Вернуться   Форум FONAREVKA.RU Фонари (по типу) Сверхмощные и поисковые фонари
Просмотров в теме 44274   Ответов в теме 38   Подписчиков на тему 8   Добавили в закладки 0
Старый 02.01.2011, 17:25 Автор темы   1
Администратор
Аватар для Admin
Сказал(а) спасибо: 4330
По умолчанию Мега - фонарь. "Fat Star" Octa 8x SST-90
Hello,
instead of doing something serious with my money like going to Ibiza, I put some parts together,
in the beginning there was this lathe and a piece of aluminium:
...later it looked like this, thanks to Piet from Frankfurt:
...and here are all the parts for the whole light together:
...the SST-90 emitters, connected together in series and glued to the
massive heatsink for the modamag 4" Turbo Head:
...the modamag configurable battery adapter with 8x IMR18650 cells, I will use
a stock Mag switch to power this light- not sure, what will happen in use...
"Fat Star" Octa 8x SST-90 in 4" Colossus Turbo Head:
"Fat Star" Octa 8x SST-90 Colossus Led Flashlight at about 18.000 Lumens, the whole light:
This current I measured with 8x AW IMR18650 cells fresh from the charger, I wanted to get
nothing more but 9amps for 8x 2250 lumens = 18.000 lumens, but I got this, my camera had
some problems to take the photo, down left is the heatsink with the working SST-90 emitters.
I hope some resistance will be added when the flashlight host and the switch will come
in between and current will be reduced...
Controlshot at white wall:
DX stock P7 light:
"Fat Star" Octa 8x SST-90:
DX stock P7 at a parking lot:
"Fat Star" 8x SST-90:
Avenue with trees, light up by my car with 2x H7 on high:
Same Avenue light up by the "Fat Star" (without help of carlights):
"Frankfurt Holiday Inn", DX stock P7:
"Messeturm Frankfurt", 70 floors overground, DX stock P7:
Fat Star with new alu-reflectors:
Beamshots with new reflectors:
To have any comparison to the Ledil reflectors, I took new photos at the "Holiday Inn", controlshot:
...please excuse blurish quality, I could only take one beamshot, then some security from the hotel showed up and asked me "friendly" to leave...
"Fat Star" with new reflectors:
...a street close to my home at night:
...same setup with Fat Star:
...and here is the video: FatStar
Thank you for watching & best regards from Frankfurt,
Steffen.
:wave:
Старый 02.01.2011, 19:14   2
Tymmmi
Аватар для Tymmmi
Последняя активность: 04.10.2021 09:16
Сказал(а) спасибо: 53
По умолчанию Re: Мега - фонарь. "Fat Star" Octa 8x SST-90
ппц...
Tymmmi вне форума   Ответить с цитированием Вверх
Старый 02.01.2011, 19:23   3
Angel
Самоделкин
Аватар для Angel
Сказал(а) спасибо: 81
Hellburner =)
Старый 02.01.2011, 19:29 Автор темы   4
Admin
Администратор
Аватар для Admin
Посмотреть сообщение Сообщение от Angel :
Hellburner =)
Тебе есть к чему стремиться
Старый 02.01.2011, 19:36   5
Angel
Самоделкин
Аватар для Angel
Да мне уже некчему,фонарик достающий до облаков я уже сделал В этот фонарик неплохо бы еще в центр диодов добавить.
Старый 02.01.2011, 21:56   6
knyaz
Аватар для knyaz
Сказал(а) спасибо: 47
холдер в данном агрегате конфигурируется как угодно, а с расширительными кольцами, и дополнительными проставками кол-во аккумов можно увеличить до 16.
knyaz вне форума   Ответить с цитированием Вверх
Старый 03.01.2011, 01:00   7
Juster
Последняя активность: 07.04.2013 14:57
Питания хватит примерно на 6 минут... а алюминиевая голова расплавиться через 2 минуты, ибо на неё приходится ~ 40 ватт тепла... так что всё нормально с питанием
PS так то смысла в этой игрушке никакого кроме вау-эффекта
[Исправлено: Juster, 03.01.2011 в 01:06]
Juster вне форума   Ответить с цитированием Вверх
Старый 03.01.2011, 12:19   8
Wector
Раздуплятор нубов
Аватар для Wector
Последняя активность: 02.02.2019 12:46
Сказал(а) спасибо: 23
Поблагодарили: 41 раз(а) в 26 сообщениях
Отправить сообщение для Wector с помощью ICQ
Ничего не будет алюм. голове, диоды раньше умрут...
И на нее приходится не 40 Вт, а ок. 200 Вт тепла.
Wector вне форума   Ответить с цитированием Вверх
Старый 03.01.2011, 13:07   9
Juster
Мда, чё то я вчера прогнал... 3,8 Вольта х 13,22 Ампера х 8 штук = 402 Вт с учетом ~ кпд диодов в маааксимум 20% получаем 321 Вт тепла.
И кстати никто не знает что за фонарик был в оригинале? из под чего?
Старый 03.01.2011, 13:22   10
Firebird
Аватар для Firebird
Последняя активность: 25.08.2024 07:00
Сказал(а) спасибо: 34
Поблагодарили: 66 раз(а) в 33 сообщениях
Отправить сообщение для Firebird с помощью ICQ
Посмотреть сообщение Сообщение от justerius :
Думаю, здесь, при желании, найдутся все составные части.
Firebird вне форума   Ответить с цитированием Вверх
Старый 03.01.2011, 21:34   11
John Jack
Аватар для John Jack
Записей в дневнике: 18
Сказал(а) спасибо: 1790
Там в оригинале был кусок алюминия. Единственная более-менее промышленная часть - кнопка от маглайта.
Старый 03.01.2011, 21:40   12
knyaz
Аватар для knyaz
В оригинале стоит лампа 250 ватт, 24В, в перекале около 300 ВАтт
Старый 04.01.2011, 00:55   13
Juster
Посмотреть сообщение Сообщение от knyaz :
http://www.candlepowerforums.com/vb/...ens-TK-Monster В оригинале стоит лампа 250 ватт, 24В, в перекале около 300 ВАтт
вот это искал, рефлектор там оригинальный.
Единственная изготовленная деталь это алюминивая чушка на которой автор расположил диоды. И вот что что, а кнопу я бы сделал слаботочную с полевиком.
Старый 04.01.2011, 01:36   14
knyaz
Аватар для knyaz
Ну и сам фонарь-кастом и изготовлен малой партией....
Старый 04.01.2011, 13:05   15
Децибел
Аватар для Децибел
Последняя активность: 12.03.2023 20:54
Сказал(а) спасибо: 26
Ничего такой фонарик можно использовать как зенитный прожектор
Децибел вне форума   Ответить с цитированием Вверх
Старый 04.01.2011, 14:36   16
Hocum
Сказал(а) спасибо: 215
Посмотреть сообщение Сообщение от Децибел :
Яичницу на нем жарить самое то
Старый 04.01.2011, 20:20   17
John Jack
Яичницу таки лучше на лампе накаливания жарить же.
Старый 04.01.2011, 20:25   18
Wector
Раздуплятор нубов
Аватар для Wector
Неа. У него фокусировка галимая.
Автор просто влепил мелкие рефлекторы, чтоб удивить всех размером. А свет ерунда, просто ближний заливной...
Старый 04.01.2011, 23:02   19
Hocum
Не прогрессивно ))
Старый 08.02.2011, 22:53   20
npomokoji
Аватар для npomokoji
Последняя активность: 12.03.2023 10:25
Сказал(а) спасибо: 13
Отправить сообщение для npomokoji с помощью ICQ Отправить сообщение для npomokoji с помощью Skype™
Thanks for review I like this
В планах сфокусировать солнце
npomokoji вне форума   Ответить с цитированием Вверх
Время генерации страницы 0.16058 секунды с 15 запросами
