NOT INCLUDED), it reaches a mighty 80W output along with a sequence of other unique features including centered 510 connector, 2A quick charge and 0.91inch OLED screen.
Tank:
The Wismec Amor NSE Tank, a practical atty designed for both MTL and DL vaping, will definitely offer you incomparable vaping experience with intense flavor and huge clouds.
Original Wismec SINUOUS V200 200W TC VW Box Mod + Amor NSE Tank Kit $45.90
The Wismec SINUOUS V200 Kit consists of Wismec SINUOUS V200 Mod and Wismec Amor NSE Tank. This item also has other colors to choose.
Mod:
SINUOUS V200 Mod is a new upgraded version of SINUOUS series. Differing from the conventional e-cigs, the SINUOUS V200 impresses people with its transparent body and centered 510 connector. Powered by dual 18650 batteries (NOT INCLUDED), SINUOUS V200 is able to output 200 watts and has a 2A quick charge capability.
Tank:
Kindbright Replacement AFC Airflow Insert for KA V7 RTA $5.99
The Kindbright Replacement AFC Airflow Inserts come with 0.8mm / 1.0mm / 1.2mm airhole and are suitable for By-Ka V7 RTA / YFTK KA V7 RTA Clone.
Kindbright Replacement AFC Airflow Insert for Billet Box DNA 60W Mod $4.99
The Kindbright Replacement AFC Airflow Inserts come with 0.8mm / 1.0mm / 1.2mm / 1.4mm airhole and are suitable for Billet Box DNA 60W / SXK Billet Box 60W Mod Clone / YFTK Billet Box 60W Mod Clone.
Original Vandy Vape Replacement Airflow Cap for Bonza Kit / Bonza V1.5 RDA $10.34
The Vandy Vape Bonza Replacement Airflow Cap is made from stainless steel and suitable for Vandy Vape Bonza Kit / Vandy Vape Bonza V1.5 RDA. This item also has other colors to choose.
Original Vandy Vape Replacement Extension Tube for Bonza Kit / Bonza Mod $14.94
The Vandy Vape Bonza Replacement Extension Tube is made from copper and suitable for Vandy Vape Bonza Kit / Vandy Vape Bonza Mod. This item also has other colors to choose.
Original Eleaf Replacement Pod Cartridge for Elven Pod System Kit $7.82
The Eleaf Elven Replacement Pod Cartridge features 1.6ohm resistance and 1.6ml of juice capacity. It is suitable for Original Eleaf Elven Pod System Kit.
This product comes with 4 PCS in 1 pack.
Старый 08.01.2019, 05:06 Автор темы   283
3FVAPE
Original Joyetech ATOPACK Magic 1300mAh Pod System Starter Kit $25.29
Joyetech adopted the innovative coil-less NCFilm heater into a pod system in a creative way, which is Joyetech ATOPACK Magic. The NCFilm heater supports long life-span with huge vapor production. Having 1300mAh battery capacity, the ATOPACK Magic, coupled with Joyetech ultra-efficient low voltage solution, making the battery lasts longer. The cartridge contains the e-liquid up to 2.0ml. Having various color options, you're also free to switch different indicator lights.
SteamTuners Top Fill Tank Kit Clone for Dvarw 22mm RTA Clone $5.99
The SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PC tank tube. It is suitable for Dvarw 22mm MTL / DL RTA Clone.
Original Asmodus Hybrid BubbaComb 810 Drip Tip for Goon / Kennedy / Reload RDA $5.66
The Asmodus Hybrid BubbaComb 810 Drip Tip is made from resin and stainless steel. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
This drip tip will be shipped with random color (one piece). More option than what's on the image. This item also has other color to choose.
Original Asmodus Bubba Comb 810 Drip Tip for Goon / Kennedy / Reload RDA $5.66
The Asmodus Bubba Comb 810 Drip Tip is made from resin. It is suitable for Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
This drip tip will be shipped with random color (one piece). More option than what's on the image. This item also has other Version to choose.
YFTK Replacement Tank Tube for Dvarw 16 RTA Clone $3.64
The replacement tank tube is made from PEI and is suitable for YFTK Dvarw 16 RTA Clone. It has 2ml of juice capacity.
YFTK Replacement Full Tank Tube Kit for Dvarw 16 RTA Clone $6.38
The replacement full tank tube kit is made from PC and is suitable for YFTK Dvarw 16 RTA Clone. It has 2ml of juice capacity. This item also has other color to choose.
Leather Textured Protective Silicone Sleeve Case for JUUL Pods $2.06
This Protective Silicone Sleeve Case is made from food grade silicone and comes with leather texture. It is suitable for JUUL Pods. This item also has other colors to choose.
Original Joyetech Replacement Pod Cartridge for Atopack Magic Pod System Kit $3.27
The Joyetech Atopack Magic Replacement Pod Cartridge features 0.6ohm resistance and 2ml of juice capacity. It adopted the innovative coil-less NCFilm heater, which supports 3 months long life-span than normal coils. It is suitable for original Joyetech Atopack Magic Pod System Kit. This item also has other Version to choose.
Старый 09.01.2019, 04:56 Автор темы   284
3FVAPE
Original Wismec SINUOUS V80 80W TC VW Variable Wattage Box Mod $31.44
Being compact and portable, the SINUOUS V80 with semitransparent body is sleekly designed and crafted. Powered by single 18650 battery (NOT INCLUDED), it reaches a mighty 80W output along with a sequence of other unique features including centered 510 connector, 2A quick charge and 0.91inch OLED screen. This item also has other colors to choose.
Original Wismec SINUOUS V200 200W TC VW Variable Wattage Box Mod $31.77
SINUOUS V200 Mod is a new upgraded version of SINUOUS series. Differing from the conventional e-cigs, the SINUOUS V200 impresses people with its transparent body and centered 510 connector. Powered by dual 18650 batteries (NOT INCLUDED), SINUOUS V200 is able to output 200 watts and has a 2A quick charge capability. This item also has other colors to choose.
Original Capitvape Black Bat RDA Rebuildable Dripping Atomizer with BF Pin Original Price $25.90, Now Only $19.99
The Original Capitvape Black Bat RDA is a 25mm rebuildable dripping atomizer with simple deck design for dual coil builds. Special top design allows you to adjust the airflow with ease, and the bottom airflow will bring you very good flavor and massive clouds.
Kayfun Prime Plus RTA Rebuildable Tank Atomizer Clone $18.99
The Kayfun Prime Plus RTA Clone is made from 316 stainless steel with a diameter of 22mm and 2ml of juice capacity. It features small chamber and narrow air channel for denser flavorful vapor. The deck is designed for only single coil. The 510 PEI drip tip can protect your mouth form heat.
This RTA comes with a glass tank and a PEI tank. This item also has other colors to choose.
Original Freemax Twister 80W 2300mAh VW Mod + Fireluke 2 Tank Kit Original Price $60.00, Now Only $41.49
The Freemax Twister 80W VW Kit consists of Freemax Twister 80W Mod and Freemax Fireluke 2 Mesh Tank. This item also has other colors to choose.
Mod:
The Freemax Twister Mod features pen-style appearance. Powered by the built-in 2300mAh battery, the Twister can reach max output to 80W. With the twist-style mechanism, the output wattage can be varied from 5W to 80W by a simple twist of the base. An advanced chip provides quick firing speed and multiple protections. Plus, the LED light embedded inside the firing button indicates various working conditions.
Tank:
The Freemax Fireluke 2 Tank is a 24mm sub ohm tank, which can be refilled easily with its patented slide-to-open top filling design. The tank is compatible with the X1, X2 and X3 Mesh Coil. With 360-degree juice feeding, the Fireluke 2 will provide great flavor and huge clouds.
Original ThinkVape Asteroid 420mAh Pod System Starter Kit Original Price $29.00, Now Only $10.99
The Original Think Vape Asteroid Kit is an ultra-portable pod kit powered by 420mAh built-in battery and comes with 1.5ml pod cartridge. The battery works with constant voltage output and has 3-level remaining battery indicator. The coil inside the pod comes with 1.6ohm resistance and will bring you pure flavor. This item also has other colors to choose.
Protective Leather Sleeve Case for Pod System Starter Kit $2.59
This Protective Sleeve Case is made from leather and is suitable for slim sized pod system kits, like Suorin iShare, SMOKTech SMOK SLM, Tesla GG, etc.
Original ThinkVape Replacement Pod Cartridge for Asteroid Pod System Kit $5.90
The Think Vape Asteroid Replacement Pod Cartridge features 1.6ohm resistance and 1.5ml of juice capacity. It is suitable for Original ThinkVape Asteroid Pod System Kit.
Старый 10.01.2019, 04:39 Автор темы   285
3FVAPE
Mod:
Tank:
[Исправлено: 3FVAPE, 10.01.2019 в 05:06]
Старый 11.01.2019, 04:35 Автор темы   286
3FVAPE
Original VapeCige VTX 100W TC VW Variable Wattage Box Mod $23.96
The Original VapeCige VTX 100W Mod is made from ABS material with rubber paint for soft and comfortable hand feel. Powered by single 18650 / 26650 battery (NOT INCLUDED), Vapecige VTX100 Mod can reach its max output to 100W, and supports VW, Ni, Ti, SS, Bypass modes. It has a 0.91-inch OLED screen to display vape data. With spring-loaded 510 connection, it can be compatible with most atomizers in the market. This item also has other colors to choose.
Get Low Mods GLM V3 RDA Rebuildable Dripping Atomizer Clone $8.55
The GLM V3 Style RDA is a nice rebuildable dripping atomizer made from stainless steel. It features dual post build deck and adjustable side airflow. It will bring you great amount of cloud and dense flavor. This item also has other color to choose.
YFTK Speed RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The YFTK Speed Style RDA is a 14mm rebuildable dripping atomizer constructed from 316 stainless steel. It has a dual post build deck for single coil build. The RDA comes with two Delrin drip tips and one decorative ring.
The diaplay stand is not included.
Original VOOPOO Rota Spinning 10W 340mAh Pod System Starter Kit $21.99
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.
The original VOOPOO Rota Kit is the first spinning vape pod kit which with ergonomic and aesthetic design. With Rota Kit, you can spend your whole day vaping and spinning at the same time. Made of Zinc Alloy and Plastic, it's so tiny but powerful. Powered by 340mAh built-in battery and Max. 7W output, comes with replacement refillable 1.5ml e-juice pod cartridge for nicotine salt and other juices. Allow more air to produce larger vapor and better flavor, and multiple safe protections avoid all potential risks. This item also has other colors to choose.
Original Smoant Battlestar 200W Squonker Kit VV / VW / DVW Box Mod + RDA Kit $59.90
The Smoant Battlestar Kit is simplicity and tiny Battlestar Squonker box mod Battlestar RDA. The Battlestar 200W Mod is powered by dual 18650 batteries (not included), it can fire up to 200W max output, encompassing a conveniently located 7mL food grade squonk bottle section made in conjunction with ergonomic designs. Battlestar mod adopts self-developed trigger button, this function controls liquid flow to prevent over squonking into the RDA. Battlestar Squnoker Mod features 0.96 inch OLED display, clear and bright user interface makes you easy to use it. As for the Battlestar RDA, measuring 24 in diameter, unique floating build deck design, and side angled airflow control. This is a high-performance squonk kit designs for today's vaping needs. This item also has other colors to choose.
Original VOOPOO Rota Spinning Pod System Kit Replacement Pod Cartridge $8.99
The VOOPOO Rota Spinning Pod Cartridge is specially designed for the VOOPOO Rota Spinning 400mAh Pod Starter Kit. It comes with 1.5ml e-juice capacity and 1.5 ohm Coil, featuring the easy bottom refilling system. So the VOOPOO Rota Cartridge will bring the optimal flavor to vapers. Get it as a spare part for your VOOPOO Rota Pod Starter Kit.
Original Smoant Battlestar 200W Squonker Kit Replacement Bottom Feeder BF Bottle $3.59
The 7ml food grade silicone bottom feeder bottle is suitable for Smoant Battlestar 200W Squonker Kit
Старый 12.01.2019, 04:37 Автор темы   287
3FVAPE
Original MyVapors Myuz Astora Kit 10W 500mAh Pod System Starter Kit $19.99
The Original MyVapors Myuz Astora Kit is an ultra-compact and portable vaping kit designed for vapers on the go. It is powered by 500mah built-in battery with a max output of 10W. The combination of a convenient filling solution, a leak-free design, adjustable output voltage, and simplicity makes Myuz Astora the best on-the-go device for MTL vaping experience. Optimized for entry-level users and individuals looking for a high nicotine vape system, Myuz Astora is a phenomenal option for the portable vape pods segment. This item also has other colors to choose.
Original MyVapors Myuz Astora Pod System Kit Replacement Pod Cartridge $2.99
The MyVapors Myuz Astora Pod Cartridge is suitable for the MyVapors Myuz Astora Kit. It comes with 3ml e-juice capacity, features the side-fill design, making you free of any leakage. Moreover, it's optimized for nicotine salts and MTL vaping.
Старый 14.01.2019, 04:54 Автор темы   288
3FVAPE
Original Blitz Vigor 81W TC VW Variable Wattage Squonk Box Mod Original Price $49.90, Now Only $39.99
The Original Blitz Vigor Mod is a nice compact squonk mod with 10ml juice bottle. Powered by single 18650 / 20700 battery (NOT INCLUDED), Blitz Vigor can reach its maximum output of 81W. The Blitz Vigor MOD comes with a 0.91 inch OLED display that indicates necessary vaping status. You can enjoy a long vaping time with 10ml large capacity. This item also has other colors to choose.
Original Horizon Falcon King Sub Ohm Tank Clearomizer $30.97
The Original Horizon Falcon King Sub Ohm Tank is constructed of durable Pyrex Glass and high quality Stainless Steel material. Resin drip tip makes the tank more elegant and special. The tank utilizes a bulb glass tube to hold 6ml e-juice, enough to meet your vaping demands. The Falcon King tank is compatible with new coils of M-Dual 0.38ohm mech coil and M1+ 0.16ohm mesh coil. Both of them are made of bamboo fiber, which produce better flavor and has longer lifespan. All of Falcon coils are compatible with Falcon King tank. Moreover, it features new filling design. You just need to click the button to open top cap and refill e-liquid easily. This item also has other colors to choose.
SteamTuners Top Refill Dvarw V2 MTL RTA Rebuildable Tank Atomizer Clone $10.78
The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience. The RTA comes with 2ml SteamTuners Style Top Refill Tank. This item also has other colors to choose.
Original Horizon Replacement M2 Coil Head for Falcon Sub Tank Clearomizer $8.99
The Original Horizon Falcon M2 Coil features 0.16ohm resistance and works well at 70~80W. It is suitable for Original Horizon Falcon sub tank clearomizer.
This product comes with 3 PCS in 1 pack. This item also has other Version to choose.
Original Horizon Replacement M1+ Coil Head for Falcon King Sub Tank Clearomizer $9.99
The Original Horizon Falcon King M1+ Coil features 0.16ohm resistance and works well at 75W. It is suitable for Original Horizon Falcon King sub tank clearomizer.
Старый 15.01.2019, 04:38 Автор темы   289
3FVAPE
Original Smoant Battlestar Squonker RDA Rebuildable Dripping Atomizer with BF Pin Original Price $18.99, Now Only $13.72
The Original Battlestar Squonker RDA, measuring 24 in diameter, features unique floating build deck design, and side angled airflow control. This is a high-performance squonk RDA designs for today's vaping needs. This item also has other colors to choose.
The SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PC tank tube. It is suitable for Dvarw 22mm MTL / DL RTA Clone. This item also has other colors to choose.
Старый 16.01.2019, 04:58 Автор темы   290
3FVAPE
Original Blitz M1911 200W TC VW Variable Wattage Box Mod Original Price $55.99, Now Only $39.99
Inspired by M1911 Pistol, the Blitz M1911 Mod features stunning appearance and excellent grip feeling. Powered by built-in powerful 200W chip and dual 18650 batteries (NOT INCLUDED), the mod can reach its maximum output to 200W. It also comes with other modes like Bypass, Curve and TC modes. This item also has other colors to choose.
Original Blitz Versus Sub Ohm Tank Clearomizer Original Price $33.99, Now Only $22.99
The Blitz Versus Subohm Tank adopts new mesh coil with the wide contact surface, providing saturated flavor and longer lifespan. Bottom dual adjustable airflow brings great flavor, the easy top refilling design with 5.5ml liquid capacity also brings you a better experience. This item also has other colors to choose.
Please note: the language of package and user manual is Chinese.
Original SXmini Replacement Pod Cartridge for Mi Class Pod System Kit $9.89
Please note: This product comes with 2 PCS in 1 pack.
Старый 17.01.2019, 05:03 Автор темы   291
3FVAPE
Original Yosta Livepor 100W TC VW Variable Wattage Box Mod $30.98
The Original Yosta Livepor 100W Mod is a versatile regulated box mod with compact size and ergonomic design. Powered by single 18650 / 20700 / 21700 battery (NOT INCLUDED), the mod can reach its maximum output to 100W. The mod supports various modes like POWER, Ti, Ni200, SS316, BYPASS. It comes with a 0.96-inch colorful display screen to show necessary vaping data. This item also has other colors to choose.
ShenRay Armor BF Squonk Mechanical Box Mod Clone Original Price $119.00, Now Only $114.99
The ShenRay Armor BF Squonk Mod Clone is constructed from high-end stabilized wood body, black stainless steel top / bottom and brass battery tube. This mod is powered by single 18650 battery (NOT INCLUDED). The bottle has 8ml of juice capacity. This mod is without LOGO.
This product will be shipped with random color due to its material. More options than what's on the image.
Original Blitz M1911 200W TC VW Variable Wattage Box Mod + Versus Tank Kit Original Price $69.99, Now Only $51.99
The Original Blitz M1911 Kit consists of Blitz M1911 Mod and Blitz Versus Subohm Tank. This item also has other colors to choose.
Mod:
Tank:
Original Tesla Teslacigs WYE 430mAh Pod System Starter Kit $19.90
The Original Teslacigs WYE kit is a tiny and compact vape pod system kit, which can contain 2ml e-liquid. The 1.2ohm ceramic coil can provide you pure and clean flavor. It has super light weight and tiny size for easy carrying. Powered by a built-in 430mah battery, it only needs 1.1 hours to be fully charged. This item also has other colors to choose.
Original Tesla Teslacigs Replacement Pod Cartridge for WYE Pod System Kit $8.99
The Teslacigs WYE Replacement Pod Cartridge features 1.2ohm resistance and 2ml of juice capacity. It is suitable for Original Teslacigs WYE Pod System Kit.
Please note: This product comes with 3 PCS in 1 pack. This item also has other colors to choose.
Старый 18.01.2019, 04:34 Автор темы   292
3FVAPE
Original Voopoo Drag Mini 117W 4400mAh TC VW Variable Wattage Box Mod $50.29
The Original Voopoo Drag Mini 117W TC VW box mod, powered by built-in 4400mAh battery, it can fire up to 117W max output. As a new generation of drag, the DRAG mini features mini size and compact design, utilizes colorful resin panels to make your vaping life colorful. It also adopts GENE.FIT chip to ensures excellent taste and enjoyable vaping experience. The innovative FIT mode intelligent match and protect tanks. The mod equips with a crystal OLED display to show parameters of device such as mode, resistance, voltage and wattage. This item also has other colors to choose.
Original Voopoo Drag 2 177W TC VW Variable Wattage Box Mod $49.74
The Original Voopoo Drag 2 177W TC VW box mod is powered by dual 18650 batteries (NOT INCLUDED), it can fire up to a powerful output of 177W. As a new generation of drag, the Drag 2 is more lighter and functional. The Drag 2 mod adopts GENE.FIT chip, which is secured by a V0 class fireproofing bridge to block dust, liquid or burnout. It comes with innovative FIT mode to intelligently match and protect tanks from burnout. This item also has other colors to choose.
Original Aspire Tigon 2600mAh Starter Kit Original Price $42.99, Now Only $41.24
The Tigon kit, an easy to use 'child safe' compact device from ASPIRE. It can be used as an MTL (mouth to lung) or a restricted DTL (direct to lung) vape. It comes with a long-lasting 2600mAh built-in battery and works in By-Pass mode. It is the first Aspire product to use an ingenious design that will seal the wicking holes in the tank when the coil is removed. The Tigon kit comes supplied with a choice of MTL, longer style, drip tip and a slightly wider bore stubby style drip tip more suited to restricted DTL hits. This item also has other colors to choose.
Original Aspire Replacement DTL Coil Head for Tigon Kit / Tigon Tank Original Price $14.99, Now Only $10.99
The Original Aspire Tigon Replacement Coil features 0.4ohm resistance and works well at 23~28W. It is suitable for Original Aspire Tigon Kit / Tigon Tank.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Старый 21.01.2019, 04:53 Автор темы   293
3FVAPE
Original OBS Cube 80W 3000mAh VW Variable Wattage Box Mod Original Price $45.00, Now Only $36.99
The Original OBS Cube Mod is constructed from zinc alloy, it is powered by a built-in 3000mAh 23600 A+ high rate battery, with the fire speed of 10 milliseconds, it is very safe and durable. It features 0.96-inch LED screen, high-tech appearance, ergonomic design, comfort grip and exquisite buttons. The 1.5A charge current makes it safe and efficient to charge within 2~3 hours. The new version comes with resin control panel. This item also has other colors to choose.
Original OBS Cube 80W 3000mAh VW Variable Wattage Starter Kit Original Price $60.50, Now Only $47.99
The Original OBS Cube Starter Kit consists of OBS Cube Mod and OBS Cube Tank. This item also has other colors to choose.
Mod:
Tank:
The Original OBS Cube Tank is made from stainless steel, it has 25.5mm diameter with a juice capacity of 4ml. with the pre-installed 0.2ohm M1 mash coil, it has a output wattage of 50~80W (BEST 65~75W), which can bring you smooth flavor and huge clouds.
Старый 23.01.2019, 05:27 Автор темы   294
3FVAPE
Original Hotcig G217 217W TC VW Variable Wattage Box Mod $25.99
The Hotcig G217 MOD was designed with unique patterns, which looks much more beautiful and attractive. Powered by dual 18650 batteries (NOT INCLUDED), G217 Mod delivers a maximum output of 217W with 0.8ms quick firing speed. The 0.96inch OLED display is arranged centrally, featuring a neatly organized sections with essential readouts at a quick glance. This item also has other colors to choose.
Original Asmodus .Blank RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.95, Now Only $28.99
Constructed of premium stainless steel, the .Blank RDA utilizes a build deck design similar to the Bunker and C4 RDAs, with large, wall-like posts located on each side of the atomizer acting as chamber reducers, condensing the vapor produced in the chamber for peak flavor and vapor production. The leads of the coil can be tightened in place with the use of two hex grub screws, and the outer curved edges of the posts allow for the leads to be trimmed to the perfect length after the grub screws are tightened, making installation a breeze. The bottom of the large juice well takes a concave form, allowing for any juice fed into the RDA to be funneled towards the wick. The asMODus .Blank RDA is sure to deliver great flavor and vapor with minimal leaking.
Original G-Taste COOMO 350mAh Pod System Starter Kit Original Price $19.90, Now Only $14.99
The Original G-TASTE COOMO is an ultra-mini round shaped pod kit with 350mAh built-in battery and 2.0ml cartridge capacity. With air driven design, the COOMO can be used by a simple drag. It can be charged via USB port with 5V / 0.5A input.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from Stainless Steel. It is suitable for all atomizers that fit 510 drip tip, such as OBS Engine 2 RTA, GeekVape Ammit MTL RTA, Phevanda Bell MTL RDA, Gas Mods G.R.1 GR1 Pro RDA, Vapefly Galaxies MTL Squonk RDTA, Vandy Vape Berserker MTL RDA, Ubertoot MTL RTA.
Старый 24.01.2019, 04:28 Автор темы   295
3FVAPE
Original Digiflavor Helix Box Mod + GeekVape Cerberus Tank Kit Original Price $39.99, Now Only $32.49
The Digiflavor Helix Kit consists of Digiflavor Helix Mod and GeekVape Cerberus Tank. This item also has other colors to choose.
Mod:
The Digiflavor Helix Mod is a stylish single 18650 mod inspired by the form of double-helix. Built with high grade ultra-lightweight ABS material which increases impact and heat resistance. Three power output modes are available to match your personal preference. Three output modes available. The mod is powered by single 18650 battery (NOT INCLUDED).USB Pass-through allows you to simultaneously use the device while charging. The advanced AS chipset fires extremely fast and stable.
Tank:
The Original GeekVape Cerberus sub ohm tank is optimized by the ultimate Super Mesh coil that maximizes heating contact surface area in order to provide maximum flavor and large vapor production. Super Mesh Coils are compatible with Aero Mesh tank too. The tank comes with 27mm diameter and 5.5ml large juice capacity.
Please note: this product will not be shipped to Korea.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
The replacement 810 drip tip is made from Ceramic and Stainless Steel. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA. This item also has other color to choose.
SteamTuners Top Fill Tank Kit Clone for Dvarw 2 22mm RTA Clone $5.89
The SteamTuners Top Fill Tank Kit Clone is constructed from 316SS top lid / chimney and PC tank tube. It is suitable for Dvarw 2 22mm MTL / DL RTA Clone. This item also has other color to choose.
Original Union Mini Bag Portable Carrying Storage Vape Bag for Pod System Kit $5.99
The Original Union Mini Bag is small sized carrying bag for pod system kits. Made of leather, it feels smooth and is very easy to carry. It can carry one POD system kit and four POD cartridges.
Старый 25.01.2019, 05:22 Автор темы   296
3FVAPE
Hello everyone.
Thank you for your support, because in the Spring Festival near China, in order to avoid everyone's waiting, and in order to receive products faster, we have set all the related products into a 24-hour area, we will dispatches in one business day. If you like other products, you can also order, but the delivery time will be after the Spring Festival, please understand. For more information, please check our website or contact our customer service team directly. Our website will also have a Spring Festival discount, please look forward to it.
Our website: 3FVape.com
Open a ticket to get help>>>
Click here for more 24 hour zone products>>>
Старый 26.01.2019, 05:37 Автор темы   297
3FVAPE
Strong Recommend in 3FVape:
SteamTuners Top Refill Dvarw V2 MTL RTA Clone $10.38 In Stock
YFTK Dvarw MTL RTA Clone $17.99 In Stock
ShenRay Armor BF Squonk Mod Clone $59.00 In Stock
OFRF Gear RTA Original Price $39.99, Now Only $26.19
Kennedy Vindicator Mech Kit Clone Original Price $22.99, Now Only $22.79
Buy Now! Get Order Shipped Before Chinese New Year!
Click here and get side-wide extra 3% off >>>
Старый 28.01.2019, 05:26 Автор темы   298
3FVAPE
In order to allow customers in Europe to receive products faster, we have established a European warehouse.
Click here to get more>>>
Please Note:
These products are in Europe warehouse (Germany) for Germany and Europe customers ONLY.
These products will be fulfilled by DHL and will be shipped in 1~2 business days after payment accepted. Normally the parcels will be delivered in 3~5 business days after shipment.
The dispatchment of Europe warehouse will not be affected by the CNY holiday. The products in Europe warehouse will be delivered quickly and with low shipping fee.
Please place order with those products in separated order, and DO NOT mix with other products from China warehouse.
If you feel that there are limited types of products you can choose, you can also choose the products in our 24-hour zone. We will arrange the delivery within one working day. Now we can use the Spring Festival discount.
For more information, please visit our website. Click here to get more>>>
Старый 12.02.2019, 05:23 Автор темы   299
3FVAPE
Fantasy RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.34
The Fantasy RDA Clone is made from POM (top cap & drip tip & beauty ring) and 316 stainless steel. It is a 22.5mm RDA with dual posts build deck for single coil. The size air holes allow airflow to hit the coil directly. 24mm decorative ring is included.
The RDA comes with bottom feeder pin. This item also has other colors to choose.
SXK Doggystyle 2K18 V2 RTA Rebuildable Tank Atomizer Clone Original Price $15.90,Now Only $12.05
The SXK Doggystyle 2K18 RTA Clone is a 22mm rebuildable tank atomizer constructed from 316 stainless steel with PC tank tube and 316SS drip tip. The tank has 3.5ml of juice capacity. It comes with single coil build deck, adjustable bottom airflow and 510 threading connection. The side airhole size is the same as SXK Doggystyle 2K16 Style RTA, and the internal airhole size is 2.0mm, it is more like restricted DL than MTL vaping.
Gem Mini RTA Rebuildable Tank Atomizer Clone $14.99
The Gem Mini RTA Clone is made from stainless steel and glass. It features 2ml capacity, dual post build deck for single coil build and bottom airflow for great flavor.
Original SMOKTech SMOK Mico 26W 700mAh Pod System Starter Kit $23.99
In the palm of your hand, MICO is coming for you. It adopts a classic resin design on the device where the unique multicolored fluid lines look like abstract oil paintings, possessing a stylish and elegant high-gloss finish. Powered by a built-in 700mAh lithium battery, MICO is sufficient for you to enjoy vaping all day along. There are two pods included in this kit, one pod with 0.8ohm mesh coil and one pod with 1.0ohm regular coil which can offer superb MTL vaping experience; both of them have 1.7ml capacity, and you can drip your favorite e-liquid into them. Besides, one lanyard is attached in the kit for both decorative purpose and portability. This item also has other color to choose.
Original Serisvape O-Pod 380mAh Pod System Starter Kit with Lanyard Original Price $22.00,Now Only $18.77
The first type circular shape pod system of Serisvape, the O-Pod. You will like its cute appearance and mini size, as well as the feeling when you handle it. It's rechargeable and refillable, you can use it repetitively for your daily vape time. It's designed portable, you can take it with yourself every day and everywhere. The cartridge is replaceable, you can change it when the coil inside could not offer best flavor. The slidable button can keep the suction nozzle clean when it's unoccupied. Besides, you can hang it on your neck with the lanyard. The O-Pod comes with 380mAh built-in battery and 2ml pod cartridge. This item also has other color to choose.
The replacement 810 drip tip is made from POM. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon 25mm RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Vandy Vape Pulse V2 RDA, Vandy Vape Pulse X RDA, Vandy Vape Kylin V2 RTA, Hellvape Drop Dead RDA, Wotofo Profile RDA, Wotofo Serpent Elevate RTA, Digiflavor Drop Solo RDA, Geekvape Loop V1.5 RDA, THC Tauren Honeycomb RTA.
Original SMOKTech SMOK Replacement Pod Cartridge for Mico Pod System Kit $7.99
The SMOKTech SMOK Mico Replacement Pod Cartridge can hold 1.7ml of juice capacity and comes with 0.8ohm mesh coil. It is suitable for SMOKTech SMOK Mico Stater Kit.
This product comes with 3PCS in 1 pack. This item also has other Version to choose.
Original Serisvape Replacement Pod Cartridge for O-Pod Pod System Kit $2.99
The Serisvape O-Pod Replacement Pod Cartridge can hold 2ml of juice capacity. It is suitable for Serisvape O-Pod Stater Kit.
Старый 14.02.2019, 04:46 Автор темы   300
3FVAPE
Original SMOKTech SMOK Nord 15W 1100mAh Pod System Starter Kit $27.99
The Original SMOKTech SMOK Nord, is a button-triggered pod system device. It is powered by a built-in 1100mAh battery, which making it a definitely powerful one among pod system devices. It is equipped with two exclusive coils (Nord Mesh 0.6ohm coil and Nord regular 1.4ohm coil), one is perfect to get massive vapor while the other can offer excellent MTL experience. Its size is very comfortable to hold in hand, and it has a newly added button to start vaping and provide information about battery life, besides, there's an e-liquid window on the pod, all of which are for your convenience. This item also has other color to choose.
Original Vandy Vape Pulse Dual 220W TC VW Squonk Box Mod + Pulse V2 RDA Kit Original Price $87.99, Now Only $68.39
The Original Vandy Vape Pulse Dual 220W Kit consists of the authentic Vandy Vape Pulse Dual 220W TC VW Squonk box mod and the Vandy Vape Pulse V2 RDA. This item also has other color to choose.
Mod:
The Original Vandy Vape Pulse Dual 220W TC VW Squonk box mod is the smallest dual battery squonk mod. Powered by an upgraded Vandy Chip, it can reach up to an output wattage from 5W to 220W. It also supports multiple protections and comes with a 7ml juice bottle.
RDA:
The Original Vandy Vape Pulse V2 RDA is a 24mm rebuildable atomizer. It comes with 3 different airflow rings, which support both single and dual coil build, two of them with honeycomb airflow, and one wide open, directing airflow directly to your coils.
Original Advken CP Squonking Mechanical Box Mod + RDA Kit Original Price $69.99, Now Only $26.22
The Original Advken CP Squonking Kit consists of CP Bottom Feeder Mechanical Box Mod and the CP RDA. This item also has other color to choose.
Mod:
Powered by single 18650 battery, the authentic Advken CP Mod adopts press filling and fire button locking design. Inside is the 7ml glass bottle, and there is a hole for users to check e-juice. There is a button locking design for your safety.
Tank:
The Original Advken CP RDA features single coil building and post air holes design to deliver pure flavor, and a plate near positive pole effectively avoids splashing. It comes with a 810 drip tip.
Время генерации страницы 0.37053 секунды с 15 запросами
