530276
577
48
61
Администратор
Сказал(а) спасибо: 4330
Nebo hands-free LED light
This convenient little gadget from Nebo hooks on your ear and looks similar to many Bluetooth headsets but is actually a LED flashlight that lets you keep your hands free and have a light wherever your head’s pointing. The LED light is adjustable, fits on either ear and has two modes; one is a bright white light and the other is green allowing you to illuminate something in the dark but not loose so much of your night vision. It runs off of a lithium battery and the LEDs are said to last over 100,000 hours without getting hot (over 11 years of continuous light). It retails for about $16 with shipping. |
62
Администратор
63
Администратор
![]() Eco Gadgets: Concept flashlight requires no batteries for operation. The market is flooded with gadgets that are being touted to serve you in times of emergency. Be it emergency flashlights or radios, all these products run on batteries, which might not be available in a real emergency. Industrial designer Jon Thai has shared with us his latest creation, an emergency flashlight that doesn’t require batteries to work. ![]() The flashlight requires no batteries, and charges by shaking the flashlight. Inside of the flashlight is a coil, a capacitor and a magnet. By shaking, the magnet passes through the coil, generating energy which is stored in the capacitor. By switching the light on, the flashlight uses the energy stored in the capacitor. The light can last about 30 minutes before needing another shake. The light is emitted from one magnified LED light. ![]() Furthermore, there are supplementary LEDs housed internally to light the glow rods of the flashlight. All in all, the flashlight requires no batteries and no replacement bulbs. Thus, because it is ideally a survival emergency light, you can store the light, until needed, and in an emergency one would never have to worry about battery life, because they could kinetically charge it. ![]() Whereas with other normal flashlights requiring batteries, the fault is that the batteries most likely drain, even in storage, and must be discarded. This is harmful to the environment. The kinetic flashlight aids in the movement to be environmentally friendly, while being logically useful in emergency situations. ![]() The light features an extendable bezel. By extending the head of the flashlight, the user exposes the lit rods. In essence, the light could then be used as a torch guide for situations where the user needs to be seen by a tow truck, airplane or any other rescue help, without blinding the rescuers with the bright white LEDs. ![]() ![]() ![]() Thanks: [Jon Thai] |
64
Администратор
66
у одного моего друга был лампочный фонарь, который выдвигался и становился настольной лампой, если раздобуду фотки - выложу
67
Администратор
68
луч со световым пятном ну как-то совсем уж палевно нарисованы =)
69
Администратор
70
Администратор
71
Администратор
72
www.vk.com/wolkozay
Хорошая тема. Много забавного и прикольного.
По скольку увидел тут не только сами фонарики, но и предметы интерьера, то осмелюсь добавить еще несколько любопытных экземпляров связанных со светом. И так: [Исправлено: wolkozay, 09.06.2011 в 22:50] |
75
www.vk.com/wolkozay
И еще немного дизайна.
Работа не моя! Фотки взяты с форума про мебель. Но при росте рук из правильного места и умении работать с электроинструментом, смолами и стеклом... А может просто при наличии средств и умельцев... Вообщем можно и вот так у себя дома или еще где. Назовём это ручеек на столе: столешница фрезеруется по шаблону, на дно канала (при вдумчевом подходе можно канал сделать сквозным и снизу к столешнице прикрепит крышку, которая станет дном канала и будес съёмной для замены света, сам свет разделить от смолы и стекла) укладывается световой шнур или светодиодная лента, битое стекло ( тут синее, но вариантов много) засыпается и заливается эпокситкой. Всё это дело полируется и подключается к источнику питания. Вуа-ля. [Исправлено: wolkozay, 09.06.2011 в 22:48] |
76
Администратор
77
прикольные, вот если бы ещё светили норм, то вобщею круто было
78
Администратор
79
да я знаю, только у меня в городе такого нет, а в Москву переться только за этим как-то несолено...
80
www.vk.com/wolkozay
Ищем местную контору делающую полиграфию, замеряем фонарь и заказываем наклейку на виниле с выбранной картинкой, наклеиваем на обезжиренную поверхность, вмятины и прочие неровности прогреваем техническим феном, прокатываем и прижимаем для усадки по месту (акромя мелких - они не проявятся и выпуклостей - их лучше обойдти или прорезать отдельно), наслаждаемся личным дизайном. Если есть вариант напечатать рисунок на термоусадочной плёнке, то вообще здыбвнско. Хлопот меньше, а результат лучше. Для примера такая технология используется для этикеток бутылочных и на пасхальных яйцах.
[Исправлено: wolkozay, 10.06.2011 в 17:15] |
