340519
960
51
821
822
Регистрация: 25.05.2012 Последняя активность: 24.05.2019 15:41
Сказал(а) спасибо: 47
Поблагодарили: 50 раз(а) в 44 сообщениях
823
Шурик с шуриком
вот такой вот чайнашур http://kaidomain.com/produc...
824
[Исправлено: Mauser, 28.04.2013 в 16:05] |
825
HID маньяк
Регистрация: 04.09.2010 Последняя активность: 13.10.2025 12:38
Сказал(а) спасибо: 787
826
Регистрация: 25.12.2012 Последняя активность: 23.06.2016 14:00
Сказал(а) спасибо: 249
http://www.olightworld.com/...
Olight new product “M18” launch M18 Maverick( M18 for short) is supper power LED flashlight specially designed for tactical applications, it is extended from Olight’s S20 Baton but better. M18 is assigned striking stainless steel bezel、tail forward push switch and friend tactical user interface, beyond that , it assembled the latest in CREE XM-L2 LED, highly optimized small window smooth reflector, which raise light intensity up to 80%, the output reach 500 lumens。M18 can be powered by 2xCR123A or RCR123A and 1x 18650 batteries, it includes high efficiency constant current circuit and precise light-thermal balance program which ensure high brightness but long run time. The structure is designed under the idea of compact、light、difference and reliable so that it is very solid and durable. Olight produced various accessories (such as weapon mount、filter、remote controller) to promote its value. It is a perfect choice for government agencies, law enforcement, military applications, hunting, outdoor and much more. M18 Maverick Features: 1.Utilizing the newest Cree XM-L2 LED, the output is up to 500 lumens; 2.Multi-functional tail forward push switch. lightly press tailcap switch will ouput momentary light, and retain the modes set by side tact switch, while a triple click /triple press of the tailcap switch jumps to Strobe, further hard press of the tailcap switch loosen the chosen modes. Under on status, hard press turns off the light; 3.Side switch in head controls output brightness levels, three brightness levels “low-medium-high”changes by circle. Hold the button to activate strobe; 4.ntelligent driver circuit with memory function, automatically memorize the output modes chosen by the side switch, but not for the modes activated by tail switch; 5.Deep carry pocket clip, easy and reliable for use; 6.Thick stainless steel bezel is able to bear higher tensile impaction; 7.Highly efficiency constant current drive circuit, perfectly support CR123A, RCR123 or 18650 batteries; 8.Time based ATM (Active Thermal Management), the output on high will gradually step down to 60% within 3 minutes after 4.5 minutes if the flashlight is running at high brightness level; 9.Reverse polarity protection; 10.Low, Medium, and high three adjustable brightness levels and 10herz strobe; 11.Low voltage indication: the bottom side switch will shine in red, when the power is low; 12.Patented lock-out function; 13.Flexible conductive contacts on battery electrodes enhance the ablity of anti-vibration. Standard accessories: Lanyard*1, Battery Magazine*1,O-Ring*2,Silicon rubber boot*1, Optional accessories: Offset Weapon Mount,Traffic Wand,Filter,Remote Tactical Switch |
828
Моторезиновый
Регистрация: 14.11.2011 Последняя активность: Сегодня 13:06
Сказал(а) спасибо: 335
Ну хвостокнопку...Ну блин....Почему нельзя было сделать её поменьше,чтоб фонарь мог стоять на хвосте...
829
Регистрация: 27.05.2011 Последняя активность: Сегодня 14:23
Сказал(а) спасибо: 6703
потому что позиционируется как тактик, а не едц
830
Регистрация: 11.07.2011 Последняя активность: 18.10.2025 21:48
Сказал(а) спасибо: 119
Поблагодарили: 311 раз(а) в 108 сообщениях
Что-то новенькое...
UniqueFire UF-T18 3 x Cree XM-L U2 5-Mode 4000 Lumens LED Flashlight (2 x 18650) ![]()
Нажми кнопочку "Спасибо" если мой пост оказался полезен или просто понравился. Вам все равно, а мне приятно
asket32420 (01.05.2013)
831
Регистрация: 21.10.2011 Последняя активность: 17.11.2018 09:26
Сказал(а) спасибо: 80
чтоб убиться засветиться
Sunwayman Thrunite Fenix и прочие по выгодной цене |
833
http://intl-outdoor.com/com...
предзаказ на медные ноктигоны 16/20 мм форматов XM/XP не сегодня, но тоже довольно недавно http://d******/p/replacement... холодный XM-L2 T6 на медяхе
трол. [Исправлено: blindnick, 01.05.2013 в 19:47] |
| Поблагодарили: 2 раз(а) |
Alex TG (01.05.2013), asket32420 (01.05.2013)
834
835
Сказал(а) спасибо: 324
836
Регистрация: 24.03.2011 Последняя активность: 17.12.2025 10:30
Сказал(а) спасибо: 262
Поблагодарили: 214 раз(а) в 144 сообщениях
Забавный китайченок
С характеристиками, конечно, китайцы отжигают, но идея интересная. |
837
Регистрация: 30.12.2012 Последняя активность: 07.01.2019 06:41
Сказал(а) спасибо: 66
Поблагодарили: 205 раз(а) в 146 сообщениях
838
Регистрация: 11.02.2012 Последняя активность: 16.11.2025 03:48
Сказал(а) спасибо: 3561
839
Меня больше расцветка интересует, чем геометрия - надо набить новый тактический рюкзак плюшками.
Да и равнодушен я к фирменным и дорогим фонарям. |
