65667
210
101
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Coppervape Millennium Clone RTA V1.1 Rebuildable Tank Vape Atomizer 316SS + Glass, 4.0ml, 22mm Diameter Original Price $35.99, Now Only $29.99.
The Coppervape Millennium clone RTA Deck 1.1A slightly improved version of Millenniums deck made to meet its user's needs without modifying its essence and functionality. Two O-rings on the deck, one above and one below the juice channels, give a better sealing for users.With 3 bells,3 airflow deck for choice. ![]() Original IJOY Captain AirGo Pod System Vape Starter Kit 930mAh Original Price $29.99, Now Only $22.99. original IJOY Captain AirGo Kit is the first IP68 tri-proof auto-draw pod system kit. It will delight fans of compact devices. Stylish and modern appearance. The combination of metal and synthetic leather ensures a good high-quality feel and high durability in daily life. And through the new injection molding technology to achieve ultra-light, portable, and more robust design. Durable, easy to use, support coil replacement, and has a great flavor and vapor. The Captain AirGo is powered by 930mAh built-in battery for all-day use and a superb warm flavor-packed vape ![]() Coppervape Millennium Clone RTA V1.1 Replacement Glass Tank Tube 4.0ml Original Price $1.99, Now Only $1.39. Coppervape Millennium clone RTA V1.1 Vape Atomizer Replacement Tank Tube is made from glass and holds 4.0ml capacity. ![]() Coppervape Millennium Clone RTA V1.1 Replacement SS+PC Tank Tube 4.0ml Original Price $4.99, Now Only $3.59. Coppervape Millennium clone RTA V1.1 Vape Atomizer Replacement Tank Tube is made from stainless steel + PC and holds 4.0ml capacity. ![]() Coppervape Millennium Clone RTA V1.1 Replacement PEI Tank Tube 4.0ml Original Price $4.99, Now Only $3.59. Coppervape Millennium clone RTA V1.1 Vape Atomizer Replacement Tank Tube is made from PEI and holds 4.0ml capacity. ![]() Coppervape Millennium Clone RTA V1.1 Nano Kit Replacement Glass Tank Tube 2.0mL Original Price $1.99, Now Only $1.39. Coppervape Millennium clone RTA V1.1 Nano Kit Replacement Tank Tube is made from Glass and holds 2.0ml capacity. ![]() Coppervape Millennium Clone RTA V1.1 Replacement Nano Kit - 316SS + Glass, 2.0ml, 3-Chimney Original Price $14.99, Now Only $10.99. Coppervape Millennium clone RTA V1.1 Replacement Nano Kit, comes with 2.0ml glass tank tube and 3 PCS 316stainelss steel Chimney. ![]() Original GeekVape Replacement Squonk Bottle for Athena Squonk Kit - Translucent, 6.5ml Original Price $1.99, Now Only $0.99. The original GeekVape replacement squonk bottle is made out of food grade material and comes with 6.5ml e-liquid capacity. It is suitable for GeekVape Athena Squonk Kit.
102
Original FLHS Tiger Squonk Mechanical Box Mod 20700 Original Price $69.99, Now Only $20.99.
The original FLHS Tiger Mech mod is a 20700 squonk box mod with stunning tiger pattern on the battery door. Made from durable Bakelite material, it is powered by single 20700 battery (NOT INCLUDED). This mod will bring you excellent squonking experience. ![]() Original Movkin Disguiser 150W TC VW Variable Wattage Box Mod Original Price $55, Now Only $27.99. Movkin Disguiser 150W mod comes to change the way how vapor device looks. Just like the name Disguiser, it can hide the 90percent tanks in the current market except these RDAs. The elastic drip tip and the windows on the back door just make this concept work well. 150W output with Kanthal, Ni, Ti and SS modes can meet most vaper's demand. ![]() Original Vision Vapros iBox 1500mAh VV / VW Box Mod Original Price $49.99, Now Only $14.99. The Vapros iBox is a unique 25 Watt box MOD made by Vision. This device features a unique pull down fire button and an easy to use wattage adjustment dial. This powerful and compact device will fire an atomizer up to 25 watts, and is compatible with resistance down to 0.5ohm. The iBox includes a built in 1500mAh battery and can be charged with a standard USB cable. Also has a USB output so you can use the iBox as a power source to charge your other devices. Compatible with any 510 threaded atomizer. eGo threaded Clearomizer will require the use of a 510-eGo adapter. ![]() Original ZQ GO Pod System Vape Kit Original Price $29.99, Now Only $14.99. ZQ firstly introduces the CSA technology Whenever you puff the CSA (cellular spiral airflow) system guides the air now through the honeycomb mesh, thus the puff of air comes evenly and spirally into the atomizer coil with organic cotton, more smooth flavor and the coil wont easily get burnt.
103
Original Vaporesso LUXE 80 Pod System Vape Mod Kit Original Price $44.99, Now Only $37.99.
Vaporesso Luxe 80 is the new Pod Mod Kit of the Vaporesso Luxe series, the ergonomic body has a compact design, and the size is more refined than the previous. Luxe 80 gives you a luxurious feel combined with a classic appearance. ![]() Original KIZOKU Shima 18mm MTL Tank Vape Atomizer Original Price $30.82, Now Only $22.99. The original KIZOKU Shima 18mm MTL tank which is designed for KIZOKU OAKER 25W VW Kit. The KIZOKU Shima MTL comes with dual-use system to support both DIY coils and pre-made coil heads. And the KIZOKU Shima MTL Tank has 0.8~1.0 mm air inlet hole and a user-friendly single coil deck. With the pre-made KCL1 0.7ohm Mesh Coil and DIY coils access in the package, you will have a wonderful vaping experience. ![]() Original KIZOKU OAKER 25W 1100mAh Battery Mod + MTL Tank Starter Kit Original Price $39.07, Now Only $31.99. original KIZOKU OAKER 25W VW Kit is not merely the representation of fine work; it is also the embodiment of delicate and high end. Compact design with 19mm, fine graining and fully build with machined stainless steel, Oaker delivers the ultimate hand feels experience. A designed dual-use system supports both DIY coils and pre-made coil heads, making it unique and compelling. What is more, Oaker was made to be much smarter and better by using 0.8~1.0mm air inlet hole and a user-friendly single coil deck. Therefore, Oaker gives more than what you expected. ![]() Original SMOKTech SMOK Thiner Pod System Vape Kit Original Price $29.99, Now Only $25.99. original SMOKTech SMOK Thiner Kit is a card-style and slim and convenient pod system device, features a high-capacity of 750mAh battery with a buttonless inhalation system, and the built-in mesh coil in the pod will bring you endless deliciousness. ![]() Original ETU Replacement Front + Back Door Panel Plates for dotMod dotAIO Vape Pod System Original Price $15.9, Now Only $12.9. The original ETU Replacement Front and Back Door Panel Plates is made from PC and suitable for dotMod dotAIO Vape Pod System. ![]() Original ZQ GO Pod System Replacement Pod Cartridge Original Price $8.99, Now Only $4.99. The GO Pod Cartridge is designed especially for the ZQ GO Pod Kit, coming with 2ml e-juice capacity. ![]() Original YouDe UD Zirconia Ceramics Tweezers with Sharp Head Original Price $8.99, Now Only $4.99. Tweezers for DIY. The head part is made of ceramic, which is good at thermal insulation, so as to protect users' hands. The other parts are made of stainless steel. Easy to use and clean. ![]() Original YouDe UD Koh Gen Do Organic Cotton for RBA / RDA / RTA Vape Atomizer Original Price $4.99, Now Only $2.69. Japanese Koh Gen Do Cotton is known for its superior flavor and wicking ability. ![]() Original Youde UD Cotton Hook for RBA / RDA / RTA Vape Atomizer Original Price $8.99, Now Only $4.99. original YouDe UD Cotton Hook is a perfect DIY tool for rebuildable atomizers. ![]() Original YouDe UD Miracle Cotton for RBA / RDA / RTA Vape Atomizer Original Price $6.99, Now Only $3.99. original YouDe UD Miracle Cotton is Suitable for for RBA / RDA / RTA Vape Atomizer. ![]() Original Youde UD Heating Wire for RBA / RTA / RDA Original Price $18.99, Now Only $14.99. The original Youde heating wire is suitable for RBA / RTA / RDA atomizers. There are 6 kinds of different wires in the package. Hope this wire set can meet your demands. ![]() Original YouDe UD SS316L 28 AWG Resistance Wire for RBA Original Price $4.99, Now Only $2.39. The original YouDe UD SS316L Resistance Wire is suitable for RBA / RTA / RDA Vape Atomizer. With 28GA / 0.32mm and 30FT (10m) length. ![]() Original YouDe UD Twisted Fuse Clapton Coil Set Original Price $8.99, Now Only $4.99. original YouDe UD Staggered Fuse Clapton Coil Set, including SS316L Twisted Fuse Clapton Coil, (26GA x 2) x 2 + Ribbon ![]() Original YouDe UD Staggered Fuse Clapton Coil Set Original Price $8.99, Now Only $4.99. original YouDe UD Staggered Fuse Clapton Coil Set, including SS316L Staggered Fuse Clapton Coil, (26GA + Ribbon) x 2 + 32GA ![]() Original YouDe UD Staggered Fuse Clapton Coil Set Original Price $8.99, Now Only $4.99. original YouDe UD Staggered Fuse Clapton Coil Set, including SS316L Staggered Fuse Clapton Coil, (26GA x 3 + 32GA) ![]() Original YouDe UD Kanthal A1 30 AWG Resistance Wire for RBA Original Price $5, Now Only $2.29. The original YouDe UD Kanthal A1 Resistance Wire is suitable for RBA / RTA / RDA Vape Atomizer. With 30GA / 0.25mm and 30FT (10m) length. ![]() Original YouDe UD Ferris Wheel Coil Box with 7 x 10 PCS Prebuilt Coils - Kanthal A1, 0.5ohm / 0.6ohm / 1.0ohm / 1.2ohm Original Price $14.99, Now Only $13.99. The original Youde UD Ferris Wheel Coil Box is perfect for those that are on-the-go or like having the luxury of prebuilt coils for a faster rebuilding of RTA's or RDA's equating in less downtime for vaping, featuring a mix of coils that range from 0.5 to 1.2ohm in a different array of shapes and sizes. ![]() Original YouDe UD Pre-built Alien Coil Kit Original Price $6.99, Now Only $4.99. original YouDe UD Pre-built Alien Coil Kit, including Kanthal A1 Alien coil, (26GA x 3 + 32GA) ![]() Original YouDe UD Ni200 Resistance Wire for RBA / RTA / RDA Vape Atomizer Original Price $5.99, Now Only $2.99. The original YouDe UD Ni200 wire for use in building coils on temperature control mods. Wire comes supplied on a 10m spool, 30 Gauge, 0.25mm in diameter. ![]() Original Coilology MTL 4-IN-1 Prebuilt Coils Set - SS316L, MTL Coil / 0.70ohm MTL Clapton / MTL Fused Clapton / MTL Staple Original Price $14.99, Now Only $7.99. The original Coilology MTL 4-in-1 Prebuilt Coils Set is collectively crafted for Mouth-to-Lung builders looking for a range of coil builds with the convenience of pre-coiled setting. Each coil is machine-twisted for precise and consistent building material, presenting different types of structures optimized for flavor recreation and vapor-orientated performance. Each coil set comes in an efficient portable box to carry 4 different types of coils, with different amount of prebuilt coils in each that totals 24 ready-to-use coils. ![]() Original HorizonTech Falcon King Replacement F3 Mesh Coil - 0.2ohm (3 PCS) Original Price $14.99, Now Only $9.99. The original HorizonTech Falcon King F3 Mesh Coil come in a 3-pack and are made for the original Falcon tank as well as the Falcon King Tank. Featuring multiple wicking material options and parallel as well as mesh coil designs for a wide variety of tastes and vape styles.
104
Original Auguse V1.5 MTL RTA Rebuildable Tank Vape Atomizer w/ 5 Airflow Inserts - Black, SS + PCTG, 4ml, 22mm Diameter Original Price $29.99, Now Only $25.99.
The original Auguse V1.5 MTL RTA rebuildable tank atomizer is constructed from stainless steel in 22mm diameter and features 5 airflow inserts option for your different flavors (2.0mm, 1.5mm, 1.2mm, 1.0mm, 0.8mm). The Auguse V1.5 MTL RTA can be loaded 4.0ml e-juice through the bottom fill port. The build deck is oriented to accept a single coil configuration with two posts with a single large open terminal on each (coil is not included), affixed from the side via flathead screws. It is very easy to build. ![]() Original Vaporesso LUXE 80S 80 S Pod System Vape Mod Kit Original Price $44.99, Now Only $36.99. The Vaporesso LUXE 80S 80 S 80W 18650 Pod kit is another new member in the luxurious/stylish LUXE series. And the Vaporesso LUXE 80S is powered by a single 18650 battery (not included) to bring longer enjoyment and vape experience. Secondly, the Vaporesso LUXE 80S is a 80W pod mod powered by Axon Chip with user-friendly UI and functions ![]() Original Auguse MTL RTA V1.5 Vape Atomizer Replacement Tank Tube 4.0ml Original Price $14.99, Now Only $5.99. original Auguse MTL RTA V1.5 Vape Atomizer Replacement Tank Tube holds 4.0ml capacity. ![]() Original Auguse MTL RTA V1.5 Nano Kit Replacement Tank Tube 2.0ml Original Price $14.99, Now Only $5.99. original Auguse MTL RTA V1.5 Nano Kit Replacement tank tube holds 2.0ml capacity. This tank tube is used on Nano Kit and suitable for Auguse MTL RTA V1.5 vape atomizer. ![]() Original Auguse MTL RTA V1.5 Vape Atomizer Replacement Nano Kit 2.0ml Original Price $14.99, Now Only $9.99. original Auguse MTL RTA V1.5 Vape Atomizer Replacement Nano Kit, including tank tube and chimney, holds 2.0ml capacity. ![]() Original Dovpo Topside Dual (SE) Squonk Box Mod Replacement Battery Door Original Price $9.99, Now Only $7.99. The original Dovpo Topside Dual (SE) Squonk Box Mod Replacement Battery Door is designed especially for the Dovpo Topside Dual 200W Squonk Box Mod.
105
Atto 18350 / 18650 Mechanical Tube Mod Clone - Black Original Price $22.99, Now Only $14.99.
Atto clone mechanical mod is made from Stainless Steel. It is powered by 1 x 18650 / 18350 battery (NOT INCLUDED). The mod is equipped with a MOSFET. ![]() Coppervape Hussar The End Clone RTA Rebuildable Tank Vape Atomizer - 316SS + PEI, 3.0ml, 22mm Diameter Original Price $29.99, Now Only $27.99. The Coppervape Hussar The End clone RTA Rebuildable Tank Vape Atomizer is made from 316 stainless steel and PEI. The 22mm RTA holds 3.0ml capacity. The single coil building deck with 2.5mm airflow pin pre-installed. ![]() Coppervape Hussar Clone RTA Replacement Dual Coil deck with 1.3mm / 1.0mm Airflow Pin Original Price $9.99, Now Only $7.99. The Coppervape Hussar clone RTA Replacement Dual Coil deck comes with 1.3mm (pe-installed) and 1.0mm Airflow Pin. ![]() Coppervape Hussar the end Clone RTA Replacement Tank Tube 3.5ml Original Price $3.99, Now Only $2.59. The Coppervape Hussar the end clone RTA Replacement Tank Tube holds 3.5ml capacity. ![]() Coppervape Hussar Clone RTA Replacement 1.0mm MTL Airflow Pin Original Price $3.99, Now Only $2.99. The Coppervape Hussar clone RTA Replacement 1.0mm MTL Airflow Pin, comes with 1 PC / Pack. ![]() Coppervape Hussar Clone RTA Replacement 1.3mm Airflow Pin Original Price $2.99, Now Only $1.99. The Coppervape Hussar clone RTA Replacement 1.3mm Airflow Pin, comes with 1 PC / Pack. ![]() Replacement Ring for DotMod Dotaio and DotMod Dotaio Mini Pod System Original Price $4.99, Now Only $2.99. The replacement ring is made from rubber and is suitable for DotMod Dotaio and DotMod Dotaio Mini Pod System
106
Replacement Frame for dotMod dotAIO SE Vape Pod System - Ice Blue Original Price $69.99, Now Only $59.99.
This replacement PC Frame is only suitable for dotMod dotAIO SE Vape Pod System. ![]() DEV Whistle V3 Drip Tip Clone for dotMod dotAIO Pod / Billet Box Vapor Box / DELRO Box Original Price $9.99, Now Only $5.99. The DEV Whistle V3 clone Drip Tip is made from PMMA and is suitable for BB / Billet Box Vapor Box / DELRO Box / dotMod dotAIO Pod System. ![]() DEV Whistle V3 Clone Drip Tip + Button + Small Button for dotMod dotAIO Pod Original Price $20.99, Now Only $14.99. The DEV Whistle V3 clone Drip Tip + Button + Small Button Set is made from PMMA and is suitable for dotMod dotAIO Pod System.
107
Original Uwell Koko Prime (Vision) 18W Pod System Vape Kit Original Price $39.99, Now Only $33.49.
The authentic Uwell Koko Prime (Vision) Pod System vape Kit is constructed of PCTG & PC with translucent body and replaceable decorative panels. Uwell Koko Prime (Vision) Pod kit is powered by built-in 690mAh battery with 1.6A Type-C charging. Uwell Caliburn KOKO Prime (Vision) features draw-activated design, easy to operate. Uwell Caliburn KOKO Prime (Vision) cartridge has FeCrAl 1.0ohm coil, FeCrAI UN2 Meshed-H 0.8ohm coil, 2.0ml capacity with top filling design. Caliburn KOKO Prime (Vision) also is compatible with Caliburn G coils and can switch between MTL and DTL vaping. Uwell Caliburn KOKO Prime pod adopts Exclusive Patented Pro-Focs Flavor Testing Technology ![]() Original Uwell Aeglos P1 80W Pod System Vape Mod Kit Original Price $59.99, Now Only $43.89. The authentic Uwell Aeglos P1 Kit is a Pod Mod device with exquisite size, elegant leather inlaid in the body, comfortable and non-slip. The metal part of the body is made of zinc alloy and aluminum alloy, and the matte texture is high-quality and durable. Remove the battery cover on one side, you can see that Aeglos P1 Kit is powered by a single 18650 battery (not included), which is replaceable and supports Type-C 5V / 2A fast charging. Comes with a 0.96 inch high-definition TFT color display, the screen can clearly display every data, and has a device lock to accidentally firing. The chip-set inside functions multiple circuit protection, providing a stable, safe and reliable output. it's very funny due to puff counting to keep track of your vaping. As for the 4ml capacity Pod tank, it fits UN2 Meshed series coils, pre-installed 0.2 ohm coils that will bring a DTL vaping; and the UN2 Meshed-H 0.6 ohm coils will bring the RDL or MTL vaping. Featuring Pro-FOCS technology to ensure an authentic flavor of the e-juice, the cartridge and coil are both replaceable, replace them whenever it's needed. Comes with adjustable airflow, You just need to rotate the pod to adjust to different needs. The underfill is very simple, and effective leak-proof, the Pod cartridge with magnetic, it's easy to install. Also, The adapter available for switching to an atomizer with a 510 connection. (Adapter is not included.) ![]() Original Vapefly Brunhilde SBS 100W Box Mod Kit with Kriemhild II Tank Original Price $149.99, Now Only $99.99. The authentic Vapefly Brunhilde SBS 100W Mod is a cooperative project between Vapefly and the "Vapefly Deutschland Offiziell" group, which equips with the Kriemhild Il W version as a kit. The German standard typical Brunhilde design adopts CNC 5-axis carving processed, and the 1800 seconds for carving a single wing. Brunhilde SBS's body is made of aerospace aluminum, it is light in weight, perfect in hand. It is compatible with a single 18650 / 20700 / 21700 battery (not included), bringing 100w max output. Using 5V / 2A Type-C fast charging to save more time. Built-in a 3S chipset that brings safety protections: short circuit / reversed battery connection / low voltage / high temperature / overcharge / 10s cut-off protection. The Brunhilde SBS mod comes with Kriemhild II W Version, which is applied to the Duplex mesh coil. With Duplex technology the coil fires up instantly, heats evenly, and creates a soft and delicate taste. The Kriemhild II RBA W Version capacity of 4ml is compatible with cotton & wire DIY or preinstalled coils, a set that has much vaping fun is more economical and more environmentally friendly. ![]() Original Vapefly Brunhilde SBS 100W Side by Side Vape Box Mod Original Price $99.99, Now Only $74.99. The authentic Vapefly Brunhilde SBS 100W Box Mod with aerospace aluminum casing, light in weight, and perfect in hand. The Vapefly Brunhilde SBS Mod is compatible with a single 18650 / 20700 / 21700 battery (not included). And the Vapefly Brunhilde SBS battery is a powerful Mod with max output 100W. With Type-C 2A fast charging, the Vapefly Brunhilde SBS Box Mod must bring you long-last vaping. Moreover, the Vapefly Brunhilde SBS battery has 3S Chip with six protections for safe vaping. ![]() Original Ambition Mods Converter 50W VW Variable Wattage Tube Mod - Full Black $53.99 Authentic Ambition Mods Converter 50W VW Variable Wattage Vape Tube Mod is powered by 1 x 18350 / 18650 battery (battery not included, 18650 Adaptor Tube included) with power output 1~50W. Equipped with 0.49 inch OLED screen, Converter Tube Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes. Constructed from aluminum and stainless steel, Converter Tube Mod 50W can be feasibly switched from a good mechanical mod to box mod, compatible with your favorite atomizers with 510 threading connection ![]() Original Ambition Mods Converter SBS Side-by-Side Box Mod - Full Black $79.99 Authentic Ambition Mods Converter SBS Side-by-Side Vape Box Mod is powered by 1 x 18350 / 18650 battery (battery not included) with power output 1~50W. Equipped with 0.49 inch OLED screen, Converter Box Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes. Constructed from aluminum and stainless steel, Converter Box Mod 50W can be feasibly switched from a good mechanical mod to box mod, compatible with atomizers up to 23mm. ![]() Original Mechlyfe x Fallout Vape Screamer RDA BF 24mm Rebuildable Dripping Vape Atomizer Original Price $35.99, Now Only $25.99. The authentic Mechlyfe x Fallout Vape Screamer RDA vape atomizer is designed for advanced vapers, who have a good understanding of ohms law and coil building. Fallout x Mechlyfe Screamer RDA is made of stainless steel with 24mm deck to build single coil / dual coils easily. The Screamer RDA, the cooperation between Mechlyfe and Fallout Vape, is compatible with squonk mods with Bottom Feed pin.
108
Original Vandy Vape PR SE Squonk Mod Kit with Requiem RDA Atomizer - 1 x 16850, 20700, 21700 Original Price $79.99, Now Only $59.99.
The PR SE Kit by Vandy Vape is a Special Edition Kit that includes the Pulse V2 Mod by Tony B & the Requiem RDA by El Mono Vapeador. This is a 95W Squonk Box Mod. Its made of Strong & Durable ABS Nylon. You can use a 20700, 21700, or 18650 Battery (not included) with the included Battery Adaptor. This has a Waterproof PCBA so cleaning this Device is a breeze. They do give you 2 x 7mL Squonk Bottles. There is no Bluetooth functionality. It does allow for USB Type-C Charging, but we dont recommend regularly using that method to charge your Device. Only as a last resort or an emergency.The RDA is Single Coil, has a low profile, with multiple Airflow Options (DL, RDL, & MTL). Included is a 24mm Beauty Ring & 3 Air Hoods. You will also receive 2 x Fused Clapton Coils .26 Ohms & a Winding Rod. ![]() Original Wotofo MDura 200W Box Mod - 5~20W, 2 x 18650 Original Price $49.99, Now Only $33.99. Original Wotofo Dual-18650 vape mod, max 200w output. Though lightweight, it's very durable with an exquisite leather wrap that's soft to grip. Powered by nexCHIP Technology and features rapid-firing in 0.001 seconds and fast 2A charging. Features a 0.96 inch color screen with an easy-to-navigate interface. ![]() Original Wotofo MDura 200W Mod Kit with nexMINI Sub Ohm Tank Atomizer - 5~200W, 2 x 18650, 3.5ml Original Price $69.99, Now Only $49.99. Original Wotofo MDura Vape Mod Kit pairs up a high wattage mod with a small-sized sub ohm tank and makes a fabulous combination that functions way better than you'd think! High-performing dual-18650 vape mod of excellent build quality, Capable of 200 watts, features a color screen with an easy-to-navigate interface. ![]() Original Wotofo nexMINI Sub Ohm Tank Atomizer - 3.5ml / 4.5ml, 22mm Diameter Original Price $29.99, Now Only $21.99. The Original Wotofo nexMINI Subtank has a child lock on the fill port. To fill the tank, push open the top cap, then press down the needle tip of your juice bottle into the fill port and squeeze the juice in. It completely leak-proof as well. Rugged PCTG Tube and Large Capacity Glass Tube Both Included, Offer SMRT V8 Baby Rebuildable Coil, RBA coil and replacement coil options.
109
SXK Duetto Lucido Clone MTL RTA Rebuildable Tank Vape Atomizer - 316 Stainless Steel, 2.5ml, 22mm Original Price $26.9, Now Only $24.9.
SXK DUETTO LUCIDO clone RTA is a rebuildable Mesh Atomizer, The MTL RTA is made from 316 stainless steel in 22mm diameter. The RTA has a small room with a single hole Air 1.2mm and a Deck for Single Coil with hole Mesh from 2.7mm. ![]() Original Lost Vape Hyperion DNA 100C Box Mod - 1~100W, 1 x 18650 / 20700 / 21700, Evolv DNA100C Original Price $148, Now Only $99.99. The Original Lost Vape Hyperion DNA 100C Vape Mod is powered by single 21700 / 20700 / 18650 battery (Not Included) with 100W max output. The Mod is constructed of Zinc-Alloy and LSR with ergonomic design. It adopts the newest DNA 100C chip with military grade tri-proof: IP68 Waterproof, IP68 Dustproof, Shock Resistant for durability and functionality. Lost Vape Hyperion DNA 100C Box Mod is equipped with 0.9" 80 x 160 screen to clearly show the vaping data. With 3A Type-C fast charging port, it would bring wonderful and on-the-go vaping experience. ![]() Original Uwell Aeglos P1 Replacement Empty Pod Cartridge - 4.0ml (1 PC) Original Price $8.99, Now Only $5.99. Original Uwell Aeglos P1 Pod Cartridge is designed especially for the Uwell Aeglos P1 Vape Mod Kit. Made of PCTG food-grade safe material which has a capacity of 4.0ml, it can be easily refilled. Uwell Aeglos P1 Cartridge without coil but it is compatible with the most Uwell Mesh Coils, which enhances the flavor and brings an excellent DTL vaping experience. Plug and unplug to change the coil, quite easy and convenient. The powerful magnet at the bottom of the Aeglos P1 Pod ensures a perfect match with the mod. Featuring a bottom refill stoppered by a silicone plug. You need to remove the pod first, turn it upside down and open the silicone plug for filling. 1pc each pack. ![]() Original Uwell Aeglos P1 Replacement Coils Original Price $14.99, Now Only $9.99. The Original Uwell Aeglos P1 Replacement mesh Coils is designed to boost flavor and vapor production from your favorite E-liquids. There are 0.6ohm UN2 Meshed-H Coil designed for the Uwell Aeglos P1 Kit. The 0.6ohm UN2 Meshed-H Coil has the greatest advantage between 23W~27W, the feeling of vaping hitting the throat is really good. Pressing to install is super simple. ![]() Original Wotofo nexMINI Sub Ohm Tank Replacement RBA Coil Original Price $14.99, Now Only $7.59. The nexMINI Sub Ohm Tank RBA Coil is designed especially for the Wotofo nexMINI Sub Ohm Tank. ![]() Original Wotofo nexMINI Sub Ohm Tank Replacement Coil Original Price $14.99, Now Only $7.59. The Wotofo nexMINI Subtank is a crucial component for many of our most renowned vaping kits, like the MDura Kit and the MDura Mini Kit. This amazing Subtank allows for convenient use, easy refills, and a design that eliminates the risk of leaking the vape juice while refilling the tank. The nexMINI Subtank also allows for a tailor-made experience through the adjustable airflow and several types of Sub-Ohm coils with unique qualities. ![]() Original Vapefly Kriemhild II Replacement RBA Coil for Vapefly Brunhilde SBS Kit / Kriemhild II Sub Ohm Tank Original Price $14.99, Now Only $7.99. The Original Vapefly Kriemhild II RBA Coil is suitable for your Vapefly Brunhilde SBS Kit / Vapefly Kriemhild II Sub Ohm Tank vape atomizer. The Vapefly Kriemhild II Coil comes with RBA Coil-0.6ohm. ![]() Original Vapefly Kriemhild II RMC Coil for Vapefly Brunhilde SBS Kit / Kriemhild II Sub Ohm Tank Original Price $14.99, Now Only $7.99. The Original Vapefly Kriemhild II Replacement RMC Coil is suitable for Vapefly Brunhilde SBS Kit / Vapefly Kriemhild II Sub Ohm Tank. ![]() Original Vapefly Kriemhild II RMC Coil Replacement Wire + Cotton Kit Original Price $12.99, Now Only $6.99. The Vapefly Kriemhild II RMC Coil Wire & Cotton as a spare part. Designed for Vapefly Brunhilde SBS Kit / Vapefly Kriemhild II Sub Ohm Tank, the Vapefly Kriemhild II RMC Coil Wire & Cotton bring you the joy of DIY coil.
110
Original GeekVape Z RDA Rebuildable Dripping Vape Atomizer - BF Pin, Dual-Coil, 25mm Original Price $33.99, Now Only $26.1.
Original GeekVape Z RDA with 25mm diameter is a leak-proof RDA vape atomizer with a Z-rated zero-leakage design for optimal leak-proof performance. GeekVape Z RDA has a unique top-to-bottom leak-proof airflow system, which allows air to flow more quickly to the internal connector, to the coil, and to fully contact the coil for a better effect and a more intense, pure flavor. A special point is that the GeekVape Z RDA's anti-spit design prevents accidental spitting out of liquid, so that users will not accidentally inhale the oil when using it, and it can operate with low noise. ![]() Original Mike Vapes & DOVPO & Signature Mods Clutch X18 Mechanical Vape Box Mod - 2 x 18650 Original Price $149.99, Now Only $129.99. Dovpo Clutch X18 Mod is another great mod created by Signature Tips, Mike Vapes & DOVPO! It is the most anticipated parallel mechanical mod created by the top leaders of the industry. It has tons of safety features first for any parallel type mechanical mods! This mod is not for new starters or beginners. ![]() Original Univapo Symba RDA Rebuildable Dripping Vape Atomizer - Mesh Coil / Single coil / Dual coil / Triple Coil, 25mm Original Price $29.99, Now Only $19.99. The Original Univapo Symba RDA vape atomizer is the world's first RDA which supports both mesh coil and regular coil: single coil / dual coil / triple coil for versatile vaping. Univapo Symba features two airflow control: Honeycomb AFC (airflow control) for RDL and regular AFC for DTL. Symba RDA provides unique deck design for cutting coil legs more convenient. And drip tip's inverted groove design can prevent condensation from climbing into the mouth.
111
Original SMOKTech SMOK G-PRIV Pro 80W Pod Mod Kit - VW 5~80W, 1 x 18650, 5.5ml, 0.23hom / 0.4ohm Original Price $48.99, Now Only $32.99.
Original SMOKTech SMOK G-PRIV Pro 80W Pod Mod Kit comes with compact, sleek and stylish appearance with exquisite matte coating. SMOK G-PRIV Pro Pod Kit is powered by single 18650 battery (not included) with up to 1.4A Type-C charging and adjustable wattage of 5~80W. ![]() Original SMOKTech SMOK G-PRIV 80W Pod Mod Kit - VW 5~80W, 2500mAh, 5.5ml, 0.23ohm / 0.4ohm Original Price $49.99, Now Only $33.99. Original SMOK G-PRIV Pod 80W Kit comes with compact, sleek and stylish appearance with exquisite matte coating. SMOK G-PRIV Pod Kit is powered by 2500mAh battery with up to 1.4A Type-C charging and adjustable wattage of 5~80W. ![]() 510 Drip Tip for RTA / RDA / RDTA / Sub Ohm Tank Vape Atomizer Original Price $4.99, Now Only $2.59. The 510 Drip Tip is suitable for RTA / RDA / RDTA / Sub Ohm Tank Vape Atomizer. ![]() Four One Five 415 Clone RTA Ultima Rebuildable Tank Atomizer - 2.0ml, MTL / RDL, 22 Diameter Original Price $24.99, Now Only $17.99. The Four One Five 415 clone RTA Ultima Rebuildable Tank Atomizer holds a 2.0ml e-juice capacity with top filling system in 22mm diameter. It is made of Stainless Steel (body) and PCTG (Tank tube). It supports MTL / RDL air flow ring, bringing your excellent vaping experience.
112
Original Univapo Unico Pod System Vape Kit - 1500mAh, 4.0ml Original Price $29.99, Now Only $21.99.
Univapo Unico Pod Kit, the minimal and exquisite case mod accompanies 0.3ohm and 0.6ohm lattice loops, ideal for DL vaping and making large mists. On the off chance that you are a new hand to a mod or a client new to changing force, it is energetically prescribed for you to pick Unico. ![]() Original Univapo Miso Pod System Vape Kit - 600mAh, 2.0ml Original Price $22.99, Now Only $14.99. The new Univapo MISO is going to bring you a new vaping experience. Our fast charge is the fastest and safest charging technology to help you get MISO from zero to ready to go. With a 600mAh battery, the MISO will not only charge really fast, but it will also have whole-day lasting battery life. The perfect combination between temperature and the e-liquid control system makes nicotine release in the best way. ![]() SXK Delro Clone AIO Mod Kit Replacement Door Cover Panel Plate - Translucent Original Price $20.99, Now Only $14.9. The SXK Delro Clone AIO Mod Kit Replacement Door Cover Panel Plate comes with 2 PCS / Pack. ![]() SXK Delro Clone AIO Mod Kit Replacement Fire / Adjustable Button Key Original Price $14.99, Now Only $7.9. The SXK Delro Clone AIO Mod Kit Replacement Button Key is made from stainless steel and comes with 2 PCS / Pack (1 Fire button and 1 Adjustable button). ![]() Original Univapo Miso Pod System Replacement Pod Cartridge (3 PCS) Original Price $14.99, Now Only $7.99. The Miso Pod Cartridge is designed especially for the Univapo Miso Pod System Kit. The pod cartridge holds 2.0ml and with 1.2ohm coil.Comes with 3 PCS / Pack. ![]() Original Univapo Unico Pod System Replacement Pod Cartridge - 4.0ml (1 PC) Original Price $10.99, Now Only $5.99. The Unico Pod Cartridge is designed especially for the Univapo Unico Pod Kit. Holds 4.0ml capacity and comes with 1 PC / Pack. ![]() Original Univapo Unico Pod System Replacement Coil - 0.3ohm, (3 PCS) Original Price $14.99, Now Only $8.99. The Unico Replacement Coils are perfectly compatible with Univapo Unico Pod System Vape Kit. 3 PCS / Pack
113
Original Voopoo Musket 120W Mod Kit with PnP Pod Tank Atomizer - VW 5~120, 2 x 18650, 4.5ml, 0.15ohm / 0.2ohm Original Price $74.99, Now Only $47.99.
Original VOOPOO MUSKET Vape Mod Kit is carefully crafted from space aluminum alloy, which looks high-end and durable. The ergonomic design makes the body very easy to grasp. The unique design of the body is powered by 2 x 18650 batteries (not included), which can provide a maximum power output of 120W. ![]() Original Voopoo Musket 120W VW Vape Box Mod - VW 5~120W, 2 x 18650 Original Price $59.99, Now Only $38.99. Original VOOPOO MUSKET Vape Box Mod with ergonomic body design which is carefully crafted from space aluminum alloy looks high-end and durable, and very easy to grasp. ![]() Original Voopoo Drag X Plus Pro 100W Mod Kit with TPP 2.0 Pod Tank Atomizer - VW 5~100W, 1 x 18650 / 21700, 5.5ml Original Price $79.99, Now Only $58.99. Authetnic Voopoo Drag X Plus Pro 100W Mod Kit with TPP 2.0 Pod Tank Atomizer. The Voopoo Drag X Plus Pro 100W vape box Mod is powered by 1 x 18650 / 20700 battery (not included) and supports wattage adjustable from 5W to 100W. The TPP 2.0 Pod Tank Atomizer holds 5.5ml capacity and compatible with All TPP Coils (not included). ![]() Original Voopoo Drag X Plus Pro 100W VW Vape Box Mod - 5~100W, 1 x 18650 / 21700 Original Price $69.99, Now Only $44.99. The Voopoo Drag X Plus Pro 100W vape box Mod is powered by 1 x 18650 / 20700 battery (not included) and supports wattage adjustable from 5W to 100W.
114
5AVape Melampous Clone RTA Rebuildable Tank Vape Atomizer - MTL Vaping, 316SS, 4.0ml, 22mm Original Price $33.99, Now Only $26.99.
The 5AVape Melampous clone RTA is a 22mm rebuildable vape atomizer. The RTA is with liquid adjustment, top refill and the airflow adjustment takes place through the rotation of the tank. ![]() Original ZQ Xtal SE Pod System Vape Kit - 520mAh, 1.8ml Original Price $24.99, Now Only $14.99. The Original ZQ Xtal SE Pod System Vape Kit is built-in 520mAh battery and 1.8ml capacity pod cartridge. ![]() Original VOOPOO SEAL Pod System Vape Kit - 1200mAh, VW 5~40W, 2.0ml, 0.8ohm / 1.2ohm Original Price $38.99, Now Only $29.99. Original VOOPOO SEAL Pod System Vape Kit is a three-proof pod system device with a built-in 1200mAh integrated battery. It uses an advanced IP66 chip to be water-proof, dust-proof and shock-proof, allowing you to be fearless wherever you are during use. There is a layer of skin-friendly liquid silicone outside the body which allows you to handle various challenges with ease. The 1200mAh built-in battery can bring 5~40W output power.
115
MK2 Special Style Mechanical Mod - Black Gold, Brass, 1 x 18650, Albert Limited Edition Original Price $33.99, Now Only $26.99.
The MK2 Special Clone Mechanical Mod is made from brass and features an unique locking system and fire button, internals made in top notch brass alloy provides an unique conductivity like no other. The mech mod is powered by 1 x 18650 battery (not included). ![]() Original Curdo Smart X Pod Kit - 650mAh, 2.0ml Original Price $20.99, Now Only $13.99. Original Curdo Smart X Kit is a pod system with an ultra-compact design, it has a built-in 650mAh battery which made of 34 stainless steel materials is excellent, and can be grasped with one hand. The 650mAh battery can be used for a long time, and there is a USB charging port at the bottom for charging. The whole body has no buttons, you only need to take a puff and it will be activated. Smart X Kit is also accompanied by 3 kinds of indicator lights to remind you of the device status. Smart X pods have a capacity of 2.0ml and come with a 1.0ohm coil that cannot be knockdown. Curdo Smart X Kit will bring you an endless aftertaste. Smart X pod is fillable, the side filling is very convenient, compared to disposable vape kit, Curdo Smart X Kit is really environmentally friendly, and the arched drip tip fits your mouth perfectly. ![]() Original Curdo Smart X Replacement Pod Cartridge - 2.0ml (3 PCS) Original Price $14.99, Now Only $7.99. The Smart X Pod Cartridge is designed especially for the Curdo Smart X Pod System Vape Kit. ![]() MK2 Special Style Mechanical Mod - Black Gold, Brass, 1 x 18650, Skull Limited Edition Original Price $33.99, Now Only $26.99. The MK2 Special Clone Mechanical Mod is made from brass and features an unique locking system and fire button, internals made in top notch brass alloy provides an unique conductivity like no other. The mech mod is powered by 1 x 18650 battery (not included).
116
Original Ambition Mods Converter SBS Box Mod - Silver, 1~50W, 1 x 18350 / 18650 $79.99
Original Ambition Mods Converter SBS Side-by-Side Vape Box Mod is powered by 1 x 18350 / 18650 battery (battery not included) with power output 1~50W. Equipped with 0.49 inch OLED screen, Converter Box Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes. Constructed from aluminum and stainless steel, Converter Box Mod 50W can be feasibly switched from a good mechanical mod to box mod, compatible with atomizers up to 23mm. ![]() Original Ambition Mods Converter SBS Box Mod - Black Dot, 1~50W, 1 x 18350 / 18650 $79.99 Original Ambition Mods Converter SBS Side-by-Side Vape Box Mod is powered by 1 x 18350 / 18650 battery (battery not included) with power output 1~50W. Equipped with 0.49 inch OLED screen, Converter Box Mod supports constant power output, constant temperature control output in Ni / 316L / Ti materials (200~600'F / 100~315'C), TCR mode, By-pass mode and other modes. Constructed from aluminum and stainless steel, Converter Box Mod 50W can be feasibly switched from a good mechanical mod to box mod, compatible with atomizers up to 23mm. ![]() Original GeekVape OBELISK 200 Box Mod - 5~200W, 2 x 18650 Original Price $49.99, Now Only $39.99. Original GeekVape OBELISK 200 VW Vape box Mod features a portable design that makes it the perfect on-the-go companion. The extraordinary portability is only possible thanks to the CNC machining technique, one-step engraving a single block of aluminum. ![]() Original GeekVape Obelisk 200 Box Mod Kit - 5~200W, 2 x 18650, 5.5ml, 0.2ohm Original Price $69.99, Now Only $49.99. Original GeekVape OBELISK 200 VW Vape box Mod features a portable design that makes it the perfect on-the-go companion. The extraordinary portability is only possible thanks to the CNC machining technique, one-step engraving a single block of aluminum. The Obelisk Tank has 5.5ml of e-liquid capacity, it is designed to take full advantage of the childproof lock design and easy top-filling operation of the tank. ![]() Original Uwell Whirl T1 Pod Mod Kit - 1300mAh, 3.0ml, 0.75ohm Original Price $33.99, Now Only $27.59. Original UWELL WHIRL T1 pod system vape Kit uses the Pro-FOCS Technology to create a realistic taste, and its integrated pod and coil meet the rich taste experience.
117
Original Vandy Vape Jackaroo Mini 128W Box Mod Kit - 5~128W, 4000mAh, 4.0ml, 0.15ohm Original Price $69.99, Now Only $49.99.
Original Vandy Vape Jackaroo Mini Kit is the mini version of Jackaroo Kit with ergonomic design and small size for comfortable holding. It is powered by dual 18650 built-in rechargeable battery which is equal to 4000mAh cell. With IP67 waterproof, shockproof and dustproof, there is no need to worry about rains or dropping by accident. The upgraded Vandy Chip enables Jackaroo Mini to provide you different modes of Power / Bypass / Voltage / TC-NI / TC-SS / TC-TI, and some safety protections are also available for Jackroo Mini. It is equipped with a 4.0ml tank atomizer that is compatible with VVC series coils. ![]() Temple RDA 28mm Clone, with Acrylic Cap + BF Pin Original Price $14.99, Now Only $11.99. The Temple 28mm RDA Clone is made from stainless steel in 28mm outer diameter. Comes with acrylic top cap and bottom feeder pin for squonk mods. The 28mm Temple Clone RDA is with classic dual-post deck design, with each post bringing you squared off 3mm post holes. This update allows enough room for exotic coils or large gauge wire builds. The Temple 28mm Clone RDA features a chamber reducer which not only improves the flavor given, but also positions the airflow intake higher to give a top-to-bottom airflow.
118
5AVape Rose V2S RTA Clone Rebuildable Tank Atomizer - 316 Stainless Steel, 22mm Diameter Original Price $34.99, Now Only $28.99.
The 5AVape Rose V2S clone RTA rebuildable tank atomizer is made of 316 stainless steel. You can rest your inverted Rose while re-coiling without fear of spilling your e-juice. ![]() ULTON MELAMPOUS Chorus RTA Clone Rebuildable Tank Vape Atomizer - SS + PMMA, 4.0ml, 22mm Diameter Original Price $34.99, Now Only $27.99. The ULTON MELAMPOUS Chorus clone RTA Rebuildable Tank Vape Atomizer is made from stainless steel in 22mm diameter and PMMA tank tube holds 4.0ml capacity. The RTA is faithful to MTL roots (2 x 0.8 flat) and Low profile feeding. The AFC is with three holes of 1.7mm & two of 1.0mm on each side.
119
Original Wotofo MDura Mini 80W VW Box Mod - VW 5~80W, 1 x 18650 Original Price $39.95, Now Only $27.99.
The Wotofo MDura Mini box Mod is with compact side-by-side appearance. The MDura Mini box Mod is powered by 1 x 18650 battery (not included) and supports wattage adjustable from 5W to 80W. ![]() Original Wotofo MDura Mini 80W VW Box Mod Kit with nexMINI Sub Ohm Tank Atomizer - VW 5~80W, 1 x 18650, 3.5ml Original Price $54.95, Now Only $39.99. The Original MDura Mini Kit contains an 80W MDura Mini box Mod and a nexMINI Subtank that's capable to produce superb flavor. ![]() 5AVape 415 Four One Five S61 V2 Genesis Atty Clone RDTA Vape Atomizer - 316SS + PEI, 3.0ml, 22mm Diameter Original Price $34.99, Now Only $27.99. The 5AVape 415 Four One Five S61 V2 Clone Genesis Atty RDTA Vape Atomizer is made from 316 stainless steel and PEI Tank tube. The S61 V2 Clone Genesis Atty is in 22mm diameter and holds 3.0ml capacity. The AFC size is 0.9mm~1.1mm ![]() Stabwood Scud TT TC VW Box Mod Clone - Stabilized Wood, 1~60W, 1 x 18650, Evolv DNA 60 Chipset Original Price $359, Now Only $299. The Scud TT Clone TC VW Box Mod is made from Stabilized Wood. The Scud TT Clone Box Mod is powered by Evolv DNA 60 Chipset. The Scud TT box Mod is compatible with 22mm diameter atomizer. Powered by 1 x 18650 battery (not included). ![]() Original Squid Industries Double Barrel V4 200W Box Mod - 5~200W, 2 x 18650 Original Price $99.99, Now Only $69.99. The Original Squid Industries Double Barrel V4 200W Box Mod, featuring a 5~200W output range, adjustable voltage dial, and utilizes a dual high-amp batteries (not included). Constructed from durable zinc-alloy, the chassis is impervious to light falls and drops without any worry. Outputting between 5~200W, the firing button doubles as a voltage adjustment dial that uses power from the dual high-amp 18650 batteries (not included). The perfect successor to the original Double Barrel series, this is a well constructed box mod of high quality. ![]() Original Dovpo Odin 200 200W Box Mod - Aluminum Alloy + Zinc Alloy, 5~200W, 200~600'F, 2 x 20700 / 21700 Original Price $99.99, Now Only $75.99. The Original Dovpo Odin 200 200W TC VV VW Box Vape Mod is constructed from Aluminum Alloy and Zinc Alloy material. Equipped with Dovpo Chipset and powered by 20700 / 21700 Rechageable Batteries (Batteries are not included), the power range of Odin 200 is from 5W to 200W (Max.) and the temperature range is from 100'C to 315'C / 200'F to 600'F. ![]() Original YiHi SXmini MK Pro Class Pod Kit - 700mAh, 2.0ml Original Price $49.99, Now Only $34.99. Original YiHi SXmini MK Pro Class pod system Kit comes with 2.0ml e-juice capacity, and internal 700mAh battery. It is charged via Type-C port. YiHi SXmini MK Pro Class Kit adopts beautiful patterns crafted with aluminum and good plated copper. It delivers effortless, all-day vaping on the go with YiHi SX366 chip. ![]() Original YiHi IPV A1 50W AIO Pod Kit - 2000mAh, 4.0ml, 0.15ohm / 0.5ohm Original Price $59.99, Now Only $48.99. YiHi IPV A1 50W AIO Pod System Kit is powered by built-in 2000mAh battery and YiHi SX380 chip with max 50W output. IPV A1 Pod Kit is equipped with 0.69 inch OLED screen to show vaping data clearly. IPV A1Cartridge has 4.0ml capacity with bottom filling design. IPV A1 Pod supports plug-in coil installation and adjustable airflow. ![]() Original YouDe UD Clapton Coil Original Price $6.99, Now Only $3.99. YiHi IPV A1 50W AIO Pod System Kit is powered by built-in 2000mAh battery and YiHi SX380 chip with max 50W output. IPV A1 Pod Kit is equipped with 0.69 inch OLED screen to show vaping data clearly. IPV A1Cartridge has 4.0ml capacity with bottom filling design. IPV A1 Pod supports plug-in coil installation and adjustable airflow. ![]() Original YouDe UD Aluminum Base Holder Stand for RDA / RTA / RDTA Vape Atomizer Original Price $12.99, Now Only $7.99. The YouDe UD Aluminum base provides a solid platform for coil building your RDA or RTA atomizers as well doubling up as an attractive solution for mounting your atomizers for storage and display. The stand has a 22mm diameter at the top but will support any diameter atomizer or tank fitted with a 510 thread. ![]() Original YiHi IPV A1 50W AIO Pod System Replacement Empty Pod Cartridge - 4.0ml Original Price $12.99, Now Only $7.99. The Original YiHi IPV A1 Replacement Pod Cartridge is suitable for IPV A1 Pod System Vape Kit. The pod cartridge is bottom filling system design empty 4ml capacity. ![]() Original YiHi IPV A1 Pod System Replacement Coil Head Original Price $14.99, Now Only $11.99. The Original YiHi IPV A1 Pod System Replacement Coil Head is in 0.5ohm resistance and comes with 5 PCS / Pack.
120
Kontrl V2 Kontrl Mag Clone Front + Back Door Panel Plates w/ Button for dotMod dotAIO Vape Pod System Original Price $59.99, Now Only $44.99.
The Kontrl V2 Kontrl Mag Clone Replacement Front and Back Door Panel Plates is made from Acrylic and suitable for dotMod dotAIO Vape Pod System (Door Panel only, pod system not included). It comes with a button for easy operation. ![]() Original BP Mods Bushido V3 RDA Replacement 7 Balls Caps Kit - PCTG, 7 PCS / Pack Original Price $12.99, Now Only $9.99. The original BP Mods Bushido V3 RDA replacement 7 Balls Caps Kit are all made of PCTG Better for fruity juices. Comes with 7 PCS / Pack: 1 x Black Translucent Cap, 1 x Red Translucent Cap, 1 x Green Translucent Cap, 1 x Purple Translucent Cap, 1 x Amber Translucent Cap, 1 x Fully Translucent Cap, 1 x White Opaque Cap
