Поблагодарили: 6697 раз(а) в 4633 сообщениях
Реклама на форуме. | |
Разместить рекламу
Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
Crelant developed a new police torch recently, and are able to be shipped.
- CREE XP-G2 R5 LED with 50 000 hours life span. - Maximum output: 460 lumens (ANSI FL-1 standard) - High efficient constant current circuit and regulated output-luminance - Durable, custom-designed Microcontroller drive circuit - Tactical tailcap default high mode by rotating or pressing the tail switch - Working voltage: 2.7V--8.4V DC - Battery Types Supported: 1 x 18650 or 2 X CR123A - Runtime: High output at 1.5 A: 460 lumens for 125 minutes. - Mil. Spec. Type III hard anodized aircraft grade 6063-T6 aluminum alloy - Color: Black - Ergonomic grip with anti-roll design - Tactical forward tail cap switch - High performance aluminum smooth reflector with concentrated beam shot - Waterproof: IPX-8 Standard - Lens: Toughened & ultra-clear coated and anti-abrasive glass - Dimensions: Length 132mm, Head Diameter 32mm, Body Diameter 25.4mm - Weight: 115g excluding battery - Accessories: Lanyard, spare o-ring ![]() |
Поблагодарили: 1356 раз(а) в 888 сообщениях
Ух ты, какой новый и необычный!
Turn Day into Night
Регистрация: 23.10.2012 Последняя активность: 30.04.2022 22:15 Адрес: Львів
Сказал(а) спасибо: 1743
Продам фонари Convoy S3 с разной TIR оптикой |
Olight H15S WAVE
Обновление налобника Olight The H15S has three output modes (Low, Medium, and High) and an optimized user interface for easy access. It can be configured to either use the switch or infrared hands-free sensor to turn the light on and off. A filter built-in filter diffuses the light for close-up work but can instantly be flipped out of the way to project the beam far. This makes the H15S an extremely versatile light great for reading, inspecting equipment, working on the car, or walking at night. ![]() |
http://www.foursevens.com/p...
4sevens Atom A0 Titanium Limited Edition Специальная редакция Preon P0. Титановый корпус и XP-G2. ![]() |
