Просмотров в теме 65723   Ответов в теме 210   Подписчиков на тему 1   Добавили в закладки 0
Старый 10.07.2021, 10:06 Автор темы   121
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update. Part 2.
Original Hellvape Fat Rabbit 28mm RTA Rebuildable Tank Vape Atomizer - Stainless Steel + Glass, 5.5ml, 28.4mm Diameter Original Price $39.9, Now Only $29.99.
The original Hellvape Fat Rabbit RTA is a diameter of 28.4mm vape atomizer which gives beast vaping quality and massive cloud. The Dual Airflow System enables Fat Rabbit RTA to provide more desirable vaping effects. Double honeycomb airflow intake to help produce huge vapor and rich flavor. It is made of durable SUS304 material, the classic Rabbit corrosion pattern is printed on the body that feels very good.
Original SMOKTech SMOK Fortis 80W Box Mod Kit with TFV18 Mini Tank - VW 5~80W, 1 x 18650 / 21700, 5.5ml Original Price $69.99, Now Only $49.99.
The original SMOKTech Fortis vape box mod Kit, is with a 510 thread TFV18 Mini tank vape atomizer, the elegant leather on the top of his body, the ergonomic design makes it easy to grip and non-slip. Powered By a single external 18650 / 21700 battery (not included) then serves your vaping with adjustable power up to 80w. Built-in smart chipset, features 0.001s instant firing speed, straightforward operation data on the 0.96 inch TFT color screen, with operation buttons, you can adjust the wattage and function or more.
Original Digiflavor Siren MTL RTA V4 S MTL V4 Rebuildable Tank Vape Atomizer - 2.0ml, 22mm Diameter Original Price $34.99, Now Only $26.99.
original Digiflavor Siren MTL RTA V4 vape atomizer features center-located honeycomb-style airflow holes to allow the air to flow straight to the coil, leakproof bottom airflow system with Semi-hidden AFC structure to provide boosting flavor. Digiflavor Siren MTL V4 RTA vape atomizer adopts 22mm single-coil dual-post GTA design deck
Original Eleaf Mini iStick 2 Kit Vape Box Mod Kit with GS Air 4 Tank - 1050mAh, VW 1~25W, 2.5ml, 0.8ohm / 1.4ohm Original Price $65.99, Now Only $43.99.
The original Eleaf Mini iStick 2 Vape Box Mod Kit is smaller than before, features AST steel technology for extends long-lasting life and improves the flavor taste. The Eleaf Mini iStick 2 Kit is extremely small and easy to hold, and it is more than enough to put it in a pocket. Its metal shell is made of advanced matte craftsmanship, which looks very delicate and does not leave fingerprints. Powered by a strong 1050mAh built-in battery, and the OLED screen shows the battery life that you can be using Type-C fast charging at any time.
Original Joyetech EVIO Box Pod Kit PC Version - 1000mAh, 2.0ml, 0.8ohm / 1.2ohm Original Price $34.99, Now Only $20.32.
The original Joyetech EVIO Box Pod System Vape Kit is compact and lightweight, using AST steel technology, which improves flavor transfer and extends the winding life. EVIO Box equipped with an integrated 1000mAh battery, which is charged with a modern USB Type-C connector. You can quickly replenish the reserve of autonomy using a current of up to 2A.
Original Joyetech EVIO Box Pod Kit Zinc Alloy Version - 1000mAh, 2.0ml, 0.8ohm / 1.2ohm Original Price $39.99, Now Only $23.81.
The original Joyetech EVIO Box Pod System Vape Kit is compact and lightweight, using AST steel technology, which improves flavor transfer and extends the winding life. EVIO Box equipped with an integrated 1000mAh battery, which is charged with a modern USB Type-C connector. You can quickly replenish the reserve of autonomy using a current of up to 2A. Comes with LED indictor to show the user three vaping modes: High, Medium and Low.
3FVAPE вне форума   Вверх
Старый 12.07.2021, 09:59 Автор темы   122
3FVAPE
Original YDDZ Tannhauser Legacy RDA Rebuildable Dripping Vape Atomizer 24mm Original Price $29.99, Now Only $17.99.
The original YDDZ Tannhauser Legacy RDA Rebuildable Dripping Vape Atomizer is made from Stainless Steel in 24mm Diameter. The airflow adjustable from the middle with air slots. The RDA is with building deck V1.8 for dual coil building.
Original YDDZ Tannhauser Legacy RDA Rebuildable Dripping Vape Atomizer 24mm Original Price $29.99, Now Only $14.99.
Simurg SX RTA Clone Rebuildable Tank Vape Atomizer - MTL / DL, 6.5ml, 22mm Diameter Original Price $38.99, Now Only $28.99.
The Simurg SX clone RTA Rebuildable Tank Vape Atomizer is made from stainless steel in 24mm diameter. The RTA is with mesh deck supports MTL / DL vaping. The Simurg SX clone RTA supports airflow adjustable and AFC with cam lock.
Stratum Balance 60W Clone TC VW Vape Box Mod Original Price $199.99, Now Only $179.99.
The Stratum Balance clone 60W TC VW Vape Box Mod is made from JUMA and Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The Box Mod is Compatible with 24mm diameter vape atomizer. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output.
Original SMOKTech SMOK Fortis 80W VW Box Mod - VW 5~80W, 1 x 18650 / 21700 Original Price $49.99, Now Only $38.99.
The original SMOKTech SMOK Fortis 80W VW Box Mod features elegant leather and ergonomic design, easy to grip. SMOK Fortis box mod is powered by single 18650 / 21700 battery (not included) with adjustable wattage of 5~80W output. SMOK Fortis 80W Mod adopts smart chipset with 0.001s firing speed and 0.96 inch TFT color screen with 6 theme colors for options.
Original Eleaf Mini iStick 2 VW Variable Wattage Vape Box Mod - 1050mAh, VW 1~25W Original Price $44.99, Now Only $29.99.
The original Eleaf Mini iStick 2 VW vape box Mod comes in the smallest size. The Manual and Auto mode in one mod; Freely choose your vaping clone between button-activated and draw-activated mechanisms. notice: Draw-activated mechanism only works with GS Air 4 Tank (not included). Comes with smart coil protection, the device will stop output when it detects a lack of e-liquid, protecting the coil from the dry hit. Mini iStick 2 also provides VW (Variable Wattage) or VV (Variable Voltage) mode. Just choose the mode you are most accustomed to. With USB Type-C 2A quick charge, only about half an hour is required to fully charge the internal 1050mAh battery of Mini iStick 2. Mini iStick 2 mod provides Over-charge / Over-discharge / Over-current / Over-time and Short Circuit protections.
Simurg SX RTA Replacement Tank Shield Maze Silber Clone - Silver, Stainless Steel Original Price $6.99, Now Only $3.99.
The Simurg SX clone RTA Replacement Tank Shield Maze Silber is made from Stainless Steel.
Original Auguse Seaman 510 Drip Tip for RDA / RTA / RDTA Vape Atomizer Original Price $7.99, Now Only $5.99.
The original Auguse FOTO 510 Drip Tip is made from Stainless Steel + Delin and is suitable for RDA / RTA / RDTA Vape Atomizer.
Original Auguse FOTO 510 Drip Tip for RDA / RTA / RDTA Vape Atomizer Original Price $7.99, Now Only $5.99.
The original Auguse FOTO 510 Drip Tip is made from Stainless Steel and is suitable for RDA / RTA / RDTA Vape Atomizer.
Original Hellvape Fat Rabbit RTA Replacement Glass Tank Tube - Transparent, 5.5ml Original Price $3.99, Now Only $2.59.
The Glass Tube is designed for Hellvape Fat Rabbit RTA vape atomizer. It holds 5.5ml capacity.
Старый 13.07.2021, 06:53 Автор темы   123
3FVAPE
Taifun GT III 2021 GT 3 RTA Clone Rebuildable Tank Vape Atomizer - Silver, 316SS + Glass, 5.0ml, 23mm Diameter Original Price $29.5, Now Only $24.99.
The Taifun GT III (GT3) Style RTA is a Rebuildable Tank Vape Atomizer with a incredible flavor production, glass tank, stainless steel shield for the glass, adjustable air flow, adjustable juice flow, and 5.0ml liquid capacity. This 2021 version of the Taifun GT III Style RTA is identical to the original version from 2016, with a slight change to the insulator.
Taifun GT III 2021 GT 3 Clone RTA Replacement XS Tank Nano Kit - Silver, 316SS + Glass, 2.8ml Original Price $12.9, Now Only $9.99.
The Taifun GT III 2021 GT 3 Style RTA Replacement XS Tank Nano Kit is made from 316 Stainless Steel + Glass and holds 2.8ml capacity.
Старый 14.07.2021, 10:46 Автор темы   124
3FVAPE
Original Eleaf IORE LITE Pod System Vape Starter Kit - 350mAh, 1.6ml, 1.2ohm Original Price $14.99, Now Only $9.99.
The original Eleaf IORE LITE Kit is different from the previous IORE disposable series, it is compatible with pre-filled pods (not included) and open pods. The rubber shell of IORE LITE Kit is soft and comfortable to the touchand weighs only 25g. It combines a refillable replaceable pod and a rechargeable battery in a minimalist design so that it is easy to grip and carry.
Original Eleaf IORE Lite Empty Replacement Pod Cartridge - 1.6ml, 1.2ohm (2 PCS) Original Price $8.99, Now Only $6.99.
Original Eleaf IORE Lite Pod Cartridge is suitable for Eleaf IORE Lite Kit, have a capacity of 1.6ml, built-in 1.2ohm Kanthal coil, which makes every puff of vaping you breathe smooth and pure. The empty pod adopts a side filling design, and you can inject your favorite e-liquid by opening the silicone plug; Fasten the silicone plug tightly after 2/3 fully filling, which can perfectly prevent leakage.
Старый 15.07.2021, 15:40 Автор темы   125
3FVAPE
Original SMOKTech SMOK TFV18 Mini Tank Vape Atomizer - 6.5ml, 0.15 / 0.2ohm Mesh Coil, 28mm Diameter Original Price $38.99, Now Only $25.99.
The original SMOKTech SMOK TFV18 Mini Tank features a 6.5mL tank tube capacity with a top-fill system for simple to use. Utilized the meshed coil to spreads the heat over a wider area on the cotton for the beast cloud and beauty flavor. TFV18 MINI vape atomizer is constructed from durable stainless steel, the 28mm diameter can fits on most box mods.
Replacement Front + Bottom Panel Plate for Aspire Boxx Mod Kit Original Price $20.99, Now Only $14.99.
The Replacement Front and Bottom Panel Plate is made from acrylic and is suitable for Aspire Boxx Mod Kit. 2 PCS / Pack. One Front Panel Plate / One Bottom Panel Plate
Original SMOKTech SMOK TFV18 Mini Tank Replacement Coil Original Price $14.99, Now Only $11.99.
The SMOKTech SMOK TFV18 Mini Tank Replacement Meshed Coil is suitable for SMOK TFV18 Mini Tank Vape Atomizer. The Dual Meshed Coil is in 0.15ohm resistance and suitable for 80W~110W, Best at 90W. The Meshed Coil is in 0.2ohm resistance and suitable for 40~80W, best 60W. The Meshed Coil is in 0.33ohm resistance and suitable for 80W~140W, Best at 100W~110W.
Original SMOKTech SMOK TFV18 Mini Tank Replacement RBA Coil Head Original Price $14.99, Now Only $9.99.
The original SMOKTech SMOK TFV18 Mini Tank Replacement RBA Coil Head is made from stainless steel and comes with 1 PC / Pack.
Старый 19.07.2021, 06:45 Автор темы   126
3FVAPE
VG Kronos 2 S 2021 Clone RTA Rebuildable Tank Vape Atomizer - 23mm Diameter, RDL / MTL, 4.5ml Original Price $26.99, Now Only $21.99.
The VG Vapor Giant KRONOS 2 S Clone RTA is 23mm diameter and can be used with a restrictive DTL or in MTL, it is equipped with a 4.5ml tank. The Kronos 2S Clone RTA is designed Made of 316 stainless steel and polycarbonate, The optics of the KRONOS 2S 2 S Clone RTA are just as versatile as the airflow. A second polycarbonate tank protection and a second polycarbonate MTL end cap are included. For this rebuildable of simple construction, with a single coil resistance plate, the air circulates directly on the side of the coil, no matter if you go from an airflow for the DTL of 4 x 1.8 mm or those of 2 x 0.8mm for MTL. The Kronos 2S Clone RTA thus guarantees silent air intake and intense flavor. The liquid supply will be in the upper part (top cap) to prevent accidental opening and emptying.
510 Drip Tip for RDA / RTA / RDTA Vape Atomizer Original Price $2.99, Now Only $1.99.
The replacement 510 Drip Tip is suitable for RDA / RTA / RDTA Vape Atomizer. The Stainless Steel base and the PEI mouthpiece can take off.
Original Auguse Coil Jig for RDA / RTA / RDTA Coil Building - Silver, 316SS, 2.0mm / 2.5mm / 3.0mm (3 PCS) Original Price $10.99, Now Only $7.99.
The Original Auguse coil jig new set is made from 316 stainless steel;, has Multifunctional design. It can build 2.0mm coil, 2.5mm coil and 3.0mm coil. The one side is with Slotted screwdriver and the other side with Phillips screwdriver and thread.
Original Auguse Era Pro RTA Replacement Top Cap Gear Shape Original Price $7.99, Now Only $4.99.
The Original Auguse Era Pro RTA Vape Atomizer Replacement Top Cap is with Gear Shape new design. It is easier to take off.
Original Auguse Era Pro RTA Replacement Nano Tank Kit 316SS + Glass, 2.0ml Original Price $8.99, Now Only $5.99.
The Original Auguse Era Pro RTA Replacement Nano Tank Kit is made from 316 stainless steel and Glass with 2.0ml capacity. This Nano Tank Kit will switch your Auguse Era Pro RTA Vape atomizer into Nano Version.
Original Auguse Era Pro RTA Nano Replacement Glass Tank Tube - Transparent, 2.0ml Original Price $2.99, Now Only $1.49.
The Original Auguse Era Pro RTA Nano Replacement Glass Tank Tube holds 2.0ml capacity. It is suitable for Auguse Era Pro RTA Nano Kit.
Original Auguse Era Pro RTA Replacement Decorative Ring - Anodized Aluminum, 22mm Diameter (1 PC) Original Price $4.99, Now Only $2.99.
Original Auguse Decorative Ring is made of anodized aluminum, designed for Auguse Era Pro RTA Rebuildable Tank Vape Atomizer. 1 PC / Pack
Старый 20.07.2021, 10:45 Автор темы   127
3FVAPE
Original Steam Crave Mini Robot RTA Rebuildable Tank Vape Atomizer Original Price $46.99, Now Only $36.99.
Original Steam Crave Mini Robot RTA is a rebuildable tank atomizer for MTL vaping. It has two types of capacity: 2.0ml (straight glass) or 3.0ml (bubble glass). It is easy to build with single coil deck. And you will enjoy different and great vaping experience with various air pins options and top airflow design.
Original Rincoe JellyBox 228W VW Vape Box Mod + Metis RDA V2 Kit Original Price $69.99, Now Only $52.99.
Original Rincoe Jellybox 228W RDA Vape Kit consists of Rincoe Jellybox 228W vape box mod and Metis RDA V2 vape atomizer.Rincoe Jellybox 228W Kit is constructed of transparent PC cover and Zinc alloy frame with visually stunning aesthetic. Rincoe Jellybox 228W mod features 6 LED lights and shine through into the full device. Rincoe Jellybox box mod is powered by dual 18650 batteries (not included) with max 228W output. Rincoe Jellybox mod can support VW / TC (Ni200 / Ti / SS) modes to meet different needs.
Original Rincoe JellyBox Mini 80W Box Mod + Metis RDA V2 Vape Kit Original Price $59.99, Now Only $49.99.
The Original Rincoe Jellybox Mini 80W Vape Kit is composed of Rincoe Jellybox Mini 80W vape box mod and Metis RDA V2 vape atomizer. Rincoe Jellybox Mini 80W mod is made of transparent PC cover and Zinc alloy frame with visually stunning aesthetic. Rincoe Jellybox Mini 80W box mod features 6 LED lights and shine through into the full device. Rincoe Jellybox Mini box mod is powered by single 21700 / 20700 / 18650 battery (not included) with max 80W output. Rincoe Jellybox mini can support VW / TC (Ni200 / Ti / SS) modes to meet different needs.
Original SMOKTech SMOK Nord 50W Pod System Kit - Regular Version Original Price $46.99, Now Only $35.99.
The Original SMOKTEch SMOK Nord 50W Pod System Vape Kit continues the superior and stable performance of the SMOK NORD Pod Mod, it comes with an internal 1800mAh battery that brings you up to 50W of power to your satisfaction. The 1800mAh built-in battery brings long-lasting life, the Type-C 1.2A maximum charge current makes fast charging stable and more efficient. Up to 50 watts of horsepower can easily handle all of your vaping needs, ensuring worry-free vaping all day long. The flashing frequency of the white LED light can show various function protections and tell you the status of the device.
Original SMOKTech SMOK Nord 50W Pod System Vape Kit - Leather Version Original Price $46.99, Now Only $35.99.
Four One Five 415 S61 Genesis Atomizer Clone RDTA Rebuildable Dripping Tank Atomizer Original Price $29.99, Now Only $21.99.
The Four One Five 415 S61 Genesis Atomizer Clone RDTA Rebuildable Dripping Tank Atomizer is constructed from stainless steel and PEI tank tube. The 22mm RDTA is designed for dry flavor, hard throat hit. The Four One Five S61 Genesis Atomizer Clone RDTA is with single coil building and airflow adjustable.
Original Steam Crave Mini Robot RTA Replacement Single Coil Build Deck Original Price $9.9, Now Only $7.99.
The Original Steam Crave Single Coil Build Deck is made from stainless steel and suitable for Mini Robot RTA vape atomizer.
Original SMOKTech SMOK Nord 50W Pod System Replacement LP2 Empty Pod Cartridge for LP2 Series Coil -4.0ml (3 PCS) Original Price $8.99, Now Only $5.99.
The SMOK Nord 50W Replacement Empty Pod Cartridge is designed for the SMOK Nord 50W Pod System Vape Kit. The Nord 50W 4.0ml LP2 Pod cartridge is Compatible with LP2 Series Coil (coils not included). They both combine with a side-fill system to minimize the possibility of e-juice leakage
Original SMOKTech SMOK Nord 50W Pod System Replacement Nord Empty Pod Cartridge for Nord Series Coil -4.5ml (3 PCS) Original Price $8.99, Now Only $5.99.
The SMOK Nord 50W Replacement Empty Pod Cartridge is designed for the SMOK Nord 50W Pod System Vape Kit. The Nord 50W 4.5ml Nord Pod cartridge is Compatible with Nord Series Coil (coils not included). They both combine with a side-fill system to minimize the possibility of e-juice leakage.
Original SMOKTech SMOK Nord 50W Pod System Replacement RPM Empty Pod Cartridge for RPM Series Coil -4.0ml (3 PCS) Original Price $8.99, Now Only $5.99.
The SMOK Nord 50W Replacement Empty Pod Cartridge is designed for the SMOK Nord 50W Pod System Vape Kit. The Nord 50W 4.0ml RPM Pod cartridge is compatible with RPM Series Coil (coils not included). They both combine with a side-fill system to minimize the possibility of e-juice leakage.
Старый 21.07.2021, 06:15 Автор темы   128
3FVAPE
Original Steam Crave Mini Robot Tube Mod - 1 x 18650, Semi-Mechanical Original Price $39.9, Now Only $32.99.
Steam Crave Mini Robot Vape mechanical tube Mod is made of durable stainless steel with elegant finishing in tiny size, with CNC engraving and corrosion craftsmanship, making it more exquisite. Powered by a single 18650 battery (not included), Steam Crave Mini Robot Kit with a LED light indicator to remind you of the state of your device. And It supports 3 output levels: 3.5V, 3.8V, and 4.2V max power. Equipped with a proprietary waterproofed chipset, the MINI ROBOT TUBE is resistant to leaking e-Juice or those that are prone to accidents.
Original Steam Crave Mini Robot MTL Kit Mini Robot Tube Mod + MTL RTA Kit Original Price $89.99, Now Only $61.99.
Steam Crave Mini Robot Vape Mod Kit is a specialized portable device for MTL vapers. Made of durable stainless steel with elegant finishing in tiny size, with CNC engraving and corrosion craftsmanship, making it more exquisite. Powered by a single 18650 battery (not included), Steam Crave Mini Robot Kit with a LED light indicator to remind you of the state of your device. And It supports 3 output levels: 3.5V, 3.8V, and 4.2V max power. Equipped with a proprietary waterproofed chipset, the MINI ROBOT TUBE is resistant to leaking e-Juice or those that are prone to accidents. The diameter of the 23mm deck with a Single coil design, with a wide deck platform, makes building simple! There are two glass tubes with different capacities for replacement, 2.0ml and 3.0ml. The change of flavor is achieved through the top airflow adjustment, and the built-in ultra-fine air pins are used to adjust the airflow size to more accurately realize the delicious atomization conversion. Screw the refill top cap off, and drip it into the tank from the 4 refill holes, the silicone plugs can avoid leakage problems.
Original Kamry Epipe Vape Mod Kit - Wood Grain, 900mAh, 2.8ml, 0.5ohm Original Price $59.99, Now Only $44.99.
The Original Kamry VapingGT GT EPIPE is a unique design epipe vape, comes with 900mAh battery, with PCTG + Resin material, atomizer is 2.8ml capacity with resistance 0.5ohm.
Original Kamry GT Epipe Mod - Wood Grain, 900mAh Original Price $49.99, Now Only $33.99.
The Original Kamry VapingGT GT EPIPE is a unique design epipe vape, comes with 900mAh battery, with PCTG+ Resin material.
Original Kamry GT E-Pipe Tank Atomizer - 2.8ml, 0.5ohm Original Price $14.99, Now Only $11.99.
The Kamry VapingGT GT EPIPE is a unique design pipe vape, atomizer is 2.8ml capacity with resistance 0.5ohm.
Original Kamry GT Epipe Coil Head for GT Epipe Kit / Pod Cartridge Atomizer - 0.5ohm (5 PCS) Original Price $12.99, Now Only $8.99.
The GT Epipe Coils are perfectly compatible with Kamry GT Epipe Kit / Pod Cartridge Atomizer. The resistance is 0.5ohm and is suitable for 5W to 40W.
Старый 22.07.2021, 13:17 Автор темы   129
3FVAPE
Original GeekVape Obelisk C Cerberus Tank Sub Ohm Tank Original Price $27.9, Now Only $24.99.
Original GeekVape Obelisk C Tank is the incredible Cerberus Sub Ohm Tank with 25mm base diameter. Designed with an adjustable tri-slotted bottom airflow ring to control the inflow of air, it will create thicker vapor or richer flavor production. The knurled and threaded top cap design makes top filling system leak-proof and convenient. Obelisk C Tank has 5.5ml capacity with a bubble glass tube or 4ml capacity with a regular glass tube. There are new GeekVape S Series Coil for Obelisk C Tank: single mesh 0.15ohm coil (80~90W), and dual mesh 0.25ohm coil (45~55W).
Original GeekVape S Series Mech Coil for Obelisk C Tank Original Price $15.9, Now Only $13.99.
The Original GeekVape S Series Single mesh Coil is super mesh coil and compatible with GeekVape Obelisk C Cerberus Tank vape atomizer. The single mesh coil is 0.15ohm (80~90W). The coil will bring you massive clouds and flavor.
Original UD Youde Diagonal Pliers V2 for Coil Building Original Price $10.99, Now Only $6.99.
The Original UD YouDe diagonal pliers is specially designed for installing atty coils, which can cut coils close to the post holes. It will make the DIY easier.
Original BP MODS Vape Tool Kit - Flat Head Screwdriver, Philip's Head Screwdriver, Hex Screwdriver, Coiling Pole, Cotton Hook Original Price $19.99, Now Only $14.99.
The Original BP Mods Kit Vape Tool Pro is required for rebuildable material. There is a space in the Kit for your own pair of folding scissors. All the tools can fit in trunk of Futon Ohm Tab (not included). Package including: 1 x Flat Head Screwdriver SL2.0, 1 x Flat Head Screwdriver SL3.0, 1 x Philip's Head Screwdriver PH00, 1 x Hex Screwdriver H1.5, 1 x Hex Screwdriver H2.0, 1 x Coiling Pole 2.0, 1 x Coiling Pole 2.5, 1 x Coiling Pole 3.0, 1 x Hook for cotton combing, 1 x Handle
Original Steam Crave Mini Robot RTA Replacement Drip Tip Original Price $5.99, Now Only $3.99.
The Mini Robot Drip Tip is designed especially for the Steam Crave Mini Robot RTA Vape Atomizer.
Original Steam Crave Mini Robot RTA Replacement Straight Glass Tube Original Price $5.99, Now Only $3.99.
Original Steam Crave Mini Robot Replacement Straight Glass Tube is designed for Steam Crave Mini Robot MTL RTA 23mm. Holds 2.0ml capacity and comes with 2 PCS / Pack.
Original Steam Crave Hadron Pro DNA250C Box Mod Replacement Genuine Leather Case Original Price $25.99, Now Only $22.99.
The Original Steam Crave Hadron Pro Genuine Leather Case is designed especially for the Hadron Pro DNA250C Mod, Hadron Pro DNA250C Kit.
ULTON Peek Chamber Reducer for Original Flash E Vapor V4 / V4.5S / V4.5S+ / ULTON Fev V4.5S+ / YFTK Fev V4.5S+ - Brown (1 PC) Original Price $9.99, Now Only $7.99.
The ULTON Peek Chamber Reducer is suitable for Original Flash E Vapor V4 / V4.5S / V4.5S+ / ULTON Fev V4.5S+ / YFTK Fev V4.5S+ RTA Vape atomizer. The Chamber reducer is for intense flavor.
SXK Delro Style AIO Mod Kit Replacement Battery Pack - 2200mAh, 3.7V Original Price $18.9, Now Only $14.9.
The Battery Pack is with 2200mAh capacity and 3.7V voltage. It is suitable for SXK Delro Style 60W / 70W AIO Mod Kit.
Старый 23.07.2021, 06:37 Автор темы   130
3FVAPE
Original DEJAVU Pocket 40W AIO Pod System Vape Starter Kit - Chrome Version, 5~40W, 950mAh, 2.0ml, 0.6ohm / 1.0ohm Original Price $51.9, Now Only $48.99.
DEJAVU DJV Pocket 40W AIO Kit with 2.0ml capacity cartridge adopts side filling system with lateral triple air slots, easy for operation. This is the special Chrome Version with Zinc Alloy + PCTG
Coilturd RDA Clone Rebuildable Dripping Vape Atomizer w/ BF Pin / AFC Ring - Single / Dual Coil Configuration, 24mm Dia Original Price $11.99, Now Only $8.99.
Coilturd Clone RDA Rebuildable Dripping Vape Atomizer in 24mm diameter features optional single or dual coil configuration and comes with 2 x AFC rings with different airflow, meeting your different vaping demands. With 510 threading connection, Coilturd Clone RDA is suitable for most of your favorite mods, like Mechanical Mod, BF Squonker and other box mod.
Flash-e-Vapor FEV BF-1 Clone RDA Rebuildable Dripping Atomizer w/ BF Pin - 23mm Diameter Original Price $12.99, Now Only $9.99.
The Flash-e-Vapor FEV BF-1 Clone Squonker RDA is constructed from stainless steel and with 23mm diameter. The single coil RDA comes with bottom feeder pin for squonker mod. The Squonker RDA comes with various airflow screw pin for different vaping experience.
510 Drip Tip w/ Spare Mouthpieces for RDA / RTA / RDTA Vape Atomizer Original Price $6.99, Now Only $4.99.
The 510 Drip Tipis with stainless steel 510 base and 3 PCS Spare Mouthpieces (PEI / POM / PC). It is suitable for RDA / RTA / RDTA Vape Atomizer.
Long 510 Drip Tip for dotMod dotAIO Vape Pod System / RDA / RTA / RDTA Vape Atomizer Original Price $3.99, Now Only $2.59.
The Long 510 Drip Tip is made from PMMA and suitable for dotMod dotAIO Vape Pod System and other RDA / RTA / RDTA Vape Atomizer with 510 drip tip connector.
Short 510 Drip Tip for dotMod dotAIO Vape Pod System / RDA / RTA / RDTA Vape Atomizer Original Price $3.99, Now Only $2.59.
The short 510 Drip Tip is made from PMMA and suitable for dotMod dotAIO Vape Pod System and other RDA / RTA / RDTA Vape Atomizer with 510 drip tip connector.
Replacement Button for dotMod dotAIO Vape Pod System Original Price $2.99, Now Only $1.49.
The Replacement fire button is made from PMMA and is suitable for dotMod dotAIO Vape Pod System. 1 PC / Pack
Старый 24.07.2021, 10:28 Автор темы   131
3FVAPE
Original Yachtvape x Mike Vapes Eclipse RTA 24mm Rebuildable Tank Atomizer Original Price $38.99, Now Only $32.99.
The Eclipse single coil RTA is a collaboration between Mike Vapes and YachtVape. RTA was designed to be a small stealthy RTA that creates great flavor. Recurve Clone build deck with smooth honeycomb airflow. The 24mm diameter RTA comes with straight glass is 2.0ml and 3.5ml with bubble glass.
ULTON Hussar Gobby RTA Clone 22mm Rebuildable Tank Atomizer Original Price $35.9, Now Only $31.5.
ULTON Hussar Gobby Clone RTA Rebuildable Tank Atomizer is constructed from 316 stainless steel in 22mm diameter and holds 4.5ml capacity. The Gobby Clone RTA supports Interchangeable angle-adjustable airflow, you can change the way the air hits the coil. The atomizer supports juice flow control: Fully Open, Fully closed for leakproof filling.
Original Vaporesso XROS Mini Pod System Kit Original Price $27.99, Now Only $18.99.
Original Vaporesso XROS MINI Pod System Kit provides the best MTL vaping experience. Comes with a compact and portable design, the luxury diamond pattern surface gives it a prestigious look and it is great non-slip and overall feeling in hand. XROS MINI Kit has a built-in 1000mAh battery that provides a significant improvement for the XROS MINI and can offer nearly 2 days without recharging and supports 5V / 1A Type-C fast charging.
Penon V2 Clone 60W VW Box Mod 1~60W, 1 x 18650 Original Price $89.99, Now Only $69.99.
The Penon V2 Clone 60W VW Vape Box Mod is made from Delrin and 316 Stainless Steel. The Penon V2 Clone Box Mod is powered by 60W chipset supports variable wattage from 1W to 60W. The Penon V2 Clone Box Mod is powered by 1 x 18650 battery (not included) and supports maximum 22mm diameter atomizer.
Original KoguoVape Flow Rate Control Kit for Flash-e-Vapor Fev V4.5S+ / V4.5 RTA Original Price $18.99, Now Only $14.98.
Flow Rate Control Kit for Flash-e-vapor V4.5S+ RTA & Flash-e-vapor V4.5 RTA is made from 316 stainless steel body and PEI Tank tube / PC Tank tube. The e-liquid control switch made by PEEK, it can control the flow rate of e-liquid, the tank can be completely closed and it's easy to remove the deck to change the coil. It is suitable for Original Flash E Vapor Fev V4.5S+ RTA / Flash e vapor V4.5 RTA (and the Clone Flash E Vapor Fev V4.5S+ RTA / Flash e vapor V4.5 RTA 1:1 made)
Original KoguoVape Flow Rate Control Kit Replacement Tank Tube for for Flash-e-Vapor Fev V4.5S+ / V4.5 RTA Original Price $8.99, Now Only $6.98.
The Replacement Tank is suitable for Original KoguoVape Flow Rate Control Kit and used for Flash-e-vapor Fev V4.5S+ RTA / Flash-e-vapor V4.5 RTA Vape Atomizer.
Original Vaporesso XROS Mini Replacement Pod Cartridge - 2.0ml, 1.2ohm (2 PCS) Original Price $12.99, Now Only $5.99.
The XROS Mini Pod Cartridge holds 2.0ml capacity and with 1.2ohm coil, is designed especially for the Vaporesso XROS Mini Pod Kit.
Старый 27.07.2021, 09:18 Автор темы   132
3FVAPE
Original Joyetech Vaal 5000 Pod Kit System Vape Starter Kit - 570mAh, 12ml, 1.2ohm Original Price $20.99, Now Only $16.99.
Original Joyetech Vaal 5000 Pod System Vape Starter Kit is fully analyzing and taking into account the needs of users, attentively incorporating the rechargeable and refillable designs to reduce the waste of kits. The Joyetech Vaal 5000 Pod System Kit also has a huge battery capacity which can reach up to 570mAh, providing you with superlong standby time. At the same time, Joyetech Vaal 5000 Pod System Kit also has an unusual e-liquid filling space, and it has a 12.0ml pod capacity per device to ensure and meet your daily smoking needs. The Joyetech Vaal 5000 Pod System Kit also comes with patented COP technology and superior quality Mesh Coil to bring you the excellent and purest enjoyment when you are vaping.
SXK Haku Duet RDA Clone Rebuildable Dripping Atomizer w/ BF Pin - 316SS, 22mm Diameter Original Price $29.9, Now Only $25.9.
The SXK Haku Duet Clone RDA is constructed from 316 stainless steel in 22mm diameter. The SXK Haku Duet Clone RDA is with dual pole design for single coil building. The Duet Clone RDA has an Innovative Airflow control for fine tuning providing desirable and smooth air flow, and astonishing flavor.The RDA comes with bottom feeder / BF / Squonker pin.
Original Lost Vape Ursa Mini 30W Pod Kit - VW 5~30W, 1200mAh, 3.0ml, 0.4ohm / 1.0ohm Original Price $33.99, Now Only $29.99.
The Original Lost Vape URSA Mini 30W Pod System Vape Kit, featuring a 1200mAh built-in battery, 5~30W output range, and utilizes coils from the Lost Vape UB Lite Series (coils not included). Constructed from durable zinc-alloy, the URSA Mini is a compact portable pod system. Below the magnetic pod sits a dual slotted airflow control ring to deliver a controlled flow of air to the center of the coil. Outputting between 5~30W, the URSA Mini Pod Kit makes full use of the 1200mAh battery to deliver outstanding vapor and flavor.
Original Lost Vape Ursa Mini Replacement Empty Pod Cartridge - 3.0ml Original Price $5.99, Now Only $3.99.
The Ursa Mini Empty Pod is suitable for the Lost Vape Ursa Mini Pod System Vape Mod Kit. The pod cartridge is compatible with Lost Vape UB Lite Coil Series (coils not included).
Original Cthulhu Hastur Atomizer Stand Base Holder - Black, PMMA Original Price $14.99, Now Only $12.99.
The Original Cthulhu Hastur Atomizer Stand Base. It is a simple and classic device which can support 18 atomizers (not included). Decorated by the sandblasted surface, the Cthulhu Hastur Atomizer Base is very comfortable to use. Just get it for easy and funny vaping.
Старый 28.07.2021, 17:58 Автор темы   133
3FVAPE
Original Vandy Vape Nox 60W Pod System Kit - VW 5~60W, 1600mAh, 3.0ml / 4.5ml Original Price $34.99, Now Only $29.99.
The original Vandy Vape Nox Pod System Vape Mod Kit is an exquisite, small and durable pod system kit. The mod is built with 1600mAh battery and can fire up to 60W max. USB Type-C charging design makes the charging fast and convenient. Nox Pod Kit comes with two pod cartridges: 4.5ml DL Pod cartridge and 3.0ml MTL pod cartridge. You can rotate the cartridge to adjust the airflow from DL to MTL. Nox Pod is compatible with VVC Coils.
Kontrl V2 Kontrl Mag Clone Front + Back Door Panel Plates w/ Button for dotMod dotAIO Original Price $59.99, Now Only $44.99.
The Kontrl V2 Kontrl Mag clone Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a button for easy operation.
Старый 29.07.2021, 06:35 Автор темы   134
3FVAPE
SXK BB Clone 70W Box Mod Kit w/ USB Port - Orange, 1~70W, 1 x 18650, with 2021 Logo Original Price $85, Now Only $77.99.
The SXK BB Clone Box Mod Kit is constructed from aluminum with an all-in-one design. This mod comes with Nautilus coil adaptor.
SXK BB Clone 70W Box Mod Kit w/ USB Port - Blue, 1~70W, 1 x 18650, with 2021 Logo Original Price $85, Now Only $77.99.
Original Blitz CIO RDA Rebuildable Dripping Atomizer - 25mm Diameter Original Price $29.99, Now Only $23.99.
The Original Blitz CIO RDA Rebuildable Dripping Vape Atomizer is made from stainless steel in 25mm diameter. The RDA is with post-less deck for dual coil configuration.
Original ThinkVape Think Vape Craton DNA 75C Box Mod - 1 x 18650 / 20700 / 21700 Original Price $129.99, Now Only $109.99.
The Original ThinkVape Think Vape Craton DNA 75C Vape Box Mod, constructed of Aluminum Alloy and Stainless Steel, is powered by 1 x 21700 / 20700 / 18650 battery and can fire up to 75W output. ThinkVape Craton DNA 75C mod features DNA 75C Evolv chip and supports multi modes: VW / Kanthal / Nichrome / Ni Fethal 30 / SS430 / SS316 / Titomium / Nickel 200 to meet different needs. The 510 deck is with 26mm diameter for most of vape atomizers.
Original Asvape Vulcan Plus Pod Kit - 700mAh, 5~25W, 3.0ml, 0.7ohm / 1.2ohm Original Price $49.99, Now Only $38.99.
The Original Asvape Vulcan Plus pod system vape starter kit comes with a magnetic art panel structure whose both sides can be quickly disassembled, which is conducive to easy replacement and kinds of Clone. Asvape Vulcan Plus battery device is electroplated stainless steel refining light and shadow mirrors, reproducing outstanding classics. Zinc alloy shapes a rounded body with black and white double color fine and smooth coating. Multi-dimensional OLED displays contribute to intelligent control freely and comprehensive records of various data including output power, lock screen display, resistance display, battery level display. The self-developed REEKBOX chip features a self-check system when powering on, guarding security at all times.
Original Asvape Vulcan Plus Replacement Pod Cartridge - 3.0ml (2 PCS) Original Price $8.99, Now Only $6.99.
The Original Asvape Vulcan Plus Pod System Replacement Pod Cartridge holds 3.0ml capacity and comes with 2 PCS / Pack.
Старый 30.07.2021, 17:44 Автор темы   135
3FVAPE
Original Uwell Aeglos H2 Pod System Kit - 5~60W, 1500mAh, 4.5ml, 0.18ohm / 1.2ohm Original Price $59.99, Now Only $39.99.
Original Uwell Aeglos H2 Pod system Vape Mod Kit is equipped with a 1500mAh large-capacity rechargeable battery and the output power can reach 60W. The chassis is made of durable zinc alloy, it is thin and strong, so it can withstand light drops and is not easily damaged. This pod mod kit has four protection mechanisms, namely Low Power Protection, Over-Temperature Protection, Vaping Overtime Protection, and Short-Circuit Protection. These four protection mechanisms can fully guarantee the safety of the product. You can adjust the airflow through the airflow control ring to achieve the effect you want.
5AVape EVL Wraith RTA Clone Rebuildable Tank Atomizer - Silver, 316SS + PC, 2.0ml, 22mm Diameter Original Price $29.99, Now Only $25.99.
The 5AVape EVL Wraith Clone RTA is made from 316 stainless steel in 22mm diameter and PC tank tube in 2.0ml capacity. The RTA has a single coil deck in dual-post. The opening for the air supply is located between the two posts. The airflow can be adjusted with different inserts, which are enclosed with the tank with the following diameters: 0.8mm, 1.0mm, 1.5mm, 2.0mm, 2.5mm and 3.0mm. The airflow can be adjusted from RDL to MTL. The bottom airflow system is with holes on the underside of the base.
5AVape EVL Wraith RTA Clone Replacement XL Tank Tube Kit - Translucent, PC + 316SS, 7.5ml Original Price $12.99, Now Only $9.99.
The 5AVape EVL Wraith Clone RTA Replacement XL Tank Tube Kit includs PC tank tube and 316 Stainless Steel chimney. The tank tube holds 7.5ml capacity.
5AVape EVL Wraith RTA Clone Replacement XL Tank Tube Section - Brown, PEI, 7.5ml Original Price $9.99, Now Only $6.99.
The 5AVape EVL Wraith Clone RTA Replacement XL Tank Tube Section is made from PEI and holds 7.5ml capacity.
5AVape EVL Wraith RTA Clone Replacement Tank Tube Section - Brown, PEI, 2.0ml Original Price $8.99, Now Only $5.99.
The 5AVape EVL Wraith Clone RTA Replacement Tank Tube Section is made from PEI and holds 2.0ml capacity.
Taifun GT III 2021 GT 3 RTA Clone Replacement Glass Tank Tube - 5.0ml Original Price $2.99, Now Only $1.99.
The Taifun GT III 2021 GT 3 Clone RTA Replacement Glass Tank Tube holds 5.0ml capacity and comes with 1 PC / Pack.
Original Uwell Aeglos H2 Pod System Replacement UN2 Meshed-H Aeglos H2 Coil - 1.2ohm (4 PCS) Original Price $20.49, Now Only $13.66.
The Original Uwell Aeglos H2 UN2 Meshed-H 1.2ohm Aeglos H2 Coil is a mesh coils, designed to improve the flavor of your favorite e-juice. There are 1.2ohm UN2 Meshed-H coils designed for Uwell Aeglos H2 Pod Mod Kit and Uwell Aeglos H2 Empty Cartridge. The 1.2ohm UN2 Meshed-H Coil can enjoy the unique RDL and MTL vaping experience. The feeling of vaping hitting the throat is really good.
Original Uwell Aeglos H2 Replacement Empty Pod Cartridge - 4.5ml Original Price $5.99, Now Only $3.99.
Original Uwell Aeglos H2 Pod Cartridge is designed especially for Uwell Aeglos H2 Pod System Vape Mod Kit. It is used with Uwell Aeglos H2 Replacement Coils (not included). Uwell Aeglos H2 Empty Pod Cartridge has a capacity of 4.5ml and can be easily refilled. Uwell Aeglos P1 Cartridge without coil but it is compatible with the most Uwell Mesh Coils (not included), which enhances the flavor and brings an excellent DTL vaping experience. Using Press-Fit Coil Installation, quite easy and convenient. The powerful magnet at the bottom of the Aeglos H2 Pod ensures a perfect match with the mod. Featuring a bottom refill stoppered by a silicone plug
Старый 05.08.2021, 09:24 Автор темы   136
3FVAPE
Original Wotofo Profile Squonk Mod - VW 5~80W / 5~200W, 1 / 2 x 18650 Original Price $54.99, Now Only $44.99.
Wotofo & Mrjustright1Profile Squonk vape box Mod is an 80W squonk mod, but it can be transformed into a non-squonker which is able to output 200W max power. Just take out the squonk bottle and add an 18650 battery there. So in single battery mode, it is a squonk mod, and in dual battery mode, it is a regular high wattage mod. Easy to switch and easy to use. Equipped with nexCHIP technology, the Profile Squonk Mod has an instant fire speed of 0.001s. And all safety protections are built in. The mod features a simple-to-navigate interface with 6 theme colors, plus fire key lock function, wattage lock function, and 2A fast charging through type-c port. The squonk bottle is 7.0ml in capacity, which is large enough for a long lasting use. It is made of 100% food-grade silicone with leak-proof seal design on the opening. All the solid and click buttons are placed on the mod with ergonomic consideration, comfortable to grip and easy to reach.
PVC Wrappers Skin Sticker for 20700 / 21700 Battery (5 PCS) Original Price $2.99, Now Only $1.69.
The PVC Wrappers Skin Sticker is designed for 20700 / 21700 Batteries. 5 PCS / Pack.
PVC Wrapper Skin Sticker for 18650 Battery (5 PCS) Original Price $2.99, Now Only $1.69.
The PVC Wrapper Skin Sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. 5 PCS / Pack.
PVC Wrappers Skin Sticker for 20700 / 21700 Battery (20 PCS) Original Price $3.99, Now Only $2.29.
The PVC Wrappers Skin Sticker is designed for 20700 / 21700 Batteries. 20 PCS / Pack.
PVC Wrapper Skin Sticker for 18650 Battery (20 PCS) Original Price $3.99, Now Only $2.29.
The PVC Wrapper Skin Sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. 20 PCS / Pack.
Старый 06.08.2021, 12:55 Автор темы   137
3FVAPE
5AVape Paravozz Mini RDTA Clone Rebuildable Dripping Tank Atomizer - 316SS + PEI, 2.0ml, 22mm Diameter Original Price $39.99, Now Only $32.99.
The 5AVape Paravozz Mini clone RDTA Rebuildable Dripping Tank Vape Atomizer is made from 316 stainless steel in 22mm diameter and PEI tank holds 2.0 capacity.
SXK EVL Wraith RTA Clone Rebuildable Tank Atomizer - Silver, 316SS + PC, 2.0ml, 22mm Original Price $24.9, Now Only $23.9.
The SXK EVL Wraith clone RTA is made from 316 stainless steel in 22mm diameter and PC tank tube in 2.0ml capacity. The RTA has a single coil deck in dual-post. The opening for the air supply is located between the two posts. The airflow can be adjusted with different inserts, which are enclosed with the tank with the following diameters: 1.0mm and 2.5mm. The airflow can be adjusted from RDL to MTL. The bottom airflow system is with holes on the underside of the base.
SXK Haku Duet RDA Clone Rebuildable Dripping Atomizer w/ BF Pin - Black, 316SS, 22mm Diameter Original Price $32.9, Now Only $27.9.
The SXK Haku Duet clone RDA is constructed from 316 stainless steel in 22mm diameter. The SXK Haku Duet clone RDA is with dual pole design for single coil building. The Duet clone RDA has an Innovative Airflow control for fine tuning providing desirable and smooth air flow, and astonishing flavor. The RDA comes with bottom feeder / BF / Squonker pin.
SXK EVL Wraith RTA Replacement XL Tank Tube Kit Clone - Brown, PEI + 316SS, 7.5ml Original Price $14.9, Now Only $12.9.
The SXK EVL Wraith clone RTA Replacement XL Tank Tube Kit includes PEI tank tube and 316 Stainless Steel chimney. The tank tube holds 7.5ml capacity.
SXK EVL Wraith RTA Replacement XL Tank Tube Kit Clone - Translucent, PC + 316SS, 7.5ml Original Price $11.9, Now Only $9.9.
The SXK EVL Wraith clone RTA Replacement XL Tank Tube Kit includes PC tank tube and 316 Stainless Steel chimney. The tank tube holds 7.5ml capacity.
SXK EVL Wraith RTA Replacement Tank Tube + Drip Tip Kit Clone - Brown, PEI, 2.0ml Original Price $11.9, Now Only $9.9.
The SXK EVL Wraith clone RTA Replacement Tank Tube and Drip Tip Kit is made from PEI and holds 2.0ml capacity.
SXK EVL Wraith RTA Replacement Air Inserts Clone - Silver, 0.8, 1.2, 1.5, 2.0, 3.0mm (5 PCS) Original Price $6.9, Now Only $5.9.
The SXK EVL Wraith clone RTA Replacement Air Inserts comes with 5 PCS in 5 size: 0.8mm, 1.2mm, 1.5mm, 2.0mm, 3.0mm.
Старый 07.08.2021, 10:56 Автор темы   138
3FVAPE
5AVape Cloud 2 MTL RTA Clone Rebuildable Tank Atomizer - 316SS + PMMA, 3.5ml, 22mm Diameter Original Price $30.99, Now Only $24.99.
The 5AVape Cloud 2 MTL RTA Clone Rebuildable Tank Vape Atomizer is constructed from 316 stainless steel in 22mm diameter and PMMA Tank tube holds 3.5ml capacity. The deck is dual-pole design for single coil building. The air adjustment ring supplies 3 options: each air hole in the ring has a diameter of 1.2mm.
Original Uwell Caliburn A2 Pod System Starter Kit - 520mAh, 2.0ml, 0.9ohm, Draw / Button Activated Original Price $30.99, Now Only $24.99.
Original Uwell Caliburn A2 Pod System vape starter Kit is equipped with a leak-proof top filling system, which can hold 2.0ml nicotine salt or freebase e-juice. Each kit comes complete with two Caliburn A2 refillable pod cartridge that feature mesh coils for better flavor. This kit has a lightweight frame and slim design, very easy to carry. Its maximum wattage output can be up to 15W. The chassis of the Caliburn A2 Pod System encases an integrated 520mAh rechargeable battery that allows you to use it for a long enough time. And You can use it in two modes, automatic and manual.
Original Uwell Caliburn Replacement Refillable A2 Pod Cartridge for Uwell Caliburn A2 / AK2 Kit - 2.0ml, 0.9ohm (4 PCS) Original Price $20.99, Now Only $14.99.
Original Uwell Caliburn A2 Refillable Pod cartridge is designed specifically for Uwell Caliburn AK2 Pod System Kit and Uwell Caliburn A2 Pod System Kit. Uwell Caliburn A2 Refillable Pod cartridge has an e-juice capacity of 2.0ml. Each pod cartridge is refillable and thanks to its top-fill design, you can fill e-juice at any time. 0.9ohm Pod Coil can provide a slightly warmer vaping experience for you because it does have lower coil resistance and the device will output more wattage.
Старый 10.08.2021, 12:30 Автор темы   139
3FVAPE
Original YouDe UD Kanthal Prebuilt Coils Wire for RDA / RTA Vape Atomizer - 24GA,0.5ohm (10 PCS) Original Price $5.99, Now Only $3.99.
The original YouDe UD Kanthal Prebuilt Coils comes with 24GA, 0.5mm in diameter for each Kanthal wire. It is perfectly wrapped and manufactured with 0.5ohm. Users can use it directly on RDA or RBA.
Original Coilology MTL Clapton Ni80 Spool Wire - 28GA / 40GA, 5.2ohm/ft, 10ft Original Price $7.99, Now Only $4.99.
original Coilology Prebuilt Wire MTL Spools features an intuitive way to experiment with exotic coil configurations, featuring distinctive build structures for an advanced rebuildable experience. It is packed in a roll of 10 Feet with the utilization of Nichrome 80 heating elements, designed with fast ramp-up time and long-lasting capability. It comes in a plethora of options, ranging from, Fused, Framed, and Clapton styles, all specially machine-twisted for a precise weave and high consistency throughout each spool.
Original ZQ ZEST Quest INR18650 3000mAh 40A Flat Top Li-ion Rechargeable Battery - (2 PCS) Original Price $18.99, Now Only $14.99.
The original ZQ ZEST Quest INR18650 3000mAh 40A Flat Top Li-ion Rechargeable Battery is suitable mechanical mod / VW Box Mod. 2 PCS / Pack
Original Wotofo Profile Squonk Mod Replacement Bottom Feeder Bottle - 7.0ml (1 PC) Original Price $8.99, Now Only $4.99.
The Wotofo Profile Squonk Mod Replacement Bottom Feeder Bottle is with 7.0ml capacity, which is large enough for a long lasting use. It is made of 100% food-grade silicone with leak-proof seal design on the opening.
Старый 11.08.2021, 09:50 Автор темы   140
3FVAPE
Original Digiflavor S G MTL Tube Kit - S Tube Mod + Siren G MTL Tank, 1 x 18350 / 18650, 4.0ml, 1.2 / 1.8ohm Original Price $49.99, Now Only $38.99.
The original Digiflavor S G MTL Tube Vape Mod Kit is composed of S Tube Mod and Siren G MTL Tank. Digiflavor S Tube Mod is first tube mod with accidental press protection. Digiflavor S Mod is powered by single 18650 / 18350 battery (not included) for whole day vaping. And Digiflavor S features 3-level adjustable power output. Digiflavor Siren G MTL Tank has 4.0ml capacity with top filling design and leakproof top cap. Siren G MTL Tank features linear precise airflow control with stealthy airflow inlet to support MTL & RDL vaping. Its 22mm anti-lock deck is compatible with GeekVape G series coils (not included), G1.8 coil and G1.2 s coil included.
Original GeekVape M100 Aegis Mini 2 Box Mod + Z Nano 2 Tank Starter Kit - 2500mAh, 3.5ml / 2.0ml, 0.2 / 0.6ohm Original Price $88.8, Now Only $59.99.
The original GeekVape M100 Aegis Mini 2 Starter Kit consists of GeekVape M100 mod and Geekvape Z Nano 2 Tank. GeekVape M100 box mod is a IP68 rated tri-proof mod with 2500mAh built-in battery and max 100W wattage. GeekVape M100 features A-lock for accidental press protection and can show clear vaping data by 1.08-inch full Screen. M100 mod supports VW / VPC / Bypass / Stealth modes to meet different vapers' needs. GeekVape Z Nano 2 Tank utilizes direct top airflow and top-to-bottom airflow for massive flavor. GeekVape Z Nano 2 Tank has 3.5ml capacity (2.0ml replacement tube included) with top filling design and compatible with GeekVape B series coil (not included).
Original GeekVape S100 Aegis Solo 2 Box Mod + Z Sub-ohm 2021 Tank Starter Kit - 1 x 18650, 5.5ml, 0.2 / 0.25ohm Original Price $81.6, Now Only $57.99.
The original GeekVape S100 (Aegis Solo 2) Starter Kit consists of GeekVape S100 mod and GeekVape Z Sub-ohm 2021 Tank with smaller and lighter.
GeekVape S100 box mod, as a tri-proof mod, is powered by single 18650 battery (not included) with max 100W wattage. GeekVape S100 features A-lock for accidental press protection and can show clear vaping data by 1.08-inch TFT Screen. S100 mod supports VW / VPC / Bypass / Stealth modes to meet different vapers' needs. GeekVape Z 2021 Tank utilizes direct top airflow and top-to-bottom airflow for massive flavor. GeekVape Z Sub-ohm Tank has 5.5ml capacity with top filling design and compatible with GeekVape Z series coil (not included).
Original GeekVape Z Nano 2 Sub Ohm Tank Atomizer - 3.5ml / 2.0ml, 0.6ohm / 0.2ohm, 22mm Diameter Original Price $25, Now Only $21.99.
The original GeekVape Z Nano 2 Tank utilizes direct top airflow and top-to-bottom airflow for massive flavor. GeekVape Z Nano 2 has 3.5ml capacity (2.0ml replacement tube included) with top filling design. And Z Nano 2 Tank is compatible with GeekVape B series coil (not included).
Original Vaporesso XROS 2 16W Pod System Starter Kit - 1000mAh, 2.0ml, 0.8ohm / 1.2ohm Original Price $32.99, Now Only $26.99.
The original Vaporesso XROS 2 Pod System vape starter kit is equipped with a 1000mAh large capacity battery and is compatible with Mesh and regular Pod cartridge. You can activate this pod system kit by drawing or button, which is convenient for you to use at any time and making the XROS 2 pod system ideal for travel or business travelers. The kit is also equipped with a top filling system, which can hold 2.0ml of nicotine salt or free alkali e-juice so that you can enjoy the fun of vaping all day. The kit has a lightweight frame and slim design, which is very easy to carry. And its maximum wattage output can reach 16W, which will definitely bring you an unforgettable vaping experience.
Время генерации страницы 0.40434 секунды с 15 запросами
