Просмотров в теме 302440   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 13.04.2018, 06:11 Автор темы   81
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original GeekVape Zeus Dual RTA Rebuildable Tank Atomizer Standard Edition $37.99
The Original Zeus Dual RTA is an upgraded dual coil version of the original Zeus RTA, with the innovative leak-proof top airflow system, airflow transferring from the top to the bottom to maintain great flavor. It comes with upgraded postless build deck that allows for easy building with both single coil and dual coil. Zeus Dual RTA is compatible with 810 and 510 drip tip and 5.5ml bubble tank (not included).
This RTA is Standard Edition with 4ml of capacity. This item also has other colors to choose.
Original GeekVape Aero Mesh Version Sub Ohm Tank Atomizer TPD Edition $29.90
The Original GeekVape Aero Mesh Version Tank is a 25mm sub ohm tank that adopts super mesh X1 coil head, which comes with 0.2ohm resistance and supports output at 30~90W. Another coil is IM4 head with 0.15ohm resistance and supports output at 60~80W.
The Aero Tank is TPD Edition with 2ml of juice capacity. This item also has a Standard Edition, other Capacity and colors to choose.
Dvarw MTL RTA Rebuildable Tank Atomizer Clone $12.99
The Dvarw MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 different airflow accessories to adjust airflow. This RTA will bring you extreme MTL vaping experience.
Original Suorin Drop 300mAh All-in-One Starter Kit $39.99
The Original Murdex Suorin Drop Starter Kit is an all-in-one vaping kit clone with unique shape and design. It comes with built-in 300mAh battery and 2ml cartridge. Compact size enables it to be carried around anywhere you go. This starter kit is definitely suitable for all vapers. This item also has other colors to choose.
Original Suorin Air 400mAh Battery All-in-one Starter Kit $21.99
The Original Suorin Air is a game changing all-in-one device that is redefining the term "stealth vaping". Smaller than a credit card, and slimmer than a standard ballpoint pen; the Suorin Air features a 400mAh rechargeable battery and 2ml refillable pod which provides incredible battery life and liquid capacity for a device of such diminutive dimensions. Incorporated into the design is a master on / off switch and subdued battery life indicator light which is activated when the device is firing and charging. An extremely efficient design, there are no buttons, screens, or complicated settings; the device is instantly activated through inhalation. The Suorin Air is manufactured with excellent build quality and exacting tolerances which provide a rarely matched level of reliability and durability. Whether you are seeking to streamline your setup, add a reliable backup, or start with a stylish and dependable device; the Suorin Air is the device you've been waiting for.
Original OVNS Cookie 400mAh All-in-One Starter Kit $21.99
The Ovns Cookie Starter Kit features unique rhombus shape in a small size which is both lightweight and easy to hold in hand. The Ovns Cookie Kit comes with a built-in 400mAh battery and 2ml cartridge pod. The Ovns Cookie Starter Kit adopts 1.4ohm coil with large vapor production specially designed for MTL vaping. This item also has other colors to choose.
Original GeekVape Replacement Glass Tank Tube for Zeus Dual RTA $4.50
The replacement glass tank tube from GeekVape has 4ml of capacity and is suitable for original GeekVape Zeus Dual RTA.
Original GeekVape Super Mesh Coil for Aero Mesh Version Tank $19.50
The GeekVape Super Mesh Coil comes with 0.2ohm resistance and works well at 30~90W, best 60~80W. It is suitable for original Geekvape Aero Mesh Version Tank.
This product comes with 5 PCS in 1 pack.
Original GeekVape Replacement Bubble Glass Tank Tube for Zeus Dual RTA $4.90
The replacement bubble glass tank tube from GeekVape has 5.5ml of capacity and is suitable for original GeekVape Zeus Dual RTA.
Original GeekVape IM4 Coil for Aero Mesh Version Tank $19.50
The GeekVape IM4 Coil comes with 0.15ohm resistance and works well at 60~80W. It is suitable for original Geekvape Aero Mesh Version Tank.
Original Suorin Drop Replacement Refillable Cartridge $3.99
The replacement cartridge features 1.2ohm resistance and 2ml of juice capacity. It is refillable and suitable for original Suorin Drop starter kit.
Original Suorin Air Replacement Refillable Cartridge $3.99
The replacement cartridge features 2ml of juice capacity. It is refillable and suitable for original Suorin Air starter kit.
Original Angorabbit Cotton Share Wicking Cotton for RDA / RTA / RDTA $3.99
The Original Angorabbit Cotton Share is 100% natural cotton. It has been treated professionally for vapers to get the better taste of the e-juicy. It has high resistance to heat, long service life, and easy to use.
Original SMOKTech SMOK V8 Baby Strip Coil for TFV12 Baby Prince Tank $18.99
The Original SMOK Strip coil is a fire-new revolutionary coil from SMOK, which is made of Kanthal. SMOKTech has innovatively developed the heating membrane unit, whose porous structure can bring great surface adsorption so as to fasten the speed of e-juice absorption. It has larger heating area and radiation area, making the heating more evenly and helping the e-juice to heat up quickly. Besides, it can also avoid the heat accumulation and the corrosion of heating materials. Compared with other traditional heating wires, strip coil can easily load higher power. The large number of thin films formed in the porous has greatly improved the free energy of the surface. On the combined effects of surface tension and van Edward force, it will activate numerous aromatic compounds in the e-juice to achieve both large cloud and dense flavor, bringing an unprecedented vaping experience.
This product comes with 5PCS in 1 pack.
Original Vapeasy Replacement Mouthpiece for Kayfun 5 / Kayfun Prime Drip Tip $4.99
The Original Vapeasy Replacement Mouthpiece is used for the Vapeasy Kayfun 5 / Kayfun Prime 510 Drip Tip. It comes with threads at bottom to become piece with the base (not included). The kit comes with 1 x Acrylic mouthpiece, 1 x PEI mouthpiece, and 2 x POM mouthpieces. The POM mouthpiece comes with 5.5mm bore for low resistance and huge clouds, while the Acrylic and PEI ones comes with 3.9mm bore for high resistance and small vapor.
This product comes with 4 PCS of mouthpieces in 1 pack.
Original Shield Cig Boss Device Preloaded Cotton for RDA / RTA / RDTA $4.99
The Original Shield Cig Boss Device Cotton features fast absorption and easy separation. The pre-cut cotton is very easy to wick with two heads at both ends. It is designed for low ohm builds and will leave you with minimal dry hits. This cotton provides more capacity and clean pure flavor.
This product comes with 12 x Pre-cut cotton and 3 x cotton, totally 15 PCS.
Original Ovns Cookie Replacement Refillable Cartridge $3.99
The Original Ovns Cookie Replacement Cartridge is specially design for Ovns Cookie Starter Kit, featuring 2ml juice capacity and 1.4ohm coil for nice flavor and huge clouds.
SXK Vape Shell for BB Box Mod Clone $19.90
The SXK Vape Shell is made out of 316 Stainless Steel and is suitable for SXK BB Box Mod Clone.
Original Avidartisan Steamcoil 6 in 1 A1 Ni80 SS316 Pre-built Coil Kit $10.99
The Original Avidartisan Steamcoil 6 in 1 Pre-built Coil Kit comes with 4 x 0.25ohm Alien Coil, 2 x 0.19ohm Araneid Coil, 4 x 0.25ohm Staggered Clapton Coil, 4 x 0.21ohm Triple Clapton Coil, 2 x 0.3ohm Interlock Clapton Coil, 4 x 0.3ohm Staircase Clapton Coil.
This product comes with totally 20 PCS of pre-built coils.
Original Vapeasy 510 Drip Tip Kit with Logo for Kayfun 5 / Kayfun Prime RTA Clone $6.99
The Original Vapeasy 510 Drip Tip Kit for Kayfun 5 / Kayfun 6 RTA Clone consists of 1 base (SS316) and 4 mouthpieces (Acrylic, POM, PEI).
The base is made out of 316 stainless steel. With the mouthpiece, it is suitable for Kayfun 5,Kayfun Prime and other atomizers that fit 510 drip tip.
The mouthpiece comes with threads at bottom to become piece with the base. The kit comes with 1 x SS316 drip tip base, 1 x Acrylic mouthpiece, 1 x PEI mouthpiece, and 2 x POM mouthpieces. The POM mouthpiece comes with 5.5mm bore for low resistance and huge clouds, while the Acrylic and PEI ones comes with 3.9mm bore for high resistance and small vapor.
This product comes with 4 x mouthpieces and 1 x drip tip base (with Kayfun logo) in 1 pack. There are other non-logo versions of this project, you can choose what you like.
3FVAPE вне форума   Вверх
Старый 14.04.2018, 05:06 Автор темы   82
3FVAPE
Original ESPION Infinite 230W TC VW Variable Wattage Box Mod $57.69
The Joyetech ESPION Infinite Mod has a set of tunnel light effects, it even reacts to each action you made. You can easily manage it with an intuitive 0.96inch color display. The ESPION Infinite is powered by dual 21700 batteries, but still works with normal 18650 as well (batteries not incldued), reaching a formidable 230W output and supporting 2A quick charge. This item also has other colors to choose.
Bettle V3 Hybrid Mechanical Mod Clone $20.99
The Bettle V3 mechanical mod Clone is constructed from brass. It features hybrid connection and knurled body. With the raw power output, this mod will bring you extreme huge clouds and optimal flavor.
Flave RTA Rebuildable Tank Atomizer Clone with BF Pin $8.99
The Flave RTA Clone is constructed from stainless steel in 24mm diameter. It features dual post deck for single coil and middle side adjustable airflow. The deck has notches for easy installation of the coil. The tank is large and allows to take about 30 puffs per drip.
This RTA comes with bottom feeder pin. This item also has other material and colors to choose.
YFTK Strike Hellfire RDA Rebuildable Dripping Atomizer Clone with BF Pin $19.99
The YFTK Strike Hellfire RDA Clone is constructed from 316 stainless steel in 22mm diameter. Its build deck adopts dual post design for single coil building. The airflow can be adjusted by the top cap. POM wide bore drip tip is included.
This RDA comes with bottom feeder pin.
Vapeasy Dvarw MTL RTA Rebuildable Tank Atomizer Clone $21.99
The Vapeasy Dvarw MTL RTA Clone is a 22mm RTA made out of 316 stainless steel. The build deck comes with dual post design and bottom airflow system. The kit comes with 4 different airflow accessories to adjust airflow. This RTA will bring you extreme MTL vaping experience.
Original ESPION Infinite 230W TC VW Box Mod + ProCore Conquer Tank Kit $80.66
The original Joyetech ESPION Infinite Kit consists of ESPION Infinite Mod and ProCore Conquer Tank. This item also has other colors to choose.
Mod:
Tank:
The Joyetech ProCore Conquer Tank is uniquely designed. Having the new bulging glass tube, its capacity was upgraded to 5.5ml. ProC series heads are all capable: from direct-lung or mouth-to-lung, from massive vapor production to optimal flavor. Meanwhile, its push-to-open system makes filling easily.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The 810 drip tip is made from resin with 13.5mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
One piece will be shipped (random color). More options than what's on the image.
810 Color Changing Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The 810 drip tip is made from resin with 12mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
This drip tip will change its original color when being heated and will return to original color after cooling down. For the color changing effect, please check the first image. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $3.99
The 810 drip tip is made from glass (mouthpiece) and stainless steel (base) with 13mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Original Vandy Vape Replacement 18650 Battery Adapter for Pulse BF 80W Box Mod $2.99
The replacement 18650 battery adapter is suitable for authentic Vandy Vape Pulse BF 80W Box Mod. This product also has 2 PCS in 1 pack and you can choose what you like.
Старый 16.04.2018, 05:24 Автор темы   83
3FVAPE
Bettle V3 Hybrid Mechanical Mod Clone $21.99
The Bettle V3 mechanical mod Clone is constructed from brass. It features hybrid connection, copper battery contact and knurled body. The fire button is activated by magnets. Powered by single 18650 battery, this mod will bring you extreme huge clouds and optimal flavor. This item also has other colors to choose.
Original Hellvape Dead Rabbit SQ RDA Rebuildable Dripping Atomizer with BF Pin $23.19
The original Hellvape Dead Rabbit SQ RDA is 22mm version of the Dead Rabbit and it is a single coil RDA. It comes with new features like a barrel lock, and the side airflow for Mouth to Lung Vaping. Its deck comes with dual post for single coil building, and the slide in top coil deck takes the guesswork out of pre-cutting your coil leads.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Please note: the drip tip included is random color.
Original Wotofo Recurve RDA Rebuildable Dripping Atomizer with BF Pin $26.59
The original Wotofo Recurve RDA is a recent collaboration between Wotofo and the well-known YouTube reviewer Mike Vapes. This single coil RDA gets its name from its overall shape, which is a total innovation compared to the existing straight sleeve design on all RDAs available now. The sleeve of this RDA curves like a recurve bow implying energy and efficiency. It is 24mm in diameter and features side & bottom airflow hitting on postless coil installations to give a sensational flavor burst.
SXK Billet Box 70W All-in-One Box Mod Kit Clone $85.00
The SXK Billet Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor. This item also has other material,and different power products with Evolv DNA 60 chip to choose. You can choose what you like.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from PC with 11mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for 528 Goon / Kennedy / Reload RDA $2.99
The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Старый 17.04.2018, 05:25 Автор темы   84
3FVAPE
Coppervape Dvarw MTL RTA Rebuildable Tank Atomizer Clone $13.99
The Coppervape Dvarw MTL RTA Clone is a 22mm RTA made out of 316 stainless steel and PC tank tube. The build deck comes with dual post design and bottom airflow system with 1.2mm airhole. The RTA supports 4 different airflow accessories to adjust airflow (not included). This RTA will bring you extreme MTL vaping experience. This item also has other Material and colors to choose.
Original Vaptio Solo-Flat 650mAh All-in-One Starter Kit $21.99
The original Vaptio Solo-Flat Starter Kit is an ultra slim and powerful closed system pod device with a built-in 650mAh battery and 1.5ml refillable tank. It has a lip friendly duckbill mouth drip tip and a smart airflow control chip for instant vaping. The Solo-flat has an easy top filling design that you can fill by removing the top cap. A fountain type indicator light makes the Vaptio solo-flat more attractive. This item also has other colors to choose.
Original Vaptio Spin-It 650mAh All-in-One Starter Kit $21.99
The original Vaptio Spin-It Starter Kit is a super cool all-in-one pod system device. The kit features the top terminal spinnable drip tip with 1.8ml refillable cartridge. When you spin the drip tip and keep it inside, the power supply will be cut off, avoiding any risk of mis-firing. Powered by built-in 650mAh battery and constant 15W output as well as a micro USB port at the bottom, it will provide a stable performance to bring you amazing vaping experience. This item also has other colors to choose.
Original Suorin Vagon 12W 340mAh Starter Kit $34.99
The original Suorin Vagon Kit is a portable ergonomically designed starter kit with pod vaporizer system. It utilizes a 340mAh built-in battery and 2.5ml refillable Vagon pods. With the draw-to-activate design, you can just take a puff without any fire button. The pod can be filled with Nic salt or regular e-liquid. This item also has other colors to choose.
Coppervape Replacement Screws + O-rings Accessory Bag for Dvarw RTA Clone $1.39
The replacement screws and o-rings are suitable for Coppervape Dvarw RTA Clone.
Coppervape Replacement Oval Hole Chimney for Dvarw RTA Clone $1.99
The replacement Oval hole chimney is suitable for Coppervape Dvarw RTA Clone. The Oval hole is bigger than standard round hole, which could be helpful for vapers to use use very high VG juice and bigger coils. The hole size is 4mm by 2.5mm.
Coppervape Replacement AFC Airflow Control Tight Kit for Dvarw RTA Clone $2.59
The replacement AFC Airflow Control Tight Kit is suitable for Coppervape Dvarw RTA Clone. The AFC accessory comes with 0.8mm and 1mm airflow hole for your option.
This product comes with 2 PCS in 1 pack. This item also has a Normal Kit. Different Airflow hole inner diameter can be choose.
Coppervape Replacement 510 MTL Drip Tip for Dvarw RTA Clone $1.39
The replacement 510 drip tip is made from Teflon with 22mm height. It is suitable for Coppervape Dvarw RTA Clone and all atomizers that fit 510 drip tip. This item also has other size and colors to choose.
Coppervape Replacement 510 Wide Bore Drip Tip for Dvarw RTA Clone $1.39
The replacement 510 drip tip is made from POM with 17mm height. It is suitable for Coppervape Dvarw RTA Clone and all atomizers that fit 510 drip tip. This item also has other size and colors to choose.
Coppervape Replacement Tank Tube for Dvarw RTA Clone $1.99
The replacement tank tube has 5ml of juice capacity and is suitable for Coppervape Dvarw RTA Clone. It is made out of PC. This item also other Capacity, Material and colors to choose.
Coppervape Replacement Tank Tube + Top Chimney Kit for Dvarw RTA Clone $3.99
The replacement tank tube has 2ml of juice capacity and is suitable for Coppervape Dvarw RTA Clone. It is made out of PEI. The top chimney is made out of 316 stainless steel. This item also has other Capacity to choose.
SJMY Replacement Front + Back Cover Panel for SXK Billet Box Mod Clone $19.99
The replacement front and back cover panel from SJMY is made out of G10 fiberglass and is suitable for SXK Billet Box Mod Clone.
This product comes with 2 PCS in 1 pack. This item also has other colors to choose.
Original Vandy Vape Tool Kit Pro for DIY Coil Building $18.99
The newest VandyVape Tool Kit Pro is a perfect all-in-one kit for DIY users. All tools are high-quality made to reach various needs of users.
Original Vaptio Replacement Pod Cartridge for Solo-Flat Starter Kit $10.99
The replacement pod cartridge is suitable for Original Vaptio Solo-Flat Starter Kit. It comes with 1ohm coil and 1.5ml of juice capacity.
This product comes with 4 PCS in 1 pack.
Старый 18.04.2018, 05:14 Автор темы   85
3FVAPE
Original SMOKTech SMOK I-PRIV 230W TC VW Variable Wattage Box Mod $62.09
The Original SMOK I-PRIV Kit is the first AI kit from SMOKTech. It adopts the latest voice control system which allows you to control the mod by voice. It can recognize speech and understand spoken commands. Powered by dual 21700 batteries, it also compatible with 20700 and 18650 (battery not included), the maximum output of SMOK I-PRIV kit can reach 230W. Besides, it is equipped with TFV12 Prince tank, with 8ml large juice capacity and adopts new coils for nice flavor. It is available in VW, TC and bypass modes for nice vaping experience. This item also has other colors to choose.
Original Eleaf iStick Pico S 100W TC VW Variable Wattage Box Mod $45.29
Inspired by sports car, the Eleaf iStick Pico S Mod is designed to be the most stunning setup, which comes with a bare battery tube with the design of corroded texture, a resin 810 drip tip and decorative 7-color LEDs. In addition to its appearance, iStick Pico S Mod can reach 100W max output with single 18650 / 21700 battery (not included).
Original HCigar Aurora 80W TC VW Variable Wattage Squonk Box Mod $48.89
The Original Hcigar Aurora Squonk Mod is a regulated mod that can reach maximum output up to 80W with single 18650 / 20700 / 21700 battery (not included). It has a unique battery replacement method and can be easily replaced without an adapter, which brings a better experience.
Original Innokin Zenith MTL Sub Ohm Tank Atomizer $26.99
The Original Innokin Zenith Atomizer is a collaboration between Phil Busardo, Dimitris Agrafiotis, and Innokin which aims to create an easy and intuitive mouth to lung (MTL) vaping with replaceable coil heads. It adopts one 1.6ohm Kanthal coil for a cooler vape at lower wattage and one 0.8ohm Kanthal coil for a slightly warmer vape at higher wattage. Together with convenient top fill twist design that will automatically shut off the liquid flow when filling in order to prevent flooding and gurgling, adjustable bottom airflow control and easy replacement coil design, Zenith is absolutely a good choice for MTL lovers. This item also has other colors to choose.
Original Vaporesso Nexus 650mAh All-in-One Starter Kit $22.09
The Original Vaporesso Nexus Starter Kit is an ultra compact and portable vaping kit designed for vapers on the go. The combination of a care-free filling system, adjustable airflow, high performance CCELL coil, and simplicity makes it the best on-the-go device for MTL vaping experience. The 650mah built-in battery with quick charging system allows you to enjoy vaping anytime and anywhere. This item also has other colors to choose.
Original Vaporesso Orca Solo 800mAh All-in-One Starter Kit $19.59
The Vaporesso Orca Solo is a compact All-in-One Pen-Style starter kit with elegant styling. The unique CCELL coil is optimized for high nicotine satisfaction. Flash Heat System brings purer and smoother flavor by rapid and even heating. The Orca Solo is perfect for starters and Mouth-to-Lung enthusiasts. Metal sleeve along with top fill system, not only brings great convenience, but also protect your device. Built-in 800mAh battery and 1A quick charging, the Orca Solo is always ready for use. This item also has other colors to choose.
Original Vaporesso Cascade One 1800mAh Mod + Cascade Mini Tank Kit $34.09
The Original Vaporesso Cascade One Kit consists of Cascade One Mod and Cascade Mini Tank.
Vaporesso Cascade One Kit Powered by built-in 1800mAh battery, provides a long-lasting vaping time to you. The Cascade Mini Tank features top refill and unique safety lock mechanism for easy filling and anti-leakage. It has an innovative isolation structural design that separates coil and juice chamber, allowing consistent, intense flavor at every puff also reducing lower leakage and dry hit potential. The tank adopts innovative GT Mech coils too. This item also has other colors to choose.
Original Eleaf iStick Pico S 100W TC VW Variable Wattage Box Mod + ELLO VATE Tank Kit $56.99
The Original Eleaf iStick Pico S Kit consists of Eleaf iStick Pico S Mod and ELLO VATE Tank.
Inspired by sports car, the Eleaf iStick Pico S Mod is designed to be the most stunning setup, which comes with a bare battery tube with the design of corroded texture, a resin 810 drip tip and decorative 7-color LEDs. In addition to its appearance, the iStick Pico S kit also adpots new HW-Net and HW-Multihole coils to provide optimal vaping experience. It can reach 100W max output with single 18650 / 21700 battery (not included). This item also has other colors to choose.
Original Digiflavor Upen 650mAh All-in-One Starter Kit $29.90
The Original Digiflavor Upen Kit is a high quality pen style vaporizer designed by Justin. Designed for portability and safety, it is a perfect kit for users who are looking for a stealth vape due to its compact size. It comes with a cap to protect atomizer from dust and keep hygienic. Upen is made to be used as a MTL inhalation to accommodate ex-smokers transition to quitting cigarettes. This item also has other colors to choose.
510 Color Changing Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from resin with 14mm height. It is suitable for all atomizers that fit 510 drip tip.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.99
The replacement 510 drip tip is made from resin (mouthpiece) and stainless steel (base) with 18mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for Battle / 528 Goon / Kennedy / Reload RDA $2.59
The 810 drip tip is made from resin with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
The 810 drip tip is made from resin (mouthpiece) and stainless steel (base) with 15mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original Suorin Replacement Refillable Pod Cartridge for Vagon Starter Kit $6.99
The replacement refillable pod cartridge features 2.5ml of juice capacity, horizontal coil, organic cotton and gold-plated connection. It is suitable for Original Suorin Vagon Starter Kit.
Original Smoant Replacement Refillable Pod Cartridge for S8 Starter Kit $3.99
The replacement refillable pod cartridge features 2ml of juice capacity and 1.3ohm resistance. It is suitable for Original Smoant S8 Starter Kit.
Original Vaporesso Mouthpiece for Nexus Starter Kit $1.59
The replacement mouthpiece is suitable for Original Vaporesso Nexus Starter Kit.
Original Vaporesso Replacement NX Coil Head for Nexus Starter Kit $9.99
The replacement NX coil head features 1ohm resistance for 7~12W wattage. It is suitable for Original Vaporesso Nexus Starter Kit.
This product comes with 5 PCS in 1 pack. This item also has NX CCELL coil to choose. You can choose what you like.
Старый 19.04.2018, 06:00 Автор темы   86
3FVAPE
Complyfe Takeover Hybrid Mechanical Mod Engraved Version Clone $20.99
The Complyfe Takeover Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This one is engraved version with carved grooves. This item also has other colors to choose.
Original Vaporesso NRG SE Mini Sub Ohm Tank Clearomizer $18.99
The Vaporesso NRG SE Mini Tank inherited the twist open design with smooth adjustable bottom airflow from the NRG family. As a special edition, it is 22mm wide with 2ml capacity. It keeps the same universal compatibility coil selections. The little magic invention is the most amazing flavor tank that Vaporesso has ever made. This item also has other colors to choose.
Original Vaporesso NRG SE Sub Ohm Tank Clearomizer $18.99
The Vaporesso NRG SE Tank inherited the twist open design with smooth adjustable bottom airflow from the NRG family. As a special edition, it is 22mm wide with 3.5ml capacity. It keeps the same universal compatibility coil selections. The little magic invention is the most amazing flavor tank that Vaporesso has ever made. This item also has other colors to choose.
Original Vaporesso NRG Mini Sub Ohm Tank Clearomizer $21.99
The NRG Tank Mini by Vaporesso is a master piece of everyday vape and cloud chasing, featuring innovative GT Cores that comes in traditional and CCELL Ceramic coil. The Slide-n-Fill design makes refill easier than ever. The heating insulation layer on the bottom demonstrates how Vaporesso care for safer and relaxing vaping experience. Furthermore, the mesh drip tip with specially engineered structure will prevent any spit back. Enjoy the flavor and vapor out of the variety of GT cores available. This item also has other colors to choose.
Original Vaporesso NRG Sub Ohm Tank Clearomizer $22.99
The NRG Tank by Vaporesso is a master piece of everyday vape and cloud chasing, featuring innovative GT Cores that comes in traditional and CCELL Ceramic coil. The Slide-n-Fill design makes refill easier than ever. The heating insulation layer on the bottom demonstrates how Vaporesso care for safer and relaxing vaping experience. Furthermore, the mesh drip tip with specially engineered structure will prevent any spit back. Enjoy the flavor and vapor out of the variety of GT cores available. This item also has other colors to choose.
Original Vaporesso Cascade Mini Sub Ohm Tank Clearomizer $24.09
The Vaporesso Cascade Mini Sub Ohm Tank is the newest member of Vaporesso family, which features stylish look, 3.5ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. The GT Mesh coils will heat up evenly compared to regular coils. With its unique triangular air flow structure, the GT Mesh can enlarge the heating area, and the use of mesh offers great flavor. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. This item also has other colors to choose.
Original Vaporesso Cascade Baby Sub Ohm Tank Clearomizer $24.89
The Vaporesso Cascade Baby Sub Ohm Tank is the newest member of Vaporesso family, which features stylish look, 5ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. The GT Mesh coils will heat up evenly compared to regular coils. With its unique triangular air flow structure, the GT Mesh can enlarge the heating area, and the use of mesh offers great flavor. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. This item also has other colors to choose.
Original Vaporesso Cascade Baby SE Sub Ohm Tank Clearomizer $25.39
The Vaporesso Cascade Baby SE Sub Ohm Tank is the newest member of Vaporesso family, which features stylish look, 6.5ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. The GT Mesh coils will heat up evenly compared to regular coils. With its unique triangular air flow structure, the GT Mesh can enlarge the heating area, and the use of mesh offers great flavor. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. This item also has other colors to choose.
Original Vaporesso Cascade SE Sub Ohm Tank Clearomizer $30.49
The Vaporesso Cascade SE Sub-Ohm Tank is the newest member of Vaporesso family, which features stylish look, 7ml juice capacity, slide-n-fill system, EUC plug-pull style coil change method. Innovative universal coil system allows the tank to be compatible with GT cores. This unique coil system design makes Cascade the only tank in the market to satisfy vaper from 25W to 200W power range. The first of its kind isolation structural design separates coil and juice vault allows consistent, intense flavor at every puff and also reduces leakage and potential dry hit in a way. Combo with balanced triangular adjustable bottom airflow, users will be surprised by how smooth, flavorful, massive cloud this tank can offer. This item also has other colors to choose.
Original Digiflavor Pharaoh Mini RTA Rebuildable Tank Atomizer $42.99
Designed by Rip Trippers, the original Digiflavor Pharaoh Mini RTA is one of the best flavor maker, giving you best vaping experience. The Pharaoh Mini is 24mm in diameter and comes with 2ml capacity. It can be extended to 5ml with spare glass tube. The interchangeable build deck design allows more options of building for you. This item also has other colors to choose.
Старый 19.04.2018, 06:09 Автор темы   87
3FVAPE
SXK One RDA Rebuildable Dripping Atomizer Clone $15.90
The SXK One RDA Clone is a 22mm single coil RDA made out of POM (drip tip, cap) and 316 stainless steel. The dual post build deck supports single coil building, with side direct airflow hitting the coil for great flavor.
Original NCR TOGO 1500mAh All-in-One Starter Kit $33.99
The original NCR TOGO Kit is a pod-style starter kit with built-in 1500mAh battery and 2ml of juice capacity. The battery features 278C temperature control and magnetic connection. The pod adopts easy top fill system that greatly reduces the possibility of liquid leakage. And the 0.5ohm stainless coil with organic cotton will deliver intense flavor and massive clouds. It is simple and convenient in use for daily vaping.
Aftermath V2 Mechanical Mod Clone + Redemption RDA Kit Clone $24.59
The Aftermath V2 Mech Kit Clone consists of Aftermath V2 Mechanical Mod Clone and Redemption RDA Clone. This item also has other colors to choose.
Mod:
The Aftermath V2 Mechanical Mod Clone is constructed from brass. It comes with stunning appearance, with carved grooves on it. There are totally 16 venting holes on the mod for battery safe. The fire button is activated by magnets.
RDA:
The Redemption RDA Clone is a 24mm rebuildable atomizer constructed from stainless steel. It features Rapture style posts and Apocalypse style airflow with single airflow option. The dual clamp posts forms a bridge over the shelf for extra space. Resin and POM drip tip are included.
Ulton Replacement Tank Tube + Chimney Kit for FEV V3 / V4 / V4.5 RTA Clone $5.99
The replacement PMMA tank tube and chimney kit from Ulton is suitable for FEV V3 / V4 / V4.5 RTA Clone. This item also has other colors to choose.
Ulton Replacement Tank Tube for FEV V3 / V4 / V4.5 RTA Clone $3.89
The replacement PEI tank tube from Ulton is suitable for FEV V3 / V4 / V4.5 RTA Clone.
Original SMOKTech SMOK Replacement Pod Cartridge for Fit Starter Kit $2.29
The replacement pod cartridge features 2ml of juice capacity and refillable tank. It is suitable for original SMOKTech SMOK FIT starter kit. This item also has applications for the Infinix Starter Kit. you can choose what you like.
Original SMOKTech SMOK Replacement Pod Cartridge for Rolo Badge Starter Kit $2.39
The replacement pod cartridge features 2ml of juice capacity and refillable tank. It is suitable for original SMOKTech SMOK Rolo Badge starter kit.
Original Vaporesso GT Core Adapter for Cascade Tank Atomizer $4.89
The original Vaporesso GT Core Adapter is designed for Cascade Tank. With this Adapter, GT Core is also perfectly compatible with Cascade Tank. Easy installation to adapt GT core into Cascade tank.
Original Vaporesso GT2 Core Coil for Revenger Kit / NRG Tank / NRG Mini Tank $6.99
The original Vaporesso GT2 Core Coil is suitable for the Vaporesso Revenger Kit / NRG Tank / NRG Mini Tank. It features 0.4ohm resistance, supporting output wattage from 40 to 80 watts, best flavor for 55 to 65 watts.
This product comes with 3 PCS in 1 pack. This item also has other mode to choose.
Original Freemax Replacement SS316L Coil Head for Fireluke Mesh Sub Ohm Tank $17.99
The replacement coil head features 0.12ohm resistance, which works well at both wattage mode and temperature control mode at 400~550F. It is suitable for original Freemax Fireluke Mesh Sub Ohm Tank. It has wide contact surface between organic cotton and coil, which allows it to burn evenly and absorb e-juice effectively, giving you more intensive flavor and vapor production.
Старый 20.04.2018, 05:08 Автор темы   88
3FVAPE
Original Desire RAGE 155W TC VW Variable Wattage Squonk Box Mod $66.19
Designed and developed by Desire and Ohm Boy OC, the original Desire RAGE Squonk Box Mod is a dual 18650 (battery not included) squonk box mod with powerful chip to support VW / TC / Bypass mode. The wattage can be varied from 5 to 155W. The silicone squeeze bottle has 7ml of juice capacity. With Desire RAGE Squonk Box Mod, you can enjoy vaping with ease. This item also has other colors to choose.
Original Asmodus Lustro 200W Touch Screen TC VW Variable Wattage Box Mod $75.99
The original Asmodus Lustro Box Mod is a versatile regulated mod powered by dual 18650 batteries (not included), which can reach maximum output to 200W. With a capacitive touch screen, the operation on Lustro is very easy to vapers. Working with the latest GX-200-HUT chipset, Lustro Box Mod provides high performance in all aspects. The Curve output mode allows for detailed customization of the firing curve. The Lustro Box Mod will bring you the most comfortable vaping experience. This item also has other colors to choose.
Redemption RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
The Redemption RDA Clone is a 24mm rebuildable atomizer constructed from brass. It features Rapture style posts and Apocalypse style airflow with single airflow option. The dual clamp posts forms a bridge over the shelf for extra space. Resin and POM drip tip are included.
Original Vandy Vape Revolver RTA Rebuildable Tank Atomizer $47.99
The original VandyVape Revolver RTA is a 24.4mm RTA that features single coil build deck and unique 120 degrees revolving airflow design with different air hole types to choose. You can rotate the usual external screw to adjust the air hole to get the optimal flavor. This item also has other colors to choose.
Original Aspire Feedlink Squonk Box Mod + Revvo Boost Tank Kit $74.99
The original Aspire Feedlink Revvo Kit consists of Feedlink Squonk Mod and Revvo Boost Tank. This item also has other colors to choose.
Mod:
The Feedlink is a single 18650 battery (not included) bypass firing mod with all the quality and safety features you have come to expect from Aspire. Its almost pistol grip feel makes it very ergonomic in the hand and easy to operate the squonk bottle and fire button with just one hand, an absolute joy to hold and use. The silicone bottle has 7ml of juice capacity.
Tank:
The Aspire Revvo Boost Tank is redesigned with innovative, revolutionary, new type of coil, the ARC Aspire Radial Coil. The tank comes with 2ml of juice capacity for TPD compliant, and can be easily fed with bottom feeder pin.
Original Asmodus Spruzza 80W TC VW Variable Wattage Squonk Box Mod + Fonte RDA Kit $115.99
The original Asmodus Spruzza 80W Squonk Kit consists of Spruzza Squonk Box Mod and Fonte RDA. This item also has other colors to choose.
Mod:
The authentic Asmodus Spruzza Suqonk Box Mod is powered by GX-80-HUT chip which allows various modes (Power, Curve, TC, TFR, and TCR) with full touch screen operation. Powered by single 18650 battery (not included), the mod can reach maximum output to 80W (60W at TC mode). The Spruzza comes with its proprietary Smart Siphon System (SSS), a pump system that is the first of its kind. Both simple to maintain and operate; the SSS can be easily removed for cleaning and replacement, and can hold up to 6mL of your favorite juice in the reservoir, which can be filled by sliding the glass door upwards.
RDA:
The Fonte RDA is a low profile 24mm RDA that utilizes a squonk ready pin and is constructed from premium SS316. Compatible with both single and dual coil configurations with an optional single coil block. The deck of the Fonte is a simple two post design with side-mounted screws, making it easy to build on, and the juice well has a convex shape that makes juice flow to the walls, where it will be absorbed by your wicks. The side airflow inlets were machined at a downward angle to simulate a bottom-airflow design for improved flavor, which is enhanced by the conical top cap and wide-bore drip tip. The large heat sink on the top cap will help to get rid of excess heat.
Original Asmodus Spruzza 80W TC VW Squonk Box Mod Mosaic Edition + Oni-One RDA Kit $115.99
The original Asmodus Spruzza 80W Squonk Kit consists of Spruzza Squonk Box Mod and Oni-One RDA. This item also has other colors to choose.
Mod:
RDA:
The Oni-One RDA is a 24mm RDA. The deck of the ONI is a Unique two post design in which you remove the whole hex screw and placing your coil, making it easy to build on. The juice well is not only deep but also split so when you squonk, the juice directly wicks into the cotton for. We've machined the bottom airflow inlets in an upward angle to increase the flavor production. The 810 Black Delrin drip tip was designed in a way where the vape will condense into the bottom of the top and give you a denser, and flavorful vape experience. There is also a hidden feature inside the top cap of the ONI-ONE, inside the top cap, there is an ORING located in the top. This will catch all the juice and drip it back down the wick not wasting a drop of your valuable juice.
Original Vaporesso CCELL Core Coil for Revenger Kit / NRG Tank / NRG Mini Tank $8.29
The original Vaporesso CCELL Core Coil is suitable for the Vaporesso Revenger Kit / NRG Tank / NRG Mini Tank. It features 0.5ohm resistance, supporting output wattage from 20 to 35 watts.
Original GeekVape Flask Liquid Dispenser Light Version for BF Squonk Mod / RDA $14.90
The original GeekVape Flask is a multi-functional liquid dispenser that can be used to fill squonker mods or as a conventional dripping / filling bottle. The light version is made out of PC material and uses removable soft silicone internal bottle for long term economical usage due to its replaceable capability. It is a must have for squonk lovers! This item also has other colors to choose.
Старый 23.04.2018, 05:06 Автор темы   89
3FVAPE
Original VOOPOO Rune RDA Rebuildable Dripping Atomzier with BF Pin $25.99
The original VOOPOO Rune RDA has the 4 adjustable bottom airflow holes to provide optimal flavor for you. Its electrode-mast-free basement creates a maximum E-liquid capacity of the RDA. Rune features vertical coil connecting system which makes coil building easier. Besides, you can change the 810 or 510 resin drip tip freely.
Original KAEES Solomon 2 RTA Rebuildable Tank Atomizer $22.99
The original KAEES Solomon 2 is an updated version of KAEES Solomon RTA, which is an innovative leakproof RTA tank with 5ml large e-juice capacity and 24mm diameter. The build deck is 24K gold plated and is designed for single coil building. With the help of top adjustable airflow control system, the Solomon 2 RTA can prevent juice leakage and bring optimal flavor. This item also has other colors to choose. This item also has other colors to choose.
Original Footoon Aqua Reboot RTA Rebuildable Tank Atomizer $27.99
The original Footoon Aqua Reboot RTA is a unique 24mm dual coil RTA with 4.3ml juice capacity and exquisite design. The Aqua Reboot RTA provides a smoother airflow and enhanced flavor with the revolutionary new airflow design. The tank comes with dual post build deck to support various dual coil builds. The Aqua Reboot RTA is suitable for DIY fans. This item also has other colors to choose.
Original Eleaf iStick Pico Resin 75W TC VW Variable Wattage Box Mod + Melo 4 Tank Kit $56.99
The original Eleaf iStick Pico Resin Kit consists of iStick Pico Resin Mod and Melo 4 Tank. This item also has other colors to choose.
Mod:
This new iStick Pico Resin features all-new reimagined Net and multihole coil systems, presenting an unprecedented vaping experience with ultra-flavorful taste and huge clouds. A durable resin encasement of light weight and comfortable texture, and its elegant honeycomb looking makes it stand out from others. Powered by single interchangeable 18650 battery (not included), the iStick Pico Resin provides you with 75W maximum output and upgradeable firmware.
Tank:
The MELO 4 atomizer utilizes new EC-N (Net) and EC-M (Multihole) coils to give you an unprecedented vaping experience. The retractable top fill system makes it really easy to fill the tank. You just need to slide the drip tip back and it reveals the fill port. The dual large air inlets allow optimal airflow for great vapor production. It comes with resin style mouthpiece.
Original Innokin Proton 235W TC VW Variable Wattage Box Mod + Scion II Tank Kit $65.99
The original Innokin Proton Kit consists of Innokin Proton Mod Scion II Tank. This item also has other colors to choose.
Mod:
The Innokin Proton Mod adopts a brand new chipset to provide high performance, which can reach maximum power to 235W with dual 18650 batteries (not incldued). It also features the large side fire panel and joystick-style selector, making operation more convenient.
Tank:
The Innokin Scion II Tank utilizes new Mesh coil to provide optimal flavor. The tank comes with 3.5ml of juice capacity and can be extended to 5ml with extra glass tube.
Original VOOPOO Panda 1100mAh All-in-One Starter Kit $25.99
The original VOOPOO Panda Starter Kit comes with cute appearance and powerful output. Made of rubber, Panda can bring you softer touch feelings, and it can be held easily with ergonomically designed body. The Panda has 5ml pod capacity, and two different pods for other juices are included. The new vertical juice injection system is adopted to allow more air in to produce larger vapor and better flavor, and multiple safe protections avoid all potential risks. This item also has other colors to choose.
Original Aspire Revvo Boost Replacement ARC Coil $10.00
The fantastic all new coil design, the ARC, Aspire Radial Coil, sits horizontally in the tank similar to a stove-top design. Of course the real trick in the design is the increased surface area of the coil for great flavor and great vapor production rated at 0.10~0.14ohm using Kanthal AF wire. It works well at 70~80W. It is suitable for Aspire Revvo Boost Tank / Feedlink Revvo Kit.
Original Digiflavor Replacement Drip Tip for Upen Starter Kit $1.00
The replacement drip tip is suitable for original Digiflavor Upen Starter Kit.
Original Digiflavor Replacement Tank Tube for Upen Starter Kit $3.90
The replacement PCTG tank tube is suitable for original Digiflavor Upen Starter Kit.
Original Digiflavor Replacement Top Cap for Upen Starter Kit $4.90
The replacement top cap is suitable for original Digiflavor Upen Starter Kit.
Original Digiflavor Replacement Cover Cap for Upen Starter Kit $9.90
The replacement cover cap is suitable for original Digiflavor Upen Starter Kit.
Original Digiflavor Replacement Ni80 Coil Head for Upen Starter Kit $9.90
The replacement coil head is suitable for original Digiflavor Upen Starter Kit. It comes with 1.2ohm resistance and works well at 3.3~4.2V.
SXK Replacement 510 Drip Tip for Kayfun 5 Prime RTA Clone $1.99
The replacement 510 drip tip is suitable for SXK Kayfun 5 Prime RTA Clone and other atomizers that fit 510 drip tip. It is made out of PEI.
SXK Replacement Tank Tube for Kayfun 5 Prime RTA Clone $1.99
The replacement tank tube is suitable for SXK Kayfun 5 Prime RTA Clone. It is made out of PEI.
SXK Replacement Drip Tip + Tank Tube Kit for Kayfun 5 Prime RTA Clone $5.99
The replacement drip tip and tank tube kit is suitable for SXK Kayfun 5 Prime RTA Clone. The kit comes with PEI drip tip, PEI tube and 316SS tank.
Старый 24.04.2018, 05:25 Автор темы   90
3FVAPE
Original Asmodus Minikin V2 180W TC VW Variable Wattage Box Mod $81.99
The original Asmodus Minikin V2 is powered by a GX-180-HT chip which incorporates the same battery power saving capabilities as its predecessors but features 180W output and touch screen control. Coming with redesigned ergonomic body, you can hold it comfortably in hands. The mod is powered by dual 18650 batteries (not included). This item also has other colors to choose.
Original Asmodus Minikin V2 180W TC VW Variable Wattage Box Mod Kodama Version $299.99
The original Asmodus Minikin V2 Kodama Version is powered by a GX-180-HT chip which incorporates the same battery power saving capabilities as its predecessors but features 180W output and touch screen control. Coming with redesigned ergonomic body, you can hold it comfortably in hands. The mod is powered by dual 18650 batteries (not included). This item also has other colors to choose.
Original Asmodus Minikin Boost 155W TC VW Variable Wattage Box Mod $54.39
The original Minikin Boost Mod retains the shape of original Minikin while adding the most praised function of the Minikin V2, like the curve mode. Curve mode allows user to adjust their favorite output and keep it for vaping. With dual 18650 batteries (not included), the mod can reach maximum output up to 155W. The atomizer resistance range is from 0.1 to 2.5ohm. This item also has other colors to choose.
Original Asmodus Nefarius TF / BF RDTA Rebuildable Dripping Tank Atomizer with BF Pin $40.99
The original Asmodus Nefarius RDTA is a traditional Genesis style RDTA with removable micro hex screw, which makes it become a Top Fill / Bottom Fill (TF / BF) RDTA. You can bottom feeding the tank without worrying juice mess. The tank comes with centered airflow lock, 3 different airflow configurations and 2 drip tips for your option. With the help of different airflow, you can enjoy a tight and flavorful mouth-to-lung draw, or a nice airy cloudy draw. This item also has other colors to choose.
Original Asmodus Galatek RDA Rebuildable Dripping Atomizer with BF Pin $32.19
The original Asmodus Galatek RDA is a low profile RDA with unique graveyard deck, which allows enough space for easy coil building in such low profile atomizer. The metal cage that sits between the drip tip and top cap can absorb and dissipate the excess heat.
Original Asmodus Voluna RTA Rebuildable Tank Atomizer $31.99
The original Asmodus Voluna RTA is a 25mm tank focusing on flavor. The dual bottom airflow of the Voluna directs the entering air upwards against the bottom of the coils, ensuring the airflow comes in contact with as much surface area as possible to generate maximum flavor, and the adjustable dual cyclops style airflow slots allow the user to fine tune the draw to the favorite one. This item also has other colors to choose.
Original Asmodus Zesthia RTA Rebuildable Tank Atomizer $32.19
The original Asmodus Zesthia RTA is a 24mm RTA with dual post four terminal hot dog style deck. The two large posts located on the sides of the chamber enable the user to install even the largest of coils easily. The amazing flavor of the Zesthia is created by two main components: the airflow system and the unique chimney. The inlets sit at an angle, directing the incoming air upwards and along the length of the coil to boost vapor production which naturally results in a more flavorful experience. This vapor is then condensed by the upper chimney, concentrating the flavor present in every hit. This item also has other colors to choose.
Ulton Krma RDA Rebuildable Dripping Atomizer Clone with BF Pin + Spare Top Cap $13.98
The Ulton Krma RDA Clone is a 22mm RDA designed for single coil building and focused flavor. It is easy to build coil on the dual post build deck, with cutout at each post to put the lead easily. The RDA comes with side airflow system for smooth vapor.
This RDA comes with bottom feeder pin and extra black top cap (with PEI drip tip).
Duetto Reborn RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.99
The Duetto Reborn RDA Clone is a 22mm RDA that comes with dual post build deck for single coil building. The airflow hole is positioned at the base, providing tight airflow for the coil. It will bring fantastic vaping experience.
VCMT V2 RTA Rebuildable Tank Atomizer Clone $13.79
The VCMT V2 RTA Clone is a 25mm tank with 4.5ml juice capacity. It comes with Velocity style build deck for easy building. The tank also features internal juice flow control and adjustable airflow control. Juice can be easily refilled from the top. POM wide bore drip tip included.
Vapeasy Replacement Internal Tube for Dvarw MTL RTA Clone $6.99
The replacement internal tube is made out of PC and is suitable for Vapeasy Dvarw MTL RTA Clone. This item also has other colors to choose.
Vapeasy Replacement Tank Tube for Dvarw MTL RTA Clone $5.99
The replacement tank tube is made out of PC and has 5ml of juice capacity. It is suitable for Vapeasy Dvarw MTL RTA Clone. This item also has other colors to choose.
Старый 25.04.2018, 05:11 Автор темы   91
3FVAPE
Original ThinkVape Thor 200W TC VW Variable Wattage Box Mod $34.99
The original ThinkVape Thor Box Mod is a versatile regulated device with aesthetic appearance. Powered by ST200 Chip, this mod can reach maximum output power to 200W with dual 18650 batteries (not included). There are multiple modes can be selected: VW / VT (Ni / Ti / SS) / TCR / Bypass. The atomizer resistance range is from 0.05 to 3.5ohm. This item also has other colors to choose.
Original Soomook Hato K-One 238W TC VW Variable Wattage Box Mod $47.99
The Original Soomook Hato K-One Mod is a high end regulated device that is powered by ST chipset. With dual 18650 batteries (not included), the wattage can be varied from 5 to 238W. Hato K-One supports various modes, like power mode, temperature control mode, memory mode and bypass mode. The resistance range is 0.1 to 5ohm (VW), 0.06 to 1.3ohm (TC). The 510 connector is spring-loaded to match most atomizers in the market. This item also has other colors to choose.
Original Cthulhu Hastur MTL RTA Mini Rebuildable Tank Atomzier $32.00
The original Cthulhu Hastur MTL RTA Mini is an innovative single coil RTA tank with 2ml e-juice capacity and 22mm diameter. Designed for the best MTL vaping, the Hastur MTL RTA Mini features precise bottom airflow control with 3 air holes and a smaller chamber for better flavor. This item also has other colors to choose.
SXK Krma RDA Rebuildable Dripping Atomizer Clone with BF Pin $17.90
The SXK Krma RDA Clone is a 22mm RDA designed for single coil building and focused flavor. It is made out of 316 stainless steel. It is easy to build coil on the dual post build deck, with cutout at each post to put the lead easily. The RDA comes with side airflow system for smooth vapor.
This RDA comes with bottom feeder pin (pre-installed), no standard 510 pin included. This item also has other colors to choose.
Original Kado Stealth 450mAh 8W Ultra Portable System Starter Kit $23.79
The original Kado Stealth Starter Kit is a slim pod system kit designed for on-the-go. The Kado Stealth features no buttons and is automatically activated when you inhale. The Kado Stealth features a built-in 450mAh battery in a lightweight zinc alloy and rubber construction. The Kado Stealth comes with 2ml refillable cartridge. The Kado Stealth includes a micro USB charging cable. This item also has other colors to choose.
Original Asvape Defender 1200mAh All-in-One Starter Kit $59.00
The original Asvape Defender Starter Kit is an all-in-One vape kit that shows noble identity with its 316 stainless steel body material, the industry's top press and laser technology for 360 degrees seamless link. It caters for ergonomics and fit with extreme touch and excellent grip, exquisite switch, 1200mAh built-in lithium battery, this device will definitely bring you comfortable vaping experience.
Original Limitless Marquee 80W 1800mAh Box Mod + Tank Kit $69.00
The original Limitless Marquee 80W Kit consists of Limitless Marquee Box Mod and Limitless Marquee Sub Ohm Tank. This item also has other colors to choose.
Mod:
The original Limitless Marquee 80W Mod is an elegant and portable device featuring a maximum output of 80W and a built-in 1800mAh battery. Charged using the convenient Micro USB charging port, the Marquee offers a threadless 510 connection for providing users a wide variety of atomizers to use with the box mod system. The Limitless Marquee has a full temperature control suite, supporting Nickel, Titanium, Stainless Steel 316L and bypass mode. The vibrant OLED screen displays a clean and crisp layout. The Limitless Marquee 80W Box Mod is an amazing portable, versatile and well-balanced vapor system for flavor and vapor production.
Tank:
The Marquee Sub Ohm Tank is a 19mm atomizer with 2ml e-liquid capacity and threaded top fill system. It utilizes 0.6ohm Marquee Coil for great flavor and vapor production.
Original Nikola Niagara 200W VW Variable Wattage Squonk Box Mod + RDA Kit $79.90
The original Nikola Niagara 200W Squonk Kit consists of Nikola Niagara 200W Squonk Mod and Niagara Squonk RDA. This item also has other colors to choose.
Mod:
The original Nikola Niagara Squonk Box Mod is a high end regulated squonk device that features 200W maximum output with dual 18650 batteries (not included). The mod comes with various modes for your options. The resistance range is from 0.1 to 3ohm. The silicone bottle has 6ml of juice capacity.
RDA:
The original Nikola Niagara RDA is a 25mm RDA that comes with easy-to-build deck and adjustable side airflow. With this RDA, you can enjoy nice squonking experience, optimal flavor and huge vapor production.
Original Nikola Niagara PEI 100W VW Variable Wattage Squonk Box Mod + RDA Kit $79.90
The original Nikola Niagara PEI Squonk Kit consists of Niagara PEI 100W Squonk Mod and Gravity Squonk RDA. This item also has other colors to choose.
Mod:
The original Nikola Niagara PEI Squonk Box Mod is a high end regulated squonk device that features 100W maximum output with single 18650 / 20700 / 21700 battery (not included). The mod comes with various modes for your options. The resistance range is from 0.1 to 3ohm. The silicone bottle has 6ml of juice capacity.
RDA:
The original Nikola Gravity RDA is a 25mm RDA that comes with easy-to-build deck and adjustable side airflow. With this RDA, you can enjoy nice squonking experience, optimal flavor and huge vapor production.
Original SMOKTech SMOK Replacement Coil Head for Vape Pen Tank / Vape Pen 22 / Vape Pen Plus Kit $9.99
The replacement coil head comes with 0.25ohm resistance and works well at 30~50W. It is suitable for SMOK Vape Pen Tank / SMOK Vape Pen 22 / SMOK Vape Pen Plus Kit.
Original Joyetech Replacement Cartridge for Exceed Edge Starter Kit (5 PCS) $10.99
The replacement cartridge comes with 2ml of juice capacity. It is suitable for original Joyetech Exceed Edge Starter Kit.
Original Joyetech Replacement Cartridge for Exceed Edge Starter Kit $4.99
One piece will be shipped.
Vapeasy Replacement Battle Deck for Battle RDA Clone $4.99
The replacement Battle Deck from Vapeasy is made out of silver-plated stainless steel. It can be compatible with Battle Cap.
Vapeasy Replacement Top Cap A for Battle RDA Clone $70.99
The replacement Battle Cap from Vapeasy is made out of Damascus steel. It can be compatible with Battle RDA Clone. This one can work without drip tip.
Vapeasy Replacement Top Cap B for Battle RDA Clone $70.99
The replacement Battle Cap from Vapeasy is made out of Damascus steel. It can be compatible with Battle RDA Clone. This one is compatible with 810 drip tip.
Vapeasy Replacement Front + Back Panels for Billet Box Mod Clone $335.99
The replacement Billet Box Mod Clone Cover Panel from Vapeasy is made out of Damascus steel. It is suitable for SXK Billet Box Mod Clone perfectly. The Damascus pattern is very attractive and beautiful.
This product comes with 1 front panel and 1 back panel, totally 2 PCS.
Original Limitless Pulse 380mAh 8W Pod System Vape Pen Starter Kit $29.90
The original PLY Rock Pulse Pod System Starter Kit is designed to be slim, compact, and easily transported, featuring versatile ultra portable pod system that allows you to use your favorite e-liquids. The kit comes with 380mAh built-in battery and 8W output power. The Pulse is activated and used by a draw-activated firing mechanism, making it easy to vape whenever you like.
Старый 26.04.2018, 05:00 Автор темы   92
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Pioneer4You IPV Trantor TC VW Variable Wattage Box Mod $59.99
The original Pioneer4You IPV Trantor Mod utilizes advanced YiHi SX500A Chip, which allows it to provide high performance and multiple protections. With dual 18650 batteries (not included), the Trantor can reach maximum output power to 200W. The innovative SXi-Q control system allows you to customize your own taste. There are many options to adjust output modes. The atomizer resistance range is from 0.15 to 3ohm. Trantor will bring you a lot of fun of vaping. This item also has other colors to choose.
Original Mecanvape Voiceprint RDA Rebuildable Dripping Atomizer with BF Pin $17.99
The original Mecanvape Voiceprint RDA is a 24mm RDA with innovative X style post design. The positive post and negative post are cross, and you can build coils easily on this deck. The Z style airflow tunnel can efficiently control the airflow and provide purer flavor and more clouds. 810 resin drip tip is included.
Original Joyetech Batpack Box Mod + Joye ECO D16 Tank Kit $27.99
The original Joyetech Batpack Kit consists of Joyetech Batpack Mod and Joye ECO D16 Tank Atomizer. This item also has other colors to choose.
Mod:
The original Joyetech Batpack Mod is designed to use dual AA / AA Ni-MH Batteries (not included). The Batpack is incredibly simple and convenient to use and now it comes with ECO technology. ECO Tech still provides the best vaping experience and allows the battery to have a very low output. This extends the battery life by almost double.
Tank:
The Joye ECO D16 atomizer adopts an integrated mouthpiece and exquisite restricted airflow. BFHN 0.5ohm coil head is optimized for using with high nicotine e-liquids. Meanwhile, it is easy to carry, install and refill. In short, this atomizer looks clean and tight.
The Batpack Mod can only used with Joye ECO D16 Tank, and the Joye ECO D16 Tank can only work with Batpack Mod.
Original Pioneer4You IPV Trantor TC VW Variable Wattage Box Mod + LXV4 Tank Kit $71.99
The original Pioneer4You IPV Trantor Kit consists of IPV Trantor Mod and LXV4 Tank. This item also has other colors to choose.
Mod:
Tank:
The IPV LXV4 Tank is a 26mm sub ohm tank with 2ml of juice capacity. It is integrated with 0.15ohm LXV4 quadruple coil, providing optimal flavor and great vapor production.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $2.59
The replacement 510 drip tip is made from resin with 12.6mm height. It is suitable for all atomizers that fit 510 drip tip.
One piece will be shipped (random color). More options than what's on the image. This item also has other Height to choose.
The 810 drip tip is made from resin with 12mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload / Battle RDA $3.59
The 810 drip tip is made from resin with 13.6mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Romio Tool Kit for E-Cigarette DIY Coil Building $29.99
The Romio Tool Kit comes with 1 x diagonal pliers, 1 x needle-nose pliers, 1 x folding scissors, 1 x coiling kit, 2 x screwdrivers, 2 x tweezers, 1 x cleaning brush and 1 x Kanthal A1 heating wire. This DIY tool kit is a good choice for DIY lovers.
Старый 27.04.2018, 05:31 Автор темы   93
3FVAPE
Original Wismec SINUOUS RAVAGE230 230W TC VW Variable Wattage Box Mod $45.99
The original Wismec SINUOUS RAVAGE230 TC VW Box Mod features sleek appearance with ergonomic design, 1.45inch large color display and updated centered 510 connector. Powered by dual 18650 batteries (not included), the mod is capable of delivering output power from 1W to 230W. It also supports temperature control and multiple working modes. With side fire switch, it is very easy to use. This item also has other colors to choose.
Original Alphafox Famas 100W TC VW Variable Wattage Box Mod $79.90
The original Alphafox Famas Mod is a convenient single 18650 device (battery not included) for you to vape on the go. It can reach maximum output power to 100W. Famas supports various modes, like VW, TC and Curve, which provides lots of fun of vaping. This item also has other colors to choose.
Original Vzone Culture 100W TC VW Variable Wattage Box Mod $83.90
The original Vzone Culture Mod is a compact device that utilizes single 18650 or 20700 battery (not included), which can reach maximum output power to 100W. The allowed atomizer resistance is from 0.1 to 3ohm (KA mode), 0.05 to 1ohm (Ti / Ni200 / SS316 Mode). This item also has other colors to choose.
Original Vzone Graffiti 220W TC VW Variable Wattage Box Mod $85.90
The original Vzone Graffiti Mod utilizes the most advanced chipset HW Board 1.0, which allows it to reach maximum output power to 220W with dual 18650 batteries (not included). The allowed atomizer resistance is from 0.1 to 3ohm (KA mode), 0.05 to 1ohm (Ti / Ni200 / SS316 Mode). The mod comes with aesthetic graffiti pattern on it, it is really cool to vape with Vzone Graffiti Mod. This item also has other colors to choose.
Original HCigar Wildwolf 235W TC VW Variable Wattage Box Mod $44.99
The original Hcigar Wildwolf Mod adopts the advanced XT235 chipset, which allows it to reach output power to 235W with dual 18650 batteries (not included). With 1.3inch TFT HD display screen, you can view and operate the value setting more comfortably. This item also has other colors to choose.
Original VapeOnly Aura 2000mAh All-in-One Starter Kit $32.99
The original VapeOnly Aura AIO Kit is a pen-style device that is designed for beginner or those who want a convenient vape when they are on the go. It comes with 2000mAh built-in battery, which can provide quite a long time for vaping. The atomizer has about 2ml of juice capacity. The innovative dust cap keeps the drip tip clean, and it can be attached to the bottom of the kit due to the magnet. The kit also features adjustable airflow design and child-proof lock design. This item also has other colors to choose.
Original Aspire Breeze 2 1000mAh All-in-One Starter Kit $34.99
The original Aspire Breeze 2 AIO Kit has a built-in 1000mAh battery, it has an improved filling method compare to its previous version. The same compact and ergonomic design but a more convenient pod system that holds 2ml capacity e-juice, or a slightly larger 3ml version. It is ergonomic and comfortable to hold. The great U-tech coil technology ensures you a flavorful vape. The 1ohm coil is recommended for nicotine salt. This item also has other colors to choose.
Original Wismec SINUOUS RAVAGE230 230W TC VW Box Mod + GNOME King Tank Kit $59.99
The original Wismec SINUOUS RAVAGE230 Kit consists of Wismec SINUOUS RAVAGE230 Mod and GNOME King Tank. This item also has other colors to choose.
Mod:
Tank:
The GNOME King is a 26mm tank with 5.8ml juice capacity. Featuring the unique crown molding shape and perfect color scheme, the gorgeous GNOME King atomizer utilizes the updated WM01 coil for intense flavor.
Original Blitz Snake Skin 810 Drip Tip for SMOK TFV8 / TFV12 Tank Atomizer $2.99
The original Blitz 810 drip tip is made from Epoxy resin. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
3FVAPE вне форума   Вверх
Старый 28.04.2018, 05:06 Автор темы   94
3FVAPE
Original VOOPOO TOO Resin 180W TC VW Variable Wattage Box Mod $65.99
The original VOOPOO TOO Resin box mod adopts upgraded Gene.Fan chip, which broke a record of the world's fastest firing speed and allows the firing speed reach 10 milliseconds (0.01S). VOOPOO TOO can be powered by single battery or dual batteries (battery not included), and the power range with single battery is 5~80W, while the range with dual is 5~180W. The colorful resin panels makes the mod looks more beautiful, and they are also replaceable.
This mod comes with red frame. This item also has other colors to choose.
Original Vapesoon LTN 1800mAh HNB Heat-Not-Burn Box Mod $45.99
The original Vapesoon LTN Box Mod is a new HNB (Heat-Not-Burn) device specially designed for tobacco. It is compatible with wide IQOS HEETS / Heatsticks. With built-in 1800mAh battery and steel needle heating design, Vapesoon LTN offers heating at stable temperature and the large battery capacity is enough for heating 20 HEETS. The accurate heating temperature ensures better flavor. Moreover, comes with the clear OLED screen, you can simply glance at remaining battery capacity, puffs, temperature and other notices. This item also has other colors to choose.
Original OBS Engine 2 RTA Rebuildable Tank Atomizer $25.99
The original OBS Engine II RTA, the updated version of OBS Engine RTA, is a dual coil RTA with 5ml of juice capacity. It is easy to build dual coils on this build deck. The Engine 2 also features the precise design of air circulation system to concentrate the vapor and enhance the flavor. This item also has other colors to choose.
Original Fummy Maple Leaf RDA Rebuildable Dripping Atomizer with BF Pin $20.99
The original Fummy Maple Leaf RDA is a 24mm RDA that features visible top cap, which is made out of stainless steel and glass. It allows you to know how much juice is left without taking off any part. The air enters the angled airslots on both sides of the top cap, and hit the coils directly, providing really smooth and tasty vapor.
Original Cool Vapor Cavalry RDTA Rebuildable Dripping Tank Atomizer with BF Pin $29.90
The original Cool Vapor Cavalry RDTA is a 24.5mm RDTA with 3ml of juice capacity. The dual coil build deck allows you to build coils easily. The filling port is hidden unless you rotate the external cap. It also supports bottom feeding. The airflow can be adjusted by the top cap. PEI threaded top cap is included.
This RDTA comes with bottom feeder pin only, no stardard 510 pin. This item also has other colors to choose.
Original Oumier Wasp Nano Mini RDA Rebuildable Dripping Atomizer with BF Pin $13.59
The original Oumier Wasp Nano Mini RDA is constructed from brass in 22mm diameter. The Authentic Oumier Wasp Nano Mini RDA is with large build deck design for single coil build. This RDA has direct side airflow design to ensure fabulous vaping experience.
The RDA comes with bottom feeder pin. This item also has other colors to choose.
Original SMOKTech SMOK X-Priv Baby 80W 2300mAh TC VW Box Mod + TFV12 Big Baby Prince Tank Kit $63.49
The original SMOK X-Priv Baby Kit consists of SMOK X-Priv Baby Mod and TFV12 Big Baby Prince Tank. This item also has other colors to choose.
Mod:
The SMOK X-Priv Baby Mod is small and subtle, with glassy texture at front, and cobra pattern at back, which is wonderful more than one side. Its nobleness and stylishness highlight the new traits and extraordinary taste. It has a 2.0inch large screen with high-definition to offer you more clear vaping data. The built-in 2300mAh large capacity and 80W output will inspire your endless vaping desire.
Tank:
The TFV12 Big Baby Prince Tank is a 28mm sub ohm tank with 6ml of juice capacity. It combines with innovative V8 Baby cores, which will bring you denser cloud and purer flavor.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $2.59
The replacement 510 drip tip is made from resin and stabilized wood with 14mm height. It is suitable for all atomizers that fit 510 drip tip.
810 Cobra Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload / Battle RDA $2.99
Старый 02.05.2018, 05:12 Автор темы   95
3FVAPE
Original SMOKTech SMOK X-Priv Baby 80W 2300mAh TC VW Variable Wattage Box Mod $48.79
The SMOK X-Priv Baby Mod is small and subtle, with glassy texture at front, and cobra pattern at back, which is wonderful more than one side. Its nobleness and stylishness highlight the new traits and extraordinary taste. It has a 2.0inch large screen with high-definition to offer you more clear vaping data. The built-in 2300mAh large capacity and 80W output will inspire your endless vaping desire. This item also has other colors to choose.
Original Yiloong Fog Box V2 DNA75C 75W TC VW Variable Wattage Box Mod $159.99
The original Yiloong Fog Box V2 DNA75C Mod is a high-end regulated device that utilizes advanced DNA75C chip from Evolv, providing stable and high performance. Powered by single 18650 / 20700 battery (not included), Fog Box V2 can reach maximum power to 75W. The chassis adopts beautiful and high quality stabilized wood, making this mod more attractive.
Original Yiloong Fog Box DNA250 167W TC VW Variable Wattage Box Mod $169.99
The original Yiloong Fog Box DNA250 Mod is a high-end regulated device that utilizes advanced DNA250 chip from Evolv, providing stable and high performance. The Fog Box DNA250 Mod is powered by dual 18650 batteries (not included), Fog Box can reach maximum power to 167W. The chassis adopts beautiful and high quality stabilized wood, making this mod more attractive.
Original HCigar Aurora 80W TC VW Variable Wattage Squonk Box Mod $46.39
The original Hcigar Aurora Squonk Mod is a regulated mod that can reach maximum output up to 80W with single 18650 / 20700 / 21700 battery (not included). It has a unique battery replacement method and can be easily replaced without an adapter, which brings a better experience.
Original Oumier Flash VT-1 222W TC VW Variable Wattage Box Mod $46.99
The original Oumier Flash VT-1 Mod is a versatile regulated box mod, which can power from 5 to 222W with dual 18650 batteries (not included). It supports various modes, including VW, NI, TI, SS, and Bypass. The atomizer resistance range is from 0.08 to 3ohm. This item also has other colors to choose.
Original Wismec Luxotic 100W Squonk Box Mod $37.99
The Wismec Luxotic BF Box Mod, designed by JayBo, features its reimagined squonk system and inbuilt refillable e-liquid bottle of 7.5ml capacity. Powered by single 18650 battery (not included), Luxotic can reach maximum output to 100W. The large capacity squonk bottle allows you to vape with ease without refilling frequently. The cover panel is replaceable, making it different whenever you like. This item also has other colors to choose.
Original Smokjoy OPS-1 1100mAh All-in-One Starter Kit $26.99
The original Smokjoy OPS-1 Starter Kit is a tiny and portable device for you on the go. It utilizes built-in 1100mAh battery for full power output and comes with 2ml refillable pods, with both 0.6 and 1.2ohm for MTL and DTL experience. This item also has other colors to choose.
Original Oumier Wasp Nano Mechanical Squonk Kit $85.99
The Oumier Wasp Nano Squonk Kit is a new squonk device which is powered by single 18650 battery (not included) and comes with 8ml of juice capacity. It will bring you great squonking experience. This item also has other colors to choose.
Original Wismec Luxotic 100W Squonk Box Mod + Tobhino BF RDA Kit $48.99
The original Wismec Luxotic BF Kit consists of Luxotic BF Box Mod and Tobhino BF RDA. This item also has other colors to choose.
Mod:
RDA:
The Wismec Tobhino BF RDA is a 22mm atty that features open build place and adjustable side airflow. You can even build a fancy coil in this tiny RDA. It comes with decorative ring for not only decoration, but also heat insulation. With optional top cap, Tobhino is compatible with both 510 and 810 drip tips.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from resin with 12.5mm height. It is suitable for all atomizers that fit 510 drip tip.
One piece will be shipped (random color). More color than what's on the image.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload / Battle RDA $2.99
Original Aspire Replacement Coil Heads for Breeze 2 Starter Kit $11.99
The original Aspire Breeze 2 Replacement Coils features 1.0ohm resistance and works perfectly with nicotine salt. It is suitable for Aspire Breeze 2 Starter Kit.
Vapeasy Scissors for Cutting Cotton $2.99
The Vapeasy Scissors is used to cut or trim the cotton. It is very easy to use and very durable.
Vapeasy 24-in-1 Screwdriver Tool Kit for DIY $30.99
The Vapeasy Screwdriver Kit consists 1 aluminum container box, 1 aluminum screwdriver handle and 24 types of screwdriver bits. It can be used to repair watches, cameras, radios, computers, smartphones, drones and other small size household electrical appliances. You can also use it for DIY coil building.
Старый 03.05.2018, 04:57 Автор темы   96
3FVAPE
Original IJOY Saber 100W VW Variable Wattage Mod with 20700 Battery $36.99
The IJOY Saber Mod is a single 20700 battery regulated tube mod, which is ergonomically designed and very compact. It utilizes IWEPAL chip for stable performance and comes with several protections, such as short-circuit protection, low-power protection, and anti-reverse protection of the battery. This makes the mod safer and more reliable and removes the unsafe factors of the mechanical mod. The battery is removable and supports USB fast charging. Equipped with a 20700 battery, the energy density is almost 1.5 times higher than 18650, and 18650 battery can also be used through the battery adaptor. This item also has other colors to choose.
Original Fuumy Su Lie Hybrid Mechanical Mod $62.99
The original Fuumy Su Lie Mechanical Mod is constructed from anodizing sandblasted aluminum. It comes with hybrid connection and is not overhang with 25mm atomizers. There are grooves for vape bands at the top and bottom. The kit comes with 4 different color bands for replacement. The fire button is activated by magnets. This mod comes without lockable mechanism.
Original Shield Cig BoBo Sub Ohm Tank Clearomizer $7.99
The original Shield Cig BoBo Sub Ohm Tank is a 22mm atomizer with 2ml of juice capacity. It is constructed from stainless steel and Pyrex glass. The tank utilizes 0.3ohm mesh coil, which works well at 30~45W. The bottom airflow can be adjusted by the AFC ring. 510 resin drip tip is included. This item also has other colors to choose.
Original Shield Cig Luxembourg RDA Rebuildable Dripping Atomizer $10.99
The Shield Cig Luxembourg RDA is a 24mm RDA that features gold plated dual post build deck. It is easy to build coils with 4 terminals at the posts. The air enters the bottom airslots and travels up to the bottom of the coils. Removable wide bore drip tip is included. This item also has other colors to choose.
Original IJOY Saber 100W VW Variable Wattage Mod + Diamond Tank Kit with 20700 Battery $51.89
The original IJOY Saber 100 Kit consists of IJOY Saber Mod and IJOY Diamond Sub Ohm Tank. This item also has other colors to choose.
Mod:
Tank:
The IJOY Diamond Tank is a 25mm sub ohm tank with 5.5ml of juice capacity. It features large airflow, great vapor, good flavor, 180 degrees fast screw-cap filling, wide bore 810 resin drip tip, and stylish diamond design. The tank utilizes the innovative Diamond coil, which can atomize the juice completely and restore the original taste.
Original Shield Cig Redemption Hybrid Mechanical Mod + RDA Kit $31.99
The original Shield Cig Redemption Mech Kit consists of Redemption Mechanical Mod and Redemption RDA. This item also has other colors to choose.
Mod:
The original Shield Cig Redemption Mechanical Mod is constructed from brass with 24mm diameter. It features aesthetic engraved pattern on the tube, hybrid connection, bottom ventilation, and magnetic fire button.
RDA:
The Shield Cig Redemption RDA is a 24mm RDA that features gold plated dual post build deck. It is easy to build coils with 4 terminals at the posts. The air enters from the bottom airslots and travels up to the bottom of the coils. PEI drip tip is included.
Старый 04.05.2018, 05:07 Автор темы   97
3FVAPE
NextEra-LE RDTA Rebuildable Dripping Tank Atomizer Clone with BF Pin $8.99
The NextEra-LE RDTA Clone is a 22mm rebuildable tank atomizer with 2ml of juice capacity. The RDTA is constructed from stainless steel and comes with 510 POM drip tip, PC top cap and tank tube. The build deck is dual post design for single coil building. The side airflow can be adjusted by rotating the top cap. Delrin decorative ring (24mm outer diameter) is included.
This RDTA comes with bottom feeder pin. This item also has other colors to choose.
Original Wismec CB-80 80W TC VW Variable Wattage Box Mod + Amor NS Pro Tank Kit $58.99
The original Wismec CB-80 Kit consists of CB-80 Mod and Amor NS Pro Tank. This item also has other colors to choose.
Mod:
The Wismec CB-80 (Check Bunny 80watt), another masterpiece designed for nic-salts use by Jake Barney, boasts its 80W max output with 2A quick charge technology. Stylish in look and convenient in use, you can get the vaping pleasure instantly from CB-80 under the support of optimized software. The CB-80 is powered by single 18650 battery (not included).
Tank:
The Wismec Amor NS Pro Tank is a 22mm sub ohm tank with 2ml of juice capacity. Featuring a refined airflow control system and new WS04 MTL 1.3ohm head for pure flavor, the colorful Amor NS Pro provides you intense flavor and wonderful MTL vaping enjoyment.
The replacement 510 drip tip is made from resin (mouthpiece) and stainless steel (base) with 15mm height. It is suitable for all atomizers that fit 510 drip tip.
One piece will be shipped (random color). More color than what's on the image. This item also has other height to choose.
810 Replacement Drip Tip for 528 Goon / Kennedy / Battle / Reload RDA $1.99
The 810 drip tip is made from resin with 13mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
YFTK Replacement Drip Tip for M-Atty RDA Clone $2.99
The replacement drip tip is made from plastic and is suitable for YFTK M-Atty RDA Clone. This item also has other colors to choose.
YFTK Replacement Top Cap for M-Atty RDA Clone $3.59
The replacement top cap is made from POM and is suitable for YFTK M-Atty RDA Clone. This item also has other colors to choose.
YFTK Replacement Top Cap + Bottom Cap for M-Atty RDA Clone $8.99
The replacement top cap and bottom cap are made from PEI and is suitable for YFTK M-Atty RDA Clone.
YFTK Replacement Airflow Blocker for M-Atty RDA Clone $4.99
The replacement airflow blocker are made from PEEK and is suitable for YFTK M-Atty RDA Clone.
Original Shield Cig Shield Tool Kit for E-Cigarette DIY Coil Building $19.99
The Shield Cig Shield Tool Kit comes with 1 x diagonal pliers, 1 x needle-nose pliers, 1 x folding scissors, 1 x coiling kit, 1 x screwdriver kit, 1 x tweezers and 6 x hex screws. This DIY tool kit is a good choice for DIY lovers.
Original Shield Cig Shield Tool Kit V2 for E-Cigarette DIY Coil Building $30.99
The Shield Cig Shield Tool Kit V2 comes with 1 x diagonal pliers, 1 x needle-nose pliers, 1 x folding scissors, 1 x coiling kit, 1 x screwdriver kit, 1 x cleaning brush, 2 x tweezers and 1 x 510 drip tip. This DIY tool kit is a good choice for DIY lovers. This item also has other colors to choose.
Старый 05.05.2018, 04:51 Автор темы   98
3FVAPE
Original IJOY Saber 100W VW Variable Wattage Mod $36.69
The IJOY Saber Mod is a single 20700 battery regulated tube mod, which is ergonomically designed and very compact. It utilizes IWEPAL chip for stable performance and comes with several protections, such as short-circuit protection, low-power protection, and anti-reverse protection of the battery. This makes the mod safer and more reliable and removes the unsafe factors of the mechanical mod. The battery is removable and supports USB fast charging. Equipped with a 20700 battery (not included), the energy density is almost 1.5 times higher than 18650, and 18650 battery can also be used through the battery adaptor. This item also has other colors to choose.
Original Wismec CB-80 80W TC VW Variable Wattage Box Mod $39.79
The Wismec CB-80 (Check Bunny 80watt), another masterpiece designed for nic-salts use by Jake Barney, boasts its 80W max output with 2A quick charge technology. Stylish in look and convenient in use, you can get the vaping pleasure instantly from CB-80 under the support of optimized software. The CB-80 is powered by single 18650 battery (not included). This item also has other colors to choose.
Original IJOY Saber 100W VW Variable Wattage Mod + Diamond Tank Kit $46.99
Mod:
Tank:
YFTK Billet Box 60W All-in-One Box Mod Kit Clone $99.99
The YFTK Billet Box mod Clone is constructed from aluminum with an all-in-one design. It is powered by 1 x 18650 battery (not included) and maximum power output is 60W. The box mod is powered by Evolv DNA 60 chip. This item also has other colors to choose.
Original Coil Father X9 Carrying Storage Bag for E-cigarette $5.99
The original Coil Father Vape Pocket X9 Carrying Storage Bag is a multifunctional bag for you to carry vaping devices or DIY tools on the go. This durable, practical, portable bag is a good choice for all vapors.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $2.99
The 810 drip tip is made from resin with 13.6mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors and Drip tip for Battle RDA to choose
Старый 07.05.2018, 05:03 Автор темы   99
3FVAPE
Rogue Wolf Hybrid Mechanical Mod Clone $19.99
The Rogue Wolf Mechanical Mod Clone is constructed from aluminum in 24mm diameter. It is powered by single 18650 battery (not included). It features 510 hybrid top cap, 4 venting holes and spring fire button. This item also has other Material to choose.
Original Aleader Caesar 100W TC VW Variable Wattage Box Mod $79.99
The Original Aleader Caesar Box Mod is a high end regulated temperature control mod that features colorful stabilized wood chassis and 100W maximum output. The Caesar 100W stabilized wood box mod is powered by single 18650 / 20700 / 21700 battery (not included).
This mod will be shipped with random color. More color than whats on the image.
Original ThinkVape Thor 200W TC VW Variable Wattage Box Mod $35.99
The Original ThinkVape Thor Box Mod is a versatile regulated device with aesthetic appearance. Powered by ST200 Chip, this mod can reach maximum output power to 200W with dual 18650 batteries (not included). There are multiple modes can be selected: VW / VT (Ni / Ti / SS) / TCR / Bypass. The atomizer resistance range is from 0.05 to 3.5ohm. This item also has other colors to choose.
Original Coil Father Mega Sub Ohm Tank Clearomizer $8.99
The Original Coil Father Mega Sub Ohm Tank is a 24mm clearomizer with 3ml of juice capacity. The tank utilizes 0.2ohm head and features threaded Delrin drip tip, convenient top filling, and adjustable top airflow. This item also has other colors to choose.
Original Atomvapes Atom Sandman Hybrid Mechanical Mod + Njord RDA Kit $99.99
The Original Atom Sandman Mech Kit consists of Atom Sandman Mech Mod and Njord RDA.
Mod:
The Atom Sandman Mech Mod from Atomvapes is ergonomically designed for you to find the sweet spot to hold. It comes with revolutionary Tricon firing system, which ensures quick firing at low voltage. It is powered by single 18650 battery (not included).
RDA:
The Atom Njord RDA is an innovative single coil RDA that comes with dual post build deck for easy single vertical coil building. Besides, the RDA comes with triple angled airflow system to provide optimal airflow for the vertical coil.
Decorative Ring for 24mm RDA / RTA / Sub Ohm Tank Atomizer $1.59
The decorative ring adpater is made from PC and is suitable for 24mm diameter atomizers. The outer diameter is 26mm and the inner diameter is 24mm. This item also has other colors to choose.
The replacement 510 drip tip is made from resin with 13.6mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors and Material to choose.
Старый 08.05.2018, 04:59 Автор темы   100
3FVAPE
SOB V2 Squonk Mechanical Box Mod Clone $23.99
The SOB V2 Squonk Box Mod Clone is constructed from POM and brass. The mod is powered by single 18650 battery (not included) and comes with built-in 8ml bottle for squonking. The Delrin chassis feels smooth in hands.
Original Coil Father King RDTA Rebuildable Dripping Tank Atomizer $9.59
The Original Coil Father King RDTA is a 25mm rebuildable tank atomizer with 6.5ml of juice capacity. The tank features dual post build deck with quad terminals for easy coil building. The filling port will be blocked by the plug in the cap. The bottom airflow is adjustable. 810 wide bore Delrin drip tip is included.
Ulton Jorda B RDA Rebuildable Dripping Atomizer Clone with BF Pin + PMMA / SS Cap $11.59
The Ulton Jorda B RDA Clone is a small size squonk RDA for MTL or restricted DL vapers. The RDA comes with 2 SS cap with different airhole sizes and 1 PMMA cap. The airhole size is 1.5mm, 2mm and 3mm. The build deck comes with dual post design for single coil building. 510 POM drip tip is included. This item also has other colors to choose.
YFTK Genny 2 RTA Rebuildable Tank Atomizer $19.99
The YFTK Genny 2 RTA is a 22mm RTA constructed from 316 stainless steel and PEI. It comes with 4.2ml of juice capacity. The RTA features dual post design and wide build deck for easy coil building. The PEI drip tip and tank tube can insulate heat, providing comfortable vaping experience.
Original SMOKTech SMOK Stick Prince Baby 2000mAh Mod + TFV12 Baby Prince Tank Kit $37.29
The SMOK Stick Prince Baby Kit consists of Stick Prince Baby 2000mAh Battery Mod and TFV12 Baby Prince Tank. This item also has other colors to choose.
Mod:
The SMOK Stick Prince Baby Mod comes with 2000mAh built-in battery, giving you great vaping experience. With large battery capacity, it is possible to vape for a long time. The newly designed hexagon power button looks special and can give you better hand-feel when you press it. SMOK Stick Prince Baby is so portable that you can put it in your pocket on the go.
Tank:
The original SMOK TFV12 Baby Prince from SMOKTech is the upgraded version of TFV8 baby beast tank. The new mesh coils can produce denser clouds and purer flavor at the same wattage, which is an awesome improvement. These coils are newly designed, the light coil will emit beautiful light when you are vaping and the mesh coil has larger heating area to speed up heating process. Besides, this tank employs bulb glass tube, which can enlarge the e-juice capacity to 4.5ml. Every detail of TFV12 Baby Prince is the best guarantee for high-quality vaping.
SOB V2 Squonk Mechanical Box Mod Clone + Outlaw RDA Clone Kit $26.99
The SOB V2 Squonk Kit Clone consists of SOB V2 Squonk Mod Clone and Outlaw RDA Clone. This item also has other colors to choose.
Mod:
RDA:
The Outlaw RDA Clone is constructed from stainless steel with 24mm diameter. The deck features classic dual post style design and comes with a deep juice well. The airflow can be adjusted by dual airslots on each side. The heat resistant POM drip tip can protect your mouth from heat.
Captain America Mechanical Mod Clone + RDA Kit $29.99
The Captain America Mech Kit Clone consists of Captain America Style mechanical mod and Captain America Style RDA. This item also has other colors to choose.
Mod:
The Captain America mechanical mod Clone is constructed from aluminum and is powered by single 18650 / 20700 battery (not included). It comes with top ventilation system and magnetic fire button.
RDA:
The Captain America RDA Clone is a 26mm RDA that features bullet shape and side airflow system. The Delrin drip tip can insulate the heat and protect your mouth.
Replacement Tank Tube for SMOK TFV12 Prince Tank Atomizer $1.99
The replacement tank tube is made from PC and is suitable for authentic SMOKTech SMOK TFV12 Prince Tank Atomizer. This item also has other colors to choose.
The replacement 510 drip tip is made from resin with 15.5mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other colors to choose.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 14mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has other colors to choose.
Время генерации страницы 0.67874 секунды с 15 запросами
