302474
822
741
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
Uwell Caliburn G Pod System Kit $23.99
The Original Uwell Caliburn G Pod System Vape starter Kit is the upgrade version of Caliburn, works with 690mAh built-in battery and can fire up to max 15W output. Uwell Caliburn G Pod System Vape kit can vape directly through air pressure sensor or manual button to start vaping. Uwell Caliburn G Pod cartridge comes with 2.0ml capacity with top-fill and leakproof design. Uwell Caliburn G pod cartridge supports two different airflows: restricted DTL vaping (when the air inlet of the pod and the air inlet of the device are close to each other) and MTL vaping (when the air inlet of the pod and the air inlet of the device are far away from each other). ![]() Isurevape Diavel Pod System Kit $28.99 The Original Isurevape Diavel Pod System Vape Starter Kit is Powered by a single external 18650 battery (not included) and fires to a maximum output of 80W. The Isurevape Diavel Pod System supports wattage adjustable from 5W to 80W. The Isurevape Diavel Pod cartridge features replaceable coil-installation system, bringing much convenience for coil replacement and holds 3.7ml capacity. The Isurevape Diavel Coils are meshed cores with 0.15ohm mesh / 0.3ohm mesh / 0.6ohm mesh / 1.0ohm mesh resistance. You can adjust the wattage via the UP / DOWN button and clear display. The 2A QC ensures a fast charging time too. ![]() SXK Replacement Colorful Screw Set Kit for SXK BB(9 PCS) original price $6.90, now only $4.99 The SXK Replacement Colorful Screw Set Kit is suitable for SXK BB 70W / DNA 60W Box Mod Kit. They are used as replacement parts to fix your BB box mod and make your BB box mod look nice, which is made from stainless steel material. The Kit includes 9 x Colorful Screws. ![]() Original Isurevape Diavel Mesh Coil Head for Isurevape Diavel (5 PCS) $10.99 The Original Isurevape Diavel mesh coil head is suitable for Isurevape Diavel Pod System Vape Starter Kit / Isurevape Diavel pod Cartridge. The Isurevape Diavel mesh coil head is in 0.15ohm. With the meshed structure, the Isurevape Diavel coil will bring you huge cloud productions and dense flavor. ![]() Original Golisi S6 6-Solt Charger with LCD for 18650, 26650, 18350, 16340, 21700 Battery - US Plug $46.99 The Original Golisi S6 Intelligent Battery Charger is specially designed in response to customers who are in search of professional level of fast charging products, which supports fast charging when charge 3 batteries on the "2A" slots at the same time. With an extremely visible HD LCD display, the unique "%" readout accurately displays charging status, battery type, output current and more. Moreover, Golisi S6 is not just compatible with 20700, 26650, 18650 Li-ion batteries but nearly all cylinder shaped rechargeable batteries, even charging different batteries at the same time. US Plug ![]() Original Golisi S6 6-Solt Charger with LCD for 18650, 26650, 18350, 16340, 21700 Battery - EU Plug $46.99 The Original Golisi S6 Intelligent Battery Charger is specially designed in response to customers who are in search of professional level of fast charging products, which supports fast charging when charge 3 batteries on the "2A" slots at the same time. With an extremely visible HD LCD display, the unique "%" readout accurately displays charging status, battery type, output current and more. Moreover, Golisi S6 is not just compatible with 20700, 26650, 18650 Li-ion batteries but nearly all cylinder shaped rechargeable batteries, even charging different batteries at the same time. EU Plug ![]() Original Golisi S6 6-Solt Charger with LCD for 18650, 26650, 18350, 16340, 21700 Battery - UK Plug $55.99 The Original Golisi S6 Intelligent Battery Charger is specially designed in response to customers who are in search of professional level of fast charging products, which supports fast charging when charge 3 batteries on the "2A" slots at the same time. With an extremely visible HD LCD display, the unique "%" readout accurately displays charging status, battery type, output current and more. Moreover, Golisi S6 is not just compatible with 20700, 26650, 18650 Li-ion batteries but nearly all cylinder shaped rechargeable batteries, even charging different batteries at the same time. UK Plug ![]() Original Golisi S6 6-Solt Charger with LCD for 18650, 26650, 18350, 16340, 21700 Battery - AU Plug $55.99 The Original Golisi S6 Intelligent Battery Charger is specially designed in response to customers who are in search of professional level of fast charging products, which supports fast charging when charge 3 batteries on the "2A" slots at the same time. With an extremely visible HD LCD display, the unique "%" readout accurately displays charging status, battery type, output current and more. Moreover, Golisi S6 is not just compatible with 20700, 26650, 18650 Li-ion batteries but nearly all cylinder shaped rechargeable batteries, even charging different batteries at the same time. AU Plug ![]() Original Golisi Needle 6 USB Smart Charger for 18650 / 20700 / 21700 Battery $11.90 Original Golisi Needle 6 USB Charger is a USB smart charger that comes with a compact and portable structure. It is compatible with most smart phone adaptors nowadays with a 5V / 2A USB power port. Made by high quality of fire proof resistance material, it is safe to use. The interaction resistance will be lessened and the smooth sliding action will be increased with the military grade loading springs and contact plates. Needle 6 Charger is suitable with most cylindrical rechargeable batteries of length ranging from 32mm to 70mm, and up to 32mm in diameter.
742
Haar RTA Clone $18.99
The Haar RTA Clone is a 22mm rebuildable tank atomizer, which supports Single coil building, it is compatible with MTL and DL styles and can contain up to 4.0ml of e-liquid with top filling. The airflow is versatile and has a spectrum from slightly restrictive DL (direct lung) to a slightly open MTL (mouth to lung). ![]() Original Aspire BP80 Pod System Kit $59.99 The Original Aspire BP80 Pod System Vape Mod Kit, constructed of zinc alloy and soft leather, is powered by 2500mAh built-in battery with max 80W output. Aspire BP80 Pod Kit features Aspire self-developed ASP chipset to seamless switch between Auto mode and Manual mode and easy-to-read UI (0.96 inch color screen). Aspire BP80 cartridge has 4.6ml capacity with bottom filling design. Aspire BP80 pod adopts precise airflow adjustment and double unlimited airflow holes to meet different needs. Aspire BP80 is compatible with all of the BP60 coils (not included). ![]() Original Aspire BP Mesh Coil for BP80 Pod System Kit(5 PCS) $14.99 The Original Aspire BP 0.17ohm Mesh Coil is perfectly compatible with Aspire BP80 Pod System Vape Mod Kit. Comes with 5 PCS / Pack. ![]() Original Aspire BP Double-shot Coil for BP80 Pod System Kit(5 PCS) $14.99 The Original Aspire BP 0.6ohm Double-shot Coil is perfectly compatible with Aspire BP80 Pod System Vape Mod Kit. Comes with 5 PCS / Pack. ![]() Original Aspire BP Empty Pod Cartridge for BP80 Pod System Kit(1 PC) $3.99 The Original Aspire BP80 Pod Cartridge is an empty pod that designed for Aspire BP80 Pod Mod Kit. It features bottom adjustable airflow and bottom filling. Utilizing innovative Aspire coil technology, it is compatible with 0.17ohm / 0.3ohm Mesh Coil, 0.6ohm double-shot Coil (coils not included) and will present unrivalled flavor. In addition, it is also compatible with all BP60 Coils. ![]() Original Reewape RUOK 510 Adapter Connector for GeekVape Aegis Boost Plus $2.59 The Reewape RUOK 510 Adapter Connector is suitable for GeekVape Aegis Boost Plus 40W Pod System Vape Kit. It can switch your GeekVape Aegis Boost Plus 40W Pod System to a normal box mod to use any 510 thread RTA / RDA / RDTA / Sub Ohm Tank Vape atomizer. ![]() Original Reewape RUOK 510 Adapter Connector for SMOK RPM 2 / RPM 2S $2.59 The Reewape RUOK 510 Adapter Connector is suitable for SMOK RPM 2 / SMOK RPM 2S Pod System Vape Kit. It can switch your SMOK RPM 2 / SMOK RPM 2S Pod System Vape Kit to a normal box mod to use any 510 thread RTA / RDA / RDTA / Sub Ohm Tank Vape atomizer. ![]() 510 Drip Tip MTL Mouthpiece $1.99 The 510 Drip Tip MTL Mouthpiece is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. The MTL 510 drip tip is made from stainless Steel (base) and POM (mouthpiece). ![]() SXK Replacement 510 Drip Tip Kit for Haku Venna RDA Clone $8.80 The SXK replacement 510 drip tip and top cap and decorative ring is made from acrylic. The Top cap kit is suitable for Venna RDA Clone.
743
Original Kizoku Techmod 80W Vape Box Mod original price $59.99, now only $40.99
The Kizoku Techmod 80W TC VV VW Vape Box Mod is powered by single 18650 battery (Not included) with Max. 80W Output Wattage. Equipped with 0.91" large Screen, you can get specific data of this device in details. Techmod Mod is perfect match the Kizoku Limit RTA tank and it is also Wide compatibility with most atomizers in the market. KIZOKU TECHMOD is a side by side vape mod, which is specially designed for advanced vapers. Powered by an external single 18650 battery, the TECHMOD fires up to 80W max power output with four working modes (VW / VV / TC / ByPass) to satisfy all your vaping needs. The 24mm ultra-thin body and unique ergonomic design of 5 degree bevel will give you a super comfortable hand-feel and ultimate visual experience. ![]() Original ZQ Vi 2 Pod System Kit $23.99 The Original ZQ Vi 2 Pod System Vape Starter Kit which guides the airflow through a piece of mesh to hit the 0.6ohm & 1.2ohm coil. This process creates a sufficient atomization effect so as to bring you ultra great and smooth vaping. ZQ Vi 2 Vape Kit has 1000mAh built-in battery, Designed with air switch, it has a manual key for you to operate it. It supports either Puff activated or button activated. ![]() Original ZQ MOOX Pod System Kit $27.99 The Original ZQ Moox Pod System Vape Starter Kit is capable of creating a satisfying vaping with the lasting standby time, well-content taste and decent temperature for you benefited from the 1100mAh large battery, rich power levels and developed airflow system. What' more, 3 colors of the LED indicator acts on informing you of the remaining of the battery capacity in the actual use. Topped with a 3.0ml pod cartridge, you are allowed to fill it with any flavor you favored to cater to your diverse taste preference. ![]() Original Kizoku Techmod MTL RTA Kit original price $97.99, now only $58.99 The Kizoku Techmod MTL RTA Kit consists of Kizoku Techmod 80W TC VV VW Vape Box Mod and Kizoku Limit RTA Tank Atomizer. The Kizoku Techmod 80W TC VV VW Vape Box Mod is powered by single 18650 battery (Not included) with Max. 80W Output Wattage. Equipped with 0.91" large Screen, you can get specific data of this device in details. Techmod Mod is perfect match the Kizoku Limit RTA tank and it is also Wide compatibility with most atomizers in the market. KIZOKU TECHMOD is a side by side vape mod, which is specially designed for advanced vapers. Powered by an external single 18650 battery, the TECHMOD fires up to 80W max power output with four working modes (VW / VV / TC / ByPass) to satisfy all your vaping needs. The 24mm ultra-thin body and unique ergonomic design of 5 degree bevel will give you a super comfortable hand-feel and ultimate visual experience. ![]() Original ZQ Vi 2 Pod System Replacement Mesh Coil Head - DL Vaping (5 PCS) $9.99 The Original Vi 2 Replacement 0.6ohm mesh Coil is for DL vaping and it perfectly compatible with ZQ Vi 2 Pod System Vape Kit. ![]() Original ZQ Vi 2 Pod System Replacement Coil Head - MTL Vaping (5 PCS) $9.59 The Original Vi 2 Replacement 1.2ohm Ni-chrome Coil is for MTL vaping and it perfectly compatible with ZQ Vi 2 Pod System Vape Kit. ![]() Original ZQ Vi 2 Pod System Replacement Empty Pod Cartridge(1 PC) $3.99 The Original Vi 2 Replacement Empty Pod Cartridge holds 3.0ml and it perfectly compatible with ZQ Vi 2 Pod System Vape Kit. ![]() Original ZQ MOOX Pod System Replacement Mesh Coil Head - DL Vaping (5 PCS) $10.99 The Original Vi 2 Replacement 0.6ohm mesh Coil is for DL vaping and it perfectly compatible with ZQ MOOX Pod System Vape Kit. ![]() Original ZQ MOOX Pod System Replacement Coil Head - MTL Vaping (5 PCS) $10.59 The Original Vi 2 Replacement 1.2ohm Ni-chrome Coil is for MTL vaping and it perfectly compatible with ZQ MOOX Pod System Vape Kit. ![]() Original ZQ MOOX Pod System Replacement Empty Pod Cartridge(1 PC) $5.99 The Original Vi 2 Replacement Empty Pod Cartridge holds 3.0ml and it perfectly compatible with ZQ MOOX Pod System Vape Kit.
744
Original VOOPOO Argus GT 160W Box Mod $36.99
The VOOPOO Argus GT TC 160W Box Mod finds inspiration for dynamism and lightness from racing bikes. Using the same zinc alloy and leather process as the racing bike, it's more aesthetically pleasing and 30% lighter than the usual Mod. Argus GT is powered by two external 18650 batteries (not included), in combination with the Type-C fast charging interface, offering you a longer vaping experience in a portable size. Argus GT has a high power output of up to 160W. 5W to 160W adjustable power range, fully meet your different needs. Besides, Argus GT built-in powerful GENE.TT chip that gives it a thick haze in an instant, has the powerful performance of fast ignition and high burst and also provides intelligent functions such as SMART and TC mode. TC mode supports the temperature adjustment of Nickel, Titanium, and Stainless Steel heating wire materials. Just press "+" and "-" at the same time to enter the page adjustment. ![]() Original ZQ Essent DNA75C 75W Box Mod original price $149.99, now only $139.99 The Original ZQ Essent Mod is a collaboration created by ZQ, YouTube reviewer Steamshots TV and Smartin TV. It is the most ergonomic box mod that is designed to have a firm grip and makes it comfortable in the palm of your hand, with The most advanced and customizable DNA 75c chipset designed by EVOLV. The rounded edges make the mod the best and constructed with high-quality Aluminum Alloy with the comfortable shape either you are thumb firing or finger firing. The ZQ Essent Mod is powered by a single 21700 battery and can be compatible with 18650 batteries using the included 18650 adapter (Battery not included). The 21700 / 18650 batteries are sealed with the telescoping style of doors making it more durable and sure will last long. The. DNA 75c chipset provides rich functions for each user, support VW / TC / TCR / VV and other modes, and can use the replay function, which can imitate and repeat previous actions. Using Escribe software, you can conveniently make all settings at home on your PC. The device is equipped with a large 0.9" full-color TFT screen to make all parameters clearly visible. ![]() SXK 415 S61 Genesis Atomizer RDTA Clone original price $28.90, now only $25.90 The SXK 415 S61 Genesis Atomizer RDTA Rebuildable Dripping Tank Atomizer Clone is constructed from 316 stainless steel and PEI tank. The 22mm RDTA is designed for dry flavor, hard throat hit. The Four One Five S61 Genesis Atomizer RDTA Clone is with single coil building and airflow adjustable. ![]() Monarchy J3S MTL RTA Clone $14.99 The Monarchy J3S MTL RTA Rebuildable Tank Vape Atomizer Clone is made from Stainless Steel and PCTG tank with 22mm diameter and holds 2.5ml capacity. The Monarchy J3S MTL RTA Clone is with single coil deck and bottom airflow control for MTL vaping.
745
Hussar Legacy II RDA Clone with BF Pin $8.99
The Hussar Legacy 2 II V2 RDA Clone is made from 316 stainless steel in 22mm diameter. The Legacy 2 RDA Clone is designed for DL vaping with single coil building deck. The Legacy II Style RDA is with dual side airflow adjustable. Comes with Bottom Feeder / BF / Squonker Pin for Bottom Feeder Mod. ![]() Original Wotofo Alien Wires Pre-built Coil(5 PCS) $7.59 The Original Wotofo Alien Wires Pre-built Coil is made from Ni80 with 3 x 30GA + 38GA and is suitable for RDA / RTA / RDTA Vape Atomizer. Wotofo introduces a range of Prebuilt Coils for the customers who do not have the time for building coils. You can buy different prebuilt coils. The Wotofo prebuilt coils are convenient for those who find coil building boring. These coils offer an outstanding flavor intensity with vast vapor production. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production. An alien wire is an upgraded version of the Clapton wire. It is a de-cored Clapton wrapped around a multi-strand core. A distinct texture of the outer wire makes it different from the fused Clapton. Wotofo offers prebuilt alien coils with a 0.50ohm resistance ![]() Original Wotofo Core Fused Clapton Pre-built Wire Coil(5 PCS) $5.59 The Original Wotofo Core Fused Clapton Pre-built Wire Coil is made from Ni80 with 5 x 30GA + 40GA and suitable for RDA / RTA / RDTA Vape Atomizer. Wotofo introduces a range of Prebuilt Coils for the customers who do not have the time for building coils. You can buy different prebuilt coils. The Wotofo prebuilt coils are convenient for those who find coil building boring. These coils offer an outstanding flavor intensity with vast vapor production. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production. Need to wrap thin gauge wire around two or more thick cores to build a Fused Clapton coil. A fused Clapton helps provide a better user experience. ![]() Original Wotofo Dual Core Fused Clapton Coil Pre-built Wire(5 PCS) $3.99 The Original Wotofo Dual Core Fused Clapton Coil Pre-built Wire is made from Ni80 with 2 x 26GA + 40GA and suitable for RDA / RTA / RDTA Vape Atomizer. Wotofo introduces a range of Prebuilt Coils for the customers who do not have the time for building coils. You can buy different prebuilt coils. The Wotofo prebuilt coils are convenient for those who find coil building boring. These coils offer an outstanding flavor intensity with vast vapor production. Using prebuilt coils is the best way to avoid tedious time-consuming work of coiling. This is where the Wotofo prebuilt coils comes in to provide the convenience for rebuilders who may not in the mood of wrapping your coils by hand at times. Wotofo prebuilt coils can eliminate the hassle with its machine-accurate fine work, offering remarkable flavor intensity and immense vapor production. Need to wrap thin gauge wire around two or more thick cores to build a Fused Clapton coil. A fused Clapton helps provide a better user experience. ![]() Original Wotofo Dual Core Fused Clapton Pre-built Coil Wire(10 PCS) $3.99 The Original Wotofo Dual Core Fused Clapton Pre-built Coil Wire is made from Ni80 with 2 x 30GA + 38GA and suitable for RDA / RTA / RDTA V |
746
SUPCOIL Mistohm Sub Tank Vape Atomizer RBA Edition $18.99
The Original SUPCOIL Mistohm Sub Tank Vape Atomizer RBA Edition features slide coil design as the first bottom push coil tank and can be Comes with RBA coils (included) to provide DIY fun. SUPCOIL Mistohm maintains 22mm diameter and 6.5ml large capacity with top filling design. Mistohm Tank can support both MTL & DTL vaping in same tank. ![]() Voopoo DRAG MAX 177W Pod System Kit $49.99 The Original Voopoo DRAG MAX 177W Pod System Vape Kit is with brand new Gene Fan 2.0 Chip, Drag Max is more powerful and multifunctional! Break the definition of traditional vape devices. Perfect for starters, flavor chasers, cloud chasers and DIY enthusiasts! ![]() VapeSoon DT116 810 Drip Tip $1.99 The Original VapeSoon DT116 810 Drip Tip is made from resin and it suitable for RDA / RTA / RDTA Vape Atomizer. ![]() Original VapeSoon G.Pod Mesh Coil Head for GeekVape Boost Plus Pod System(5 PCS) $7.99 The Original VapeSoon G.Pod Mesh Coil Head is suitable for GeekVape Boost Plus Pod System Vape Kit. The Mesh-tech coil is with 0.6ohm resistance and supports 13W to 18W. ![]() Original VapeSoon RPM2 Mesh Coil for SMOK Scar-P5 Kit / Scar-P3 Kit / RPM 2 / 2S Kit(5 PCS) $7.99 The Original VapeSoon RPM2 Mesh Coil is suitable for SMOK Scar-P5 Kit / Scar-P3 Kit / RPM 2 / 2S Vape Mod Kit. The Mesh coil is with 0.16ohm and supports 25W to 50W. ![]() Original VapeSoon RPM2 DC Coil for SMOK Scar-P5 Kit / Scar-P3 Kit / RPM 2 / 2S Kit(5 PCS) $7.99 The Original VapeSoon RPM2 DC Coil is suitable for SMOK Scar-P5 Kit / Scar-P3 Kit / RPM 2 / 2S Vape Mod Kit. The Mesh coil is with 0.6ohm and supports 12W to 25W. ![]() Original VapeSoon 510 Thread Adapter Connector for GeekVape Aegis Boost $3.99 The Original VapeSoon 510 Thread Adapter Connector is designed for Geekvape Aegis Boost Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Geekvape Aegis Boost Kit into a normal 510 thread box mod kit to use different atomizers. ![]() Original VapeSoon 510 Thread Adapter Connector for GeekVape Aegis Boost Plus $3.99 The Original VapeSoon 510 Thread Adapter Connector is designed for Geekvape Aegis Boost Plus Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Geekvape Aegis Boost Plus Kit into a normal 510 thread box mod kit to use different atomizers.
747
Original VapeSoon 510 Thread Adapter Connector for Voopoo Drag X / S $3.59
The Original VapeSoon 510 Thread Adapter Connector is designed for Voopoo Drag X / S Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Voopoo Drag X / S Kit into a normal 510 thread box mod kit to use different atomizers. ![]() Original VapeSoon 510 Thread Adapter Connector for SMOK RPM80 / RPM80 Pro $3.99 The Original VapeSoon 510 Thread Adapter Connector is designed for SMOK RPM80 / RPM80 Pro Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your SMOK RPM80 / RPM80 Pro Kit into a normal 510 thread box mod kit to use different atomizers. ![]() Original VapeSoon 510 Thread Adapter Connector for Voopoo VINCI Air $3.99 The Original VapeSoon 510 Thread Adapter Connector is designed for Voopoo VINCI Air Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your Voopoo VINCI Air Kit into a normal 510 thread box mod kit to use different atomizers. ![]() Original Uwell Caliburn G Replacement Mesh Coil Head(4 PCS) $8.99 The Original Uwell Caliburn G Mesh Coil is designed for Caliburn G Pod System Vape Starter Kit. Featuring 0.8ohm mesh coil resistance, it will provide you great vaping experience. 4 PCS each pack. ![]() Original Uwell Caliburn G Pod System Replacement Empty Pod Cartridge(2 PCS) $5.99 The original Uwell Caliburn G Pod Cartridge is an empty pod cartridge that is suitable for Uwell Caliburn G Pod System Vape Kit. It holds 2.0ml e-juice capacity and comes with top filling design for easy refilling. 2 PCS each pack. ![]() Replacement Screws for dotMod dotAIO Pod(4 PCS) $2.99 The Replacement Screws is made from stainless steel and is suitable for dotMod dotAIO Pod System Vape Kit. 4 PCS / Pack. ![]() Replacement Inner Door for dotMod dotAIO Pod $19.99 The Replacement Inner Door is made from Acrylic and is suitable for dotMod dotAIO Pod System Vape Kit. 1 PC / Pack. ![]() Original VapeSoon 510 Thread Adapter Connector for SMOK RPM2 / RPM2S $3.99 The Original VapeSoon 510 Thread Adapter Connector is designed for SMOK RPM2 / RPM2S Pro Pod System Vape Kit, it is made of stainless steel (510 threading connector) and POM (outer housing), which can switch your SMOK RPM2 / RPM2S Kit into a normal 510 thread box mod kit to use different atomizers.
748
Curdo Halo Box Mod $24.99
The Original Curdo Halo VW Vape Box Mod supports VW / TC and combines exquisite appearance, grid design and cooling performance. It is powered by dual 18650 batteries (not included) with adjustable output power from 1W to 218W. And with 0.001S ignition, it allows you to obtain the first hit of intense flavor and massive vapor. And there is a 0.96-inch OLED screen to display clear vaping information. It also supports VV Mode and TC Mode for your option. Moreover, it is also compatible with most DIY tank. ![]() Vandy Vape Requiem RDA original price $32.99, now only $24.99 The Original Vandy Vape Requiem RDA rebuildable dripping vape atomizer is designed with 22mm diameter and comes with 24mm beauty ring. It integrates a single coil with the replaceable airflow tubes for DL, RDL and MTL vapers. And there are 3 drip tips for your option. Besides, it adopts easy and convenient single coil building and 510 pin. Andit comes with 0.26ohm fused Clapton coil in the package, it provides you with excellent flavor. ![]() Uwell Whirl 2 Tank Clearomizer Vape Atomizer $27.99 The Original Uwell Whirl II 2 V2 Tank Short is 25mm in diameter and has 3.5ml e-juice capacity. It is compatible with Whirl Replacement Coils: Dual Nichrome Coil 0.6ohm for restricted DTL and Single Nichrome Coil 1.8ohm for MTL. The top cover and base of the atomizer are designed with a curvature and the overall outline of the atomizer forms a concave arc, which will avoid the damage of glass tube. Whirl II Tank utilizes self-cleaning technology that will reduce juice leakage and lessen the cleaning frequency, it is of great convenience. Besides, the top cap adopts a quarter turn design for easier juice adding and the filler holes feature a silicone check valve to prevent e-juice leakage and make the filling cleaner. ![]() Original Suorin ACE Pod System Kit $25.99 The Original Suorin ACE 15W Pod System Vape Kit is a simple but interesting ultra-compact product, using ACE-Style design, with a tight puff effect and overall good performance. The Suorin ACE Pod is built-in 1000mAh battery and charges via the USB Type-C port at up to 1A charging rate. The Suorin ACE supports deliver vapor in an instant via button activated firing mechanism or draw-activated firing. The output power reaches a maximum of 15 watts. The design of the replaceable pod cartridge is familiar: there is a flat mouthpiece at the top, a magnetic connector at the bottom, has 2.0ml e-juice capacity, and an integrated coil with a 1.0ohm coil is provided inside. The filling groove is hidden on the sidewall. In addition, the Suorin ACE Cartridge has made some upgrade changes, redesigned the mouthpiece on the pod for the ACE, changed the airflow intake to the base of the pod to improve the flow of e-liquid through the pod, and new hanging condensing design. The Suorin ACE is also compatible with Suorin Shine Pod Cartridge, easily switch from the different devices while enjoying the same original pure flavor. ![]() Suorin ACE Replacement Pod Cartridge with 1.0ohm Coil(3 PCS) $9.99 The Original Suorin Ace Pod Cartridge is a refillable 2.0ml magnetic cartridge which makes refilling on-the-go a fuss-free experience. The pod simply pops into the device body and to refill you simply add e-liquid through the side port located on the pod. A non-replaceable coil with a resistance of 1.0ohm is installed inside. The pod is also compatible with the Suorin Shine, but the ACE cartridge has had a few upgrades. Suorin Ace Pod has optimized mouthpiece shape, air intake direction, optimize the airway, upgraded internal structure. ![]() Original SUPCOIL Mistohm Tank Replacement RBA Coil Deck(1 PC) $5.99 Original SUPCOIL Mistohm RBA coil deck is with airflow for better vaping experience and is designed for SUPCOIL Mistohm Tank. With the RBA coil deck, your Mistohm tank will switch to a rebuildable tank that bringing more fun to your vaping daily life. ![]() Original SUPCOIL Mistohm Tank Replacement Mesh Coil(5 PCS) $8.99 The Original SUPCOIL Mistohm Mesh Coil is designed for SUPCOIL Mistohm Tank. The 0.2ohm mesh coil is suitable for 40W to 60W.
749
SXK Bantam Revision Box Mod Kit w/o 18350 Battery original price $75.00, now only $55.99
The SXK Bantam Revision 30W VW Variable Wattage Mini Box Vape Mod Kit is powered by 1 x 18350 battery (Not included) with output power of maximum 30W. Compact but fully functional variable power device that integrates various pre-built and reconfigurable coil units with a variety of adapters. SXK Bantam Revision is equipped with new updated SEVO-30 Chipset that provide you a new experience. It comes with new MTL pod unit and EUC Coil to provide you MTL vaping experience and great vapor enjoyment. The mod kit is compatible with Aspire Nautilus Coils that meet your different vaping needs. What's more, Bantam Revision has an AFC airflow control function that makes airflow control conveniently and fast. ![]() SXK KF 5² Square SE RTA Clone Replacement Positive Pin $1.99 The SXK Replacement Positive Pin is made from Stainless Steel and is suitable for KF 5² Square SE RTA Vape Atomizer Clone. ![]() SXK KF 5² Square SE RTA Clone Replacement Tank Tube $1.99 The SXK Replacement Tank Tube is made from PCTG and is suitable for KF 5² Square SE RTA Vape Atomizer Clone. ![]() Original Geekvape Aegis Hero Replacement Pod Cartridge(1 PC) original price $11.99, now only $8.99 The Original GeekVape Aegis Hero Pod System Vape Kit Replacement 4.0ml Pod Cartridge features a practical top fill method which reduces the chance of leakage. The sleek adjustable airflow features supplies users complete control over inhalation, whilst the push fit coil installation makes inserting and replacing coils an easy, hassle free process. Compatible with the G coil series, comes with a 0.4 Ohm mesh coil and 0.6 Ohm mesh coil. Use with high VG e-liquids of 50% and above for best performance. ![]() Original Uwell Whirl II 2 Tank Replacement Dual Nichrome Coil Head(4 PCS) $8.99 The original Uwell Replacement Dual Nichrome Coil Head is in 0.6ohm resistance and supports 18W to 22W. It is suitable for Whirl II 2 Tank Vape Atomizer. ![]() Original Uwell Whirl 2 Tank Replacement Single Nichrome Coil Head(4 PCS) $8.99 The Original Uwell Replacement Single Nichrome Coil Head is in 1.8ohm resistance and supports 10W to 15W. It is suitable for Whirl II 2 Tank Vape Atomizer.
750
Stratum Balance 60W Box Mod Clone $54.99
The Stratum Balance 60W TC VW Vape Box Mod Clone is made from POM and Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The Box Mod is Compatible with 24mm diameter vape atomizer. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output. ![]() Vaporesso FORZ TX80 80W Box Mod $44.99 The Original Vaporesso FORZ TX80 VW Vape Box Mod which is a vaping box mod with all around protections. And the FORZ TX80 is waterproof, shockproof, and dustproof, the IP67 1.5m waterproof for 30mins. The MIL-STD-810G that FORZ TX80 has qualified, is a set of tests performed on a piece of equipment in order for the Department of Defense (DoD) to make sure it can withstand the harsh undertakings of a military endeavor. The Vaporesso FORZ TX80 adopts new vaping mode of F(t). F(t) is a transformative mode developed to achieve an unprecedented leap in flavor release. You can get 80W max output by Vaporesso FORZ TX80 mod with the single 18650 battery (not included). Moreover, the Vaporesso FORZ TX80 mod has the AXON 2.0 chipset inside for stable and smart operation. ![]() Vaporesso FORZ RDA $23.99 The Original Vaporesso FORZ RDA Vape Atomizer is perfect for Vaporesso FORZ TX80 Kit / Vaporesso FORZ TX80 Mod. The Vaporesso FORZ RDA supports single / dual coil configurations for meeting your different needs. And the Vaporesso FORZ RDA is easy to building, compatible with 810 Drip Tip and 510 drip tip (with 510 drip tip adapter). Featuring the honeycomb airflow control system, the Vaporesso FORZ RDA must bring you amazing flavor and dense clouds. Comes with BF / Bottom Feeder / Squonker Pin. ![]() Vaporesso FORZ TX80 80W Mod Kit $59.99 The Original Vaporesso FORZ TX80 80W Box Mod Vape Kit is an all-round sturdy box mod vape kit that features a waterproof, shockproof, and dustproof function. It consists of Vaporesso FORZ TX80 Mod and a new sturdy FORZ Tank 25 atomizer. ![]() Replacement 810 Drip Tip with O-Ring $0.99 The Replacement 810 Drip Tip is made from resin and comes with silicone O-Rings. It is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. ![]() Vaporesso GTR Mesh Coil for FORZ TX80 VW Kit / FORZ Tank 25(3 PCS) $9.99 The Original Vaporesso GTR coils platform brings the brand-new sub-ohm vaping experience consistently, with the anti-bacteria organic cotton, a larger airway, and an updated leak-proof structure, making each puff an impressive one. The GTR Mesh Coil 0.15ohm supports 60W to 80W vapeing. ![]() Vaporesso GTR Mesh Coil for FORZ TX80 VW Kit / FORZ Tank 25(3 PCS) $8.99 The Original Vaporesso GTR coils platform brings the brand-new sub-ohm vaping experience consistently, with the anti-bacteria organic cotton, a larger airway, and an updated leak-proof structure, making each puff an impressive one. The GTR Mesh Coil 0.4ohm supports 40W to 60W vapeing. ![]() Vandy Vape Requiem RDA Replacement Fused Clapton Coil(10 PCS) $4.99 The Vandy Vape prebuilt Fused Clapton Coil is made from Ni80 in 27GA x 2 + 40GA with 0.26ohm. These coils feature amazing quality and vapor production. It is perfect for Vandy Vape Requiem RDA. Each vial contains 10 coils and 1 coiling pole.
751
Original SXK Supbox 70W Box Mod Kit $86.80
The Original SXK Supbox 70W Box Mod Kit is built-in SEVO-70 chipset and adopts creative design, compatible with Most accessories for Billet Box and all 510 atomizers within 24mm diameter. Provide more personalized accessories such as battery tube and outside case. Comes with 1.1ohm and 0.6ohm cotton coil for choice. The SXK Supbox 70W Vape Box Mod Kit is using the same chipset as SXK BB 70W Mod kit, which supports VW / TC / By Pass Modes. The SXK Supbox 70W Vape Box Mod Kit supports 5 different Modes: Pod Mode, 510 Tank / RDA Mode, Universal Mode, 18650 Mode, 18350 Mode. ![]() Original IJOY PikGo Pod Mod Kit original price $20.99, now only $17.99 The Original IJOY PikGo Pod Vape Starter Kit is ultra portable and lightweight. The IJOY PikGo Pod Kit is powered by 1300mAh inbuilt battery with Type-C fast charging. And the IJOY PikGo Pod uses the Univ.mini chipset and intelligent auto-match technology for easy operation and safe vaping. In addition, The IJOY PikGo Pod Kit has 3 output modes optional. Featuring iJoyLAB Flavor Testing Technology (IFTT), the IJOY PikGo kit is suitable for DL / MTL vaping. The IJOY PikGo pod cartridge sealed by ultrasonic technology for leaking-proof. And the IJOY PikGo cartridge comes with P0.6 Mesh Pod and P1.0 Mesh Pod for meeting your different needs. With easy top-fill and side adjustable airflow valve design, the IJOY PikGo cartridge will bring you amazing flavor. ![]() Original IJOY PikGo D18 Pod Mod Kit original price $15.99, now only $13.99 The Original IJOY PikGo D18 Pod Mod Vape Starter Kit is best for beginners. Powered by internal 1000mAh battery, the IJOY PikGo D18 has slim size of 18mm diameter. The IJOY PikGo D18 has 0.6ohm and 1.0ohm pod cartridge for different vaping experience and flavor. The IJOY PikGo D18 reaches a maximum output of 23W with new Univ.mini chipset. The IJOY PikGo D18 adopts intelligent auto-match technology, so it will recognize the suitable power smartly. The top-fill and adjustable airflow design make the IJOY PikGo D18 an easy vape device for starters. The IJOY PikGo D18 is both perfect for DL and MTL vape. ![]() SXK Exocet V2 RBA Deck Clone original price $22.90, now only $19.80 The SXK Exocet V2 RBA Deck Clone is suitable for Billet Box / SXK BB Vape Box Mod kit / SXK Supbox Vape Box Mod Kit. The SXK Exocet V2 is made from 316 stainless steel with dual pole for single coil building. It comes with 3 x air tubes, 1 x 1.0mm, 1 x 2.0mm (pre-installed) and 1 x 3.3mm. ![]() Original SXK Unit Tank for SXK Supbox / Supbox Pro Box Mod Kit $8.90 The Original SXK Unit Tank is made from Acrylic with 5.0ml capacity. And it Compatible with SXK Vape Shell (SKU 22401) / SXK SVT Crossbow RBA (SKU 39503) / SXK Bridg'D Bridg D Style MTL / DL RBA (SKU 43487) / SXK EXOCET V2 For Billet (SKU 46661). The Tank is suitable for SXK Supbox / Supbox Pro Vape Box Mod Kit ![]() Original SXK Supbox Replacement RBA Coil Head Deck $14.90 The Original SXK Replacement RBA Coil Head Deck is with dual pole for single coil building. It is suitable for SXK Supbox Vape Box Mod Kit. ![]() Original SXK Supbox Replacement 510 Atomizer + Pod Cartridge Case Cage Sleeves(2 PCS) $13.90 The Replacement Case Cage Sleeves set comes with 2 PCS pack. One is for 510 RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer and the other is for Pod Cartridge. It is suitable for Original SXK Supbox Vape Box Mod Kit. ![]() Original SXK Supbox Replacement Hollow-out 18650 Battery Adapter Tube $15.50 The Original SXK Replacement Hollow-out Battery Adapter Tube holds 1 x 18650 battery (not included) and is suitable for Supbox Box Mod Kit. ![]() Original IJOY PikGo Pod Cartridge for IJOY PikGo D18 Kit / IJOY PikGo Pod Kit(3 PCS) original price $10.99, now only $7.99 The IJOY PikGo Replacement Pod Cartridge is perfectly compatible with IJOY PikGo D18 Kit / IJOY PikGo Pod Kit. The IJOY PikGo Pod Cartridge is built-in 1.0ohm mesh coil. The top-fill and adjustable airflow design make the IJOY PikGo Pod an easy vape device for starters. The IJOY PikGo Pod is both perfect for DL and MTL vape ![]() Original IJOY PikGo Pod Cartridge for IJOY PikGo D18 Kit / IJOY PikGo Pod Kit(3 PCS) original price $10.99, now only $7.99 The IJOY PikGo Replacement Pod Cartridge is perfectly compatible with IJOY PikGo D18 Kit / IJOY PikGo Pod Kit. The IJOY PikGo Pod Cartridge is built-in 0.6ohm mesh coil. The top-fill and adjustable airflow design make the IJOY PikGo Pod an easy vape device for starters. The IJOY PikGo Pod is both perfect for DL and MTL vape. ![]() Original Exvape Expromizer TCX RDTA Replacement Organic Cotton Vape Laces(10 PCS) $4.99 The Original Exvape Expromizer TCX RDTA Replacement Organic Cotton Vape Laces is Tasteless and without Chemicals. The Cotton is perfect for Exvape Expromizer TCX RDTA Vape Atomizer. ![]() Original REEWAPE AS319S 510 Drip Tip $2.59 The REEWAPE AS319S Replacement 510 Drip Tip is made from resin (mouthpiece) & Stainless Steel (connector base) and with silicone O-Rings. It is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. This drip tip is with SS Mesh Sheet for Anti Spit. ![]() Original REEWAPE AS319 510 Drip Tip $2.59 The REEWAPE AS319 Replacement 510 Drip Tip is made from resin (mouthpiece) & Stainless Steel (connector base) and with silicone O-Rings. It is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. This drip tip is with SS Mesh Sheet for Anti Spit.
752
ShenRay VG Extreme V2 Version RTA $29.99
The ShenRay VG Extreme V2 RTA Rebuildable Tank Vape Atomizer Clone is in 23mm diameter and holds 6.5ml capacity. The ShenRay VG Extreme V2 RTA Clone supports dual / single coil building and DL / RDL / MTL Vape. The airflow control is adjustable via Air Pins, Winding is supplied air from three sides (frontal, bottom, diagonal top). ![]() Original Innokin Ares 2 D24 LE MTL RTA $26.99 The Innokin Ares 2 D24 LE MTL RTA Tank Vape Atomizer is a limited edition. The new ARES 2 LE is with a particularly elegant appearance thanks to its sandblasted matt surface. Thus the ARES 2 LE looks more modern and in connection with the tank even more elegant. The branding of the bell was revised and had to make room for the embossing "ARES-2 LE". Innokin has used a slide mechanism for easy filling, which means that the top cap can be easily moved to the side. The existing Cross-Airflow-Control (CAFC) allows the air intake below the coil to be regulated in 5 stages without having to adjust screws or inserts. ![]() YFTK Monarchy J3S DL RTA Clone $23.99 The YFTK Monarchy Monarch J3S RTA Rebuildable Tank Vape Atomizer Clone is made from 316 Stainless Steel and PCTG tank with 22mm diameter and holds 2.5ml capacity. The YFTK Monarch J3S RTA Clone is with single coil deck and bottom airflow control. The RTA supports DL Vaping. ![]() Original Innokin Glim Pod System Kit $14.99 The Original Innokin Glim is an open pod system vape kit with an excellent flavor experience. Stylish, compact, portable, easy to operate, beginner-friendly. GLIM can be easily placed in the palm of your hand, or it can be quickly slipped into your pocket. Glim provides a fixed 500mAh battery, which can be easily charged via a Micro USB cable, and has a maximum output of 9W, without buttons, with a draw-activated function, you can atomize just by blowing air, and experience the real atomization satisfaction. The LED indicator on the front of the device allows you to check the battery level. The Glim has a full range of integrated safety protections. Each kit comes with refillable Glim pod cartridge that have a capacity of 1.8ml. To refill the pod with your favorite juice, just take the cartridge from the device, turn it over, and filling it with the liquid. With a "push to fill" silicon seal to prevent children from entering. The built-in 1.2ohm coil ensures that it produces an excellent taste at a pleasant vapor temperature. ![]() YFTK Monarchy J3S Replacement Air Insert(3 PCS) $6.99 The YFTK Monarchy J3S RTA Clone Replacement Air Insert is made from PEEK and in 3 size: 1.0mm + 1.2mm + 1.5mm. With this air inserts, the YFTK Monarchy J3S DL RTA Clone will be switched into MTL RTA (mouth-to lung vaping). ![]() YFTK Monarchy J3S Replacement Drip Tip Set $7.99 The YFTK Replacement Drip Tip Set is made from stainless steel and PEEK. It is suitable for Monarchy J3S RTA Clone. ![]() Original Innokin Glim Pod System Replacement Pod Cartridge(4 PCS) $8.99 The Glim Pod Cartridge is designed especially for the Innokin Glim Pod System Vape Starter Kit, coming with 1.8ml e-juice capacity. ![]() Steam Tuners Tank Tube Clone + Chimney + Top Cap Top Filling Kit for Dvarw FL 22mm RTA $4.99 The Steam Tuners Top Filling Kit Clone includes Acrylic Tank Tube and stainless steel Chimney and Top Cap. The tank tube holds 3.5ml capacity and is suitable for 22mm Dvarw MTL FL Facelift RTA Vape Atomizer. Top Fill Kit is suitable for Dvarw FL MTL 22m RTA allows the user to refill from the top without unscrewing the tank. The top fill kit consists of a new chamber, a acrylic tank, a new top cap and gives the ability of liquid control. ![]() 510 Drip Tip Set $4.59 The 510 Drip Tip Set is suitable for RDA / RTA / RDTA / Sub Tank Vape Atomizer. This 510 drip tip set comes 2 PCS 510 connector base, 3 PCS mouthpiece. You can combine them with different shape and color drip tips.
753
Vaporesso Forz Tank 25 Clearomizer Vape Atomizer $22.99
The Original Vaporesso FORZ Tank 25 Vape Atomizer is a new maintenance-free sub-ohm tank with a protective metal frame and silicone sanitary cover. With 4.5ml e-juice capacity and replaceable coil system. The easy-to-tighten top filling system is easy to use. In this system, up to 4.5ml of e-liquid can be filled through the exposed double fill port and prevent leakage. The top drip tip type of Vaporesso FORZ Tank 25 is 510, covered with a silicone cover, and there is a traditional airflow adjustment ring at the bottom. A pair of replaceable coils are included in the package, below sub-ohm. This is a new coil production line called GTR Coil Series. It with anti-bacteria organic cotton, larger airway, and an updated leak-proof structure, it will bring great flavor consistently for you. In addition, the airflow is heated by the infinitely adjustable bottom airflow through the GTR coil, thereby raising the production of aroma and steam to a new level. ![]() Augvape DRUGA 2 BF RDA original price $34.99, now only $23.99 The Original Augvape DRUGA 2 24mm RDA, featuring revised Clamp Snag System build deck bundled in a visually striking aesthetic. Constructed from superior 304 Stainless steel, the chassis is well constructed and visually striking. Implemented within the build deck is an upgraded clamp snag system to maintain ease of building, accommodating a single or dual coil configuration. In addition, the top cap features a dual sided airflow control, offering control over airflow intake. At the bottom is a threaded 510 connection to facilitate connectivity through a swappable gold plated pin or bottom feeder squonk pin, allowing e-Juice to travel through the bottom from your favorite squonk mod. ![]() Voopoo Drag Max 177W Pod System Kit $49.99 The Original VOOPOO Drag Max is made of soft leather and cold tough metal, ergonomic size, the collision of leather and metal brings a luxurious, comfortable, and durable holding experience. DRAG Max is powered by two external 18650 batteries to provide long-term standby energy (batteries not included). And equipped with a fast-charging system, 5V / 2A Type-C fast charging can increase the charging speed by 50%. Stay powered for all-day long. The core innovative design of Drag Max uses the flagship GENE.FAN 2.0 chip, which has stronger explosive power, more stable output, and more intelligent functions. Provides a maximum power output of 177W, 0.001s extreme ignition, dynamic stable output, SMART and RBA modes, and comprehensive safety protection functions. In addition, Drag Max is equipped with a 1.08-inch TFT color screen for a clear display of various vape data and designed two different styles of UI themes. At the same time, press "+" and "-" to enter the UI switching interface. ![]() 510 Drip Tip $1.99 The 510 Drip Tip is made from POM and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer.
754
Original IJOY Aria Pod System Kit original price $29.99, now only $20.99
The Original IJOY Aria Pod System Vape Starter Kit is a compact box-shaped pod system kit with an ultra-portable design and a square appearance. It is made of zinc alloy and has excellent durability and can also bring you super flavor. For such a small pod system, IJOY Aria is built-in 900mAh battery. With the Type-C USB charging port, you can quickly charge the battery within 60 minutes and long-lasting vape. IJOY Aria pod kit runs on a proprietary UNIV.mini board with IFTT (IJoyLAB Flavor Testing Technology), which can provide up to 22 watts of power, which is sufficient for such a compact device and has intelligent automatic matching technology and a variety of safety protection functions. You can turn it on and off by pressing the ignition button five times. When you press it three times, you can switch the current output mode: Low 3.4V / Medium 3.5V / High 3.6V. Single-key design, easy to operate and safe to use. In addition, the IJOY Aria Pod Kit is equipped with a transparent Pod Cartridge with a capacity of 3.0ml and uses a simple side filling design, no airflow adjustment, and an internal 0.6ohm / 1.0ohm prebuilt coil to bring the best flavor. ![]() Original Vissel X Pod System Kit $25.99 The Original Vissel X Pod System Vape Starter Kit is a brand new and quite different vape pod kit. Vissel X will glow and flash, with a unique breathing light, providing eye-catching vision. This device remains compact while maintaining accurate flavor and ease of use. With a 1200mAh built-in battery, it can meet your daily demand of vaping. Fast charging through the Type-C port at the device connection, providing two ways to activate the device, draw-activated mechanism, and manual button, quickly click the fire button 5 times to turn on / off the device. Are you worried that the device will consume a lot of battery power due to the breathing light? The breathing light on the Vissel X device can lasting to bright, or you can turn it off when you don't need it. Actually Vissel X is more interesting to use! You can change the lantern's pattern by patting the bottom of the device. The Vissel X Pod Kit is equipped with 3.0ml refillable pod cartridge, filling liquid from the side, and has a transparent design for easy viewing. It is compatible with a 1.2ohm regular coil & 0.6ohm mesh coil, gives you better flavor, huge clouds and a smoother throat hit. ![]() Original IJOY Aria Replacement Pod Cartridge with 1.0ohm Coil(3 PCS) original price $9.90, now only $7.99 The Original IJOY Aria Replacement Pod Cartridge is Specially designed for IJOY Aria Pod System Vape Starter Kit. It is made of PCTG material and is a magnetic connection to IJOY Aria Mod firmly. Aria Pod can hold 3.0ml e-juice, with a convenient side e-juice refill design, with the silicone stopper to prevent leaking. The Aria Pod is transparent, which is designed for checking the level of e-liquid in real-time. Comes with 1.0ohm coil, which will bring you pure flavor, suitable for MTL vaping. ![]() Original Vissel X Replacement Empty Pod Cartridge(3 PCS) $4.99 The Original Vissel X Pod Cartridge is a set of Refillable Empty Pod made of PCTG material, cost-effective to use, implementing a 3.0mL side filled capacity. And support airflow adjustment, this pod with airflow valve, pods can be inserted according to the airflow holes of different calibers on the device. In addition, Vissel X Pod Cartridge adopts a highly transparent design to monitor the remaining e-juice level. Moreover, it is compatible 0.6ohm mesh coil and 1.2ohm regular coil (coil not included), plug 'n' play coil installation, suitable for the Vissel X Pod System Vape Starter kit. ![]() Original Vissel X Pod System Replacement Mesh Coil Head(5 PCS) $7.29 The Original Vissel X Replacement Coil is specially designed for Vissel X Pod Kit / Vissel X Pod Cartridge, Comes with 0.6ohm mesh coil. 0.6ohm mesh coil mesh will provide a faster heating process resulting in massive vapor clouds. ![]() Original Vissel X Pod System Replacement Regular Coil Head(5 PCS) $6.69 The Original Vissel X Replacement Coil is specially designed for Vissel X Pod Kit / Vissel X Pod Cartridge, Comes with 1.2ohm regular coil, the 1.2ohm regular coil allowing users to enjoy a satisfying throat hit similar to the sensation that comes with the use of combustibles. ![]() Original SXK Supbox Replacement Mesh Coil Head(5 PCS) $12.90 The Original SXK Mesh Coil Head is with 1.1ohm resistance and supports 10W to 15W. It is suitable for authentic SXK Supbox Box Mod Kit.
755
Original Eleaf iStick S80 80W Box Mod $37.74
Original Eleaf iStick S80 Vape Box Mod is compatible with iStick S80 Kit and GZeno Tank. It innovatively applies the intrecciato design to the metallic finish, bringing unprecedented texture and comfortable hand feeling. Powered by 1800mAh internal battery, it can fire up to 80W max output power. And it utilizes Type-C 2A fast and safe charging port. Besides, it supports 2 modes: Smart Mode, which will adjust the output automatically according to coil resistance, and Power Mode, which allows you to enjoy freely adjustment. And it is equipped with a 0.96-inch screen to show clear information and provide convenient operation. Moreover, it is designed with multiple protections to ensure your safety. ![]() Original Eleaf GZeno Tank Clearomizer Vape Atomizer $29.99 Original Eleaf GZeno Tank holds 3.0ml e-juice capacity and comes with GZ 1.2ohm Coil for MTL vaping. It features convenient top filling system and easy coil replacing. GZeno Tank is designed with 5 airflow holes, which will provide you precise airflow adjustment. ![]() Lost Vape Thelema 80W Pod System Mod Kit original price $49.99, now only $35.99 The Original Lost Vape Thelema Pod System Vape Mod Kit is a pod mod kit that equipped with the proprietary Quest chip. It is powered by 3000mAh built-in battery with 80W max power, which will satisfy your all-day vape demand. Designed with type-c 2A charging port. the charging is proper fast, reversible and powerful. Thelema Kit also comes with a 4ml visual pod Cartridge. The pod Cartridge is built with top filling and plug-play coil replacing. Besides, it features dual-channel airflow and adjustable airflow. There are six theme colors for you, you can enjoy the colorful theme and see the crucial data with a 0.96 inch TFT color screen. ![]() Asvape Hita Ink 40W Pod System Kit original price $36.00, now only $26.99 Original Asvape Hita Ink Pod System Vape Mod Kit inherits the classic style of Asvape strider. Asvape Hita Ink Pod Kit is powered by built-in 1500mAh battery with adjustable wattage of 5~40W. Asvape Hita Ink features self-developed ReekBox chip to identify the coil resistance and match the power automatically and OLED screen to display the detailed vaping data. Asvape Hita Ink Pod cartridge has 5.0ml capacity and 0.3ohm mesh coil for DTL vaping, 1.0ohm for MTL vaping. ![]() Original Eleaf iStick S80 80W Box Mod Kit $56.90 The Original Eleaf iStick S80 Mod Kit applies the intrecciato design to the metallic finish, bringing unprecedented texture and luxury. With metallic and compact design, it will give you the most solid and comfortable hand feeling. Powered by 1800mAh built-in battery, it can fire up to 80W max output. And charged via safe and reliable Type-C 2A fast port, it also helps you save time. In addition, there are 2 modes available: Smart Mode and Power Mode. Besides, it is compatible with 3.0ml GZeno Tank, which comes with GZ 1.2ohm coil for MTL vaping and pure flavor. And it adopts convenient top filling and precise airflow adjustment with 5 airflow holes. ![]() Original Lost Vape Thelema Replacement Empty Pod Cartridge(1 PC) $3.99 The Original Lost Vape Thelema Pod System Replacement Empty Pod Cartridge holds 4.0ml, empty pod cartridge only, without coils. 1 PC / Pack ![]() Original Eleaf GZ Coil Head for Eleaf GZeno Tank / Eleaf iStick S80 Kit(3 PCS) $8.99 The Original Eleaf GZ Coil is designed for MTL vaping. It can be applied to GZeno Tank and iStick S80 Vape Mod Kit. The coil resistance is 1.2ohm. GZ Coil is easy to replace and will offer you the best pure flavor.
756
Decorative Beauty Ring $1.99
The Replacement Decorative Beauty Ring is designed for 22mm RTA / RDA / RTA / RDTA Vape Atomizer, which is made of Stainless Steel and has 22mm inner diameter and 24mm outer diameter. ![]() 510 Drip Tip $1.99 The 510 Drip Tip is made from POM & stainless steel and is suitable for RDA / RTA / RDTA / Sub Ohm Tank Vape Atomizer. ![]() Timesvape Wave Mini Replacement Ceramic Coil Head(5 PCS) $7.99 The Original Timesvape Wave Mini Mod Kit Replacement Ceramic Coil Head is with 1.2ohm resistance and comes with 5 PCS / Pack. ![]() Asvape Vulcan Replacement Empty Pod Cartridge(3 PCS) $8.99 The Original Asvape Vulcan Pod System Replacement Empty Pod Cartridge holds 1.5ml capacity and with 1.2ohm resistance coil. ![]() [Ships from Battery Warehouse] Original Golisi S11 18350 3.7V 1100mAh 10A Battery for Mechanical Mod / VW Mod(2 PCS) $10.99 The Original Golisi S11 18350 3.7V 1100mAh 10A Battery is suitable for Mechanical Mod / VW Mod. The battery is with safety protection: S11 has a protection mechanism. It stops working immediately and permanently when short-circuited, no worries of flame or leaking.
757
Vapeasy Sprint BF RDA Clone $14.99
The Vapeasy Sprint BF RDA Rebuildable Dripping Vape Atomizer Clone is made from 316 stainless steel and comes with white POM 510 drip tip. The Sprint BF RDA Clone is with dual-pole for single coil building. Comes with BF pin, it is ready for Bottom Feeder / Squonker Mod. ![]() SMOKTech SMOK Novo 3 Pod System Kit $27.99 Original SMOKTech SMOK Novo 3 25W Pod System Vape Kit has the same lightweight and compact size and provides Carbon Fiber and IML series color options. Compared with Novo 2 and Novo X, the upgrade of Novo 3 is subtle, with updated airflow and advanced draw activation. It redesigned sensing elements, also newly added air-intake grooves on both sides, while has the same 800mAh integrated battery and 6~25W output power range. There is an integrated LED indicator on the front of the device and a micro USB port on the bottom. There is no ignition button on Novo 3. Instead, it integrates a redesigned air-sensing system. In addition, Novo 3 also provides a variety of protection measures to ensure the stable operation of the device. ![]() Auguse Draw RTA Pod Cartridge Replacement Tank Tube for Voopoo Drag S / X $2.99 The Original Auguse Draw RTA Pod Cartridge Replacement Tank Tube is made from acrylic and holds 4.5ml. It is compatible with Auguse Draw RTA Pod Cartridge for Voopoo Drag S / X Pod System.
758
Stratum Balance 60W Box Mod Clone $63.99
The Stratum Balance 60W TC VW Vape Box Mod Clone is made from Black PC and Stainless Steel and powered by 1 x 18350 / 18650 battery (not included). The Box Mod is Compatible with 24mm diameter vape atomizer. The chip is the same as the Ambition Easy Box Mod and supports max. 60W output. ![]() Shanlaan Laan Ripple Pod System Kit $24.99 Original Shanlaan Laan Ripple Pod System Mod Kit is with an ultra-portable, and compact design, the overall appearance is like a fountain pen, balances the ratio of toughness and lightweight, making it extremely portable with high quality. The device shell adopts a delicate ripple finishing, enjoy vape in a simple, fluent, and beginner-friendly way. Despite its small size, Shanlaan Laan Ripple is equipped with a 500mAh internal battery and uses a C-type charging port, which will output max 11W. It adopts a draw-activated firing mechanism, free of any buttons or screens, and comes with a 3-Level battery indicator. The Shanlaan Laan Ripple comes with a 1.4ml refillable pod and offering an integrated coil design that is side filled for a leak-free experience. The pod utilizes an integrated 1.0ohm dual coil head to vaporize your favorite e-juice or nicotine salts, providing optimal flavors to vapers. In addition, Laan Ripple pod uses a duck beak style mouthpiece design to perfectly fit the lips. ![]() SMOKTech SMOK Novo 3 Replacement Pod Cartridge(3 PCS) $8.99 The Original SMOKTech SMOK Novo 3 Pod Cartridge is specially designed for SMOK Novo 3 Pod System Kit. It has a 2.0ml capacity, features a side-fill system, and has a 0.8ohm mesh integrated coil inside. This coil is combined with organic cotton to provide the best vapor generation and flavor enhancement. The Novo 3 Mesh 0.8ohm Pod is ideal for vapers looking for a dense and full drag that produces massive clouds. Additionally, the pod has an ergonomically designed mouthpiece to give you a more comfortable vaping experience.
759
Lost Vape Grus 100W Box Mod original price $49.99, now only $34.99
Original Lost Vape Grus 100W Vape Box Mod is powered by single 21700/ 20700/ 18650 battery (not included) with max 100W output. Lost Vape Grus mod features 0.96 inch color screen to show the vaping data clearly. Lost Vape Grus Box Mod can support VW / TC modes and is compatible with up to 30mm diameter tanks vape atomizer. ![]() Gas Mods Pallas MTL RTA original price $39.69, now only $26.99 The Original Gas Mods Pallas MTL RTA supports single coil deck and provides 6 size airflow control. The Original Gas Mods Pallas MTL RTA 22mm comes with 1 glass tube and another SS + PC tube which can bring you 2 different looks. With the distinct U shape surround airflow system, you will get decent flavor from it. ![]() Hugo Vapor Boxer AIO Pod Mod Kit original price $29.99, now only $22.99 The Original Hugo Vapor Boxer AIO Pod Vape Mod Kit has an adjustable power from 5W to 40W by the 1500mAh built-in battery which will hold a whole day vaping. And you can see all vaping details in 0.91"OELD screen. The Hugo Vapor Boxer AIO kit is equipped with 3.5ml Hugo Vapor Boxer pod which has 0.4ohm mesh coil inside. With special airflow system allowing the user to rotate the installed pod to access a restricted DL or MTL airflow. Featuring 1A Type-C quick charge, the Hugo Vapor Boxer AIO device can be fully charged than 90 minutes.
760
Регистрация: 27.11.2017 Последняя активность: 16.12.2021 19:02
SXK Haku Venna RDA Clone original price $19.90, now only $17.90
The SXK Haku Venna RDA Clone is a low profile 22mm RDA with dual post design for single coil building. Constructed from 316 stainless steel, the RDA adopts sandblasting technology to make it feel smooth on the surface. The air enters the chamber via two different sizes of airholes on both side of the cap, hitting the coil directly. POM drip tip is included. ![]() Artery Cold Steel AK47 Pod System Kit NP Version original price $49.99, now only $37.99 The Original Artery Cold Steel AK47 is the first member of the new Cold Steel Series, ideas generating from the essential part of the well-known rifle AK47. Cold Steel AK47 uses a compact zinc case, decorated in a militaristic style. The narrow control panel is equipped with a set of ergonomic buttons and a monochrome display. The casings on side of the device have air inlets with the rotating gear. The bottom is equipped with a USB port and a ventilation grille. The integrated 1500mAh battery is responsible for the power supply, Cold Steel AK47 ensure you a full day of vaping on the go. Charging should be carried out via USB Type-C with a current of 1.5A. Provides a standard function with a maximum output power of up to 50 watts, and an automatic system for monitoring the liquid in the pod to intelligently avoid dry burning. Artery Cold Steel AK47 NP Pod Cartridge holds up to 4.0ml of e-juice. At the bottom of the pod Cartridge, there are a filling hole and an additional airflow regulator. Airflow adjustment is naturally available and double adjustment. Cold Steel AK47 Pod also supports top drip tip replacement, with two drip tips, one for DTL vaping, and one for MTL vaping. ![]() Artery Cold Steel AIO 120W Pod System Kit RBA Version original price $64.99, now only $43.99 The Original Artery Cold Steel AIO is the most versatile pod mod in the market to cater to all your demand for a pod mod. It is the second member of the new Cold Steel Series, captures its designing features from another renown Desert Eagle, does it remind you of the military dream. Cold Steel AIO has a zinc body and a translucent pod cartridge with accessible filling holes and a 510 drip tip on the top. A fully functional control panel with ergonomic activation buttons, a display, and a pair of adjustment keys are placed on the narrow front side. The USB type-c port is installed at the bottom next to the twist cover of the battery compartment. Cold Steel AIO uses a replaceable battery, which is installed through a threaded bottom cover. The Pod mod is powered by 1 x 18650 / 20700 / 21700 batteries (including a 18650 adapter, batteries not included), RBA Version also comes with a complete 510 adapter, which allows you to use the mod with a conventional atomizer. The equipment has all the necessary safety measures and a patented system that automatically detects the liquid level in the tank to prevent it from burning. The maximum output power is 120 watts. The Artery Cold Steel AIO RBA Pod Cartridge Version holds 2.0ml of e-liquid. The filling port can be opened by sliding up. COLD STEEL AIO RBA Pod Cartridge is compatible with XP RBA that exclusively built for DIY enthusiasm. In addition, Cold Steel AIO supports airflow adjustment, use removable silicone inserts for airflow adjustment. It brings pure taste and dense vapor clouds.
