302474
822
101
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
YFTK Dvarw MTL RTA Rebuildable Tank Atomizer Clone $21.99
The YFTK Dvarw MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 different airflow accessories to adjust airflow. This RTA will bring you extreme MTL vaping experience. ![]() Jorda B RDA Rebuildable Dripping Atomizer Clone with BF Pin + Spare SS Cap $8.99 The Jorda B RDA Clone is a small size squonk RDA for MTL or restricted DL vapers. The RDA comes with stainless steel top cap and 1 spare SS cap with different airhole sizes. The airhole size is 0.5mm, 1mm and 1.5mm. The build deck comes with dual post design for single coil building. 510 POM drip tip is included. This item also has other colors to choose. ![]() Duetto Reborn RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.59 The Duetto Reborn RDA Clone is a 22mm RDA that comes with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience. PC cap is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Coppervape Hussar RTA Rebuildable Tank Atomizer with Micro Tank $21.99 The Coppervape Hussar RTA Clone with Micro Tank is constructed from 316 stainless steel and PEI with 22mm diameter. This RTA features single coil build deck, juice control and bottom airflow system. The RTA comes with convenient side filling and the juice control can prevent leaking, making it easy to access the deck. The Torpedo Cap is great for heat dissapation. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin (mouthpiece) and stainless steel (base) with 15.7mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() Vapeasy T-Style Screwdriver Allen Key for E-cigarette $0.99 The Vapeasy T-Style Screwdriver Allen Key is used for e-cigarette DIY coil building. ![]() Coppervape Replacement 510 Drip Tip for Hussar RTA Clone $1.59 The replacement 510 drip tip is made from POM with 11mm height. It is suitable for Coppervape Hussar RTA Clone and all atomizers that fit 510 drip tip. This item also has other colors and Material to choose. ![]() Coppervape Replacement Tank Tube for NarBa / NarTa RDTA Clone $2.99 The replacement tank tube is made from PEI and is suitable for Coppervape NarBa / NarTa RDTA Clone. ![]() Coppervape Replacement Nano Tank Tube for Hussar RTA Clone $3.59 The replacement nano tank tube is made from PEI and is suitable for Coppervape Hussar RTA Clone. ![]() Coppervape Replacement Micro Tank Tube for Hussar RTA Clone $3.99 The replacement micro tank tube is made from PEI and is suitable for Coppervape Hussar RTA Clone. ![]() Coppervape Replacement Nano Tank Set for Hussar RTA Clone $7.99 The replacement micro tank set is made from 316 stainless steel (filling cap, internal cap) and PEI (tank tube) and is suitable for Coppervape Hussar RTA Clone. ![]() Original BX Grapefruit E-juice Liquid for E-cigarette $10.99 The BX Grapefruit E-juice Liquid comes with a flavor of grapefruit. It comes with 60ml e-juice,70% VG and 30% PG. This item also has other Flavor to choose.
102
Original Wotofo Flow Sub Ohm Tank Atomizer $18.99
The Original Wotofo Flow Tank, coming with 4ml capacity, is a 24mm diameter sub ohm tank constructed from 316 stainless steel. With a silicone plug, the capacity can be changed to 2ml. The Flow features top filling, which is convenient, and silver plated electrode post for better conductivity. The adjustable bottom airflow brings great flavor and dense clouds. The pre-installed coil is 0.25ohm resistance, supporting wattage output from 30 watts to 60 watts. This item also has other colors to choose. ![]() Original Wotofo Freakshow RDA Rebuildable Dripping Atomizer $4.99 The Original Wotofo Freakshow RDA is a rebuildable dripping atomizer with 22mm diameter. It is made from stainless steel. The triple post design can be used for single or dual coil build. There are two huge airflow slots on each side of the deck to deliver airflow from the bottom to the coils. This item also has other colors to choose. ![]() Original Wotofo Atty Cubed RDA Rebuildable Dripping Atomizer $6.99 The Original Wotofo Atty Cubed RDA / Atty3 RDA is the essential box mod specific RDA, combining a very strong feature set, high quality machining, and a box mod centric form factor. The Atty Cubed features a split positive center post and deck-milled negatives, with each post hole measuring 2mm in diameter. Coupled with a 6mm deep juice well, the Atty Cubed can accommodate a wide variety of build configurations. Airflow is designed as dual staggered air slots, each measuring 7mm by 2mm, allowing absolutely tremendous airflow. ![]() Original IJOY Elite Mini Kit with RDTA Box Mini 60W 2200mAh Mod + Captain Elite RTA + Pod System $51.59 The Original IJOY Elite Mini Kit consists of IJOY RDTA Box Mini Mod, Captain Elite RTA, and IJOY J&P Pod System. This item also has other colors to choose. Mod: The Original IJOY RDTA Box Mini Mod comes with built-in 2200mAh Li-Po battery and 60W maximum output. It is compact and portable, yet powerful with multiple working modes, including VW, TC-Ni, TC-Ti, TC-SS and unique custom user mode. The resistance range is from 0.05 to 3ohm. This mod support USB port charging. Tank: The Original IJOY CAPTAIN ELITE Subohm & RTA Tank is a new-designed MINI single coil RTA with good balance between pure flavor and massive vapor production. It is a 22.5mm tank with 2ml capacity, which can be extended to 3ml with extra bubble tank. It features sliding mechanism for convenient top filling, both DIY coil and pre-built coil head compatible, gold plated deck with side bottom airflow, which provides unique airflow for smooth vapor. Pod System: The IJOY J&P Pod Adapter is an adapter that allows you to use the pod on the Elite Mini Kit or other devices. It is compatible with Juul and Phix pods. With the J&P Pod Adapter, you can not only use pods on a mod with long battery life, but also do some wattage setting adjustments. ![]() Original Wotofo Replacement Coil Head for Flow Sub Ohm Tank Clearomizer $9.19 The replacement coil head features 0.25ohm resistance and works well at 35~60W. It is suitable for authentic Wotofo Flow Sub Ohm Tank. This product comes with 5 PCS in 1 pack. ![]() Original Wotofo Easy Fill Squonk Cap for 60ml E-juice Bottle / BF Squonk Box Mod $6.79 The Original Wotofo Squonk Cap is designed to refill squonk bottle through the 510 connector. Made of food grade aluminum material, it is the very helpful tool that to refill without any leak problem. This squonk refill cap is for 60ml juice bottles. This item also has other colors to choose. ![]() Original Geekvape 810 Resin Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $4.99 The Geekvape 810 Resin Drip Tip is made from resin. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. One piece will be shipped. This item also has other colors to choose.
103
Original ShenRay GEO 75W TC VW Variable Wattage Box Mod $69.90
The Original ShenRay GEO TC Box Mod is a versatile regulated box mod constructed from PC and zinc alloy, featuring various working modes and taste modes. Powered by single 18650 / 26650 battery (not included), GEO can reach maximum output to 75W. The atomizer resistance range is from 0.05 to 2.5ohm. GEO supports TYPE-C Micro-USB quick charging. This item also has other colors to choose. ![]() Original Vapefly Galaxies MTL RTA Rebuildable Tank Atomizer $36.99 The Original Vapefly Galaxies MTL RTA is an all new RTA featuring with unique 8 levels gearwheel airflow control and inner cube airflow control design, which delivery excellent flavor via smooth and easy operation. The Galaxies RTA has 3ml of juice capacity, which can be extended with extra 5ml bubble glass tube. It is a great RTA designed for mouth-to-lung lover. ![]() YFTK Squape E RTA Rebuildable Tank Atomizer Clone $21.39 The YFTK Squape E (C) RTA Clone is a 22mm RTA with 2ml of juice capacity. Constructed from stainless steel, it is durable for long-term use. It comes with bottom airflow system for smooth and dense vapor. ![]() Original Lcovape 98K RDA Rebuildable Dripping Atomizer with BF Pin $31.99 The Original Lcovape 98K RDA is a 24.5mm RDA constructed from 316 stainless steel. The gold plated build deck features single large post design and postless negative terminal, which allows you to build horizontal or vertical coils. The spring loaded clamp design makes building easier. The air enters the dual side airslots and hit the coils directly. 810 SS drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Joyetech eVic Primo Fit 80W 2800mAh TC VW Variable Wattage Mod + EXCEED Air Plus Tank Kit $64.29 The Original Joyetech eVic Primo Fit Kit consists of Vic Primo Fit Mod and EXCEED Air Plus Tank Atomizer. This item also has other colors to choose. Mod: Having a large 0.96inch OLED display and an intuitive menu system, the eVic Primo Fit is such a compact starter box mod available in multiple stylish finishes. It reaches a formidable 80W power along with a sequence of unique features including 2A quick charge, preheat, clock and timeout safety protect. Coupled with an easy-to-go menu system, the eVic Primo Fit handles swiftly at your convenience. The eVic Primo Fit is powered by a built-in 2800mAh battery. With 80W max output, itll surely satisfy you for your daily vaping. Tank: Featuring the new bulging glass tube and convenient push-to-open top filling system, the EXCEED Air Plus atomizer also presents you with more spare resin and cellular tubes. EX series heads with novel designs are meant to provide pure flavor with great vaping experience, no matter for mouth-to-lung or direct-lung. The EXCEED Air Plus is 22mm in diameter and with 3ml of juice capacity. ![]() Original SMOKTech SMOK Replacement Pod Cartridge for Fit Starter Kit $7.99 The replacement pod cartridge features 2ml of juice capacity and refillable tank. It is suitable for Original SMOKTech SMOK FIT starter kit. This product comes with 3 PCS in 1 pack. ![]() Original SMOKTech SMOK Replacement Pod Cartridge for Infinix Starter Kit $8.99 The replacement pod cartridge features 2ml of juice capacity and refillable tank. It is suitable for Original SMOKTech SMOK Infinix starter kit. This product comes with 3 PCS in 1 pa ![]() Original SMOKTech SMOK Replacement Pod Cartridge for Rolo Badge Starter Kit $8.99 The replacement pod cartridge features 2ml of juice capacity and refillable tank. It is Original for Original SMOKTech SMOK Rolo Badge starter kit. This product comes with 3 PCS in 1 pack. ![]() Original Vapefly Replacement Glass Tank Tube for Galaxies MTL RTA $2.70 The replacement glass tank tube from Vapefly has 3ml of juice capacity. It is suitable for Original Vapefly Galaxies MTL RTA. ![]() Original Vapefly Replacement Bubble Glass Tank Tube for Galaxies MTL RTA $5.99 The replacement bubble glass tank tube from Vapefly has 5ml of juice capacity. It is suitable for Original Vapefly Galaxies MTL RTA. ![]() Original Vapefly Replacement Cube Airflow Control Set for Galaxies MTL RTA $3.00 The replacement Cube Airflow Control Set from Vapefly is suitable for Original Vapefly Galaxies MTL RTA. It can be replaced and installed at the deck for different airflow configurations. This one is Circular Hole version. This item also has Other Type to choose. ![]() SXK Replacement Cover Panel for Billet Box Mod Clone $22.90 The Replacement Cover Panel is made from resin, and is designed for SXK Billet Box 70W / DNA60W Box Mod Clone. This cover panel comes with 2 pieces (front and back). This product is not suitable for SXK Billet Box (Purple Color). This item also has other colors to choose.
104
Original Hugo Vapor Enterprise 230W TC VW Variable Wattage Box Mod $35.59
The Original Hugo Vapor Enterprise Mod adopts advanced GT230 chipset, which allows it to power up to 230W with dual 18650 batteries (not included). Constructed from PC and stainless steel material, with ergonomically designed body, it feels light and comfortable in hand. The Enterprise Box Mod comes with a 0.96inch IPS screen, with three control buttons near the screen, it is very convenient to view the data and operate. The supported atomizer resistance range is from 0.1 to 3ohm. This item also has other colors to choose. ![]() AV Complyfe Takeover Hybrid Mechanical Mod Clone $20.99 The Complyfe Takeover Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This one is engraved version with carved grooves. This item also has other colors to choose. ![]() AV Medieval Gyre Hybrid Mechanical Mod Clone $24.99 The AV Medieval Gyre Mechanical Mod Clone is constructed from brass. It features Medieval style machined body, hybrid connection and adjustable magnetic bottom firing button. The mod is powered by single 18650 battery (not included). This item also has other colors to choose. ![]() Original Ehpro Panther RDA Rebuildable Dripping Atomizer with BF Pin $16.59 The Original Ehpro Panther RDA is a 24mm RDA which features dual post with quad terminals, gold plated build deck for great conductivity, bottom-up direct airflow. The bottom airflow will bring you flawless flavor and huge vapor production. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Dvarw MTL RTA Rebuildable Tank Atomizer Clone $8.99 The Dvarw MTL RTA Clone is a 22mm RTA made out of stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom airflow hole. This RTA will bring you extreme MTL vaping experience. ![]() Original Riscle Pirate King RDA Rebuildable Dripping Atomizer with BF Pin $26.99 The Original Riscle Pirate King RDA is a 24mm RDA constructed from brass (cap) and stainless steel (base). The build deck features central positive post and postless negative terminal, making coil building much easier. The central post screw is used to control the oil in case of leaking and is also used to provide spiral bottom airflow. Removable 810 wide bore drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() YFTK Ataman V2 RTA Rebuildable Tank Atomizer Clone $22.99 The YFTK Ataman V2 RTA Clone is a 22mm rebuildable tank atomizer designed for MTL vaping. The build deck comes with dual post design for single coil building. The intake air hits the coil from the bottom, providing tight airflow and mouth-to-lung vaping experience. The tank comes with 3.5ml of juice capacity. ![]() AV Complyfe Takeover Hybrid Mechanical Mod Clone + Battle RDA Clone Kit $27.99 The Complyfe Takeover Mech Kit Clone consists of Complyfe Takeover Mechanical Mod Clone and Complyfe Battle RDA Clone. This item also has other colors to choose. Mod: The Complyfe Takeover Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This one is engraved version with carved grooves. RDA: The Complyfe Battle RDA Clone is constructed from stainless steel build deck, brass top cap and stainless steel drip tip. With the large post holes and flathead screws, the triple post deck is easy for coil building. The cap has dual large airslots for side airflow. ![]() Original Coil Master DIY Kit Mini V2 for E-Cigarette Coil Building $19.89 The Original Coil Master DIY Kit Mini V2 is the simplest version of DIY Kit. The DIY Kit Mini V2 Case is made from ABS material which has the advantages of corrosion resistance and high-temperature resistance. All tools are made of high-quality metals and high-temperature-resistant plastic materials, and well organized in a solid carry case. The new designed multi-functional screwdriver kit can also be used as coil winder.
105
AV Gyre Slow Twist Hybrid Mechanical Mod Clone $23.99
The AV Gyre Slow Twist Hybrid Mechanical Mod Clone is constructed from brass in 24mm diameter. The hybrid cap allows more aggressive raw power for massive clouds. The tube comes with Slow Twist style machined body (engraved logo), which is stylish and better to grip. The fire button is magnetic. Powered by single 18650 battery (not included). This item also has other colors to choose. ![]() Original ThunderHead Creations THC Tauren Mechanical Mod $82.90 The Original THC Tauren Mech Mod from ThunderHead Creations is the first mechanical mod with innovative Ball style connected button, which allows the mod to be fired immediately without any delay. With a built-in battery tube, it can be powered by single 21700, 20700, and 18650 battery (not included). The precision machined body and unique luxury painting make THC Tauren Mech Mod more attractive. The top is not overhang with 24mm atomizers. Each one comes with its own serial number. This item also has other colors and Material to choose. ![]() Original Riscle Pirate King RDA Rebuildable Dripping Atomizer with BF Pin $22.99 The Original Riscle Pirate King RDA is a 24mm RDA constructed from brass (cap) and stainless steel (base). The build deck features central positive post and postless negative terminal, making coil building much easier. The central post screw is used to control the oil in case of leaking and is also used to provide spiral bottom airflow. Removable 810 wide bore drip tip is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Smoant S8 370mAh Pod Starter Kit $19.99 The Original Smoant S8 Pod Starter Kit is designed for vape beginner. The Smoant S8 features streamline appearance for better grip. Powered by built-in 370mAh battery, the S8 will satisfy your needs for simple puffs. The cartridge has 2ml of juice capacity and is refillable. The air-activated switch makes the S8 pretty easy to vape. This item also has other colors to choose. ![]() Original GAS Mods Replacement 510 Standard Pin + Bottom Feeder Pin Kit for G.R.1 RDA $2.49 The replacement 510 standard pin and bottom feeder pin is suitable for authentic GAS Mods G.R.1 RDA. ![]() Original GAS Mods Replacement Airflow Control Set for G.R.1 RDA $2.49 The replacement airflow control set is suitable for authentic GAS Mods G.R.1 RDA. The accessory comes with dual airhole, each with 2mm size. This item also has other Airhole size to choose.
106
Original ThunderHead Creations THC Thunder Storm BF Squonker Mechanical Box Mod $59.95
The original THC Thunder Storm BF Squonker Mod is constructed from PA-GF material, which has a much higher thermal resistance than polyamide. The mod can be powered by single 18650, 20700, 21700 battery (not included). With built-in 8ml squeeze bottle, it allows you to enjoy great squonking experience without refilling frequently. Besides, the mod comes with lockable mechanism to guarantee safety. This item also has other colors to choose. ![]() Original Snowwolf Xfeng Mod High-Class Version 230W TC VW Variable Wattage Box Mod $62.99 The original Sigelei Snowwolf Xfeng High-Class Version 230W Box Mod is constructed from zinc alloy and aluminum alloy. Powered by dual 18650 batteries (not included), the Xfeng is capable of delivering power up to 230W. The temperature control suite includes SS / Ti1 / Ni200 / TCR modes. The mod supports atomizer resistance from 0.05 to 3.0ohm. This item also has other colors to choose. ![]() YFTK Ataman V2 RTA Rebuildable Tank Atomizer Clone $35.99 The YFTK Ataman V2 RTA Clone is a 22mm rebuildable tank atomizer designed for MTL vaping. The build deck comes with dual post design for single coil building. The intake air hits the coil from the bottom, providing tight airflow and mouth-to-lung vaping experience. The tank comes with 3.5ml of juice capacity. ![]() Original Phevanda MTL A1 RDTA Rebuildable Dripping Tank Atomizer with BF Pin $29.99 The original Phevanda MTL A1 RDTA is a 22mm single coil RDTA designed for extreme MTL vaping. The top cap has 7 different sizes of airholes to adjust, and there is airflow control set at the center of the deck, which is replaceable and two extra sets are included. The build deck is super easy for coil building and wicking, and under the deck there is a tank with about 2.5 to 3ml of juice capacity. Delrin and stainless steel 510 drip tip are included. This RDTA comes with bottom feeder pin. ![]() Vapeasy Biatch RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $13.99 The Vapeasy Biatch RDTA Clone is a 22mm single coil RDTA which integrates the build deck and tank as one piece. Constructed from 316 stainless steel (top cap, deck) and PC (tank), the RDTA has been designed to combine the best of PitBull and Doggystyle into a convenient and compact BF atomizer. The side airflow air slot is 5mm by 1.2mm, which is adjustable. The postless build deck allows single coil building. The tank has about 1.5ml of juice capacity. This RDTA comes with bottom feeder pin. ![]() YFTK Billet Box 60W All-in-One Box Mod Kit Clone $99.99 The YFTK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin with 13mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99 The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose. ![]() YFTK Replacement Tank Tube + Chimney for Flash e-Vapor V4.5 RTA Clone $7.99 The replacement PEI tank tube and 316SS chimney is suitable for YFTK Flash e-Vapor V4.5 RTA Clone. ![]() Original ThunderHead Creations THC Tauren Pro Tool Kit for Vape $25.99 The orifinal THC Tauren Pro Tool Kit is a multi-functional tool kit designed for vape. The kit includes 1 x Professional Screwdriver, 1 x Multifunctional Pliers, 1 x Folding Scissors, 1 x Ceramic Tweezer, 1 x Pointed Tweezer, 1 x Wire Cutter, 1 x Coiling Jig Stick, 1 x Storage Case, 1 x THC Keychain. ![]() MLD Egg EDC Fidget Toy Clone $61.99 The MLD Egg EDC Fidget Toy Clone is constructed from aviation aluminum. The fidget toy is a small toy designed to keep your hands busy and your mind focused. It is pocket sized and can be carried with you every day. Great for people with fidgety hands, ADHD, anxiety and OCD sufferers. This item also has other colors to choose. ![]() MLD Mechanical Box EDC Fidget Toy Clone $115.99 The Mechanical Box EDC Fidget Toy Clone is constructed from stainless steel. The fidget toy is a small container designed to keep your small things in it. It is pocket sized and can be carried with you every day. ![]() MLD Push-and-Pull EDC Fidget Toy Clone $77.99 The MLD Push-and-Pull EDC Fidget Toy Clone is constructed from stainless steel. The fidget toy is a small toy designed to keep your hands busy and your mind focused. It is pocket sized and can be carried with you every day. Great for people with fidgety hands, ADHD, anxiety and OCD sufferers. This item also has other colors to choose. ![]() Vorso Crowbar EDC Fidget Toy Clone $25.99 The Vorso Crowbar EDC Fidget Toy Clone is constructed from TC4 titanium. The Crowbar is a multi-functional tool for different situations. ![]() Quickdraw EDC Fidget Toy Clone $18.99 The Quickdraw EDC Fidget Toy Clone is constructed from TC4 titanium and Damascus steel. The Quickdraw is a multi-functional tool for different situations, which works as a crowbar and screwdriver. This item also has other Material to choose.
107
Original Eleaf Lexicon 235W TC VW Variable Wattage Box Mod $53.99
The Eleaf new Lexicon, designed with futuristic elements, boasts a gorgeous looking decorated with intersecting lights. Available in various colors and effects, the LEDs will light up in the way youd like them to be. The Lexicon is powered by dual 18650 batteries (not included) and can fire up to 235 watts. Additional features including a centered 510, an easy-to-use and upgradeable firmware as well as 0.05ohm lowest resistance support. This item also has other colors to choose. Original Vaporesso Armour Pro 100W TC VW Variable Wattage Box Mod $37.99 The Original Vaporesso Armour Pro Mod, with beautiful and simple design and 0.96inch color screen, can fire up to 100W with single 18650, 20700, 21700 battery (not included). The amazing 0.002S firing speed brings you the fastest heating and purest rich flavor from the first puff to the last. The atomizer resistance range is from 0.03 to 5ohm. This item also has other colors to choose. ![]() Original Vapor Storm Puma 200W TC VW Variable Wattage Box Mod $31.99 The Original Vapor Storm Puma Mod has sleek appearance and is versatile with its multiple output modes. Powered by dual high rate 18650 batteries (not included), it is able to reach 200W in wattage mode. In temperature control mode, Puma supports Ni, Ti, SS316 and TCR. In bypass mode, the output can even be higher than 200W and the maximum is 230W. Puma will definitely provide you with different vaping experience. This item also has other colors to choose. ![]() ShenRay SRG V4 RTA Rebuildable Tank Atomizer Clone $29.00 The ShenRay SRG V4 RTA Clone is a 25mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel. The build deck comes with dual post design for easy single or dual coil building. The air enters via the bottom air slots and travel up to the bottom of the coils, providing pure flavor and massive cloud production. ![]() Original Tesla Silver 350mAh All-in-one Pod Starter Kit $21.99 The Original Tesla Silver Pod Starter Kit is made of lightweight aluminum and PC, making it so portable and lightweight in your hands. It comes with a 350mAh inbuilt battery and 2ml pod cartridge. The device will be fully charged in 1.8 hours. The Tesla Silver Pod Starter Kit is designed to be slim, compact, and easily transported, making it easy to vape whenever you like. USB charging cable is included. This item also has other colors to choose. ![]() Original SMOKTech SMOK X-Force 45W 2000mAh Pod Starter Kit $28.99 The SMOK X-Force Kit is constructed from the PC and PCTG material. As a first one-button activation device by Smoktech in minimalist design, its color, carved lines and cutting design shows the beauty of modern style. powered by one internal 2000mAh build-in battery, that can bring you excellent vaping experience. There are 5 LED indicators that can show you the battery status obviously. X-Force tank is refillable with a large e-juice capacity up to 7ml, supporting bottom filling. And what's more remarkable design is the fantastic X-Force Coil - the transverse coil, which is different from the previous layout structure, providing diversified vaping experiences to all the vapers. This item also has other colors to choose. ![]() Original Eleaf Lexicon 235W TC VW Variable Wattage Box Mod + ELLO Duro Tank Kit $66.29 The Original Eleaf Lexicon Kit consists of Eleaf Lexicon 235W Mod and ELLO Duro Tank Atomizer. This item also has other colors to choose. Mod: The Eleaf new Lexicon, designed with futuristic elements, boasts a gorgeous looking decorated with intersecting lights. Available in various colors and effects, the LEDs will light up in the way youd like them to be. The Lexicon is powered by dual 18650 batteries (not included) and can fire up to 235 watts. Additional features including a centered 510, an easy-to-use and upgradeable firmware as well as 0.05ohm lowest resistance support. Tank: ELLO Duro, a new member of Eleaf ELLO family, features all-new reimagined Net and Multihole coil technologies which present unprecedented vaping experience with ultra flavorful taste and huge clouds and have a longer lifespan. To fill the tank, you just need to slide the drip tip back to reveal the fill port. The tank has 6.5ml of juice capacity. Original Vaporesso Armour Pro 100W TC VW Box Mod + Cascade Baby Tank Kit $50.99 The Vaporesso Armour Pro Kit consists of Vaporesso Armour Pro Mod and Cascade Baby Tank. This item also has other colors to choose. Mod: The Original Vaporesso Armour Pro Mod, with beautiful and simple design and 0.96inch color screen, can fire up to 100W with single 18650, 20700, 21700 battery (not included). The amazing 0.002S firing speed brings you the fastest heating and purest rich flavor from the first puff to the last. The atomizer resistance range is from 0.03 to 5ohm. Tank: The Vaporesso Cascade Baby Sub Ohm Tank is the newest member of Vaporesso family, which features stylish look, 5ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. The GT Mesh coils will heat up evenly compared to regular coils. With its unique triangular air flow structure, the GT Mesh can enlarge the heating area, and the use of mesh offers great flavor. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. ![]() Original GAS Mods Replacement 510 Drip Tip Kit for G.R.1 GR1 RDA $12.00 The 510 drip tip kit is suitable for Original GAS Mods G.R.1 RDA. The drip tip is only compatible with GAS Mods 22mm Colour Caps. This kit comes with 3 drip tips. This item also has other colors to choose.
108
Original Tesla XT 220W TC VW Variable Wattage Box Mod $50.99
The Original Tesla XT TC VW Box Mod is constructed from zinc alloy, with fancy lighting design and comfortable hand-feel. The Tesla XT Mod can fire up to 220W with dual 18650, 20700, 21700 batteries (not included). With comprehensive temperature control suite and various of settings, you can enjoy the fun of regulated mod. There are 7 kinds of RGB LED display lights inside, providing a more stunning appearance when vaping. This item also has other colors to choose. ![]() Original VBS Rasin 75W TC VW Variable Wattage Box Mod $55.99 The Original VBS Rasin TC VW Box Mod features beautiful resin surface and ergonomic design for comfortable hand feeling, making the mod lightweight and durable. It is powered by single 18650 battery, providing a maximum power of 75W. The atomizer resistance range is from 0.1 to 3ohm. One mod will be shipped (random color). More color than whats on the image. ![]() Original VBS Rasin 80W TC VW Variable Wattage Box Mod $55.99 The Original VBS Rasin TC VW Box Mod features beautiful resin surface and ergonomic design for comfortable hand feeling, making the mod lightweight and durable. It is powered by single 18650 battery, providing a maximum power of 80W. The atomizer resistance range is from 0.1 to 3ohm. One mod will be shipped (random color). More color than whats on the image. ![]() Dvarw MTL RTA Rebuildable Tank Atomizer Clone $8.99 The Dvarw MTL RTA Clone is a 22mm RTA made out of stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom airflow hole. This RTA will bring you extreme MTL vaping experience. ![]() Original HQD Comma 380mAh All-in-one Pod System Starter Kit $26.99 The Original HQD Comma Kit looks very ergonomic and very convenient to use, designed like a water drop, made from Zinc Alloy and PC. It features a 380mAh rechargeable battery with 2ml refillable pod cartridges. HQD Comma Kit is the first pod system kit with LED screen to check vaping status in the electronic cigarette industry, which is very unique in pod kits. There is no button and no setting, all the information about quantity of power, puffs and other vaping data has been shown on the LED screen. Moreover, the output power range is from 20W to 40W, makes it a very suitable for new beginners. This item also has other colors to choose. ![]() Original Usonicig Rhythm UltraSonic E-Cig 1500mAh Starter Kit $70.99 The Original Usonicig Rhythm UltraSonic starter kit adopts the advanced UltraSonic technology of Ultra-high frequency ceramic vibration that vibrate at 2,400,000 times per second, which will turn E-liquid into vapor. In this way, you will experience the unique pure and smooth flavor. It works with built-in 1500mAh battery and 2.0ml capacity tank which meet your daily need. The most outstanding feature is the bold design of the fire button combine music element with mechanical principle, bring you both visual and tactile enjoyment. Along with beautiful indication of power design, brilliant lights build on the advanced indication and protection functions to let you know what situation the device is. Small body but subvert your recognition again and again. In a word, if you want to enjoy amazing vaping life, you simply must try this amazing new device. Usonicig Rhythm is a great vaping device for you. This item also has other colors to choose. ![]() Original Snowwolf Mfeng Limited Edition 200W TC VW Variable Wattage Mod + Mfeng Tank Kit $50.89 The Original Snowwolf Mfeng Kit Limited Edition consists of Snowwolf Mfeng Limited Edition Mod and Mfeng Sub Ohm Tank. The Original Snowwolf Mfeng Limited Edition Mod is a high-class versatile regulated mod with 0.96inch TFT full-color screen and friendly interface. Powered by dual 18650 batteries (not included), the Mfeng mod can reach 200W maximum output. With a brand new chipset, Mfeng allows you to choose different modes to meet your needs. Together with Mfeng Sub Ohm Tank, the Snowwolf Mfeng Kit will bring you excellent vaping experience. This item also has other colors to choose. ![]() Original IJOY Avenger 270 234W TC VW Box Mod + Avenger Tank Kit with Battery $73.49 The IJOY Avenger 270 Kit consists of Avenger 270 Mod and Avenger Tank. This item also has other colors to choose. Mod: The IJOY Avenger 270 Mod is a revolutionary vape device with "AI" that you can control it via your voice. It is powered by dual 18650 or 20700 batteries (20700 batteries included) and the maximum output power can reach 234W. The voice control will bring you brand new vape experience. Tank: The Original IJOY Avenger Sub Ohm Tank is a 25mm tank with normally 3.2ml capacity and can be extended to 4.7ml with extra glass tube. The Avenger can be compatible with various coils and Mesh pre-made coil, which will bring you pure flavor and massive vapor production. ![]() BF Bottom Feeder Squonk Bottle + Adapter for Mechanical Mod / Non-BF Mod $4.99 The BF Bottom Feeder Squonk Accessory is constructed from 316 Stainless Steel adapter and PC bottle. It is designed for mechanical mods and other mods that without squonk bottle. The connector is 24mm diameter and the bottle comes with 8ml capacity. It can be installed between your mod and atomizer to fill e-liquid simply and conveniently. ![]() YFTK Replacement Drip Tip for M-Atty RDA Clone $4.99 The replacement drip tip is suitable for YFTK M-Atty RDA Clone. It is made of PEI.
109
Original Soomook Hato K-One 238W TC VW Variable Wattage Box Mod $47.99
The Original Soomook Hato K-One Mod is a high end regulated device that is powered by ST chipset. With dual 18650 batteries (not included), the wattage can be varied from 5 to 238W. Hato K-One supports various modes, like power mode, temperature control mode, memory mode and bypass mode. The resistance range is 0.1 to 5ohm (VW), 0.06 to 1.3ohm (TC). The 510 connector is spring-loaded to match most atomizers in the market. ![]() Original OBS T-VCT Sub Ohm Tank Clearomizer with RBA Coil Head $12.99 The OBS T VCT Sub-Ohm Tank is a highly effective platform that integrates a large top filled 6ml tank capacity, independent juice control, and a multitude of coil options including a RBA base. The OBS T VCT Sub-Ohm features a massive 6ml tank capacity coupled with an easily accessible top filling system. Sealed by two gasket and featuring two 4mm diameter fill holes, unthreading the top section is quick and easy and filling is simple and hassle free. This tank comes with a RBA coil head for coil building. ![]() Kaonashi RDA Rebuildable Dripping Atomizer Clone with BF Pin $13.99 The Kaonashi RDA Clone is a 22mm RDA constructed from PEI (top cap) and stainless steel (base). The build deck comes with dual post design for single coil building. Both of the posts share an Ultem clamp, which is right above them. The air enters the internal and hit the coil directly via the side air slot, which can be adjusted with the top cap. POM drip tip and adapter ring are included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Tesla AT 45W 900mAh Mod + AT Tank Starter Kit $34.99 The Tesla AT Kit is constructed from durable zinc alloy and is ergonomically designed to be held comfortably. The mod is powered by a built-in 900mAh battery, which is chargeable via USB port and supports pass through charging. The maximum power output of the AT Starter Kit is 45W. The tank included has 1.5ml of juice capacity. Tesla AT Kit is compact and easy to use, being a good choice for beginner. This item also has other colors to choose. ![]() Original IJOY Wand 100W 2600mAh Mod + Diamond Tank Kit $29.39 The Original IJOY Wand Kit consists of IJOY Wand Mod and IJOY Diamond Sub Ohm Tank. This item also has other colors to choose. Mod: The Original IJOY Wand Mod, with built-in IWEPAL chip and 2600mAh battery, features compact structure, medium size, as well as various functions. The maximum power output is 100W. Unlike mechanical mod, the chip provides short-circuit protection and low power protection, making it much safer and reliable. The individual pentagonal fire button is easy to operate. The Wand supports USB quick charging. Tank: The IJOY Diamond Tank is a 25mm sub ohm tank with 5.5ml of juice capacity. It features large airflow, great vapor, good flavor, 180 degrees fast screw-cap filling, wide bore 810 resin drip tip, and stylish diamond design. The tank utilizes the innovative Diamond coil, which can atomize the juice completely and restore the original taste. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99 The 810 drip tip is made from resin with 12.3mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors and Material to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy RDA $5.99 The 810 drip tip is made from Titanium Alloy and Epoxy Resin with 13.2mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. One piece will be shipped. This item also has other colors to choose.
110
Original Tesla DB 219W TC VW Variable Wattage Box Mod $72.90
The Original Tesla DB Mod is a high end regulated device with comfortable hand feeling. Powered by dual 18650 batteries (not included), the wattage can be varied from 7 to 219W which will create massive cloud. Tesla DB supports power mode and temperature control mode. The resistance range is 0.1 to 3ohm. The 510 connector can match most atomizers in the market. This item also has other colors to choose. ![]() Original Fumytech Dragon Ball V2 RTA Rebuildable Tank Atomizer $29.99 The Original Fumytech Dragon Ball V2 RTA Tank Atomizer is made from stainless steel. It is a dragon-ball-shape RTA that it will attract many anime fans. Features large 5.5ml juice capacity, the Dragon Ball V2 RTA tank utilizes postless build deck design, compatible with dual and single coil for nice flavor and big smoke amount. It is compatible with 810 drip tip. With the top filling design, you just need to slide the top cap with drip tip back to reveal the fill port. The Dragon Ball V2 RTA will bring you a smooth vapor and amazing vaping experience. The base is 24mm in diameter. ![]() Original Hotcig Castle RDA Rebuildable Dripping Atomizer with BF Pin $19.59 The Original Hotcig Castle RDA is a dual post design for single coil rebuildable drip atomizer. The Castle is designed to be compact, flavorful, and meant for Bottom Feed Devices. The build deck on the Castle offers a large build area with a dual post single terminal that utilizes top mounted flat head screw for securing the clamps. The Castle comes with two types of top caps, a stainless steel top cap and a matte white ULTEM drip cap. Located on the top of the Castle is a 8mm bore 510 delrin drip tip. The Hotcig Castle is squonk ready and also comes with a non-squonk gold-plated 510 pin. The Hotcig Castle 22mm RDA is designed for build enthusiast and offers a great platform for all single coil and specialty builds. This item also has other colors to choose. ![]() Original Joyetech TEROS 480mAh All-in-one Pod System Starter Kit $23.99 The Original Joyetech TEROS start kit is an all-in-one pod system with draw activated firing mechanism. It features a compact size with comfortable handling feeling. Discard the fire button, simply vape on it. Having a refillable side filling solution, it offers 2ml e-liquid capacity which is TPD compliant. Powered by ECO technology, it offers you long using time. It also has thermochromic and photochromic finishes where the color changes by sunlight or environment temperature. A 480mAh built-in battery powers the device with an indicator light which indicates working condition and battery life. The TEROS is such an elegant, simple, and versatile pod system that could be your next pocket vape. This item also has other colors to choose. ![]() Original Smoant Charon Mini 225W TC VW Variable Wattage Box Mod + Battlestars Tank Kit $53.99 The Original Smoant Charon Mini Kit with battlestar tank is an innovative vape kit with stylish looking and comfortable hand-feeling. This item also has other colors to choose. Mod: Powered by dual 18650 batteries (not included), the Charon Mini Mod can fire up to 225 watts, available in TC and VW modes, with a large high-definition 2.0 UI full screen, you can watch all the parameters clearly and easy to operate. Tank: The Battlestar tank integrates 100% Japanese OCC and Ni80 (coil heads). The Smoant Battlestar Sub Ohm Tank can store 4ml e-juice, with top filling design and adjustable airflow system for fantastic flavor and huge smoke amount. ![]() Original MOOKO GTA E-juice Liquid for E-cigarette $13.99 The Original MOOKO GTA e-juice liquid comes with a flavor of orange, berry, cranberry, and milk chocolate. It comes with 60ml e-juice,70% VG and 30% PG. ![]() Original MOOKO GTA E-juice Liquid for E-cigarette $13.99 The Original MOOKO GTA e-juice liquid comes with a flavor of mint and blueberry. It comes with 60ml e-juice,70% VG and 30% PG. ![]() Original Purple Light E-juice Liquid for E-cigarette $20.99 The Original Purple Light e-juice liquid comes with a flavor of grape. It comes with 100ml e-juice,70% VG and 30% PG.
111
Original SMOKTech SMOK Priv M17 60W 1200mAh Box Mod $21.39
The SMOKTech SMOK Priv M17 mod has a slim body, you can easily hold it in your hand. Although Priv M17 is not a big mod, it is very powerful. Its max output power can up to 60W, which could meet your expection for a slimmer mod. Besides, it has big lateral fire key, which can offer you more convenient operations. LED indicator can clearly show you the working status of the mod, for example, it will flash 15 times when the battery voltage is lower than 3.3V. Priv M17 provides multiple protections to avoid potential risks, such as 8s cut-off, low voltage and short circuit protection. You can charge your Priv M17 by the included USB cable, with its built-in 1200mAh battery, the mod can be very durable and no need to replace battery frequently. This item also has other colors to choose. ![]() Original Lost Vape Furyan Squonk Mechanical Box Mod $79.90 The Original Lost Vape Furyan Squonk Box Mod features PEI chassis , brass battery tube and 9ml squeeze bottle. Made out of high-quality material, the Furyan can give you the best touch feeling. The Lost Vape Furyan Squonk Mod is compatible with single 18650, 20700 or 21700 battery (not included). This item also has other colors to choose. ![]() Kindbright Sherman V3 RTA Rebuildable Tank Atomizer Clone $18.99 The Kindbright Sherman RTA Clone is a 25mm tank constructed from 316 stainless steel and comes with 4ml capacity glass tank. The deck features clamp style dual post design for single or dual coil build. The airflow is fully adjustable via bottom airslots. The RTA comes with wide bore Delrin and Ultem drip tip. This item also has other colors to choose. ![]() Vital RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The Vital RDA Clone in 24mm diameters is constructed from stainless steel. The build deck comes with dual post design for single and dual coil building. It features teardrop airflow, engraved pattern and locking cap that prevents the e-juice from leaking. Removable 810 wide bore drip tip and bottom feeder pin are included. This item also has other colors to choose. ![]() Original SMOKTech SMOK Priv M17 60W 1200mAh Mod + Priv M17 Tank Starter Kit $31.69 The Original Priv M17 comes with Priv M17 mod and Stick 17MM tank. This item also has other colors to choose. Mod: This Priv M17 mod has a slim body, you can easily hold it in your hand. Although Priv M17 is not a big mod, it is very powerful. Its max output power can up to 60W, which could meet your expection for a slimmer mod. Besides, it has big lateral fire key, which can offer you more convenient operations. LED indicator can clearly show you the working status of the mod, for example, it will flash 15 times when the battery voltage is lower than 3.3V. Priv M17 provides multiple protections to avoid potential risks, such as 8s cut-off, low voltage and short circuit protection. You can charge your Priv M17 by the included USB cable, with its built-in 1200mAh battery, the mod can be very durable and no need to replace battery frequently. Tank: The Stick 17MM tank with 510 threading connection has 2ml capacity, and the included 0.6ohm Stick M17 coil is the perfect match of Stick 17MM tank, both of which can help to produce incredible vaping power. Top refill system makes filling as easy and leak proof e-liquid slot can significantly solve leaking problem. The airflow can adjusted freely by turning the ring at the base of atomizer. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from resin 9.1mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Reload $3.99 The 810 replacement drip tip is made from resin, stabilized wood (mouthpiece )and stainless steel (base). It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. One piece will be shipped (random color). More color than what's on the image. ![]() Original Advken Doctor Coil Cotton for RDA / RTA / RDTA $4.99 The Original Advken Doctor Coil Cottons are made from 100% organic cotton. It is good to wick the coils and will bring you great vaping experience. This product comes with 10 PCS of cotton in 1 pack.
112
Original Sigelei Sobra 198W TC VW Variable Wattage Box Mod $56.99
The Original Sigelei Sobra Mod adopt the innovative sleek design and supports maximum output 198W. There are HD OLED screen and updated user interface to show you all the dates while vaping. It features special cobra modeling design and powered by dual 18650 batteries (not included). Comes with multiple protections and an easily-installed battery cover, it will never let you down. This item also has other colors to choose. ![]() Original Snowwolf Mfeng Limited Edition 200W TC VW Variable Wattage Box Mod $66.99 The Original Snowwolf Mfeng Limited Edition Mod is a high-class versatile regulated mod with 0.96inch TFT full-color screen and friendly interface. Powered by dual 18650 batteries (not included), the Mfeng mod can reach 200W maximum output. With a brand new chipset, Mfeng allows you to choose different modes to meet your needs. This item also has other colors to choose. ![]() Ulton Typhoon GT4 RTA Rebuildable Tank Atomizer Clone $28.00 The Ulton Typhoon GT4 RTA Clone is a 25mm rebuildable tank atomizer with 1:1 size and 5ml of juice capacity. It is constructed from 316 stainless steel. The build deck comes with dual post design for easy single or dual coil building. The air enters via the bottom air slots and travel up to the bottom of the coils, providing pure flavor and massive cloud production. There is no logo engraved on this RTA. This item also has other colors to choose. ![]() Vape Breed Atty V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $7.99 The Vape Breed Atty V2 RDA Clone is constructed from stainless steel in 24mm diameter. The beveled top cap fits the drip tip perfectly. It features side adjustable airflow and bottom direct airflow. The deck features two posts with 6 holes. Each post has 3 slot screws on top and side. It is easy to build both single and dual coils. The 510 protruding pin makes it hybrid safe. The RDA comes with a removable wide bore drip tip. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Duetto Reborn V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Duetto Reborn V2 RDA Clone is a 22mm RDA that comes with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original Sigelei Sobra 198W TC VW Variable Wattage Box Mod + Sobra Tank Kit $71.99 The Original Sigelei Sobra Mod Kit Painting Edition consists of Sigelei Sobra Mod and Sigelei Sobra tank. This item also has other colors to choose. Mod: The Original Sigelei Sobra Mod adopt the innovative sleek design and supports maximum output 198W. There are HD OLED screen and updated user interface to show you all the dates while vaping. It features special cobra modeling design and powered by dual 18650 batteries (not included). Comes with multiple protections and an easily-installed battery cover, it will never let you down. Tank: The Original Sigelei Sobra atomizer is made of stainless steel and glass with large e-juice capacity. It comes with airflow adjustment which will bring you excellent vaping experience. It is with 510 thread connection. ![]() Decorative Adapter Ring for 24mm RDA / RTA / Sub Ohm Atomzier $1.99 This decorative adapter ring is suitable for 24mm diameter RBA / RTA / RDA atomizers and clearomizers. It is made of POM. The outer diameter is 27.1mm and the inner diameter is 24.8mm. This item also has other colors to choose. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from Resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
113
Original Aspire Feedlink Revvo Squonk Box Mod $50.99
The Feedlink is a single 18650 battery (not included) bypass firing mod with all the quality and safety features you have come to expect from Aspire. Its almost pistol grip feel makes it very ergonomic in the hand and easy to operate the squonk bottle and fire button with just one hand, an absolute joy to hold and use. The silicone bottle has 7ml of juice capacity. This item also has other colors to choose. ![]() Original Tesla Tallica TS-XX Sub Ohm Tank Clearomizer $36.90 The original Tesla Tallica Sub Ohm Tank is made of the high-quality stainless steel and pyrex glass, and has 6ml e-juice capacity and fantastic appearance an designed for metal texture. With the powerful TS-XX Coil system, Tesla Tallica Tank can quickly heating, it will bring you a cool vaping experience. Together with convenient Slide filling system and Plug-n-pull coil change, it is easy to refill and can plug and pull to replace the coil. Features the adjustable bottom airflow control system, it is convenient to adjust the base air slot to get the best flavor. The resistance of TS-XX coil head is 0.18 ohm. It comes with two 0.18ohm TS-XX coils (one is pre-installed). This item also has other colors to choose. ![]() Original Tesla Tallica TS-S Sub Ohm Tank Clearomizer $37.40 The original Tesla Tallica Sub Ohm Tank is made of the high-quality stainless steel and pyrex glass, and has 6ml e-juice capacity and fantastic appearance an designed for metal texture. With the powerful TS-XX Coil system, Tesla Tallica Tank can quickly heating, it will bring you a cool vaping experience. Together with convenient Slide filling system and Plug-n-pull coil change, it is easy to refill and can plug and pull to replace the coil. Features the adjustable bottom airflow control system, it is convenient to adjust the base air slot to get the best flavor. It comes with one 0.18ohm TS-XX coil (pre-installed) and one spare 0.2ohms TS-S coil. This item also has other colors to choose. ![]() Original Hellvape Anglo RDA Rebuildable Dripping Atomizer with BF Pin $31.29 The original Hellvape Anglo RDA, with 24mm diameter, presents a stunning rebuildable dripper featuring a two-post build deck with clamp-style mechanism and an intuitive bottom airflow control system. Airflow of the Anglo RDA deploys a multi-slotted airflow with fully adjustable AFC ring that redirects upwards to the coil chamber for a phenomenal bottom airflow experience. The two-post build deck is integrated with a spring-loaded component to the clamp-secured quad terminals. PC cap is included. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Radius V2 RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Radius V2 RDA Clone is constructed from stainless steel. It features dual post single coil build deck, adjustable side airflow and squonk-ready. The RDA tends to deliver pure flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Krma RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Krma RDA Clone is a 22mm RDA designed for single coil building and focused flavor. It is made out of stainless steel. It is easy to build coil on the dual post build deck, with cutout at each post to put the lead easily. The RDA comes with side airflow system for smooth vapor. This RDA comes with bottom feeder pin (pre-installed), no standard 510 pin included. ![]() YFTK Paravozz V10.1 RDTA Rebuildable Dripping Tank Atomizer Clone $24.99 The YFTK Paravozz V10.1 RDTA Clone is constructed from 316 stainless steel. It features dual post build deck for single coil build and with large capacity. The tank tube and drip tip are made out of PEI. Please note: the atomizer is 22mm in diameter, while the PEI tank tube is 24mm in diameter. ![]() Original Wismec HiFlask 2100mAh All-in-one Pod System Starter Kit $32.79 Being ergonomic and slick, HiFlask is the first pod for all vapers which features exquisite adjustable airflow system, made from PETG and Silicone. Innovative JVUA (Juice Vertical and U Airflow) system is the first application for Wismec e-cigarettes, offering you pure flavor as well as large clouds. The replaceable cartridge is refillable with 5.6ml/2ml e-liquid capacity, which will definitely provide you with unexpected vaping enjoyment. Moreover, the unique design of airflow control and cartridge lock makes HiFlask much more attractive and popular. It is powered by 2100mAh battery and supports 2A quick charging. Simply open the filling lid, you can finish the refilling quickly and easily. This item also has other colors to choose. Original Joyetech Replacement Pod Cartridges for Teros Pod System Kit $10.99 The original Joyetech Teros replacement Pod Cartridges features 2ml capacity. Just open the stopper on the side and inject the e-liquid into the Teros cartridge easily. It is suitable for Joyetech Teros Portable Device. This product comes with 5 PCS in 1 pack. ![]() Original Tesla Replacement Coil Head for AT Sub Ohm Tank Clearomizer $14.95 The replacement coil head features 1.0 ohm resistance and works well at 10~15W. It is suitable for original Tesla AT Sub Ohm Tank. This product comes with 5 PCS in 1 pack. ![]() OriginalTesla Replacement Coil Head for Tallica TS-XX Sub Ohm Tank Clearomizer $19.60 The replacement coil head features 0.18 ohm resistance and works well at 60~110W. It is suitable for original Tesla Tallica TS-XX Sub Ohm Tank. This product comes with 4 PCS in 1 pack. ![]() Original Tesla Replacement Coil Head for Tallica TS-S Sub Ohm Tank Clearomizer $19.60 The replacement coil head features 0.2 ohm resistance and works well at 80~140W. It is suitable for original Tesla Tallica TS-S Sub Ohm Tank. This product comes with 4 PCS in 1 pack. ![]() Original Tesla Replacement Pod Cartridges for Silver Pod System Kit $24.50 The Original Tesla replacement 1.4ohm Pod Cartridges features 2ml capacity. It is suitable for Tesla Silver portable device. This product comes with 5 PCS in 1 pack.
114
Original Vzone eMask 218W TC VW Variable Wattage Box Mod $61.59
The Original Vzone eMask box mod is a high quality device with interior water protection construction. Powered by dual 18650 batteries (not included), the max power can be varied up to 218W. There are 5 colors on the backlight panel, which can be selected, and the mod can be charged by included USB cable. It comes with large ventilation mask. It support KA / TC (316SS, Ni200, Ti) / TCR / VW mode. This item also has other colors to choose. ![]() Original SXmini T Class SX580J 200W TC VW Variable Wattage Box Mod $189.99 The Original SXmini T Class box mod uses the YiHi SX580J chip set, an ultra premium and sophisticated output board that is able to compete with the best chip developers in the industry. Powered by dual 18650 batteries (not included), the max output wattage can be up to 200W. There are spinner on top and Joystick spinner for relaxing and fun. You can adjust most setting on your phone by Bluetooth app. It supports TC (SS / Ti / Ni ) Mode. The backlight color is changeable and selectable. This item also has other colors to choose. ![]() Original Asmodus Lustro 200W Touch Screen TC VW Variable Wattage Box Mod $73.99 The Original Asmodus Lustro Box Mod is a versatile regulated mod powered by dual 18650 batteries (not included), which can reach maximum output to 200W. With a capacitive touch screen, the operation on Lustro is very easy to vapers. Working with the latest GX-200-HUT chipset, Lustro Box Mod provides high performance in all aspects. The Curve output mode allows for detailed customization of the firing curve. The Lustro Box Mod will bring you the most comfortable vaping experience. ![]() Original Yiloong Predator 80W TC VW Variable Wattage Squonk Box Mod $42.99 The Original Yiloong Predator box mod is made of ABS material. It is an regulated device with copper 510 connect to support a high efficiency and performance with a higher power 80W chip. Besides, the decent panel design with a REAL PREDATOR on its surface makes it different with stylish fashion and classic high end. Small size makes it slim and tiny to hold in hands even for a stealth vape. Inside the box, a large capacity and removeable juice bottle sits tight. The mod is powered by single 18650 battery (not included). ![]() Original Arctic Dolphin Anita 100W TC VW Squonk Box Mod $41.99 The Original Arctic Dolphin Anita Squonk Box Mod is a regulated BF mod, which can reach maximum output up to 100W with single 18650, 20700, or 21700 battery (not included). With the 0.96inch OLED screen, all necessary vaping data can be displayed on it. The resistance range is from 0.06 to 1 ohm (TC) / 0.06 to 3ohm (VW). This item also has other colors to choose. ![]() Original Wotofo Flux 200W VW Variable Wattage Box Mod $69.99 Co-designed with the renowned American brand Rig Mod, the Wotofo Flux Box Mod aims to redefine what powerful really means to vaping. Featuring an easy operation interface, this compact starter mod discards all confusing multi-menu functions including temperature control which is proven to be unnecessary. The Flux Box Mod is powered by dual 18650 batteries (not included) to give a max output of 200W. It resembles a medieval helmet in appearance and utilizes a fire bar instead of a fire button for the purpose of better grip and overall aesthetics. This item also has other colors to choose. ![]() Original Wotofo Flow Pro SubTank Sub Ohm Tank Clearomizer $29.99 Furtherly upgraded from the popular flavor monster Flow SubTank, this Flow Pro SubTank can provide way better flavor experience than the original one. It is 25mm in diameter, capable of holding up to 4ml e-juice with a regular straight glass tube and 5ml with a bubble glass tube. The tank features a super convenient top fill system with a push-open top cap. The highlight of the Flow Pro SubTank is the utilization of the revolutionary mesh-like multihole coil design, which gives a lot more contact surface with the juice, thus producing greater flavor. Whats more, the Flow Pro SubTank is compatible with SMOK Baby Beast coils. This item also has other colors to choose. ![]() Original Vaporesso Polar 220W TC VW Box mod + Cascade Baby SE Tank Starter Kit $56.99 The Original Vaporesso Polar Starter Kit consists of Polar box mod and Cascade Baby SE sub ohm tank. This item also has other colors to choose. Mod: The Original Vaporesso Polar box mod is the perfect match of brains and looks, packing in a beautiful 2 inch color screen. The 0.001s Firing Speed brings you the most rapid and safe heating and the purest rich flavor from the first puff to the last! The upgraded OMNI Board 4.0 integrates Insta-Fire, It features multiple protections, such as overtime, low resistance, low power, short-circuit protection and so on. Powered by dual 18650 batteries (not included), the max output power can be up to 220W. The 2.5A quick charge can extremely halve your charging time to 1.5 hours. What's more, it supports Super Player Mode, Bypass Mode and Other Mode, such as VW (H/ N/ S), VT (SS, NI, TI), TCR (M1, M2) and CCT / CCW / VV / CCV Mode. Tank: The Vaporesso Cascade Baby SE Sub Ohm Tank is the newest member of Vaporesso family, which features stylish look, 6.5ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. The GT Mesh coils will heat up evenly compared to regular coils. With its unique triangular air flow structure, the GT Mesh can enlarge the heating area, and the use of mesh offers great flavor. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. ![]() Original Wotofo Flux 200W VW Variable Wattage Box Mod + Flow Pro SubTank Kit $94.99 The Original Wotofo Flux Kit consists of Wotofo Flux Box Mod and Flow Pro SubTank. This item also has other colors to choose. Mod: Co-designed with the renowned American brand Rig Mod, the Wotofo Flux Box Mod aims to redefine what powerful really means to vaping. Featuring an easy operation interface, this compact starter mod discards all confusing multi-menu functions including temperature control which is proven to be unnecessary. The Flux Box Mod is powered by dual 18650 batteries (not included) to give a max output of 200W. It resembles a medieval helmet in appearance and utilizes a fire bar instead of a fire button for the purpose of better grip and overall aesthetics. Tank: Furtherly upgraded from the popular flavor monster Flow SubTank, this Flow Pro SubTank can provide way better flavor experience than the original one. It is 25mm in diameter, capable of holding up to 4ml e-juice with a regular straight glass tube and 5ml with a bubble glass tube. The tank features a super convenient top fill system with a push-open top cap. The highlight of the Flow Pro SubTank is the utilization of the revolutionary mesh-like multihole coil design, which gives a lot more contact surface with the juice, thus producing greater flavor. Whats more, the Flow Pro SubTank is compatible with SMOK Baby Beast coils. ![]() Original Vaptio Replacement Pod Cartridges for Spin-It Starter Kit $12.99 The Original Vaptio Spin-It Pod Cartridges feature 1.8ml capacity and 1.2ohm resistance. It will work well at 15W. It is suitable for original Vaptio Spin-It starter kit. You can to fill e-liquid easily by opening the silicone cap. This product comes with 4 PCS in 1 pack. ![]() Original Wotofo Replacement Coil Head for Flow Pro SubTank Clearomizer $19.99 The Flow Pro Coil Head adopts the trending mesh-like heating element which can be seen as a finger-sized perforated metal sheet. Such coil structure with little holes evenly punched on a single sheet can provide larger contact surface than a traditional wire coil, or even larger than a mesh coil which is woven with strands of heating wires. Hence, the coil sheet can vaporize a lot more e-juice in a faster way, bringing both intensive flavor and massive cloud. It is called Multihole coil. Another great point is that it has a longer service life. And, the Flow Pro multihole coil is interchangeable with SMOK Baby Beast coil. This product comes with 5 PCS in 1 pack.
115
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Caliber Hybrid Mechanical Mod Clone $20.99
The Caliber Hybrid Mechanical Mod Clone is constructed from brass. It features hybrid connection and high quality spring bottom firing button that will bring good feeling when pressing it. Adopting silver plated electrode can produce prefect electrical conductivity. ![]() Original Ikarno X-Mini 50W 1500mAh TC VW Variable Wattage Box Mod $31.99 The Original Ikarno X-Mini is a compact box mod, made from high quality zinc alloy, which is solid and feel well in your hand. Powered by a built-in 1500mAh battery that can be charged by the included micro USB cable, the max output wattage can be up to 50W. It supports VW / TC-Ni / TC-Ti / TC-SS mode. The resistance range is 0.2~3.5ohm. This item also has other colors to choose. ![]() Original Benecig Killer 260W VW Variable Wattage Box Mod $46.99 The Benecig Killer 260W mech mod, as it is called as mech mod by Benecig Official, is actually more functional than mechanical mod. With the power evolution of output technology, integrated with a proprietary chipset capable of 260W power, variable wattage adjustment, 0.02S fast firing speed, and multiple protection. All of these features make Killer box mod a great device to vape. The mod supports minimum atomizer resistance of 0.05ohm. The potentiometer offers 5 level adjustment of output wattage. The Killer mod is made from zinc alloy and carbon fiber, integrated with rigid line and sharp corners. This item also has other colors to choose. ![]() Original Joyetech RFC Riftcore Duo RTA Rebuildable Tank Atomizer $47.99 The Original Joyetech RFC Riftcore Duo RTA in 26mm diameter, made from stainless steel. It gets rid of the tedious rebuilding process by using the RFC heater, which designed with a self-cleaning feature and molecule heating technology, allowing a simple replacement of cotton for a pure and delicate vaping experience. The RFC heater is made in USA and safely tested by independent US laboratory. The Riftcore Duo atomizer adopts the push-to-open top filling design. Simply push the top cap to reveal the filling hole. Then you're free to go. The bold airflow structure on the RIFTCORE DUO atomizer was designed to deliver massive vapor production. This item also has other colors to choose. ![]() Dvarw V2 MTL RTA Rebuildable Tank Atomizer Clone $9.99 The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience. ![]() Dvarw V2 MTL RTA Atomizer Clone with Airflow Control Sets + Spare Tank Sets $14.99 The Dvarw V2 MTL RTA Clone is a 22mm RTA made out of stainless steel. The build deck comes with dual post design and bottom airflow system. The RTA has 1mm bottom and 7mm by 1.9mm side airflow hole. This RTA will bring you extreme MTL vaping experience. It comes with 2ml tank set (top lid, tank tube and chimney, 3.5ml tank set, 5ml tank tube, and five airflow control sets with different sized airhole. The size of circular airholes are 0.5mm, 0.8mm, 1.3mm, 1.8mm and 2.3mm. ![]() Duetto Reborn RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99 The Duetto Reborn RDA Clone is a 22mm RDA that comes with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience. This RDA has pre-installed bottom feeder pin and comes with a 510 standard pin. ![]() Stutt-Art Bogati RTA Rebuildable Tank Atomizer Clone $14.59 The Stutt-Art Bogati RTA Clone in 23mm diameter is made of 316 stainless steel. It comes with dual post build deck for single or dual coil building. The capacity of the tank is 5ml and top filling design makes it refill e-liquid very simply. The airflow can be adjusted as you like. ![]() 510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99 The replacement 510 drip tip is made from Resin. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose. ![]() 810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Reload $2.99 The 810 replacement drip tip is made from resin (mouthpiece) and stainless steel (base). It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. ![]() Replacement Airflow Control Set for Dvarw V2 MTL RTA Clone $1.99 The replacement airflow control set is suitable for Dvarw V2 MTL RTA Clone. The accessory comes with single airhole, with 0.5mm airhole size. This item also has other airhole size to choose. ![]() Replacement Airflow Control Sets for Dvarw V2 MTL RTA Clone $5.99 The replacement airflow control set is suitable for Dvarw V2 MTL RTA Clone. There are five sets with different sized single circular airhole. They are 0.5mm, 0.8mm, 1.3mm, 1.8mm and 2.3mm. It comes with 5 airflow control sets. This product is suitable for Dvarw RTA Clone. ![]() Replacement Tank Tube for Dvarw V2 MTL RTA Rebuildable Tank Atomizer Clone $1.99 The replacement 2ml capacity tank tube is made from stainless steel and is suitable for Dvarw V2 MTL RTA Tank Atomizer Clone. This product is suitable for Dvarw RTA Clone. ![]() Replacement Tank Tube + Top Lid + Chimney for Dvarw V2 MTL RTA Clone $3.59 The replacement 2ml capacity tank tube is made from PC. Top lid and chimney are made from stainless steel. They are suitable for Dvarw V2 MTL RTA Tank Atomizer Clone. It comes with a 2ml tank tube, top lid and chimney. This product is suitable for Dvarw RTA Clone. This item also has other Capacity to choose.
116
Original Bravo Box Bottom Feeder Squonk Mechanical Box Mod $14.99
The Original Bravo Box Squonk Box Mod is a convenient squonking device with large fire button and 7ml built-in bottle, which should satisfy your daily use. Most importantly, the mod support single 18650 / 20700 / 21700 battery (not included), which makes it compatible with various kinds of batteries. It comes with two 7ml bottom feeder bottles (one is pre-installed). ![]() Lokos Hybrid Mechanical Box Mod Clone $22.89 The Lokos mechanical mod Clone is made from POM and brass, powered by one 18650 battery (not included). It features spring-loaded fire button and 510 threading connection. This item also has other colors to choose. ![]() Original HKS SQV RDA Rebuildable Dripping Atomizer $27.99 The Original HKS SQV Style RDA rebuildable atomizer is made from 316 stainless steel and the diameter is 24mm. It is designed as two posts with four terminals for dual coil building. It features gold plated base and 510 threading connection. This item also has other colors to choose. ![]() Original Advken Artha RDA Rebuildable Dripping Atomizer with BF Pin $29.99 The Original Advken Artha RDA is a 24mm diameter dripper with compact size. The deck is 24K gold plated with dual post design for easy building. The deep juice well can hold more e-juice. The airflow can be adjusted by dual airholes on the cap. 810 drip tip is included. The RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Original GeekVape Ammit MTL RDA Rebuildable Dripping Atomizer with BF Pin $29.99 The Original Geekvape Ammit MTL RDA is a 22mm rebuildable atomizer that is tight and compact. It features a wide single coil build deck with dual deep juice wells, which is designed for the purest flavor. A top adjustable airflow valve with an advanced airflow circulation system will helps recycles the airflow throughout the chamber. This RDA comes with bottom feeder pin. ![]() Original Vzone eMask 218W TC VW Variable Wattage Box Mod + Uranus Tank Kit $109.90 The Vzone eMask Kit consists of Vzone eMask Mod and Uranus sub ohm tank. This item also has other colors to choose. Mod: The Original Vzone eMask box mod is a high-quality device with interior water protection construction. Powered by dual 18650 batteries (not included), the max power can be varied up to 218W. There are 5 colors on the backlight panel, which can be selected, and the mod can be charged by included USB cable. It comes with large ventilation mask. It supports KA / TC (316SS, Ni200, Ti) / TCR / VW mode. Tank: The Uranus sub ohm tank in 26mm diameter has 6ml large juice capacity with VN-XX 0.18ohm mesh coil inside. It works well when the wattage is 60~110W. ![]() Original Marvec Priest AIO 90W Starter Kit $40.99 The Original Marvec Priest AIO 90W Starter Kit is an all-in-one style device with 90W full output. It is powered by single 18650 battery (not included). The pod has 5ml juice capacity. The supported lowest resistance is 0.1ohm. 90W full-power output with amazing coils, making super huge vapor. The kit comes with multiple protections and supports 2A fast charging. This item also has other colors to choose. ![]() Lokos Hybrid Mechanical Box Mod Clone + RDA Kit $28.19 The Lokos mechanical mod kit Clone consists of Lokos mechanical box mod Clone and rebuildable dripping atomizer. This item also has other colors to choose. Mod: The Lokos mechanical mod Clone is made from POM and brass, powered by one 18650 battery (not included). It features spring-loaded fire button and 510 threading connection. Tank: The Lokos rebuildable dripping atomizer Clone in 24mm diameter is constructed from stainless steel and POM. It comes with adjustable side airflow control and dual posts design for single or dual coil building. It features brass electrode that has good electrical conductivity. ![]() Original Advken 21700 4000mAh 3.7V 20A Flat Top Rechargable Battery $13.99 The Original Advken 21700 Battery, featuring a diameter of 21mm and a length of 70mm, has a 4000mAh large battery capacity with 20A max continuous discharging current. Long storage life, light weight and high energy density.
117
Original Smoant Battlestar Nano 80W Box Mod $20.99
The Original Smoant Battlestar Nano Mod features compact size with 80W full power output. It comes with big fire button and supports USB charging. The mod is powered by single 18650 battery (not included). This item also has other colors to choose. ![]() Original GeekVape Ammit MTL RDA Rebuildable Dripping Atomizer Original Price $31.90,Now Only $22.99 The Geekvape Ammit RDA is a compact MTL RDA that features three-dimensional airflow system transferring air from top to bottom producing unbeatable flavor while retaining leak-proof capability. 10 airflow adjustment options providing the most variable restrictions for different preferences. The Ammit MTL RDA comes with innovative dual-layer chamber structure to provide outstanding heat dissipation effect. This item also has other colors to choose. ![]() Original Smoant Talos V4 Sub Ohm Tank Clearomizer $13.99 The Original Smoant Talos V4 Sub Ohm Tank Clearomizer in 24mm diameter is made from Stainless Steel and Quartz Glass. It features 3ml capacity tank and easy to refill the e-juice from the top by rotating the cap anticlockwise. It comes with adjustable airflow control at the side and high-quality Kanthal A1 heating wire made in America, which will bring you excellent vaping experience. It is with 510 threading connection. This item also has other colors to choose. ![]() Original ADVKEN Ziggs V2 RDA Rebuildable Dripping Atomizer with 810 Drip Tip $14.49 The Original ADVKEN Ziggs V2 RDA rebuildable dripping atomizer in 24mm diameter is constructed from stainless steel (base) and aluminum with sand blasting (sleeve). It is designed as dual brass post for single coil building. The two air slots and dual 35 degree beveled airflow design to ensure both good taste and massive cloud of vapor. The 24K gold plated brass 510 threading pin has good electrical conductivity. It comes with a 810 drip tip. This item also has other colors to choose. ![]() Original GAS Mods G.R.1 GR1 RDA Rebuildable Dripping Atomizer with BF Pin Original Price $39.99,Now Only $26.99 The Original GAS Mods GR1 RDA is a 22mm atty that features single coil build deck, replaceable airflow control accessories and squonk-ready. It is made from stainless steel (base) and PMMA (transparent cap). The airflow control accessories comes with two different sizes of airholes, one is 2mm by 2mm each side, the other is 2mm by 5mm each side. The most recommended angle is 45 degrees, giving you the best flavor. This RDA comes with bottom feeder pin. This item also has other colors to choose. ![]() Panda PVC Wrapper Skin Sticker for 18650 Battery $1.59 The wrapper sticker is commonly used for 18650 battery, Like LG MH1, LG HB6, Samsung ICR18650-26F, Samsung INR18650 batteries, etc. This product comes with 10 PCS in one pack. 18650 battery tag. This item also has other pattern to choose. ![]() American Flag PVC Wrapper Skin Sticker for 20700 Battery $1.59 The wrapper sticker is commonly used for 20700 battery, Like IJOY 20700 battery. This product comes with 10 PCS in one pack. This item also has other pattern to choose.
118
Original Smoant Charon Mini 225W TC VW Variable Wattage Box Mod $47.79
Powered by dual 18650 batteries (not included), the Charon Mini Mod can fire up to 225W, available in TC and VW modes, with a large high-definition 2.0 UI full screen, you can watch all the all the parameters clearly and easy to operate. It utilizes the Ant225 chip with a faster response in only 0.015s when firing and has multiple automatic protections.This device has 2.0 inch TFT colorful screen, compared with other product it can offer you a clearer interface. Charon mini is designed ergonomically, which give you more comfortable hand-feel. It has 9 basic pictures to choose, you can download picture you like for user customizable wallpaper and standby screen. And Smoant Charon Mini supports firmware updating and charging by included USB cable. Besides, the minimum atomizer resistance allowed is 0.1 ohm. This item also has other colors to choose. ![]() Original Vaporesso Polar 220W TC VW Variable Wattage Box mod $50.89 The Original Vaporesso Polar box mod is the perfect match of brains and looks, packing in a beautiful 2 inch color screen. The 0.001s Firing Speed brings you the most rapid and safe heating and the purest rich flavor from the first puff to the last! The upgraded OMNI Board 4.0 integrates Insta-Fire, It features multiple protections, such as overtime, low resistance, low power, short-circuit protection and so on. Powered by dual 18650 batteries (not included), the max output power can be up to 220W. The 2.5A quick charge can extremely halve your charging time to 1.5 hours. What's more, it supports Super Player Mode, Bypass Mode and Other Mode, such as VW (H/ N/ S), VT (SS, NI, TI), TCR (M1, M2) and CCT / CCW / VV / CCV Mode. This item also has other colors to choose. ![]() Original Advken Manta MTL RTA Rebuildable Tank Atomizer Original Price $39.99, Now Only $27.99 The Original Advken Manta MTL RTA in 24mm diameter is with 2ml capacity, which can be changed to 3ml with extension tube, made from stainless steel (base and cap) and glass (tank tube). There is gold-plated build deck and large cotton location place which make building easier. The adjustable airflow control and side-air intake of posts design is good for vaping flavor. It is easy to refill the e-juice from the top. It comes with 510 threading connection and 510 drip tip. This item also has other colors to choose. ![]() Original CoilART MAGE RTA V2 Rebuildable Tank Atomizer Original Price $35.00, Now Only $27.99 The Original CoilART MAGE RTA V2 is an updated version of MAGE RTA. MAGE V2 RTA is 24mm in diameter and has 3.5ml of juice capacity, which can be extended to 5.5ml with extra PCTG bubble tube. The postless build deck is gold plated and has 29 airholes (1mm diameter) at the post, where the airflow will travel up and hit the bottom and side of the coils. The RTA comes with 810 drip tip and 510 drip tip adapter. This item also has other colors to choose. ![]() Original Advken Dominator 100W TC VW Box Mod + Tank Starter Kit Original Price $86.88, Now Only $63.99 The Original Advken Dominator starter kit consists of original Advken Dominator box mod and Dominator sub ohm tank. This item also has other colors to choose. Mod: The Original Advken Dominator Mod is powered by single 18650, 20700 or 21700 battery (not included). The max output wattage can be up to 100W. Designed with a large lateral fire button and magnetic battery cover ensures operating easily and simply. It supports bypass mode, TC mode and VW modes. Tank: The Original Advken Dominator tank is a 24mm diameter sub ohm tank with 2ml / 4.5ml capacity. The tank has been pre-installed with 0.2ohm coil that is best to used at 50W to 80W. It also supports RBA deck for DIY building (deck not included). With slide top cap, it is convenient to refill. 510 drip tip is included. The convenient top slide refilling and bottom airflow adjustment design bring you simple vaping. ![]() Original Advken Dominator 100W TC VW Box Mod + Tank Starter Kit with RBA Deck Original Price $88.88, Now Only $64.99 The Original Advken Dominator starter kit consists of original Advken Dominator box mod and Dominator sub ohm tank. This item also has other colors to choose. Mod: The Original Advken Dominator Mod is powered by single 18650, 20700 or 21700 battery (not included). The max output wattage can be up to 100W. Designed with a large lateral fire button and magnetic battery cover ensures operating easily and simply. It supports bypass mode, TC mode and VW modes. Tank: The Original Advken Dominator tank is a 24mm diameter sub ohm tank with 2ml / 4.5ml capacity. The tank has been pre-installed with 0.2ohm coil that is best to used at 50W to 80W. It also supports RBA deck for DIY building. With slide top cap, it is convenient to refill. 510 drip tip is included. The convenient top slide refilling and bottom airflow adjustment design bring you simple vaping. It comes with a RBA deck. ![]() Original Advken CP Squonk Mechanical Box Mod + RDA Kit Original Price $69.99, Now Only $49.99 The Original Advken CP Squonking Kit consists of CP Bottom Feeder Mechanical Box Mod and the CP RDA. This item also has other colors to choose. Mod: Powered by single 18650 battery, the original Advken CP Mod adopts press filling and fire button locking design. Inside is the 7ml glass bottle, and there is a hole for users to check e-juice. There is a button locking design for your safety. Tank: The Original Advken CP RDA features single coil building and post air holes design to deliver pure flavor, and a plate near positive pole effectively avoids splashing. It comes with a 810 drip tip. ![]() 810 Replacement Drip Tip for 528 Goon / Reload / Battle RDA $2.99 The 810 drip tip is made from resin with 13.6mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
119
Original CKS Fujin 24 Hybrid Mechanical Mod Original Price $109.69, Now Only $52.99
The Original CKS Fujin 24 mod is made from stainless steel, powered by one 18650 battery (not included). It features hybrid connection, 24K gold plated and 24K gold plated firing with side-channel battery vent. It comes with hybrid-style top cap with delrin insulator. ![]() Original Thunderhead Creations Phyer Mini 80W TC VW Variable Wattage Box Mod $31.99 The Original Thunderhead Creations Phyer Mini 80W Mod is constructed from aluminum alloy. Phyer Mini 80 is powered by 1 x 18650 battery (not included) and the maximum output power can reach up to 80W. Phyer Mini 80 mod comes with six working modes, which is power control mode, voltage control mode, temperature Ni mode, temperature Ti mode, temperature SS mode, temperature TCR mode. It provides various protections for safety, such as Short Circuit Protection, Temperature Protection, Anti-Reverse Protection, Low Voltage Protection, Over Current Protection, etc. This item also has other colors to choose. ![]() Original Thunderhead Creations THC Teemo Clearomizer $19.99 The Original Thunderhead Creations THC Teemo Clearomizer in 22mm diameter is made of stainless steel, with 2.5ml capacity. The coil resistance is 0.55ohm. It works well at 25W. The top-filling system make it refill juice easily and simply. It is 510 threading connection. This item also has other colors to choose. ![]() Original Thunderhead Creations THC Proto RTA Rebuildable Tank Atomizer $11.99 The Original Thunderhead Creations THC RTA in 22mm diameter is made of stainless steel, with 5ml capacity. It supports 1~200W Mod. The top-filling system make it refill juice easily and simply. Designed as postless building deck makes operating quickly, it is recommanded for dual coil building. The airflow control system is good for adjusting vaping cloud as you like. It comes with 510 threading connection. ![]() Original Thunderhead Creations THC Fog Rider RTA Rebuildable Tank Atomizer $10.99 The Original Thunderhead Creations THC Fog Rider RTA in 22mm diameter is made of stainless steel, with 2.5ml capacity. The top-filling system make it refill juice easily and simply. The two post design is for dual coil building. The airflow control system is good for adjusting vaping cloud as you like. It comes with 510 threading connection. It comes with a 510 drip tip. ![]() Original Thunderhead Creations Hexagram RDTA Rebuildable Dripping Tank Atomizer $10.99 The Original Thunderhead Creations Hexagram RDTA in 22mm diameter is with 2.5ml juice capacity, made of stainless steel. It features gold plated positive and negative posts for absolute conductivity and two post design for single / dual / triple / quad coil buildings. The top filling system make it easy to refill e-juice. ![]() Original ThunderHead Creations THC Tauren RDA Rebuildable Dripping Atomizer with BF Pin Original Price $46.80, Now Only $21.19 The Original ThunderHead Creations THC Tauren RDA is a 24mm RDA that features 45-degree angled dual post and 28 micro airholes on each post for delicate and fullest flavor. The RDA has gold-plated 510 pin for great conductivity and also comes with BF pin for squonking. PEI drip tip is included. This RDA comes with bottom feeder pin. This item also has other Material,colors to choose. ![]() Flash e-Vapor V4.5 Mini RTA Rebuildable Tank Atomizer Clone $12.99 The Flash e-Vapor V4.5 Mini RTA Clone is a 17mm rebuildable tank constructed from stainless steel. The RTA features dual post build deck and adjustable airflow for MTL vaping. This tank will provide fantastic mouth-to-lung vaping experience. ![]() Typhoon GT4 RTA Rebuildable Tank Atomizer Clone $23.99 The Typhoon GT4 RTA Clone is a 26mm rebuildable tank atomizer with 5ml of juice capacity. It is constructed from 316 stainless steel. The build deck comes with dual post design for easy single or dual coil building. The air enters via the bottom air slots and travel up to the bottom of the coils, providing pure flavor and massive cloud production. ![]() Original THC Thunder Storm Squonk Mechanical Box Mod + RDA Kit Original Price $68.80, Now Only $37.49 The Original Thunderhead Creations THC Thunder Storm squonk mechanical box mod kit consists of THC Thunder Storm box mod and Thunder Storm tank. Mod: The Original THC Thunder Storm BF Squonker Mod is constructed from PPS material, which has a much higher thermal resistance. The mod can be powered by single 18650, 20700, 21700 battery (not included). With built-in 8ml squeeze bottle, it allows you to enjoy great squonking experience without refilling frequently. Besides, the mod comes with lockable mechanism to guarantee safety. Tank: The Thunder Storm BF RDA in 24mm diameter is made from stainless steel and aluminum alloy, with brass bottom feeder pin. Designed as two post for single or dual coil building, it features adjustable side airflow that you can control it as you like. It comes with a 510 threading connection. ![]() Original THC Thunder Storm TS-75 75W 2000mAh TC TW Box Mod + Sub Ohm Tank Starter Kit $37.49 The Original THC Thunder Storm TS-75 starter kit consists of Thunder Storm TS-75 box mod and Thunder Storm TS-75 tank. This item also has other colors to choose. Mod: The Thunderhead Creations THC Thunder Storm box mod is made from Aluminum and Carbon Fiber. Powered by built-in 2000mAh battery, the max wattage will be up to 75W which will bring you excellent vaping experience. The resistance range is 0.05~3.5ohm. With OLED 0.96 inch display that will show the parameters clearly. It supports over-heating / time-delay / battery / short circuit protection and can be charged by included micro-USB cable. Tank: The THC Thunder Storm sub ohm tank in 24mm diameter is pre-installed a 0.6ohm coil head, with 2ml juice capacity. There are two air slots on bottom that make the huge vaping cloud. It's with 510 threading connection. ![]() OriginalThunderhead Creations THC Pyer Pipe 1000mAh Starter Kit $39.99 The Original Thunderhead Creations THC Pyer Pipe is powered by 1000mAh built-in battery, made of aluminum alloy, with 2ml capacity. The top-filling design makes it easy to refill the e-juice. It comes with 1.0ohm and 0.55ohm clapton nichrome coil heads. The unique and outstanding appearance make it very popular among many people. This item also has other colors to choose. ![]() Original ThunderHead Creations THC Coil 3-Core Fused Clapton Ni80 Pre-made Coil Kit $4.99 The Original THC Coil Ni80 3-Core Fused Clapton Coil comes with 26GA x 3 + 36GA 0.2ohm wires. These heating wires will be a good vaping choice for DIY. It comes with 5 capsule and 2 pcs coils in each capsule, totally 10pcs in one pack. This item also has Other version can choose. ![]() Original ThunderHead Creations THC Hexapak Ni80 6-in-1 Pre-built Coil Kit $4.39 The Original ThunderHead Creations THC Hexapak comes with 6 x 0.3ohm Tiger Coil, 6 x 0.5ohm Transformer Coil, 6 x 0.5ohm Ni80 Twisted Coil, 6 x 0.65ohm Clapton Coil, 6 x 0.55ohm Super Clapton Coil, 6 x 0.3ohm Staple Coil. It comes with totally 36pcs in one pack ![]() Original THC Replacement Coil Head for Thunder Storm Kit / TFV8 Sub Ohm Tank Clearomizer $8.99 The Thunderhead Creations THC Thunder Storm coil head is used for THC Thunder Storm Kit and TFV8 Sub Tank Clearomizer. The resistance is 0.6ohm and works well at 20~60W. It comes with 5 PCS in one pack. ![]() Original THC Replacement Clapton Nichrome Coil Head for Pyer Pipe Starter Kit $9.99 The clapton nichrome coil head is used for THC Pyer Pipe. The resistance is 0.55ohm. It comes with 5 PCS in one pack. This item also has other Resistance can choose. ![]() Original THC Replacement Clapton Nichrome Coil Head for Teemo Tank Clearomizer $9.99 The clapton nichrome coil head is used for THC Teemo Tank Clearomizer. The resistance is 0.55ohm. It comes with 5 PCS in one pack.
120
Original IJOY Captain PD270 234W TC VW Variable Wattage Box Mod $38.89
The original IJOY Captain PD270 box mod is powered by dual 18650 or 20700 batteries (not included), the max wattage can reach to 234W, with 18650 battery adapter. The 0.96 inch OLED screen can show the parameters clearly. Equipped with a chipset designed by IWEPAL, it has a comprehensive temperature control mode with effective fine-tuning adjustments. It supports charging and upgrade firmware by included USB cable. This item also has other colors to choose. ![]() Original Augvape Intake RTA Rebuildable Tank Atomizer Original Price $39.99,Now Only $25.99 The original Augvape Intake RTA with 24mm diameter is a rebuildable tank atomizer, made from stainless steel. It features two airflow tubes to direct the air from top to the bottom of the coil to bring maximum flavor, which is one of the reason why it is called Intake RTA. It comes with a 4.2ml bubble glass tubes and a 2.5ml straight glass tube, and designed as leakage proof easy top filling system. The build deck has two posts design with open channels for easy single coil building. Including low profile resin drip tip and a tall Delrin drip tip, the 510 drip tip can also be used with the 510 adapter. This item also has other colors to choose. ![]() Original Vandy Vape Triple 2 RTA Rebuildable Tank Atomizer Original Price $48.99,Now Only $28.99 The original Vandy Vape Triple II RTA with 28mm diameter (32mm with a resin cover) is a rebuildable tank atomizer, made from stainless steel. With a unique six terminals, postless deck design that can be recommended with single or dual or triple coil building, which will bring intense flavor and pure taste production. Vandy Vape Triple 2 Vape RTA integrates honeycomb postless deck and bottom honeycomb airflow system providing 120' smooth air delivery and huge vapors. Besides,Triple V2 RTA adopts large 4ml e-juice capacity by normal glass tube and can be easily changed to 7ml e liquid capacity by included bulb glass tube. Special nifty slide-out top filling system make your refiling conveniently. This item also has other colors to choose. ![]() Original OBS ACE Sub Ohm Tank Clearomizer $9.99 The original OBS ACE Sub Ohm Tank with 22mm is a 4.5ml capacity clearomizer. It comes with 11mm by 1.5mm massive airhole at base and precision three 1mm slots at top, the airflow control system can bring you excellent vaping experience. Besides, there is a 0.45ohm coil head pre-installed which works well at 30~50W, and also include a replacement 0.25ohm coil head that works perfectly at 30~55W. The side filling design can prevent e-juice from leakaging. It comes with 510 threading connection. This item also has other colors to choose. ![]() Original IJOY Captain PD270 234W TC VW Box Mod + Diamond Tank Kit $49.99 The IJOY Captain PD270 New Kit consists of IJOY Captain PD270 Mod and Diamond Tank. This item also has other colors to choose. Mod: The original IJOY Captain PD270 box mod is powered by dual 18650 or 20700 batteries (not included), the max wattage can reach to 234W, with 18650 battery adapter. The 0.96 inch OLED screen can show the parameters clearly. Equipped with a chipset designed by IWEPAL, it has a comprehensive temperature control mode with effective fine-tuning adjustments. It supports charging and upgrade firmware by included USB cable. Tank: The IJOY Diamond Tank is a 25mm sub ohm tank with 5.5ml of juice capacity. It features large airflow for great vapor, 180 degrees fast screw-cap for easy top filling, with wide bore 810 resin drip tip and stylish diamond design. The tank utilizes the innovative Diamond coil, which can atomize the juice completely and restore the original taste. ![]() Original Vaporesso Zero 650mAh All-in-one Pod System Starter Kit $26.99 The original Vaporesso Zero 650mAh Starter Kit is the new pacemaker for all refillable POD systems. It comes with 2ml capacity tank which adopts a new innovative filling system - press to fill which allows easy filling and improved leak prevention. The Omini Board Mini integrates auto temperature control and multiple protections. The massive 650mAh battery is built in and can be quickly charged to full within 45 minutes. All of these are the perfect mix to give you an easy vaping life. This item also has other colors to choose.
