Просмотров в теме 288772   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 04.06.2018, 05:15 Автор темы   121
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Pandora Hybrid Mechanical Mod Clone $26.99
The Pandora Mechanical Mod Clone is made from brass, powered by single 18650 or 20700 battery (not included). It features hybrid connection and beautiful hollowed out pattern. It comes with a 18650 battery adapter. The fire button is activated by magnets. This item also has other colors to choose.
Original Sigelei Kaos Skycar 230W TC VW Variable Wattage Box Mod $61.99
The Original Sigelei Kaos Skycar box mod is made from Zinc alloy and plastic, designed as advanced car appearance that is full of fashion style. Powered by dual 18650 batteries (not included), the max output power can reach to 230W, which will bring you excellent vaping experience. It supports charging by the included micro USB cable. Besides, the resistance range is from 0.1ohm to 3.0ohm and output voltage range is 1.0~7.5V. It comes with 510 threading connection. This item also has other colors to choose.
Original Fumytech Ballon RDA Rebuildable Dripping Atomizer with BF Pin Original Price $55.90,Now Only $32.99
The Original Fumytech Ballon RDA is a rebuildable dripping tank atomizer with 24mm diameter of deck and 32.7mm outer diameter, made from stainless steel, designed as special football shape is created with the theme of the World Cup. At the base, two large air slots are easy to adjust, ensuring airflow for massive vapor production. Ballon RDA has postless build deck for dual coils, and there are two large holes for air hitting from both sides. It supports oil dripping and also supports bottom squonk feeding with 3.5ml e-liquid capacity, and it's compatible with 810 drip tip.
This RDA comes with bottom feeder pin.
Original Asmodus C4 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.95,Now Only $25.99
The Original Asmodus C4 RDA is a 24mm diameter rebuildable dripping atomizer, with the main chassis being composed of 304 stainless steel, anodized 6063 Aluminum used for the top cap to provide a solid finish that is resistant to chipping and scratching, and a layer of 24K gold-plated on the build deck for a finish that not only offers an elegant accent to this pretty little powerhouse, but maximum conductivity to ensure that this little beast hits as hard as possible. The C4 RDA is a two posts design for easy single building. The 9 individual air inlets is on either side of the sleeve are machined into the body at a slight 25' angle, creating a cyclonic airflow within the chamber that maximizes the area of the coil that is contacted by the incoming air, creating a greater amount of vapor.
It comes with a pre-installed 510 standard pin and bottom feeder pin. This item also has other colors to choose.
Original CoilART Mage SubTank Clearomizer Original Price $28.99,Now Only $21.99
The Original CoilART MAGE SUBTANK is a 24mm clearomizer with 4ml of juice capacity. It has been installed a 0.2ohm Mage Mesh coil to provide smooth and optimal flavor with the bottom airflow system. The top lid comes with knurling design, which makes it easy to be screwed out for refilling. The 510 pin is gold plated, providing great conductivity. 810 drip tip is included. This item also has other colors to choose.
Original Eleaf iJust 3 80W 3000mAh Mod + ELLO Duro Tank Kit New Acrylic Version $48.99
The Original Eleaf iJust 3 Kit New Acrylic Version consists of Eleaf iJust 3 Mod and ELLO Duro Tank. This item also has other colors to choose.
Mod:
The Eleaf iJust 3, a new upgraded version of iJust series, has the most gorgeous looking than ever. Powered by an internal 3000mAh battery, the iJust 3 is capable of firing up to 80 watts. Its intuitive four-color LEDs are for ease of checking battery level. In addition, there are six beautiful colors with three different patterns available for your choice.
Tank:
ELLO Duro, a new member of Eleaf ELLO family, features all-new reimagined Net and Multihole coil technologies which present unprecedented vaping experience with ultra flavorful taste and huge clouds and have a longer lifespan. To fill the tank, you just need to slide the drip tip back to reveal the fill port. The tank has 6.5ml of juice capacity.
Original Eleaf iJust 3 80W 3000mAh Mod + ELLO Duro Tank Kit World Cup Version $44.99
Mod:
Tank:
SXK Billet Box 60W All-in-One Box Mod Kit Clone with USB Port Original Price $129.00,Now Only $104.99
The SXK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip.
This BB Box comes with USB port for firmware upgrading, setting modification and user customization via software. This item also has other colors to choose.
810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.69
The 810 drip tip is made from resin with 14.6mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.69
The 810 drip tip is made from resin with 13mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.89
The replacement 510 drip tip is made from Resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
Original ThunderHead Creations THC Carrying Storage Bag for E-cigarette $26.99
The portable compact storage bag from ThunderHead Creations is used for carrying Electronic Cigarette and DIY Tools. It is very convenient when you go for a travel.
Original CoilART Replacement Mesh Coil Head for Mage SubTank Clearomizer Original Price $9.99,Now Only $7.99
The Original CoilART Mage Mesh Coil features 0.2ohm resistance and works well at 50~90W (best 60~80W). It is suitable for original CoilART Mage SubTank.
This product comes with 3 PCS in 1 pack.
Original CoilART Replacement Coil Head for Mage SubTank Clearomizer Original Price $9.49,Now Only $7.69
The Original CoilART Mage Coil features 0.2ohm resistance and works well at 50~100W (best 60~70W). It is suitable for original CoilART Mage SubTank.
This product comes with 3 PCS in 1 pack. This item also has other Resistance and Wattage range to choose.
Vapeasy Replacement Tank Tube + 510 Drip Tip Kit for Biatch RDTA $2.99
The replacement tank tube and drip tip is made from PEI. The tube is 22mm in diameter and with 1.5ml of juice capacity. The 510 drip tip is 9mm in height.
This product is suitable for original Biatch RDTA and Vapeasy Biatch RDTA Clone.
3FVAPE вне форума   Вверх
Старый 05.06.2018, 04:45 Автор темы   122
3FVAPE
Original Desire Cut 108W TC VW Variable Wattage Squonk Box Mod Original Price $70.00,Now Only $60.99
The Original Desire CUT box mod is powered by single 18650 or 21700 battery (not included) to ensure long lasting power and can be charged via USB port, the max output power can up to 108W. With inside CUT 108W-Chip, it supports variety protection for your safety, such as short circuit / over charging / lom auto lock / low voltage / over vaping protection. The CUT box mod is a squonk mod with installed 7ml capacity juice bottle that can meet your daily vaping need. What's more, it also features 0.96 inch screen display with eye-protecting backlight, which indicates vaping data in a diagonal arrangement. The magnetic battery cover can be removed and installed quickly and simply without loose. It comes with the 510 threading connection. A 18650 battery adapter is included. This item also has other colors to choose.
Original CoilART DPRO Mini RDA Rebuildable Dripping Atomizer with BF Pin $25.99
The Original CoilART DPRO Mini RDA with 22mm diameter is a rebuildable dripping atomizer, made from stainless steel. It features postless design for easy single coil building. There are three honey comb airholes on each side that can be adjusted via rotating top cap, which will bring the smoothest and restricted direct lung feeling for you. What's more, it comes with three different 510 drip tips for various coils, the installed 5mm short one is best for small coils, the extra 8mm height curve one for big coils and 13mm one for MTL style. You can add the e-juice from the top or by squonking, and the inside juice well is deep to meet your large demand.
It comes with a bottom feeder pin. This item also has other colors to choose.
Original 3CVAPE Savour MTL RTA Rebuildable Tank Atomizer Original Price $35.99,Now Only $29.99
The Original Airflow 3CVAPE Savour MTL RTA with 22mm diameter is a rebuildable tank atomizer which bring you mouth-to-lung vaping feeling, made from stainless steel, with 2ml capacity. It features two posts design for easy single coil building. The airflow comes from the bottom of the RTA, featuring a fully adjustable airflow ranging from 1mm to 2.5mm airholes. It comes with 510 threading connection. This item also has other colors to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from stabilized wood and resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors,Material and Height to choose.
810 Color Changing Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
This drip tip will change its original color when being heated and will return to original color after cooling down. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $3.49
The 810 drip tip is made from stabilized wood and resin with 12.6mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Старый 06.06.2018, 04:52 Автор темы   123
3FVAPE
Original Hugo Vapor Ranger GT234 234W TC VW Variable Wattage Box Mod $65.99
The Original Hugo Vapor Ranger GT234 box mod is constructed by its die-casting Zinc alloy frame with many ventilation holes. Powered by dual 18650 batteries (not included), it can fire up to 234W output. It features big RGB LED light button, three control buttons and 2.0inch TFT Color Screen, which are simple to operate and showing vaping details and the remaining battery capacity, supports temperature control, TCR, LED and clock function. It can be charged by included USB cable. It comes with 510 threading connection. This item also has other colors to choose.
Original ALD Amaze Mango 380mAh Pod System Starter Kit $26.99
The Original ALD Amaze Mango pod system starter kit with 2ml capacity is made of Zinc alloy. It's compact shape design and small size make it placed in your pocket simply. Powered by a built-in 380mAh battery, the max output power can reach to 15W. The resistance is 0.8ohm. The leakage-proof top airflow and the 316 stainless steel heating coil with organic cotton will give you better vaping experience. This item also has other colors to choose.
Original Sigelei Snowwolf Mini 100W TC VW Variable Wattage Box Mod + Tank Kit $59.99
The Sigelei Snowwolf Mini Kit consists of Sigelei Snowwolf Mini box mod and Snowwolf Mini tank.
Mod:
The Sigelei Snowwolf Mini box mod is constructed by zinc alloy materials with a 3D modeling wolf logo, and has a strong mechanical exterior for comfortable hand feel and luxury looking. Powered by single 21700 battery (not included), the max output power can reach to 100W. It also supports VW and by pass modes, which will bring you excellent vaping experience.
Tank:
The Sigelei Snowwolf Mini sub ohm tank features dual airflow system for nice flavor and amazing vaping experience. With a transparent tank tube, you can know the e-juice capacity easily.
Original MFT Dark Flow Squonk Mechanical Box Mod + RDA Kit $25.99
The Original MFT Dark Flow kit consists of Dark Flow mechanical box mod and Dark Flow tank. This item also has other colors to choose.
Mod:
The Original MFT Dark Flow box mod is a mechanical mod with bottom feeder bottle. It can be powered by single or dual 18650 battery (not included). When the mod uses single battery, it can work as a squonk mod; When it uses two batteries (take off the bottle and converter head), it can work as a dual-battery mod (not squonk mod). When using two batteries, please put them in series.
Tank:
The Original MFT Dark Flow tank is a rebuildable dripping atomizer with 22 diameter. It has two posts design for single or dual coil building. The airflow comes from the 8.2mm by 1.7mm airhole at the side of tank, which will hit the coil and produce great flavor. It comes with a bottom feeder pin.
810 to 510 Drip Tip Adapter for Kennedy 24 / Goon / Battle RDA $1.99
The 810 to 510 drip tip Adapter is made from resin. With this adapter, you can use the standard 510 drip tip in the Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other colors to choose.
810 Drip Tip for 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 8.4mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other colors to choose.
810 Wide Bore Drip Tip for Kryten / Apocalypse GEN 2 / Battle RDA $1.99
The 810 drip tip is made from resin with 12.7mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Mask RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA, Reload RTA. This item also has other colors and Height to choose.
Original VOOPOO Replacement Refillable Cartridge for Panda Starter Kit $4.59
The Voopoo Panda replacement Pod Cartridge, which is deigned for starter to vape, adopts vertical liquid refilling system to make more air in the device for more perfect cloud and flavor. The 5ml capacity is large enough to meet you daily needs.
Original Wismec Replacement Pod Cartridge for HiFlask Starter Kit with Coil $5.99
The Original Wismec HiFlask Cartridge with coil is perfectly designed for HiFlask Kit with 5.6ml e-juice capacity. It is made of PETG material. It will bring an excellent vaping with optimal flavor and intense cloud. This item also has other Version to choose.
Original Wismec Replacement Jvua Coil Head for HiFlask Pod Cartridge $8.99
The Wismec HiFlask Replacement JUVA Coil Head is designed for the WISMEC HiFlask cartridge. With the resistance of 0.35ohm, it will bring you an amazing vaping experience. Innovative JVUA (Juice Vertical and U Airflow) system is the first application for Wismec e-cigarettes, offering you pure flavor as well as large clouds. It will be a good choice for both MTL and DL enthusasts.
It comes with 5pcs in one pack
Original SMOKTech SMOK Replacement Coil Head for X-Force Starter $7.99
The Original SMOK X-Force Coils is used for SMOK X-Force Starter Kit, The resistance is 0.3ohm.
It comes with 4pcs in one pack
Original SMOKTech SMOK Replacement Coils Head for M17 AIO Starter Kit $10.99
The SMOK M17 Replacement Coils Head is used for SMOK M17 AIO Starter Kit / Priv M17 Kit / SMOK M17 Tank. The resistance is 0.4ohm.
It comes with 5pcs in one pack.
Original Eleaf HW-N Coil Head for iJust 3 Kit / Ello Duro Tank / Pico S Kit / Ello Vate Tank $11.99
The Original Eleaf HW-N Head features a new net coil technology, presenting an ultra flavorful taste with huge clouds and a longer lifespan than ever, made of kanthal. It is used for Eleaf iJust 3 Kit, Ello Duro Tank, Pico S Kit and Ello Vate Tank. The resistance is 0.2ohm and will work well at 40~90 watts.
Старый 07.06.2018, 04:44 Автор темы   124
3FVAPE
Original Modefined Draco 200W TC VW Variable Wattage Box Mod $54.99
The Original Modefined Draco box mod is a mobile-phone-styled box mod, made from Zinc alloy (frame) and G10 (side panels). Powered by dual 18650 batteries (not included), the box mod can fire up from 5W to 200W output power. The large 2.0 full color screen delivers a wide range of information in an organized manner, with a focus on ergonomic user-friendly interface. The smart chipset inside plays high performance which allows you to customize your vaping experience down to your personal preferences. It comes with 510 threading connection. This item also has other colors to choose.
Original VXV X RDA Rebuildable Dripping Atomizer with BF Pin Original Price $38.50,Now Only $25.99
The Original VXV X RDA is rebuildable dripping atomizer with 24mm diameter, made from stainless steel. It has four terminals on 2 posts for dual coils building. It comes with unique slot design that you can adjust the airflow by rotating the gear top cap, which will bring you various vaping flavor.
Original Vapjoy 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The Vapjoy 810 drip tip is made from resin with 15.4mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
One piece will be shipped (random color). More options than what's on the image. This item also has other Height to choose.
Original Vapethink Magic Shark 3M Wrapper Skin Sticker for IQOS $2.99
The Original Vapethink Magic Shark Wrapper Skin Sticker is used for IQOS, made from 3M material. It is designed as 2.5D stereoscopic cover film, which looks more vivid, and you can feel concave-convex when touch it. This item also has other Version to choose.
Original Vapethink Magic Shark IQOS Case Carrying Storage Bag for IQOS $11.79
The Original Vapethink Magic Shark carrying bag is used for holding iQOS, made from high quality PU leather. It features magnetic buckle to close tightly and easily. This item also has other colors and Size to choose.
Original Vapethink Magic Shark IQOS Case Carrying Storage Bag for IQOS with Lanyard $9.99
The Original Vapethink Magic Shark carrying bag is used for holding iQOS, made from high quality full-grain leather. It features magnetic buckle to close tightly and easily. You can hang it around your neck by using included lanyard.
It comes with a lanyard. This item also has other Colors and Version to choose.
Старый 08.06.2018, 05:26 Автор темы   125
3FVAPE
AQUA Origin Mechanical Mod Clone $7.99
The AQUA Origin Mechanical Mod Clone is made from stainless steel, powered by single 18650 battery (not included). The fire button is activated by spring loaded.
Dark Horse Mini RDA Rebuildable Dripping Atomizer Clone $4.99
The Dark Horse Mini RDA Clone is a rebuildable dripping atomizer with 22mm diameter, made from stainless steel. It has three posts for dual coils building. It comes 510 threading connection. Besides, it features airflow control at the bottom of the side by rotating the deck. It comes 510 threading connection. This item also has other Material and colors to choose.
Little Boy RDA Rebuildable Dripping Atomizer Clone $4.99
The Little Boy RDA Clone is a rebuildable dripping atomizer with 22mm diameter, made from stainless steel. It has three posts for dual coils building. Besides, it features airflow control at the bottom of the side by rotating the deck. It comes 510 threading connection.
Bambino RDA Rebuildable Dripping Atomizer Clone $4.99
The Bambino RDA Clone is a rebuildable dripping atomizer with 22mm diameter, made from stainless steel. It has three posts for dual coils building. It comes 510 threading connection.
STRO Mini V2 RDA Rebuildable Dripping Atomizer $4.99
The STRO Mini V2 RDA is a rebuildable dripping atomizer with 22mm diameter, made from stainless steel. It features velocity dual posts for dual coils building. It comes 510 threading connection.
Nuke RDA Rebuildable Dripping Atomizer Clone $5.99
The Nuke RDA Clone is a rebuildable dripping atomizer with 31mm outer diameter and 23mm deck diameter, made from stainless steel. It has four terminals on three posts for dual coils building. It features 2 mini air fans at each side and one is near the drip tip, rotating while vaping, which will bring you excellent vaping experience. It comes 510 threading connection.
Mars RTA Rebuildable Tank Atomizer Clone $6.99
The Mars RTA Clone is a rebuildable tank atomizer with 25mm diameter, made from 316 stainless steel. It has four terminals of two posts for dual coils building. Besides, it features airflow control at the bottom of the side by rotating the deck. It comes 510 threading connection.
Dolphin RBDA Rebuildable Tank / Dripping Atomizer Clone $6.99
The Dolphin RBDA Clone with 20mm diameter and 4.5ml tank is made from stainless steel. It has two posts for dual coils building and supports to use as rebuildable tank atomizer and dripping atomizer. It comes with 510 threading connection.
Erlprinz MTL RTA Sub Tank Clearomizer Clone $7.99
The Erlprinz RTA Clone with 20.8mm diameter and 8ml capacity is made out of stainless steel (deck and cap) and PC (tank tube). It features top filling system which make it easy to refill e-juice. It will bring you extreme MTL vaping experience. It comes with 510 threading connection.
Original One Top RTA Rebuildable Tank Atomizer $24.99
The original One Top RTA is a 24mm diameter rebuildable atomizer with 3ml capacity, made from stainless steel (deck and cap) and PC (tank Tube without AFC). It also comes with a stainless steel tank tube that can be adjusted airflow by rotating the cap. What's more, it has four holes of two posts design for dual coils building and it's easy to operate with large deck space. It comes with 510 threading connection.
The drip tip will be shipped in random color. More color than what's on the image.
Original Horizon Falcon Sub Ohm Tank Clearomizer $27.59
The original Horizon Falcon tank is the latest sub ohm tank with 25mm diameter, which features a large 7ml e-juice capacity. Designed as top filling system and bottom airflow control system to bring you large vapors. It comes with 4 different e-liquid guiding element which can offer you great flavors, including 70% cotton + 30% wood pulp, natural flax fiber, flax fiber + flax paper and 30% wood pulp + 70% cotton by mesh coil. This item also has other colors to choose.
Original VBRVAPE 900mAh Pod System Starter Kit $25.99
The original VBRVAPE Pod System kit is very suitable for vaping beginners. It comes with a 1.5ml capacity pod that you can insert e-liquid nozzle into the hole (no the larger central one) for filling. The unique leaf-shaped appearance makes it easy to hold in hand. With a built-in 900mAh battery, it can be charged fully within 100 minutes by included USB cable. There are low, medium and high vapor strengths which showed in 1, 2 and 3 numbered light. With the touch senor control system, you can tap it to cycle between three vaping modes and touch for 3s to activate setting modes or lock your chosen strength. What's more, if you want to know the battery level, please tap it two times, it will be shown in different light colors. This item also has other colors to choose.
Coil Smarter Coiling Kit 5-in-1 Coil Jig $6.99
The Coil Smarter 5-in-1 Coiling Kit is with the double-sized top caps and the larger size that make coil building much easier. You just need to simply slip in any gauge wire, spin the cap away to your desired resistance and size. It comes with 1.0, 1.5, 2.0, 2.5 and 3.0mm diameter poles.
Original Wotofo Fused Clapton N80 Pre-built Coil Original Price $6.29,Now Only $3.99
The Original Wotofo Fused Clapton coil is 0.5ohm, made from N80 material. The inner core is 26G and outer wire is 38G. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production.
It comes with 10pcs pre-built coils in one pack. This item also has other Version to choose.
Original Wotofo Quad Core Fused Clapton N80 Pre-built Coil Original Price $7.49,Now Only $4.99
The Original Wotofo Quad Core Fused Clapton coil is 0.26ohm, made from N80 material. The inner core is 28G x 4 and outer wire is 36G. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production.
Original Wotofo Juggernaut N80 Pre-built Coil Original Price $8.99 ,Now Only $5.49
The Original Wotofo Juggernaut coil is 0.28ohm, made from N80 material. The inner core is (26G + 36G) x 2 and outer wire is 0.1 x 0.4mm. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production.
Original Wotofo Easy Fill Squonk Cap for 100ml E-juice Bottle / BF Squonk Box Mod Original Price $9.99,Now Only $6.99
The Original Wotofo Squonk Cap is designed to refill squonk bottle through the 510 connector. Made of food grade aluminum material, it is the very helpful tool that to refill without any leak problem.
This squonk refill cap is for 100ml juice bottles. This item also has other colors to choose.
Original Wotofo Stentorian Easy Refill Squonk Bottle Original Price $14.99,Now Only $9.99
The Stentorian Easy Refill Squonk Bottle is a 30ml combination of a needle tip juice bottle and a squonk refill bottle. Designed especially for practical convenience, the bottle consists of 4 pieces: a thread-on cap to keep the tip clean and to seal the whole system for transportation; a squonk refill cap to easily refill your squonk mod bottle; a needle tip to drip juice more accurately; and a soft silicone bottle that is easy to squeeze and durable in use. This item also has other colors to choose.
Original Horizon Replacement F1 Coil Head for Falcon Sub Tank Clearomizer $9.69
The Original Horizon Falcon F1 Coil features 0.2ohm resistance and works well at 70~90W (best at 80W). It is suitable for original Horizon Falcon sub tank clearomizer. It's an initiative application of flax fiber and microporous process. This material has high heat resistance and can present the liquid flavor very well.
It comes with 3pcs in one pack. This item also has other Version to choose.
Старый 11.06.2018, 05:18 Автор темы   126
3FVAPE
Original Eleaf Pico Squeeze 2 100W TC VW Variable Wattage Squonk Box Mod $54.49
The Original Eleaf Pico Squeeze 2 box mod is powered by single 18650 or 21700 battery (not included), the max output power can fire to 100W. It supports quick charging in a maximum charge current of 2A and also can be upgraded firmware via USB cable. It mainly features reimaged squonk system, when you squeeze the 8ml soft silicone bottle, the e-liquid will directly into the bottom-fed atomizer. With a new Avatar chip, it can provide a faster firing speed than ever, and also supports multiply modes, such as TC, VW and Bypass mode. The equipped 0.49 inch screen can display all essential information clearly. This item also has other colors to choose.
Pandora Hybrid Mechanical Mod Clone $29.99
The Pandora Mechanical Mod Clone is made from copper, powered by single 18650 or 20700 battery (not included). It features hybrid connection and beautiful hollowed out pattern. It comes with a 18650 battery adapter. The fire button is activated by magnets. This item also has other colors to choose.
Original Anjou AJ-PCN005 Rechargeable 350mAh Pod System Battery Mod $13.99
The Original Anjou AJ-PCN005 is with bigger clouds and easy to refill: Enjoy bigger clouds of classic-flavored vapor and simply insert pre-filled cartridge into the device to vape.
The Pod is with Quick Charging and 350mAh battery, full-charge in 1.5 hours and lasts up to 300 puffs.
The pod is with portable sleek design, this mini e-cigarette is sleek and lightweight, thus very convenient for carrying around wherever you go. The
The pod is safe and healthy, Perfect for smokers who want to vape and pursue health at the same time since the e cig is nicotine-free.
The pod is with all around protection: overcharging, over-discharging, short circuit, low voltage and 8s auto shut off safety features keep you safe
Original Anjou AJ-PCN025 Rechargeable 350mAh Pod System Battery Mod $11.99
The pod is with revolutionary heat technology: Innovative ceramic coils heat up evenly to deliver the purest taste and thicker clouds in comparison to standard cotton wicks which can taint your hit;
The pod is 99% leak-proof: The airtight seal of the bottom tank guarantees a leak-free experience, every time;
The pod is pain-free refill: Disposable liquid pods, which lasts up to 400 puffs, let you switch flavors (2 x 1.9mL e-liquid in Green Apple Mint and White Peach Mint flavors included) in seconds and simply discard when it's empty;
The pod is vaping made easy: Using a Snap-On magnetic connection, this push-fit refill system allows you to simply insert the pod into device and vape away instantly;
Your Safety, Our Priority: Nicotine-free, CO-free and tar-free vaping is a safer alternative to smoking; Overcharging and short circuit protections keep you safe while auto-shutoff feature kicking in after 5 seconds of power to prevent overheating
Original Eleaf Coral 2 RDA Rebuildable Dripping Atomizer with BF Pin $21.49
The Original Eleaf Coral 2 RDA is a 24mm diameter rebuildable dripping atomizer, made from stainless steel. It has a large building deck and unique crooked posts design for easy single coil building. Besides, there is a channel that directs the airflow to the coil, presenting a great vaping experience with huge clouds. It comes with squonk pin that allows e-liquid to saturate the cotton from the bottom.
The Coral 2, a new rebuildable drip atomizer (RDA) by Eleaf, offers an open space for you to build coils as you like and enjoy the DIY fun in vaping to the fullest. The airflow can be adjusted to your preference by rotating the atomizer tube. With the addition of an elegant acrylic mouthpiece, a decorative ring and a bottom-fed solution, the Coral 2 fits the Pico Squeeze 2 squonker mod perfectly in terms of both appearance and performance.
Typhoon GT4 RTA Rebuildable Tank Atomizer Clone $23.99
The Typhoon GT4 RTA Clone is a 26mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel. The build deck comes with dual post design for easy single or dual coil building. The air enters via the bottom air slots and travel up to the bottom of the coils, providing pure flavor and massive cloud production. This item also has other colors to choose.
IOU-R MTL RTA Rebuildable Tank Atomizer Clone $14.99
The IOU-R MTL RTA Clone is a rebuildable tank atomizer with 22mm diameter and 3ml capacity, made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. It features side refilling system that make e-juice filling easily and quickly. This RTA will bring you extreme MTL vaping experience.
YFTK Peta Sub Ohm Tank Clearomizer Clone $24.99
TheYFTK Peta sub tank clearomizer Clone is a rebuildable tank atomizer with 22mm diameter and 3.6ml capacity, made out of stainless steel and PMMA. The airflow can be adjusted by rotating the AFC ring. It comes with 510 threading connection.
The Peta tank only comes with 0.8ohm coil head.
Original OBS KFB Starter Kit with BVC Sub Ohm Tank Atomizer Original Price $28.39, Now Only $14.99
The OBS KFB starter kit is constructed from Stainless Steel and glass construction. The OBS KFB starter kit is powered by 1 x 18650 battery (not included). The clearomizer features 0.3 ohm (25~50W) BVC coil and 2ml e-liquid capacity. Features top airflow and side filling, this OBS KFB starter kit will bring you good vaping experience!
Original Anjou AJ-PCN017 Replacement Cartridge for AJ-PCN005 Pod $5.99
Original Anjou e-Cigarette Atomizer: Certified and original atomizer for Anjou AJ-PCN005 E-Cigarettes;
What You Get: 2 x Classic Tobacco flavor and 2 x Lemon Mint flavor; 1.2 ml each for up to 200 puffs - equal to a pack of cigarettes;
Even More Lifelike Smoke: Ceramic heating technology produces more smoke for a satisfying vaping experience;
Safer Than Smoking: No CO, no tar, no nicotine, and no harmful substances; ideal for those looking to quit;
Store for Long-Lasting Flavor: Place in cool shady environment between 35.6'F to 77'F / 2'F to 25'F to preserve flavor and enjoyment
4 PCS Pack. This item also has other Package to choose.
Original Anjou AJ-PCN033 Replacement Cartridge for AJ-PCN025 Pod $3.99
Anjous Original E-Cigarette Atomizer Caps: This replacement atomizer pod pack is only compatible with AJ-PCN025 e-cigarette;
4 Pre-Filled Pods: 1.9 mL each pod for up to 400 puffs in Green Apple Mint and White Peach Mint flavors;
A Safer Alternative: Transition to vaping and start your healthier nicotine-free, CO-free, and tar-free journey;
Easy to Replace: The disposable design saves you trouble from refilling the pods and allows you to switch to new flavors whenever you like;
Tips for Best Results: It's best to store the pods at room temperature (10C~ 25C) in a dry environment in their sealed compartments until use
2 PCS Pack. This item also had 4 PCS Pack to choose.
Original IJOY Pole 600mAh MTL All-in-One Pod System Starter Kit $22.79
The Original IJOY Pole pod system starter kit is a simple and compact all-in-one MTL starter kit with 16mm diameter, powered by built-in 600mAh battery. The whole kit features fashionable appearance and rich colors with aluminum alloy CNC and oxidation technology. The chipset is designed by IWEPAL with short circuit protection, low power protection to be safe and reliable. The unique bar button and active indicator can achieve easy operation. The pole pod kit supports USB charging to ensure long working time. The atomizer utilizes top airflow intake and the latest ceramic coil to prevent dry heat and bring long coil life with original flavor experience. This item also has other colors to choose.
Original Joyetech ESPION Silk 2800mAh 80W TC VW Variable Wattage Box Mod + NotchCore Clearomizer Kit $56.99
The Joyetech ESPION Silk Kit consists of ESPION box mod and NotchCore tank. This item also has other colors to choose.
Mod:
The Original Joyetech ESPION Silk box mod, with the application of hypoallergic properties is smooth to touch and comfortable even for people with sensitive skin. It is light weighted and fits your hand comfortably. Having a 2800mAh built-in battery, the ESPION Silk can be powered up to 80W coupled with multi mode options. With a 0.69-inch OLED screen and intuitive system, you can easily manage it. It can be charged fast in 2A by a included USB cable. It is with high quality, convenience but inexpensive.
Tank:
The NotchCore with 22mm diameter and 2.5ml is easy to install and change the NotchCoil atomizer head in an economic way. The resistance is 0.45ohm. It adopts the horizontal way to achieve a pure flavored taste. Meanwhile, you can enjoy the huge clouds with a low power output (20~25W). The gold plated atomizer base makes a good electrical conductivity. With the push-to-open top filling design, you can simply push the top cap to reveal the filling hole. What's more, the airflow can be adjusted by simply rotating the ring.
Original Eleaf Pico Squeeze 2 100W TC VW Variable Wattage Squonk Box Mod + Coral 2 RDA Kit $62.99
The Original Eleaf Pico Squeeze 2 Kit consists of a Pico Squeeze 2 box mod and a Coral 2 RDA tank. This item also has other colors to choose.
Mod:
Tank:
The Coral RDA is a 24mm diameter rebuildable dripping atomizer, made from stainless steel. It has a large building deck and unique crooked posts design for easy single coil building. Besides, there is a channel that directs the airflow to the coil, presenting a great vaping experience with huge clouds. It comes with squonk pin that allows e-liquid to saturate the cotton from the bottom.
Старый 12.06.2018, 04:53 Автор темы   127
3FVAPE
Original Aspire Puxos 80W / 100W TC VW Variable Wattage Box Mod $44.99
The Original Puxos Kit allows for use with three different battery types, when using an 18650 battery (not included), it must be mounted in the supplied adapter and the max output wattage is 80W. While using a 20700 or 21700 battery (not included), it can fire to 100W. It can be used in various modes, allowing you to select between Wattage, Voltage, Bypass, CPS (C1 / C2 / C3), TC(Ni / Ti / SS316L) and TCR(M1 / M2 / M3). With a compact design, it is comfortable to hold and fits equally well in purse or pocket. It can be charged very fast via included USB cable and the maximum charging rate is 2 amps. This item also has other colors to choose.
Original GeekVape Zeus Dual RTA Rebuildable Tank Atomizer Standard Edition Original Price $37.99, Now Only $25.99
The Original Zeus Dual RTA is an upgraded dual coil version of the original Zeus RTA, with the innovative leak-proof top airflow system, airflow transferring from the top to the bottom to maintain great flavor. It comes with upgraded postless build deck that allows for easy building with both single coil and dual coil. Zeus Dual RTA is compatible with 810 and 510 drip tip and 5.5ml bubble tank.
This RTA is Standard Edition with 4ml of capacity and 5.5ml bubble tank. This item also has other colors to choose.
YFTK ReGen RTA Rebuildable Tank Atomizer Clone $23.99
The YFTK ReGen RTA Clone is a 22mm diameter rebuildable tank atomizer, made from 316 stainless steel (base and cap) and PC (tank). It has open deck design for easy coil building. With a 4.3ml capacity, it can meet your daily vaping need. It features adjustable airflow control with 1.2mm, 1.4mm and 1.6mm airholes at each side, which will bring you excellent vaping experience.
Original Tesla Tpod 500mAh Pod System Starter Kit Original Price $48.90, Now Only $32.99
The Original Teslacigs TPOD Pod system starter kit with 2ml capacity is the latest ultra-portable vape format. Powered by 500mAh built-in battery, which can be quickly charged fully within 1.3h via the USB cable . Constructed by zinc alloy (device)and PC (pod), it features a small and discrete design and is portable to carry and luxury to touch. Tesla TPOD comes with a simple large 1.4inch color screen design to provide a simple yet effective method of presenting the current status of the battery, a count of puffs taken, the output current and voltage as well as firing time. This item also has other colors to choose.
Original Aspire Puxos 80W / 100W TC VW Variable Wattage Box Mod + Cleito Pro Tank Kit Original Price $69.99, Now Only $63.99
The Original Aspire Puxos Kit consists of Puxos box mod and Aspire Cleito Pro tank. This item also has other colors to choose.
Mod:
Tank:
The all new Aspire Cleito Pro tank with 24mm diameter, which is just as flexible as it accepts coils from Cleito and Cleito Exo tanks. It features 3ml capacity and also can be 4.2ml with a spare glass tank tube. It also comes with airflow control system by rotating the ring. Easy to fill thanks to a top side-fill slot by sliding up the top ring to reveal the filling slot and fill with your preferred e-liquid. The resistance is 0.5ohm that works well at 60~80W. Remember to let the coil stand for a few minutes to thoroughly saturate the wicking material before vaping.
Original Tesla Replacement Pod Cartridges for Tpod Pod System Starter Kit Original Price $26.50, Now Only $18.99
The Original Tesla Tpod replacement Pod Cartridges features 2ml capacity with leak-proof setting. With an innovative and powerful 1.2ohm coil head, the TPOD Pod could apply to nicotine salts perfectly. It is suitable for Tesla Tpod Portable Device.
Original Aspire Replacement Side Panel for Puxos Box Mod $4.99
The replacement panel is suitable for original Aspire Puxos Box Mod. This item also has other colors to choose.
Старый 13.06.2018, 04:40 Автор темы   128
3FVAPE
Original IJOY Zenith 3 VV Variable Voltage Box Mod Original Price $56.90, Now Only $47.99
The Original IJOY Zenith 3 box mod is a new semi-mechanical box mod, powered by dual 18650 or 20700 batteries (not included). With outstanding shape in hard lines and cool appearance, it features a big voltage adjustable knob with 16 voltage levels (2.7~7.2V) in limitless 360 degree. The big sized fire button also adopts strong line design to match with the whole mod, giving the device a unique and science fiction feeling. Zenith 3 box mods chipset is designed by IWEPAL, with short circuit protection, low power protection, battery reverse protection and power light operation and has milliseconds fire speed, and a maximum output of 360W. The mod support USB charging. When using 20700 batteries (not included), it is with long battery life and 50A discharge, 6000mAh capacity. This item also has other colors to choose.
Original Modefined Draco 200W TC VW Variable Wattage Box Mod $49.99
The Original Modefined Draco box mod is a mobile-phone-styled box mod, made from zinc alloy (frame) and G10 (side panels). Powered by dual 18650 batteries (not included), the box mod can fire up from 5W to 200W output power. The large 2.0 full color screen delivers a wide range of information in an organized manner, with a focus on ergonomic user-friendly interface. The smart chipset inside plays high performance which allows you to customize your vaping experience down to your personal preferences. It comes with 510 threading connection.
AV Workman Hybrid Mechanical Mod Clone $19.99
The AV Workman Series Mechanical Mod Clone is with 24mm diameter at hybrid cap and 28mm outer diameter, made from brass, powered by single 18650 battery (not included). It features hybrid connection. The fire button is activated by magnets and can be locked for your safety when not using it. This item also has other colors to choose.
Original Arctic Dolphin Rexx RDA Rebuildable Dripping Atomizer with BF Pin $26.89
The Original Arctic Dolphin Rexx RDA is a new-designed 18mm diameter rebuildable dripping atomizer, made from stainless steel. It features gold-plated build deck with two posts, which supports both single or dual coils building. With a deep juice well, it will offer you a long-time vape experience. The unique curved design makes it looks sleek and the appearance is amazing, especially with beautiful finishes. The airflow can be adjusted by rotating decoration ring.
It comes with a bottom feeder pin and adapter ring. This item also has other colors to choose.
Moseone V2 RDA Rebuildable Dripping Atomizer Clone $7.99
The Moseone V2 RDA Clone is a 24mm diameter rebuildable dripping atomizer, made from stainless steel. It has two posts design to support single coil building. The cap consists of two parts, one features a large airhole and another is with three little holes, you can rotate them to adjust the airflow. It comes with 510 threading connection. This item also has other colors to choose.
Kindbright Duetto Reborn RDA Rebuildable Dripping Atomizer Clone with BF Pin $12.99
The Kindbright Duetto Reborn RDA Clone is 22mm diameter rebuildable dripping atomizer, made from 316 stainless steel, with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience.
This RDA comes with a bottom feeder pin.
Kindbright M-Atty RDA Rebuildable Dripping Atomizer Clone with BF Pin $13.69
The Kindbright M-Atty RDA Clone is constructed from 316 stainless steel. This RDA supports dual and single coils building. And the deck of this RDA is designed around common vertical & horizontal builds.
Original IJOY Zenith 3 VV Variable Voltage Box Mod + Diamond Tank Kit Original Price $87.90, Now Only $59.19
The Original IJOY Zenith 3 Kit consists of Zenith 3 box mod and Diamond Tank. This item also has other colors to choose.
Mod:
The Original IJOY Zenith 3 box mod is a new semi-mechanical box mod, powered by dual 18650 or 20700 batteries (not included). With outstanding shape in hard lines and cool appearance, it features a big voltage adjustable knob with 16 voltage levels (2.7~7.2V) in limitless 360 degree. The big sized fire button also adopts strong line design to match with the whole kit, giving the device a unique and science fiction feeling. Zenith 3 box mods chipset is designed by IWEPAL, with short circuit protection, low power protection, battery reverse protection and power light operation and has milliseconds fire speed, and a maximum output of 360W. The mod support USB charging. When using 20700 batteries (not included), it is with long battery life and 50A discharge, 6000mAh capacity.
Tank:
The Original Diamond Tank is with 25mm diameter at deck and 26.5mm outer diameter. It features 5.5 capacity with bubble tank and also include a 4.0ml extra tank. With a 180 degrees fast screw-cap filling design, it is easy to refill. It comes with diamond coil that is the IJOY's innovative coil. The porous dense arrangement increases the contact area between the heating wire and the cotton. The heat is faster and more uniform. The e-juice can be more fully atomized and restores the taste of the e-juice. At the same time, the use of organic fiber cotton, full of e-juice, highly retained the original taste!
Старый 14.06.2018, 05:16 Автор темы   129
3FVAPE
Original Joyetech ESPION Silk 2800mAh 80W TC VW Variable Wattage Box Mod $43.89
The Original Joyetech ESPION Silk box mod, with the application of hypoallergic properties is smooth to touch and comfortable even for people with sensitive skin. It is light weighted and fits your hand comfortably. Having a 2800mAh built-in battery, the ESPION Silk can be powered up to 80W coupled with multi mode options. With a 0.69-inch OLED screen and intuitive system, you can easily manage it. It can be charged fast in 2A by a included USB cable. It is with high quality, convenience but inexpensive. This item also has other colors to choose.
Original Tesla DB 219W TC VW Variable Wattage Box Mod Original Price $72.90, Now Only $46.99
The Original Tesla DB219 box mod is a high end regulated device with comfortable hand feeling, constructed by environmentally-friendly PEI material and has a scale-like finish, its cover is created in leaf texture and looks transparent in light. Powered by dual 18650 batteries (not included), it can fire up to 219W max output which will create massive cloud. It supports VW and TC mode.
AV Gyre Slow Twist Hybrid Mechanical Mod Clone $20.99
The AV Gyre Slow Twist Hybrid Mechanical Mod Clone is constructed from brass and aluminum in 24mm diameter. The hybrid cap allows more aggressive raw power for massive clouds. The tube comes with Slow Twist style machined body (engraved logo), which is stylish and better to grip. The fire button is magnetic. The mod is powered by single 18650 battery (not included). This item also has other colors to choose.
Original ShenRay Art Elite RTA Rebuildable Tank Atomizer $19.90
The Original ShenRay Art Elite RTA is a 25.5mm diameter rebuildable tank atomizer, made from 316 stainless steel. It features 3.5ml and 2.5ml capacity with spare tank and is easy to refill the e-juice with top filling system. Designed as the postless deck, it is easy for single coil building. The coil is among two airflow posts, and the air will hit the coil from the bottom, which will bring you excellent vaping experience. You can adjust the airflow by rotating the AFC ring. It comes with gold-plated deck and brass pin for great electronical conductivity.
The 810 drip tip will be shipped in random color.
Original Vapefly Nicolas MTL Sub Ohm Tank Clearomizer TPD Version Original Price $27.99, Now Only $18.99
The Original Nicolas with 22mm diameter is a MTL ffavor tank which features a BVC coil structure along with a convenient Plug-Pull mechanism for ergonomic replacement process. The adjustable airflow control valve features 9 different airflow settings for precise airflow adjusted down to your own personal preferences. With the top filling design, it is easy to refill e-juice by pulling out the top cap. It comes a 510 threading connection. The kit includes a 1.8 ohm coil (9~13W) and a preinstalled 0.6 ohm coil (18~25W).
This tank is TPD Edition with 2ml juice capacity. This item also has other colors to choose.
Original Vapefly Nicolas MTL Sub Ohm Tank Clearomizer Standard Version Original Price $27.99, Now Only $18.99
The Original Nicolas with 22mm diameter is a MTL flavor tank which features a BVC coil structure along with a convenient Plug-Pull mechanism for ergonomic replacement process. The adjustable airflow control valve features 9 different airflow settings for precise airflow adjusted down to your own personal preferences. With the top filling design, it is easy to refill e-juice by pulling out the top cap. It comes a 510 threading connection. The kit includes a 1.8 ohm coil (9~13W) and a preinstalled 0.6 ohm coil (18~25W).
This tank is Standard Edition with 3ml juice capacity. This item also has other colors to choose.
Original VGOD Pro Sub Ohm Tank Clearomizer Original Price $44.95, Now Only $34.99
The VGOD Pro SUBTANK delivers satisfying flavor and massive cloud production. Included is a 0.2ohm Shotgun coil, 30~100W, but is best at 60W. The tank has a 4ml capacity, made of Pyrex glass and contains two Official VGOD shields built in for a more distinctive style. It features a convenient, leak proof, top fill design and two wide adjustable airflow slots on the base to accommodate your airflow preferences.
Original Justfog C601 650mAh Pod System Starter Kit $18.99
The Original Justfog C601 Pod system Kit, made from aluminum and PC materials, powered by 650mAh built-in battery, comes with 1.7ml capacity and 1.6ohm coil. The thumb-sized device allows you to carry and vape even easier and stronger wherever you are. It is easy to charge anywhere via Micro 5 pin USB port. Using the holder, you can hang C601 on the pocket or bag. The two holes in the holder allow for the attachment of the necklace, so that you can wear the C601 to your neck. It is also possible to cover pod with a holder when not in use to prevent foreign materials from entering the pod. The light color of indicator can show you the battery status. It supports multiply protections, such as short circuit protection, overheating protection, over discharge protection and over voltage charge protection. This item also has other colors to choose.
Original Teslacigs DB 219W TC VW Variable Wattage Box Mod + Tallica Mini Tank Kit Original Price $95.90, Now Only $65.99
The Original Tesla DB219 Kit consists of DB219 box mod and Tallica Mini Tank. This item also has other colors to choose.
Mod:
Tank:
The Tallica Mini tank with 25mm diameter and 4ml capacity, made from stainless steel. The top filling and bottom airflow system will bring you the smoothest and quietest restricted direct lung vaping feeling.
Original VGOD Pro 200W TC VW Variable Wattage Box Mod + VGOD Pro SubTank Kit Original Price $119.95, Now Only $107.99
The Original VGOD Pro 200 Kit consists VGOD Pro 200 Box Mod and VGOD Pro SubTank.
Mod:
The Original VGOD Pro 200 Mod is designed for extreme versatility to give you everything you need in one box. Enjoy a simplistic wattage mode or maximize your vaping journey with a 200W max output in various modes by unlocking the advanced menu. Fire hard at a continuous 4.2V in Mech Mode. Vape like a pro in Pro mode and individually program a wattage curve for your own personalized vape style. Or select your desired temperature and wattage for your Ni, Ti or SS coils. The Pro 200 has been designed for style and comfort. It is contoured to fit in any size hands. The fire button is flush at the top of the box, so you can always press it comfortably whether it is held from the top or from the bottom. The VGOD Pro 200 is powered by dual 18650 batteries (NOT INCLUDED).
Tank:
Vape Carring Buckle Belt Hook for E-cigarette Mod $1.99
The Vape Carring Buckle Belt Hook is used for hanging your e-cigarette mod on your belt, made from stainless steel. First please put the short metal plate on the mod to make the 510 threading hole right below the big hole, then screw the atomizer on tightly. It is convenient for you to carry your favorite mod on-the-go. This item also has other colors to choose.
Replacement Top Cap for Kaonashi RDA Clone $3.99
The replacement top cap is made from PMMA. The outer diameter is 22mm. It is suitable for Kaonashi RDA Clone.
This cap is only compatible with 510 drip tips. This item also has other colors to choose.
810 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99
The replacement 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Aleader 810 Drip Tip Kit for TFV12 / TFV8 / Goon / Kennedy / Apocalypse $6.99
The Original Aleader 810 drip tip is made from resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
The drip tips will be shipped in random color (8 PCS). More color than what's on the image.
Original Aleader 510 + 810 Drip Tip Kit for RTA / RDA Atomizer $6.99
The replacement 510 / 810 drip tip is made from resin / PEI. It is suitable for RDA / RTA / Sub ohm tank.
The drip tips will be shipped in random color (10 PCS). More color than what's on the image.
Original Vapefly 510 Replacement Drip Tip for Galaxies MTL RDA $2.99
The Original Vapefly replacement 510 drip tip is made from PMMA with 16mm height. It is suitable for Vapefly Galaxies MTL RDA, and can be compatible with all atomizers that fit 510 drip tip.
Original Vapefly Replacement Coil Head for Nicolas MTL Sub Ohm Tank Clearomizer Original Price $9.69, Now Only $6.99
The Original Vapefly Nicolas Coil features 0.6ohm resistance and works well at 18~25W. It is suitable for original Vapefly Nicolas sub tank clearomizer.
It comes with 5pcs in one pack. This item also has other Resistance, Wattage range to choose.
Старый 15.06.2018, 05:11 Автор темы   130
3FVAPE
Dvarw V2 MTL RTA Rebuildable Tank Atomizer Clone $10.99
The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of 316 Stainless Steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience.
Dvarw V2 MTL RTA Atomizer Clone with Airflow Control Sets + Spare Tank Sets $18.99
The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of 316 Stainless Steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience. It comes with 2ml tank set (top lid, tank tube and chimney, 3.5ml tank set, 5ml tank tube, and five airflow control sets with different sized airhole. The size of circular airholes are 0.5mm, 0.8mm, 1.3mm, 1.8mm and 2.3mm.
Dvarw V2 DL RTA Rebuildable Tank Atomizer Clone $11.99
The Dvarw V2 DL RTA Clone is a 24mm RTA made out of 316 Stainless Steel and PC (tank). The build deck comes with dual post design and bottom airflow system. The RTA has 2.5mm bottom and 8mm by 2.5mm side airflow hole. This RTA will bring you extreme DL vaping experience. This item also has other Material to choose.
Dvarw V2 DL RTA Atomizer Clone with Airflow Control Sets + Spare Tank Set $18.99
The Dvarw V2 DL RTA Clone is a 24mm RTA made out of 316 Stainless Steel and PC (tank). The build deck comes with dual post design and bottom airflow system. The RTA has 2.5mm bottom and 8mm by 2.5mm side airflow hole. This RTA will bring you extreme DL vaping experience.It comes with 3.5ml tank set (top lid, tank tube and chimney) and three airflow control sets with different sized airhole. The size of circular airholes are 3.5mm, 4mm and 4.5mm. This item also has other Material to choose.
Ulton VG M5 MTL RTA Rebuildable Tank Atomizer Clone Original Price $26.00, Now Only $22.99
The Ulton VG M5 MTL RTA Clone is a 23mm diameter rebuildable tank atomizer, made from 316 stainless steel (deck and top cap) and PEI (tank). It comes with small inner diameter drip tip for the best MTL draft. It has dual posts design for easy single coil building. What's more, it features 5ml capacity that can meet your daily vaping need, and the top fill system makes refilling e-juice quickly and simply.
YFTK Haku Venna RDA Rebuildable Dripping Atomizer Clone with BF Pin $20.99
The YFTK Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included.
Original VGOD Shotgun SS316 Quad Coil Head for VGOD Pro Subtank Clearomizer Original Price $29.95, Now Only $23.99
The original VGOD Shotgun Pro SubTank SS316 Quad Coil Head features low resistance (0.2ohm) and higher wattage (30~100W, best 60W). It will bring you satisfying throat hits, massive clouds and hot vapor. It is suitable for VGOD Pro SUBTANK.
This product comes with 5 PCS in 1 pack. This item also has other Resistance to choose.
Vapswarm V3 Tool Kit Clone for E-Cigarette DIY Coil Building $12.99
The Vapswarm V3 tool kit Clone comes with 1 x slot screwdriver, 1 x t6 allen key, 1 x cleaning brush, 1 x phillips screwdriver, 1 x coil jig, 1 x SS scissors, 1 x ceramic tweezers, 1 x diagonal pliers and 1 x SS tweezers. This DIY tool kit is a good choice for DIY lovers.
SXK Replacement Cover Panel for Billet Box Mod Clone Original Price $22.90, Now Only $14.99
The Replacement Cover Panel is made from Acrylic, and is designed for SXK Billet Box Clone 70W / DNA60W Box Mod. This cover panel comes with 2 pieces (front and back).
This product is not suitable for SXK Billet Box (Purple Color).
Can also be used on YFTK Billet Box Mod Clone.
Replacement Tank Tube for Dvarw V2 MTL RTA Rebuildable Tank Atomizer Clone $2.99
The replacement 5ml capacity tank tube is made from 316 stainless steel and is suitable for Dvarw V2 MTL RTA Tank Atomizer Clone.
This product is also suitable for Dvarw RTA Clone.
Replacement Tank Tube + Top Lid + Chimney for Dvarw V2 MTL RTA Clone $4.79
The replacement 2ml capacity tank tube is made from PC. Top lid and chimney are made from 316 stainless steel. They are suitable for Dvarw V2 MTL RTA Tank Atomizer Clone.
It comes with a 2ml tank tube, top lid and chimney.
This product is also suitable for Dvarw RTA Clone. This item also has other Capacity to choose.
Replacement Tank Tube + Top Lid + Chimney for Dvarw V2 DL RTA Clone $4.99
The replacement 3.5ml capacity tank tube is made from PC. Top lid and chimney are made from 316 stainless steel. They are suitable for Dvarw V2 DL RTA Tank Atomizer Clone.
It comes with a 3.5ml tank tube, top lid and chimney.
This product is only suitable for Dvarw V2 DL RTA Clone. This item also has other Material to choose.
Replacement Tank Tube Set for Dvarw V2 DL RTA Clone $3.99
The replacement 6ml capacity tank set is made from PEI and is suitable for Dvarw V2 DL RTA Tank Atomizer Clone. The tank tube and chimney are in one piece.
Original Cloupor Hawaii E-juice Liquid for E-cigarette $7.99
The original Cloupor Hawaii E-juice liquid comes with a flavor of kumquat and lemon. It comes with 30ml e-juice,70% VG and 30% PG. There are other kinds of options and Flavor for this item.
Original Cloupor Evil Clown E-juice Liquid for E-cigarette $16.99
The original Cloupor Evil Clown e-juice liquid comes with a flavor of soda. It comes with 60ml e-juice,70% VG and 30% PG. There are other kinds of options and Flavor for this item.
Original Cloupor High Priestess E-juice Liquid for E-cigarette $7.99
The original Cloupor High Priestess e-juice liquid comes with a flavor of passion fruit. It comes with 30ml e-juice,70% VG and 30% PG. There are other kinds of options and Flavor for this item.
Старый 16.06.2018, 04:34 Автор темы   131
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Vapor Storm Puma 200W TC VW Variable Wattage Box Mod $31.99
The Original Vapor Storm Puma Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (not included), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience.
Original Wismec Bellerophon RTA Rebuildable Tank Atomizer $27.59
The Original Wismec Bellerophon RTA is a 27mm diameter rebuildable tank atomizer. It features specialized airflow trail, delivering you extremely pure flavors. Whats more, the airflow can be adjusted freely with the two air slots evenly spaced on the bottom, allowing you to experience different enjoyment. The design of the two post screws on the top of deck makes it more convenient for you to rebuild the Clapton 0.28 ohm coil. What's more, the fashionable appearance pattern makes it more attractive and eye-catching. The Ultem 810 drip tip is another big hit. With the top removable refill design, you just need to screw off its drip tip and top cap and then you can complete the filling in one go. The RTA is a good choice in terms of appearance and performance. It comes with 510 threading connection. This item also has other colors to choose.
Original Vandy Vape Capstone RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99, Now Only $28.99
Designed by VapeHappy, the Original Vandy Vape Capstone RDA is a 24mm RDA that features stunning appearance, single screw spring loaded capstone deck, ramp airflow system and waterfall squonk action. The RDA will provide dual slotted trapezoid airflow, which is compatible with single or dual coil. An extra PC comp cap is included for different vaping experience.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Original Vapor Storm Stalker 400mAh Pod System Starter Kit $16.89
The Original Vapor Storm Stalker pod system starter kit features compact size and no-button design, made from aluminum alloy. Powered by a built-in 400mAh battery, it will provide you with an enjoyable vaping experience. With special multiple protective functions, it will be very safe for you while vaping, such as low voltage protection, over puff protection, short circuit protection, over charging protection and over discharging protection. There are two 1.8ml refillable cartridge, and it is better to replace the cartridge after using two cans of oil. What's more, its also portable and very lightweight that you can carry it everywhere conveniently. This item also has other colors to choose.
Refilling Dripping Bottle for E-juice Liquid $4.99
The refilling dripping bottle is made out of PE material and the top lid is made of stainless steel. It has 30ml of juice capacity. With the long thin tube, it is easy to refill e-juice to your atomizer without a mess. It is also suitable for storing e-juice liquid. This item also has other Capacity to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $0.99
The replacement 810 drip tip is made from resin with 12mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
One piece will be shipped (random color). More color than what's on the image. This item also has other Version to choose.
810 Honeycomb Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The replacement 810 drip tip is made from resin with 18mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
One piece will be shipped. This item also has other colors to choose.
Replacement Top Cap for Haku RDA Atomizer Clone $3.99
The replacement top cap sleeve is made from PMMA and is suitable for the Haku RDA Clone. This item also has other colors to choose.
Старый 19.06.2018, 04:31 Автор темы   132
3FVAPE
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 12mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original YC Vape Coiling Kit for E-cigarette DIY Coil Making $6.99
The YC Vape Coiling Kit consists of aluminum coil jig and 4 different sizes of SS coiling rods, with 2.0mm, 2.5mm, 3.0mm and 3.5mm. This kit is convenient for DIY lovers to make coils by themselves. This item also has other colors to choose.
Original Vapethink Steam Shark Flat Hydra Blue Ni80 Coil $5.59
The Original Vapethink Steam Shark Flat Hydra Blue Ni80 Coil is made from Nichrome 80 wires and features 0.2 ohm. This pre-coiled heating wire comes with 0.1 x 0.3mm Flat x 8 + 38GA coils. This heating wire will be a good vaping choice for DIY.
This product comes with 10 PCS in 1 pack. This item also has other Version to choose.
Original Advken Replacement Mesh Coil Head for Dominator Sub Ohm Tank / Dominator 100W Kit $14.99
The Advken Dominator Replacement Mesh coil head features 0.16ohm resistance and is best to use under 60W to 80W. It is suitable for Original Advken Dominator Sub Ohm Tank / Advken Dominator 100W Kit.
3FVAPE вне форума   Вверх
Старый 20.06.2018, 04:37 Автор темы   133
3FVAPE
Original Sigelei Sobra 198W TC VW Variable Wattage Box Mod $61.99
The Original Sigelei Sobra Mod adopt the innovative sleek design and supports maximum output 198W. It features special cobra modeling design and powered by dual 18650 batteries (NOT INCLUDED). Comes with 1.3inch TFT colorful screen, the vaping data can be displayed clearly. It supports Power Mode and TC / TCR mode, and the coil resistance range is from 0.05 to 3.0ohm. This item also has other colors to choose.
Brass Knuckles Tank Atomizer Clearomizer Clone $3.99
The Brass Knuckles Tank Atomizer Clearomizer Clone is a 10mm tank, which is very small in size, coming with 1.8ohm dual coil and 1ml of juice capacity. It is very compact and easy to use.
Original Advken Breath RDA Rebuildable Dripping Atomizer with BF Pin Original Price $34.99, Now Only $26.99
The Original Advken Breath RDA is a 24mm BF RDA that features dual posts build deck, 5mm deep juice well, and bottom airflow control. The gold plated 510 connector pin provides great conductivity. It comes with 3 options of drip tips and extra chuff cap to give you different choices.
Caiman MTL RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99
The Caiman RDA Clone is a 22mm RDA designed for MTL vaping. Constructed from 316 stainless steel, it comes with dual posts for easy coil building. The RDA has 5 airholes at both sides for adjustable bottom airflow. Besides, the airflow control set can be replaced with different one for different experience.
Stutt-Art Bogati RTA Rebuildable Tank Atomizer Clone $14.99
The Stutt-Art Bogati RTA Clone in 23mm diameter is made of 316 stainless steel. It comes with dual post build deck for single or dual coil building. The capacity of the tank is 5ml and top filling design makes it refill e-liquid very simply. The airflow can be adjusted as you like.
Original Sigelei Sobra 198W TC VW Variable Wattage Box Mod + Moonshot120 Tank Kit $76.99
The Original Sigelei Sobra Mod Kit Hydrographics Edition consists of Sigelei Sobra Mod and Moonshot120 tank. This item also has other colors to choose.
Mod:
Tank:
The Original Sigelei Moonshot120 Tank is made of stainless steel and glass with 5ml large e-juice capacity. It features top fill design and adjustable bottom airflow, which will bring you excellent vaping experience. The coil resistance is 0.25ohm.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.09
The replacement 510 drip tip is made from resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.09
The 810 drip tip is made from resin with 12mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version and colors to choose.
Старый 21.06.2018, 04:37 Автор темы   134
3FVAPE
Original Lost Vape Furyan Squonk Mechanical Box Mod Original Price $79.90, Now Only $61.99
The Original Lost Vape Furyan Squonk Box Mod features PEI chassis and 9ml squeeze bottle. Made out of high-quality material, the Furyan can give you the best touch feeling. The Lost Vape Furyan Squonk Mod is compatible with single 18650, 20700 or 21700 battery (NOT INCLUDED).
FEV vS MTL RTA Rebuildable Tank Atomizer Clone $18.89
The FEV vS MTL RTA Rebuildable Tank Atomizer Clone, constructed from 316 Stainless Steel, is a 17mm diameter tank designed for mouth-to-lung vaping. The RDA comes with dual post design for easy coil building.
Original Ystar Nuwa RDA Rebuildable Dripping Atomizer with BF Pin $18.79
The Original Ystar Nuwa RDA is a 24mm BF RDA that features ceramic main body, which has high melting point, high hardness, high durability, and oxidation resistance. The postless build deck has 4 terminals for easy coil building. The 510 drip tip is built into top cap. With the bottom airflow, it will provides nice flavor.
Original ThunderHead Creations THC Tauren RDA Rebuildable Dripping Atomizer with BF Pin Original Price $46.80, Now Only $21.19
The Original ThunderHead Creations THC Tauren RDA is a 24mm RDA that features 45-degree angled dual post and 28 micro airholes on each post for delicate and fullest flavor. The RDA has gold-plated 510 pin for great conductivity and also comes with BF pin for squonking. PEI drip tip is included.
Original Vandy Vape Berserker 1100mAh Mod + Berserker Subtank MTL Starter Kit Original Price $47.99, Now Only $35.79
The Original Vandy Vape Berserker MTL Kit consists of Berserker Mod and Berserker Subtank. This item also has other colors to choose.
Mod:
The Original Vandy Vape Berserker Mod is a small size device with built-in 1100mAh battery, which can satisfy your daily vaping need. It comes with Constant voltage mode and Bypass mode, and the reliable protections will make it safer to take puffs.
Tank:
The Original Vandy Vape Berserker subtank is a 19mm tank designed for MTL vaping. It is great for Nic salt or 50VG / 50PG e-juice. It features 5 adjustable airflows, which are 0.8mm, 1.0mm, 1.2mm, 1.4mm and 1.6mm. With 2ml / 3.5ml capacity, top filling design and most importantly the precise adjustable airflow, this tank will bring you the real experience for MTL vaping.
The replacement 810 drip tip is made from resin with 13.6mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Replacement Tank + Chimney Set for FEV vS RTA Clone $4.99
The replacement tank set is made from acrylic (tube) and 316 SS (chimney). It is suitable for FEV vS RTA Clone.
Старый 22.06.2018, 04:57 Автор темы   135
3FVAPE
Original GeekVape Aegis Legend 200W TC VW Variable Wattage Box Mod Original Price $73.90, Now Only $46.09
The Original GeekVape Aegis Legend Mod is a stylish box mod designed to be water and shock resistant. The Aegis Legend is more powerful than its previous version. Compatible with dual 18650 batteries (not included) and powered by the new AS chipset, Aegis Legend releases up to 200W output. Aegis Legend uses up to six different materials to achieve style and extreme durability, including stainless steel powder metallurgy, zinc die casting alloys, die-casting aluminum, 40hrc carbon steel, LSR silicone and leather. If you are looking for a durable box mod with extreme power and portability, the Aegis Legend is the best choice. This item also has other colors to choose.
YC Vape Hadaly RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99
The YC Vape Hadaly RDA Clone is an innovative RDA for you flavor chasers out there. It is constructed from titanium in 22mm diameter. This RDA is amazing but if you looking for massive clouds this one is not for you. It is best suited for single coil builds. The bottom comes with serial number.
YFTK Duetto Reborn RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The YFTK Duetto Reborn RDA Clone is 22mm diameter rebuildable dripping atomizer, made from 316 stainless steel, with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience.
Original Tigertek Nada RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.99, Now Only $23.99
The Original Tigertek NADA RDA is a collaboration of Vapnfagan and Tigertek. Nada RDA is a 25mm BF RDA that features quad terminal postless build deck, bottom and side airflow control, replaceable air plug screws for different experience and 10mm deep juice well. The air plug screws come with 3 sets: solid, 1.5mm and 2.5mm. This would be another amazing RDA for your collection. This item also has other colors to choose.
Coppervape Spica Pro MTL RTA Rebuildable Tank Atomzier Clone $20.99
The Coppervape Spica Pro MTL RTA is a 22mm rebuildable tank atomizer made from 316 stainless steel. The RTA comes with 3 / 5 /7 leaved airhole pin for choice. The chimney height can be adjusted. It is designed for real MTL vaping and will bring you wonderful flavor.
JuggerKnot RTA Rebuildable Tank Atomzier Clone $25.99
The JuggerKnot RTA Clone is a 24mm RTA with 4ml of juice capacity. It was made in 1:1 scale. The build deck is postless with quad terminals for single or dual coil building. The top airflow will bring great flavor. It is easy to refill from the top and there is no leaking problem. The tank comes with 1 x glass tank, 1 x Ultem tank and 1 x Ultem fat tank. This item also has other colors to choose.
Original GeekVape Aegis Legend 200W TC VW Box Mod + Aero Mesh Version Tank Kit Original Price $96.50, Now Only $59.39
The Original GeekVape Aegis Legend Kit consists of GeekVape Aegis Legend Mod and Aero Mesh Version Tank. This item also has other colors to choose.
Mod:
Tank:
The GeekVape Aero Mesh Version Tank is a 25mm sub ohm tank that adopts super mesh X1 coil head, which comes with 0.2ohm resistance and supports output at 30~90W. Another coil is IM4 head with 0.15ohm resistance and supports output at 60~80W.
The Aero Tank has 5ml of juice capacity.
The replacement 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other Version to choose.
Original Smokjoy Replacement DTL Pod Cartridges for OPS-1 Starter Kit $5.99
The replacement pod cartridges features 0.6ohm resistance and 2ml of capacity. It is suitable for Original Smokjoy OPS-1 pod system kit. The D-Pod will bring you fullest direct-to-lung experience and massive cloud.
This product comes with 2 PCS in 1 pack. This item also has other Version to choose.
Старый 25.06.2018, 05:06 Автор темы   136
3FVAPE
Kindbright Reactor Squonk Mechanical Box Mod Clone $43.99
The Kindbright Reactor Squonk Box Mod Clone has a stunning appearance, which has a aluminum alloy body with PEI fire button on top. The mod is powered by single 18650 battery (NOT INCLUDED). The squeeze bottle has 8ml of juice capacity. There is no overhang with 25mm atomziers. The mod comes with engraved logo and serial number.
JuggerKnot RTA Rebuildable Tank Atomzier Clone $26.99
Original Hotcig Hades RDA Rebuildable Dripping Atomizer with BF Pin $24.89
The Original Hotcig Hades RDA is a 24mm BF RDA that features both huge clouds and dense flavor. The build deck is PVD coated for insulation and the deck matches the color of the selected top cap. The postless build deck has quad terminals for single or dual coil building. The juice well has 5mm depth. The dual directional airflow will hit the coils from the bottom and provides fullest flavor.
This product comes with bottom feeder pin. This item also has other colors to choose.
STRO Mini V2 RDA Rebuildable Dripping Atomizer Clone $4.99
The STRO Mini V2 RDA is a rebuildable dripping atomizer with 22mm diameter, made from stainless steel. It features dual posts build deck for dual coils building and dual airflow system. It comes with 510 threading connection.
KayFun V4 RTA Rebuildable Tank Atomizer Clone $12.99
The KayFun V4 RTA Clone is a 22mm RTA with long chamber and drip tip and bottom airflow control for restricted vaping. It is made from stainless steel. You can access to the deck easily and the quad terminals build deck is very easy for building. It comes with engraved logo.
Original Cthulhu Iris Mesh RDA Rebuildable Dripping Atomizer with BF Pin $34.39
The Original Cthulhu Iris Mesh RDA is a 24mm Single and dual mesh coil RDA. The innovative vertical post design is to make sure the wick will not get pulled away from the mesh and dry burning mesh. With the cotton touching every point of the mesh, it will bring you fullest and purest flavor.
Dvarw V2 DL RTA Rebuildable Tank Atomizer Clone $12.99
The Dvarw V2 DL RTA Clone is a 24mm RTA made out of 316 Stainless Steel (top and deck) and PC (tank). The build deck comes with dual post design and bottom airflow system. It features 6ml capacity that can meet your daily vaping need. The RTA has 2.5mm bottom and 8mm by 2.5mm side airflow hole. This RTA will bring you extreme DL vaping experience.
Dvarw V2 DL RTA Atomizer Clone with Airflow Control Sets + Spare Tank Set $20.99
The Dvarw V2 DL RTA Clone is a 24mm RTA made out of 316 Stainless Steel (deck and top cap)and PC (tank). The build deck comes with dual post design and bottom airflow system. It features 6ml capacity that can meet your daily vaping need. The RTA has 2.5mm bottom and 8mm by 2.5mm side airflow hole. This RTA will bring you extreme DL vaping experience. It comes with 3.5ml tank set (top lid, tank tube and chimney) and three airflow control sets with different sized airhole. The size of circular airholes are 3.5mm, 4mm and 4.5mm.
Original SMOKTech SMOK G-PRIV Baby 85W TC VW Box Mod + TFV12 Baby Prince Tank Kit $68.49
The Original SMOK G-Priv Baby Kit consists of SMOK G-Priv Baby Mod and TFV12 Baby Prince Tank. This item also has other colors to choose.
Mod:
The Original SMOK G-Priv Baby Mod, a small and delicate stunner, which has a highly sensitive 2.0 inch touch screen that provides you outstanding man-machine interaction experiences. This new luxury noble is compact and ergonomically designed with stylish and elegant high-gloss finish. Equipped with a top battery slot, battery replacement becomes more convenient. Powered by single 18650 battery (NOT INCLUDED), G-Priv Baby can offer up to 85 watts of power.
Tank:
The Original SMOK TFV12 Baby Prince from SMOKTech is the upgraded version of TFV8 baby beast tank. The new mesh coils can produce denser clouds and purer flavor at the same wattage, which is an awesome improvement. These coils are newly designed, the light coil will emit beautiful light when you are vaping and the mesh coil has larger heating area to speed up heating process. Besides, this tank employs bulb glass tube, which can enlarge the e-juice capacity to 4.5ml. Every detail of TFV12 Baby Prince is the best guarantee for high-quality vaping.
Original Vapethink Steam Shark Fused Clapton Blue Ni80 Coil $4.99
The Original Vapethink Steam Shark Fused Clapton Blue Ni80 Coil is made from Nichrome 80 wires and features 0.25 ohm. This pre-coiled heating wire comes with 28GA x 3 + 38GA coils. This heating wire will be a good vaping choice for DIY.
Original Vandy Vape Replacement Coil Head for Berserker MTL Subtank $11.38
The replacement coil head features 1.8ohm resistance and work well at 7~13W / 3.5~4.8V. It is suitable for original Vandy Vape Berserker MTL Subtank / Vandy Vape Berserker MTL Kit.
This product come with 5 PCS in 1 pack. This item also has other Version to choose.
Replacement Tank Tube + Top Lid + Chimney for Dvarw V2 DL RTA Clone $5.99
Original VBRVAPE Replacement Pod Cartridge for Fin Starter Kit $2.99
The replacement pod cartridge has 1.5ml of juice capacity and is refillable. It comes with soft food grade rubebr mouthpiece. It is suitable for original VBRVAPE Fin pod system starter kit.
Старый 26.06.2018, 04:39 Автор темы   137
3FVAPE
Purge Serenity Koi Fish Hybrid Mechanical Mod Clone $27.99
The Purge Serenity Koi Fish Mechanical Mod Clone is a 26mm mech mod which tapers to 25mm on top. It features unique engraved artwork on the body, which is Koi fish pattern. The hybrid top cap allows more power hit. It is powered by single 18650 battery (NOT INCLUDED). This item also has other colors to choose.
Original ThunderHead Creations THC Tauren Mechanical Mod Original Price $84.90, Now Only $45.99
The Original THC Tauren Mech Mod from ThunderHead Creations is the first mechanical mod with innovative Ball style connected button, which allows the mod to be fired immediately without any delay. With a built-in battery tube, it can be powered by single 21700, 20700, and 18650 battery (not included). The precision machined body and unique luxury painting make THC Tauren Mech Mod more attractive. The top is not overhang with 24mm atomizers. Each one comes with its own serial number.
Original Squid Industries Double Barrel V2.1 150W VW Variable Wattage Box Mod Original Price $95.00, Now Only $75.99
The Original Squid Industries Double Barrel V2.1 mod combines exciting updates with the simple but powerful features of the original Double Barrel. Measuring only 3.5 high and about the size of the two 18650 high amp batteries that power it (BATTERY NOT INCLUDED), the Double Barrel has a sleek and compact chassis reinforced by stainless steel, ensuring only the best build quality and durability. Version 2.1 now comes with a new 0.47 top OLED display with indicators for wattage levels, atomizer resistance, and battery life. The Double Barrel now also has a power output from 5 to 150W. The Double Barrel is controlled by a single multi-function, tactile firing button coupled with a surrounding dial for wattage adjustment. The advanced chipset of the Double Barrel V2.1 allows for steady voltage output with Reverse Polarity Protection, Overheat Protection, and Short Circuit Protection. The Double Barrel V2.1 is a no-frills, classic mod for vapers who want a device that takes the most crucial features of a modern regulator mod and does them better than everything else out there. This item also has other colors to choose.
Ohmec RTA Rebuildable Tank Atomizer Clone $18.99
The Ohmec RTA Clone is a 30mm huge tank with 10ml capacity. It is constructed from stainless steel. Coming with triple posts build deck, it is easy to build dual coils on it. The gold plated contact pin provides great electrical conductivity.
Stutt-Art Bogati RTA Rebuildable Tank Atomizer Clone $18.99
Hussar The End RTA Rebuildable Tank Atomizer Clone $25.99
Hussar The End RTA Clone is a 22mm rebuildable tank atomizer with 3.5ml capacity. It is constructed from 316 stainless steel and ultem tank. The deck has dual posts design for single coil configuration. The tank comes with bottom airflow for optimal flavor.
This RTA comes without any drip tip.
YFTK Convergent RDA Rebuildable Dripping Atomizer Clone with BF Pin $23.99
The YFTK Convergent RDA Clone is a 22mm RDA constructed from 316 stainless steel. It is a simple coil RDA that is designed to produce an extremely smooth vapor by means of several convergent nozzles. Less amount of air can cool down a coil in the RDA and produce rich flavor vapor. This RDA is great for mouth to lung vaping.
Original SHELBI MODS Regga Hybrid Mechanical Mod + RDA Kit Original Price $99.90, Now Only $82.99
The Original SHELBI MODS Regga Mech Kit consists of SHELBI MODS Regga Mechanical Mod and Regga RDA. This item also has other colors to choose.
Mod:
The Original SHELBI MODS Regga Mech Mod is a 25mm, featuring its stunning pattern with high-end handcraft finishing. It is specifically designed for competition and comes with hybrid connection for more power hit. The innovative fire button on the bottom can fit the battery perfectly without any battery rattle. The mod is powered by single 18650 battery (NOT INCLUDED).
RDA:
The Original SHELBI MODS Regga RDA is a 25mm RDA, which has the same unique pattern as the Regga mech mod to fit perfectly. The RDA has a wide build deck with dual posts design for dual coils building. The air holes are positioned on both sides of the top cap. It is a real competition RDA for cloud-chasing.
Старый 27.06.2018, 04:55 Автор темы   138
3FVAPE
Original CoilART Mage 217W TC VW Variable Wattage Box Mod Original Price $59.99, Now Only $49.99
The Original CoilART Mage 217 Box Mod is a versatile regulated device that would provide convenient operation and high performance. Powered by dual 18650 / 20700 / 21700 batteries (NOT INCLUDED), this mod can fire up to 217W. You can also vape with its temperature control mode, using Ni / Ti / SS coils. It comes with self-adjusting battery contact. The atomizer resistance range is from 0.05 to 3.0ohm. This item also has other colors to choose.
Coppervape Spica Pro MTL RTA Rebuildable Tank Atomzier Full Kit Clone $24.99
The Coppervape Spica Pro MTL RTA is a 22mm rebuildable tank atomizer made from 316 stainless steel. The RTA is designed for throat hit and comes with 3 / 5 / 7-leaved air pins for your choice. The chimney height can be adjusted by included allen key. Coming with 3ml / 4ml of juice capacity and 5 adjustable airflow, this tank will bring you wonderful flavor and MTL experience.
Original Hugsvape Lotus RTA Rebuildable Tank Atomizer Original Price $34.99, Now Only $24.99
The Original Lotus RTA is a 24mm rebuildable tank with an aesthetic design of Lotus shape build deck, which is designed to accommodate dual coil builds. It has a push-to-refill scheme that makes it easier to refill eliquid. With an air conditioner slot style airflow system, the air hits the coils right from the side and bottom, delivering big clouds and excellent flavor. This item also has other colors to choose.
Original CoilART DPRO Mini RDA Rebuildable Dripping Atomizer with BF Pin Original Price $25.99, Now Only $21.99
The Original CoilART DPRO Mini RDA with 22mm diameter is a rebuildable dripping atomizer, made from stainless steel. It features postless design for easy single coil building. There are three honey comb airholes on each side that can be adjusted via rotating top cap, which will bring the smoothest and restricted direct lung feeling for you. What's more, it comes with three different 510 drip tips for various coils, the installed 5mm short one is best for small coils, the extra 8mm height curve one for big coils and 13mm one for MTL style. You can add the e-juice from the top or by squonking, and the inside juice well is deep to meet your large demand.
It comes with a bottom feeder pin. This item also has other colors to choose.
Original CoilART Mage 217W TC VW Variable Wattage Box Mod + Mage SubTank Kit Original Price $75.99, Now Only $58.49
The CoilART Mage 217 Kit consists of CoilART Mage 217 Box Mod and CoilART Mage Subtank. This item also has other colors to choose.
Mod:
Tank:
The Original CoilART MAGE SUBTANK is a 24mm clearomizer with 4ml of juice capacity. It has been installed a 0.2ohm Mage Mesh coil to provide smooth and optimal flavor with the bottom airflow system. The top lid comes with knurling design, which makes it easy to be screwed out for refilling. The 510 pin is gold plated, providing great conductivity. 810 drip tip is included.
Original Vapefly Firebolt Pre-loaded Cotton for E-cigarette Original Price $4.99, Now Only $3.59
The Original Vapefly Firebolt Cotton utilizes pure organic cotton. The pre-loaded cotton is very easy to wick. This cotton provides more capacity and clean pure flavor.
This product comes with 20 x Pre-loaded cotton.
Coppervape Replacement Spare Kit for Spica Pro MTL RTA Clone $1.59
The spare kit consists of 2 screws and 12 o-rings. It is suitable for Coppervape Spica Pro MTL RTA Clone.
Coppervape Replacement Drip Tip Kit for Spica Pro MTL RTA Clone $2.29
The replacement drip tip kit consists 1 Delrin drip tip and 1 SS drip tip. It is suitable for Coppervape Spica Pro MTL RTA Clone. It is not 510 drip tip.
This product comes with 2 PCS of drip tips in 1 pack.
Coppervape Replacement Drip Tip for Spica Pro MTL RTA Clone $1.99
The replacement drip tip is made of PEI. It is suitable for Coppervape Spica Pro MTL RTA Clone. It is not 510 drip tip.
Coppervape Replacement Tank Tube for Spica Pro MTL RTA Clone $1.79
The replacement tank tube is made of glass with 3ml of capacity. It is suitable for Coppervape Spica Pro MTL RTA Clone. This item also has other Version to choose.
YFTK Replacement 510 Drip Tip + Top Cap + Decorative Ring Kit for Haku Venna RDA Clone $9.99
The replacement 510 drip tip and decorative ring are made from POM, and the top cap is made from PEI. They are suitable for YFTK Haku Venna RDA Clone. This item also has other colors to choose.
Старый 28.06.2018, 05:00 Автор темы   139
3FVAPE
Original Lost Vape Triade DNA250C 300W TC VW Variable Wattage Box Mod $164.95
After the Paranormal DNA250C Mod, Lost Vape brings us another DNA250C Mod, the Lost Vape Triade DNA250C, which is powered by triple 18650 batteries (NOT INCLUDED) and can fire up to 300W. The DNA250C chip features unique Replay mode, which allows vapers to select their own perfect vape and save to replay it over and over. This item also has other colors to choose.
Fatality RTA Rebuildable Tank Atomizer Clone $27.79
The Fatality RTA Clone is a 1:1 scale RTA with 28mm diameter and 4ml of juice capacity. It features side terminal postless deck and adjustable quad airflow. The unique airflow adjustment allows you to control the top and bottom airflow separately. Spare Ultem tank and drip tip is included. This item also has other colors to choose.
Original Aspire Spryte AIO 650mAh Pod System Starter Kit $29.99
Another great AIO pod system from Aspire, the Aspire Spryte, an all new design pod system, slim and stylish. The Spryte has an easy-to-fill 3.5ml or 2ml pod, it fits comfortably in the hand in use and is very discreet. It utilizes Aspires well known BVC coils and comes with a regular 1.8ohm coil and a second one 1.2ohm for use with nicotine salts. The Spryte has built-in 650mAh battery. This item also has other colors to choose.
Gemei All-in-one Battery Mod Starter Kit Clone with PCC $34.99
The Gemei Device Clone can be used as heat-not-burn device for cigarette or all-in-one e-cig kit for e-liquid. The cartridge has 1.0ml of juice capacity. The mod can be charged by putting it into the portable charging case. It is convenient and easy for starters to use. This item also has other colors to choose.
Original Aleader Bhive 100W TC VW Variable Wattage Squonk Box Mod + RDA Kit Original Price $59.00, Now Only $39.99
The Original Aleader Bhive Squonk BF Kit consists of Aleader Bhive Squonk Box Mod and Bhive RDA. This item also has other colors to choose.
Mod:
The Original Aleader Bhive Squonk Box Mod features beautiful resin side panel and refined zinc alloy body. The squeeze bottle has 7ml of juice capacity. Powered by single 18650 battery (NOT INCLUDED), this mod can deliver 100W maximum output. It also supports temperature control mode with Ni / Ti / SS coils.
RDA:
The Original Aleader Bhive RDA is a 24mm RDA that features beautiful resin top cap and drip tip. The dual post build deck comes with quad terminals for super easy building. The juice well is 6mm deep. The air enters from the dual bottom airholes and travels up to the bottom of the coil.
SJMY Replacement Front + Back Cover Panel for SXK Billet Box Mod Clone $32.99
The replacement front and back cover panel from SJMY is made out of Carbon Fiber and is suitable for SXK Billet Box Mod Clone.
Старый 29.06.2018, 05:14 Автор темы   140
3FVAPE
Z3US Hybrid Mechanical Mod Clone $35.99
The Z3US Mechanical Mod Clone is a 28mm mech mod which tapers to 25mm at top. It comes with hybrid top cap for more power hit and deep engraved columns and slots, which makes it look stunning. The fire button is active by magnets. The mod is powered by single 18650 / 20700 battery (NOT INCLUDED). Extra extension tube is included, which allows you to use dual 20700 batteries.
Caliber Saiga Hybrid Mechanical Mod Clone $14.99
The Caliber Saiga Hybrid Mechanical Mod Clone is constructed from 316 stainless steel. It features hybrid connection and high quality spring bottom firing button that will bring good feeling when pressing it. Adopting silver plated electrode can produce prefect electrical conductivity. The mod is powered by single 18650 battery (NOT INCLUDED).
Original VGME DPS75 75W TC VW Variable Wattage Box Mod $94.99
The Original VGME DPS75 Box Mod is a high-end stabilized wood mod, which can fire up to 75W with dual 18650 batteries (NOT INCLUDED). The DPS75 supports VW / TC / Bypass modes. The minimum resistance support is 0.05ohm (TC) / 0.15ohm (VW). The mod comes with several protections, including battery reverse protection, short circuit protection, low resistance warning, low voltage protection, and over-heating protection.
This mod will be shipped in random color. More options than what's on the image.
Original VGME X Pipe Mechanical Mod $41.79
The Original VGME X Pipe Mechanical Mod is a stabilized wood mech mod with protections. It is powered by single 18650 battery (NOT INCLUDED). The recommended resistance is from 0.18ohm to 0.3ohm. The mod comes with overtime protection, short circuit protection, and low voltage protection.
Original Digiflavor Drop Solo RDA Rebuildable Dripping Atomzier with BF Pin $34.95
The Original DROP Solo RDA is a collaboration by Digiflavor and TVC The Vapor Chronicles. DROP Solo RDA is a 22mm RDA, which features a unique single coil deck and horizontal 6-airholes side airflow control. It comes with optional PMMA low profile cap for different experience. The conical top cap design enhances the flavor. This item also has other colors to choose.
Original Coil Father King RDTA Rebuildable Dripping Tank Atomizer $8.99
The Original Coil Father King RDTA is a 25mm rebuildable tank atomizer with 6.5ml of juice capacity. The tank features dual post build deck with quad terminals for easy coil building. The filling port will be blocked by the plug in the cap. The bottom airflow is adjustable. 810 wide bore Delrin drip tip is included.
Ohmec RTA Rebuildable Tank Atomizer Clone $17.99
Original eXvape eXpromizer V3 Fire MTL RTA Rebuildable Tank Atomizer Original Price $34.00, Now Only $30.99
The Original eXvape eXpromizer V3 Fire MTL RTA is a 22mm rebuildable tank with 4ml of juice capacity. It features single-coil building deck, which has proven itself very well. It provides a very good and balanced combination of taste, vapor and throat hit in conjunction with the large chamber. Besides, different sized liquid channels and several adjustment positions of the liquid control ensure an optimal flow. Precise flow control allows using viscous (High VG) and low viscosity (High PG) liquids. It is a reliable MTL atomizer for mouth-to-lung lovers. This item also has other colors to choose.
Andromeda RDA Rebuildable Dripping Atomzier Clone with BF Pin $8.49
The Andromeda RDA Clone is a 24mm RDA constructed from stainless steel. It has a dual post buil deck which allows single or dual coil builds. The airflow hit the coil directly via the side airslots. The 510 contact pin is gold plated for high conductivity. Wide bore ultem drip tip is included.
Original Aleader Bhive RDA Rebuildable Dripping Atomzier with BF Pin Original Price $24.80, Now Only $13.59
Original Hotcig R-AIO 80W TC VW Variable Wattage Starter Kit Original Price $75.00, Now Only $53.99
The Original Hotcig R-AIO Starter Kit is a regulated mod kit which can adjust wattage from 1 to 80W with single 18650 battery (NOT INCLUDED). It is constructed from zinc alloy and aluminum alloy. The coil included is with 0.6ohm resistance. The mod is compatible with all size atomizers. This item also has other colors to choose.
Original Coil Father Replacement Tank Tube for King RDTA $1.39
The replacement glass tank tube has 6.5ml of juice capacity. It is suitable for original Coil Father King RDTA.
Время генерации страницы 0.66034 секунды с 15 запросами
