Просмотров в теме 302440   Ответов в теме 822   Подписчиков на тему 2   Добавили в закладки 0
Старый 16.03.2018, 04:43 Автор темы   61
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Hellvape VP RDA Rebuildable Dripping Atomizer with BF Pin Original Price $26.99,Now Only $18.69
The Original Hellvape VP RDA is a 24mm RDA with angled dual post design. Each post has one terminal for coil, which will be locked by side mounted screws. The airflow gets in via the side airflow slots, which are measured 8mm by 2.5mm. A wide bore drip tip is included.
This RDA comes with bottom feeder pin.
Kindbright AirLab RDA Rebuildable Dripping Atomizer Clone with BF Pin $11.99
The Kindbright AirLab RDA Clone is a 22mm low profile dripper constructed from 316 stainless steel. Its deck features dual post design, top mounted flathead screws, making it easy to build single coil. The chamber is more and more narrower when it goes to the top, which will gather vapor effectively. The airflow is adjustable with dual airslots on the side of cap. POM heat resistant drip tip is included.
Kindbright Squi RDA Clone Rebuildable Dripping Atomizer with BF Pin $12.99
The Kindbright Squi RDA Clone is a 22mm diameter dripper constructed from 316 stainless steel with POM top cap and PEI drip tip. The deck features dual post clamp style design for single coil building. The RDA comes with adjustable side airflow control.This item also has many color to choose.
Original Voopoo MOJO 88W 2600mAh TC VW Variable Wattage Box Mod + Uforce Tank Kit $43.69
The Original Voopoo MOJO Kit consists of Voopoo MOJO Mod and Uforce Tank.This item also has many color to choose.
Mod:
The Voopoo MOJO Mod is a portable regulated device with 2600mAh built-in battery. Equipped with Gene.Fan chip, which is the top chip with fastest firing speed in the world, allows to vary the wattage from 5 to 88W. MOJO Mod is a perfect one for those who are seeking a tiny device with powerful output.
Tank:
The Uforce tank is a 24mm atomizer with 3.5ml capacity. It features rich and smooth flavor and high analysis of the e-liquid. It has venting system and 3 channels for banlanced airflow. Integrated with 0.4ohm dual coils (40~80W), it will let you enjoy big cloud without mouth burned.
Original Voopoo TOO 180W TC VW Variable Wattage Box Mod + Uforce Tank Kit $66.99
The Original Voopoo TOO Kit consists of Voopoo TOO Mod and Uforce Tank.This item also has many color to choose.
Mod:
The Original Voopoo TOO box mod adopts upgraded Gene.Fan chip, which broke a record of the world's fastest firing speed and allows the firing speed reach 10 milliseconds (0.01S). Voopoo TOO can be powered by single battery or dual batteries (battery not included), and the power range with single battery is 5~80W, while the range with dual is 5~180W. The colorful side panels makes the mod looks more beautiful, and they are also replaceable.
This mod comes with Black frame.
Tank:
Pre-cut Wicking Cotton for RDA / RTA / RDTA $1.99
The pre-cut wicking cotton has been specially treated and purified to remove all impurities. It is good to wick the coils and will bring you great vaping experience.
This product comes with 10 PCS of pre-cut cotton.
Ulton Replacement Dual Airflow Accessory for FEV4 RTA Clone $5.79
The replacement dual airflow accessory is used for Ulton / Shenray FEV4 RTA Clone for direct-to-lung vaping.
Original Hellvape Butcher Challenge Cap for 24mm Dead Rabbit RDA Original Price $21.00,Now Only $13.99
The Original Hellvape Butcher Challenge Cap is constructed from stainless steel with 24mm diameter. It is compatible with 810 drip tip and fits all existing 24mm dead rabbit decks.This item also has many color to choose.
This cap comes with both SS drip tip and resin drip tip (random color).
Original Hellvape Priest Challenge Cap for 24mm Dead Rabbit RDA Original Price $21.00,Now Only $13.99
The Original Hellvape Priest Challenge Cap is constructed from stainless steel with 24mm diameter. It is compatible with 810 drip tip and fits all existing 24mm dead rabbit decks.This item also has many color to choose.
3FVAPE вне форума   Вверх
Старый 19.03.2018, 04:58 Автор темы   62
3FVAPE
RHIZOME Hybrid Mechanical Mod Clone $18.99
The RHIZOME Mechanical Mod Clone is a tiny unregulated tube mod that utilizes single 18350 battery (not included). Made out of 316 stainless steel, it comes with hybrid top cap and spring loaded fire button.
Chrome Hearts Mechanical Mod Clone $21.99
The Chrome Hearts Mechanical Mod Clone is made out of silver plated stainless steel. It is powered by single 18650 battery (not included). It comes with spring fire button.
Kryten RDA Rebuildable Dripping Atomizer Clone with BF Pin Original Price $9.99,Now Only $6.99
Kryten RDA Clone is constructed from 316 stainless steel and in 24mm diameter. The Kryten RDA Clone is in 24mm diameter, is the updated version of its predecessor the Hadaly RDA. The Kryten Style RDA is with unique dual post coil clamping system for dual coil build. The RDA is compatible with 810 drip tips.
Original Blitz Ghoul RDA Rebuildable Dripping Atomizer with BF Pin Original Price $26.90,Now Only $18.99
Please log in to see the lower price.
The Original Blitz Ghoul BF RDA adopts innovative design on the building post, which is an integrated post with ceramic clamp for single coil building. The tank comes with side airflow, which is adjustable. Gold plated positive pin provides great conductivity. Resin and acrylic drip tips are included.
The resin drip tip will be shipped in random color.
Alcatraz RDA Rebuildable Dripping Atomizer Clone with BF Pin $10.99
The Alcatraz RDA Clone is a 22mm RDA that is made out of 316 stainless steel. The dual post build deck, with one of the posts raised, while the other one is lower in position, allows you to place coil vertically. The airflow enters through the side airslots, giving you great flavor.
Original Demon Killer Wick Flame Coil Ni80 + Muscle Cotton Kit $6.39
The Original Demon Killer Wick Flame Coil Ni80 Kit is made from Ni80 wires and comes with 0.12 / 0.2 / 0.3 / 0.4ohm coils. This heating wire will be a good vaping choice for DIY.
This product comes with 8 PCS Coils and 10 PCS Muscle Cotton in 1 pack.
Original Wismec Replacement Bottom Feeder Bottle for Luxotic Squonk Box Mod $0.99
The replacement bottle is made from plastic, which is the original one in the Luxotic BF box mod. It can hold about 7.5ml of e-juice. It is suitable for Luxotic BF Box Mod (Kit).
Original Wismec Replacement Cover Panel + 810 Drip Tip Kit for Luxotic Squonk Box Mod $10.99
The newly added honeycomb 810 drip tip is compatible with the equipped 810 top cap, providing you with large vapor clouds. The colorful replaceable side cover offer you more options and possibilities. You can update the box mod whenever to your preference. The product is suitable for Luxotic BF Box Mod (Kit).
This product comes with 1 cover panel and 1 drip tip.
Старый 20.03.2018, 04:36 Автор темы   63
3FVAPE
Original Marvec Priest BF 90W Squonk Box Mod $31.99
The Original Marvec Priest BF 90 Mod is an unregulated squonk mod with charging function. It is compatible with single 18650, 20700 or 21700 battery (not included) and the full power output can reach 90W. The squeeze bottle is made out of silicone with 8ml capacity. It comes with multiple protection and supports 5V / 1.5A charging.This item also has many color to choose.
Original Marvec Priest RTA Rebuildable Tank Atomizer $24.59
The Original Marvec Priest RTA is constructed from stainless steel with 27mm diameter. The tank can hold 4.2ml of e-juice. The deck has dual clamp post for easy building. With the airflow entering the airholes and travelling up to the bottom of coils, it will bring you smooth and dense vapor.This item also has many color to choose.
The U.S.1 V2 RDA Rebuildable Dripping Atomizer Clone $8.99
The U.S.1 V2 RDA Clone is constructed from stainless steel and glass with 24mm diameter. The drip tip and top cap are integrated as one piece. The deck comes with dual post design and can handle fancy coils with large post holes. The side airflow hits the coils directly for massive clouds and dense flavor.This item also has many color to choose.
The U.S.1 V2 RDA Rebuildable Dripping Atomizer Clone with Extra PEI Top Cap $9.99
The U.S.1 V2 RDA Clone is constructed from stainless steel with 24mm diameter. The drip tip and top cap are integrated as one piece. The deck comes with dual post design and can handle fancy coils with large post holes. The side airflow hits the coils directly for massive clouds and dense flavor.This item also has many color to choose.
This RDA comes with extra stainless steel & PEI top cap.
YFTK GSL RTA Rebuildable Tank Atomizer Clone $23.99
The YFTK GSL RTA Clone is constructed from 316 stainless steel with 23mm diameter. The tank can hold 5ml of e-juice. The deck comes with dual post design for single coil build. The cotton slot is large for more cotton on the both sides. The airflow can be adjusted via the bottom AFC ring. It is a great tank for MTL vaping.
Original Marvec Priest AIO 90W Starter Kit $58.99
The Original Marvec Priest AIO 90W Starter Kit is an all-in-one style device with 90W full output. It is powered by single 18650 battery (not included). The pod has 5ml juice capacity. The supported lowest resistance is 0.1ohm. 90W full-power output with amazing coils, making super huge vapor. The kit comes with multiple protections and supports 2A fast charging.This item also has many color to choose.
The stabilized wood cover is random color.
Original Vandy Vape Squonk Bottle for Pulse BF 80W Box Mod $3.49
This replacement squonk bottle is made out of soft silicone with 8ml e-juice capacity. It is suitable for Original Vandy Vape Pulse BF 80W Mod.This item also has many color to choose.
Original Coil Father SS316 Pre-built Coil Heating Wire $3.99
The Original Coil Father Pre-built Coils Heating Wire is made from SS316 wires and features 22GA coils. This heating wire will be a good vaping choice for DIY.
This product comes with 50 PCS in 1 pack.
Original Coil Father Ni80 Pre-built Coil Heating Wire $5.99
The Original Coil Father Pre-built Coils Heating Wire is made from Ni80 wires and features 24GA coils. This heating wire will be a good vaping choice for DIY.
This product comes with 100 PCS in 1 pack.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank $1.99
The replacement 510 drip tip is made from stainless steel with 20mm height. It is suitable for all atomizers that fit 510 drip tip.
Replacement 510 Drip Tip + Top Cap Kit for Entheon RDA Clone $3.99
The replacement top cap is made from stainless steel and the 510 drip tip is made from POM. They are suitable for Entheon RDA Clone.This item also has many color to choose.
Старый 21.03.2018, 04:58 Автор темы   64
3FVAPE
Original Wismec Reuleaux RX GEN3 Dual 230W TC VW Variable Wattage Box Mod $40.99
Wismec introduces a new member of Reuleaux series, Reuleaux RX GEN3 Dual, which is more compact and portable than previous box mods. Powered by dual replaceable 18650 batteries (not included), the GEN3 Dual is able to output 230W and has 2A quick charge capability. The minimum resistance supported is from 0.05 to 1.5ohm (TC) and 0.1 to 3.5ohm (VW).
Original Hotcig G177 177W TC VW Variable Wattage Box Mod $38.99
The Original Hotcig G177 Box Mod is a versatile regulated mod with durable zinc alloy chassis. Equipped with HM chipset, the output wattage is able to be varied from 1 to 177W with dual 18650 batteries (not included). It also features 0.005S instant firing speed, RGB breathing light, spring loaded 510 connection and 2A USB charging.This item also has many color to choose.
Predator Mini Hybrid Mechanical Mod Clone $19.99
The Predator Mini Mechanical Mod Clone is made from brass and powered by 1 x 18350 battery (not included). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 6 vent holes on the top of the mod. It is a portable mech mod that cloud chasers chase for.This item also has many color to choose.
YFTK Karma RDA Rebuildable Dripping Atomizer Clone w/ BF Pin $17.99
The YFTK Karma RDA Clone is constructed from 316 stainless steel in 18mm diameter. The build deck has dual post for single coil build. The air accesses the chamber via bottom airhole and travels up to the bottom of the coil. The top cap is made of Delrin.
The RDA comes with bottom feeder pin and decorative ring.
Kindbright FL RTA Rebuildable Tank Atomizer Clone with BF Pin $14.99
The Kindbright FL RTA Clone is constructed from 316 stainless steel in 24mm diameter. It features dual post deck for single coil and middle side adjustable airflow. The deck has notches for easy installation of the coil. The tank is large and allows to take about 30 puffs per drip.
This RTA comes with bottom feeder pin.This item also has many color to choose.
Original Wismec Reuleaux RX GEN3 Dual 230W TC VW Box Mod + GNOME King Tank Kit $61.99
The Original Wismec Reuleaux RX GEN3 Dual Kit consists of Reuleaux RX GEN3 Dual Mod and GNOME King Tank.This item also has many color to choose.
Mod:
Tank:
The GNOME King is a 26mm tank with 5.8ml juice capacity. Featuring the unique crown molding shape and perfect color scheme, the gorgeous GNOME King atomizer that utilizes the updated WM01 coil for intense flavor can perfectly combine with RX GEN3 Dual in terms of appearance and performance.
Kratos Mechanical Mod Clone + Zeus RDA Clone Kit $21.99
The Kratos Mech Clone Kit consists of Kratos Mechanical Mod Clone and Zeus RDA Clone.This item also has many color to choose.
Mod:
The Kratos Mechanical Mod Clone is constructed from brass and POM. It is 25mm diameter. Powered by single 18650 battery (not included), this mod will bring you massive cloud and dense flavor.
RDA:
The Zeus RDA Clone is a 24mm RDA with velocity style dual post build deck, which is very easy to build coils. The RDA comes with adjustable side airflow and bottom airflow system, giving you great flavor and massive vapor. PEI drip tip is included.
Vortecon Kinetic Desk Toy Clone Spinner EDC Fidget Toy $8.99
The Vortecon Kinetic Desk Toy Clone is constructed from stainless steel. The spinner is a small spinning device designed to keep your hands busy and your mind focused. It is pocket sized and can be spun on the desk by using your hand to rapidly spin it from small continuous strikes. Great for people with Fidgety hands, ADHD, Anxiety & OCD sufferers. The bearing is R188 and made from stainless steel, with size of 12.7 x 6.35mm (diameter x height).This item also has many color to choose.
Старый 22.03.2018, 05:06 Автор темы   65
3FVAPE
Original Serisvape Golden Armor RDA Rebuildable Dripping Atomizer $20.99
The Serisvape Golden Armor RDA is a 26mm RDA featuring fully gold plated base, PEI drip tip and top cap, and innovative angled airflow system. The dual post clamp system makes building easier as the clamp piece will automatically adjust when you loosen or tighten the screw. The angled airflow system allows more airflow to hit the coil for better flavor and massive cloud.
Original GeekVape Loop RDA Rebuildable Dripping Atomizer with BF Pin Original Price $29.90,Now Only $20.99
The Original GeekVape Loop RDA is the first leak-proof RDA with surround bottom airflow system. The innovative W style postless build deck is raised and provide more space for the juice well. Whats more, it will not cause juice leaking when refilling because of the deck and beveled airslots. The air accesses the internal via side airslots and hit the bottom of coils. The structure of the deck can surround the coils well and enhance the flavor.
Entheon RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.59
The Entheon RDA Rebuildable Dripping Atomizer is constructed from stainless steel in 22mm diameter. The Innovative dual post style deck and coil clamping system makes coil building effortless. The airflow is adjustable by the two airslots on the side of cap.
The black piece can be placed into the hole at the base
Kratos Mechanical Mod Clone + Zeus RDA Clone Kit $22.99
The Kratos Mech Kit Clone consists of Kratos Mechanical Mod Clone and Zeus RDA Clone.
Mod:
RDA:
Original Serisvape Closers Squonk Mechanical Box Mod + RDA Kit $31.89
The Original Serisvape Closers Squonk Kit consists of Serisvape Closers Box Mod and Closers RDA.
Mod:
The Serisvape Closers Squonk Box Mod is made from aluminum with stainless steel 510 connector. The mod is powered by single 18650 / 20700 battery (not included). The squeeze bottle can hold 7ml of e-juice. The fire button can be locked to avoid mis-fire.
RDA:
The Serisvape Closers RDA is a 26mm RDA with innovative angled airflow system, allowing more airflow to hit the coil for better flavor and massive cloud. The Delrin drip tip can protect your mouth from heat.
Original Marvec Replacement Coil Head for Priest AIO 90W Starter Kit $2.99
The replacement coil head features 0.2ohm resistance and is suitable for authentic Marvec Priest AIO 90W Starter Kit.
One piece will be shipped.
Original Marvec Replacement Coil Head for Priest AIO 90W Starter Kit(5 PCS) $10.99
This product comes with 5 CPS in 1 pack.
Original Vapjoy Tortuosity Coil Ni80 Heating Wire $7.99
The Original Vapjoy Tortuosity Coil is made from Ni80 wires and features 0.22ohm resistance, 3mm I.D (inner diameter), 6 wraps, 23GA. It is a good choice for DIY coil building.
This product comes with 10 PCS in 1 pack.
Original Serisvape Miracle Mechanical Mod Protector $14.99
The Original Serisvape Miracle Mechanical Mod Protector is designed for unregulated box / tube mod without protection function. It features battery reverse protection, low voltage warning, short circuit protection, time-out function, LED battery life indictor. This protector is 24mm in diameter.
Working voltage at 3.25~4.2V; Supporting resistance at 0.2~3ohm.
Original Wick 'N' Vape Cotton Bacon Prime for E-Cigarettes $4.99
The Original Wick 'N' Vape Cotton Bacon Prime features 33% faster absorption and easier separation. It has the world's most cutting edge, cleanest and easy to use cotton wick. It is designed with large fibers for low ohm builds and will leave you with minimal dry hits. This cotton provides more capacity and clean pure flavor!
Старый 23.03.2018, 08:45 Автор темы   66
3FVAPE
Original U-Yo Stacked Hybrid Mechanical Mod $32.99
The Original U-Yo Mechanical Mod is a stackable mod that is compatible with signle 18350 or 18650 battery (not included). The mod comes with hybrid connection for direct output. The fire button is activated by magnets. This item also has many color to choose.
Original U-Yo Stacked Hybrid Mechanical Mod with Extension Tube $50.99
The Original U-Yo Mechanical Mod is a stackable mod that is compatible with signle 18350 or 18650 battery (not included). The mod comes with hybrid connection for direct output. The fire button is activated by magnets. Extension tubes is included (detachable), with which you can put 2 or 3 18650 batteries in series. This item also has many color to choose.
Original Vapor Storm Subverter 200W TC VW Variable Wattage Box Mod $36.59
The Original Vapor Storm Subverter Box Mod, powered by dual 18650 batteries (not included), can reach maximum wattage to 200W. The side panels has many geometrical cut-outs and becomes aesthetic pattern. The mod comes with a 0.96 inch colorful display and big fire button. The resistance allowed is from 0.05 to 3ohm (VW), 0.05 to 1ohm (TC). This item also has many color to choose.
Shenray PantheonS Hybrid Mechanical Mod Clone $24.99
The Shenray PantheonS Mechanical Mod Clone is a 24mm tube mod with hybrid connection. The tube has many cut-outs and forms regular pattern. It is powered by single 18650 or 20700 battery (not included). The 18650 battery adapter is frosted. The fire button is activated by spring. This item also has many color to choose.
The Shenray PantheonS Mechanical Mod is a 24mm tube mod with hybrid connection. The tube has many cut-outs and forms regular pattern. It is powered by single 18650 or 20700 battery (not included). The 18650 battery adapter is frosted. The fire button is activated by spring. This item also has many color to choose.
Original NCR 256W TC VW Variable Wattage Box Mod Original Price $47.99,Now Only $38.99
The Original NCR Mod is a sleek and ergonomically designed mod, which can reach 256W with triple 18650 batteries (not included). The NCR 256W Mod comes with multiple output modes, including NCR mode, VW, Ni-200, Ti-01, SS-316, Bypass and PTC (curve) mode. This versatile mod will definitely give you fantastic experience.
Saint Seiya RDA Rebuildable Dripping Atomizer Clone $13.99
The Saint Seiyas RDA is a 24mm RDA made out of stainless steel Clone. The build deck features dual post design, 4 slots to place cotton, and 5mm deep juice well. The airflow enters from the bottom airslots and travels up to the bottom of coils. The cap has 2 deep-carved lines on it. PEI drip tip is included. This item also has many color to choose.
Original Vandy Vape Lit RDA Rebuildable Dripping Atomizer with BF Pin Original Price $33.99,Now Only $24.99
The Original Vandy Vape Lit RDA is a 24mm RDA with multifunctional base and Rhombus airflow control. The clamp post allows you to build coils in 3 different ways: Horizontal, Mesh, and Vertical. The Rhombus airflow control provides you with 2 different airflow configurations: linear airflow or dot airflow. Besides, there are 3 drip tips included for Lit RDA: resin, Delrin, and Ultem. Not to mention the squonk function, it is also available. The VandyVape Lit RDA is going to be lit this time!This item also has many color to choose.
YFTK Replacement Top Cap for Karma RDA Clone $5.99
The replacement top cap is made out of PC and is suitable for YFTK Karma RDA.
Старый 24.03.2018, 04:59 Автор темы   67
3FVAPE
Original Voopoo Drag 157W TC VW Variable Wattage Box Mod Original Price $53.99,Now only $40.99
The Original Voopoo Drag 157W TC VW Variable Wattage Box Mod is made from zinc alloy and powered by 2 x 18650 batteries (not included). It features Super Mode, which will be activated automatically under 130W wattage. Also it features fastest fire speed, 0.025s only.
Phantom X V2 Hybrid Mechanical Mod Clone $24.99
The Phantom X V2 Mechanical Mod Clone is constructed from copper with hybrid connection. It is powered by single 18650 battery (not included). The fire button is activated by spring.
Original Dovpo LQT RDA Rebuildable Dripping Atomizer with BF Pin $22.99
The Original Dovpo LQT RDA is a 24mm RDA with gold plated dual post. Using flathead grub screws, it is easy to get coils built and fixed. The Ultem drip tip can prevent juice spitting and condensation. With the direct side airflow, the flavor in this RDA is dense and solid.
This RDA comes with bottom feeder pin. This item also has many colors to choose
Hadaly RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
The Hadaly RDA Clone is an innovative RDA for you flavor chasers out there. It is constructed from PMMA (cap) and 316 stainless steel (base) in 22mm diameter. This RDA is amazing but if you looking for massive clouds this one is not for you. It is best suited for single coil builds.
This RDA comes with bottom feeder pin. This item also has many colors to choose.
Original Serisvape Cavalry Hybrid Mechanical Mod + RDA Kit $31.89
The Original Serisvape Cavalry Mech Mod Kit consists of Cavalry Mechanical Mod and Cavalry RDA.
Mod:
The Serisvape Cavalry Mechanical Mod is constructed from brass with hybrid connection. It is powered by single 18650 battery (not included). It comes with two options to activate you fire button, magnet and spring.
RDA:
The Serisvape Cavalry RDA is constructed from brass (cap) and stainless steel (base) in 25mm diameter. The build deck comes with dual post and the T shape post has 4 terminals, which allow you to get coils fixed separately. The side airflow hit the coil directly with two sizes of airholes. Ultem drip tip and Delrin doc tip are included.
Original NCR Replacement Wafer Heater for NCR RDA Original Price $17.99,Now only $11.99
The Wafer Heater is designed for NCR RDA / NCR 256W Mod Kit. It supports 600,000 times cycle-uses with self-cleaning function. It is very easy to install and use.
Original Wismec Replacement 810 Drip Tip for Tobhino BF RDA $2.99
The Original Wismec replacement 810 drip tip is made from resin with 11.5mm height. It is suitable for Tobhino BF RDA / Luxotic Kit.
It is also suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA. This item also has many colors to choose
Старый 26.03.2018, 04:57 Автор темы   68
3FVAPE
SXK NarDA RDA Clone Rebuildable Dripping Atomizer with BF Pin Original Price $15.00 ,Now only $12.99
Please Note: This product will be shipped around March 31, 2018 (ETA, not guaranteed). The final shipping date depends on the manufacturer. We will try to get it delivered as soon as we can.
The product images and information are provided by the manufacturer, for reference only. The final refers to the manufacturer's actual product.
The SXK NarDA style RDA is a rebuildable dripping atomizer with 22mm diameter. It is made out of 316 stainless steel. Coming with dual-post design, it is easy to build. SXK NarDA style RDA is a nice single coil RDA that will provide intense flavor and massive cloud. 510 POM drip tip is included.
The replacement 510 drip tip is made from resin with 15mm height. It is suitable for all atomizers that fit 510 drip tip.
One piece will be shipped (random color). More options than what's on the image.
810 Replacement Drip Tip for 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 12.5mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
810 Replacement Drip Tip for TFV8 / TFV12 Tank / 528 Goon / Kennedy / Reload RDA $1.99
The 810 drip tip is made from resin with 15mm height. It is suitable for TFV8 Tank, TFV8 Big Baby Tank, TFV12 Tank, TFV12 Prince Tank, Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
One piece will be shipped (random color). More options than what's on the image. This item also other specification.
YFTK Replacement Top Cap for Short Cranked RDA Clone $5.99
The replacement top cap is made out of PEEK and is suitable for YFTK Short Cranked RDA Clone. This item also has other colors and material.
YFTK Short Cranked RDA Clone Rebuildable Dripping Atomizer with BF Pin $18.99
The YFTK Short Cranked RDA Clone is a 22mm RDA made from 316 stainless steel. The build deck is wide and has two terminals to build single coil. The airflow enters from the side air holes and hit the coil directly. The cap comes with triple-groove design.
Please note: there is no drip tip included, the RDA is compatible with 510 drip tip.
Старый 28.03.2018, 05:43 Автор темы   69
3FVAPE
Original Vapor Storm Raptor 120W Squonk Mechanical Box Mod $21.99
The original Vapor Storm Raptor Squonk Box Mod is an unregulated mod with chip protection and LED indicators. Powered by single 18650, 20700 or 21700 battery (not included), the mod can reach max output at 120W. It supports 0.05ohm super low resistance. The squeeze bottle has 5ml capacity. This item also has other colors to choose.
Kurba Hybrid Mechanical Box Mod Clone $11.99
The Kurba Mechanical Box Mod Clone has Delrin chassis and copper 510 connector. It is powered by single 18650 battery (not included). The body is ergonomically designed, which will give you comfortable hand feel. This item has other colors, other suppliers can choose.
Original Vapor Storm Raptor 120W Squonk Mechanical Box Mod + RDA Kit $34.99
The original Vapor Storm Raptor Squonk Kit consists of Vapor Storm Raptor Box Mod and Raptor RDA.This RDA Kit also has other colors to choose.
Mod:
RDA:
The Vapor Storm Raptor RDA is constructed from PEI (drip tip, cap) and stainless steel (base). Together with Raptor Box Mod, it will bring you fantastic vaping experience.
[Исправлено: 3FVAPE, 28.03.2018 в 05:45]
Старый 28.03.2018, 05:45 Автор темы   70
3FVAPE
Original Marvec Magic Wand 90W Tube Mod $23.99
The Marvec Magic Wand Tube Mod is an unregulated mod with built-in chip, which allows it to fire at 90W full power with single 18650 battery (not included). It can be used safely with multiple protections, including short circuit protection, anti-reverse connection, over temperature protection, battery overcharge protection, discharge protection and smoking prevention timeout. This mod also has other color and Materials to choose. And it can Compatible with different types of batteries.
Predator Mini Hybrid Mechanical Mod Clone $17.99
The Predator Mini Mechanical Mod Clone is made from brass and powered by single 18350 battery (not included). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 6 vent holes on the top of the mod. It is a portable mech mod that cloud chasers chase for. This mod also has other color and Materials to choose.
Kindbright Warhead RDA Rebuildable Dripping Atomizer Clone with BF Pin $18.99
The Kindbright Warhead RDA Clone has a beast size of 30mm and is constructed from 316 stainless steel. The build deck comes with triple post design for dual coil building. The top cap has a wide airslot and five airholes on both sides for multiple airflow configuration. The beveled Delrin drip tip can prevent the juice spitting out.
This RDA comes with bottom feeder pin. and it also has other color and Materials to choose.
Original Marvec Magic Wand 90W Tube Mod + Sub Ohm Tank Kit $44.99
The original Marvec Magic Wand Starter Kit consists of Marvec Magic Wand Mod and Marvec Magic Wand Tank. This kit also has other color and Materials to choose. And it can Compatible with different types of batteries.
Mod:
The Marvec Magic Wand Tube Mod is an unregulated mod with built-in chip, which allows it to fire at 90W full power with single 18650 battery (not included). It can be used safely with multiple protections.
Tank:
The Marvec Magic Wand Tank is a 25mm tank which adopts 0.2ohm and 0.4ohm coil heads, performing well at 90W output. Coming with bottom airflow system, it will bring you massive cloud and great flavor.
This kit will be shipped with random color. More color than what's on the image.
Старый 29.03.2018, 05:57 Автор темы   71
3FVAPE
Entheon RDA Rebuildable Dripping Atomizer Clone with BF Pin + Hadeon Cap + Spare Drip Tip $11.99
The Entheon RDA Rebuildable Dripping Atomizer Clone is constructed from stainless steel in 22mm diameter. The Innovative dual post style deck and coil clamping system makes coil building effortless. The airflow is adjustable by the airslots on the side of cap.
This RDA comes with bottom feeder pin. Hadeon Cap and 3 Spare Drip Tips are included in this kit. This item also has other Hadeon Cap colors to choose.
Original Vapefly Wormhole RDA Rebuildable Dripping Atomizer with BF Pin $35.99
The orginal Vapefly Wormhole RDA is a 24mm RDA which features amazing airflow for cloud chaser. The air enters side and bottom air slots, surrounding the coil to produce outstanding flavor and huge cloud. Besides, the side and bottom airflow can be controlled separately by adjusting the cap. And there are 2 kinds of airflow adjusting clamps, which allows you to use single coil or dual coils. The juice well is very deep and is very friendly to squonking. Compatible with 510 and 810 drip tip.
This RDA comes with bottom feeder pin. And it also has other colors to choose.
SXK BB 70W All-in-One Box Mod Kit Clone $85.00
The SXK BB Box Mod Kit Clone is constructed from aluminum with an all-in-one design. This mod comes with Comes with Kanger Subtank RBA Coil, Kanger OCC coil adaptor, Nautilus coil adaptor.
Original Coil Father Kanthal A1 Pre-built Coil Heating Wire $3.99
The Original Coil Father Pre-built Coils Heating Wire is made from Kanthal A1 wires and features 0.6ohm, 24GA. This heating wire will be a good vaping choice for DIY.
This product comes with 50 PCS in 1 pack. And it also suitable for other types of Resistance and Gauge.
Original Coil Father Ni80 Pre-built Coil Heating Wire $3.99
The Original Coil Father Pre-built Coils Heating Wire is made from Ni80 wires and features 0.36ohm, 22GA. This heating wire will be a good vaping choice for DIY.
The Original Coil Father Pre-built Coils Heating Wire is made from SS316 wires and features 0.29ohm, 24GA. This heating wire will be a good vaping choice for DIY.
Original Demon Killer Muscle Cotton II for RDA / RTA / RDTA $3.59
The Original Demon Killer Muscle Cotton II is medical level degreasing cotton, coming with longer fiber and better absorbability. It is a good choice to wick on your favorite RDA, RTA, RDTA.
Старый 30.03.2018, 05:15 Автор темы   72
3FVAPE
Original ThinkVape Finder DNA250C TC VW Variable Wattage Box Mod $117.99
The original ThinkVape Finder DNA250C Box Mod adopts the most up-to-date DNA250C chip from Evolv, providing stable and high performance for your vaping. It is powered by triple 18650 batteries (not included). The chassis of Finder DNA250C is made out of high quality zinc alloy and comes with leather battery cover. With ergonomic design, you can grab it in hand comfortably. This item also has other colors to choose.
Predator Mini Hybrid Mechanical Mod Clone $18.99
The Predator Mini Mechanical Mod Clone is made from brass and powered by single 18350 battery (not included). The fixed 510 hybrid top is machined into the mod for enhanced conductivity. There are 6 vent holes on the top of the mod. It is a portable mech mod that cloud chasers chase for. This item also has other colors to choose.
Complyfe Takeover Hybrid Mechanical Mod Clone $19.99
The Complyfe Takeover Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This item also has other materials and colors to choose.
510 Replacement Drip Tip for RDA / RTA / Sub Ohm Tank Atomizer $1.99
The replacement 510 drip tip is made from POM with 8mm height. It is suitable for all atomizers that fit 510 drip tip. This item also has other materials and colors to choose.
510 Replacement Drip Tip + 22mm Decorative Ring Kit for RDA / RTA / Sub Ohm Tank Atomizer $3.99
The replacement 510 drip tip and decorative ring are made from POM. The drip tip is suitable for all atomizers that fit 510 drip tip. The decorative ring comes with 22mm inner diameter. This item also has other materials and colors to choose.
The decorative ring is suitable for 22mm atomizers.
1 drip tip and 1 decorative ring will be shipped.
Replacement Top Cap for Complyfe Battle RDA Clone $4.99
The replacement top cap is made from stainless steel. It is suitable for Complyfe Battle RDA Clone. This item also has other materials and colors to choose.
Старый 02.04.2018, 05:35 Автор темы   73
3FVAPE
The Complyfe Takeover Mechanical Mod Clone is made out of brass with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This item also has other colors to choose.
Original IJOY Diamond PD270 234W TC VW Variable Wattage Box Mod $48.99
The IJOY Diamond is a dual 20700 battery mod with diamond design, which makes it look angular and stylish. Powered by dual 20700 or 18650 batteries with adapter (batteries not included), the mod is capable of delivering power up to 234W. It can support atomizer resistance from 0.05 to 3.0ohm. This item also has other colors to choose.
Original IJOY Diamond PD270 234W TC VW Variable Wattage Box Mod with 20700 Batteries $59.99
The IJOY Diamond is a dual 20700 battery mod with diamond design, which makes it look angular and stylish. Powered by dual 20700 or 18650 batteries with adapter (20700 batteries included), the mod is capable of delivering power up to 234W. It can support atomizer resistance from 0.05 to 3.0ohm.
Kindbright Chanupa Stacked Hybrid Mechanical Mod Clone $35.99
The Kindbright Chanupa Mechanical Mod Clone is constructed from brass. The tube mod has many carved patterns on it. It is able to be stacked with extra extension tube, which allows it to use dual 18650 batteries; When it is not stacked, single 18650 battery can make this mod work (batteries not included). The fire button is activated by spring. This item also has other colors to choose.
Original Vapefly 510 Replacement Drip Tip for Galaxies MTL RDA $2.99
The original Vapefly replacement 510 drip tip is made from POM with 16mm height. It is suitable for Vapefly Galaxies MTL RDA, and can be compatible with all atomizers that fit 510 drip tip. This item also has other colors to choose.
Старый 03.04.2018, 05:43 Автор темы   74
3FVAPE
Original Paradigm Modz Octarine V2 RDA Rebuildable Dripping Atomizer $14.99
The original Paradigm Modz Octarine V2 RDA is a 22mm RDA that features dual post build deck and multiple airflow system. The cap has dual side airslots and signle bottom airslot on each side. The internal of the cap is domed for concentrated flavor. The 510 PEI drip tip can prevent juice spitting back. This item also has other colors to choose.
Original 528 Custom Titanium Goon RDA Rebuildable Dripping Atomizer $69.99
The original 528 Custom Titanium Goon 1.5 RDA Clone is made out of 100% Titanium. The bridges and clamps are silver plated. Blue anodized screws, bridges, clamps are included. It is a great RDA for cloud chasing.
Original Ovns Saber 400mAh All-in-one Starter Kit $14.99
The Ovns Saber Starter Kit is a tiny kit that is suitable for beginner and features ultra-portable system, which is extremely portable to carry. Coming with a cartridge pod with 1.8ml juice capacity and built-in 400mAh battery, you can carry it anywhere you go. With the auto-vaping design, you can just take a puff without pressing any button or adjusting any setting. This item also has other colors to choose.
Original Ovns SEGO 650mAh All-in-one Starter Kit $9.79
The original Ovns SEGO Starter Kit is one of the best AIO device for vape beginners. With portable pen-style design, you can carry it anywhere. It features built-in 650mAh rechargeable battery and 1.5ml e-liquid juice capacity. The tank with LED indicator is very cool, which can show the real time status while vaping. Besides, Ovns SEGO Starter Kit has multiple protections to guarantee safe using. This item also has other colors to choose.
Original VapeOnly Malle AIO 180mAh All-in-one Starter Kit $14.99
The original VapeOnly Malle Starter Kit is a newly designed pen-style MTL device with simple design and delicate appearance. With a 180mAh built-in battery and a 0.7ml pod atomizer, Malle AIO Kit will bring you convenient and comfortable vaping. This item also has other colors to choose.
Original VapeOnly vPen 390mAh All-in-one Starter Kit $20.99
The original VapeOnly vPen Kit is a portable device that supports both e-juice and nicotine capsule for double enjoyment. And the pen cap can prevent dust when carrying. The 390mAh vPen battery is an automatic battery with a LED and a USB port on bottom. You can start vaping by a single drag. This item also has other colors to choose.
Original VapeOnly Malle S Lite 180mAh Starter Kit $30.99
The original VapeOnly Malle S Lite is a super portable device with convenient operation and good handle. It comes with 2 e-cigarettes with 180mAh battery each set to provide you all day need. Moreover, it is automatic and do not need to press any button when vaping. Together with the convenient charging box and easy bottom refilling atomizer, it is absolutely a good choice for daily use. This item also has other colors to choose.
Original VapeOnly New Malle PCC 2250mAh Starter Kit with 180mAh E-cigs $42.99
The original VapeOnly New Malle PCC Kit consists of a 2250mAh PCC and 180mAh battery with each set to provide you with all the vaping you need all day long. It is also automatic so you do not need to press any button when vaping. Together with the convenient charging box and easy bottom refilling atomizer. This item also has other colors to choose.
Original VapeOnly vPipe 3 e-Pipe Starter Kit with 18350 Battery $89.99
The original VapeOnly vPipe 3 is a high end e-cig pipe device made from rosewood that combines traditional pipe functions with new revolutions. The vPipe body has a LED light indicator and blinks from up to down when using. And the included BVC atomizer has a 1.2ml tank capacity and 0.7ohm resistance, which can be filled easily with all detachable structure. Luxurious design and superior technologies make vPipe III a piece of art work.
2 x 18350 batteries included.
Original Smoant S8 370mAh Pod Starter Kit $19.99
The original Smoant S8 Pod Starter Kit is designed for vape beginner. The Smoant S8 features streamline appearance for better grip. Powered by built-in 370mAh battery, the S8 will satisfy your needs for simple puffs. The cartridge has 2ml of juice capacity and is refillable. The air-activated switch makes the S8 pretty easy to vape.
Original Joyetech Exceed Edge 650mAh Starter Kit $20.79
Being a pod system while you can still change the coil heads as you like, the Joyetech EXCEED Edge is ergonomically designed, inspired by the sports car. It is meant to offer you a delectable and pure flavor using with the fine EX 1.2ohm head for mouth-to-lung enthusiasts. Meanwhile, it is compatible with high nicotine and nicotine salts. The EXCEED Edge is such a tiny and sleek device that fits you perfectly not just for starters but also advanced vapers. This item also has other colors to choose.
Original Vaporesso Cascade One Plus 3000mAh Mod + Cascade Baby Tank Kit $37.99
The original Vaporesso Cascade One Plus Kit consists of Cascade One Plus Mod and Cascade Baby Tank.
Vaporesso Cascade One Plus Kit Powered by built-in 3000mAh battery, provides a long-lasting vaping time to you. The Cascade Baby features top refill and unique safety lock mechanism for easy filling and anti-leakage. It has an innovative isolation structural design that separates coil and juice chamber, allowing consistent, intense flavor at every puff also reducing lower leakage and dry hit potential. The tank adopts innovative GT Mech coils too. This item also has other colors to choose.
Original Vaporesso Cascade One Plus 3000mAh Mod + Cascade Baby SE Tank Kit $40.99
The original Vaporesso Cascade One Plus SE Kit consists of Cascade One Plus Mod and Cascade Baby SE Tank.
Vaporesso Cascade One Plus SE Kit Powered by built-in 3000mAh battery, provides a long-lasting vaping time to you. The Cascade Baby SE features top refill and unique safety lock mechanism for easy filling and anti-leakage. It has an innovative isolation structural design that separates coil and juice chamber, allowing consistent, intense flavor at every puff also reducing lower leakage and dry hit potential. The tank adopts innovative GT Mech coils too. This item also has other colors to choose.
Original Ovns Replacement Pod Cartridge for Saber Starter Kit $7.99
The replacement pod cartridge features 1.8ml juice capacity and 1.8ohm resistance. It is suitable for authentic Ovns Saber Starter Kit.
This product comes with 5 PCS in 1 pack.
Старый 04.04.2018, 05:28 Автор темы   75
3FVAPE
Original Wismec Luxotic NC 250W Box Mod $46.99
As a new product designed by Jaybo, it is powered by dual 20700 or 18650 batteries with 250W maximum output. With the Resin and Brushed Stainless Steel body, this mod has stunning appearance. Besides, NC mod has a particular switch button for different vaping experience. This item also has other colors to choose.
Original Lost Vape Paranormal DNA250C 200W TC VW Box Mod $149.00
The original Lost Vape Paranormal DNA250C Box Mod adopts the most advanced chip from Evolv, the DNA250C chip. Paranormal DNA250C Mod features Replay mode, which allows vapers to select their own perfect vape and save to replay it over and over. Powered by dual 18650 batteries (not included), the Paranormal can be varied from 1 to 200W. The On-the-Go function of DNA250C allows Paranormal DNA250C to act like a power bank.
This one is silver frame version. For the color combination, please refer to the last image. This item also has other Color pattern to match.
YFTK M-Atty RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.69
The YFTK M-Atty RDA Clone is constructed from 316 stainless steel. This RDA supports dual and single airflow. And the deck of this RDA is designed around common vertical & horizontal builds.
YFTK Paravozz RDTA Rebuildable Dripping Tank Atomizer Clone $23.99
The YFTK Paravozz RDTA Clone is constructed from 316 stainless steel. It features dual post build deck for single coil build and with large capacity. The tank tube and drip tip are made out of PEI.
YFTK Daytona RDA Rebuildable Dripping Atomizer Clone with BF Pin $14.99
The YFTK Daytona RDA Clone is constructed from 316 stainless steel in 22mm diameter. The build deck features dual post design for single or dual coil builds. The RDA comes with side airflow system. PEEK airflow blocker is included for single coil build. POM wide bore drip tip is included.
Original Kanger Uboat 550mAh Starter Kit $16.89
The original Kanger Uboat Starter Kit is a tiny vape device that consists of Kanger Uboat 550mAh battery and Kanger Uboat cartridge. The cartridge features 2ml juice capacity and 1.5ohm resistance. It is very portable for you to carry it everywhere.
Original OVNS Vape-X 500mAh Pod Starter Kit $21.99
The original OVNS Vape-X Pod Starter Kit comes with the built-in 500mAh battery and 1.5ml capacity pods. The intelligent LED indicator that indicate the battery remaining power and different battery voltage. Power will be saved with the help of sleep mode. Besides, there is the bypass mode to guarantee the safe vaping. This item also has other colors to choose.
Original Eleaf iCard 650mAh 15W Starter Kit $19.79
The original Eleaf iCard Starter Kit is powered by built-in 650mAh battery. As a newest start kit which is very simple to use, you just need to fill in the juice and click the fire key, then you can enjoy taking puffs. The iCard kit contains a 2ml cartridge and all-new ID 1.2ohm coil head. The protective mouth cover on the top prevents dust getting inside. Its portable size and easy operation is very friendly to beginner. This item also has other colors to choose.
Original Wismec Luxotic NC 250W Box Mod + Guillotine V2 RDA Kit $65.99
The original Wismec Luxotic NC Dual 20700 Kit consits of Wismec Luxotic NC Box Mod and Guillotine V2 RDA. This item also has other colors to choose.
Mod:
RDA:
The Guillotine V2 RDA is a 24mm RDA adopts dual post deck and has large space for easy coils building. It comes with resin 810 drip tips for large vapors and BF Pin to make it compatible with squonk mod.
YFTK Replacement Top Cap for Daytona RDA Clone $5.99
The replacement top cap is made out of PEI and is suitable for YFTK Daytona RDA Clone.
Original Kanger Uboat USB Charger for Uboat Starter Kit $3.99
The original Kanger Uboat USB Charger is used to charge the Kanger Uboat Starter Kit. By charging Uboat for 30 minutes, you can vape it for a whole day.
Original Kanger Uboat Pod Cartridge for Uboat Starter Kit $7.99
The original Kanger Uboat Pod Cartridge is used for the Kanger Uboat Starter Kit. It features 2ml juice capacity and 1.5ohm resistance.
This product comes with 3 PCS in 1 pack.
Старый 08.04.2018, 05:55 Автор темы   76
3FVAPE
Original Hugo Vapor Rader Mage 218W TC VW Variable Wattage Box Mod $49.99
The Original Hugo Vapor Rader Mage Box Mod adopts new chipset and with dual 18650 batteries (not included), it can reach 218W maximum output. The lightest and hardest design makes the mod a durable and functional mod for great vaping experience. This item also has other colors to choose.
Ulton 502 RDA Rebuildable Dripping Atomizer Clone with BF Pin $9.59
The Ulton 502 RDA Clone is a 25mm RDA with unique post and clamp design which allows you to DIY various coil builds in vertical or horizontal way. It is compatible with 810 wide bore drip tip (POM drip tip incldued).
Original CoilART DPRO 133 Premium Kit with DPRO RDA Original Price $69.99, Now Only $39.99
The CoilART DPRO 133 Premium Kit consists of CoilART DPRO 133 mod and DPRO RDA. This item also has other colors to choose.
Mod:
The CoilART DPRO 133 mod can be regarded as a mech mod with regular protection. Powered by dual 18650 batteries in parallel, the output is straight and powerful without any delay. This mod can also be powered by only one battery (battery not included). With short-circuit protection and reverse polarity protection, it is much safer to use it. With the aluminum anodized body, it feels comfortable in hands and it is also very lightweight.
RDA:
The Stylish DPRO RDA from CoilART is a 24mm diameter RDA with creative postless deck. The length extended airflow system creates awesome flavor. The build deck features 24K gold plated postless deck with 3mm juice well. It is easy for both single coil and dual coil. The Goon style ultem drip tip has inner groove, which can prevent e-juice coming from the bottom to mouth.
Please note: this kit is Chinese version, but only the package and user manual are in Chinese.
Original Eleaf iJust 3 80W 3000mAh Mod + ELLO Duro Tank Kit $40.99
The Original Eleaf iJust 3 Kit consists of Eleaf iJust 3 Mod and ELLO Duro Tank. This item also has other colors to choose.
Mod:
The Eleaf iJust 3, a new upgraded version of iJust series, has the most gorgeous looking than ever. Powered by an internal 3000mAh battery, the iJust 3 is capable of firing up to 80 watts. Its intuitive four-color LEDs are for ease of checking battery level. In addition, there are six beautiful colors with three different patterns available for your choice.
Tank:
ELLO Duro, a new member of Eleaf ELLO family, features all-new reimagined Net and Multihole coil technologies which present unprecedented vaping experience with ultra flavorful taste and huge clouds and have a longer lifespan. To fill the tank, you just need to slide the drip tip back to reveal the fill port. The tank has 6.5ml of juice capacity.
Original iBuddy i1 1800mAh Heating Kit $52.99
The Original iBuddy i1 is the first innovative device of pin-style heating element. It has built-in 1800mAh battery. It can work together with iBuddystick (not included). With longer lifespan, integrated design and easy operation, iBuddy i1 is a nice device to vape. This item also has other colors to choose.
Original GeekVape Ceramic Tweezer for E-Cigarette $1.99
The Geekvape Ceramic Tweezer is Multi-functional E-cig DIY tool with advanced stainless steel body and ceramic tip. The Ceramic Tweezer can be used with coil building, diamonds selecting, circuit checking, eyelash cleaning and so on. Good tool for DIY lovers.
Original GeekVape Diagonal Pliers for E-Cigarette $2.99
The Geekvape Diagonal Pliers for E-cig DIY is a better DIY tool to cut coils. Allows for close cutting to posts. It will make the DIY easier. Very convenient and practical tool for vapers.
Старый 09.04.2018, 04:42 Автор темы   77
3FVAPE
Get Low Mods GLM V2 Hybrid Mechanical Mod Clone $21.99
The Get Low Mods GLM Mechanical Mod Clone is a hybrid mechanical mod constructed from brass with beautiful design. The top and bottom of the tube is wider than middle part. There are six grooves on both top side and bottom side. It is powered by 1 x 18650 battery (not included). The mod comes with spring fire button and series number on it. This item also has other colors to choose.
AV Gyre Slow Twist Hybrid Mechanical Mod Clone $23.99
The AV Gyre Slow Twist Hybrid Mechanical Mod Clone is constructed from brass in 24mm diameter. The hybrid cap allows more aggressive raw power for massive clouds. The tube comes with Slow Twist style machined body (engraved logo), which is stylish and better to grip. The fire button is magnetic. Powered by single 18650 battery (not included).
Kindbright Complyfe Takeover Hybrid Mechanical Mod Clone $21.99
The Kindbright Complyfe Takeover Mechanical Mod Clone is made out of 316 stainless steel with hybrid connection. It is powered by single 18650 battery (not included). There are several venting holes around the top side for safe use. The bottom fire button is activated by magnets. This item also has other colors to choose.
Original Dovpo Thunder 200W TC VW Variable Wattage Box Mod $42.99
The original Dovpo Thunder Box Mod is a versatile regulated mod, which can provide maximum output up to 200W with dual 18650 batteries (not included). It supports multiple modes and temperature mode for vapers to vape in different ways. With 0.96inch OLED screen, all necessary vaping data can be displayed on it. Thunder 200W box mod provides many protections to avoid danger, including short circuit protection, high resistance protection, low resistance protection, low voltage protection, over-heat protection, and battery-reversal protection. This item also has other colors to choose.
SXK KF Lite Plus Five Pawns RTA Rebuildable Tank Atomizer Clone $11.99
The SXK KF Lite Plus Five Pawns RTA Clone is constructed from 316 stainless steel with PC tank. It is 22mm in diameter and comes with 2.5ml capacity. With the special "Pawn" style drip tip, you can enjoy more denser flavor as well as a high volume of vapor.
Magneto RDA Rebuildable Dripping Atomzier Clone with BF Pin + Spare Top Caps $19.99
The Magneto RDA Clone is a tiny squonk RDA with 16mm diameter. It is constructed from 316 stainless steel. The build deck comes with dual post design for single coil building. The RDA has side airflow system. POM drip tip is included.
This RDA comes with bottom feeder pin (no standard 510 pin), 2 spare top caps and 1 decorative ring.
Refilling Dripping Bottle for E-juice Liquid $0.99
The refilling dripping bottle is made out of PET material and has 10ml of juice capacity. It is suitable for storing e-juice liquid. This item also has other colors and capacity to choose.
Старый 10.04.2018, 05:19 Автор темы   78
3FVAPE
Original Zoor 500mAh Portable Pod System Device $42.99
The original ZOOR Ultra-Portable Pod System Device delivers the modern progression of today's travel-friendly pod systems, beautifully designed with an integrated 500mAh lithium battery and a tasty collection of pre-filled pods (not included). The ZOOR features a robust pen-style design and optimized for portability with soft curvature all-around and a comfortable grip section. Staying true to its closed-system core, the ZOOR is enabled by a draw-activated mechanism with a built-in 500mAh lithium rechargeable battery and LED indicators. A proprietary magnetic pod is implemented onto the device for easy-to-use set-up, housing a wide range of replacement pods infused with Ceramic Coil Technology. Each pod is pre-filled with 2mL of salts e-liquid in a lot of flavor options such as Apple, Cake, and Mint ICE.
This product comes with battery device only, pod cartridges not included.
Original Arctic Dolphin Anita 100W TC VW Squonk Box Mod $41.99
The original Arctic Dolphin Anita Squonk Box Mod is a regulated BF mod, which can reach maximum output up to 100W with single 18650, 20700, or 21700 battery (not included). With the 0.96inch OLED screen, all necessary vaping data can be displayed on it. The resistance range is from 0.06 to 1 ohm (TC) / 0.06 to 3ohm (VW). This item also has other colors to choose.
Original Arctic Dolphin Blaze RDA Rebuildable Dripping Atomizer with Bf Pin $22.99
The original Arctic Dolphin Blaze RDA is a 24mm BF RDA with gold plated dual post build deck, which provides great conductivity. The RDA comes with adjustable side airflow design, giving you great flavor and huge vapor production. PEI drip tip is included.
This RDA comes with bottom feeder pin. This item also has other colors to choose.
Original Serisvape Bomb UFO V1.5 RDTA Rebuildable Dripping Tank Atomizer $27.99
The Original Serisvape Bomb UFO V1.5 RDTA is a 25mm RDTA which has many innovative design. The oil plug is positioned in the middle of the deck and it can block the tank and the drip tip, making it leak-proof and dust-proof. The tank comes with 2ml juice capacity. The RDTA has star style side airflow and top hidden airflow. The PEI drip tip is round shape, which can not only fit the oil plug, but also make vapor more denser due to its beveled internal structure. This item also has other colors to choose.
Original Wismec Guillotine V2 RDA Rebuildable Dripping Atomizer with Bf Pin $23.99
The original Wismec Guillotine V2 RDA is a 24mm RDA with beautiful resin drip tip and dual post build deck for easy coil building. The adjustable side airflow brings great flavor to you. Guillotine V2 RDA is one of the best BF RDA for your squonk mod. This item also has other colors to choose.
Original Vaporesso Cascade One Plus 3000mAh Mod + Cascade Baby Tank Kit $36.99
The 810 drip tip is made from PC with 11mm height. It is suitable for Goon RDA, Goon RTA, Lost Art Goon RDA, Goon LP RDA, Kennedy 24 / 25 RDA, Battle RDA, Kryten RDA, Mad Dog RDA, Mask RDA, CSMNT Cosmonaut RDA, Unholy RDA, Apocalypse GEN 2 RDA, Reload RDA, Mini Battle RDA, Avid Lyfe Captain Cap II, Sith RDA.
Original VapeOnly Replacement MS Coil Head for Malle S Lite Starter Kit $7.99
The replacement MS Coil Head features 1.5ohm resistance and is suitable for Authentic VapeOnly Malle S Lite Starter Kit.
Original VapeOnly Replacement Coil Head for vPen Starter Kit $7.99
The replacement Coil Head features 1.3ohm resistance and is suitable for Authentic VapeOnly vPen Starter Kit.
Original VapeOnly Replacement vAir-P Coil Head for vPipe 3 Starter Kit $8.99
The replacement Coil Head features 0.7ohm resistance and is suitable for Authentic VapeOnly vPipe 3 Starter Kit.
Original SMOKTech SMOK V12 Prince Mesh Coil for TFV12 Prince Tank $10.99
Compared with traditional coil, the authentic SMOK TFV12 Prince Mesh Coil has a wide heating area, which can heat evenly and absorb e-liquid effectively, and it ensures you preferable flavor and huge vapor. What's more, the mesh coil has a longer life span.
This product comes with 3PCS in 1 pack. This item also has other types and Wattage range to choose.
Original Zoor Replacement Pod Cartridges for Zoor Portable Device $28.99
The Original Zoor Replacement Pods features 2ml capacity (pre-filled). It adpots ceramic coil technology and proprietary magnetic connection, which makes it very easy to use. It is suitable for Zoor Ultra Portable Device. This one is Sweets flavor.
This product comes with 4 PCS in 1 pack. This item also has Other Flavor to choose.
Старый 11.04.2018, 05:21 Автор темы   79
3FVAPE
Original GeekVape Aegis Legend Mod 200W TC VW Variable Wattage Box Mod $73.90
The original GeekVape Aegis Legend Mod is a stylish box mod designed to be water and shock resistant. The Aegis Legend is more powerful than its previous version. Compatible with dual 18650 batteries (not included) and powered by the new AS chipset, Aegis Legend releases up to 200W output. Aegis Legend uses up to six different materials to achieve style and extreme durability, including stainless steel powder metallurgy, zinc die casting alloys, die-casting aluminum, 40hrc carbon steel, LSR silicone and leather. If you are looking for a durable box mod with extreme power and portability, the Aegis Legend is the best choice. This item also has other colors to choose.
Original CoilART MAGE RTA V2 Rebuildable Tank Atomizer $35.00
The original CoilART MAGE RTA V2 is an updated version of MAGE RTA. MAGE V2 RTA is 24mm in diameter and has 3.5ml of juice capacity, which can be extended to 5.5ml with extra PCTG bubble tube. The postless build deck is gold plated and has 29 airholes (1mm diameter) at the post, where the airflow will travel up and hit the bottom and side of the coils. The RTA comes with 810 drip tip and 510 drip tip adapter. This item also has other colors to choose.
Flash e-Vapor V4.5 RTA Rebuildable Tank Atomizer Clone $23.99
The Flash e-Vapor V4.5 RTA Clone is a 23mm rebuildable tank constructed from stainless steel. The RTA features dual post build deck and adjustable airflow for MTL vaping. This tank will provide fantastic mouth-to-lung vaping experience.
VG V5s RTA Rebuildable Tank Atomizer Clone $22.99
The VG V5s RTA Clone is a 23mm rebuildable tank with 4.2ml e-juice capacity. It is constructed from stainless steel. The build deck comes with dual post for single coil building, which is friendly to even beginners. With the adjustable bottom airflow, it will bring you smooth vapor and nice flavor.
Original GeekVape Aegis Legend Mod 200W TC VW Box Mod + Aero Mesh Version Tank TPD Kit $96.50
The original GeekVape Aegis Legend Kit consists of GeekVape Aegis Legend Mod and Aero Mesh Version Tank. This item also has other colors and Capacity to choose.
Mod:
Tank:
The GeekVape Aero Mesh Version Tank is a 25mm sub ohm tank that adopts super mesh X1 coil head, which comes with 0.2ohm resistance and supports output at 30~90W. Another coil is IM4 head with 0.15ohm resistance and supports output at 60~80W.
The Aero Tank has 2ml of juice capacity for TPD compliant.
Original VapeOnly vPipe 3 e-Pipe Starter Kit $85.99
This product comes without any battery.
Original Wismec Replacement Bottom Feeder Bottle for Luxotic Squonk Box Mod / Kit $5.99
Apart from the original plastic e-liquid bottle, the newly added colorful silicone bottle will offer you more choices. The bottles are attractive in look and convenient in use, providing you with completely different vaping experiences. It is suitable for Luxotic BF Box Mod (Kit).
This product comes with 2 PCS in 1 pack. This item also has other colors to choose.
Старый 12.04.2018, 05:18 Автор темы   80
3FVAPE
Последняя активность: 16.12.2021 19:02
По умолчанию Re: 3FVape - New products & Deals Update
Original Limitless LMC 200W TC VW Variable Wattage Box Mod $58.99
The original Limitless LMC 200W Box Mod is a 200W regulated box mod with interchangeable plates. The Limitless 200W Mod is powered by dual 18650 battery (not included) that can fire up to max 200 watts. It supports low resistance to 0.08 ohm. Unique stylish design and fully customizable, three firing modes and multiple protections, makes LMC 200W Box Mod a good choice for you to vape. This item also has other colors to choose.
Original Asmodus Minikin V2 180W TC VW Variable Wattage Box Mod $100.89
The original Asmodus Minikin V2 is powered by a GX-180-HT chip which incorporates the same battery power saving capabilities as its predecessors but features 180W output and touch screen control. Coming with redesigned ergonomic body, you can hold it comfortably in hands. The mod is powered by dual 18650 batteries (not included). This item also has other colors to choose.
Chrome Hearts V2 Mechanical Mod Clone $18.99
The Chrome Hearts V2 Mechanical Mod Clone is made out of 316 stainless steel. It features engraved pattern on the tube and 510 threading connection (not hybrid). It is powered by single 18650 battery (not included). The fire button is activated by magnets. This item also has other Material and Colors to choose.
Goon Ti RDA Rebuildable Dripping Atomizer Clone with BF Pin $8.99
The Goon Ti RDA Clone is constructed from 316 stainless steel in 24mm diameter. It features bridge clamp design for easy building and middle side adjustable air slots for airflow control.
Original FreeMax Fireluke Mesh Sub Ohm Tank Atomizer $27.99
The original FreeMax Fireluke Mesh Sub Ohm Tank features 24mm diameter, 3ml juice capacity, convenient top fill design, adjustable bottom airflow, and most importantly the new mesh coil. The new mesh coil comes with 0.15ohm, supporting 40W to 90W power. It has wide contact surface between organic cotton and coil, which allows it to burn evenly and absorb e-juice effectively, giving you more intensive flavor and vapor production. This item also has other colors to choose.
Original Suorin Eva 380mAh All-in-One Starter Kit $26.99
The original Suorin Eva Starter Kit is an all-in-one pod system device, which features slim and compact design. The Eva integrates built-in 380mAh battery and a refillable pod cartridge with 1.8ml of capacity. The LED battery life indicator helps you know the battery juice and Suorin Eva supports USB charging.
Vapeasy Replacement Top Cap for Battle RDA Clone $11.99
The replacement top cap from Vapeasy is made out of titanium and suitable for Battle RDA Clone. This item also has other Material to choose.
3FVAPE вне форума   Вверх
Время генерации страницы 0.49567 секунды с 15 запросами
