Просмотров в теме 302440   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 26.07.2018, 05:32 Автор темы   161
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original CigGo Praxis Vapor Banshee 150W TC VW Variable Wattage Box Mod Original Price $38.99, Now Only $20.99
The Original CigGo Praxis Vapor Banshee Box Mod is a reliable regulated device which is powered by dual 18650 batteries (NOT INCLUDED) and can reach maximum output to 150W. It support temperature control from 100 to 300 Celsius degrees (200 to 600 Fahrenheit degrees) and is compatible with SS / TI / NI coils. The minimum resistance allowed is 0.1ohm. This item also has other Version to choose.
Original CigGo Tattoo Plus 75W TC VW Variable Wattage Box Mod Original Price $37.99, Now Only $19.99
The Original CigGo Tattoo Plus Box Mod is a compact regulated device which is powered by single 18650 batteries (NOT INCLUDED) and can reach maximum output to 75W. It support temperature control from 100 to 315 Celsius degrees (200 to 600 Fahrenheit degrees) and is compatible with SS / TI / NI coils. This item also has other Version to choose.
Original Da One Splash Hybrid Mechanical Tube Mod $14.99
The Da One Splash Mech Mod is a 24mm mechanical mod that comes with stainless steel top and bottom, brass internal tube and resin external tube. The mod is powered by single 18650 battery (NOT INCLUDED). The fire button is activated by spring. This item also has other colors to choose.
Original Jac Vapour Series-B DNA 75W TC VW Variable Wattage Box Mod $119.00
The Original Jac Vapour Series-B Box Mod is a small sized DNA Mod which incorporates DNA75 chip and is powered by single 18650 battery (NOT INCLUDED). The output power is variable from 1 to 75 Watts. It adopts a 0.91inch OLED screen, spring-loaded positive connector and electroplated magnetic cover. The atomizer resistance range is from 0.15 to 0.25ohm. This item also has other colors to choose.
Original Fumytech Govap 70W VW Variable Wattage Box Mod Original Price $49.90, Now Only $36.99
The Original Fumytech Govap Mod is a compact device with variable wattage from 15 to 70 Watts. The mod is powered by single 18650 battery (NOT INCLUDED). The atomizer resistance range is from 0.3 to 3 Ohm. The mod supports USB charging.
Original Wismec Luxotic MF Box 100W VW Squonk Box Mod with Screen $50.79
Being multifunctional and versatile, LUXOTIC MF BOX undoubtedly satisfies you in various ways to vape as squonk mod and box mod. The device comes with variable voltage board with a 0.91inch OLED screen. Another highlight is that the 18650 and 21700 battery can be used interchangeably (BATTERY NOT INCLUDED). This item also has other Version to choose.
Original Vapesoon VS12 Super Cloud Tank Clearomizer $11.99
The Vapesoon VS12 Super Cloud Tank is the latest atomizer from Vapesoon which is specially designed for big smoke lovers. Measures in a huge 28mm and constructed by stainless steel and glass, it is durable and comes with 8ml large e-juice capacity. The most important feature is that the tank is compatible with three types of SMOK TFV12 Prince Coil including the V12 Prince-M4 0.17ohm Quadruple Coils, V12 Prince-Q4 0.4ohm Quadruple Coils, and V12 Prince-T10 0.12ohm Decuple Coils. Moreover, VS12 Super Cloud Tank also features adjustable bottom airflow and easy top refill design.
The drip tip will be in random color.
Original Fumytech Gotank MTL RTA Rebuildable Tank Atomizer Original Price $27.50, Now Only $24.99
The Original Fumytech Gotank MTL RTA is a 22mm MTL rebuildable tank atomizer with 3ml of juice capacity. It comes with dual post build deck for single coil builds. With bold airflow structure and adjustable bottom airflow, this RTA will bring you great MTL vaping experience.
Vapeasy Pico Femto BF RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $19.99, Now Only $10.99
The Vapeasy Pico Femto BF RDA is a 22mm single coil squonk ready RDA with direct bottom airflow, which provides a rich and silky vapor production in MTL to Semi-DL setup. There is a crank shaped narrow juice path hidden beneath the deck, which will prevent the juice leaking.
Coppervape Penodat MTL RTA Rebuildable Tank Atomizer Clone $22.99
The Coppervape Penodat MTL RTA Clone is a 22mm rebuildable tank atomizer with 4ml of juice capacity. The tank comes with extra fat PC tank with 5.5ml capacity. The tank is built with 0.7 mm x 5 airflow insert and comes with spare 1.2mm / 1.6mm MTL kit. The tank also features easy top filling and adjustable bottom airflow.
Original Da One Splash Hybrid Mechanical Tube Mod + Gaze RDA Kit $24.99
The Original Da One Splash Mech Kit consists of Da One Splash Mech Mod and Gaze RDA. This item also has other colors to choose.
Mod:
RDA:
The Gaze RDA is a 24mm rebuildable dripping atomizer that features dual post build deck and adjustable side airflow. The posts has quad terminals for easy building. The airflow holes can be fully open or closed. PEI wide bore drip tip is included. This RDA comes with bottom feeder pin.
Original Fumytech Govap 70W VW Variable Wattage Box Mod + Gotank Kit Original Price $64.90, Now Only $47.99
The Original Fumytech Govap 70W Kit consists of Fumytech Govap Mod and Fumytech Gotank.
Mod:
Tank:
The Original Fumytech Gotank is a 23.5mm sub ohm tank with 4ml of juice capacity. The pre-installed coil has 0.36ohm resistance and supports wattage from 30 to 70W. It is easy to refill the tank from the top.
Original Wismec Luxotic MF Box 100W Squonk Mod with Screen + Guillotine V2 RDA Kit $70.39
The Original Wismec LUXOTIC MF BOX Kit consists of LUXOTIC MF BOX and Guillotine V2 RDA. This item also has other Version to choose.
Mod:
RDA:
The Original Wismec Guillotine V2 RDA is a 24mm RDA with dual post build deck for easy coil building. The adjustable side airflow brings great flavor to you. Guillotine V2 RDA is one of the best BF RDAs for your squonk mod.
Original Vapesoon V8 Baby-Q4 Quadruple Coil for SMOK TFV12 Baby Prince Tank $7.99
The Vapesoon V8 Baby-Q4 coil head is suitable for SMOK TFV12 Baby Prince tank atomizer. The V8 Baby-Q4 core features 0.4 ohm resistance which supports 30~65W power output (best 50~60W). This coil head will bring you denser vapor and purer flavor.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Vapeasy Replacement 510 Drip Tip for Pico Femto BF RDA Clone $1.99
The replacement 510 drip tip is made from POM. It is designed for Vapeasy Pico Femto BF RDA Clone, but is also suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose.
Vapeasy Replacement Top Cap + AFC Ring for Pico Femto BF RDA Clone $3.99
The replacement top cap and AFC ring are made from PEI. They are suitable for Vapeasy Pico Femto BF RDA Clone. This item also has other Version to choose.
3FVAPE вне форума   Вверх
Старый 27.07.2018, 04:49 Автор темы   162
3FVAPE
Avid Lyfe Kane Hybrid Mechanical Tube Mod Clone $24.99
The Avid Lyfe Kane Mechanical Tube Mod Clone is a mech mod made from resin and brass. It comes with hybrid top cap and magnetic fire button. It is powered by single 20700 battery (NOT INLCUDED). 18650 battery adapter tube is also included.
The color of resin tube may vary a bit due to the material. This item also has other colors to choose.
Original Laisimo Vapsoon-Spin 208W TC VW Variable Wattage Box Mod $46.99
The Original Laisimo Vapsoon Spin 208W Box Mod adopts unique spin button on the central part instead of common "+" and "-" button. With its 1.3inch colorful screen and cool UI, you can operate this mod with ease. The mod is powered by dual 18650 batteries (NOT INCLUDED) and can reach maximum output to 208W. This item also has other colors to choose.
Original S-Body Orca 220W TC VW Variable Wattage Box Mod Original Price $45.90, Now Only $35.99
The Original S-Body ORCA 220 Mod is a super lightweight box mod which uses ABS and PC material. It features impressive colorful pattern all over the mod. Powered by advanced S-Body chipset, the mod can reach maximum output to 220W with dual 18650 batteries (NOT INCLUDED). It supports Temp (Ni, SS, Ti, TCR), VPC, Bypass modes and comes with multiple protections. This item also has other colors to choose.
Original CoilART Salt RTA Rebuildable Tank Atomzier Original Price $32.99, Now Only $27.79
The Original CoilART Salt RTA is a small sized rebuildable tank atomizer. It comes with 18mm diameter and 2ml capacity, which can be extended to 3.5ml with bubble glass tube. The single coil deck is very easy to build. The adjustable bottom airflow has 7 levels, from 0.6 to 2.0mm. This item also has other colors to choose.
Reckoning RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99
The Reckoning RDA Clone is a 25mm RDA with a vertical clamp system. With a spring loaded positive center post and opposing negative posts, it can handle whatever build you can come up with. It has multiple airflow control options. This RDA will bring you cloud-chasing and DIY fun.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
SXK Artoo R2 RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $15.90, Now Only $12.99
The SXK Artoo R2 RDA Clone is a 22mm low profile squonk RDA with easy single coil build deck and side airflow system. The deck is wide for the wicks. The large posts makes coil mounting very easy.
Original Vapor Storm ECO 90W Box Mod + Lion RDA Kit $29.00
The Vapor Storm ECO Kit consists of Vapor Storm ECO Box Mod and Lion RDA. This item also has other colors to choose.
Mod:
The Vapor Storm ECO Box Mod is an ultra lightweight unregulated mod powered by single 18650 battery (NOT INCLUDED). It works with direct output and the maximum wattage is 90W. The recommended resistance is over 0.9ohm.
RDA:
The Vapor Storm Lion RDA is a 24mm RDA that has a gold plated build deck for dual coil builds. The side airflow is adjustable for optimal flavor.
Replacement Tank Tube for Hussar The End RTA Clone $3.59
The replacement tank tube is made from PC and has 3.5ml of juice capacity. It is suitable for Hussar The End RTA Clone.
One piece will be shipped.
Replacement Tank Tube + Chimney for Hussar The End RTA Clone $6.99
The replacement tank tube is made from PEI and has 2ml of juice capacity. The chimney is made from 316 stainless steel. They are suitable for Hussar The End RTA Clone.
Старый 28.07.2018, 04:50 Автор темы   163
3FVAPE
Original Vaporesso Tarot Baby 85W 2500mAh TC VW Variable Wattage Box Mod $49.49
The Original Vaporesso Tarot Baby Mod is a elegant and versatile mod powered by built-in 2500mAh battery and the maximum output can reach up to 85W. There is a 0.96-inch full-color display with a vertical menu that has all necessary vape data. With an upgraded OMNI Board 4.0 which supports 0.002s fast firing speed and is adaptive to all mainstream tanks from 0.03ohm to 5ohm (Super Player Mode). This item also has other colors to choose.
Original Vapor Storm Puma Stone 200W TC VW Variable Wattage Box Mod $39.99
The Original Vapor Storm Puma Stone Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (NOT INCLUDED), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience. This item also has other colors to choose.
Reload X RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.69
The Reload X RDA Clone is a 24mm RDA constructed from stainless steel. It features a quad terminal postless deck designed for dual coil configurations and dual adjustable top-down bottom airflow system that minimizes leakage while providing intense flavor.
Yup RDA Rebuildable Dripping Atomizer Clonw with BF Pin $10.90
The Yup BF RDA Clone is a 24mm RDA that features Y-shaped build deck. The unique Y deck design with quad gold plated posts makes coil building really easy. Comes with adjustable side airflow, this RDA will bring pure flavor and massive clouds.
Convergent RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.79
The Convergent RDA Clone is a 22mm RDA constructed from 316 stainless steel. It is a simple coil RDA that is designed to produce an extremely smooth vapor by means of several convergent nozzles. Less amount of air can cool down a coil in the RDA and produce rich flavor vapor. This RDA is great for mouth to lung vaping.
Noble RDA Rebuildable Dripping Atomzier Clone $10.99
The Noble RDA is a 25mm RDA that features postless build deck design, bottom airlflow system and spit back defuser. It comes with a glass tube, a stainless steel tube and a standard 810 drip tip with 4-way AFC fins. This item also has other colors to choose.
Original Kindbright Black Swan RDA Rebuildable Dripping Atomizer with BF Pin $24.99
The Original Kindbright Black Swan RDA is a 24mm RDA made from stainless steel. The build deck comes with large central positive post with big Philips screw and dual negative posts with hex screws. The Black Swan RDA has two types of airflow, the bottom-top airflow and angled side airflow, which will bring you optimal flavor and massive clouds.
Original Vaporesso Tarot Baby 85W 2500mAh TC VW Variable Wattage Box Mod + NRG SE Tank Kit $57.99
The Original Vaporesso Tarot Baby Kit consists of Vaporesso Tarot Baby Mod and NRG SE sub ohm tank. This item also has other colors to choose.
Mod:
Tank:
The Vaporesso NRG SE Tank inherited the twist open design with smooth adjustable bottom airflow from the NRG family. The tank comes with 4.5ml capacity with bubble glass and 2ml with the standard glass. Two kinds of coils are included, GT Meshed Coil (0.18ohm) and GT CCELL Coil (0.5ohm).
Original SMOKTech SMOK Replacement Pod Cartridge for Novo Pod System Kit $8.69
The replacement Pod Cartridge has 2ml of juice capacity and is suitable for SMOK Novo Pod System Kit.
This product comes with 3 PCS in 1 pack.
Vapeasy Crossbow MTL RBA Clone for Billet Box Mod Clone $9.99
The Vapeasy Crossbow MTL RBA Clone is made from 316 stainless steel and PEEK insulator. It is suitable for SXK Billet Box Mod Clone/ YFTK Billet Box Mod Clone. It supports single coil builds.
Старый 30.07.2018, 04:44 Автор темы   164
3FVAPE
Original Timesvape Reverie RDA Rebuildable Dripping Atomizer with BF Pin Original Price $28.00, Now Only $21.99
The Original Timesvape Reverie RDA is a 24mm single coil RDA designed in USA by Stan, who is a famous reviewer in YouTube. The Reverie RDA has a simplified vertical build deck for easy vertical single coil building with a convenient squonk pin and deep juice well. Besides, the Reverie RDA features multi-port airflow system with many airflow options to provides precise airflow control and optimal flavor. A reduced inner chamber for maximum flavor and two kinds of 810 drip tips are included. This item also has other colors to choose.
Kindbright Redemption RDA Rebuildable Dripping Atomizer Clone $9.29
The Kindbright Redemption RDA Clone is a 24mm rebuildable atomizer constructed from 316 stainless steel. It features Rapture style posts and Apocalypse style airflow with single airflow option. The dual clamp posts forms a bridge over the shelf for extra space. POM drip tip is included. This item also has other colors to choose.
Original Aleader Funky 80W TC VW Variable Wattage Box Mod + Sub Ohm Tank Kit Original Price $55.99, Now Only $34.39
The Original Aleader Funky 80W Kit consists of Funky Box Mod and Funky Sub Ohm Tank. This item also has other colors to choose.
Mod:
The Aleader Funky 80W Box Mod is constructed from Aluminum Alloy and Honeycomb resin. Powered by single 18650 battery (NOT INCLUDED), the Funky Mod can reach up to a maximum output power of 80W. Besides, it comes with a 0.91inch screen to view all necessary data.
Tank:
The Aleader Funky Sub Ohm Tank is a 24mm clearomizer with 2ml of juice capacity. It features the same honeycomb resin design as Aleader Funky 80W Box Mod, easy top filling and adjustable bottom airflow. The pre-installed coil has 0.15ohm resistance.
Replacement Bottom Feeder Squonk Bottle for Limelight BF Box Mod $2.99
The replacement bottom feeder bottle is made from silicone and has 8ml of juice capacity. It is suitable for Limelight squonk box mod. This item also has other colors to choose.
Original Vapesoon SS316 Coil Head for Joyetech eGo AIO Kit / D16 / D22 Tank $4.99
The Vapesoon SS316 Coil Head has 0.6ohm resistance and works well at 15~28W. It is suitable for Original Joyetech eGo AIO / D16 / D22 / D22 XL / Pro / Pro C / Cubis / Cubis Pro. This item also has other resistance to choose.
Original Vapesoon V8 Baby-M2 Coil Head for SMOK TFV8 Baby Tank $6.59
The V8 Baby-M2 coil head is suitable for SMOK TFV8 Baby Beast tank atomizer / TFV8 Big Baby / SMOK Alien Kit, SMOK G-Priv Kit / SMOK G320 Kit. The V8 Baby-M2 core features 0.25 ohm resistance that can support 3.7V direct output. This item also has other Version to choose.
Старый 31.07.2018, 04:31 Автор темы   165
3FVAPE
Vapeasy Mini B MiniB Mechanical Tube Mod Clone $20.99
The Vapeasy Mini Bestia Mini B Mod Clone is the smallest 18650 mech mod. It is constructed from brass, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Original Timesvape Reverie RDA Rebuildable Dripping Atomizer with BF Pin Original Price $28.00, Now Only $22.99
Original Kangvape Mini K 400mAh VV All-in-One Starter Kit $10.89
The Original Kangvape Mini K is a compact starter kit that is powered by built-in 400mAh battery. The atomizer has 0.5ml of juice capacity and 1.5ohm coils pre-installed. The power can be adjusted change the output voltage in 3 gears, 3.4V, 3.7V and 4.0V. This item also has other colors to choose.
Original Green Sound GT125 125W 4800mAh TC VW Variable Wattage Box Mod Kit $37.79
The Original Green Sound GT125 mod is a powerful and versatile vape device, which is made of Zinc alloy, powered by a built-in 4800mAh battery. The GT125 can reach its maximum output to 125W. It has a 1.3 inch colorful display screen. The tank features 0.15ohm resistance, 4.5ml capacity.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip.
This drip tip will be shipped in random color (1 piece). This item also has other colors to choose.
SXK 510 Flat Mouthpiece Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.39
The SXK replacement 510 drip tip is made from POM. It is suitable for all atomizers that fit 510 drip tip.
Старый 01.08.2018, 04:35 Автор темы   166
3FVAPE
Original Wotofo Recurve 80W Squonk Mechanical Box Mod Original Price $49.99, Now Only $45.79
The Original Wotofo Recurve Squonk Mod, a collaboration between Wotofo and Mike Vapes, is an 80W mech mod level squonk mod, and an unregulated mod with full safety features. It is powered by a single 18650, 20650, 20700, or 21700 battery (BATTERY NOT INCLUDED) under working voltage of 3.2~4.2 volts. The mod combines the essence of beautiful curves and ergonomics seamlessly and delivers a fantastic smooth feel with special rubber coating. This item also has other colors to choose.
The Vapeasy Mini Bestia Mini B Mod Clone is the smallest 18650 mech mod. It is constructed from stainless steel, with hybrid connection and side fire button. The mod is powered by only single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Chronos RDA Rebuildable Dripping Atomizer Clone $8.59
The Chronos RDA Clone is a 24mm RDA constructed from stainless steel. It has a dual post build deck for easy coil building. The juice well is deep and the center pin is gold plated. The side airflow is adjustable for optimal flavor. Wide bore Ultem drip tip is included. This item also has other colors to choose.
Original Augvape BTFC RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.90, Now Only $23.99
The Original Augvape BTFC (Bottom Top Flavor Cloud) RDA is a 25mm RDA with a spacious deck for easy building. The BTFC RDA features adjustable double airflow system, top airflow and bottom airflow. The four airholes on the build deck bring direct airflow underneath the coil to maximize flavor. The RDA is compatible with both 810 and 510 drip tips.
The Original Green Sound GT125 mod is a powerful and versatile vape device, which is made of Zinc alloy, powered by a built-in 4800mAh battery. The GT125 can reach its maximum output to 125W. It has a 1.3 inch colorful display screen. The tank features 0.15ohm resistance, 4.5ml capacity. This item also has other colors to choose.
Original Wotofo Fused Clapton N80 Heating Resistance Wire Original Price $10.99, Now Only $8.29
This new line of quality wires is the same with Wotofo's popular prebuilt coil series wires. High in quality, able to be configured to the most complex coil builds, perfect for delivering massive vapor production without sacrificing the flavor. This wires is wrapped with 26GA + 38GA and comes with almost 20 feet length in total. This item also has other Version to choose.
Original Hsmax NOS 1100mAh Heat Not Burn Device Original Price $85.00, Now Only $66.99
The Original Hsmax NOS Heat Not Burn Device features 1100mAh built-in battery, adjustable output temperature from 300 to 400 Celsius degrees, assemble clearomizer, ceramic heating blade. NOS suits current marketing heatsticks, like Marlboro, Heets, Parliament, Fiit, Kuanzhai etc.
Старый 02.08.2018, 04:48 Автор темы   167
3FVAPE
Original SMOKTech SMOK Micro One 150 R150 1900mAh TC VW Variable Wattage Box Mod Original Price $39.99, Now Only $26.99
The SMOK R150 Mod is built-in battery type mod which has 1900mAh capacity and the max output power can be up to 150W. In addition to its portable and compact size, R150 TC has a fundamentally improvement in finish. The new rubberized finish adds a shiny look and soft feel, and is more durable than an oxidized one. This item also has other colors to choose.
Original SMOKTech SMOK H-Priv Mini 50W 1650mAh TC VW Variable Wattage Box Mod Original Price $39.99, Now Only $19.59
The Original SMOK H-Priv Mini 50W TC VW Box Mod is a stylish mod with hidden fire button design. It has built-in 1650mAh battery and the output power can reach up to 50W. The mod supports nickel, titanium and 316 stainless steel in temperature control mode and the TC range is 100~315'C / 200~600'F. H-Priv Mini comes with multiple protections, like intelligent atomizer recognition, puff monitoring system, 12 seconds cut-off, short circuit protection, over-heating protection, low battery warning. Micro USB port supports both charging and software upgrading.
Original USV L USV-L 75W TC VW Variable Wattage Box Mod Original Price $45.99, Now Only $30.99
The Original USV L 75W Box Mod is a nice machined mod with compact design. It is equipped with VO 75 chipset and the max power output can reach 75W. The temperature control range is 100~300'C (212~572'F). The doors of both sides can be slided easily but it is not loose. This mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Purge Suicide Queen Hybrid Mechanical Tube Mod Clone $25.59
The Purge Suicide Queen Mechanical Mod Clone is a 26mm mech mod which tapers to 25mm on top. It features unique engraved artwork on the body. The hybrid top cap allows more power hit. It is powered by single 18650 or 20700 battery (NOT INCLUDED). This item also has other colors to choose.
SOB Uno Bersikulo Hybrid Mechanical Mod Clone $12.99
The SOB Uno Bersikulo Mechanical Mod Clone features translucent PC chassis, brass hybrid top cap and tube, Ultem fire button on the side and copper battery door. It is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
YC Vape Hadaly RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.79
The YC Vape Hadaly RDA Clone is an innovative RDA for you flavor chasers out there. It is constructed from 316 stainless steel in 22mm diameter. This RDA is amazing but if you looking for massive clouds this one is not for you. It is best suited for single coil builds. The bottom comes with serial number.
Original Civanpor Atena RDA Rebuildable Dripping Atomizer with BF Pin $26.99
The Original Civanpor Atena RDA is a 24mm rebuildable squonking atomizer constructed from PEI (cap) and 316 stainless steel (base). It features dual post build deck and has quad terminals for easy building. The RDA comes with side airflow for great flavor and massive clouds.
Original SMOKTech SMOK Stick V8 2000mAh Battery + TFV8 Baby Tank Kit Original Price $34.99, Now Only $25.99
The Original Stick V8 Baby kit consists of 2000mAh Stick V8 2000 battery and TFV8 Baby tank (TPD edition). Simple mechanical pen style matches with baby beast - TFV8 Baby tank, the newest pen kit brings you experience the purest taste. Innovation keeps changing the vaping experience.
Replacement Bottom Fire Button for avid lyfe Mechanical Tube Mod Clone $13.59
The replacement bottom fire button is constructed from aluminum. It comes with copper contact pin. It is suitable for avid lyfe mech mods Clone.
This product does not come with magnets. This item also has other Version to choose.
Старый 03.08.2018, 04:57 Автор темы   168
3FVAPE
Original VGME DPS75 80W TC VW Variable Wattage Box Mod $55.99
The Original VGME DPS75 Box Mod is a high-end reconstituted wood mod, which can fire up to 80W with dual 18650 batteries (NOT INCLUDED). The DPS75 supports VW / TC / Bypass modes. The minimum resistance support is 0.05ohm (TC) / 0.15ohm (VW). The mod comes with several protections, including battery reverse protection, short circuit protection, low resistance warning, low voltage protection, and over-heating protection. This item also has other colors to choose.
Original Aspire Dynamo 220W TC VW Variable Wattage Box Mod Original Price $60.00, Now Only $55.99
The OriginalAspire Dynamo Mod, being allowed to use with three different types of battery, 18650, 20700 or 21700 (BATTERY NOT INCLUDED), can reach maximum output power to 220W. The Dynamo can also be used in various modes, allowing you to easily select between Wattage, Voltage, Bypass, CPS (C1 / C2 / C3), TC (Ni / Ti / SS316L) and TCR (M1 / M2 / M3). Even though the Dynamo is a dual battery mod, it is still quite ergonomic and comfortable to hold thanks to its rounded sides and corners. This item also has other colors to choose.
Original SynthetiCloud Alpine RDTA Rebuildable Tank Atomizer Original Price $29.99, Now Only $12.59
The Original SynthetiCloud Alpine RDTA is a 24mm rebuildable tank atomizer with 3ml of juice capacity. The tank features dual post build deck, with single terminal at each post, and the Cyclonic dual airflow system, which is fully adjustable for optimal flavor. This item also has other colors to choose.
Original Limitless Hextron Sub Ohm Tank Atomizer Original Price $29.99, Now Only $12.59
The Original Limitless Hextron Tank from LMC is a hard hitting sub-ohm masterpiece. With coils coming in at 0.5ohm, the bottom airflow design has been integrated within the coil which ties into the adjustable airflow on the tank to ensure lower temperatures but higher performance. Top fill port for ease of refills and avoiding the mess. The tank features 24mm diameter and 3ml capacity.
Original Aspire Dynamo 220W TC VW Variable Wattage Box Mod + Nepho Tank Kit Original Price $85.30, Now Only $72.99
The Original Aspire Dynamo Kit consists of Aspire Dynamo Mod and Aspire Nepho Tank. This item also has other colors to choose.
Mod:
The Original Aspire Dynamo Mod, being allowed to use with three different types of battery, 18650, 20700 or 21700 (BATTERY NOT INCLUDED), can reach maximum output power to 220W. The Dynamo can also be used in various modes, allowing you to easily select between Wattage, Voltage, Bypass, CPS (C1 / C2 / C3), TC (Ni / Ti / SS316L) and TCR (M1 / M2 / M3). Even though the Dynamo is a dual battery mod, it is still quite ergonomic and comfortable to hold thanks to its rounded sides and corners.
Tank:
The Aspire Nepho Tank comes with 4ml of juice capacity and adopts 0.5ohm KA coil and 0.15ohm Mesh coil. The triple slot airflow is easy to adjust to your own vaping style and preference, The Nepho tank ensures great flavor at all settings with a wide bore Delrin drip tip ensuring comfort.
Original Omeka MSM Replacement Ni80 Coil Head for C8 Starter Kit $11.59
The replacement Ni80 coil head comes with 0.5ohm resistance and is suitable for Original Omeka MSM C8 Starter Kit.
810 Gear Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.99
The 810 drip tip is made from aluminum with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version to choose.
510 Spinning Fidget Stand Base for RDA / RTA / Sub Ohm Tank Atomizer $5.89
The 510 spinning stand base can be used as a normal stand for your favorite RDA, RTA or Sub Ohm Tank. It comes with spinning bearing and can be played as a desktop fidget toy. The base stand is made from aluminum. This item also has other colors to choose.
Original Shield Cig Multifunction Tool Kit for E-Cigarette $18.59
The Shield Cig Multifunction Tool Kit comes with 1 x 6-in-1 screwdriver, 1 x folding scissors, 1 x tweezers, 1 x pliers. The 6-in-1 screwdriver comes with 5 different screwdrivers, each coming with a two-head screwdriver bit, which can also be used for winding wires. And this tool can be used as a torch by using a single AA battery (NOT INCLUDED). The tool kit will bring you great convenience.
Original Nitecore Q6 2A 6 Slots Battery Charger for 18650 / 20700 / 21700 Battery $34.39
The Original Nitecore Q6 Battery Charger is a 6 slots quick charger with output current up to 2A in a single slot, which is equipped with the charging system optimized for IMR batteries. It charges 6 Li-ion batteries independently, automatically detecting power levels and selecting charging mode. Moreover, heat dissipation fins and multiple protections are adopted for safe charging.
Original Nitecore LC10 Portable USB Charger $14.49
The Original Nitecore LC10 USB Charger is a lightweight charger compatible with adapter, solar panel, car adapter, power bank and notebook with a max charging current up to 1A, capable of charging almost all kinds of 3.6V or 3.7V cylinder Li-ion Batteries. It can also serve as a power bank with battery to charge IOS mobile phone. Having charging, discharging & lighting functions, magnetic design and portable size, it offers great convenience for you.
Старый 06.08.2018, 04:52 Автор темы   169
3FVAPE
Coppervape CloudOne Blasted V4 RTA Rebuildable Tank Atomizer Clone $18.99
The Coppervape CloudOne Blasted V4 RTA Clone is a great rebuildable tank atomizer made from 316 stainless steel. The Cloud One V4 comes with single coil build deck and bottom airflow system for optimal flavor. It is a 22mm RTA with 3.7ml of juice capacity. The dual center air hole is 2 x 2mm and 2 x 1mm MTL kit is included. This item also has other colors to choose.
B2K RSA V5 RDA Rebuildable Dripping Atomizer Clone with BF Pin + Spare Caps $14.99
The B2K RSA V5 RDA Clone is a 24mm RSA & RDA which has postless build deck for single coil builds. It is easy to mount coils with such structure. The side airflow will bring you smooth, quiet and extremely flavorful vape experience.
This RDA comes with 3 extra sets of drip tips, caps and decorative rings (POM, PEI), the original one comes with PC drip tip, SS cap and PC decorative ring.
Original Eleaf iWu 15W 700mAh Pod System Starter Kit $20.99
The Original Eleaf iWu is a sleekly designed refillable pod system with a protective hollow-out cover design that allows you to conceal the mouthpiece. The pod boasts an innovative and leakage-free side-fill solution and can hold 2ml e-liquid. The iWu is quite simple to use for its no-button feature that automatically initiates when you inhale. Packed with a 700mAh inbuilt battery, the iWu remains a remarkably small size and is ultra-portable. It is optimized for nicotine salts especially using the 1.3ohm coil contained within the pod. Offering ultra-convenience and portability, Eleaf iWu is a best option for vapers on the go or simply looking for an easy to use pod vape. This item also has other colors to choose.
Original Asmodus Spruzza 80W TC VW Variable Wattage Squonk Box Mod + Oni-One RDA Kit Original Price $119.99, Now Only $71.99
The Original Asmodus Spruzza 80W Squonk Kit consists of Spruzza Squonk Box Mod and Oni-One RDA. This item also has other colors to choose.
Mod:
The Original Asmodus Spruzza Suqonk Box Mod is powered by GX-80-HUT chip which allows various modes (Power, Curve, TC, TFR, and TCR) with full touch screen operation. Powered by single 18650 battery (not included), the mod can reach maximum output to 80W (60W at TC mode). The Spruzza comes with its proprietary Smart Siphon System (SSS), a pump system that is the first of its kind. Both simple to maintain and operate; the SSS can be easily removed for cleaning and replacement, and can hold up to 6mL of your favorite juice in the reservoir, which can be filled by sliding the glass door upwards.
RDA:
The Oni-One RDA is a 24mm RDA. The deck of the ONI is a Unique two post design in which you remove the whole hex screw and placing your coil, making it easy to build on. The juice well is not only deep but also split so when you squonk, the juice directly wicks into the cotton for. We've machined the bottom airflow inlets in an upward angle to increase the flavor production. The 810 Black Delrin drip tip was designed in a way where the vape will condense into the bottom of the top and give you a denser, and flavorful vape experience. There is also a hidden feature inside the top cap of the ONI-ONE, inside the top cap, there is an ORING located in the top. This will catch all the juice and drip it back down the wick not wasting a drop of your valuable juice.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.39
The replacement 510 drip tip is made from stainless steel. It is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose.
Replacement 510 Drip Tip + Top Cap for Narda RDA Clone $3.69
The replacement 510 and top cap are made from PMMA and is suitable for Narda RDA Clone. This item also has other colors to choose.
Original Vapesoon V12 Prince-Q4 Quadruple Coil for SMOK TFV12 Prince Tank $2.59
The V12 Prince-Q4 coil head is suitable for SMOK TFV12 Prince tank atomizer. The V12 Prince-Q4 core features 0.4 ohm resistance which supports 40~100W power output (best 60~80W). This SMOK TFV12 Prince coil head will bring you deep and rich cloud vapor. This item also has other Version to choose.
Coppervape Replacement 510 Drip Tip for CloudOne Blasted V4 RTA $1.29
The Coppervape 510 Drip Tip is made from POM, and it is suitable for CloudOne Blasted V4 RTA and other atomizers compatible with 510 drip tip. This item also has other colors to choose.
Coppervape Replacement PC Tank Tube for CloudOne Blasted V4 RTA $2.99
Coppervape CloudOne Blasted V4 RTA Replacement Tank Tube is made from PC with 3.7ml capacity. This item also has other Version to choose.
Старый 07.08.2018, 04:37 Автор темы   170
3FVAPE
Original Eleaf iWu 15W 700mAh Battery Mod $8.99
The iWu battery is quite simple to use for its no buttons design. When you inhale, it automatically initiates. The iWu battery is small in size but comes with an internal 700mAh battery which can last a long time of vaping. Enjoy vaping whenever and wherever you want. This item also has other colors to choose.
Original Acevape MK RTA Rebuildable Tank Atomizer Original Price $32.90, Now Only $28.99
The Original Acevape MK RTA is a 25mm rebuildable tank atomizer with 3ml / 5ml of juice capacity. The postless build deck supports both single coil and dual coil. With the leak-proof top airflow system, the airflow hits directly on the coil for denser cloud and better flavor. This item also has other colors to choose.
Original Cool Vapor MGTK RDA Rebuildable Dripping Atomizer with BF Pin Original Price $25.90, Now Only $19.59
The Original Cool Vapor MGTK RDA is a 24mm rebuildable squonking atomizer made from stainless steel. The MGTK RDA features a wide postless build deck, which is easy to build dual coils. With the adjustable side airflow, this RDA will bring you smooth vaping experience.
SXK Legend Atty RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin Original Price $21.99, Now Only $19.99
The SXK Legend Atty RDTA Clone is a 22mm rebuildable dripping tank atomizer made from 316 stainless steel. It comes with about 2ml of juice capacity. The chamber is very compact, which gives it a dense vapor and reveals the flavor to the fullest. The RDA comes with two different caps for different airflow options.
This RDTA comes with bottom feeder pin only, standard 510 pin is not included.
Original Eleaf Replacement Cartridge for iWu Pod System Starter Kit $8.59
The iWu cartridge boasts an innovative side-fill solution, which makes refill of a pod easier and faster than ever and is leakage-free. It is optimized for nicotine salts especially using the 1.3ohm coil contained within the pod. To compliant with TPD regulations, the iWu pod comes with an e-liquid capacity of 2ml.
Original Eleaf Replacement Cover for iWu Pod System Starter Kit $5.99
The iWu is a sleekly designed pod system with a protective hollow-out cover design. The cover is retractable, allowing you to conceal and protect the mouthpiece. The cover can also be removed and replaced. This item also has other colors to choose.
Original Phevanda Replacement Top Cap for Bell RDA $9.99
The replacement top cap is made from PEI and is suitable for Original Phevanda Bell RDA. This item also has other colors to choose.
Старый 08.08.2018, 04:37 Автор темы   171
3FVAPE
Original Pioneer4You iPV D3S 80W TC VW Variable Wattage Box Mod Original Price $39.99, Now Only $21.99
The iPV D3S Mod by Pioneer4You is an upgraded version of iPV D3, featuring a streamlined form factor with a magnetized battery door powered by single 18650 battery (NOT INCLUDED) along with a zinc alloy chassis, a gold plated spring loaded 510 connection. The iPV D3S adopts the new YiHi SX150H that can support 7~80W power output. This item also has other colors to choose.
Carnage RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.49
The Carnage RDA Clone is constructed from stainless steel in 25mm diameter. The build deck features dual post design, and the posts are not the same style. The negative post utilizes flathead grub screw, while the positive post adopts clamp design with dual flathead heads. The internal cap comes with single-hole airslot and triple-hole airslot, which allows you to adjust the configuration to your favorite one.
Coil Father Classic G Goon V1.5 RDA Rebuildable Dripping Atomizer Clone $7.59
The Coil Father Classic G Goon V1.5 RDA Clone is constructed from stainless steel in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable airslots for airflow control. The airflow can be adjusted for single or dual coil builds. This item also has other colors to choose.
Reckoning RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
Kindbright Crossbow MTL RBA Clone for Billet Box Mod Clone $13.99
The Kindbright Crossbow MTL RBA Clone is made from 316 stainless steel and PEEK insulator. It is suitable for SXK Billet Box Mod Clone/ YFTK Billet Box Mod Clone. It supports single coil builds.
The product does not contain AFC modular.
The image is for reference only, the actural product is the MTL RBA.
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.59
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Старый 09.08.2018, 04:44 Автор темы   172
3FVAPE
Original Cthulhu Fractal DNA75C Hybrid Mod $219.79
The Original Cthulhu Fractal DNA75C Hybrid Mod is a unique mod which is made from real wood and resin hybrid material. It is powered by Evolv DNA75C Chip and can be compatible with single 18650 / 20700 / 21700 battery (NOT INCLUDED).
The image is for reference only, each Cthulhu Fractal Mod is unique and comes with different grain and pattern. This item also has other colors to choose.
Kindbright Centurion V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $21.99
The Kindbright Centurion V2 RDA Clone is a 30mm BF RDA made from 316 stainless steel. It is a large RDA with triple-post build deck for dual coil builds. The airflow is adjustable for optimal flavor. The RDA comes with 2 extra caps and 1 PEI drip tip.
Original KAEES Stacked RTA Rebuildable Tank Atomizer Original Price $34.95, Now Only $23.99
The KAEES Stacked RTA is a collaboration project from KAEES and Tony B, which is designed to give you great pure flavor, with an easy to build dual coil deck, that is "stacked" and only requires tightening two screws. The deck can accommodate any wire you want, and you can even use mesh because its a flat clamp. Plus, it will not twist your flat wire. It is a great RTA for DIY lovers. This item also has other colors to choose.
Vapeasy NarDA RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.99
The Vapeasy NarDA RDA Clone is a rebuildable dripping atomizer with 22mm diameter. It is made from 316 Stainless Steel. This RDA comes with dual-post design, which is easy to build. It comes with adjustable airflow for "direct-lung" and "mouth-to-lung" hits.
This RDA comes with Botton feeder pin.
YFTK Hussar Legacy RDA Rebuildable Dripping Atomizer Clone with BF Pin $20.59
The YFTK Hussar Legacy RDA Clone has been designed to fit those who use more fruity or fresh liquids while maintaining a lot of custard profile. The build deck is easy for single coil building. The RDA has side airflow system for pure flavor.
Original Vapesoon 810 Drip Tip for TFV8 / TFV12 Tank / Goon / Kennedy / Reload RDA $1.99
The replacement 810 drip tip is made from POM and aluminum. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Original Vapjoy CS4 Intelligent 4-Slot LCD Charger $28.99
The Original Vapjoy CS4 Charger is an intelligent charger that is compatible with IMR / Li-ion / LiFePO4 / Ni-MH / Ni-Cd batteries. It has a LCD screen which displays each cell of voltage, charging current, charging time, battery type. Each of four battery slots monitors and charges independently. After charging over 8 hours, it will stop automatically to ensure safety.
This charger comes with US Plug. This charger also has EU Plug to choose.
Original Bravo Arrow Box 1500mAh PCC Portable Charging Case for JUUL $20.99
The Original Bravo Arrow Box PCC Portable Charging Case is specifically designed for JUUL. It comes with 1500mAh and can charge the JUUL device.
Старый 10.08.2018, 04:49 Автор темы   173
3FVAPE
Original Vandy Vape Pulse X RDA Rebuildable Dripping Atomizer with BF Pin Original Price $32.99, Now Only $24.69
The Vandy Vape Pulse X RDA feeds the juice directly to the top of your coils, giving you the experience you would get with typical dripping atomizers, and saturating your wicks and coils from the top. This ensures that your coils are always wet and ready to go. When squonking, the one-way-valve design allows excess juice to return to the bottole at the bottom. It also allows you to drip right onto the center through the drip tip for non-squonk usage, and the liquid rolls off the top center of the post and onto your coils. The "X" design for the post can be used effectively for vertical and horizontal builds, and can accommodate large or small coils. This item also has other colors to choose.
Original Steam Crave Aromamizer Plus RDTA Rebuildable Dripping Tank Atomizer $34.99
The Original Steam Crave Aromamizer Plus RDTA features huge size with 30mm diameter and new air intake screen design to both improve flavor and reduce the effects of coil spitting. The enhanced juice flow design is for more accurate juice supply and ease of assembly 10ml juice capacity as standard. The spacious postless build deck can hold coils of over 6mm internal diameter. This item also has other Version to choose.
Original Joyetech EXCEED NC 2300mAh Battery Mod + NotchCore Tank Starter Kit Original Price $49.99, Now Only $40.99
The Original Joyetech EXCEED NC Kit consists of EXCEED NC Battery and NotchCore Tank. This item also has other colors to choose.
Mod:
The Joyetech EXCEED NC battery presents you with two optional modes: direct output and constant voltage output along with advanced dual circuit protection. It has built-in 2300mAh battery capacity which will provide you a long vaping experience.
Tank:
The Joyetech NotchCore with 22mm diameter and 2.5ml is easy to install and change the NotchCoil atomizer head in an economic way. The resistance is 0.45ohm. It adopts the horizontal way to achieve a pure flavored taste. Meanwhile, you can enjoy the huge clouds with a low power output (20~25W). The gold plated atomizer base makes a good electrical conductivity. With the push-to-open top filling design, you can simply push the top cap to reveal the filling hole. What's more, the airflow can be adjusted by simply rotating the ring.
Original Rincoe Neso 370mAh Pod System Starter Kit $21.89
The Original Rincoe Neso Kit is an all-in-one ultra-thin and portable pod system kit. Constructed by the zinc alloy shell with a rubberized finish, the Rincoe NESO Kit is equipped with the 2ml e-juice pod, a 1.3ohm coil that allows for plenty of juice capacity to provide pure flavor and great vaping experience. Comes with a built-in 370mAh battery, the NESO allows you to enjoy vaping any time. There is no fire button, just draw and it will activate automatically with multiple protections. This item also has other colors to choose.
Original Vandy Vape Pulse X 90W TC VW Squonk Box Mod + Pulse X BF RDA Kit Original Price $69.90, Now Only $57.99
The Pulse X Kit comes with the colored translucent panels that were so popular with the Pulse BF Kit, and features the Pulse X RDA, co-designed by Tony B and Stefen Z. This item also has other colors to choose.
Mod:
The Vandy Vape Pulse X Mod has maximum power output of 90 watts with single 18650 / 20700 / 21700 battery (NOT INCLUDED). It is powered by Vandy Chip, which has excellent quality and highest stability. The replaceable panel comes with magnetic structure design.
RDA:
The Pulse X RDA feeds the juice directly to the top of your coils, giving you the experience you would get with typical dripping atomizers, and saturating your wicks and coils from the top. This ensures that your coils are always wet and ready to go. When squonking, the one-way-valve design allows excess juice to return to the bottole at the bottom. It also allows you to drip right onto the center through the drip tip for non-squonk usage, and the liquid rolls off the top center of the post and onto your coils. The "X" design for the post can be used effectively for vertical and horizontal builds, and can accommodate large or small coils.
Coppervape Replacement PEI Chimney for CloudOne Blasted V4 RTA Clone $4.59
The Coppervape CloudOne Blasted V4 RTA Replacement Chimney is made from PEI.
Старый 11.08.2018, 05:12 Автор темы   174
3FVAPE
Original Wismec Active 2100mAh 80W TC VW Variable Wattage Box Mod $48.99
The Original Wismec Active can serve as an e-cig device and a speaker, adopting the innovative Bluetooth technology. Moreover, the stylish box mod designed to be waterproof and shockproof, the masterpiece is now born and combines with built-in 2100mAh battery and 80W output power. Every detail is meticulously designed and elaborately crafted, whether from the design, the material or the workmanship, youll find it a desirable vaping device. This item also has other colors to choose.
Complyfe Vortex Hybrid Mechanical Tube Mod Clone $24.29
The Complyfe Vortex Mechanical Tube Mod Clone is made from brass and it comes with copper battery contact. The mod has hybrid connection for more power hit. The battery contact is made from copper. The fire button is activated by magnets. This mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Scepter Hybrid Mechanical Mod Clone $25.59
The Scepter mechanical mod Clone is constructed from brass with copper battery contact. The mod features twisted design and engraved millings and patterns. It comes with top venting holes and magnetic fire button. The mod is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
SXK Boxer 200W VV VW Variable Wattage Squonk Box Mod Clone Original Price $48.90, Now Only $40.59
The SXK Boxer Box Mod Clone is a durable regulated mod made from ABS. The wattage can be varied from 5 to 200 watts with dual 18650 / 20700 batteries (NOT INCLUDED). It comes with three modes: power mode, voltage regulation mode, and mechanical mode. The squonk bottle has 7ml of juice capacity. This item also has other colors to choose.
Avid lyfe Kane Dragon Hybrid Mechanical Tube Mod Clone $26.59
The Avid lyfe Kane Dragon Mechanical Tube Mod Clone is a mech mod made from brass. It comes with hybrid top cap and magnetic fire button. It is powered by single 20700 battery (NOT INLCUDED). 18650 battery adapter tube is also included. The engraved dragon pattern makes this mech mod unique.
Original Kanger KBOX 70W 4000mAh TC VW Variable Wattage Box Mod Original Price $37.99, Now Only $18.99
The Original Kanger KBOX is a TC Temperature Control and VW Variable Wattage APV box mod. It comes with 4000mAh fixed battery that can support 7~70W power output. This item also has other colors to choose.
Original Kanger KBOX 40W VW Variable Wattage Box Mod Original Price $24.99, Now Only $13.99
This is the KangerTech's first box mod. KBOX makes use of an aluminum chassis to give you lighter mod to handle. Lightweight but durable. With a design to feel comfortable in the palm of your hand. A simple wattage setting that you can choose from 7 variables for 0.4 ohm and above atomizers. The KBOX features a heat dissipation hole, short circuit and over current protection. 510 thread connection and interchangeable battery socket. Making an overall convenient device for you vaping experience.
Original Cloupor GT 80W TC VV VW Variable Wattage Box Mod Original Price $47.99, Now Only $13.99
The Cloupor GT 80W is a smart-auto temperature control box mod. It is the smallest dual 18650 box mod on the market today coming in at 0.86" inches thickness. It is with one of the most efficient power management chips leading to super long battery life. This temperature control mod is with an intelligent chip that will automatically set the appropriate power (joules) based on the selected temperature. You also have the ability to manually select temperature and power (joules) like traditional temperature control mods.
This mod features smart-auto temperature control while still having the ability to use standard temperature control as well as standard variable wattage and variable voltage modes using traditional Kanthal / Nichrome coils.
Original Asmodus Vault RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.95, Now Only $27.99
The Original Asmodus Vault RDA is a 24mm flavor-based RDA that will amaze anyone's standards in terms of flavor. The Vault's low-profile design that minimizes the chamber space and a domed top cap to help concentrate the flavor and a dual post clamp style retention method that enables even the thickest and most exotic of coil designs to be installed with ease. Measuring 24mm in diameter, the Vault will fit on almost any mod you can think of without any overhang. Airflow is handled via the adjustable dual sided 7.25mm by 2mm airflow slots that provide the perfect amount of draw resistance to provide a warm, flavorful vape even when fully open. These can be closed off with the use of the rotating inner barrel to fine-tune the Vault to suit your preference, and make the vapor warmer and the flavor more pronounced as you restrict the incoming air.
Original Hellvape Drop Dead RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $29.99
The Original Hellvape Drop Dead RDA is an epic collaboration by Hellvape, Vapin' Heathen, and TVC The Vapor Chronicles, creating a rebuildable masterpiece based on the designs of two of the best selling atomizers of the past year, the Hellvape Dead Rabbit RDA and Digiflavor DROP RDA. The Drop Dead RDA feature Drop style deck and Dead Rabbit style top cap, which brings fantastic chemistry, performing greatly in flavor and cloud production. This item also has other colors to choose.
Original Wismec Active 2100mAh 80W TC VW Box Mod + Amor NS Plus Tank Kit $65.59
The Wismec Active Bluetooth Music Kit consists of Wismec Active Mod and Amor NS Plus Tank. This item also has other colors to choose.
Mod:
Tank:
The Original Wismec Amor NS Plus Tank is a 27mm tank with 2ml and 4.5ml of juice capacity with different glass tubes. The brand-new WS04 MTL 1.3ohm head is optimized for high nicotine and nic-salts e-liquid. The unique design of atomizer head will offer you intense flavor and wonderful MTL vaping enjoyment. Simply slide the top cap, you can finish the refilling quickly and easily. You will also get a great vaping experience through the sophisticated and accurate airflow control system.
Original Kanger Subox Mini 50W VW Variable Wattage Starter Kit Original Price $54.99, Now Only $25.99
This starter kit includes both the all new KangerTech KBOX Mini as well as the brand new Subtank Mini. The KangerTech KBOX was an extremely popular box mod, and the KBOX mini looks to build on the success of that unit. The KBOX mini has a magnetic battery cover as well as an OLED display to check your settings and battery life.
Vapeasy Replacement 510 Drip Tip + Top Cap + AFC Ring for Pico Femto BF RDA Clone $4.99
The replacement 510 drip tip is made from POM. The top cap and AFC ring are made from 316 stainless steel. They are suitable for Vapeasy Pico Femto BF RDA Clone.
Старый 13.08.2018, 04:43 Автор темы   175
3FVAPE
Original Vapordance Newbie RDA Rebuildable Dripping Atomizer $16.59
The Original Vapordance Newbie RDA is a 24mm RDA that adopts replaceable coil deck, which is convenient to replace if you do not want to build coils. The pre-installed coil comes with 0.35ohm resistance. The RDA comes with adjustable bottom airflow. This item also has other colors to choose.
Original 3CVAPE Sahara RDA Rebuildable Dripping Atomizer with BF Pin $35.79
The Original 3CVape Sahara RDA, a collaboration from 3CVape and Geek Vape Q8, is a 24mm BF RDA with a unique W-shaped dual terminal posts. The 3CVape Sahara RDA has a 4mm juice well and has a dual section top cap; one Acrylic airflow adjustment cap, and a lower barrel portion with four 2mm air holes on each side. Each air hole is sloped downwards and the top cap is locked in place with a 1.5mm locking ridge, ensuring consistent airflow and top cap alignment.
Original Smokjoy Rebel 2200mAh All-in-One Starter Kit $23.79
The Original Smokjoy Rebel Kit is the latest pen-style kit from Smokjoy, which features top push-style to fill the atomizer, bottom power button, and 3.5ml e-juice capacity. Measured in 24mm diameter, it has a 2200mAh built-in battery. There is a LED indicator which will show you the different state of the kit through different colors. This item also has other colors to choose.
Original Shanlaan Laan Pod 40W 1300mAh Starter Kit Original Price $109.00, Now Only $65.99
The Original Shanlaan Laan Pod Kit has built-in 1300mAh battery and a tank with 2ml juice capacity and adjustable airflow. The Pod mod is made from aluminum and premium leather. And its top filling system is not only highly leakage-proof but also very convenient to refill. The Laan System is enabled by a draw-activated mechanism with child-lock functionality, and the ability for output adjustment such as power output and temperature settings when connected to iOS or Android System via Bluetooth connection (requires Laan App). This item also has other colors to choose.
Coppervape Replacement 510 Ultem Drip Tip for Penodat MTL RTA Clone $1.99
The replacement 510 drip tip is made from PEI Ultem. It is designed for Coppervape Penodat MTL RTA Clone, but is also suitable for all atomizers that fit 510 drip tip.
Coppervape Replacement Tank Tube for Penodat MTL RTA Clone $1.99
The replacement glass tank tube is suitable for Coppervape Penodat MTL RTA Clone.
Coppervape Replacement Ultem Tank Tube for Penodat MTL RTA Clone $3.59
The replacement PEI Ultem tank tube is suitable for Coppervape Penodat MTL RTA Clone.
Original Wotofo Agleted Organic Cotton for Coil Wicking $3.99
Wotofo Agleted Organic Cotton is inspired by the ever increasing needs of fast cotton preparation for your rebuilding convenience. The cotton we selected are of long fibers so that it wicks smooth and its not easy to pull apart. However, thats not the best part, the best part is that we put a sheath on one end of the cotton strip so as to function like the aglet on your shoelace, then its much easier to thread the cotton through the coils. Each cotton strip is ready-to-use with proper cotton amount thats tested to best fit for dominant 3mm I.D. coils on the market. The cotton features great absorption capability and better retention ability, freshly packaged to deliver the purest flavor. There are 10 pieces of agleted cotton strips in one little box, convenient to carry around and stored in a clean way.
Original Shanlaan Laan Refillable Pod Cartridge $23.99
The Shanlaan Laan pod is a 2ml refillable pod cartridge and is suitable for Original Shanlaan Laan Pod Kit.
This product comes with 4 PCS in 1 pack.
Original Vapordance Newbie Replacement Coil Head $6.99
The Vapordance Newbie Replacement Coil Head comes with 0.35ohm resistance and is suitable for Original Vapordance Newbie RDA.
Старый 14.08.2018, 04:47 Автор темы   176
3FVAPE
Rouge Rainmaker Hybrid Mechanical Tube Mod Clone $17.99
The Rogue Mechanical Mod Clone is constructed from stainless steel in 24mm diameter. It is powered by single 18650 battery (NOT INCLUDED). It features 510 hybrid top cap, 4 venting holes and spring fire button. This item also has other Version to choose.
Rogue 3 Faces Hybrid Mechanical Tube Mod Clone $17.99
Rogue American Angel Hybrid Mechanical Tube Mod Clone $17.99
Rogue Hybrid Mechanical Tube Mod Clone $19.99
The Rogue Mechanical Mod Clone is constructed from copper in 24mm diameter. It is powered by single 18650 battery (NOT INCLUDED). It features 510 hybrid top cap, 4 venting holes and spring fire button. This item also has other Version to choose.
Coil Father Classic G Delta RDA Rebuildable Dripping Atomizer Clone $7.99
The Coil Father Classic G Goon Delta RDA Clone is constructed from stainless steel in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable airslots for airflow control. The airflow can be adjusted for single or dual coil builds.
Старый 15.08.2018, 04:44 Автор темы   177
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original DEJAVU DJV Hybrid Mechanical Tube Mod Original Price $101.99, Now Only $57.99
The Original DEJAVU DJV Mech Mod, designed by the YouTube reviewer Adrian Lo Dejavu, is a high-end mech mod powered by single 18650 battery (NOT INCLUDED). The DJV Mech Mod can work efficiently with two types of button, the stainless steel or acrylics. DEJAVU DJV Mod also features the innovative hybrid system, which makes the 510 pin of atomizer contact the battery directly for better power transfer and a harder, faster hit. With the advanced canted coil inside the gold-plated contact pin, the DEJAVU DJV Mech MOD can provide maximum firing and reduce heat effectively.
Original Advken Manta RTA Rebuildable Tank Atomizer original Price $39.99, Now Only $26.99
The Original Advken Manta RTA is a 24mm diameter tank with 4.5ml capacity (3ml with spare tank sleeve). The special two-post design can be compatible with different types of wires. It also features convenient top filling, gold plated posts, and bottom adjustable airflow. Manta RTA comes with a PEI 810 wide bore drip tip. This item also has other colors to choose.
Original SMOKTech SMOK Species 230W TC VW Mod + TFV8 Baby V2 Tank Kit $85.59
The SMOKTech SMOK Species Kit consists of SMOK Species Mod and TFV8 Baby V2 Tank. This item also has other colors to choose.
Mod:
The Original SMOKTech SMOK Species is an angular mod with hard lines, which reflects its sublime heroism. The front brand new 1.45" high-definition touch screen comes with upgraded user interface offers you more comprehensive and clearer vaping data, while the back has classic cobra pattern that reveals its domineering potential. Moreover, the screen locking button ensures a safe operation. And its output can be varied from 1 to 230W with dual 18650 batteries (NOT INCLUDED), which can meet your various demands.
Tank:
The SMOK TFV8 Baby V2 tank adopts two powerful coils, Baby V2 A1 Coil with super large heating area and Baby V2 A2 Coil with dual heating cores, fully satisfying the vaping fans' pursuit of dense flavor and massive cloud. The tank comes with 5ml of juice capacity to meet your daily need.
Original Vapesoon Replacement Coil Head for iJust 3 Kit / Ello Duro Tank / Pico S Kit / Ello Vate Tank $2.59
The Vapesoon HW-N Head is used for Eleaf iJust 3 Kit, Ello Duro Tank, Pico S Kit and Ello Vate Tank. The resistance is 0.2ohm and will work well at 40~90 watts. This item also has other Version to choose.
510 Fuji Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99
The replacement 510 drip tip is made from POM. It is suitable for all atomizers that fit 510 drip tip. This item also has other Version to choose.
Original Advken 3.7V 20A 2500mAh 18650 High drain Rechargeable Li-ion Battery Original Price $13.98, Now Only $8.59
The Original Advken 18650 Battery, featuring a diameter of 18mm and a length of 65mm, has a 2500mAh large battery capacity with 20A max continuous discharging current.
Coil Father Bmax 4.2V E-cig Charger for 14500 / 18350 / 18650 / 26650 Li-ion Battery $4.99
This charger is suitable for charging 14500 / 18350 / 18650 / 26650 Li-ion battery. It has a compact size and has single battery slot for charging.
Старый 16.08.2018, 04:45 Автор темы   178
3FVAPE
Original Vaporesso Luxe 220W TC VW Variable Wattage Box Mod $50.99
The Vaporesso Luxe combines elegant aesthetic with beastly power. It has a 2" full-view TFT screen with touch panel gives you a much wider and smoother space to play. The Insta-Fire technology delivers 0.001s firing rate. The OMNI-Board 4.0 with 2.5A ultrafast charge technology is the perfect engine for this sophisticated cloud machine. It is powered by dual 18650 batteries (NOT INCLUDED). This item also has other colors to choose.
Purge Slam Piece Hybrid Mechanical Tube Mod CLone $21.49
The Purge Slam Piece Mod is a 30mm mechanical tube mod that is made from brass. It can be compatible with single 18650 / 20700 / 21700 battery, coming with hybrid top cap for more power hits. The fire button is activated by magnets.
Original Demon Killer Sniper RDA Rebuildable Dripping Atomizer with BF Pin $11.99
The Original Demon Killer Sniper RDA is a 24mm RDA made from stainless steel. It has dual post build deck with 4 terminals for easy building. The airflow can be adjusted by the side airflow ring, with 8 airholes on each side, which makes the airflow hit the coil directly. It is compatible with 810 and 510 drip tips.
This product comes with bottom feeder pin. This item also has other colors to choose.
Original Cthulhu 1928 MTL RDA Rebuildable Dripping Atomizer with BF Pin $20.59
The Original Cthulhu 1928 MTL RDA is one of the smallest chamber RDA with 22mm diameter, which is designed for true MTL and nic-salts vaping. It comes with 0.8mm, 1.2mm, 1.6mm, 2.0mm airflow holes for tight or loose MTL vaping. The raised building deck makes sure no flavor loss. This RDA comes with smooth bottom airflow.
Vapor Giant Extreme RTA Rebuildable Tank Atomizer Clone $26.99
The Vapor Giant Extreme RTA Clone is a 23mm RTA made from 316 Stainless Steel and PEI. It comes with 23mm diameter and 5ml of juice capacity. The build deck is dual-post designed and the tank has air draft regulation in the top cap. With top filling design, you can refill your favorite juice easily.
Original Vaporesso Luxe 220W TC VW Variable Wattage Box Mod + Skrr Tank Kit $68.99
The Original Vaporesso Luxe Kit consists of Vaporesso Luxe Mod and Skrr Sub Ohm Tank. This item also has other colors to choose.
Mod:
Tank:
The Vaporesso Skrr Tank is a 30mm sub ohm tank with 8ml of juice capacity. The Quad-flow air distribution system provides exquisite flavor and warmth by keeping cold drafts out, creating a perfect balance between taste and cloud chasing. With this new breakthrough technology, it eliminates spit back. A thoughtful innovation on the drip tip provides a secure yet simple locking mechanism. The base of the tank has been redesigned to prevent leakage.
Original Demon Killer Slacker Cotton for Coil Wicking $2.99
The Demon Killer Slacker Cotton is good for coil wicking. The size is 80mm by 1.5mm.
This product comes with 60 PCS in 1 pack. This item also has other Version to choose.
Original Demon Killer Replacement Double Wire Coil Head for Magic Hat Sub Ohm Tank $6.99
The replacement Double Wire Coil Head has 0.5ohm resistance and the best power is 50W. It is suitable for Original Demon Killer Magic Hat Sub Ohm Tank.
This product comes with 3 PCS in 1 pack. This item also has other Version to choose.
Original Demon Killer Magic Hat Sub Ohm Tank Clearomizer $9.99
The Original Demon Killer Magic Hat Sub Ohm Tank is a 24mm clearomizer and comes with two different capacity. When 0.5ohm coil head installed, this tank has 5ml of juice capacity; when 0.15ohm coil head installed, it has 4.5ml of capacity. The tank has bottom-top airflow for great flavor. This item also has other colors to choose.
3FVAPE вне форума   Вверх
Старый 17.08.2018, 04:49 Автор темы   179
3FVAPE
Original USV L USV-L 75W TC VW Variable Wattage Box Mod Original Price $69.99, Now Only $39.99
Original Augvape Druga Foxy 150W VW Variable Wattage Box Mod $51.99
The Original Augvape Druga Foxy 150W Box Mod is made from zinc alloy and has switchable IML panels. Powered by dual 18650 batteries (NOT INCLUDED), the Druga Foxy can reach maximum output power to 150W. The allowed resistance range is from 0.05 to 3.0 ohm. This item also has other colors to choose.
Original S-Body Orca 220W TC VW Variable Wattage Box Mod $35.99
Original Asmodus Voluna V2 RTA Rebuildable Tank Atomizer Original Price $39.95, Now Only $33.99
The Original Asmodus Voluna V2 RTA is a 25mm rebuildable tank atomizer with 3.2ml of juice capacity. The deck has been greatly improved and is very easy to build due to its unique and innovative dual lego-like posts. The deck also has much space for building. With the adjustable bottom airflow, the RTA will bring you incredible clouds and optimal flavor. This item also has other colors to choose.
Original Shanlaan Laan Lite 320mAh Pod System Kit $28.99
The Original Shanlaan Laan Lite Pod Kit is operated with a draw activated firing mechanism and has a maximum output of 7.4W. Shanlaan Laan has a refillable pod with an atomizer resistance of 1.3 ohm and a maximum capacity of 1.4ml. A 310 mAh built in battery supplies power for the device and an LED battery life indicator indicates its battery life. The Laan can be charged via the proprietary magnetic charging cable. This item also has other colors to choose.
810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.59
The 810 drip tip is made from oak. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Original Snowwolf Replacement WF Coil Head for Vfeng Sub Ohm Tank $14.99
The replacement coil head has 0.2ohm of atomizer resistance and works well at 60 to 150W, best at 80 to 140W. It is suitable for Snowwolf Vfeng sub ohm tank / Vfeng Kit.
This product comes with 5 PCS in 1 pack. This item also has other Version to choose.
Original Shanlaan Laan Lite Replacement Pod Cartridge $10.99
The Authentic Shanlaan Laan Lite Replacement Pod Cartridge comes with 1.3ohm of resistance and 1.4ml capacity. It is suitable for Shanlaan Laan Lite Pod System Kit.
Original Vapeasy Display Base Stand for RDA / RTA / Sub Ohm Tank Atomizer $9.99
The Vapeasy display base stand is made out of stainless steel. It is suitable for all size atomziers. Fingerprints and scratches are not easy to be left on this stand. And the curve design holds e-juice, preventing your table being flooded with liquid. The thread is specially designed and will not get any atomizer stuck. This item also has other colors to choose.
Старый 20.08.2018, 04:39 Автор темы   180
3FVAPE
Original Vaporesso Skrr Sub Ohm Tank Clearomizer $28.99
The Vaporesso Skrr Tank is a 30mm sub ohm tank with 8ml of juice capacity. The Quad-flow air distribution system provides exquisite flavor and warmth by keeping cold drafts out, creating a perfect balance between taste and cloud chasing. With this new breakthrough technology, it eliminates spit back. A thoughtful innovation on the drip tip provides a secure yet simple locking mechanism. The base of the tank has been redesigned to prevent leakage. This item also has other colors to choose.
Original Tesla Punk Mini 85W TC VW Variable Wattage Box Mod + H8 Mini Tank Kit Original Price $101.56, Now Only $42.99
The Original Tesla Punk 85W Kit consists of Tesla Punk 85W Mod and Tesla H8 Mini Tank. This item also has other colors to choose.
Mod:
The Original Tesla Punk Mini is the slim version of Punk 220W mod, which is powered by single 18650 battery (NOT INCLUDED) and the maximum output is 85W. It is constructed from zinc alloy, ABS and PC, and it still comes with the same steampunk style PCB, which you can see through the transparent PC panel. The portable size and retro looking will catch everyone's eyes when you show off this to your friends.
Tank:
The Tesla H8 Mini Tank is a 24mm sub ohm tank that is made from stainless steel. It features 2ml e-juice capacity, slide top filling and bottom airflow for smooth vapor and pure flavor. The tank comes with two different coils, 0.15ohm F2 coil for 50 to 90W, and 0.15ohm E4 coil for 30 to 70W.
Single Port USB Charger for Juul Pod System Device $1.99
This USB charger has single port for charging. It is suitable for Juul device. This item also has other Version to choose.
USB Charging Cable Charger for Juul Pod System Device $2.99
This USB charging cable has single ports for charging. It is suitable for Juul device.
COCO Vapor 1200mAh PCC Portable Charging Case for Juul Pod System Device $18.99
The COCO Vapor charging box has 1200mAh of battery capacity and is suitable for Juul Device. It has 3 slots to place the pods and one for Juul to charge. The charging box has a LED screen to view the charging status. This item also has other colors to choose.
Replacement Coil Head for Typhoon GT4 Tisno Replaceable Deck Clone $2.99
The replacement coil head is made from gold plated stainless steel and features mesh structure. It has 0.15ohm resistance, which works well at 40 to 100W, best at 50 to 80W. It is suitable for GT4 Tisno Replaceable Deck Clone, which can be used on 1:1 Typhoon TF GT4 RTA.
Original Vaporesso Replacement SK CCELL Coil Head for Skrr Sub Ohm Tank $11.99
The Vaporesso Skrr SK CCELL coil head is now including temperature control through the use of SS316 coils. It also allows you to vape at higher wattages, with pure and smooth flavors. It comes with 0.5ohm resistance and works well at 50 to 75W.
Tisno Replaceable Deck Clone with Coil Head for Typhoon GT4 RTA Clone $12.99
The Tisno Replaceable Deck Clone is made from 316 stainless steel and is suitable for 1:1 Typhoon TF GT4 RTA. The coil head has 0.15ohm resistance, which works well at 40 to 100W, best at 50 to 80W.
Время генерации страницы 0.55147 секунды с 15 запросами
